[U-Boot-Users] cpu/mips/start.S cache config CONF_CM_CACHABLE_NONCOHERENT and CONF_CM_CACHABLE_NO_WA difference
after mips_cache_reset, when i set config as CONF_CM_CACHABLE_NONCOHERENT, the copy u-boot to sdram in relocate_code will not succeed, for every 16 bytes, it only last 4 bytes be correct.
but if i set CONF_CM_CACHABLE_NO_WA after mips_cache_reset, the copy function will work well.but after that, when run in ram, in the line to get u_boot_end label, it can't get the correct value, if i step in with BDI2000, it can run to
la t9,board_init_r jr t9
but the t9 still keep the value (0xbfcxxxx, which was loaded by la t9, board_init_f j t9)
and if i add sync before la t9, board_init_f, it can run into board_init_f, but it load the c functions address not correctly
my questions
1) what the CP0_CONFIG need to set for cache (my core is 4KEC)? 2) i see before the jump to in_ram, there is some comment as follow:
.......... /* If caches were enabled, we would have to flush them here. */
/* Jump to where we've relocated ourselves. */ addi t0, a2, in_ram - _start j t0 nop
does it means if i used mips_cache_lock before, i need to add flush code here ?
zhuzhenhua
