[PATCH] am625x_evm_a53: Tweak boot command to set fdt
With the current config for tha SK-AM62, fdtfile isn't set in the U-Boot environment. When using bootflow to boot from a block device, where the extlinux.conf file specifies `fdtdir`, a fallback device tree is being constructed from the `soc` (`k3`) and `board` (`am62x`) environment variables, resulting in u-Boot trying to retrieve `/dtbs/6.8.1+/k3-am62x.dtb`. This file doesn't exist.
The environment variables `default_device_tree` and `default_device_tree_arch` are set in the config, the `findfdt` script can be called to construct `fdtfile` from the environment variables set by these config options, however this script currently isn't being run.
Calling this script results in the correct device tree being retrieved:
Retrieving file: /dtbs/6.8.1+/ti/k3-am625-sk.dtb
Many boards are calling this script as part of their boot command. The am62x currently isn't. Rectify this so that booting works correctly.
Signed-off-by: Martyn Welch martyn.welch@collabora.com --- configs/am62x_evm_a53_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/am62x_evm_a53_defconfig b/configs/am62x_evm_a53_defconfig index 78287ec18a..e373e44a93 100644 --- a/configs/am62x_evm_a53_defconfig +++ b/configs/am62x_evm_a53_defconfig @@ -30,7 +30,7 @@ CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 CONFIG_BOOTSTD_FULL=y CONFIG_SYS_BOOTM_LEN=0x800000 -CONFIG_BOOTCOMMAND="run envboot; bootflow scan -lb" +CONFIG_BOOTCOMMAND="run findfdt; run envboot; bootflow scan -lb" CONFIG_BOARD_LATE_INIT=y CONFIG_SPL_MAX_SIZE=0x58000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y
Hi Martyn.
Would this also be appropriate to add to the defconfig for other AM62x boards (e.g beagleplay) ?
Anyway, for this device:
Reviewed-by: Christopher Obbard chris.obbard@collabora.com
Thanks!
Chris
On Tue, 2024-03-26 at 14:35 +0000, Christopher Obbard wrote:
Hi Martyn.
Hi Chris,
Probably, but this is the only board I have available to test.
Martyn
Thanks!
Chris
I think this patch will be unneeded after this series goes in:
https://lore.kernel.org/u-boot/20240109191506.3820908-1-nm@ti.com/
Andrew
Andrew Davis
Christopher Obbard
Martyn Welch
