[U-Boot-Users] [PATCH 06/30] disk/: Remove obsolete references to CONFIG_COMMANDS
Signed-off-by: Jon Loeliger jdl@freescale.com --- disk/part.c | 26 +++++++++++++------------- disk/part_amiga.c | 6 +++--- disk/part_dos.c | 8 ++++---- disk/part_iso.c | 8 ++++---- disk/part_mac.c | 8 ++++---- 5 files changed, 28 insertions(+), 28 deletions(-)
diff --git a/disk/part.c b/disk/part.c index 0d6477d..b0c909c 100644 --- a/disk/part.c +++ b/disk/part.c @@ -34,9 +34,9 @@ #define PRINTF(fmt,args...) #endif
-#if ((CONFIG_COMMANDS & CFG_CMD_IDE) || defined(CONFIG_CMD_IDE) || \ - (CONFIG_COMMANDS & CFG_CMD_SCSI) || defined(CONFIG_CMD_SCSI) || \ - (CONFIG_COMMANDS & CFG_CMD_USB) || defined(CONFIG_CMD_USB) || \ +#if (defined(CONFIG_CMD_IDE) || \ + defined(CONFIG_CMD_SCSI) || \ + defined(CONFIG_CMD_USB) || \ defined(CONFIG_MMC) || \ defined(CONFIG_SYSTEMACE) )
@@ -46,13 +46,13 @@ struct block_drvr { };
static const struct block_drvr block_drvr[] = { -#if (CONFIG_COMMANDS & CFG_CMD_IDE) || defined(CONFIG_CMD_IDE) +#if defined(CONFIG_CMD_IDE) { .name = "ide", .get_dev = ide_get_dev, }, #endif -#if (CONFIG_COMMANDS & CFG_CMD_SCSI) || defined(CONFIG_CMD_SCSI) +#if defined(CONFIG_CMD_SCSI) { .name = "scsi", .get_dev = scsi_get_dev, }, #endif -#if ((CONFIG_COMMANDS & CFG_CMD_USB) || defined(CONFIG_CMD_USB)) && defined(CONFIG_USB_STORAGE) +#if defined(CONFIG_CMD_USB) && defined(CONFIG_USB_STORAGE) { .name = "usb", .get_dev = usb_stor_get_dev, }, #endif #if defined(CONFIG_MMC) @@ -86,9 +86,9 @@ block_dev_desc_t *get_dev(char* ifname, int dev) } #endif
@@ -176,9 +176,9 @@ void dev_print (block_dev_desc_t *dev_desc) } #endif /* CFG_CMD_IDE || CFG_CMD_SCSI || CFG_CMD_USB || CONFIG_MMC */
-#if ((CONFIG_COMMANDS & CFG_CMD_IDE) || defined(CONFIG_CMD_IDE) || \ - (CONFIG_COMMANDS & CFG_CMD_SCSI) || defined(CONFIG_CMD_SCSI) || \ - (CONFIG_COMMANDS & CFG_CMD_USB) || defined(CONFIG_CMD_USB) || \ +#if (defined(CONFIG_CMD_IDE) || \ + defined(CONFIG_CMD_SCSI) || \ + defined(CONFIG_CMD_USB) || \ defined(CONFIG_MMC) || \ (defined(CONFIG_MMC) && defined(CONFIG_LPC2292)) || \ defined(CONFIG_SYSTEMACE) ) @@ -331,4 +331,4 @@ void print_part (block_dev_desc_t * dev_desc) # error nor CONFIG_ISO_PARTITION configured! #endif
-#endif /* (CONFIG_COMMANDS & CFG_CMD_IDE) || CONFIG_COMMANDS & CFG_CMD_SCSI) */ +#endif diff --git a/disk/part_amiga.c b/disk/part_amiga.c index d55249f..6c3d748 100644 --- a/disk/part_amiga.c +++ b/disk/part_amiga.c @@ -26,9 +26,9 @@ #include <ide.h> #include "part_amiga.h"
-#if ((CONFIG_COMMANDS & CFG_CMD_IDE) || defined(CONFIG_CMD_IDE) || \ - (CONFIG_COMMANDS & CFG_CMD_SCSI) || defined(CONFIG_CMD_SCSI) || \ - (CONFIG_COMMANDS & CFG_CMD_USB) || defined(CONFIG_CMD_USB) || \ +#if (defined(CONFIG_CMD_IDE) || \ + defined(CONFIG_CMD_SCSI) || \ + defined(CONFIG_CMD_USB) || \ defined(CONFIG_MMC) || \ defined(CONFIG_SYSTEMACE) ) && defined(CONFIG_AMIGA_PARTITION)
diff --git a/disk/part_dos.c b/disk/part_dos.c index b13f426..4707f80 100644 --- a/disk/part_dos.c +++ b/disk/part_dos.c @@ -35,9 +35,9 @@ #include <ide.h> #include "part_dos.h"
-#if ((CONFIG_COMMANDS & CFG_CMD_IDE) || defined(CONFIG_CMD_IDE) || \ - (CONFIG_COMMANDS & CFG_CMD_SCSI) || defined(CONFIG_CMD_SCSI) || \ - (CONFIG_COMMANDS & CFG_CMD_USB) || defined(CONFIG_CMD_USB) || \ +#if (defined(CONFIG_CMD_IDE) || \ + defined(CONFIG_CMD_SCSI) || \ + defined(CONFIG_CMD_USB) || \ defined(CONFIG_MMC) || \ defined(CONFIG_SYSTEMACE) ) && defined(CONFIG_DOS_PARTITION)
@@ -248,4 +248,4 @@ int get_partition_info_dos (block_dev_desc_t *dev_desc, int part, disk_partition }
-#endif /* (CONFIG_COMMANDS & CFG_CMD_IDE) && CONFIG_DOS_PARTITION */ +#endif diff --git a/disk/part_iso.c b/disk/part_iso.c index 8d52097..06dd75e 100644 --- a/disk/part_iso.c +++ b/disk/part_iso.c @@ -25,9 +25,9 @@ #include <command.h> #include "part_iso.h"
-#if ((CONFIG_COMMANDS & CFG_CMD_IDE) || defined(CONFIG_CMD_IDE) || \ - (CONFIG_COMMANDS & CFG_CMD_SCSI) || defined(CONFIG_CMD_SCSI) || \ - (CONFIG_COMMANDS & CFG_CMD_USB) || defined(CONFIG_CMD_USB) || \ +#if (defined(CONFIG_CMD_IDE) || \ + defined(CONFIG_CMD_SCSI) || \ + defined(CONFIG_CMD_USB) || \ defined(CONFIG_MMC) || \ defined(CONFIG_SYSTEMACE) ) && defined(CONFIG_ISO_PARTITION)
@@ -257,4 +257,4 @@ int test_part_iso (block_dev_desc_t *dev_desc) return(get_partition_info_iso_verb(dev_desc,0,&info,0)); }
-#endif /* ((CONFIG_COMMANDS & CFG_CMD_IDE) || (CONFIG_COMMANDS & CFG_CMD_SCSI)) && defined(CONFIG_ISO_PARTITION) */ +#endif diff --git a/disk/part_mac.c b/disk/part_mac.c index 441f03b..d303a73 100644 --- a/disk/part_mac.c +++ b/disk/part_mac.c @@ -34,9 +34,9 @@ #include <ide.h> #include "part_mac.h"
-#if ((CONFIG_COMMANDS & CFG_CMD_IDE) || defined(CONFIG_CMD_IDE) || \ - (CONFIG_COMMANDS & CFG_CMD_SCSI) || defined(CONFIG_CMD_SCSI) || \ - (CONFIG_COMMANDS & CFG_CMD_USB) || defined(CONFIG_CMD_USB) || \ +#if (defined(CONFIG_CMD_IDE) || \ + defined(CONFIG_CMD_SCSI) || \ + defined(CONFIG_CMD_USB) || \ defined(CONFIG_MMC) || \ defined(CONFIG_SYSTEMACE) ) && defined(CONFIG_MAC_PARTITION)
@@ -251,4 +251,4 @@ int get_partition_info_mac (block_dev_desc_t *dev_desc, int part, disk_partition return (0); }
-#endif /* (CONFIG_COMMANDS & CFG_CMD_IDE) && CONFIG_MAC_PARTITION */ +#endif
Jon Loeliger
