[PATCH] arm: dts: kirkwood: Enable upstream DT on Kirkwood boards
Enable OF_UPSTREAM to use upstream DT and add marvell/ prefix to the DEFAULT_DEVICE_TREE for Kirkwood boards. And so we can directly build DTBs from dts/upstream/src/arm/marvell, and including *-u-boot.dtsi files from arch/arm/dts/ directory.
Background:
Hi Stefan, Hi Michael,
I did a survey and we currently have 28 Kirkwood boards. Using some commands and filters, here are the finding.
git grep -li arch_kirkwood configs | xargs grep DEVICE_TREE | cut -d '"' -f2 | xargs -n1 sh -c 'diff -qs arch/arm/dts/$1.dts dts/upstream/src/arm/marvell/$1.dts' sh | grep differ
diff: dts/upstream/src/arm/marvell/kirkwood-atl-sbx81lifkw.dts: No such file or directory diff: dts/upstream/src/arm/marvell/kirkwood-atl-sbx81lifxcat.dts: No such file or directory
Files arch/arm/dts/kirkwood-dockstar.dts and dts/upstream/src/arm/marvell/kirkwood-dockstar.dts differ Files arch/arm/dts/kirkwood-dreamplug.dts and dts/upstream/src/arm/marvell/kirkwood-dreamplug.dts differ Files arch/arm/dts/kirkwood-goflexnet.dts and dts/upstream/src/arm/marvell/kirkwood-goflexnet.dts differ Files arch/arm/dts/kirkwood-guruplug-server-plus.dts and dts/upstream/src/arm/marvell/kirkwood-guruplug-server-plus.dts differ Files arch/arm/dts/kirkwood-iconnect.dts and dts/upstream/src/arm/marvell/kirkwood-iconnect.dts differ Files arch/arm/dts/kirkwood-net2big.dts and dts/upstream/src/arm/marvell/kirkwood-net2big.dts differ Files arch/arm/dts/kirkwood-ns2max.dts and dts/upstream/src/arm/marvell/kirkwood-ns2max.dts differ Files arch/arm/dts/kirkwood-ns2mini.dts and dts/upstream/src/arm/marvell/kirkwood-ns2mini.dts differ Files arch/arm/dts/kirkwood-nsa310s.dts and dts/upstream/src/arm/marvell/kirkwood-nsa310s.dts differ Files arch/arm/dts/kirkwood-nsa325.dts and dts/upstream/src/arm/marvell/kirkwood-nsa325.dts differ Files arch/arm/dts/kirkwood-openrd-client.dts and dts/upstream/src/arm/marvell/kirkwood-openrd-client.dts differ
diff -qrbu arch/arm/dts/ dts/upstream/src/arm/marvell/ | grep kirkwood | grep ".dtsi "
Files arch/arm/dts/kirkwood-6192.dtsi and dts/upstream/src/arm/marvell/kirkwood-6192.dtsi differ Files arch/arm/dts/kirkwood-6281.dtsi and dts/upstream/src/arm/marvell/kirkwood-6281.dtsi differ Files arch/arm/dts/kirkwood-98dx4122.dtsi and dts/upstream/src/arm/marvell/kirkwood-98dx4122.dtsi differ Files arch/arm/dts/kirkwood-dnskw.dtsi and dts/upstream/src/arm/marvell/kirkwood-dnskw.dtsi differ Files arch/arm/dts/kirkwood.dtsi and dts/upstream/src/arm/marvell/kirkwood.dtsi differ Files arch/arm/dts/kirkwood-lsxl.dtsi and dts/upstream/src/arm/marvell/kirkwood-lsxl.dtsi differ Files arch/arm/dts/kirkwood-nsa3x0-common.dtsi and dts/upstream/src/arm/marvell/kirkwood-nsa3x0-common.dtsi differ Files arch/arm/dts/kirkwood-synology.dtsi and dts/upstream/src/arm/marvell/kirkwood-synology.dtsi differ
And after reviewing these differences, the following are my observation.
OF_LIST is not used in these Kirkwood boards.
1. Boards that have only u-boot DTS that should be opt-out for now with "#CONFIG_OF_UPSTREAM is not set"
2. DTS and DTSI files that have only cosmetic, style, or binding changes (safe to take)
Files arch/arm/dts/kirkwood-dockstar.dts and dts/upstream/src/arm/marvell/kirkwood-dockstar.dts differ Files arch/arm/dts/kirkwood-goflexnet.dts and dts/upstream/src/arm/marvell/kirkwood-goflexnet.dts differ Files arch/arm/dts/kirkwood-guruplug-server-plus.dts and dts/upstream/src/arm/marvell/kirkwood-guruplug-server-plus.dts differ Files arch/arm/dts/kirkwood-iconnect.dts and dts/upstream/src/arm/marvell/kirkwood-iconnect.dts differ Files arch/arm/dts/kirkwood-net2big.dts and dts/upstream/src/arm/marvell/kirkwood-net2big.dts differ Files arch/arm/dts/kirkwood-ns2max.dts and dts/upstream/src/arm/marvell/kirkwood-ns2max.dts differ Files arch/arm/dts/kirkwood-ns2mini.dts and dts/upstream/src/arm/marvell/kirkwood-ns2mini.dts differ Files arch/arm/dts/kirkwood-nsa325.dts and dts/upstream/src/arm/marvell/kirkwood-nsa325.dts differ Files arch/arm/dts/kirkwood-openrd-client.dts and dts/upstream/src/arm/marvell/kirkwood-openrd-client.dts differ
Files arch/arm/dts/kirkwood-dnskw.dtsi and dts/upstream/src/arm/marvell/kirkwood-dnskw.dtsi differ Files arch/arm/dts/kirkwood.dtsi and dts/upstream/src/arm/marvell/kirkwood.dtsi differ Files arch/arm/dts/kirkwood-synology.dtsi and dts/upstream/src/arm/marvell/kirkwood-synology.dtsi differ
3. DTS files that are newer in upstream (safe to take with regression test)
4. DTSI files that have additional PCI-related bindings in upstream (safe to take with regression test)
5. DTSI files that will need new or modified -u-boot.dtsi
Files arch/arm/dts/kirkwood-dreamplug.dts and dts/upstream/src/arm/marvell/kirkwood-dreamplug.dts differ Files arch/arm/dts/kirkwood-lsxl.dtsi and dts/upstream/src/arm/marvell/kirkwood-lsxl.dtsi differ Files arch/arm/dts/kirkwood-nsa3x0-common.dtsi and dts/upstream/src/arm/marvell/kirkwood-nsa3x0-common.dtsi differ
So these u-boot.dtsi files need to be created/modified so we can use upstream DTS/DTSI:
modified: arch/arm/dts/kirkwood-lschlv2-u-boot.dtsi modified: arch/arm/dts/kirkwood-lsxhl-u-boot.dtsi
new file: arch/arm/dts/kirkwood-dreamplug-u-boot.dtsi new file: arch/arm/dts/kirkwood-nsa325-u-boot.dtsi
I've regression tested this patch with the Zyxel NSA325 (Kirkwood 88F6282) and Zyxel NSA310S (Kirkwood 88F6281). The Zyxel NSA325 board has a USB 3.0 controller attached to the PCIe bus. And the Zyxel NSA310S has an extensive overhaul in bindings and styles in upstream DTS version.
Signed-off-by: Tony Dinh mibodhi@gmail.com ---
arch/arm/dts/kirkwood-dreamplug-u-boot.dtsi | 7 +++++++ arch/arm/dts/kirkwood-lschlv2-u-boot.dtsi | 6 ++++-- arch/arm/dts/kirkwood-lsxhl-u-boot.dtsi | 6 ++++-- arch/arm/dts/kirkwood-nsa325-u-boot.dtsi | 7 +++++++ arch/arm/mach-kirkwood/Kconfig | 4 ++++ configs/SBx81LIFKW_defconfig | 1 + configs/SBx81LIFXCAT_defconfig | 1 + configs/d2net_v2_defconfig | 2 +- configs/dns325_defconfig | 2 +- configs/dockstar_defconfig | 2 +- configs/dreamplug_defconfig | 2 +- configs/ds109_defconfig | 2 +- configs/goflexhome_defconfig | 2 +- configs/guruplug_defconfig | 2 +- configs/ib62x0_defconfig | 2 +- configs/iconnect_defconfig | 2 +- configs/inetspace_v2_defconfig | 2 +- configs/lschlv2_defconfig | 2 +- configs/lsxhl_defconfig | 2 +- configs/nas220_defconfig | 2 +- configs/net2big_v2_defconfig | 2 +- configs/netspace_lite_v2_defconfig | 2 +- configs/netspace_max_v2_defconfig | 2 +- configs/netspace_mini_v2_defconfig | 2 +- configs/netspace_v2_defconfig | 2 +- configs/nsa310s_defconfig | 2 +- configs/nsa325_defconfig | 2 +- configs/openrd_base_defconfig | 2 +- configs/openrd_client_defconfig | 2 +- configs/openrd_ultimate_defconfig | 2 +- configs/pogo_e02_defconfig | 2 +- configs/pogo_v4_defconfig | 2 +- configs/sheevaplug_defconfig | 2 +- 33 files changed, 54 insertions(+), 30 deletions(-) create mode 100644 arch/arm/dts/kirkwood-dreamplug-u-boot.dtsi create mode 100644 arch/arm/dts/kirkwood-nsa325-u-boot.dtsi
diff --git a/arch/arm/dts/kirkwood-dreamplug-u-boot.dtsi b/arch/arm/dts/kirkwood-dreamplug-u-boot.dtsi new file mode 100644 index 0000000000..59f19a211f --- /dev/null +++ b/arch/arm/dts/kirkwood-dreamplug-u-boot.dtsi @@ -0,0 +1,7 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/ { + aliases { + spi0 = &spi0; + }; +}; diff --git a/arch/arm/dts/kirkwood-lschlv2-u-boot.dtsi b/arch/arm/dts/kirkwood-lschlv2-u-boot.dtsi index 7fc2d7d3b4..cf33ff822e 100644 --- a/arch/arm/dts/kirkwood-lschlv2-u-boot.dtsi +++ b/arch/arm/dts/kirkwood-lschlv2-u-boot.dtsi @@ -1,7 +1,9 @@ // SPDX-License-Identifier: GPL-2.0+
-ð0 { - status = "disabled"; +/ { + aliases { + spi0 = &spi0; + }; };
&hdd_power { diff --git a/arch/arm/dts/kirkwood-lsxhl-u-boot.dtsi b/arch/arm/dts/kirkwood-lsxhl-u-boot.dtsi index 7fc2d7d3b4..cf33ff822e 100644 --- a/arch/arm/dts/kirkwood-lsxhl-u-boot.dtsi +++ b/arch/arm/dts/kirkwood-lsxhl-u-boot.dtsi @@ -1,7 +1,9 @@ // SPDX-License-Identifier: GPL-2.0+
&hdd_power { diff --git a/arch/arm/dts/kirkwood-nsa325-u-boot.dtsi b/arch/arm/dts/kirkwood-nsa325-u-boot.dtsi new file mode 100644 index 0000000000..dec27b2a87 --- /dev/null +++ b/arch/arm/dts/kirkwood-nsa325-u-boot.dtsi @@ -0,0 +1,7 @@ +// SPDX-License-Identifier: GPL-2.0+ + +&nand { + partition@0 { + /delete-property/ read-only; + }; +}; diff --git a/arch/arm/mach-kirkwood/Kconfig b/arch/arm/mach-kirkwood/Kconfig index c2fff84a68..39593c83d0 100644 --- a/arch/arm/mach-kirkwood/Kconfig +++ b/arch/arm/mach-kirkwood/Kconfig @@ -28,6 +28,10 @@ config CUSTOM_SYS_INIT_SP_ADDR depends on HAS_CUSTOM_SYS_INIT_SP_ADDR default 0x5ff000
+config OF_UPSTREAM + bool "Use upstream DTS for Kirkwood boards" + default y + choice prompt "Marvell Kirkwood board select" optional diff --git a/configs/SBx81LIFKW_defconfig b/configs/SBx81LIFKW_defconfig index cc17a8b114..977daf9f09 100644 --- a/configs/SBx81LIFKW_defconfig +++ b/configs/SBx81LIFKW_defconfig @@ -6,6 +6,7 @@ CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_KWD_CONFIG="board/alliedtelesis/SBx81LIFKW/kwbimage.cfg" CONFIG_TEXT_BASE=0x00600000 CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc8012000 +# CONFIG_OF_UPSTREAM is not set CONFIG_TARGET_SBx81LIFKW=y CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0xC0000 diff --git a/configs/SBx81LIFXCAT_defconfig b/configs/SBx81LIFXCAT_defconfig index 0612723298..9bc8614030 100644 --- a/configs/SBx81LIFXCAT_defconfig +++ b/configs/SBx81LIFXCAT_defconfig @@ -6,6 +6,7 @@ CONFIG_ARCH_KIRKWOOD=y CONFIG_SYS_KWD_CONFIG="board/alliedtelesis/SBx81LIFXCAT/kwbimage.cfg" CONFIG_TEXT_BASE=0x00600000 CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc8012000 +# CONFIG_OF_UPSTREAM is not set CONFIG_TARGET_SBx81LIFXCAT=y CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0xC0000 diff --git a/configs/d2net_v2_defconfig b/configs/d2net_v2_defconfig index bb1bcb0aa3..69658a2ba7 100644 --- a/configs/d2net_v2_defconfig +++ b/configs/d2net_v2_defconfig @@ -11,7 +11,7 @@ CONFIG_TARGET_NET2BIG_V2=y CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x70000 CONFIG_ENV_SECT_SIZE=0x10000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-d2net" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-d2net" CONFIG_IDENT_STRING=" D2 v2" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_ENV_ADDR=0x70000 diff --git a/configs/dns325_defconfig b/configs/dns325_defconfig index edfe92c5f3..b85f7cac8e 100644 --- a/configs/dns325_defconfig +++ b/configs/dns325_defconfig @@ -10,7 +10,7 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc8012000 CONFIG_TARGET_DNS325=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0xE0000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-dns325" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-dns325" CONFIG_IDENT_STRING="\nD-Link DNS-325" CONFIG_SYS_LOAD_ADDR=0x800000 # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/dockstar_defconfig b/configs/dockstar_defconfig index 719fa3979e..7b5f19433a 100644 --- a/configs/dockstar_defconfig +++ b/configs/dockstar_defconfig @@ -13,7 +13,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_DOCKSTAR=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0x80000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-dockstar" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-dockstar" CONFIG_IDENT_STRING="\nSeagate FreeAgent DockStar" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_BOOTDELAY=3 diff --git a/configs/dreamplug_defconfig b/configs/dreamplug_defconfig index 02a2635af8..8518eabcb2 100644 --- a/configs/dreamplug_defconfig +++ b/configs/dreamplug_defconfig @@ -13,7 +13,7 @@ CONFIG_TARGET_DREAMPLUG=y CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x100000 CONFIG_ENV_SECT_SIZE=0x10000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-dreamplug" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-dreamplug" CONFIG_IDENT_STRING="\nMarvell-DreamPlug" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_ENV_ADDR=0x100000 diff --git a/configs/ds109_defconfig b/configs/ds109_defconfig index 304c098c99..ef805eca56 100644 --- a/configs/ds109_defconfig +++ b/configs/ds109_defconfig @@ -14,7 +14,7 @@ CONFIG_TARGET_DS109=y CONFIG_ENV_SIZE=0x10000 CONFIG_ENV_OFFSET=0x3D0000 CONFIG_ENV_SECT_SIZE=0x10000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-ds109" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-ds109" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_ENV_ADDR=0x3D0000 # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/goflexhome_defconfig b/configs/goflexhome_defconfig index d577d5807b..53b2ce97e8 100644 --- a/configs/goflexhome_defconfig +++ b/configs/goflexhome_defconfig @@ -13,7 +13,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_GOFLEXHOME=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0xC0000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-goflexnet" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-goflexnet" CONFIG_IDENT_STRING="\nSeagate GoFlex Home" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_BOOTDELAY=3 diff --git a/configs/guruplug_defconfig b/configs/guruplug_defconfig index 7cb649e29c..5371ee403b 100644 --- a/configs/guruplug_defconfig +++ b/configs/guruplug_defconfig @@ -10,7 +10,7 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc8012000 CONFIG_TARGET_GURUPLUG=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0xE0000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-guruplug-server-plus" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-guruplug-server-plus" CONFIG_IDENT_STRING="\nMarvell-GuruPlug" CONFIG_SYS_LOAD_ADDR=0x800000 # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/ib62x0_defconfig b/configs/ib62x0_defconfig index 074384e387..32b0e1c395 100644 --- a/configs/ib62x0_defconfig +++ b/configs/ib62x0_defconfig @@ -10,7 +10,7 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc8012000 CONFIG_TARGET_IB62X0=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0xE0000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-ib62x0" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-ib62x0" CONFIG_IDENT_STRING=" RaidSonic ICY BOX IB-NAS62x0" CONFIG_SYS_LOAD_ADDR=0x800000 # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/iconnect_defconfig b/configs/iconnect_defconfig index f7b74c4662..45ffbd92db 100644 --- a/configs/iconnect_defconfig +++ b/configs/iconnect_defconfig @@ -13,7 +13,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_ICONNECT=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0x80000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-iconnect" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-iconnect" CONFIG_IDENT_STRING=" Iomega iConnect" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_PCI=y diff --git a/configs/inetspace_v2_defconfig b/configs/inetspace_v2_defconfig index 2e8e3f3928..3fa7790d77 100644 --- a/configs/inetspace_v2_defconfig +++ b/configs/inetspace_v2_defconfig @@ -11,7 +11,7 @@ CONFIG_TARGET_NETSPACE_V2=y CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x70000 CONFIG_ENV_SECT_SIZE=0x10000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-is2" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-is2" CONFIG_IDENT_STRING=" IS v2" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_ENV_ADDR=0x70000 diff --git a/configs/lschlv2_defconfig b/configs/lschlv2_defconfig index 99bdbc1483..ad060079a7 100644 --- a/configs/lschlv2_defconfig +++ b/configs/lschlv2_defconfig @@ -15,7 +15,7 @@ CONFIG_ENV_SIZE=0x10000 CONFIG_ENV_OFFSET=0x70000 CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-lschlv2" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-lschlv2" CONFIG_IDENT_STRING=" LS-CHLv2" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_HAS_BOARD_SIZE_LIMIT=y diff --git a/configs/lsxhl_defconfig b/configs/lsxhl_defconfig index bb0a5ddf50..b2d9f0c9d8 100644 --- a/configs/lsxhl_defconfig +++ b/configs/lsxhl_defconfig @@ -16,7 +16,7 @@ CONFIG_ENV_SIZE=0x10000 CONFIG_ENV_OFFSET=0x70000 CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-lsxhl" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-lsxhl" CONFIG_IDENT_STRING=" LS-XHL" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_HAS_BOARD_SIZE_LIMIT=y diff --git a/configs/nas220_defconfig b/configs/nas220_defconfig index f01b26f2df..4ea342a043 100644 --- a/configs/nas220_defconfig +++ b/configs/nas220_defconfig @@ -10,7 +10,7 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc8012000 CONFIG_TARGET_NAS220=y CONFIG_ENV_SIZE=0x10000 CONFIG_ENV_OFFSET=0xA0000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-blackarmor-nas220" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-blackarmor-nas220" CONFIG_IDENT_STRING="\nNAS 220" CONFIG_SYS_LOAD_ADDR=0x800000 # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/net2big_v2_defconfig b/configs/net2big_v2_defconfig index dda627aac6..39cbc3384f 100644 --- a/configs/net2big_v2_defconfig +++ b/configs/net2big_v2_defconfig @@ -12,7 +12,7 @@ CONFIG_NET2BIG_V2=y CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x70000 CONFIG_ENV_SECT_SIZE=0x10000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-net2big" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-net2big" CONFIG_IDENT_STRING=" 2Big v2" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_ENV_ADDR=0x70000 diff --git a/configs/netspace_lite_v2_defconfig b/configs/netspace_lite_v2_defconfig index 742e6205d8..cd416cb150 100644 --- a/configs/netspace_lite_v2_defconfig +++ b/configs/netspace_lite_v2_defconfig @@ -12,7 +12,7 @@ CONFIG_NETSPACE_LITE_V2=y CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x70000 CONFIG_ENV_SECT_SIZE=0x10000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-ns2lite" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-ns2lite" CONFIG_IDENT_STRING=" NS v2 Lite" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_ENV_ADDR=0x70000 diff --git a/configs/netspace_max_v2_defconfig b/configs/netspace_max_v2_defconfig index 7779e6815e..6a3d9296ac 100644 --- a/configs/netspace_max_v2_defconfig +++ b/configs/netspace_max_v2_defconfig @@ -12,7 +12,7 @@ CONFIG_NETSPACE_MAX_V2=y CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x70000 CONFIG_ENV_SECT_SIZE=0x10000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-ns2max" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-ns2max" CONFIG_IDENT_STRING=" NS Max v2" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_ENV_ADDR=0x70000 diff --git a/configs/netspace_mini_v2_defconfig b/configs/netspace_mini_v2_defconfig index 9e3614bb44..e25631b09f 100644 --- a/configs/netspace_mini_v2_defconfig +++ b/configs/netspace_mini_v2_defconfig @@ -12,7 +12,7 @@ CONFIG_NETSPACE_MINI_V2=y CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x70000 CONFIG_ENV_SECT_SIZE=0x10000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-ns2mini" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-ns2mini" CONFIG_IDENT_STRING=" NS v2 Mini" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_ENV_ADDR=0x70000 diff --git a/configs/netspace_v2_defconfig b/configs/netspace_v2_defconfig index 1583a0adb3..b6ac2a8b19 100644 --- a/configs/netspace_v2_defconfig +++ b/configs/netspace_v2_defconfig @@ -12,7 +12,7 @@ CONFIG_NETSPACE_V2=y CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x70000 CONFIG_ENV_SECT_SIZE=0x10000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-ns2" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-ns2" CONFIG_IDENT_STRING=" NS v2" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_ENV_ADDR=0x70000 diff --git a/configs/nsa310s_defconfig b/configs/nsa310s_defconfig index 89d8b18b16..e859a43ffa 100644 --- a/configs/nsa310s_defconfig +++ b/configs/nsa310s_defconfig @@ -13,7 +13,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_NSA310S=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0xE0000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-nsa310s" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-nsa310s" CONFIG_DEBUG_UART_BASE=0xf1012000 CONFIG_DEBUG_UART_CLOCK=166666667 CONFIG_IDENT_STRING="\nZyXEL NSA310S/320S 1/2-Bay Power Media Server" diff --git a/configs/nsa325_defconfig b/configs/nsa325_defconfig index 5da4a002b4..88a890002e 100644 --- a/configs/nsa325_defconfig +++ b/configs/nsa325_defconfig @@ -13,7 +13,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_NSA325=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0xC0000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-nsa325" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-nsa325" CONFIG_IDENT_STRING="\nZyXEL NSA325 2-Bay Power Media Server" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_PCI=y diff --git a/configs/openrd_base_defconfig b/configs/openrd_base_defconfig index 29a14e0927..057dd28dff 100644 --- a/configs/openrd_base_defconfig +++ b/configs/openrd_base_defconfig @@ -11,7 +11,7 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc8012000 CONFIG_TARGET_OPENRD=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0x80000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-openrd-base" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-openrd-base" CONFIG_IDENT_STRING="\nOpenRD-Base" CONFIG_SYS_LOAD_ADDR=0x800000 # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/openrd_client_defconfig b/configs/openrd_client_defconfig index a95a435bdf..05e4292764 100644 --- a/configs/openrd_client_defconfig +++ b/configs/openrd_client_defconfig @@ -12,7 +12,7 @@ CONFIG_TARGET_OPENRD=y CONFIG_BOARD_IS_OPENRD_CLIENT=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0x80000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-openrd-client" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-openrd-client" CONFIG_IDENT_STRING="\nOpenRD-Client" CONFIG_SYS_LOAD_ADDR=0x800000 # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/openrd_ultimate_defconfig b/configs/openrd_ultimate_defconfig index e3f5294ff1..6e13c6eabd 100644 --- a/configs/openrd_ultimate_defconfig +++ b/configs/openrd_ultimate_defconfig @@ -12,7 +12,7 @@ CONFIG_TARGET_OPENRD=y CONFIG_BOARD_IS_OPENRD_ULTIMATE=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0x80000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-openrd-ultimate" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-openrd-ultimate" CONFIG_IDENT_STRING="\nOpenRD-Ultimate" CONFIG_SYS_LOAD_ADDR=0x800000 # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/pogo_e02_defconfig b/configs/pogo_e02_defconfig index e53ccf34c7..880cb20b22 100644 --- a/configs/pogo_e02_defconfig +++ b/configs/pogo_e02_defconfig @@ -13,7 +13,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_POGO_E02=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0xC0000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-pogo_e02" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-pogo_e02" CONFIG_IDENT_STRING="\nPogo E02" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_BOOTDELAY=3 diff --git a/configs/pogo_v4_defconfig b/configs/pogo_v4_defconfig index 95e22b3fef..50046e83b7 100644 --- a/configs/pogo_v4_defconfig +++ b/configs/pogo_v4_defconfig @@ -12,7 +12,7 @@ CONFIG_TEXT_BASE=0x600000 CONFIG_TARGET_POGO_V4=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0xC0000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-pogoplug-series-4" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-pogoplug-series-4" CONFIG_IDENT_STRING="\nPogoplug V4" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_PCI=y diff --git a/configs/sheevaplug_defconfig b/configs/sheevaplug_defconfig index 0af87dc4fb..b673b3f6da 100644 --- a/configs/sheevaplug_defconfig +++ b/configs/sheevaplug_defconfig @@ -13,7 +13,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_SHEEVAPLUG=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0x80000 -CONFIG_DEFAULT_DEVICE_TREE="kirkwood-sheevaplug" +CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-sheevaplug" CONFIG_IDENT_STRING="\nMarvell-Sheevaplug" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_HAS_BOARD_SIZE_LIMIT=y
Hi Tony,
Thanks for taking care.
Tested-by: Michael Walle michael@walle.cc # on lschlv2
lsxl should work too as it is just different in memory and cpu frequency settings.
arch/arm/dts/kirkwood-lschlv2.dts arch/arm/dts/kirkwood-lsxhl.dts
Should be then be removed.
-michael
Hi Michael,
On Fri, Mar 22, 2024 at 2:10 PM Michael Walle michael@walle.cc wrote:
Hi Tony,
Thanks for the lschlv2 review/test! I plan to send a follow-up patch to remove the corresponding DTS and DTSI files.
All the best, Tony
-michael
Hi Tony,
Background:
- Boards that have only u-boot DTS that should be opt-out for now with "#CONFIG_OF_UPSTREAM is not set"
- DTS and DTSI files that have only cosmetic, style, or binding changes (safe to take)
- DTS files that are newer in upstream (safe to take with regression test)
- DTSI files that have additional PCI-related bindings in upstream (safe to take with regression test)
- DTSI files that will need new or modified -u-boot.dtsi
modified: arch/arm/dts/kirkwood-lschlv2-u-boot.dtsi modified: arch/arm/dts/kirkwood-lsxhl-u-boot.dtsi new file: arch/arm/dts/kirkwood-dreamplug-u-boot.dtsi new file: arch/arm/dts/kirkwood-nsa325-u-boot.dtsi
aliases {
spi0 = &spi0;
-ð0 {
aliases {
spi0 = &spi0;
-ð0 {
aliases {
spi0 = &spi0;
+&nand {
partition@0 {
+config OF_UPSTREAM
default y
You don't have to create a new config option here, just add "imply OF_UPSTREAM" for the SoC which you want to switch, something like:
diff --git a/arch/arm/mach-kirkwood/Kconfig b/arch/arm/mach-kirkwood/Kconfig index c2fff84a686..031d4e5ecd3 100644 --- a/arch/arm/mach-kirkwood/Kconfig +++ b/arch/arm/mach-kirkwood/Kconfig @@ -6,10 +6,12 @@ config FEROCEON_88FR131 config KW88F6192 bool select ARCH_VERY_EARLY_INIT + imply OF_UPSTREAM
config KW88F6281 bool select ARCH_VERY_EARLY_INIT + imply OF_UPSTREAM
config SHEEVA_88SV131 bool
-Sumit
Hi Sumit,
On Tue, Mar 26, 2024 at 9:21 PM Sumit Garg sumit.garg@linaro.org wrote:
Hi Tony,
Background:
aliases {
spi0 = &spi0;
-ð0 {
aliases {
spi0 = &spi0;
-ð0 {
aliases {
spi0 = &spi0;
+&nand {
partition@0 {
+config OF_UPSTREAM
default y
imply OF_UPSTREAM
imply OF_UPSTREAM
Thanks! That's a better way indeed. I'll send v2.
All the best, Tony
-Sumit
Michael Walle
Sumit Garg
Tony Dinh
