[U-Boot] [PULL] u-boot-socfpga/master
The following changes since commit a032e0a6aed208977f48e78d2cc497b91543beaf:
travis: give every job a name (2018-08-10 13:50:30 -0400)
git://git.denx.de/u-boot-socfpga.git master
for you to fetch changes up to b0c0a715f90690a7dd4f33cb5b5c21960be26d3c:
arm: socfpga: Fix SYSMGR_FPGAINTF_EMACx bit mask (2018-08-15 12:41:09 +0200)
---------------------------------------------------------------- Ley Foon Tan (1): arm: socfpga: Fix SYSMGR_FPGAINTF_EMACx bit mask
Marek Vasut (20): ARM: socfpga: Register the FPGA on A10 in SPL again ARM: dts: socfpga: Flag reset manager on A10 as pre-reloc ARM: dts: socfpga: Add missing UART resets ARM: dts: socfpga: Fix Arria10 GMAC resets ARM: dts: socfpga: Add missing I2C resets ARM: dts: socfpga: Add i2c alias to A10 SoCDK ARM: socfpga: Enable DM reset framework on A10 ARM: socfpga: Enable DM I2C framework on A10 ARM: socfpga: Zap all the UART handling complexity net: designware: socfpga: Add Arria10 extras ARM: socfpga: Zap unused reset code ARM: socfpga: Remove adhoc ethernet reset and configuration ARM: socfpga: Enable DM ethernet on A10 ARM: socfpga: clk: Obtain handoff base clock via DM ARM: socfpga: clk: Make L4SP and MMC clock calculation Gen5 only ARM: socfpga: clk: Drop unused variables on Arria10 ARM: dts: socfpga: Add u-boot,dm-pre-reloc to necessary clock nodes clk: socfpga: Add initial Arria10 clock driver mmc: socfpga: Add clock framework support ARM: socfpga: clk: Convert to clock framework
Simon Goldschmidt (5): arm: socfpga: fix SPL on gen5 after moving to DM serial arm: socfpga: spl_gen5: clean up malloc_base assignment arm: socfpga: cyclone5: handle debug uart arm: socfpga: fix device trees to work with DM serial arm: socfpga: gen5: combine some init code for SPL and U-Boot
arch/arm/Kconfig | 2 +- arch/arm/dts/socfpga_arria10.dtsi | 32 ++++++++++-- arch/arm/dts/socfpga_arria10_socdk.dtsi | 26 ++++++++++ arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts | 17 ++++++ arch/arm/dts/socfpga_arria5_socdk.dts | 5 ++ arch/arm/dts/socfpga_cyclone5_dbm_soc1.dts | 5 ++ arch/arm/dts/socfpga_cyclone5_de0_nano_soc.dts | 5 ++ arch/arm/dts/socfpga_cyclone5_de10_nano.dts | 5 ++ arch/arm/dts/socfpga_cyclone5_de1_soc.dts | 5 ++ arch/arm/dts/socfpga_cyclone5_is1.dts | 5 ++ arch/arm/dts/socfpga_cyclone5_socdk.dts | 5 ++ arch/arm/dts/socfpga_cyclone5_sockit.dts | 5 ++ arch/arm/dts/socfpga_cyclone5_socrates.dts | 5 ++ arch/arm/dts/socfpga_cyclone5_sr1500.dts | 2 + arch/arm/dts/socfpga_cyclone5_vining_fpga.dts | 5 ++ arch/arm/mach-socfpga/Kconfig | 10 ++++ arch/arm/mach-socfpga/clock_manager.c | 2 + arch/arm/mach-socfpga/clock_manager_arria10.c | 306 ++++++++++++++++++++++++------------------------------------------------------------------------------------ arch/arm/mach-socfpga/include/mach/clock_manager_arria10.h | 6 --- arch/arm/mach-socfpga/include/mach/misc.h | 6 +-- arch/arm/mach-socfpga/include/mach/reset_manager_arria10.h | 4 -- arch/arm/mach-socfpga/include/mach/system_manager_s10.h | 6 +-- arch/arm/mach-socfpga/misc_arria10.c | 176 -------------------------------------------------------------- arch/arm/mach-socfpga/misc_gen5.c | 29 ++++++----- arch/arm/mach-socfpga/reset_manager_arria10.c | 135 ------------------------------------------------ arch/arm/mach-socfpga/spl_a10.c | 9 ++-- arch/arm/mach-socfpga/spl_gen5.c | 44 +++++----------- configs/socfpga_arria10_defconfig | 2 + drivers/clk/Makefile | 1 + drivers/clk/altera/Makefile | 7 +++ drivers/clk/altera/clk-arria10.c | 363 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/mmc/socfpga_dw_mmc.c | 40 ++++++++++---- drivers/net/Kconfig | 8 +++ drivers/net/Makefile | 1 + drivers/net/dwmac_socfpga.c | 143 +++++++++++++++++++++++++++++++++++++++++++++++++++ 35 files changed, 800 insertions(+), 627 deletions(-) create mode 100644 drivers/clk/altera/Makefile create mode 100644 drivers/clk/altera/clk-arria10.c create mode 100644 drivers/net/dwmac_socfpga.c
