[PATCH v3 0/4] mx6cuboxi: enable support for OF_CONTROL and DM in SPL
Make an additional step to add full DM support to mx6cuboxi, including its support for SPL
With this new configuration SPL image is 50 KB, higher than the 38 KB from the previous version, but it still under the 68 KB limit.
Changes in v3: - Cleanup
Changes in v2: - Fix board_boot_order to avoid pointing to a NAND device - Fix board_boot_order to include MMC iomux - Remove unused code
Walter Lozano (4): mx6cuboxi: enable MMC and eMMC in DT for SPL mx6cuboxi: customize board_boot_order to access eMMC mx6cuboxi: enable OF_CONTROL and DM in SPL mx6cuboxi: remove unused code
...qdl-hummingboard2-emmc-som-v15-u-boot.dtsi | 8 ++ board/solidrun/mx6cuboxi/mx6cuboxi.c | 113 ++++++++---------- configs/mx6cuboxi_defconfig | 3 + 3 files changed, 59 insertions(+), 65 deletions(-)
Signed-off-by: Walter Lozano walter.lozano@collabora.com --- .../dts/imx6qdl-hummingboard2-emmc-som-v15-u-boot.dtsi | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/arch/arm/dts/imx6qdl-hummingboard2-emmc-som-v15-u-boot.dtsi b/arch/arm/dts/imx6qdl-hummingboard2-emmc-som-v15-u-boot.dtsi index d302b2e275..400b885e43 100644 --- a/arch/arm/dts/imx6qdl-hummingboard2-emmc-som-v15-u-boot.dtsi +++ b/arch/arm/dts/imx6qdl-hummingboard2-emmc-som-v15-u-boot.dtsi @@ -34,3 +34,11 @@ &usdhc1 { status = "disabled"; }; + +&usdhc2 { + u-boot,dm-pre-reloc; +}; + +&usdhc3 { + u-boot,dm-pre-reloc; +};
Best regards, Stefano Babic
In SPL legacy code only one MMC device is created, based on BOOT_CFG register, which can be either SD or eMMC. In this context board_boot_order return always MMC1 when configure to boot from SD/eMMC. After switching to DM both SD and eMMC devices are created based on the information available on DT, but as board_boot_order only returns MMC1 is not possible to boot from eMMC.
This patch customizes board_boot_order taking into account BOOT_CFG register to point to correct MMC1 / MMC2 device. Additionally, handle IO mux for the desired boot device.
Signed-off-by: Walter Lozano walter.lozano@collabora.com --- board/solidrun/mx6cuboxi/mx6cuboxi.c | 48 ++++++++++++++++++++++++++++ 1 file changed, 48 insertions(+)
diff --git a/board/solidrun/mx6cuboxi/mx6cuboxi.c b/board/solidrun/mx6cuboxi/mx6cuboxi.c index 6a96f9ecdb..cb06b6c46e 100644 --- a/board/solidrun/mx6cuboxi/mx6cuboxi.c +++ b/board/solidrun/mx6cuboxi/mx6cuboxi.c @@ -624,6 +624,54 @@ int board_fit_config_name_match(const char *name) return strcmp(name, tmp_name); }
+void board_boot_order(u32 *spl_boot_list) +{ + struct src *psrc = (struct src *)SRC_BASE_ADDR; + unsigned int reg = readl(&psrc->sbmr1) >> 11; + u32 boot_mode = imx6_src_get_boot_mode() & IMX6_BMODE_MASK; + unsigned int bmode = readl(&src_base->sbmr2); + + /* If bmode is serial or USB phy is active, return serial */ + if (((bmode >> 24) & 0x03) == 0x01 || is_usbotg_phy_active()) { + spl_boot_list[0] = BOOT_DEVICE_BOARD; + return; + } + + switch (boot_mode >> IMX6_BMODE_SHIFT) { + case IMX6_BMODE_SD: + case IMX6_BMODE_ESD: + case IMX6_BMODE_MMC: + case IMX6_BMODE_EMMC: + /* + * Upon reading BOOT_CFG register the following map is done: + * Bit 11 and 12 of BOOT_CFG register can determine the current + * mmc port + * 0x1 SD2 + * 0x2 SD3 + */ + + reg &= 0x3; /* Only care about bottom 2 bits */ + switch (reg) { + case 1: + SETUP_IOMUX_PADS(usdhc2_pads); + spl_boot_list[0] = BOOT_DEVICE_MMC1; + break; + case 2: + SETUP_IOMUX_PADS(usdhc3_pads); + spl_boot_list[0] = BOOT_DEVICE_MMC2; + break; + } + break; + default: + /* By default use USB downloader */ + spl_boot_list[0] = BOOT_DEVICE_BOARD; + break; + } + + /* As a last resort, use serial downloader */ + spl_boot_list[1] = BOOT_DEVICE_BOARD; +} + #ifdef CONFIG_SPL_BUILD #include <asm/arch/mx6-ddr.h> static const struct mx6dq_iomux_ddr_regs mx6q_ddr_ioregs = {
In SPL legacy code only one MMC device is created, based on BOOT_CFG register, which can be either SD or eMMC. In this context board_boot_order return always MMC1 when configure to boot from SD/eMMC. After switching to DM both SD and eMMC devices are created based on the information available on DT, but as board_boot_order only returns MMC1 is not possible to boot from eMMC. This patch customizes board_boot_order taking into account BOOT_CFG register to point to correct MMC1 / MMC2 device. Additionally, handle IO mux for the desired boot device. Signed-off-by: Walter Lozano walter.lozano@collabora.com
In order to take the beneficts of DT and DM in SPL, like reusing the code and avoid redundancy, enable SPL_OF_CONTROL, SPL_DM and SPL_DM_MMC.
Signed-off-by: Walter Lozano walter.lozano@collabora.com --- configs/mx6cuboxi_defconfig | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/configs/mx6cuboxi_defconfig b/configs/mx6cuboxi_defconfig index df7e4611a0..e2bcaed89f 100644 --- a/configs/mx6cuboxi_defconfig +++ b/configs/mx6cuboxi_defconfig @@ -25,6 +25,7 @@ CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="if hdmidet; then usb start; setenv stdin serial,usbkbd; setenv stdout serial,vga; setenv stderr serial,vga; else setenv stdin serial; setenv stdout serial; setenv stderr serial; fi;" CONFIG_BOUNCE_BUFFER=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y @@ -37,6 +38,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx6dl-hummingboard2-emmc-som-v15" CONFIG_OF_LIST="imx6dl-hummingboard2-emmc-som-v15 imx6q-hummingboard2-emmc-som-v15" CONFIG_MULTI_DTB_FIT=y @@ -45,6 +47,7 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y +CONFIG_SPL_DM=y CONFIG_DWC_AHSATA=y CONFIG_DM_MMC=y CONFIG_FSL_USDHC=y
In order to take the beneficts of DT and DM in SPL, like reusing the code and avoid redundancy, enable SPL_OF_CONTROL, SPL_DM and SPL_DM_MMC. With this new configuration SPL image is 50 KB, higher than the 38 KB from the previous version, but it still under the 68 KB limit. Signed-off-by: Walter Lozano walter.lozano@collabora.com
After enabling SPL_OF_CONTROL, SPL_DM and SPL_DM_MMC the MMC initialization code is not longer needed.
This patch removes the unused code.
Signed-off-by: Walter Lozano walter.lozano@collabora.com --- board/solidrun/mx6cuboxi/mx6cuboxi.c | 65 ---------------------------- 1 file changed, 65 deletions(-)
diff --git a/board/solidrun/mx6cuboxi/mx6cuboxi.c b/board/solidrun/mx6cuboxi/mx6cuboxi.c index cb06b6c46e..4466480e46 100644 --- a/board/solidrun/mx6cuboxi/mx6cuboxi.c +++ b/board/solidrun/mx6cuboxi/mx6cuboxi.c @@ -162,76 +162,11 @@ static void setup_iomux_uart(void) SETUP_IOMUX_PADS(uart1_pads); }
-static struct fsl_esdhc_cfg usdhc_cfg = { - .esdhc_base = USDHC2_BASE_ADDR, - .max_bus_width = 4, -}; - -static struct fsl_esdhc_cfg emmc_cfg = { - .esdhc_base = USDHC3_BASE_ADDR, - .max_bus_width = 8, -}; - int board_mmc_get_env_dev(int devno) { return devno; }
-#define USDHC2_CD_GPIO IMX_GPIO_NR(1, 4) - -int board_mmc_getcd(struct mmc *mmc) -{ - struct fsl_esdhc_cfg *cfg = mmc->priv; - int ret = 0; - - switch (cfg->esdhc_base) { - case USDHC2_BASE_ADDR: - ret = !gpio_get_value(USDHC2_CD_GPIO); - break; - case USDHC3_BASE_ADDR: - ret = (mmc_get_op_cond(mmc) < 0) ? 0 : 1; /* eMMC/uSDHC3 has no CD GPIO */ - break; - } - - return ret; -} - -static int mmc_init_spl(bd_t *bis) -{ - struct src *psrc = (struct src *)SRC_BASE_ADDR; - unsigned reg = readl(&psrc->sbmr1) >> 11; - - /* - * Upon reading BOOT_CFG register the following map is done: - * Bit 11 and 12 of BOOT_CFG register can determine the current - * mmc port - * 0x1 SD2 - * 0x2 SD3 - */ - switch (reg & 0x3) { - case 0x1: - SETUP_IOMUX_PADS(usdhc2_pads); - usdhc_cfg.sdhc_clk = mxc_get_clock(MXC_ESDHC2_CLK); - gd->arch.sdhc_clk = usdhc_cfg.sdhc_clk; - return fsl_esdhc_initialize(bis, &usdhc_cfg); - case 0x2: - SETUP_IOMUX_PADS(usdhc3_pads); - emmc_cfg.sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); - gd->arch.sdhc_clk = emmc_cfg.sdhc_clk; - return fsl_esdhc_initialize(bis, &emmc_cfg); - } - - return -ENODEV; -} - -int board_mmc_init(bd_t *bis) -{ - if (IS_ENABLED(CONFIG_SPL_BUILD)) - return mmc_init_spl(bis); - - return 0; -} - static iomux_v3_cfg_t const enet_pads[] = { IOMUX_PADS(PAD_ENET_MDIO__ENET_MDIO | MUX_PAD_CTRL(ENET_PAD_CTRL)), IOMUX_PADS(PAD_ENET_MDC__ENET_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL)),
After enabling SPL_OF_CONTROL, SPL_DM and SPL_DM_MMC the MMC initialization code is not longer needed. This patch removes the unused code. Signed-off-by: Walter Lozano walter.lozano@collabora.com
sbabic@denx.de
Walter Lozano
