[U-Boot] [PATCH-V4] OMAP3EVM: Added NAND support
The EVMS have been shipping with NAND (instead of OneNAND) as default. So, this patch sets NAND as default.
To choose OneNAND, define CMD_ONENAND instead of CMD_NAND in the config file omap3_evm.h.
Signed-off-by: Vaibhav Hiremath hvaibhav@ti.com --- Changes from V3 :- - Added undef statement for CMD_ONENAND.
include/configs/omap3_evm.h | 8 +++++++- 1 files changed, 7 insertions(+), 1 deletions(-)
diff --git a/include/configs/omap3_evm.h b/include/configs/omap3_evm.h index 0d99f7d..88af492 100644 --- a/include/configs/omap3_evm.h +++ b/include/configs/omap3_evm.h @@ -151,7 +151,7 @@
#define CONFIG_CMD_I2C /* I2C serial bus support */ #define CONFIG_CMD_MMC /* MMC support */ -#define CONFIG_CMD_ONENAND /* ONENAND support */ +#define CONFIG_CMD_NAND /* NAND support */ #define CONFIG_CMD_DHCP #define CONFIG_CMD_PING
@@ -306,7 +306,13 @@ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE #define CONFIG_SYS_ONENAND_BASE ONENAND_MAP
+#if defined(CONFIG_CMD_NAND) +#define CONFIG_NAND_OMAP_GPMC +#define GPMC_NAND_ECC_LP_x16_LAYOUT 1 +#define CONFIG_ENV_IS_IN_NAND +#elif defined(CONFIG_CMD_ONENAND) #define CONFIG_ENV_IS_IN_ONENAND 1 +#endif #define ONENAND_ENV_OFFSET 0x260000 /* environment starts here */ #define SMNAND_ENV_OFFSET 0x260000 /* environment starts here */
-- 1.6.2.4
-----Original Message----- From: Hiremath, Vaibhav Sent: Friday, June 04, 2010 7:15 PM To: u-boot@lists.denx.de Cc: Paulraj, Sandeep; tom@bumblecow.com; wd@denx.de; Hiremath, Vaibhav Subject: [PATCH-V4] OMAP3EVM: Added NAND support
[Hiremath, Vaibhav] As suggested by denk, I have moved the comments below ---. The patch content has not been changed so not version.
Hoping this time Tom will merge this patch.
Thanks, Vaibhav
-- 1.6.2.4
Hiremath, Vaibhav
hvaibhav@ti.com
