[U-Boot] [PATCH 0/2] atmel_nand: add sama5d2 chip support, which support up to 32bit pmecc
This patch set will enable sama5d2 chip pmecc support, it includes: 1. update the pmecc registers and pmecc error location registers map. 2. add 32bit ecc support.
Josh Wu (2): atmel_nand_ecc: update pmecc registers according to sama5d2 chip atmel_nand: Add 32 bit ecc support for sama5d2 chip
drivers/mtd/nand/atmel_nand.c | 10 +++++++++- drivers/mtd/nand/atmel_nand_ecc.h | 36 ++++++++++++++++++++++++++++++++---- 2 files changed, 41 insertions(+), 5 deletions(-)
1. add the pmecc register mapping for sama5d2. 2. add the pmecc error location register mapping for sama5d2. 3. add some new field that is different from old ip. 4. add sama5d2 pmecc ip version number.
Signed-off-by: Josh Wu josh.wu@atmel.com ---
drivers/mtd/nand/atmel_nand_ecc.h | 36 ++++++++++++++++++++++++++++++++---- 1 file changed, 32 insertions(+), 4 deletions(-)
diff --git a/drivers/mtd/nand/atmel_nand_ecc.h b/drivers/mtd/nand/atmel_nand_ecc.h index 79e3994..e13f385 100644 --- a/drivers/mtd/nand/atmel_nand_ecc.h +++ b/drivers/mtd/nand/atmel_nand_ecc.h @@ -58,14 +58,23 @@ struct pmecc_regs {
/* 0x40 + sector_num * (0x40), Redundancy Registers */ struct { +#ifdef CONFIG_SAMA5D2 + u8 ecc[56]; /* PMECC Generated Redundancy Byte Per Sector */ + u32 reserved1[2]; +#else u8 ecc[44]; /* PMECC Generated Redundancy Byte Per Sector */ u32 reserved1[5]; +#endif } ecc_port[PMECC_MAX_SECTOR_NUM];
/* 0x240 + sector_num * (0x40) Remainder Registers */ struct { +#ifdef CONFIG_SAMA5D2 + u32 rem[16]; +#else u32 rem[12]; u32 reserved2[4]; +#endif } rem_port[PMECC_MAX_SECTOR_NUM]; u32 reserved3[16]; /* 0x440-0x47C Reserved */ }; @@ -76,6 +85,7 @@ struct pmecc_regs { #define PMECC_CFG_BCH_ERR8 (2 << 0) #define PMECC_CFG_BCH_ERR12 (3 << 0) #define PMECC_CFG_BCH_ERR24 (4 << 0) +#define PMECC_CFG_BCH_ERR32 (5 << 0)
#define PMECC_CFG_SECTOR512 (0 << 4) #define PMECC_CFG_SECTOR1024 (1 << 4) @@ -120,19 +130,31 @@ struct pmecc_errloc_regs { u32 elimr; /* 0x0C Error Location Interrupt Mask Register */ u32 elisr; /* 0x20 Error Location Interrupt Status Register */ u32 reserved0; /* 0x24 Reserved */ +#ifdef CONFIG_SAMA5D2 + u32 sigma[33]; /* 0x28-0xA8 Error Location Sigma Registers */ + u32 el[32]; /* 0xAC-0x128 Error Location Registers */ + + /* + * 0x12C-0x1FC: + * Reserved for SAMA5D2. + */ + u32 reserved1[53]; +#else u32 sigma[25]; /* 0x28-0x88 Error Location Sigma Registers */ u32 el[24]; /* 0x8C-0xE8 Error Location Registers */ u32 reserved1[5]; /* 0xEC-0xFC Reserved */ +#endif
/* - * 0x100-0x1F8: - * Reserved for AT91SAM9X5, AT91SAM9N12. - * HSMC registers for SAMA5D3, SAMA5D4. + * SAMA5 chip HSMC registers start here. But for 9X5 chip it is just + * reserved. + * + * Offset 0x00-0xF8: */ u32 reserved2[63];
/* - * 0x1FC: + * Offset 0xFC: * PMECC version for AT91SAM9X5, AT91SAM9N12. * HSMC version for SAMA5D3, SAMA5D4. Can refer as PMECC version. */ @@ -148,10 +170,16 @@ struct pmecc_errloc_regs { #define PMERRLOC_DISABLE (1 << 0)
/* For Error Location Interrupt Status Register */ +#ifdef CONFIG_SAMA5D2 +#define PMERRLOC_ERR_NUM_MASK (0x3f << 8) +#else #define PMERRLOC_ERR_NUM_MASK (0x1f << 8) +#endif + #define PMERRLOC_CALC_DONE (1 << 0)
/* PMECC IP version */ +#define PMECC_VERSION_SAMA5D2 0x210 #define PMECC_VERSION_SAMA5D4 0x113 #define PMECC_VERSION_SAMA5D3 0x112 #define PMECC_VERSION_AT91SAM9N12 0x102
On 24.11.2015 09:34, Josh Wu wrote:
- add the pmecc register mapping for sama5d2.
- add the pmecc error location register mapping for sama5d2.
- add some new field that is different from old ip.
- add sama5d2 pmecc ip version number.
Reviewed-by: Andreas Bießmann andreas.devel@googlemail.com
u32 reserved1[2];
u32 rem[16];
- u32 sigma[33]; /* 0x28-0xA8 Error Location Sigma Registers */
- u32 el[32]; /* 0xAC-0x128 Error Location Registers */
* 0x12C-0x1FC:
- u32 reserved1[53];
* 0x100-0x1F8:
* reserved.
* Offset 0x00-0xF8:
* 0x1FC:
* Offset 0xFC:
- PMECC version for AT91SAM9X5, AT91SAM9N12.
- HSMC version for SAMA5D3, SAMA5D4. Can refer as PMECC version.
Dear Josh Wu,
Josh Wu josh.wu@atmel.com writes:
Signed-off-by: Josh Wu josh.wu@atmel.com Reviewed-by: Andreas Bießmann andreas.devel@googlemail.com
applied to u-boot-atmel/master, thanks!
Best regards, Andreas Bießmann
Also if minimum ecc requirment is bigger then what we support, then just use our maxium pmecc support. But it is not safe, so we'll output a warning about this.
drivers/mtd/nand/atmel_nand.c | 10 +++++++++- 1 file changed, 9 insertions(+), 1 deletion(-)
diff --git a/drivers/mtd/nand/atmel_nand.c b/drivers/mtd/nand/atmel_nand.c index 2967eee..bb54e0f 100644 --- a/drivers/mtd/nand/atmel_nand.c +++ b/drivers/mtd/nand/atmel_nand.c @@ -80,6 +80,7 @@ static struct nand_ecclayout atmel_pmecc_oobinfo; * 8-bits 13-bytes 14-bytes * 12-bits 20-bytes 21-bytes * 24-bits 39-bytes 42-bytes + * 32-bits 52-bytes 56-bytes */ static int pmecc_get_ecc_bytes(int cap, int sector_size) { @@ -638,6 +639,9 @@ static void atmel_pmecc_core_init(struct mtd_info *mtd) case 24: val = PMECC_CFG_BCH_ERR24; break; + case 32: + val = PMECC_CFG_BCH_ERR32; + break; }
if (host->pmecc_sector_size == 512) @@ -723,7 +727,11 @@ static int pmecc_choose_ecc(struct atmel_nand_host *host, else if (*cap <= 24) host->pmecc_corr_cap = 24; else - return -EINVAL; +#ifdef CONFIG_SAMA5D2 + host->pmecc_corr_cap = 32; +#else + host->pmecc_corr_cap = 24; +#endif } if (host->pmecc_sector_size == 0) { /* use the most fitable sector size (the near smaller one ) */
Acked-by: Scott Wood scottwood@freescale.com
-Scott
case 32:
break;
return -EINVAL;
+#else
Dear Josh Wu,
Signed-off-by: Josh Wu josh.wu@atmel.com Acked-by: Scott Wood scottwood@freescale.com Reviewed-by: Andreas Bießmann andreas.devel@googlemail.com
Andreas Bießmann
Josh Wu
Scott Wood
