[PATCH 1/1] doc: describe load command
Man-page for load command.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- doc/usage/index.rst | 1 + doc/usage/load.rst | 74 +++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 75 insertions(+) create mode 100644 doc/usage/load.rst
diff --git a/doc/usage/index.rst b/doc/usage/index.rst index 83cfbafd90..5754958d7e 100644 --- a/doc/usage/index.rst +++ b/doc/usage/index.rst @@ -23,6 +23,7 @@ Shell commands exit false for + load loady mbr pstore diff --git a/doc/usage/load.rst b/doc/usage/load.rst new file mode 100644 index 0000000000..1efee77317 --- /dev/null +++ b/doc/usage/load.rst @@ -0,0 +1,74 @@ +.. SPDX-License-Identifier: GPL-2.0+: + +load command +============ + +Synopsis +-------- + +:: + + load <interface> [<dev[:part]> [<addr> [<filename> [bytes [pos]]]]] + +Description +----------- + +The load command is used to read a file from a filesystem into memory. + +The number of transferred bytes is saved in the environment variable filesize. +The load address is saved in the environment variable fileaddr. + +interface + interface for accessing the block device (mmc, sata, scsi, usb, ....) + +dev + device number + +part + partition number, defaults to 0 (whole device) + +addr + load address, defaults to environment variable loadaddr or if loadaddr is + not set to configuration variable CONFIG_SYS_LOAD_ADDR + +filename + path to file, defaults to environment variable bootfile + +bytes + maximum number of bytes to load + +pos + number of bytes to skip + +addr, bytes, pos are hexadecimal numbers. + +Example +------- + +:: + + => load mmc 0:1 ${kernel_addr_r} snp.efi + 149280 bytes read in 11 ms (12.9 MiB/s) + => + => load mmc 0:1 ${kernel_addr_r} snp.efi 1000000 + 149280 bytes read in 9 ms (15.8 MiB/s) + => + => load mmc 0:1 ${kernel_addr_r} snp.efi 1000000 100 + 149024 bytes read in 10 ms (14.2 MiB/s) + => + => load mmc 0:1 ${kernel_addr_r} snp.efi 10 + 16 bytes read in 1 ms (15.6 KiB/s) + => + +Configuration +------------- + +The load command is only available if CONFIG_CMD_FS_GENERIC=y. + +Return value +------------ + +The return value $? is set to 0 (true) if the file was successfully loaded +even if the number of bytes is less then the specified length. + +If an error occurs, the return value $? is set to 1 (false). -- 2.29.2
