[PATCH v2] mmc: rockchip_sdhci: Fix 4 blocks PIO mode read limit for RK35xx
The commit 2cc6cde647e2 ("mmc: rockchip_sdhci: Limit number of blocks read in a single command") introduced a limit of number of blocks to read to fix a Data End Bit Error on RK3568 and RK3588. This had a side affect of significant slowing down reading FIT from eMMC.
After the commit 6de9d7b2f13c ("rockchip: rk35xx: Enable eMMC HS200 mode by default") the limit of number of blocks to read workaround is no longer necessary and at HS200+ a Data End Bit Error is no longer happening using PIO mode.
Change this limitation to allow reading more than 4 blocks with a single CMD18 command in PIO mode at HS200+ speed, keep using the 4 blocks limitation when loadig FIT from eMMC at lower speed than HS200.
Fixes: 2cc6cde647e2 ("mmc: rockchip_sdhci: Limit number of blocks read in a single command") Signed-off-by: Jonas Karlman jonas@kwiboo.se --- v2: Move cfg->b_max configuration to set_ios_post() ops
This significantly speed up FIT loading from eMMC on RK3588 boards with a mmc-hs200 prop in the sdhci node, and boards without a mmc-hs200 prop continue to work. --- drivers/mmc/rockchip_sdhci.c | 26 ++++++++++++++++---------- 1 file changed, 16 insertions(+), 10 deletions(-)
diff --git a/drivers/mmc/rockchip_sdhci.c b/drivers/mmc/rockchip_sdhci.c index 706fb1235796..c889c7bc9855 100644 --- a/drivers/mmc/rockchip_sdhci.c +++ b/drivers/mmc/rockchip_sdhci.c @@ -391,6 +391,8 @@ static int rk3568_sdhci_config_dll(struct sdhci_host *host, u32 clock, bool enab static int rk3568_sdhci_set_ios_post(struct sdhci_host *host) { struct mmc *mmc = host->mmc; + struct rockchip_sdhc_plat *plat = dev_get_plat(mmc->dev); + struct mmc_config *cfg = &plat->cfg; u32 reg;
reg = sdhci_readw(host, SDHCI_HOST_CONTROL2); @@ -437,6 +439,20 @@ static int rk3568_sdhci_set_ios_post(struct sdhci_host *host)
sdhci_writew(host, reg, DWCMSHC_EMMC_EMMC_CTRL);
+ /* + * Reading more than 4 blocks with a single CMD18 command in PIO mode + * triggers Data End Bit Error using a slower mode than HS200. Limit to + * reading max 4 blocks in one command when using PIO mode. + */ + if (!(host->flags & USE_DMA)) { + if (mmc->selected_mode == MMC_HS_200 || + mmc->selected_mode == MMC_HS_400 || + mmc->selected_mode == MMC_HS_400_ES) + cfg->b_max = CONFIG_SYS_MMC_MAX_BLK_COUNT; + else + cfg->b_max = 4; + } + return 0; }
@@ -598,16 +614,6 @@ static int rockchip_sdhci_probe(struct udevice *dev) dev_read_bool(dev, "u-boot,spl-fifo-mode")) host->flags &= ~USE_DMA;
- /* - * Reading more than 4 blocks with a single CMD18 command in PIO mode - * triggers Data End Bit Error on RK3568 and RK3588. Limit to reading - * max 4 blocks in one command when using PIO mode. - */ - if (!(host->flags & USE_DMA) && - (device_is_compatible(dev, "rockchip,rk3568-dwcmshc") || - device_is_compatible(dev, "rockchip,rk3588-dwcmshc"))) - cfg->b_max = 4; - return sdhci_probe(dev); }
Looking good to me. Thanks for peforming this dynamically, based on the actual MMC interface speed/mode.
Reviewed-by: Dragan Simic dsimic@manjaro.org
to
- if (!(host->flags & USE_DMA)) {
else
cfg->b_max = 4;
cfg->b_max = 4;
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
else
cfg->b_max = 4;
- return 0; }
cfg->b_max = 4;
Dragan Simic
Jonas Karlman
Kever Yang
