[U-Boot] [PATCH] env_mmc: add support for redundant environment
This patch add support for storing the environment redundant on mmc devices. Substantially it re-uses the logic from the NAND implementation, that means using an incremental counter for marking newer data.
Signed-off-by: Michael Heimpold mhei@heimpold.de --- board/freescale/common/sdhc_boot.c | 2 +- common/env_mmc.c | 133 +++++++++++++++++++++++++++++++++--- 2 files changed, 124 insertions(+), 11 deletions(-)
diff --git a/board/freescale/common/sdhc_boot.c b/board/freescale/common/sdhc_boot.c index e432318..fd0e910 100644 --- a/board/freescale/common/sdhc_boot.c +++ b/board/freescale/common/sdhc_boot.c @@ -32,7 +32,7 @@ #define ESDHC_BOOT_IMAGE_SIZE 0x48 #define ESDHC_BOOT_IMAGE_ADDR 0x50
-int mmc_get_env_addr(struct mmc *mmc, u32 *env_addr) +int mmc_get_env_addr(struct mmc *mmc, int copy, u32 *env_addr) { u8 *tmp_buf; u32 blklen, code_offset, code_len, n; diff --git a/common/env_mmc.c b/common/env_mmc.c index f568013..68f0530 100644 --- a/common/env_mmc.c +++ b/common/env_mmc.c @@ -32,6 +32,11 @@ #include <search.h> #include <errno.h>
+#if defined(CONFIG_ENV_SIZE_REDUND) && \ + (CONFIG_ENV_SIZE_REDUND != CONFIG_ENV_SIZE) +#error CONFIG_ENV_SIZE_REDUND should be the same as CONFIG_ENV_SIZE +#endif + char *env_name_spec = "MMC";
#ifdef ENV_IS_EMBEDDED @@ -48,9 +53,13 @@ DECLARE_GLOBAL_DATA_PTR; #define CONFIG_ENV_OFFSET 0 #endif
-__weak int mmc_get_env_addr(struct mmc *mmc, u32 *env_addr) +__weak int mmc_get_env_addr(struct mmc *mmc, int copy, u32 *env_addr) { *env_addr = CONFIG_ENV_OFFSET; +#ifdef CONFIG_ENV_OFFSET_REDUND + if (copy) + *env_addr = CONFIG_ENV_OFFSET_REDUND; +#endif return 0; }
@@ -112,6 +121,10 @@ static inline int write_env(struct mmc *mmc, unsigned long size, return (n == blk_cnt) ? 0 : -1; }
+#ifdef CONFIG_ENV_OFFSET_REDUND +static unsigned char env_flags; +#endif + int saveenv(void) { env_t *env_new = (env_t *)env_buf; @@ -119,16 +132,11 @@ int saveenv(void) char *res; struct mmc *mmc = find_mmc_device(CONFIG_SYS_MMC_ENV_DEV); u32 offset; - int ret; + int ret, copy = 0;
if (init_mmc_for_env(mmc)) return 1;
- if (mmc_get_env_addr(mmc, &offset)) { - ret = 1; - goto fini; - } - res = (char *)env_new->data; len = hexport_r(&env_htab, '\0', 0, &res, ENV_SIZE, 0, NULL); if (len < 0) { @@ -136,9 +144,22 @@ int saveenv(void) ret = 1; goto fini; } - env_new->crc = crc32(0, env_new->data, ENV_SIZE); - printf("Writing to MMC(%d)... ", CONFIG_SYS_MMC_ENV_DEV); + +#ifdef CONFIG_ENV_OFFSET_REDUND + env_new->flags = ++env_flags; /* increase the serial */ + + if (gd->env_valid == 1) + copy = 1; +#endif + + if (mmc_get_env_addr(mmc, copy, &offset)) { + ret = 1; + goto fini; + } + + printf("Writing to %sMMC(%d)... ", copy ? "redundant " : "", + CONFIG_SYS_MMC_ENV_DEV); if (write_env(mmc, CONFIG_ENV_SIZE, offset, (u_char *)env_new)) { puts("failed\n"); ret = 1; @@ -148,6 +169,10 @@ int saveenv(void) puts("done\n"); ret = 0;
+#ifdef CONFIG_ENV_OFFSET_REDUND + gd->env_valid = gd->env_valid == 2 ? 1 : 2; +#endif + fini: fini_mmc_for_env(mmc); return ret; @@ -168,6 +193,93 @@ static inline int read_env(struct mmc *mmc, unsigned long size, return (n == blk_cnt) ? 0 : -1; }
+#ifdef CONFIG_ENV_OFFSET_REDUND +void env_relocate_spec(void) +{ +#if !defined(ENV_IS_EMBEDDED) + struct mmc *mmc = find_mmc_device(CONFIG_SYS_MMC_ENV_DEV); + u32 offset1, offset2; + int read1_fail = 0, read2_fail = 0; + int crc1_ok = 0, crc2_ok = 0; + env_t *ep, *tmp_env1, *tmp_env2; + int ret; + + tmp_env1 = (env_t *)malloc(CONFIG_ENV_SIZE); + tmp_env2 = (env_t *)malloc(CONFIG_ENV_SIZE); + if (tmp_env1 == NULL || tmp_env2 == NULL) { + puts("Can't allocate buffers for environment\n"); + ret = 1; + goto err; + } + + if (init_mmc_for_env(mmc)) { + ret = 1; + goto err; + } + + if (mmc_get_env_addr(mmc, 0, &offset1) || + mmc_get_env_addr(mmc, 1, &offset2)) { + ret = 1; + goto fini; + } + + read1_fail = read_env(mmc, CONFIG_ENV_SIZE, offset1, tmp_env1); + read2_fail = read_env(mmc, CONFIG_ENV_SIZE, offset2, tmp_env2); + + if (read1_fail && read2_fail) + puts("*** Error - No Valid Environment Area found\n"); + else if (read1_fail || read2_fail) + puts("*** Warning - some problems detected " + "reading environment; recovered successfully\n"); + + crc1_ok = !read1_fail && + (crc32(0, tmp_env1->data, ENV_SIZE) == tmp_env1->crc); + crc2_ok = !read2_fail && + (crc32(0, tmp_env2->data, ENV_SIZE) == tmp_env2->crc); + + if (!crc1_ok && !crc2_ok) { + ret = 1; + goto fini; + } else if (crc1_ok && !crc2_ok) { + gd->env_valid = 1; + } else if (!crc1_ok && crc2_ok) { + gd->env_valid = 2; + } else { + /* both ok - check serial */ + if (tmp_env1->flags == 255 && tmp_env2->flags == 0) + gd->env_valid = 2; + else if (tmp_env2->flags == 255 && tmp_env1->flags == 0) + gd->env_valid = 1; + else if (tmp_env1->flags > tmp_env2->flags) + gd->env_valid = 1; + else if (tmp_env2->flags > tmp_env1->flags) + gd->env_valid = 2; + else /* flags are equal - almost impossible */ + gd->env_valid = 1; + } + + free(env_ptr); + + if (gd->env_valid == 1) + ep = tmp_env1; + else + ep = tmp_env2; + + env_flags = ep->flags; + env_import((char *)ep, 0); + ret = 0; + +fini: + fini_mmc_for_env(mmc); +err: + if (ret) + set_default_env(NULL); + + free(tmp_env1); + free(tmp_env2); +#endif +} +#else /* ! CONFIG_ENV_OFFSET_REDUND */ void env_relocate_spec(void) { #if !defined(ENV_IS_EMBEDDED) @@ -180,7 +292,7 @@ void env_relocate_spec(void) goto err; }
- if (mmc_get_env_addr(mmc, &offset)) { + if (mmc_get_env_addr(mmc, 0, &offset)) { ret = 1; goto fini; } @@ -200,3 +312,4 @@ err: set_default_env(NULL); #endif } +#endif /* CONFIG_ENV_OFFSET_REDUND */
Michael Heimpold
