[U-Boot] bug in malloc/calloc and setting of MORECORE_CLEARS
I've been debugging a "memory corruption" issue and it seems to come down to how we set MORECORE_CLEARS
from malloc.h:
MORECORE (default: sbrk) The name of the routine to call to obtain more memory from the system. MORECORE_FAILURE (default: -1) The value returned upon failure of MORECORE. MORECORE_CLEARS (default 1) True (1) if the routine mapped to MORECORE zeroes out memory (which holds for sbrk).
So the issue I'm seeing is that we zero out memory in mem_malloc_init(). Thus our sbrk implementation just does simple record keeping. However we can get into the following situation:
a1 = malloc(LARGE_SZ); /* causes internals to call sbrk */ ... /* use memory at 'a1' */ ... free(a1); /* causes internals to call malloc_trim, malloc_trim decides to return memory to sbrk, memory is now nonzero */
a2 = calloc(SIZE); /* internals assume sbrk memory is zero because of MORECORE_CLEARS setting, however its not */
... BAD THINGS HAPPEN ...
I'm guessing we haven't seen much of this because there aren't that many users of calloc today. I happen to see it related to NAND code which has kzalloc defined as calloc.
- k
from malloc.h:
Here's an example test case that fails if execute right after:
mem_malloc_init (malloc_start, TOTAL_MALLOC_LEN);
{ void *p1; u8 *p2; int i;
printf("MALLOC TEST\n"); p1 = malloc(135176); printf("P1 = %p\n", p1); memset(p1, 0xab, 135176);
free(p1); p2 = calloc(4097, 1); printf("P2 = %p %p\n", p2, p2 + 4097);
for (i = 0; i < 4097; i++) { if (p2[i] != 0) printf("miscompare at byte %d got %x\n", i, p2[i]); }
free(p2); printf("END MALLOC TEST\n\n"); }
Dear Kumar Gala,
In message 9D70A5EF-48AD-4D65-85D6-B81CE0A0D2A9@kernel.crashing.org you wrote:
I confirm that the test case shows errors for me, too (tested on TQM8555). I also confirm that switching MORECORE_CLEARS to 0 fixes the problem in this test.
Are you going to submit a patch?
On Nov 15, 2010, at 2:39 PM, Wolfgang Denk wrote:
Dear Kumar Gala,
Yes, but going to try a different solution in which we memset and sbrk calls that have a negative increment (free).
- k
Kumar Gala
