[U-Boot] [PATCH] powerpc/85xx: fix broken cpu "clock-frequency" property
When indexing freqProcessor[] we use the first value in the cpu's "reg" property, which on new e6500 cores IDs the threads. But freqProcessor[] should be indexed with a core index so, when fixing "the clock-frequency" cpu node property, access the freqProcessor[] with the core index derived from the "reg' property. If we don't do this, last half of the "cpu" nodes will have broken "clock-frequency" values.
Signed-off-by: Laurentiu Tudor Laurentiu.Tudor@freescale.com Cc: York Sun yorksun@freescale.com --- Based on: git://git.denx.de/u-boot-mpc85xx.git master
arch/powerpc/cpu/mpc85xx/fdt.c | 5 +++-- 1 files changed, 3 insertions(+), 2 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/fdt.c b/arch/powerpc/cpu/mpc85xx/fdt.c index 2ccd9c7..33bc900 100644 --- a/arch/powerpc/cpu/mpc85xx/fdt.c +++ b/arch/powerpc/cpu/mpc85xx/fdt.c @@ -586,6 +586,7 @@ void ft_cpu_setup(void *blob, bd_t *bd) { int off; int val; + int len; sys_info_t sysinfo;
/* delete crypto node if not on an E-processor */ @@ -615,8 +616,8 @@ void ft_cpu_setup(void *blob, bd_t *bd) get_sys_info(&sysinfo); off = fdt_node_offset_by_prop_value(blob, -1, "device_type", "cpu", 4); while (off != -FDT_ERR_NOTFOUND) { - u32 *reg = (u32 *)fdt_getprop(blob, off, "reg", 0); - val = cpu_to_fdt32(sysinfo.freq_processor[*reg]); + u32 *reg = (u32 *)fdt_getprop(blob, off, "reg", &len); + val = cpu_to_fdt32(sysinfo.freq_processor[(*reg) / (len / 4)]); fdt_setprop(blob, off, "clock-frequency", &val, 4); off = fdt_node_offset_by_prop_value(blob, off, "device_type", "cpu", 4);
Applied to u-boot-mpc85xx/master.
York
Laurentiu Tudor
york sun
