[PATCH v1] rng: nuvoton: Add NPCM7xx rng driver
Add Nuvoton BMC NPCM750 rng driver.
Signed-off-by: Jim Liu JJLIU0@nuvoton.com --- drivers/rng/Kconfig | 7 ++ drivers/rng/Makefile | 1 + drivers/rng/npcm_rng.c | 156 +++++++++++++++++++++++++++++++++++++++++ 3 files changed, 164 insertions(+) create mode 100644 drivers/rng/npcm_rng.c
diff --git a/drivers/rng/Kconfig b/drivers/rng/Kconfig index c10f7d345b..c0c49c3484 100644 --- a/drivers/rng/Kconfig +++ b/drivers/rng/Kconfig @@ -31,6 +31,13 @@ config RNG_MSM This driver provides support for the Random Number Generator hardware found on Qualcomm SoCs.
+config RNG_NPCM + bool "Nuvoton NPCM SoCs Random Number Generator support" + depends on DM_RNG + help + Enable random number generator on NPCM SoCs. + This unit can provide 750 to 1000 random bits per second + config RNG_OPTEE bool "OP-TEE based Random Number Generator support" depends on DM_RNG && OPTEE diff --git a/drivers/rng/Makefile b/drivers/rng/Makefile index 435b3b965a..0ae0ed4171 100644 --- a/drivers/rng/Makefile +++ b/drivers/rng/Makefile @@ -7,6 +7,7 @@ obj-$(CONFIG_DM_RNG) += rng-uclass.o obj-$(CONFIG_RNG_MESON) += meson-rng.o obj-$(CONFIG_RNG_SANDBOX) += sandbox_rng.o obj-$(CONFIG_RNG_MSM) += msm_rng.o +obj-$(CONFIG_RNG_NPCM) += npcm_rng.o obj-$(CONFIG_RNG_OPTEE) += optee_rng.o obj-$(CONFIG_RNG_STM32MP1) += stm32mp1_rng.o obj-$(CONFIG_RNG_ROCKCHIP) += rockchip_rng.o diff --git a/drivers/rng/npcm_rng.c b/drivers/rng/npcm_rng.c new file mode 100644 index 0000000000..70c1c032b6 --- /dev/null +++ b/drivers/rng/npcm_rng.c @@ -0,0 +1,156 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2022 Nuvoton Technology Corp. + */ + +#include <common.h> +#include <dm.h> +#include <malloc.h> +#include <rng.h> +#include <uboot_aes.h> +#include <asm/io.h> + +#define RNGCS_RNGE BIT(0) +#define RNGCS_DVALID BIT(1) +#define RNGCS_CLKP(range) ((0x0f & (range)) << 2) +#define RNGMODE_M1ROSEL_VAL (0x02) /* Ring Oscillator Select for Method I */ + +enum { + RNG_CLKP_80_100_MHZ = 0x00, /*default */ + RNG_CLKP_60_80_MHZ = 0x01, + RNG_CLKP_50_60_MHZ = 0x02, + RNG_CLKP_40_50_MHZ = 0x03, + RNG_CLKP_30_40_MHZ = 0x04, + RNG_CLKP_25_30_MHZ = 0x05, + RNG_CLKP_20_25_MHZ = 0x06, + RNG_CLKP_5_20_MHZ = 0x07, + RNG_CLKP_2_15_MHZ = 0x08, + RNG_CLKP_9_12_MHZ = 0x09, + RNG_CLKP_7_9_MHZ = 0x0A, + RNG_CLKP_6_7_MHZ = 0x0B, + RNG_CLKP_5_6_MHZ = 0x0C, + RNG_CLKP_4_5_MHZ = 0x0D, + RNG_CLKP_3_4_MHZ = 0x0E, + RNG_NUM_OF_CLKP +}; + +struct npcm_rng_regs { + unsigned int rngcs; + unsigned int rngd; + unsigned int rngmode; +}; + +struct npcm_rng_priv { + struct npcm_rng_regs *regs; +}; + +static struct npcm_rng_priv *rng_priv; + +void npcm_rng_init(void) +{ + struct npcm_rng_regs *regs = rng_priv->regs; + int init; + + /* check if rng enabled */ + init = readb(®s->rngcs); + if ((init & RNGCS_RNGE) == 0) { + /* init rng */ + writeb(RNGCS_CLKP(RNG_CLKP_20_25_MHZ) | RNGCS_RNGE, ®s->rngcs); + writeb(RNGMODE_M1ROSEL_VAL, ®s->rngmode); + } +} + +void npcm_rng_disable(void) +{ + struct npcm_rng_regs *regs = rng_priv->regs; + + /* disable rng */ + writeb(0, ®s->rngcs); + writeb(0, ®s->rngmode); +} + +void srand(unsigned int seed) +{ + /* no need to seed for now */ +} + +int npcm_rng_read(struct udevice *dev, void *data, size_t max) +{ + struct npcm_rng_regs *regs = rng_priv->regs; + int i; + int ret_val = 0; + char *buf = data; + + npcm_rng_init(); + + printf("NPCM HW RNG\n"); + /* Wait for RNG done (max bytes) */ + for (i = 0; i < max; i++) { + /* wait until DVALID is set */ + while ((readb(®s->rngcs) & RNGCS_DVALID) == 0) + ; + buf[i] = ((unsigned int)readb(®s->rngd) & 0x000000FF); + } + + return ret_val; +} + +unsigned int rand_r(unsigned int *seedp) +{ + struct npcm_rng_regs *regs = rng_priv->regs; + int i; + unsigned int ret_val = 0; + + npcm_rng_init(); + + /* Wait for RNG done (4 bytes) */ + for (i = 0; i < 4 ; i++) { + /* wait until DVALID is set */ + while ((readb(®s->rngcs) & RNGCS_DVALID) == 0) + ; + ret_val |= (((unsigned int)readb(®s->rngd) & 0x000000FF) << (i * 8)); + } + + return ret_val; +} + +unsigned int rand(void) +{ + return rand_r(NULL); +} + +static int npcm_rng_bind(struct udevice *dev) +{ + rng_priv = calloc(1, sizeof(struct npcm_rng_priv)); + if (!rng_priv) + return -ENOMEM; + + rng_priv->regs = dev_remap_addr_index(dev, 0); + if (!rng_priv->regs) { + printf("Cannot find rng reg address, binding failed\n"); + return -EINVAL; + } + + printf("RNG: NPCM RNG module bind OK\n"); + + return 0; +} + +static const struct udevice_id npcm_rng_ids[] = { + { .compatible = "nuvoton,npcm845-rng" }, + { .compatible = "nuvoton,npcm750-rng" }, + { } +}; + +static const struct dm_rng_ops npcm_rng_ops = { + .read = npcm_rng_read, +}; + +U_BOOT_DRIVER(npcm_rng) = { + .name = "npcm_rng", + .id = UCLASS_RNG, + .ops = &npcm_rng_ops, + .of_match = npcm_rng_ids, + .priv_auto = sizeof(struct npcm_rng_priv), + .bind = npcm_rng_bind, +};
Jim Liu
