[U-Boot] [PATCH] lcd: remove unused lcd_puts_xy
prevents a clang warning that the function is never used.
cc: agust@denx.de Signed-off-by: Jeroen Hofstee jeroen@myspectrum.nl --- common/lcd.c | 10 ---------- 1 file changed, 10 deletions(-)
diff --git a/common/lcd.c b/common/lcd.c index 19b86b7..98bd78d 100644 --- a/common/lcd.c +++ b/common/lcd.c @@ -109,7 +109,6 @@ DECLARE_GLOBAL_DATA_PTR;
static void lcd_drawchars(ushort x, ushort y, uchar *str, int count); -static inline void lcd_puts_xy(ushort x, ushort y, uchar *s); static inline void lcd_putc_xy(ushort x, ushort y, uchar c);
static int lcd_init(void *lcdbase); @@ -345,15 +344,6 @@ static void lcd_drawchars(ushort x, ushort y, uchar *str, int count) } }
-/*----------------------------------------------------------------------*/ - -static inline void lcd_puts_xy(ushort x, ushort y, uchar *s) -{ - lcd_drawchars(x, y, s, strlen((char *)s)); -} - -/*----------------------------------------------------------------------*/ - static inline void lcd_putc_xy(ushort x, ushort y, uchar c) { lcd_drawchars(x, y, &c, 1);
Jeroen Hofstee
