[U-Boot] [PATCH] AT91: SoC fix at91sam9261_matrix.h
Fix at91sam9261_matrix.h according to the new scheme.
Signed-off-by: Hong Xu hong.xu@atmel.com --- .../arm/include/asm/arch-at91/at91sam9261_matrix.h | 77 +++++++++----------- 1 files changed, 36 insertions(+), 41 deletions(-)
diff --git a/arch/arm/include/asm/arch-at91/at91sam9261_matrix.h b/arch/arm/include/asm/arch-at91/at91sam9261_matrix.h index e2bfc4b..913b4d7 100644 --- a/arch/arm/include/asm/arch-at91/at91sam9261_matrix.h +++ b/arch/arm/include/asm/arch-at91/at91sam9261_matrix.h @@ -15,50 +15,45 @@ #ifndef AT91SAM9261_MATRIX_H #define AT91SAM9261_MATRIX_H
-#define AT91_MATRIX_MCFG (AT91_MATRIX + 0x00) /* Master Configuration Register */ -#define AT91_MATRIX_RCB0 (1 << 0) /* Remap Command for AHB Master 0 (ARM926EJ-S Instruction Master) */ -#define AT91_MATRIX_RCB1 (1 << 1) /* Remap Command for AHB Master 1 (ARM926EJ-S Data Master) */ +#ifndef __ASSEMBLY__
-#define AT91_MATRIX_SCFG0 (AT91_MATRIX + 0x04) /* Slave Configuration Register 0 */ -#define AT91_MATRIX_SCFG1 (AT91_MATRIX + 0x08) /* Slave Configuration Register 1 */ -#define AT91_MATRIX_SCFG2 (AT91_MATRIX + 0x0C) /* Slave Configuration Register 2 */ -#define AT91_MATRIX_SCFG3 (AT91_MATRIX + 0x10) /* Slave Configuration Register 3 */ -#define AT91_MATRIX_SCFG4 (AT91_MATRIX + 0x14) /* Slave Configuration Register 4 */ -#define AT91_MATRIX_SLOT_CYCLE (0xff << 0) /* Maximum Number of Allowed Cycles for a Burst */ -#define AT91_MATRIX_DEFMSTR_TYPE (3 << 16) /* Default Master Type */ -#define AT91_MATRIX_DEFMSTR_TYPE_NONE (0 << 16) -#define AT91_MATRIX_DEFMSTR_TYPE_LAST (1 << 16) -#define AT91_MATRIX_DEFMSTR_TYPE_FIXED (2 << 16) -#define AT91_MATRIX_FIXED_DEFMSTR (7 << 18) /* Fixed Index of Default Master */ +struct at91_matrix { + u32 mcfg; /* Master Configuration Registers */ + u32 scfg[5]; /* Slave Configuration Registers */ + u32 filler[6]; + u32 ebicsa; /* EBI Chip Select Assignment Register */ +}; +#endif /* __ASSEMBLY__ */
-#define AT91_MATRIX_TCR (AT91_MATRIX + 0x24) /* TCM Configuration Register */ -#define AT91_MATRIX_ITCM_SIZE (0xf << 0) /* Size of ITCM enabled memory block */ -#define AT91_MATRIX_ITCM_0 (0 << 0) -#define AT91_MATRIX_ITCM_16 (5 << 0) -#define AT91_MATRIX_ITCM_32 (6 << 0) -#define AT91_MATRIX_ITCM_64 (7 << 0) -#define AT91_MATRIX_DTCM_SIZE (0xf << 4) /* Size of DTCM enabled memory block */ -#define AT91_MATRIX_DTCM_0 (0 << 4) -#define AT91_MATRIX_DTCM_16 (5 << 4) -#define AT91_MATRIX_DTCM_32 (6 << 4) -#define AT91_MATRIX_DTCM_64 (7 << 4) +#define AT91_MATRIX_ULBT_INFINITE (0 << 0) +#define AT91_MATRIX_ULBT_SINGLE (1 << 0) +#define AT91_MATRIX_ULBT_FOUR (2 << 0) +#define AT91_MATRIX_ULBT_EIGHT (3 << 0) +#define AT91_MATRIX_ULBT_SIXTEEN (4 << 0)
-#define AT91_MATRIX_EBICSA (AT91_MATRIX + 0x30) /* EBI Chip Select Assignment Register */ -#define AT91_MATRIX_CS1A (1 << 1) /* Chip Select 1 Assignment */ -#define AT91_MATRIX_CS1A_SMC (0 << 1) -#define AT91_MATRIX_CS1A_SDRAMC (1 << 1) -#define AT91_MATRIX_CS3A (1 << 3) /* Chip Select 3 Assignment */ -#define AT91_MATRIX_CS3A_SMC (0 << 3) -#define AT91_MATRIX_CS3A_SMC_SMARTMEDIA (1 << 3) -#define AT91_MATRIX_CS4A (1 << 4) /* Chip Select 4 Assignment */ -#define AT91_MATRIX_CS4A_SMC (0 << 4) -#define AT91_MATRIX_CS4A_SMC_CF1 (1 << 4) -#define AT91_MATRIX_CS5A (1 << 5) /* Chip Select 5 Assignment */ -#define AT91_MATRIX_CS5A_SMC (0 << 5) -#define AT91_MATRIX_CS5A_SMC_CF2 (1 << 5) -#define AT91_MATRIX_DBPUC (1 << 8) /* Data Bus Pull-up Configuration */ +#define AT91_MATRIX_DEFMSTR_TYPE_NONE (0 << 16) +#define AT91_MATRIX_DEFMSTR_TYPE_LAST (1 << 16) +#define AT91_MATRIX_DEFMSTR_TYPE_FIXED (2 << 16) +#define AT91_MATRIX_FIXED_DEFMSTR_SHIFT 18 +#define AT91_MATRIX_ARBT_ROUND_ROBIN (0 << 24) +#define AT91_MATRIX_ARBT_FIXED_PRIORITY (1 << 24)
-#define AT91_MATRIX_USBPUCR (AT91_MATRIX + 0x34) /* USB Pad Pull-Up Control Register */ -#define AT91_MATRIX_USBPUCR_PUON (1 << 30) /* USB Device PAD Pull-up Enable */ +#define AT91_MATRIX_M0PR_SHIFT 0 +#define AT91_MATRIX_M1PR_SHIFT 4 +#define AT91_MATRIX_M2PR_SHIFT 8 +#define AT91_MATRIX_M3PR_SHIFT 12 +#define AT91_MATRIX_M4PR_SHIFT 16 +#define AT91_MATRIX_M5PR_SHIFT 20 + +#define AT91_MATRIX_RCB0 (1 << 0) +#define AT91_MATRIX_RCB1 (1 << 1) + +#define AT91_MATRIX_CS1A_SDRAMC (1 << 1) +#define AT91_MATRIX_CS3A_SMC_SMARTMEDIA (1 << 3) +#define AT91_MATRIX_CS4A_SMC_CF1 (1 << 4) +#define AT91_MATRIX_CS5A_SMC_CF2 (1 << 5) +#define AT91_MATRIX_DBPUC (1 << 8) +#define AT91_MATRIX_VDDIOMSEL_1_8V (0 << 16) +#define AT91_MATRIX_VDDIOMSEL_3_3V (1 << 16)
#endif
Dear Hong Xu,
Applied to u-boot-atmel/master. Thanks. Reinhard
Hong Xu
Reinhard Meyer
