Pull request: u-boot-sunxi/master for 2024.01
Hi Tom,
please pull some more sunxi changes for this cycle:
the first few patches are some easy refactorings and fixes, most of them actually don't change the generated binaries at all. Then there is a defconfig for a new board, for which we just gained the .dts file from the last kernel DT sync. On top there is support for a new PMIC (AXP313), and LPDDR4 support for the Allwinner H616 SoC, both of which are needed to support new devices that appeared lately, especially cheap TV boxes.
While those are technically new features, they don't affect existing boards, for instance the LPDDR4 support code is guarded by a new DRAM type Kconfig variable. So the risk for regressions is very slim.
Gitlab CI passed, and I booted that briefly on some boards, including an H616 and an H618 one (with LPDDR4).
Thanks, Andre
========================================================= The following changes since commit da2e3196e4dc28298b58a018ace07f85eecd1652:
Merge patch series "arm: dts: k3-am6: Fix Ethernet/DMA" (2023-11-10 15:25:47 -0500)
https://source.denx.de/u-boot/custodians/u-boot-sunxi.git master
for you to fetch changes up to 4b02f0120a4bb2a5d7081aef8cef6a4ca57e9db2:
sunxi: H616: add LPDDR4 DRAM support (2023-11-12 18:04:32 +0000)
---------------------------------------------------------------- Andre Przywara (4): sunxi: board: simplify early PMIC setup conditions power: pmic: sunxi: add AXP313 SPL driver power: regulator: add AXP313 support sunxi: H616: DRAM: refactor mctl_phy_configure_odt()
Ludwig Kormann (1): arm: dts: icnova-a20-adb4006: Add board support
Mikhail Kalashnikov (1): sunxi: H616: add LPDDR4 DRAM support
Samuel Holland (5): net: sun8i_emac: Drop DM_GPIO checks sunxi: mmc: Move header to the driver directory clk: sunxi: Use the right symbol in the Makefile sunxi: mmc: Sort compatible strings numerically pinctrl: sunxi: Avoid using .bss for SPL
Tom Rini (1): arm: sunxi: Correct warning in board_fit_config_name_match
arch/arm/dts/Makefile | 1 + arch/arm/include/asm/arch-sunxi/dram_sun50i_h616.h | 2 + arch/arm/include/asm/arch-sunxi/mmc.h | 139 +--------- arch/arm/mach-sunxi/Kconfig | 17 ++ arch/arm/mach-sunxi/dram_sun50i_h616.c | 294 +++++++++++++++------ arch/arm/mach-sunxi/dram_timings/Makefile | 1 + .../arm/mach-sunxi/dram_timings/h616_lpddr4_2133.c | 95 +++++++ arch/arm/mach-sunxi/pmic_bus.c | 3 + board/sunxi/MAINTAINERS | 5 + board/sunxi/board.c | 38 ++- configs/icnova-a20-adb4006_defconfig | 21 ++ drivers/clk/Makefile | 2 +- drivers/mmc/sunxi_mmc.c | 6 +- drivers/mmc/sunxi_mmc.h | 138 ++++++++++ drivers/net/sun8i_emac.c | 10 - drivers/pinctrl/sunxi/pinctrl-sunxi.c | 2 +- drivers/power/Kconfig | 19 +- drivers/power/Makefile | 1 + drivers/power/axp313.c | 134 ++++++++++ drivers/power/pmic/axp.c | 1 + drivers/power/regulator/axp_regulator.c | 17 ++ include/axp_pmic.h | 1 + 22 files changed, 688 insertions(+), 259 deletions(-) create mode 100644 arch/arm/mach-sunxi/dram_timings/h616_lpddr4_2133.c create mode 100644 configs/icnova-a20-adb4006_defconfig create mode 100644 drivers/mmc/sunxi_mmc.h create mode 100644 drivers/power/axp313.c
On Sun, Nov 12, 2023 at 09:24:50PM +0000, Andre Przywara wrote:
Hi Tom,
Thanks, Andre
Andre Przywara
