[U-Boot] [PATCH v2 0/3] ARM: ti: DFU environment consolidation + AM57x DFU
This patch series consolidates DFU environment variables into newly created include/environment/ti/dfu.h
Then goes on to add DFU support for AM57x GP EVM.
Build tested using the following buildman commands:
$ tools/buildman/buildman -j 16 -b dfu -c 3 -o test am33xx $ tools/buildman/buildman -j 16 -b dfu -c 3 -o test omap
v1 submission here: https://www.mail-archive.com/u-boot@lists.denx.de/msg222838.html
Sekhar Nori (3): board: ti: am57xx-evm: fix build warnings ARM: ti: consolidate dfu environment variables ARM: am57xx_evm: enable DFU support
board/ti/am57xx/board.c | 20 ----------- configs/am57xx_evm_defconfig | 12 +++++++ configs/am57xx_hs_evm_defconfig | 12 +++++++ include/configs/am335x_evm.h | 33 +----------------- include/configs/am43xx_evm.h | 34 ++----------------- include/configs/am57xx_evm.h | 8 +++++ include/configs/dra7xx_evm.h | 51 ++-------------------------- include/configs/omap5_uevm.h | 37 ++------------------ include/environment/ti/dfu.h | 75 +++++++++++++++++++++++++++++++++++++++++ 9 files changed, 114 insertions(+), 168 deletions(-) create mode 100644 include/environment/ti/dfu.h
USB1 is not used on AM57xx GP EVM in device mode. Enabling DWC3 USB support for AM57xx EVM gives the following warnings:
CC board/ti/am57xx/board.o ../board/ti/am57xx/board.c:448:27: warning: 'usb_otg_ss1' defined but not used [-Wunused-variable] static struct dwc3_device usb_otg_ss1 = { ^ ../board/ti/am57xx/board.c:455:32: warning: 'usb_otg_ss1_glue' defined but not used [-Wunused-variable] static struct dwc3_omap_device usb_otg_ss1_glue = { ^ ../board/ti/am57xx/board.c:461:33: warning: 'usb_phy1_device' defined but not used [-Wunused-variable] static struct ti_usb_phy_device usb_phy1_device = {
Fix it by getting rid of USB1 related structures from board.c. They can be added back if there is a need for them.
Signed-off-by: Sekhar Nori nsekhar@ti.com Reviewed-by: Lokesh Vutla lokeshvutla@ti.com --- board/ti/am57xx/board.c | 20 -------------------- 1 file changed, 20 deletions(-)
diff --git a/board/ti/am57xx/board.c b/board/ti/am57xx/board.c index 64de60254136..f3e3f0bd3d60 100644 --- a/board/ti/am57xx/board.c +++ b/board/ti/am57xx/board.c @@ -447,26 +447,6 @@ int spl_start_uboot(void) #endif
#ifdef CONFIG_USB_DWC3 -static struct dwc3_device usb_otg_ss1 = { - .maximum_speed = USB_SPEED_SUPER, - .base = DRA7_USB_OTG_SS1_BASE, - .tx_fifo_resize = false, - .index = 0, -}; - -static struct dwc3_omap_device usb_otg_ss1_glue = { - .base = (void *)DRA7_USB_OTG_SS1_GLUE_BASE, - .utmi_mode = DWC3_OMAP_UTMI_MODE_SW, - .index = 0, -}; - -static struct ti_usb_phy_device usb_phy1_device = { - .pll_ctrl_base = (void *)DRA7_USB3_PHY1_PLL_CTRL, - .usb2_phy_power = (void *)DRA7_USB2_PHY1_POWER, - .usb3_phy_power = (void *)DRA7_USB3_PHY1_POWER, - .index = 0, -}; - static struct dwc3_device usb_otg_ss2 = { .maximum_speed = USB_SPEED_HIGH, .base = DRA7_USB_OTG_SS2_BASE,
hmm.. Isn't this already taken care by commit ca39bd8ce1343 ("am57xx: Remove unused variable warnings) ?
Thanks and regards, Lokesh
- .index = 0,
- .index = 0,
- .index = 0,
You are right. I sent these based off v2016.11. I will rebase to latest u-boot/master and resend.
Thanks, Sekhar
Introduce include/environment/ti/dfu.h that consolidates environment variable definitions for various TI boards that support DFU today.
Tested on AM335x EVM, AM437x SK EVM and DRA74x EVM by using DFU to write to SD card.
Signed-off-by: Sekhar Nori nsekhar@ti.com --- include/configs/am335x_evm.h | 33 +------------------ include/configs/am43xx_evm.h | 34 ++------------------ include/configs/dra7xx_evm.h | 51 ++---------------------------- include/configs/omap5_uevm.h | 37 ++-------------------- include/environment/ti/dfu.h | 75 ++++++++++++++++++++++++++++++++++++++++++++ 5 files changed, 82 insertions(+), 148 deletions(-) create mode 100644 include/environment/ti/dfu.h
diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index ec70b72970e3..5213184c7ba9 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -17,6 +17,7 @@ #define __CONFIG_AM335X_EVM_H
#include <configs/ti_am335x_common.h> +#include <environment/ti/dfu.h>
#ifndef CONFIG_SPL_BUILD # define CONFIG_TIMESTAMP @@ -330,38 +331,6 @@
/* USB Device Firmware Update support */ #ifndef CONFIG_SPL_BUILD -#define DFU_ALT_INFO_MMC \ - "dfu_alt_info_mmc=" \ - "boot part 0 1;" \ - "rootfs part 0 2;" \ - "MLO fat 0 1;" \ - "MLO.raw raw 0x100 0x100;" \ - "u-boot.img.raw raw 0x300 0x400;" \ - "spl-os-args.raw raw 0x80 0x80;" \ - "spl-os-image.raw raw 0x900 0x2000;" \ - "spl-os-args fat 0 1;" \ - "spl-os-image fat 0 1;" \ - "u-boot.img fat 0 1;" \ - "uEnv.txt fat 0 1\0" -#ifdef CONFIG_NAND -#define DFU_ALT_INFO_NAND \ - "dfu_alt_info_nand=" \ - "SPL part 0 1;" \ - "SPL.backup1 part 0 2;" \ - "SPL.backup2 part 0 3;" \ - "SPL.backup3 part 0 4;" \ - "u-boot part 0 5;" \ - "u-boot-spl-os part 0 6;" \ - "kernel part 0 8;" \ - "rootfs part 0 9\0" -#else -#define DFU_ALT_INFO_NAND "" -#endif -#define DFU_ALT_INFO_RAM \ - "dfu_alt_info_ram=" \ - "kernel ram 0x80200000 0xD80000;" \ - "fdt ram 0x80F80000 0x80000;" \ - "ramdisk ram 0x81000000 0x4000000\0" #define DFUARGS \ "dfu_alt_info_emmc=rawemmc raw 0 3751936\0" \ DFU_ALT_INFO_MMC \ diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index 20f207c3f3a7..256182a9704b 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -14,6 +14,7 @@ #define CONFIG_MAX_RAM_BANK_SIZE (1024 << 21) /* 2GB */ #define CONFIG_SYS_TIMERBASE 0x48040000 /* Use Timer2 */
+#include <environment/ti/dfu.h> #include <asm/arch/omap.h>
/* NS16550 Configuration */ @@ -122,43 +123,12 @@
#ifndef CONFIG_SPL_BUILD /* USB Device Firmware Update support */ - -#define DFU_ALT_INFO_MMC \ - "dfu_alt_info_mmc=" \ - "boot part 0 1;" \ - "rootfs part 0 2;" \ - "MLO fat 0 1;" \ - "spl-os-args fat 0 1;" \ - "spl-os-image fat 0 1;" \ - "u-boot.img fat 0 1;" \ - "uEnv.txt fat 0 1\0" - -#define DFU_ALT_INFO_EMMC \ - "dfu_alt_info_emmc=" \ - "MLO raw 0x100 0x100 mmcpart 0;" \ - "u-boot.img raw 0x300 0x1000 mmcpart 0\0" - -#define DFU_ALT_INFO_RAM \ - "dfu_alt_info_ram=" \ - "kernel ram 0x80200000 0x4000000;" \ - "fdt ram 0x80f80000 0x80000;" \ - "ramdisk ram 0x81000000 0x4000000\0" - -#define DFU_ALT_INFO_QSPI \ - "dfu_alt_info_qspi=" \ - "u-boot.bin raw 0x0 0x080000;" \ - "u-boot.backup raw 0x080000 0x080000;" \ - "u-boot-spl-os raw 0x100000 0x010000;" \ - "u-boot-env raw 0x110000 0x010000;" \ - "u-boot-env.backup raw 0x120000 0x010000;" \ - "kernel raw 0x130000 0x800000\0" - #define DFUARGS \ "dfu_bufsiz=0x10000\0" \ DFU_ALT_INFO_MMC \ DFU_ALT_INFO_EMMC \ DFU_ALT_INFO_RAM \ - DFU_ALT_INFO_QSPI + DFU_ALT_INFO_QSPI_XIP #else #define DFUARGS #endif diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index 798002d4cd88..2d703a757db7 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -12,6 +12,8 @@ #ifndef __CONFIG_DRA7XX_EVM_H #define __CONFIG_DRA7XX_EVM_H
+#include <environment/ti/dfu.h> + #define CONFIG_DRA7XX #define CONFIG_BOARD_EARLY_INIT_F
@@ -68,50 +70,6 @@ "name=ipu2,size=1M,uuid=${uuid_gpt_ipu2};" \ "name=userdata,size=-,uuid=${uuid_gpt_userdata}"
-#define DFU_ALT_INFO_MMC \ - "dfu_alt_info_mmc=" \ - "boot part 0 1;" \ - "rootfs part 0 2;" \ - "MLO fat 0 1;" \ - "MLO.raw raw 0x100 0x100;" \ - "u-boot.img.raw raw 0x300 0x400;" \ - "spl-os-args.raw raw 0x80 0x80;" \ - "spl-os-image.raw raw 0x900 0x2000;" \ - "spl-os-args fat 0 1;" \ - "spl-os-image fat 0 1;" \ - "u-boot.img fat 0 1;" \ - "uEnv.txt fat 0 1\0" - -#define DFU_ALT_INFO_EMMC \ - "dfu_alt_info_emmc=" \ - "rawemmc raw 0 3751936;" \ - "boot part 1 1;" \ - "rootfs part 1 2;" \ - "MLO fat 1 1;" \ - "MLO.raw raw 0x100 0x100;" \ - "u-boot.img.raw raw 0x300 0x400;" \ - "spl-os-args.raw raw 0x80 0x80;" \ - "spl-os-image.raw raw 0x900 0x2000;" \ - "spl-os-args fat 1 1;" \ - "spl-os-image fat 1 1;" \ - "u-boot.img fat 1 1;" \ - "uEnv.txt fat 1 1\0" - -#define DFU_ALT_INFO_RAM \ - "dfu_alt_info_ram=" \ - "kernel ram 0x80200000 0x4000000;" \ - "fdt ram 0x80f80000 0x80000;" \ - "ramdisk ram 0x81000000 0x4000000\0" - -#define DFU_ALT_INFO_QSPI \ - "dfu_alt_info_qspi=" \ - "MLO raw 0x0 0x040000;" \ - "u-boot.img raw 0x040000 0x0100000;" \ - "u-boot-spl-os raw 0x140000 0x080000;" \ - "u-boot-env raw 0x1C0000 0x010000;" \ - "u-boot-env.backup raw 0x1D0000 0x010000;" \ - "kernel raw 0x1E0000 0x800000\0" - #define DFUARGS \ "dfu_bufsiz=0x10000\0" \ DFU_ALT_INFO_MMC \ @@ -134,11 +92,6 @@ #ifdef CONFIG_SPL_DFU_SUPPORT #define CONFIG_SPL_LOAD_FIT_ADDRESS 0x80200000 #define CONFIG_SPL_HASH_SUPPORT -#define DFU_ALT_INFO_RAM \ - "dfu_alt_info_ram=" \ - "kernel ram 0x80200000 0x4000000;" \ - "fdt ram 0x80f80000 0x80000;" \ - "ramdisk ram 0x81000000 0x4000000\0" #define DFUARGS \ "dfu_bufsiz=0x10000\0" \ DFU_ALT_INFO_RAM diff --git a/include/configs/omap5_uevm.h b/include/configs/omap5_uevm.h index 22614fb9c3a0..736d8043aae3 100644 --- a/include/configs/omap5_uevm.h +++ b/include/configs/omap5_uevm.h @@ -12,6 +12,8 @@ #ifndef __CONFIG_OMAP5_EVM_H #define __CONFIG_OMAP5_EVM_H
+#include <environment/ti/dfu.h> + #ifndef CONFIG_SPL_BUILD /* Define the default GPT table for eMMC */ #define PARTS_DEFAULT \ @@ -19,41 +21,6 @@ "name=rootfs,start=2MiB,size=-,uuid=${uuid_gpt_rootfs}" #endif
-#define DFU_ALT_INFO_MMC \ - "dfu_alt_info_mmc=" \ - "boot part 0 1;" \ - "rootfs part 0 2;" \ - "MLO fat 0 1;" \ - "MLO.raw raw 0x100 0x100;" \ - "u-boot.img.raw raw 0x300 0x400;" \ - "spl-os-args.raw raw 0x80 0x80;" \ - "spl-os-image.raw raw 0x900 0x2000;" \ - "spl-os-args fat 0 1;" \ - "spl-os-image fat 0 1;" \ - "u-boot.img fat 0 1;" \ - "uEnv.txt fat 0 1\0" - -#define DFU_ALT_INFO_EMMC \ - "dfu_alt_info_emmc=" \ - "rawemmc raw 0 3751936;" \ - "boot part 1 1;" \ - "rootfs part 1 2;" \ - "MLO fat 1 1;" \ - "MLO.raw raw 0x100 0x100;" \ - "u-boot.img.raw raw 0x300 0x400;" \ - "spl-os-args.raw raw 0x80 0x80;" \ - "spl-os-image.raw raw 0x900 0x2000;" \ - "spl-os-args fat 1 1;" \ - "spl-os-image fat 1 1;" \ - "u-boot.img fat 1 1;" \ - "uEnv.txt fat 1 1\0" - -#define DFU_ALT_INFO_RAM \ - "dfu_alt_info_ram=" \ - "kernel ram 0x80200000 0x4000000;" \ - "fdt ram 0x80f80000 0x80000;" \ - "ramdisk ram 0x81000000 0x4000000\0" - #define DFUARGS \ "dfu_bufsiz=0x10000\0" \ DFU_ALT_INFO_MMC \ diff --git a/include/environment/ti/dfu.h b/include/environment/ti/dfu.h new file mode 100644 index 000000000000..caf71a3fe630 --- /dev/null +++ b/include/environment/ti/dfu.h @@ -0,0 +1,75 @@ +/* + * Copyright (C) 2016 Texas Instruments Incorporated - http://www.ti.com + * + * Environment variable definitions for DFU on TI boards. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#define DFU_ALT_INFO_MMC \ + "dfu_alt_info_mmc=" \ + "boot part 0 1;" \ + "rootfs part 0 2;" \ + "MLO fat 0 1;" \ + "MLO.raw raw 0x100 0x100;" \ + "u-boot.img.raw raw 0x300 0x400;" \ + "spl-os-args.raw raw 0x80 0x80;" \ + "spl-os-image.raw raw 0x900 0x2000;" \ + "spl-os-args fat 0 1;" \ + "spl-os-image fat 0 1;" \ + "u-boot.img fat 0 1;" \ + "uEnv.txt fat 0 1\0" + +#define DFU_ALT_INFO_EMMC \ + "dfu_alt_info_emmc=" \ + "rawemmc raw 0 3751936;" \ + "boot part 1 1;" \ + "rootfs part 1 2;" \ + "MLO fat 1 1;" \ + "MLO.raw raw 0x100 0x100;" \ + "u-boot.img.raw raw 0x300 0x1000;" \ + "spl-os-args.raw raw 0x80 0x80;" \ + "spl-os-image.raw raw 0x900 0x2000;" \ + "spl-os-args fat 1 1;" \ + "spl-os-image fat 1 1;" \ + "u-boot.img fat 1 1;" \ + "uEnv.txt fat 1 1\0" + +#ifdef CONFIG_NAND +#define DFU_ALT_INFO_NAND \ + "dfu_alt_info_nand=" \ + "SPL part 0 1;" \ + "SPL.backup1 part 0 2;" \ + "SPL.backup2 part 0 3;" \ + "SPL.backup3 part 0 4;" \ + "u-boot part 0 5;" \ + "u-boot-spl-os part 0 6;" \ + "kernel part 0 8;" \ + "rootfs part 0 9\0" +#else +#define DFU_ALT_INFO_NAND "" +#endif + +#define DFU_ALT_INFO_RAM \ + "dfu_alt_info_ram=" \ + "kernel ram 0x80200000 0x4000000;" \ + "fdt ram 0x80f80000 0x80000;" \ + "ramdisk ram 0x81000000 0x4000000\0" + +#define DFU_ALT_INFO_QSPI_XIP \ + "dfu_alt_info_qspi=" \ + "u-boot.bin raw 0x0 0x080000;" \ + "u-boot.backup raw 0x080000 0x080000;" \ + "u-boot-spl-os raw 0x100000 0x010000;" \ + "u-boot-env raw 0x110000 0x010000;" \ + "u-boot-env.backup raw 0x120000 0x010000;" \ + "kernel raw 0x130000 0x800000\0" + +#define DFU_ALT_INFO_QSPI \ + "dfu_alt_info_qspi=" \ + "MLO raw 0x0 0x040000;" \ + "u-boot.img raw 0x040000 0x0100000;" \ + "u-boot-spl-os raw 0x140000 0x080000;" \ + "u-boot-env raw 0x1C0000 0x010000;" \ + "u-boot-env.backup raw 0x1D0000 0x010000;" \ + "kernel raw 0x1E0000 0x800000\0"
AM57xx GP EVM has USB2 port of the SoC exposed as USB client port.
It is useful to be able to use this port for USB DFU downloads.
Enable USB DFU support. Tested on AM57x GP EVM Rev A3 using DFU to download to connected SD card.
configs for HS version of the AM57x EVM are included in the patch but not really tested.
Signed-off-by: Sekhar Nori nsekhar@ti.com --- configs/am57xx_evm_defconfig | 12 ++++++++++++ configs/am57xx_hs_evm_defconfig | 12 ++++++++++++ include/configs/am57xx_evm.h | 8 ++++++++ 3 files changed, 32 insertions(+)
diff --git a/configs/am57xx_evm_defconfig b/configs/am57xx_evm_defconfig index 06f7f7677222..5b9e2fa7ea54 100644 --- a/configs/am57xx_evm_defconfig +++ b/configs/am57xx_evm_defconfig @@ -26,6 +26,9 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_DFU_RAM=y +CONFIG_DFU_MMC=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y @@ -60,5 +63,14 @@ CONFIG_TI_QSPI=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GADGET=y +CONFIG_USB_DWC3_OMAP=y +CONFIG_USB_DWC3_PHY_OMAP=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_G_DNL_MANUFACTURER="Texas Instruments" +CONFIG_G_DNL_VENDOR_NUM=0x0451 +CONFIG_G_DNL_PRODUCT_NUM=0xd022 CONFIG_USB_STORAGE=y CONFIG_SPL_OF_LIBFDT=y diff --git a/configs/am57xx_hs_evm_defconfig b/configs/am57xx_hs_evm_defconfig index 6631bb25a8e2..a583b72fccdb 100644 --- a/configs/am57xx_hs_evm_defconfig +++ b/configs/am57xx_hs_evm_defconfig @@ -27,6 +27,9 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_DFU_RAM=y +CONFIG_DFU_MMC=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y @@ -55,5 +58,14 @@ CONFIG_TI_QSPI=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GADGET=y +CONFIG_USB_DWC3_OMAP=y +CONFIG_USB_DWC3_PHY_OMAP=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_G_DNL_MANUFACTURER="Texas Instruments" +CONFIG_G_DNL_VENDOR_NUM=0x0451 +CONFIG_G_DNL_PRODUCT_NUM=0xd022 CONFIG_USB_STORAGE=y CONFIG_SPL_OF_LIBFDT=y diff --git a/include/configs/am57xx_evm.h b/include/configs/am57xx_evm.h index d865f415bccd..80a3c5d67cf1 100644 --- a/include/configs/am57xx_evm.h +++ b/include/configs/am57xx_evm.h @@ -12,6 +12,8 @@ #ifndef __CONFIG_AM57XX_EVM_H #define __CONFIG_AM57XX_EVM_H
+#include <environment/ti/dfu.h> + #define CONFIG_AM57XX
#ifdef CONFIG_SPL_BUILD @@ -41,6 +43,12 @@ "uuid_disk=${uuid_gpt_disk};" \ "name=rootfs,start=2MiB,size=-,uuid=${uuid_gpt_rootfs}"
+#define DFUARGS \ + "dfu_bufsiz=0x10000\0" \ + DFU_ALT_INFO_MMC \ + DFU_ALT_INFO_EMMC \ + DFU_ALT_INFO_RAM \ + #include <configs/ti_omap5_common.h>
/* Enhance our eMMC support / experience. */
Lokesh Vutla
Sekhar Nori
