[U-Boot] Pull request - fpga
Hi Tom and Albert,
I have created fpga branch. It is based on zynq patches(and request) I sent last week. The reason why it is based on it is that new zynq fpga driver and changes in zynq I have done. Just talk to each other and be aware that this fpga patchset is based on zynq one.
Thanks, Michal
The following changes since commit 8934f7846501070a5b01c1fab5db27559e9d70d1:
i2c: zynq: Add support for Xilinx Zynq (2013-04-30 11:39:28 +0200)
git://www.denx.de/git/u-boot-microblaze.git fpga
for you to fetch changes up to b03b25caea1ff3a501161f5bc1ad5e5b5b124e0c:
fpga: Remove all CONFIG_SYS_* fpga related options (2013-05-06 10:41:30 +0200)
---------------------------------------------------------------- Michal Simek (9): fpga: Clean coding style fpga: Fix debug message compilation error cmd: fpga: Clean coding style cmd: fpga: Move fpga_loadbitstream to fpga.c fpga: Change the first parameter in fpga_loadbitstream cmd: fpga: Do not include net.h fpga: zynq: Add support for loading bitstream fpga: Check device name against bitstream name fpga: Remove all CONFIG_SYS_* fpga related options
arch/arm/cpu/armv7/zynq/slcr.c | 35 ++++++++++++ arch/arm/include/asm/arch-zynq/hardware.h | 10 +++- arch/arm/include/asm/arch-zynq/sys_proto.h | 3 + board/xilinx/zynq/board.c | 37 ++++++++++++ common/cmd_fpga.c | 254 ++++++++++++++++++++++++++------------------------------------------------------- drivers/fpga/Makefile | 1 + drivers/fpga/fpga.c | 225 +++++++++++++++++++++++++++++++++++------------------------------------- drivers/fpga/xilinx.c | 146 +++++++++++++++++++++++++++++++++++++++++++++++ drivers/fpga/zynqpl.c | 355 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ include/altera.h | 17 ------ include/configs/M54455EVB.h | 2 +- include/configs/MERGERBOX.h | 2 +- include/configs/MVBC_P.h | 2 +- include/configs/MVBLM7.h | 2 +- include/configs/MVSMR.h | 2 +- include/configs/omap3_mvblx.h | 2 +- include/configs/zynq.h | 6 ++ include/fpga.h | 13 +---- include/lattice.h | 3 - include/xilinx.h | 25 +------- include/zynqpl.h | 59 +++++++++++++++++++ 21 files changed, 848 insertions(+), 353 deletions(-) create mode 100644 drivers/fpga/zynqpl.c create mode 100644 include/zynqpl.h
Hi Michal,
On Mon, 06 May 2013 10:50:44 +0200, Michal Simek monstr@monstr.eu wrote:
Hi Tom and Albert,
Thanks, Michal
As this is related to the Zynq series and Tom has reviewed it too, I'll pull it in the ARM tree right after I pull the Zynq patches.
Amicalement,
Hi Michal,
Hi Tom and Albert,
Thanks, Michal
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
Michal Simek
