[PATCH] arm: imx: imx8mq: add support to get values for more clocks
Return the root clock values for MXC_CSPI_CLK, MXC_I2C_CLK, MXC_UART_CLK and MXC_QSPI_CLK.
At least for the I2C clock the missing support leads to a wrong configured I2C frequency. The expected value is 100kHz but the resulting value is about 1MHz.
Signed-off-by: Heiko Thiery heiko.thiery@gmail.com ---
More information and measurements about the wrong configure I2C frequency can be found here: https://lists.denx.de/pipermail/u-boot/2021-September/460176.html
arch/arm/mach-imx/imx8m/clock_imx8mq.c | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/arch/arm/mach-imx/imx8m/clock_imx8mq.c b/arch/arm/mach-imx/imx8m/clock_imx8mq.c index 60e2218a3c..9db62b944e 100644 --- a/arch/arm/mach-imx/imx8m/clock_imx8mq.c +++ b/arch/arm/mach-imx/imx8m/clock_imx8mq.c @@ -359,10 +359,18 @@ unsigned int mxc_get_clock(enum mxc_clock clk) clock_get_target_val(IPG_CLK_ROOT, &val); val = val & 0x3; return get_root_clk(AHB_CLK_ROOT) / (val + 1); + case MXC_CSPI_CLK: + return get_root_clk(ECSPI1_CLK_ROOT); case MXC_ESDHC_CLK: return get_root_clk(USDHC1_CLK_ROOT); case MXC_ESDHC2_CLK: return get_root_clk(USDHC2_CLK_ROOT); + case MXC_I2C_CLK: + return get_root_clk(I2C1_CLK_ROOT); + case MXC_UART_CLK: + return get_root_clk(UART1_CLK_ROOT); + case MXC_QSPI_CLK: + return get_root_clk(QSPI_CLK_ROOT); default: return get_root_clk(clk); }
More information and measurements about the wrong configure I2C frequency can be found here: https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.denx...
- case MXC_CSPI_CLK:
case MXC_ESDHC_CLK: return get_root_clk(USDHC1_CLK_ROOT); case MXC_ESDHC2_CLK: return get_root_clk(USDHC2_CLK_ROOT);return get_root_clk(ECSPI1_CLK_ROOT);
- case MXC_I2C_CLK:
- case MXC_UART_CLK:
- case MXC_QSPI_CLK:
default: return get_root_clk(clk); }return get_root_clk(QSPI_CLK_ROOT);
Reviewed-by: Peng Fan peng.fan@nxp.com
Am Mi., 15. Sept. 2021 um 04:54 Uhr schrieb Peng Fan (OSS) peng.fan@oss.nxp.com:
case MXC_CSPI_CLK:
case MXC_I2C_CLK:
case MXC_UART_CLK:
case MXC_QSPI_CLK:
Any news on that?
Hi Heiko,
Reviewed-by: Fabio Estevam festevam@gmail.com
Return the root clock values for MXC_CSPI_CLK, MXC_I2C_CLK, MXC_UART_CLK and MXC_QSPI_CLK. At least for the I2C clock the missing support leads to a wrong configured I2C frequency. The expected value is 100kHz but the resulting value is about 1MHz. Signed-off-by: Heiko Thiery heiko.thiery@gmail.com Reviewed-by: Peng Fan peng.fan@nxp.com Reviewed-by: Fabio Estevam festevam@gmail.com
Best regards, Stefano Babic
Fabio Estevam
Heiko Thiery
Peng Fan (OSS)
sbabic@denx.de
