[U-Boot-Users] build failure in tools - missing CFG_ENV_SIZE ?
All,
after getting a clean u-boot clone (1.3.3 today) I get a compile error in "tools" subdir.
I've tried 2 different boards making a "TQM5200_config" and "MPC8349ITX_config" - just to make sure ...
"make CROSS_COMPILE=ppc_6xx- "
cross-compiler is gcc 4.0 as shipped with ELDK 4.1.
Am I missing something ?
Since environment.c includes config.h which pulls in board config everything should be fine.
Can someome help me out please ?
---- make[1]: Entering directory `/home/u-boot.git/tools' gcc -g -idirafter /home/u-boot.git/include -idirafter /home/u-boot.git/include2 -idirafter /home/u-boot.git/include -DTEXT_BASE=0xFC000000 -DUSE_HOSTCC -c -o environment.o environment.c In file included from environment.c:30: /home/u-boot.git/include/environment.h:107: error: 'CFG_ENV_SIZE' undeclared here (not in a function) make[1]: *** [environment.o] Error 1 make[1]: Leaving directory `/home/u-boot.git/tools' make: *** [tools] Error 2
regards, Andre Schwarz
MATRIX VISION GmbH, Talstraße 16, DE-71570 Oppenweiler - Registergericht: Amtsgericht Stuttgart, HRB 271090 Geschäftsführer: Gerhard Thullner, Werner Armingeon, Uwe Furtner
"make CROSS_COMPILE=3Dppc_6xx- "
Hm. Let's see:
-> MAKEALL TQM5200 MPC8349ITX Configuring for TQM5200 board... text data bss dec hex filename 326532 32456 315024 674012 a48dc ./u-boot Configuring for MPC8349ITX board... text data bss dec hex filename 217741 15388 223684 456813 6f86d ./u-boot
That's U-Boot 1.3.3-00117-g8155efb
Sorry, I cannot reproduce the problem.
Wolfgang,
thanks for your verification. Trying to do it your way gives :
nova u-boot-clean # CROSS_COMPILE=ppc_6xx- sh MAKEALL TQM5200 MPC8349ITX Configuring for TQM5200 board... In file included from environment.c:30: /home/u-boot-clean/include/environment.h:107: error: 'CFG_ENV_SIZE' undeclared here (not in a function) make[1]: *** [environment.o] Error 1 make: *** [tools] Error 2 ppc_6xx-size: './u-boot': No such file Configuring for MPC8349ITX board... In file included from environment.c:30: /home/u-boot-clean/include/environment.h:107: error: 'CFG_ENV_SIZE' undeclared here (not in a function) make[1]: *** [environment.o] Error 1 make: *** [tools] Error 2 ppc_6xx-size: './u-boot': No such file
Obviously it's a problem regarding include mechanism. Changing line 28 in common/environment.c ( <config.h> -> "../include/config.h") gives positive result :
nova u-boot-clean # CROSS_COMPILE=ppc_6xx- sh MAKEALL TQM5200 MPC8349ITX Configuring for TQM5200 board... text data bss dec hex filename 326532 32464 315024 674020 a48e4 ./u-boot Configuring for MPC8349ITX board... text data bss dec hex filename 217741 15388 223684 456813 6f86d ./u-boot
Unfortunately I'm not a Makefile expert ... do you have any ideas ?
regards, Andre
Hm. Let's see:
So what exactly is the difference between your source tree and toolchain and mine?
I don't see why or which changes would be necessary as it's working fine here...
I'm running ELDK 4.1 and latest u-boot from git.
How am I supposed to know if you do not ? :-( I'll stick to the local change of the #include statement.
cheers, Andre
Hi Andre,
u-boot-users-bounces@lists.sourceforge.net wrote on :
I'm also able to build (top of) U-Boot for the TQM5200 with ELDK4.1:
mkr@tq-sewsrv-4:~/git/u-boot_denx> echo $CROSS_COMPILE ppc_82xx- mkr@tq-sewsrv-4:~/git/u-boot_denx> ./MAKEALL TQM5200 Configuring for TQM5200 board... md5.c: In function `MD5Update': md5.c:95: warning: implicit declaration of function `memmove' md5.c: In function `MD5Final': md5.c:143: warning: implicit declaration of function `memset' sha1.c: In function `sha1_update': sha1.c:249: warning: implicit declaration of function `memcpy' sha1.c: In function `sha1_hmac': sha1.c:360: warning: implicit declaration of function `memset' text data bss dec hex filename 326532 32456 315024 674012 a48dc ./u-boot mkr@tq-sewsrv-4:~/git/u-boot_denx>
I don't know, why I get the warnings (they appeared first several weeks ago, and I get it for every build, since then). But since the resulting U-Boot runs fine, there was no pressure (and no time) to dig for the reason of the warnings ...
Best Regards, Martin Krause
-- TQ-Systems GmbH Muehlstrasse 2, Gut Delling, D-82229 Seefeld Amtsgericht Muenchen, HRB 105 018, UST-IdNr. DE 811 607 913 Geschaeftsfuehrer: Dipl.-Ing. (FH) Detlef Schneider, Dipl.-Ing. (FH) Ruediger Stahl http://www.tq-group.com
Martin,
thanks for the info. The misbehaviour surely has its cause on my system setup.
I simply don't know why ... it's driving me mad.
Just wanted to port another board from my local v1.3.1 and submit a patch during this merge window. But the e1000 driver isn't working anymore. Making a diff gives "files are identical".
There's something utterly wrong ... time to go home and prepare for soccer :-(
cheers, Andre
Martin Krause schrieb:
Hi Andre,
Hello,
in message 47F3F98010FF784EBEE6526EAAB078D10635DFDE@tq-mailsrv.tq-net.de you wrote:
Can you please check if this patch fixes the warnings? Thanks in advance.
diff --git a/lib_generic/md5.c b/lib_generic/md5.c index 78ef475..a9aae46 100644 --- a/lib_generic/md5.c +++ b/lib_generic/md5.c @@ -27,6 +27,8 @@
#ifndef USE_HOSTCC #include <common.h> +#else +#include <string.h> #endif /* USE_HOSTCC */ #include <watchdog.h> #include <linux/types.h> diff --git a/lib_generic/sha1.c b/lib_generic/sha1.c index c8ef4d2..a192e5f 100644 --- a/lib_generic/sha1.c +++ b/lib_generic/sha1.c @@ -31,6 +31,8 @@
#ifndef USE_HOSTCC #include <common.h> +#else +#include <string.h> #endif /* USE_HOSTCC */ #include <watchdog.h> #include <linux/string.h>
Viele Grüße,
Hello,
wd@denx.de wrote on Friday, June 06, 2008 2:28 PM:
This helped, thanks! With your patch I get a clean build:
mkr@tq-sewsrv-4:~/git/u-boot_denx> ./MAKEALL TQM5200 Configuring for TQM5200 board... text data bss dec hex filename 326532 32464 315024 674020 a48e4 ./u-boot mkr@tq-sewsrv-4:~/git/u-boot_denx>
But why did I get the warning without the patch and you not (both build with ELDK4.1 and top-of-U-Boot)?
In message 47F3F98010FF784EBEE6526EAAB078D10635DFDF@tq-mailsrv.tq-net.de you wrote:
Good. So I will pull in that patch.
My build environment was Fedora 6 with gcc version 4.1.2; you most probably use a nother Linux distro and other tools.
Me too. Also tried ELDK 4.0 and 4.2, with the same results.
I guess it must be some local changes in your environment.
Andre Schwarz
Martin Krause
