[U-Boot] dtb build issue on U-Boot
I notice that the dtb content in spl/u-boot-spl.bin and u-boot.bin not
able to update after I modify the dts file and make again, I have to
"make clean" first, and then the "make" can update the dtb content
to output binary, which lead to bad efficiency when try to modify dts.
I have try below command, the dtb file also not updated before "make clean".
dtc -I dtb -O dts spl/u-boot-spl.dtb
Is there any one can help fix this issue?
Thanks,
- Kever
+Masahiro
I have noticed this too, and also that changing a .dtsi file is not noticed.
Probably it is missing a dependency in the makefile.
Hi Kever, Simon, Sorry for my late reply.
2017-06-07 6:16 GMT+09:00 Simon Glass sjg@chromium.org:
+Masahiro
I could not reproduce the issue for me.
Editing a DT file and re-compiling gave me the expected result.
masahiro@pug:~/ref/u-boot$ make -s mrproper masahiro@pug:~/ref/u-boot$ make -s CROSS_COMPILE=aarch64-linux-gnu- uniphier_v8_defconfig all masahiro@pug:~/ref/u-boot$ nano arch/arm/dts/uniphier-ld20.dtsi (add hello-world property) masahiro@pug:~/ref/u-boot$ make CROSS_COMPILE=aarch64-linux-gnu- CHK include/config/uboot.release CHK include/generated/version_autogenerated.h CHK include/generated/timestamp_autogenerated.h UPD include/generated/timestamp_autogenerated.h CHK include/generated/generic-asm-offsets.h CHK include/generated/asm-offsets.h HOSTCC tools/mkenvimage.o HOSTLD tools/mkenvimage HOSTCC tools/fit_image.o HOSTCC tools/image-host.o HOSTCC tools/dumpimage.o HOSTLD tools/dumpimage HOSTCC tools/mkimage.o HOSTLD tools/mkimage CC arch/arm/cpu/armv8/fwcall.o LD arch/arm/cpu/armv8/built-in.o CC cmd/version.o CHK cmd/config_data_gz.h CHK cmd/config_data_size.h LD cmd/built-in.o CC common/main.o LD common/built-in.o CC lib/efi_loader/helloworld.o LD lib/efi_loader/helloworld.so OBJCOPY lib/efi_loader/helloworld.efi CC lib/smbios.o CC lib/display_options.o LD lib/built-in.o LD u-boot OBJCOPY u-boot.srec OBJCOPY u-boot-nodtb.bin start=$(aarch64-linux-gnu-nm u-boot | grep __rel_dyn_start | cut -f 1 -d ' '); end=$(aarch64-linux-gnu-nm u-boot | grep __rel_dyn_end | cut -f 1 -d ' '); tools/relocate-rela u-boot-nodtb.bin 0x84000000 $start $end DTC arch/arm/dts/uniphier-ld20-ref.dtb make[2]: 'arch/arm/dts/uniphier-ld20-ref.dtb' is up to date. SHIPPED dts/dt.dtb CAT u-boot-dtb.bin COPY u-boot.bin SYM u-boot.sym MKIMAGE u-boot.img COPY u-boot.dtb MKIMAGE u-boot-dtb.img CFGCHK u-boot.cfg masahiro@pug:~/ref/u-boot$ dtc -I dtb -O dts u-boot.dtb | grep hello-world hello-world;
If I am missing something, could you tell me the command you used for reproducing the problem?
Hi Masahiro,
On Tue, Jun 13, 2017 at 2:03 PM, Masahiro Yamada yamada.masahiro@socionext.com wrote:
+Masahiro
I just tried on x86 minnowmax, and looks the problem exists.
$ vim arch/x86/dts/minnowmax.dts $ make -j CHK include/config/uboot.release CHK include/generated/timestamp_autogenerated.h UPD include/generated/timestamp_autogenerated.h CHK include/generated/version_autogenerated.h CHK include/generated/generic-asm-offsets.h CHK include/generated/asm-offsets.h HOSTCC tools/mkenvimage.o HOSTCC tools/fit_image.o HOSTCC tools/image-host.o HOSTCC tools/dumpimage.o HOSTCC tools/mkimage.o HOSTLD tools/mkenvimage HOSTLD tools/dumpimage HOSTLD tools/mkimage HOSTLD tools/fit_info HOSTLD tools/fit_check_sign CC cmd/version.o CC common/main.o LD cmd/built-in.o LD common/built-in.o CC lib/smbios.o CC lib/display_options.o CC lib/efi_loader/helloworld.o LD lib/efi_loader/helloworld.so OBJCOPY lib/efi_loader/helloworld.efi LD lib/built-in.o LD u-boot OBJCOPY u-boot.srec OBJCOPY u-boot-nodtb.bin SYM u-boot.sym OBJCOPY u-boot-x86-16bit.bin DTC arch/x86/dts/minnowmax.dtb make[2]: `arch/x86/dts/minnowmax.dtb' is up to date. SHIPPED dts/dt.dtb CAT u-boot-dtb.bin COPY u-boot.dtb COPY u-boot.bin BINMAN u-boot.rom CFGCHK u-boot.cfg
Regards, Bin
Hi Masahiro,
+Masahiro
I try with aarch64, and the dtb update when dts changed, maybe issue only happen in armv7 for arm platform?
Thanks, - Kever
Bin Meng
Kever Yang
Masahiro Yamada
