[PATCH v2 0/2] Fix issues for small sized data reads
Change flush cache to invalidate cache and also fix cache related issues are seen with small sized data reads. Due to this, proper data is not read. Also some times sf probe fails randomly.
Ashok Reddy Soma (1): spi: zynqmp_qspi: Change flush cache to invalidate cache
Venkatesh Yadav Abbarapu (1): spi: zynqmp_qspi: Workaround for small data cache issue
drivers/spi/zynqmp_gqspi.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
Before DMA read, ideally cache should be invalidated, so that data from memory will be updated to cache after DMA is completed. But flush_dcache_range is being used which is incorrect. Change flush_dcache_range to invalidate_dcache_range.
Signed-off-by: Ashok Reddy Soma ashok.reddy.soma@amd.com Signed-off-by: Venkatesh Yadav Abbarapu venkatesh.abbarapu@amd.com --- drivers/spi/zynqmp_gqspi.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/spi/zynqmp_gqspi.c b/drivers/spi/zynqmp_gqspi.c index c4aee279aa..a506d15227 100644 --- a/drivers/spi/zynqmp_gqspi.c +++ b/drivers/spi/zynqmp_gqspi.c @@ -690,7 +690,7 @@ static int zynqmp_qspi_start_dma(struct zynqmp_qspi_priv *priv, writel(GQSPI_DMA_DST_I_STS_MASK, &dma_regs->dmaier); addr = (unsigned long)buf; size = roundup(priv->len, GQSPI_DMA_ALIGN); - flush_dcache_range(addr, addr + size); + invalidate_dcache_range(addr, addr + size);
while (priv->len) { zynqmp_qspi_calc_exp(priv, &gen_fifo_cmd);
Cache related issues are seen with small sized data reads. Due to this, proper data is not read. Also some times sf probe fails randomly. To workaround this issue, invalidate dcache after read DMA is triggered.
Signed-off-by: Ashok Reddy Soma ashok.reddy.soma@amd.com Signed-off-by: Venkatesh Yadav Abbarapu venkatesh.abbarapu@amd.com --- drivers/spi/zynqmp_gqspi.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/spi/zynqmp_gqspi.c b/drivers/spi/zynqmp_gqspi.c index a506d15227..ec59ef5804 100644 --- a/drivers/spi/zynqmp_gqspi.c +++ b/drivers/spi/zynqmp_gqspi.c @@ -707,6 +707,8 @@ static int zynqmp_qspi_start_dma(struct zynqmp_qspi_priv *priv, return -ETIMEDOUT; }
+ invalidate_dcache_range(addr, addr + size); + writel(GQSPI_DMA_DST_I_STS_DONE, &dma_regs->dmaisr);
debug("buf:0x%lx, rxbuf:0x%lx, *buf:0x%x len: 0x%x\n",
Applied. M
Michal Simek
