[U-Boot] [PATCH v4 0/3] env: Add CONFIG_ENV_FULL_SUPPORT
This patchset follow http://patchwork.ozlabs.org/project/uboot/list/?series=131268&state=*
It follow the first proposal http://patchwork.ozlabs.org/project/uboot/list/?series=129339 "env: Add CONFIG_ENV_SUPPORT"
The first patch of the serie only solves the regression introduced by commit 7d4776545b0f ("env: solve compilation error in SPL"); change_ok was always NULL in U-Boot. See "U-Boot: Environment flags broken for U-Boot" mail http://u-boot.10912.n7.nabble.com/U-Boot-Environment-flags-broken-for-U-Boot...
This first patch can be integrated in master branch for v2019.10 as requested Tom Rimi.
The next patches of the serie is a proposal after Wolfgang Denk review on the first proposal: I make the env support coherent between U-Boot, SPL and TPL.
I need to change many defconfig (to add CONFIG_(SPL/TPL)_ENV_IS_NOWHERE) because I modify the dependency between the CONFIG used by SPL.
Moreover the size of SPL increase this last patch.
So to avoid to increase the SPL and TPL size, I also allow to have empty default environment with the new options CONFIG_$(SPL_TPL_)ENV_DEFAULT
Today the last buildman result is :
02: env: Add CONFIG_ENV_FULL_SUPPORT arm: + smartweb +/local/home/frq07632/.buildman-toolchains/gcc-7.3.0-nolibc/arm-linux-gnueabi/bin/arm-linux-gnueabi-ld.bfd: u-boot-spl section `.u_boot_list' will not fit in region `.sram' +/local/home/frq07632/.buildman-toolchains/gcc-7.3.0-nolibc/arm-linux-gnueabi/bin/arm-linux-gnueabi-ld.bfd: SPL image too big +/local/home/frq07632/.buildman-toolchains/gcc-7.3.0-nolibc/arm-linux-gnueabi/bin/arm-linux-gnueabi-ld.bfd: region `.sram' overflowed by 56 bytes +make[2]: *** [spl/u-boot-spl] Error 1 +make[1]: *** [spl/u-boot-spl] Error 2 x86: (for 26/26 boards) all -23.5 bss -7.4 spl/u-boot-spl:all -226.7 spl/u-boot-spl:data +0.9 spl/u-boot-spl:rodata -228.6 spl/u-boot-spl:text +1.0 text -16.1 aarch64: (for 225/225 boards) all +0.1 rodata +0.1 spl/u-boot-spl:all -33.3 spl/u-boot-spl:bss -0.1 spl/u-boot-spl:data +18.0 spl/u-boot-spl:rodata -64.3 spl/u-boot-spl:text +13.2 powerpc: (for 309/309 boards) spl/u-boot-spl:all -338.8 spl/u-boot-spl:data -338.8 sandbox: (for 6/6 boards) all -46.7 rodata +16.0 spl/u-boot-spl:all -496.0 spl/u-boot-spl:rodata -496.0 text -62.7 microblaze: (for 1/1 boards) all +4.0 bss +100.0 data -4.0 rodata -8.0 spl/u-boot-spl:all +1136.0 spl/u-boot-spl:bss -8.0 spl/u-boot-spl:data +24.0 spl/u-boot-spl:rodata +1092.0 spl/u-boot-spl:text +28.0 text -84.0 arm: (for 689/689 boards) all -0.1 bss +0.1 rodata +0.1 spl/u-boot-spl:all -131.3 spl/u-boot-spl:data +12.9 spl/u-boot-spl:rodata -154.7 spl/u-boot-spl:text +10.5 text -0.3
With this patch I gain on the rodata size in spl for many targets.
But I need to be sure that have a empty default environment in SPL/TPL by default is normal for all architecture/boards.
Do you think I need to reactivate it by default the CONFIG for SPL and deactivated only on some target.
Any remarks are welcome.
Best regards.
Patrick Delaunay.
Changes in v4: - Add CONFIG_$(SPL_TPL_)ENV_DEFAULT: empty default environment when not activated
Changes in v3: - It is a version 3 of http://patchwork.ozlabs.org/project/uboot/list/?series=129339 "env: Add CONFIG_ENV_SUPPORT" after Tom Rimi and Wolfgang Denk remarks
Changes in v2: - Add comment for ENV_IS_IN_SOMEWHERE - Update commit message after Lukasz Majewki review
Patrick Delaunay (3): env: correct the check of env_flags_validate presence env: introduce macro ENV_IS_IN_SOMEWHERE env: Add CONFIG_ENV_FULL_SUPPORT
arch/arm/mach-omap2/Kconfig | 1 - arch/arm/mach-omap2/am33xx/Kconfig | 2 -- board/birdland/bav335x/board.c | 2 +- board/gateworks/gw_ventana/gw_ventana_spl.c | 2 +- board/liebherr/display5/spl.c | 4 +-- board/tcl/sl50/board.c | 2 +- board/ti/am335x/board.c | 2 +- board/ti/am57xx/board.c | 2 +- board/ti/dra7xx/evm.c | 2 +- cmd/Kconfig | 2 ++ cmd/nvedit.c | 27 +++------------ common/spl/Kconfig | 20 ----------- common/spl/spl_ext.c | 2 +- common/spl/spl_fat.c | 2 +- configs/A10-OLinuXino-Lime_defconfig | 1 + configs/A10s-OLinuXino-M_defconfig | 1 + configs/A13-OLinuXinoM_defconfig | 1 + configs/A13-OLinuXino_defconfig | 1 + configs/A20-OLinuXino-Lime2-eMMC_defconfig | 1 + configs/A20-OLinuXino-Lime2_defconfig | 1 + configs/A20-OLinuXino-Lime_defconfig | 1 + configs/A20-OLinuXino_MICRO-eMMC_defconfig | 1 + configs/A20-OLinuXino_MICRO_defconfig | 1 + configs/A20-Olimex-SOM-EVB_defconfig | 1 + configs/A20-Olimex-SOM204-EVB-eMMC_defconfig | 1 + configs/A20-Olimex-SOM204-EVB_defconfig | 1 + configs/A33-OLinuXino_defconfig | 1 + configs/Ainol_AW1_defconfig | 1 + configs/Ampe_A76_defconfig | 1 + configs/Auxtek-T003_defconfig | 1 + configs/Auxtek-T004_defconfig | 1 + configs/B4420QDS_NAND_defconfig | 1 - configs/B4860QDS_NAND_defconfig | 1 - configs/BSC9131RDB_NAND_SYSCLK100_defconfig | 1 + configs/BSC9131RDB_NAND_defconfig | 1 + configs/BSC9132QDS_NAND_DDRCLK100_defconfig | 1 + configs/BSC9132QDS_NAND_DDRCLK133_defconfig | 1 + configs/Bananapi_M2_Ultra_defconfig | 1 + configs/Bananapi_defconfig | 1 + configs/Bananapi_m2m_defconfig | 1 + configs/Bananapro_defconfig | 1 + configs/C29XPCIE_NAND_defconfig | 2 +- configs/CHIP_pro_defconfig | 1 + configs/CSQ_CS908_defconfig | 1 + configs/Chuwi_V7_CW0825_defconfig | 1 + configs/Colombus_defconfig | 1 + configs/Cubieboard2_defconfig | 1 + configs/Cubieboard4_defconfig | 1 + configs/Cubieboard_defconfig | 1 + configs/Cubietruck_defconfig | 1 + configs/Cubietruck_plus_defconfig | 1 + configs/Empire_electronix_d709_defconfig | 1 + configs/Empire_electronix_m712_defconfig | 1 + configs/Hummingbird_A31_defconfig | 1 + configs/Hyundai_A7HD_defconfig | 1 + configs/Itead_Ibox_A20_defconfig | 1 + configs/Lamobo_R1_defconfig | 1 + configs/LicheePi_Zero_defconfig | 1 + configs/Linksprite_pcDuino3_Nano_defconfig | 1 + configs/Linksprite_pcDuino3_defconfig | 1 + configs/Linksprite_pcDuino_defconfig | 1 + configs/MK808C_defconfig | 1 + configs/MPC8313ERDB_NAND_33_defconfig | 1 + configs/MPC8313ERDB_NAND_66_defconfig | 1 + configs/MSI_Primo73_defconfig | 1 + configs/MSI_Primo81_defconfig | 1 + configs/Marsboard_A10_defconfig | 1 + configs/Mele_A1000G_quad_defconfig | 1 + configs/Mele_A1000_defconfig | 1 + configs/Mele_I7_defconfig | 1 + configs/Mele_M3_defconfig | 1 + configs/Mele_M5_defconfig | 1 + configs/Mele_M9_defconfig | 1 + configs/Merrii_A80_Optimus_defconfig | 1 + configs/Mini-X_defconfig | 1 + configs/Orangepi_defconfig | 1 + configs/Orangepi_mini_defconfig | 1 + configs/P1010RDB-PA_36BIT_NAND_defconfig | 2 +- configs/P1010RDB-PA_36BIT_SDCARD_defconfig | 1 - configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig | 1 - configs/P1010RDB-PA_NAND_defconfig | 2 +- configs/P1010RDB-PA_SDCARD_defconfig | 1 - configs/P1010RDB-PA_SPIFLASH_defconfig | 1 - configs/P1010RDB-PB_36BIT_NAND_defconfig | 2 +- configs/P1010RDB-PB_36BIT_SDCARD_defconfig | 1 - configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig | 1 - configs/P1010RDB-PB_NAND_defconfig | 2 +- configs/P1010RDB-PB_SDCARD_defconfig | 1 - configs/P1010RDB-PB_SPIFLASH_defconfig | 1 - configs/P1020MBG-PC_36BIT_SDCARD_defconfig | 1 - configs/P1020MBG-PC_SDCARD_defconfig | 1 - configs/P1020RDB-PC_36BIT_NAND_defconfig | 2 +- configs/P1020RDB-PC_36BIT_SDCARD_defconfig | 1 - configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig | 1 - configs/P1020RDB-PC_NAND_defconfig | 2 +- configs/P1020RDB-PC_SDCARD_defconfig | 1 - configs/P1020RDB-PC_SPIFLASH_defconfig | 1 - configs/P1020RDB-PD_NAND_defconfig | 2 +- configs/P1020RDB-PD_SDCARD_defconfig | 1 - configs/P1020RDB-PD_SPIFLASH_defconfig | 1 - configs/P1020UTM-PC_36BIT_SDCARD_defconfig | 1 - configs/P1020UTM-PC_SDCARD_defconfig | 1 - configs/P1021RDB-PC_36BIT_NAND_defconfig | 2 +- configs/P1021RDB-PC_36BIT_SDCARD_defconfig | 1 - configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig | 1 - configs/P1021RDB-PC_NAND_defconfig | 2 +- configs/P1021RDB-PC_SDCARD_defconfig | 1 - configs/P1021RDB-PC_SPIFLASH_defconfig | 1 - configs/P1022DS_36BIT_NAND_defconfig | 2 +- configs/P1022DS_36BIT_SDCARD_defconfig | 1 - configs/P1022DS_36BIT_SPIFLASH_defconfig | 1 - configs/P1022DS_NAND_defconfig | 2 +- configs/P1022DS_SDCARD_defconfig | 1 - configs/P1022DS_SPIFLASH_defconfig | 1 - configs/P1024RDB_NAND_defconfig | 2 +- configs/P1024RDB_SDCARD_defconfig | 1 - configs/P1024RDB_SPIFLASH_defconfig | 1 - configs/P1025RDB_NAND_defconfig | 2 +- configs/P1025RDB_SDCARD_defconfig | 1 - configs/P1025RDB_SPIFLASH_defconfig | 1 - configs/P2020RDB-PC_36BIT_NAND_defconfig | 2 +- configs/P2020RDB-PC_36BIT_SDCARD_defconfig | 1 - configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig | 1 - configs/P2020RDB-PC_NAND_defconfig | 2 +- configs/P2020RDB-PC_SDCARD_defconfig | 1 - configs/P2020RDB-PC_SPIFLASH_defconfig | 1 - configs/Sinlinx_SinA31s_defconfig | 1 + configs/Sinlinx_SinA33_defconfig | 1 + configs/Sinovoip_BPI_M2_defconfig | 1 + configs/Sinovoip_BPI_M3_defconfig | 1 + configs/Sunchip_CX-A99_defconfig | 1 + configs/T1023RDB_NAND_defconfig | 1 - configs/T1023RDB_SDCARD_defconfig | 1 - configs/T1023RDB_SPIFLASH_defconfig | 1 - configs/T1024QDS_NAND_defconfig | 1 - configs/T1024QDS_SDCARD_defconfig | 1 - configs/T1024QDS_SPIFLASH_defconfig | 1 - configs/T1024RDB_NAND_defconfig | 1 - configs/T1024RDB_SDCARD_defconfig | 1 - configs/T1024RDB_SPIFLASH_defconfig | 1 - configs/T1040D4RDB_NAND_defconfig | 1 - configs/T1040D4RDB_SDCARD_defconfig | 1 - configs/T1040D4RDB_SPIFLASH_defconfig | 1 - configs/T1040RDB_NAND_defconfig | 1 - configs/T1040RDB_SDCARD_defconfig | 1 - configs/T1040RDB_SPIFLASH_defconfig | 1 - configs/T1042D4RDB_NAND_defconfig | 1 - configs/T1042D4RDB_SDCARD_defconfig | 1 - configs/T1042D4RDB_SPIFLASH_defconfig | 1 - .../T1042RDB_PI_NAND_SECURE_BOOT_defconfig | 1 - configs/T1042RDB_PI_NAND_defconfig | 1 - configs/T1042RDB_PI_SDCARD_defconfig | 1 - configs/T1042RDB_PI_SPIFLASH_defconfig | 1 - configs/T2080QDS_NAND_defconfig | 1 - configs/T2080QDS_SDCARD_defconfig | 1 - configs/T2080QDS_SPIFLASH_defconfig | 1 - configs/T2080RDB_NAND_defconfig | 1 - configs/T2080RDB_SDCARD_defconfig | 1 - configs/T2080RDB_SPIFLASH_defconfig | 1 - configs/T2081QDS_NAND_defconfig | 1 - configs/T2081QDS_SDCARD_defconfig | 1 - configs/T2081QDS_SPIFLASH_defconfig | 1 - configs/T4160QDS_NAND_defconfig | 1 - configs/T4160QDS_SDCARD_defconfig | 1 - configs/T4240QDS_NAND_defconfig | 1 - configs/T4240QDS_SDCARD_defconfig | 1 - configs/T4240RDB_SDCARD_defconfig | 1 - configs/UTOO_P66_defconfig | 1 + configs/Wexler_TAB7200_defconfig | 1 + configs/Wits_Pro_A20_DKT_defconfig | 1 + configs/Wobo_i5_defconfig | 1 + configs/Yones_Toptech_BD1078_defconfig | 1 + configs/Yones_Toptech_BS1078_V2_defconfig | 1 + configs/a64-olinuxino_defconfig | 1 + configs/ae350_rv32_xip_defconfig | 1 + configs/alt_defconfig | 1 + configs/am335x_guardian_defconfig | 1 - configs/am335x_hs_evm_defconfig | 2 +- configs/am335x_hs_evm_uart_defconfig | 2 +- configs/am335x_igep003x_defconfig | 1 + configs/am335x_shc_defconfig | 1 + configs/am335x_shc_ict_defconfig | 1 + configs/am335x_shc_netboot_defconfig | 1 - configs/am335x_shc_sdboot_defconfig | 1 + configs/am335x_sl50_defconfig | 1 - configs/am3517_crane_defconfig | 1 + configs/am3517_evm_defconfig | 1 + configs/am65x_evm_a53_defconfig | 1 + configs/am65x_evm_r5_defconfig | 1 + configs/am65x_hs_evm_a53_defconfig | 1 + configs/am65x_hs_evm_r5_defconfig | 1 + configs/amarula_a64_relic_defconfig | 1 + configs/apalis-tk1_defconfig | 1 + configs/apalis_imx6_defconfig | 1 + configs/apalis_t30_defconfig | 1 + configs/apf27_defconfig | 1 + configs/apx4devkit_defconfig | 1 + configs/arndale_defconfig | 1 + configs/axm_defconfig | 1 + configs/ba10_tv_box_defconfig | 1 + configs/bananapi_m1_plus_defconfig | 1 + configs/bananapi_m2_berry_defconfig | 1 + configs/bananapi_m2_plus_h3_defconfig | 1 + configs/bananapi_m2_plus_h5_defconfig | 1 + configs/bananapi_m2_zero_defconfig | 1 + configs/bananapi_m64_defconfig | 1 + configs/beaver_defconfig | 1 + configs/beelink_gs1_defconfig | 1 + configs/beelink_x2_defconfig | 1 + configs/bitmain_antminer_s9_defconfig | 1 + configs/brppt1_mmc_defconfig | 1 + configs/brppt1_nand_defconfig | 1 + configs/brppt1_spi_defconfig | 1 + configs/brsmarc1_defconfig | 1 + configs/brxre1_defconfig | 1 + configs/cairo_defconfig | 1 + configs/cardhu_defconfig | 1 + configs/cei-tk1-som_defconfig | 1 + configs/cgtqmx6eval_defconfig | 1 + configs/chiliboard_defconfig | 1 + configs/chromebook_bob_defconfig | 1 + configs/chromebook_link64_defconfig | 1 - configs/chromebook_samus_tpl_defconfig | 2 ++ configs/ci20_mmc_defconfig | 1 + configs/cl-som-imx7_defconfig | 1 + configs/clearfog_defconfig | 1 + configs/cm_fx6_defconfig | 1 + configs/cm_t335_defconfig | 1 + configs/cm_t35_defconfig | 1 + configs/cm_t43_defconfig | 1 + configs/colibri_imx6_defconfig | 1 + configs/colibri_t20_defconfig | 1 + configs/colibri_t30_defconfig | 1 + configs/colorfly_e708_q1_defconfig | 1 + configs/controlcenterdc_defconfig | 1 + configs/corvus_defconfig | 1 + configs/da850evm_defconfig | 1 + configs/da850evm_nand_defconfig | 1 + configs/dalmore_defconfig | 1 + configs/db-88f6720_defconfig | 1 + configs/db-88f6820-amc_defconfig | 1 + configs/db-88f6820-gp_defconfig | 1 + configs/db-mv784mp-gp_defconfig | 1 + configs/devkit3250_defconfig | 1 + configs/devkit8000_defconfig | 1 + configs/dh_imx6_defconfig | 1 + configs/difrnce_dit4350_defconfig | 1 + configs/display5_defconfig | 1 - configs/display5_factory_defconfig | 1 + configs/draco_defconfig | 1 + configs/ds414_defconfig | 1 + configs/dserve_dsrv9703c_defconfig | 1 + configs/edminiv2_defconfig | 1 + configs/emlid_neutis_n5_devboard_defconfig | 1 + configs/etamin_defconfig | 1 + configs/evb-px5_defconfig | 2 ++ configs/evb-rk3229_defconfig | 2 ++ configs/evb-rk3288_defconfig | 2 ++ configs/evb-rk3328_defconfig | 2 ++ configs/evb-rk3399_defconfig | 2 ++ configs/ficus-rk3399_defconfig | 1 + configs/firefly-rk3288_defconfig | 1 + configs/firefly-rk3399_defconfig | 2 ++ configs/ga10h_v1_1_defconfig | 1 + .../gardena-smart-gateway-at91sam_defconfig | 1 + configs/gose_defconfig | 1 + configs/gt90h_v4_defconfig | 1 + configs/gwventana_emmc_defconfig | 1 + configs/gwventana_gw5904_defconfig | 1 + configs/gwventana_nand_defconfig | 1 + configs/h8_homlet_v2_defconfig | 1 + configs/harmony_defconfig | 1 + configs/helios4_defconfig | 1 + configs/i12-tvbox_defconfig | 1 + configs/iNet_3F_defconfig | 1 + configs/iNet_3W_defconfig | 1 + configs/iNet_86VS_defconfig | 1 + configs/iNet_D978_rev2_defconfig | 1 + configs/icnova-a20-swac_defconfig | 1 + configs/igep00x0_defconfig | 1 + configs/imx6dl_icore_nand_defconfig | 1 + configs/imx6dl_mamoj_defconfig | 1 + configs/imx6q_icore_nand_defconfig | 1 + configs/imx6q_logic_defconfig | 1 + configs/imx6qdl_icore_mipi_defconfig | 1 + configs/imx6qdl_icore_mmc_defconfig | 1 + configs/imx6qdl_icore_nand_defconfig | 1 + configs/imx6qdl_icore_rqs_defconfig | 1 + configs/imx6ul_geam_mmc_defconfig | 1 + configs/imx6ul_geam_nand_defconfig | 1 + configs/imx6ul_isiot_emmc_defconfig | 1 + configs/imx6ul_isiot_nand_defconfig | 1 + configs/imx8mq_evk_defconfig | 1 + configs/imx8qm_mek_defconfig | 1 + configs/imx8qxp_mek_defconfig | 1 + configs/inet1_defconfig | 1 + configs/inet86dz_defconfig | 1 + configs/inet97fv2_defconfig | 1 + configs/inet98v_rev2_defconfig | 1 + configs/inet9f_rev03_defconfig | 1 + configs/inet_q972_defconfig | 1 + configs/j721e_evm_r5_defconfig | 1 - configs/jesurun_q5_defconfig | 1 + configs/jetson-tk1_defconfig | 1 + configs/k2e_evm_defconfig | 1 + configs/k2g_evm_defconfig | 1 + configs/k2hk_evm_defconfig | 1 + configs/k2l_evm_defconfig | 1 + configs/khadas-edge-captain-rk3399_defconfig | 2 ++ configs/khadas-edge-rk3399_defconfig | 2 ++ configs/khadas-edge-v-rk3399_defconfig | 2 ++ configs/koelsch_defconfig | 1 + configs/kp_imx6q_tpc_defconfig | 1 + configs/kylin-rk3036_defconfig | 1 + configs/lager_defconfig | 1 + configs/libretech_all_h3_cc_h2_plus_defconfig | 1 + configs/libretech_all_h3_cc_h3_defconfig | 1 + configs/libretech_all_h3_cc_h5_defconfig | 1 + configs/lion-rk3368_defconfig | 2 ++ configs/liteboard_defconfig | 1 + configs/ls1021aiot_sdcard_defconfig | 1 + configs/ls1021aqds_nand_defconfig | 1 - configs/ls1021aqds_sdcard_ifc_defconfig | 1 - configs/ls1021aqds_sdcard_qspi_defconfig | 1 - configs/ls1021atsn_sdcard_defconfig | 1 - ...s1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 1 - configs/ls1021atwr_sdcard_ifc_defconfig | 1 - configs/ls1021atwr_sdcard_qspi_defconfig | 1 - configs/ls1043aqds_nand_defconfig | 1 - configs/ls1043aqds_sdcard_ifc_defconfig | 1 - configs/ls1043aqds_sdcard_qspi_defconfig | 1 - configs/ls1043ardb_nand_SECURE_BOOT_defconfig | 1 - configs/ls1043ardb_nand_defconfig | 1 - .../ls1043ardb_sdcard_SECURE_BOOT_defconfig | 1 - configs/ls1043ardb_sdcard_defconfig | 1 - configs/ls1046aqds_nand_defconfig | 1 + configs/ls1046aqds_sdcard_ifc_defconfig | 1 - configs/ls1046aqds_sdcard_qspi_defconfig | 1 - configs/ls1046ardb_emmc_defconfig | 1 - configs/ls1046ardb_qspi_spl_defconfig | 1 - .../ls1046ardb_sdcard_SECURE_BOOT_defconfig | 1 - configs/ls1046ardb_sdcard_defconfig | 1 - configs/ls1088aqds_sdcard_ifc_defconfig | 1 - configs/ls1088aqds_sdcard_qspi_defconfig | 1 - ...1088ardb_sdcard_qspi_SECURE_BOOT_defconfig | 1 - configs/ls1088ardb_sdcard_qspi_defconfig | 1 - configs/ls2080aqds_nand_defconfig | 1 - configs/ls2080aqds_sdcard_defconfig | 1 - configs/ls2080ardb_nand_defconfig | 1 - configs/m53menlo_defconfig | 1 + configs/maxbcm_defconfig | 1 + configs/mccmon6_nor_defconfig | 1 - configs/mccmon6_sd_defconfig | 1 - configs/medcom-wide_defconfig | 1 + configs/miqi-rk3288_defconfig | 1 + configs/mixtile_loftq_defconfig | 1 + configs/mk802_a10s_defconfig | 1 + configs/mk802_defconfig | 1 + configs/mk802ii_defconfig | 1 + configs/mx23_olinuxino_defconfig | 1 + configs/mx23evk_defconfig | 1 + configs/mx28evk_auart_console_defconfig | 1 + configs/mx28evk_defconfig | 1 + configs/mx28evk_nand_defconfig | 1 + configs/mx31pdk_defconfig | 1 + configs/mx6cuboxi_defconfig | 1 + configs/mx6sabreauto_defconfig | 1 + configs/mx6sabresd_defconfig | 1 + configs/mx6slevk_spl_defconfig | 1 + configs/mx6sxsabresd_spl_defconfig | 1 + configs/mx6ul_14x14_evk_defconfig | 1 + configs/mx6ul_9x9_evk_defconfig | 1 + configs/nanopc-t4-rk3399_defconfig | 2 ++ configs/nanopi-m4-rk3399_defconfig | 2 ++ configs/nanopi-neo4-rk3399_defconfig | 2 ++ configs/nanopi_a64_defconfig | 1 + configs/nanopi_m1_defconfig | 1 + configs/nanopi_m1_plus_defconfig | 1 + configs/nanopi_neo2_defconfig | 1 + configs/nanopi_neo_air_defconfig | 1 + configs/nanopi_neo_defconfig | 1 + configs/nanopi_neo_plus2_defconfig | 1 + configs/novena_defconfig | 1 + configs/nyan-big_defconfig | 1 + configs/oceanic_5205_5inmfd_defconfig | 1 + configs/omap35_logic_defconfig | 1 + configs/omap35_logic_somlv_defconfig | 1 + configs/omap3_beagle_defconfig | 1 + configs/omap3_evm_defconfig | 1 + configs/omap3_ha_defconfig | 1 + configs/omap3_logic_defconfig | 1 + configs/omap3_logic_somlv_defconfig | 1 + configs/omap3_overo_defconfig | 1 + configs/omap4_panda_defconfig | 1 + configs/omap4_sdp4430_defconfig | 1 + configs/omapl138_lcdk_defconfig | 1 + configs/opos6uldev_defconfig | 1 - configs/orangepi-rk3399_defconfig | 2 ++ configs/orangepi_2_defconfig | 1 + configs/orangepi_lite2_defconfig | 1 + configs/orangepi_lite_defconfig | 1 + configs/orangepi_one_defconfig | 1 + configs/orangepi_one_plus_defconfig | 1 + configs/orangepi_pc2_defconfig | 1 + configs/orangepi_pc_defconfig | 1 + configs/orangepi_pc_plus_defconfig | 1 + configs/orangepi_plus2e_defconfig | 1 + configs/orangepi_plus_defconfig | 1 + configs/orangepi_prime_defconfig | 1 + configs/orangepi_r1_defconfig | 1 + configs/orangepi_win_defconfig | 1 + configs/orangepi_zero_defconfig | 1 + configs/orangepi_zero_plus2_defconfig | 1 + configs/orangepi_zero_plus_defconfig | 1 + configs/origen_defconfig | 1 + configs/ot1200_spl_defconfig | 1 + configs/parrot_r16_defconfig | 1 + configs/paz00_defconfig | 1 + configs/pcm051_rev1_defconfig | 1 - configs/pcm051_rev3_defconfig | 1 - configs/pcm058_defconfig | 1 + configs/peach-pi_defconfig | 1 + configs/peach-pit_defconfig | 1 + configs/pengwyn_defconfig | 1 - configs/phycore-am335x-r2-wega_defconfig | 1 + configs/phycore-rk3288_defconfig | 1 + configs/pico-hobbit-imx6ul_defconfig | 1 + configs/pico-hobbit-imx7d_defconfig | 1 + configs/pico-imx6ul_defconfig | 1 + configs/pico-imx7d_bl33_defconfig | 1 + configs/pico-imx7d_defconfig | 1 + configs/pico-pi-imx6ul_defconfig | 1 + configs/pico-pi-imx7d_defconfig | 1 + configs/picosam9g45_defconfig | 1 + configs/pine64-lts_defconfig | 1 + configs/pine64_plus_defconfig | 1 + configs/pine_h64_defconfig | 1 + configs/pinebook_defconfig | 1 + configs/platinum_picon_defconfig | 1 + configs/platinum_titanium_defconfig | 1 + configs/plutux_defconfig | 1 + configs/polaroid_mid2407pxe03_defconfig | 1 + configs/polaroid_mid2809pxe04_defconfig | 1 + configs/popmetal-rk3288_defconfig | 1 + configs/porter_defconfig | 1 + configs/pov_protab2_ips9_defconfig | 1 + configs/puma-rk3399_defconfig | 1 + configs/pxm2_defconfig | 1 + configs/q8_a13_tablet_defconfig | 1 + configs/q8_a23_tablet_800x480_defconfig | 1 + configs/q8_a33_tablet_1024x600_defconfig | 1 + configs/q8_a33_tablet_800x480_defconfig | 1 + configs/qemu-riscv32_smode_defconfig | 1 + configs/qemu-x86_64_defconfig | 1 - configs/r7-tv-dongle_defconfig | 1 + configs/r8a7795_salvator-x_defconfig | 1 + configs/r8a7795_ulcb_defconfig | 1 + configs/r8a77965_salvator-x_defconfig | 1 + configs/r8a77965_ulcb_defconfig | 1 + configs/r8a7796_salvator-x_defconfig | 1 + configs/r8a7796_ulcb_defconfig | 1 + configs/r8a77970_eagle_defconfig | 1 + configs/r8a77980_condor_defconfig | 1 + configs/r8a77990_ebisu_defconfig | 1 + configs/r8a77995_draak_defconfig | 1 + configs/rastaban_defconfig | 1 + configs/riotboard_spl_defconfig | 1 + configs/roc-rk3399-pc_defconfig | 2 ++ configs/rock-pi-4-rk3399_defconfig | 2 ++ configs/rock2_defconfig | 1 + configs/rock64-rk3328_defconfig | 2 ++ configs/rock960-rk3399_defconfig | 1 + configs/rock_defconfig | 1 + configs/rockpro64-rk3399_defconfig | 2 ++ configs/rut_defconfig | 1 + configs/sama5d27_som1_ek_mmc1_defconfig | 1 + configs/sama5d27_som1_ek_mmc_defconfig | 1 + configs/sama5d27_som1_ek_qspiflash_defconfig | 1 + configs/sama5d2_icp_mmc_defconfig | 1 + configs/sama5d2_xplained_emmc_defconfig | 1 + configs/sama5d2_xplained_mmc_defconfig | 1 + configs/sama5d2_xplained_qspiflash_defconfig | 1 + configs/sama5d2_xplained_spiflash_defconfig | 1 + configs/sama5d3_xplained_mmc_defconfig | 1 + configs/sama5d3_xplained_nandflash_defconfig | 1 + configs/sama5d3xek_mmc_defconfig | 1 + configs/sama5d3xek_nandflash_defconfig | 1 + configs/sama5d3xek_spiflash_defconfig | 1 + configs/sama5d4_xplained_mmc_defconfig | 1 + configs/sama5d4_xplained_nandflash_defconfig | 1 + configs/sama5d4_xplained_spiflash_defconfig | 1 + configs/sama5d4ek_mmc_defconfig | 1 + configs/sama5d4ek_nandflash_defconfig | 1 + configs/sama5d4ek_spiflash_defconfig | 1 + configs/sandbox_spl_defconfig | 1 - configs/sc_sps_1_defconfig | 1 + configs/seaboard_defconfig | 1 + configs/sh7752evb_defconfig | 1 + configs/silk_defconfig | 1 + configs/sksimx6_defconfig | 1 + configs/smartweb_defconfig | 1 + configs/smdk5250_defconfig | 1 + configs/smdk5420_defconfig | 1 + configs/smdkv310_defconfig | 1 + configs/snow_defconfig | 1 + configs/socfpga_arria10_defconfig | 1 - configs/socfpga_arria5_defconfig | 1 + configs/socfpga_cyclone5_defconfig | 1 + configs/socfpga_dbm_soc1_defconfig | 1 + configs/socfpga_de0_nano_soc_defconfig | 1 + configs/socfpga_de10_nano_defconfig | 1 + configs/socfpga_de1_soc_defconfig | 1 + configs/socfpga_is1_defconfig | 1 + configs/socfpga_mcvevk_defconfig | 1 + configs/socfpga_sockit_defconfig | 1 + configs/socfpga_socrates_defconfig | 1 + configs/socfpga_sr1500_defconfig | 1 + configs/socfpga_stratix10_defconfig | 1 + configs/socfpga_vining_fpga_defconfig | 1 + configs/sopine_baseboard_defconfig | 1 + configs/spring_defconfig | 1 + configs/stout_defconfig | 1 + configs/sun8i_a23_evb_defconfig | 1 + configs/sunxi_Gemei_G9_defconfig | 1 + configs/tao3530_defconfig | 1 + configs/taurus_defconfig | 1 + configs/tbs_a711_defconfig | 1 + configs/tec-ng_defconfig | 1 + configs/tec_defconfig | 1 + configs/teres_i_defconfig | 1 + configs/theadorable_debug_defconfig | 1 + configs/thuban_defconfig | 1 + configs/ti816x_evm_defconfig | 1 + configs/tinker-rk3288_defconfig | 2 ++ configs/tricorder_defconfig | 1 + configs/trimslice_defconfig | 1 + configs/ts4600_defconfig | 1 + configs/turris_omnia_defconfig | 1 + configs/udoo_defconfig | 1 + configs/udoo_neo_defconfig | 1 - configs/venice2_defconfig | 1 + configs/ventana_defconfig | 1 + configs/vyasa-rk3288_defconfig | 2 ++ configs/wandboard_defconfig | 1 + configs/wb45n_defconfig | 1 + configs/wb50n_defconfig | 1 + configs/woodburn_sd_defconfig | 1 + configs/work_92105_defconfig | 1 + configs/x530_defconfig | 1 + configs/x600_defconfig | 1 + .../xilinx_zynqmp_zc1751_xm015_dc1_defconfig | 1 + .../xilinx_zynqmp_zc1751_xm018_dc4_defconfig | 1 + .../xilinx_zynqmp_zc1751_xm019_dc5_defconfig | 1 + configs/xilinx_zynqmp_zcu102_rev1_0_defconfig | 1 + configs/xilinx_zynqmp_zcu102_revA_defconfig | 1 + configs/xilinx_zynqmp_zcu102_revB_defconfig | 1 + configs/xilinx_zynqmp_zcu104_revA_defconfig | 1 + configs/xilinx_zynqmp_zcu104_revC_defconfig | 1 + configs/xilinx_zynqmp_zcu106_revA_defconfig | 1 + configs/xilinx_zynqmp_zcu111_revA_defconfig | 1 + configs/xpress_spl_defconfig | 1 + configs/zc5202_defconfig | 1 + configs/zc5601_defconfig | 1 + configs/zynq_dlc20_rev1_0_defconfig | 1 + configs/zynq_microzed_defconfig | 1 + configs/zynq_minized_defconfig | 1 + configs/zynq_zc702_defconfig | 1 + configs/zynq_zc706_defconfig | 1 + configs/zynq_zc770_xm010_defconfig | 1 + configs/zynq_zc770_xm012_defconfig | 1 + configs/zynq_zed_defconfig | 1 + configs/zynq_zybo_defconfig | 1 + configs/zynq_zybo_z7_defconfig | 1 + drivers/input/input.c | 2 +- drivers/mtd/nand/raw/Makefile | 4 +-- drivers/reset/reset-socfpga.c | 2 +- env/Kconfig | 33 +++++++++++++++++-- env/Makefile | 11 +++---- env/common.c | 4 +-- include/configs/ls1021aiot.h | 1 - include/configs/ls1046a_common.h | 1 - include/configs/xilinx_zynqmp.h | 1 - include/env.h | 23 +++++++++++++ include/env_callback.h | 4 +++ include/env_default.h | 4 +++ include/env_flags.h | 4 +++ 586 files changed, 557 insertions(+), 207 deletions(-)
This patch corrects the check of env_flags_validate presence because "flags.c" is always compiled in U-Boot and CONFIG_ENV_SUPPORT don't exist; so the macro CONFIG_IS_ENABLED(ENV_SUPPORT) only provides the expected result for SPL and TPL (check activation of CONFIG_SPL_ENV_SUPPORT and CONFIG_TPL_ENV_SUPPORT).
This patch solves the regression introduced by commit 7d4776545b0f ("env: solve compilation error in SPL"); change_ok was always NULL in U-Boot.
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com ---
Changes in v4: None Changes in v3: None Changes in v2: None
env/common.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/env/common.c b/env/common.c index 3fb60509dd..f677b5b0da 100644 --- a/env/common.c +++ b/env/common.c @@ -24,8 +24,10 @@ DECLARE_GLOBAL_DATA_PTR; #include <env_default.h>
struct hsearch_data env_htab = { -#if CONFIG_IS_ENABLED(ENV_SUPPORT) - /* defined in flags.c, only compile with ENV_SUPPORT */ +#if !defined(CONFIG_SPL_BUILD) || CONFIG_IS_ENABLED(ENV_SUPPORT) + /* defined in flags.c, only compiled in U-Boot or + * with $(SPL_TPL_)ENV_SUPPORT + */ .change_ok = env_flags_validate, #endif };
- /* defined in flags.c, only compiled in U-Boot or
.change_ok = env_flags_validate,*/
#endif };
Joe? Wolfgang? Or Heiko (since you could verify the regression is fixed)?
Thanks!
This patch introduce a macro ENV_IS_IN_SOMEWHERE to check if the the environment can be saved somewhere, in a storage medium, without assumption on CONFIG$(SPL_TPL_)ENV_IS_NOWHERE.
Since the commit 208bd2b85ecc ("env: allow ENV_IS_NOWHERE with other storage target"), it is allowed to activated ENV_IS_NOWHERE with other CONFIG_IS_IN... in U-Boot. It is only allowed for U-Boot but the remaining restriction in Kconfig could also removed for SPL and TPL (depends on !SPL_ENV_IS_NOWHERE / depends on !TPL_ENV_IS_NOWHERE).
This macro ENV_IS_IN_SOMEWHERE can be used in code to check if the environment for U-Boot / SPL / TPL is really managed (at least one CONFIG$(SPL_TPL_)ENV_IS_IN_.. is activated).
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com --- Hi,
For this patch, I am not completely satisfied by the name "ENV_IS_IN_SOMEWHERE".
Perhaps other name will be less confusing: "ENV_IS_IN_XXX", "ENV_IS_IN_DEVICE", "ENV_IS_IN_STORAGE", "ENV_IS_IN_MEDIUM", "ENV_IS_IN_STORAGE_MEDIUM", "ENV_SAVE_SUPPORT" ...
But I don't found a perfect solution...
Any proposal on other name is welcome.
Changes in v4: None Changes in v3: None Changes in v2: - Add comment for ENV_IS_IN_SOMEWHERE
cmd/nvedit.c | 29 +++++++---------------------- include/env.h | 23 +++++++++++++++++++++++ 2 files changed, 30 insertions(+), 22 deletions(-)
diff --git a/cmd/nvedit.c b/cmd/nvedit.c index 1cb0bc1460..7a6ec5ae30 100644 --- a/cmd/nvedit.c +++ b/cmd/nvedit.c @@ -40,28 +40,13 @@
-#if defined(CONFIG_ENV_IS_IN_EEPROM) || \ - defined(CONFIG_ENV_IS_IN_FLASH) || \ - defined(CONFIG_ENV_IS_IN_MMC) || \ - defined(CONFIG_ENV_IS_IN_FAT) || \ - defined(CONFIG_ENV_IS_IN_EXT4) || \ - defined(CONFIG_ENV_IS_IN_NAND) || \ - defined(CONFIG_ENV_IS_IN_NVRAM) || \ - defined(CONFIG_ENV_IS_IN_ONENAND) || \ - defined(CONFIG_ENV_IS_IN_SATA) || \ - defined(CONFIG_ENV_IS_IN_SPI_FLASH) || \ - defined(CONFIG_ENV_IS_IN_REMOTE) || \ - defined(CONFIG_ENV_IS_IN_UBI) - -#define ENV_IS_IN_DEVICE - -#endif - -#if !defined(ENV_IS_IN_DEVICE) && \ - !defined(CONFIG_ENV_IS_NOWHERE) +#if !defined(CONFIG_SPL_BUILD) || CONFIG_IS_ENABLED(ENV_SUPPORT) +#if !ENV_IS_IN_SOMEWHERE && \ + !CONFIG_IS_ENABLED(ENV_IS_NOWHERE) # error Define one of CONFIG_ENV_IS_IN_{EEPROM|FLASH|MMC|FAT|EXT4|\ NAND|NVRAM|ONENAND|SATA|SPI_FLASH|REMOTE|UBI} or CONFIG_ENV_IS_NOWHERE #endif +#endif
/* * Maximum expected input data size for import command @@ -744,7 +729,7 @@ ulong env_get_ulong(const char *name, int base, ulong default_val) }
#ifndef CONFIG_SPL_BUILD -#if defined(CONFIG_CMD_SAVEENV) && defined(ENV_IS_IN_DEVICE) +#if defined(CONFIG_CMD_SAVEENV) && ENV_IS_IN_SOMEWHERE static int do_env_save(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { @@ -1309,7 +1294,7 @@ static cmd_tbl_t cmd_env_sub[] = { #if defined(CONFIG_CMD_RUN) U_BOOT_CMD_MKENT(run, CONFIG_SYS_MAXARGS, 1, do_run, "", ""), #endif -#if defined(CONFIG_CMD_SAVEENV) && defined(ENV_IS_IN_DEVICE) +#if defined(CONFIG_CMD_SAVEENV) && ENV_IS_IN_SOMEWHERE U_BOOT_CMD_MKENT(save, 1, 0, do_env_save, "", ""), #if defined(CONFIG_CMD_ERASEENV) U_BOOT_CMD_MKENT(erase, 1, 0, do_env_erase, "", ""), @@ -1392,7 +1377,7 @@ static char env_help_text[] = #if defined(CONFIG_CMD_RUN) "env run var [...] - run commands in an environment variable\n" #endif -#if defined(CONFIG_CMD_SAVEENV) && defined(ENV_IS_IN_DEVICE) +#if defined(CONFIG_CMD_SAVEENV) && ENV_IS_IN_SOMEWHERE "env save - save environment\n" #if defined(CONFIG_CMD_ERASEENV) "env erase - erase environment\n" diff --git a/include/env.h b/include/env.h index a74a261337..bdf42e746a 100644 --- a/include/env.h +++ b/include/env.h @@ -35,6 +35,29 @@ struct env_clbk_tbl { int flags); };
+/** + * ENV_IS_IN_SOMEWHERE - test if one storage medium is supported by enviromnent + * + * this helper macro allow to test if at a storage medium is supported by + * U-Boot enviromnent, so if one configuration of ENV_IS_IN_... is activated + * usage: #if ENV_IS_IN_SOMEWHERE + * + * WARNING: several storage medium can be activated at the same time + * and ENV_IS_NOWHERE can be also activated as fallback + */ +#define ENV_IS_IN_SOMEWHERE \ + (CONFIG_IS_ENABLED(ENV_IS_IN_EEPROM) || \ + CONFIG_IS_ENABLED(ENV_IS_IN_EXT4) || \ + CONFIG_IS_ENABLED(ENV_IS_IN_FAT) || \ + CONFIG_IS_ENABLED(ENV_IS_IN_FLASH) || \ + CONFIG_IS_ENABLED(ENV_IS_IN_MMC) || \ + CONFIG_IS_ENABLED(ENV_IS_IN_NAND) || \ + CONFIG_IS_ENABLED(ENV_IS_IN_NVRAM) || \ + CONFIG_IS_ENABLED(ENV_IS_IN_ONENAND) || \ + CONFIG_IS_ENABLED(ENV_IS_IN_REMOTE) || \ + CONFIG_IS_ENABLED(ENV_IS_IN_SPI_FLASH) || \ + CONFIG_IS_ENABLED(ENV_IS_IN_UBI)) + /* * Define a callback that can be associated with variables. * when associated through the ".callbacks" environment variable, the callback
From: Patrick DELAUNAY patrick.delaunay@st.com Sent: jeudi 3 octobre 2019 09:24
Hi Tom,
I try to solve default environment size issue in patch =
http://patchwork.ozlabs.org/patch/1257545/ [RFC RFT PATCH] env: spl: filter the variables in default environment of SPL or TPL
But as it is not acceptable and I don't see other solution for this serie.
I won't push v5 for this serie and I considere this serie abandoned.
http://patchwork.ozlabs.org/patch/1171098/
Thanks
Patrick
Add a new flag CONFIG_ENV_FULL_SUPPORT to compile all the environment features (attributes, callbacks and flags) in U-Boot, TPL and SPL.
This flag replace the existing flags for SPL and TPL (CONFIG_SPL_ENV_SUPPORT / CONFIG_TPL_ENV_SUPPORT), because the same support of environment features is mandatory for U-Boot, SPL and TPL.
To deactivate the load/save environment support in SPL / TPL, the board need to activate CONFIG_SPL_ENV_IS_NOWHERE or CONFIG_TPL_ENV_IS_NOWHERE.
With this patch, the environment is activated by default in SPL and TPL, which include the content of default_environment[] as U-boot. To avoid to increase their size, this patch also add 3 new confif : CONFIG_$(SPL_TPL_)ENV_DEFAULT. It is deactivated by default for SPL/TPL and activated by default for U-Boot, the default environment for SPL/TPL is empty and it will be populated only when it will be loaded from storage medium.
All the test on CONFIG_SPL_ENV_SUPPORT are replaced by the ENV_IS_SOMEWHERE macro, which tests if the environment is storage medium.
Changes in v2: - Update commit message after Lukasz Majewki review
arch/arm/mach-omap2/Kconfig | 1 - arch/arm/mach-omap2/am33xx/Kconfig | 2 -- board/birdland/bav335x/board.c | 2 +- board/gateworks/gw_ventana/gw_ventana_spl.c | 2 +- board/liebherr/display5/spl.c | 4 +-- board/tcl/sl50/board.c | 2 +- board/ti/am335x/board.c | 2 +- board/ti/am57xx/board.c | 2 +- board/ti/dra7xx/evm.c | 2 +- cmd/Kconfig | 2 ++ cmd/nvedit.c | 2 -- common/spl/Kconfig | 20 ----------- common/spl/spl_ext.c | 2 +- common/spl/spl_fat.c | 2 +- configs/A10-OLinuXino-Lime_defconfig | 1 + configs/A10s-OLinuXino-M_defconfig | 1 + configs/A13-OLinuXinoM_defconfig | 1 + configs/A13-OLinuXino_defconfig | 1 + configs/A20-OLinuXino-Lime2-eMMC_defconfig | 1 + configs/A20-OLinuXino-Lime2_defconfig | 1 + configs/A20-OLinuXino-Lime_defconfig | 1 + configs/A20-OLinuXino_MICRO-eMMC_defconfig | 1 + configs/A20-OLinuXino_MICRO_defconfig | 1 + configs/A20-Olimex-SOM-EVB_defconfig | 1 + configs/A20-Olimex-SOM204-EVB-eMMC_defconfig | 1 + configs/A20-Olimex-SOM204-EVB_defconfig | 1 + configs/A33-OLinuXino_defconfig | 1 + configs/Ainol_AW1_defconfig | 1 + configs/Ampe_A76_defconfig | 1 + configs/Auxtek-T003_defconfig | 1 + configs/Auxtek-T004_defconfig | 1 + configs/B4420QDS_NAND_defconfig | 1 - configs/B4860QDS_NAND_defconfig | 1 - configs/BSC9131RDB_NAND_SYSCLK100_defconfig | 1 + configs/BSC9131RDB_NAND_defconfig | 1 + configs/BSC9132QDS_NAND_DDRCLK100_defconfig | 1 + configs/BSC9132QDS_NAND_DDRCLK133_defconfig | 1 + configs/Bananapi_M2_Ultra_defconfig | 1 + configs/Bananapi_defconfig | 1 + configs/Bananapi_m2m_defconfig | 1 + configs/Bananapro_defconfig | 1 + configs/C29XPCIE_NAND_defconfig | 2 +- configs/CHIP_pro_defconfig | 1 + configs/CSQ_CS908_defconfig | 1 + configs/Chuwi_V7_CW0825_defconfig | 1 + configs/Colombus_defconfig | 1 + configs/Cubieboard2_defconfig | 1 + configs/Cubieboard4_defconfig | 1 + configs/Cubieboard_defconfig | 1 + configs/Cubietruck_defconfig | 1 + configs/Cubietruck_plus_defconfig | 1 + configs/Empire_electronix_d709_defconfig | 1 + configs/Empire_electronix_m712_defconfig | 1 + configs/Hummingbird_A31_defconfig | 1 + configs/Hyundai_A7HD_defconfig | 1 + configs/Itead_Ibox_A20_defconfig | 1 + configs/Lamobo_R1_defconfig | 1 + configs/LicheePi_Zero_defconfig | 1 + configs/Linksprite_pcDuino3_Nano_defconfig | 1 + configs/Linksprite_pcDuino3_defconfig | 1 + configs/Linksprite_pcDuino_defconfig | 1 + configs/MK808C_defconfig | 1 + configs/MPC8313ERDB_NAND_33_defconfig | 1 + configs/MPC8313ERDB_NAND_66_defconfig | 1 + configs/MSI_Primo73_defconfig | 1 + configs/MSI_Primo81_defconfig | 1 + configs/Marsboard_A10_defconfig | 1 + configs/Mele_A1000G_quad_defconfig | 1 + configs/Mele_A1000_defconfig | 1 + configs/Mele_I7_defconfig | 1 + configs/Mele_M3_defconfig | 1 + configs/Mele_M5_defconfig | 1 + configs/Mele_M9_defconfig | 1 + configs/Merrii_A80_Optimus_defconfig | 1 + configs/Mini-X_defconfig | 1 + configs/Orangepi_defconfig | 1 + configs/Orangepi_mini_defconfig | 1 + configs/P1010RDB-PA_36BIT_NAND_defconfig | 2 +- configs/P1010RDB-PA_36BIT_SDCARD_defconfig | 1 - configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig | 1 - configs/P1010RDB-PA_NAND_defconfig | 2 +- configs/P1010RDB-PA_SDCARD_defconfig | 1 - configs/P1010RDB-PA_SPIFLASH_defconfig | 1 - configs/P1010RDB-PB_36BIT_NAND_defconfig | 2 +- configs/P1010RDB-PB_36BIT_SDCARD_defconfig | 1 - configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig | 1 - configs/P1010RDB-PB_NAND_defconfig | 2 +- configs/P1010RDB-PB_SDCARD_defconfig | 1 - configs/P1010RDB-PB_SPIFLASH_defconfig | 1 - configs/P1020MBG-PC_36BIT_SDCARD_defconfig | 1 - configs/P1020MBG-PC_SDCARD_defconfig | 1 - configs/P1020RDB-PC_36BIT_NAND_defconfig | 2 +- configs/P1020RDB-PC_36BIT_SDCARD_defconfig | 1 - configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig | 1 - configs/P1020RDB-PC_NAND_defconfig | 2 +- configs/P1020RDB-PC_SDCARD_defconfig | 1 - configs/P1020RDB-PC_SPIFLASH_defconfig | 1 - configs/P1020RDB-PD_NAND_defconfig | 2 +- configs/P1020RDB-PD_SDCARD_defconfig | 1 - configs/P1020RDB-PD_SPIFLASH_defconfig | 1 - configs/P1020UTM-PC_36BIT_SDCARD_defconfig | 1 - configs/P1020UTM-PC_SDCARD_defconfig | 1 - configs/P1021RDB-PC_36BIT_NAND_defconfig | 2 +- configs/P1021RDB-PC_36BIT_SDCARD_defconfig | 1 - configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig | 1 - configs/P1021RDB-PC_NAND_defconfig | 2 +- configs/P1021RDB-PC_SDCARD_defconfig | 1 - configs/P1021RDB-PC_SPIFLASH_defconfig | 1 - configs/P1022DS_36BIT_NAND_defconfig | 2 +- configs/P1022DS_36BIT_SDCARD_defconfig | 1 - configs/P1022DS_36BIT_SPIFLASH_defconfig | 1 - configs/P1022DS_NAND_defconfig | 2 +- configs/P1022DS_SDCARD_defconfig | 1 - configs/P1022DS_SPIFLASH_defconfig | 1 - configs/P1024RDB_NAND_defconfig | 2 +- configs/P1024RDB_SDCARD_defconfig | 1 - configs/P1024RDB_SPIFLASH_defconfig | 1 - configs/P1025RDB_NAND_defconfig | 2 +- configs/P1025RDB_SDCARD_defconfig | 1 - configs/P1025RDB_SPIFLASH_defconfig | 1 - configs/P2020RDB-PC_36BIT_NAND_defconfig | 2 +- configs/P2020RDB-PC_36BIT_SDCARD_defconfig | 1 - configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig | 1 - configs/P2020RDB-PC_NAND_defconfig | 2 +- configs/P2020RDB-PC_SDCARD_defconfig | 1 - configs/P2020RDB-PC_SPIFLASH_defconfig | 1 - configs/Sinlinx_SinA31s_defconfig | 1 + configs/Sinlinx_SinA33_defconfig | 1 + configs/Sinovoip_BPI_M2_defconfig | 1 + configs/Sinovoip_BPI_M3_defconfig | 1 + configs/Sunchip_CX-A99_defconfig | 1 + configs/T1023RDB_NAND_defconfig | 1 - configs/T1023RDB_SDCARD_defconfig | 1 - configs/T1023RDB_SPIFLASH_defconfig | 1 - configs/T1024QDS_NAND_defconfig | 1 - configs/T1024QDS_SDCARD_defconfig | 1 - configs/T1024QDS_SPIFLASH_defconfig | 1 - configs/T1024RDB_NAND_defconfig | 1 - configs/T1024RDB_SDCARD_defconfig | 1 - configs/T1024RDB_SPIFLASH_defconfig | 1 - configs/T1040D4RDB_NAND_defconfig | 1 - configs/T1040D4RDB_SDCARD_defconfig | 1 - configs/T1040D4RDB_SPIFLASH_defconfig | 1 - configs/T1040RDB_NAND_defconfig | 1 - configs/T1040RDB_SDCARD_defconfig | 1 - configs/T1040RDB_SPIFLASH_defconfig | 1 - configs/T1042D4RDB_NAND_defconfig | 1 - configs/T1042D4RDB_SDCARD_defconfig | 1 - configs/T1042D4RDB_SPIFLASH_defconfig | 1 - .../T1042RDB_PI_NAND_SECURE_BOOT_defconfig | 1 - configs/T1042RDB_PI_NAND_defconfig | 1 - configs/T1042RDB_PI_SDCARD_defconfig | 1 - configs/T1042RDB_PI_SPIFLASH_defconfig | 1 - configs/T2080QDS_NAND_defconfig | 1 - configs/T2080QDS_SDCARD_defconfig | 1 - configs/T2080QDS_SPIFLASH_defconfig | 1 - configs/T2080RDB_NAND_defconfig | 1 - configs/T2080RDB_SDCARD_defconfig | 1 - configs/T2080RDB_SPIFLASH_defconfig | 1 - configs/T2081QDS_NAND_defconfig | 1 - configs/T2081QDS_SDCARD_defconfig | 1 - configs/T2081QDS_SPIFLASH_defconfig | 1 - configs/T4160QDS_NAND_defconfig | 1 - configs/T4160QDS_SDCARD_defconfig | 1 - configs/T4240QDS_NAND_defconfig | 1 - configs/T4240QDS_SDCARD_defconfig | 1 - configs/T4240RDB_SDCARD_defconfig | 1 - configs/UTOO_P66_defconfig | 1 + configs/Wexler_TAB7200_defconfig | 1 + configs/Wits_Pro_A20_DKT_defconfig | 1 + configs/Wobo_i5_defconfig | 1 + configs/Yones_Toptech_BD1078_defconfig | 1 + configs/Yones_Toptech_BS1078_V2_defconfig | 1 + configs/a64-olinuxino_defconfig | 1 + configs/ae350_rv32_xip_defconfig | 1 + configs/alt_defconfig | 1 + configs/am335x_guardian_defconfig | 1 - configs/am335x_hs_evm_defconfig | 2 +- configs/am335x_hs_evm_uart_defconfig | 2 +- configs/am335x_igep003x_defconfig | 1 + configs/am335x_shc_defconfig | 1 + configs/am335x_shc_ict_defconfig | 1 + configs/am335x_shc_netboot_defconfig | 1 - configs/am335x_shc_sdboot_defconfig | 1 + configs/am335x_sl50_defconfig | 1 - configs/am3517_crane_defconfig | 1 + configs/am3517_evm_defconfig | 1 + configs/am65x_evm_a53_defconfig | 1 + configs/am65x_evm_r5_defconfig | 1 + configs/am65x_hs_evm_a53_defconfig | 1 + configs/am65x_hs_evm_r5_defconfig | 1 + configs/amarula_a64_relic_defconfig | 1 + configs/apalis-tk1_defconfig | 1 + configs/apalis_imx6_defconfig | 1 + configs/apalis_t30_defconfig | 1 + configs/apf27_defconfig | 1 + configs/apx4devkit_defconfig | 1 + configs/arndale_defconfig | 1 + configs/axm_defconfig | 1 + configs/ba10_tv_box_defconfig | 1 + configs/bananapi_m1_plus_defconfig | 1 + configs/bananapi_m2_berry_defconfig | 1 + configs/bananapi_m2_plus_h3_defconfig | 1 + configs/bananapi_m2_plus_h5_defconfig | 1 + configs/bananapi_m2_zero_defconfig | 1 + configs/bananapi_m64_defconfig | 1 + configs/beaver_defconfig | 1 + configs/beelink_gs1_defconfig | 1 + configs/beelink_x2_defconfig | 1 + configs/bitmain_antminer_s9_defconfig | 1 + configs/brppt1_mmc_defconfig | 1 + configs/brppt1_nand_defconfig | 1 + configs/brppt1_spi_defconfig | 1 + configs/brsmarc1_defconfig | 1 + configs/brxre1_defconfig | 1 + configs/cairo_defconfig | 1 + configs/cardhu_defconfig | 1 + configs/cei-tk1-som_defconfig | 1 + configs/cgtqmx6eval_defconfig | 1 + configs/chiliboard_defconfig | 1 + configs/chromebook_bob_defconfig | 1 + configs/chromebook_link64_defconfig | 1 - configs/chromebook_samus_tpl_defconfig | 2 ++ configs/ci20_mmc_defconfig | 1 + configs/cl-som-imx7_defconfig | 1 + configs/clearfog_defconfig | 1 + configs/cm_fx6_defconfig | 1 + configs/cm_t335_defconfig | 1 + configs/cm_t35_defconfig | 1 + configs/cm_t43_defconfig | 1 + configs/colibri_imx6_defconfig | 1 + configs/colibri_t20_defconfig | 1 + configs/colibri_t30_defconfig | 1 + configs/colorfly_e708_q1_defconfig | 1 + configs/controlcenterdc_defconfig | 1 + configs/corvus_defconfig | 1 + configs/da850evm_defconfig | 1 + configs/da850evm_nand_defconfig | 1 + configs/dalmore_defconfig | 1 + configs/db-88f6720_defconfig | 1 + configs/db-88f6820-amc_defconfig | 1 + configs/db-88f6820-gp_defconfig | 1 + configs/db-mv784mp-gp_defconfig | 1 + configs/devkit3250_defconfig | 1 + configs/devkit8000_defconfig | 1 + configs/dh_imx6_defconfig | 1 + configs/difrnce_dit4350_defconfig | 1 + configs/display5_defconfig | 1 - configs/display5_factory_defconfig | 1 + configs/draco_defconfig | 1 + configs/ds414_defconfig | 1 + configs/dserve_dsrv9703c_defconfig | 1 + configs/edminiv2_defconfig | 1 + configs/emlid_neutis_n5_devboard_defconfig | 1 + configs/etamin_defconfig | 1 + configs/evb-px5_defconfig | 2 ++ configs/evb-rk3229_defconfig | 2 ++ configs/evb-rk3288_defconfig | 2 ++ configs/evb-rk3328_defconfig | 2 ++ configs/evb-rk3399_defconfig | 2 ++ configs/ficus-rk3399_defconfig | 1 + configs/firefly-rk3288_defconfig | 1 + configs/firefly-rk3399_defconfig | 2 ++ configs/ga10h_v1_1_defconfig | 1 + .../gardena-smart-gateway-at91sam_defconfig | 1 + configs/gose_defconfig | 1 + configs/gt90h_v4_defconfig | 1 + configs/gwventana_emmc_defconfig | 1 + configs/gwventana_gw5904_defconfig | 1 + configs/gwventana_nand_defconfig | 1 + configs/h8_homlet_v2_defconfig | 1 + configs/harmony_defconfig | 1 + configs/helios4_defconfig | 1 + configs/i12-tvbox_defconfig | 1 + configs/iNet_3F_defconfig | 1 + configs/iNet_3W_defconfig | 1 + configs/iNet_86VS_defconfig | 1 + configs/iNet_D978_rev2_defconfig | 1 + configs/icnova-a20-swac_defconfig | 1 + configs/igep00x0_defconfig | 1 + configs/imx6dl_icore_nand_defconfig | 1 + configs/imx6dl_mamoj_defconfig | 1 + configs/imx6q_icore_nand_defconfig | 1 + configs/imx6q_logic_defconfig | 1 + configs/imx6qdl_icore_mipi_defconfig | 1 + configs/imx6qdl_icore_mmc_defconfig | 1 + configs/imx6qdl_icore_nand_defconfig | 1 + configs/imx6qdl_icore_rqs_defconfig | 1 + configs/imx6ul_geam_mmc_defconfig | 1 + configs/imx6ul_geam_nand_defconfig | 1 + configs/imx6ul_isiot_emmc_defconfig | 1 + configs/imx6ul_isiot_nand_defconfig | 1 + configs/imx8mq_evk_defconfig | 1 + configs/imx8qm_mek_defconfig | 1 + configs/imx8qxp_mek_defconfig | 1 + configs/inet1_defconfig | 1 + configs/inet86dz_defconfig | 1 + configs/inet97fv2_defconfig | 1 + configs/inet98v_rev2_defconfig | 1 + configs/inet9f_rev03_defconfig | 1 + configs/inet_q972_defconfig | 1 + configs/j721e_evm_r5_defconfig | 1 - configs/jesurun_q5_defconfig | 1 + configs/jetson-tk1_defconfig | 1 + configs/k2e_evm_defconfig | 1 + configs/k2g_evm_defconfig | 1 + configs/k2hk_evm_defconfig | 1 + configs/k2l_evm_defconfig | 1 + configs/khadas-edge-captain-rk3399_defconfig | 2 ++ configs/khadas-edge-rk3399_defconfig | 2 ++ configs/khadas-edge-v-rk3399_defconfig | 2 ++ configs/koelsch_defconfig | 1 + configs/kp_imx6q_tpc_defconfig | 1 + configs/kylin-rk3036_defconfig | 1 + configs/lager_defconfig | 1 + configs/libretech_all_h3_cc_h2_plus_defconfig | 1 + configs/libretech_all_h3_cc_h3_defconfig | 1 + configs/libretech_all_h3_cc_h5_defconfig | 1 + configs/lion-rk3368_defconfig | 2 ++ configs/liteboard_defconfig | 1 + configs/ls1021aiot_sdcard_defconfig | 1 + configs/ls1021aqds_nand_defconfig | 1 - configs/ls1021aqds_sdcard_ifc_defconfig | 1 - configs/ls1021aqds_sdcard_qspi_defconfig | 1 - configs/ls1021atsn_sdcard_defconfig | 1 - ...s1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 1 - configs/ls1021atwr_sdcard_ifc_defconfig | 1 - configs/ls1021atwr_sdcard_qspi_defconfig | 1 - configs/ls1043aqds_nand_defconfig | 1 - configs/ls1043aqds_sdcard_ifc_defconfig | 1 - configs/ls1043aqds_sdcard_qspi_defconfig | 1 - configs/ls1043ardb_nand_SECURE_BOOT_defconfig | 1 - configs/ls1043ardb_nand_defconfig | 1 - .../ls1043ardb_sdcard_SECURE_BOOT_defconfig | 1 - configs/ls1043ardb_sdcard_defconfig | 1 - configs/ls1046aqds_nand_defconfig | 1 + configs/ls1046aqds_sdcard_ifc_defconfig | 1 - configs/ls1046aqds_sdcard_qspi_defconfig | 1 - configs/ls1046ardb_emmc_defconfig | 1 - configs/ls1046ardb_qspi_spl_defconfig | 1 - .../ls1046ardb_sdcard_SECURE_BOOT_defconfig | 1 - configs/ls1046ardb_sdcard_defconfig | 1 - configs/ls1088aqds_sdcard_ifc_defconfig | 1 - configs/ls1088aqds_sdcard_qspi_defconfig | 1 - ...1088ardb_sdcard_qspi_SECURE_BOOT_defconfig | 1 - configs/ls1088ardb_sdcard_qspi_defconfig | 1 - configs/ls2080aqds_nand_defconfig | 1 - configs/ls2080aqds_sdcard_defconfig | 1 - configs/ls2080ardb_nand_defconfig | 1 - configs/m53menlo_defconfig | 1 + configs/maxbcm_defconfig | 1 + configs/mccmon6_nor_defconfig | 1 - configs/mccmon6_sd_defconfig | 1 - configs/medcom-wide_defconfig | 1 + configs/miqi-rk3288_defconfig | 1 + configs/mixtile_loftq_defconfig | 1 + configs/mk802_a10s_defconfig | 1 + configs/mk802_defconfig | 1 + configs/mk802ii_defconfig | 1 + configs/mx23_olinuxino_defconfig | 1 + configs/mx23evk_defconfig | 1 + configs/mx28evk_auart_console_defconfig | 1 + configs/mx28evk_defconfig | 1 + configs/mx28evk_nand_defconfig | 1 + configs/mx31pdk_defconfig | 1 + configs/mx6cuboxi_defconfig | 1 + configs/mx6sabreauto_defconfig | 1 + configs/mx6sabresd_defconfig | 1 + configs/mx6slevk_spl_defconfig | 1 + configs/mx6sxsabresd_spl_defconfig | 1 + configs/mx6ul_14x14_evk_defconfig | 1 + configs/mx6ul_9x9_evk_defconfig | 1 + configs/nanopc-t4-rk3399_defconfig | 2 ++ configs/nanopi-m4-rk3399_defconfig | 2 ++ configs/nanopi-neo4-rk3399_defconfig | 2 ++ configs/nanopi_a64_defconfig | 1 + configs/nanopi_m1_defconfig | 1 + configs/nanopi_m1_plus_defconfig | 1 + configs/nanopi_neo2_defconfig | 1 + configs/nanopi_neo_air_defconfig | 1 + configs/nanopi_neo_defconfig | 1 + configs/nanopi_neo_plus2_defconfig | 1 + configs/novena_defconfig | 1 + configs/nyan-big_defconfig | 1 + configs/oceanic_5205_5inmfd_defconfig | 1 + configs/omap35_logic_defconfig | 1 + configs/omap35_logic_somlv_defconfig | 1 + configs/omap3_beagle_defconfig | 1 + configs/omap3_evm_defconfig | 1 + configs/omap3_ha_defconfig | 1 + configs/omap3_logic_defconfig | 1 + configs/omap3_logic_somlv_defconfig | 1 + configs/omap3_overo_defconfig | 1 + configs/omap4_panda_defconfig | 1 + configs/omap4_sdp4430_defconfig | 1 + configs/omapl138_lcdk_defconfig | 1 + configs/opos6uldev_defconfig | 1 - configs/orangepi-rk3399_defconfig | 2 ++ configs/orangepi_2_defconfig | 1 + configs/orangepi_lite2_defconfig | 1 + configs/orangepi_lite_defconfig | 1 + configs/orangepi_one_defconfig | 1 + configs/orangepi_one_plus_defconfig | 1 + configs/orangepi_pc2_defconfig | 1 + configs/orangepi_pc_defconfig | 1 + configs/orangepi_pc_plus_defconfig | 1 + configs/orangepi_plus2e_defconfig | 1 + configs/orangepi_plus_defconfig | 1 + configs/orangepi_prime_defconfig | 1 + configs/orangepi_r1_defconfig | 1 + configs/orangepi_win_defconfig | 1 + configs/orangepi_zero_defconfig | 1 + configs/orangepi_zero_plus2_defconfig | 1 + configs/orangepi_zero_plus_defconfig | 1 + configs/origen_defconfig | 1 + configs/ot1200_spl_defconfig | 1 + configs/parrot_r16_defconfig | 1 + configs/paz00_defconfig | 1 + configs/pcm051_rev1_defconfig | 1 - configs/pcm051_rev3_defconfig | 1 - configs/pcm058_defconfig | 1 + configs/peach-pi_defconfig | 1 + configs/peach-pit_defconfig | 1 + configs/pengwyn_defconfig | 1 - configs/phycore-am335x-r2-wega_defconfig | 1 + configs/phycore-rk3288_defconfig | 1 + configs/pico-hobbit-imx6ul_defconfig | 1 + configs/pico-hobbit-imx7d_defconfig | 1 + configs/pico-imx6ul_defconfig | 1 + configs/pico-imx7d_bl33_defconfig | 1 + configs/pico-imx7d_defconfig | 1 + configs/pico-pi-imx6ul_defconfig | 1 + configs/pico-pi-imx7d_defconfig | 1 + configs/picosam9g45_defconfig | 1 + configs/pine64-lts_defconfig | 1 + configs/pine64_plus_defconfig | 1 + configs/pine_h64_defconfig | 1 + configs/pinebook_defconfig | 1 + configs/platinum_picon_defconfig | 1 + configs/platinum_titanium_defconfig | 1 + configs/plutux_defconfig | 1 + configs/polaroid_mid2407pxe03_defconfig | 1 + configs/polaroid_mid2809pxe04_defconfig | 1 + configs/popmetal-rk3288_defconfig | 1 + configs/porter_defconfig | 1 + configs/pov_protab2_ips9_defconfig | 1 + configs/puma-rk3399_defconfig | 1 + configs/pxm2_defconfig | 1 + configs/q8_a13_tablet_defconfig | 1 + configs/q8_a23_tablet_800x480_defconfig | 1 + configs/q8_a33_tablet_1024x600_defconfig | 1 + configs/q8_a33_tablet_800x480_defconfig | 1 + configs/qemu-riscv32_smode_defconfig | 1 + configs/qemu-x86_64_defconfig | 1 - configs/r7-tv-dongle_defconfig | 1 + configs/r8a7795_salvator-x_defconfig | 1 + configs/r8a7795_ulcb_defconfig | 1 + configs/r8a77965_salvator-x_defconfig | 1 + configs/r8a77965_ulcb_defconfig | 1 + configs/r8a7796_salvator-x_defconfig | 1 + configs/r8a7796_ulcb_defconfig | 1 + configs/r8a77970_eagle_defconfig | 1 + configs/r8a77980_condor_defconfig | 1 + configs/r8a77990_ebisu_defconfig | 1 + configs/r8a77995_draak_defconfig | 1 + configs/rastaban_defconfig | 1 + configs/riotboard_spl_defconfig | 1 + configs/roc-rk3399-pc_defconfig | 2 ++ configs/rock-pi-4-rk3399_defconfig | 2 ++ configs/rock2_defconfig | 1 + configs/rock64-rk3328_defconfig | 2 ++ configs/rock960-rk3399_defconfig | 1 + configs/rock_defconfig | 1 + configs/rockpro64-rk3399_defconfig | 2 ++ configs/rut_defconfig | 1 + configs/sama5d27_som1_ek_mmc1_defconfig | 1 + configs/sama5d27_som1_ek_mmc_defconfig | 1 + configs/sama5d27_som1_ek_qspiflash_defconfig | 1 + configs/sama5d2_icp_mmc_defconfig | 1 + configs/sama5d2_xplained_emmc_defconfig | 1 + configs/sama5d2_xplained_mmc_defconfig | 1 + configs/sama5d2_xplained_qspiflash_defconfig | 1 + configs/sama5d2_xplained_spiflash_defconfig | 1 + configs/sama5d3_xplained_mmc_defconfig | 1 + configs/sama5d3_xplained_nandflash_defconfig | 1 + configs/sama5d3xek_mmc_defconfig | 1 + configs/sama5d3xek_nandflash_defconfig | 1 + configs/sama5d3xek_spiflash_defconfig | 1 + configs/sama5d4_xplained_mmc_defconfig | 1 + configs/sama5d4_xplained_nandflash_defconfig | 1 + configs/sama5d4_xplained_spiflash_defconfig | 1 + configs/sama5d4ek_mmc_defconfig | 1 + configs/sama5d4ek_nandflash_defconfig | 1 + configs/sama5d4ek_spiflash_defconfig | 1 + configs/sandbox_spl_defconfig | 1 - configs/sc_sps_1_defconfig | 1 + configs/seaboard_defconfig | 1 + configs/sh7752evb_defconfig | 1 + configs/silk_defconfig | 1 + configs/sksimx6_defconfig | 1 + configs/smartweb_defconfig | 1 + configs/smdk5250_defconfig | 1 + configs/smdk5420_defconfig | 1 + configs/smdkv310_defconfig | 1 + configs/snow_defconfig | 1 + configs/socfpga_arria10_defconfig | 1 - configs/socfpga_arria5_defconfig | 1 + configs/socfpga_cyclone5_defconfig | 1 + configs/socfpga_dbm_soc1_defconfig | 1 + configs/socfpga_de0_nano_soc_defconfig | 1 + configs/socfpga_de10_nano_defconfig | 1 + configs/socfpga_de1_soc_defconfig | 1 + configs/socfpga_is1_defconfig | 1 + configs/socfpga_mcvevk_defconfig | 1 + configs/socfpga_sockit_defconfig | 1 + configs/socfpga_socrates_defconfig | 1 + configs/socfpga_sr1500_defconfig | 1 + configs/socfpga_stratix10_defconfig | 1 + configs/socfpga_vining_fpga_defconfig | 1 + configs/sopine_baseboard_defconfig | 1 + configs/spring_defconfig | 1 + configs/stout_defconfig | 1 + configs/sun8i_a23_evb_defconfig | 1 + configs/sunxi_Gemei_G9_defconfig | 1 + configs/tao3530_defconfig | 1 + configs/taurus_defconfig | 1 + configs/tbs_a711_defconfig | 1 + configs/tec-ng_defconfig | 1 + configs/tec_defconfig | 1 + configs/teres_i_defconfig | 1 + configs/theadorable_debug_defconfig | 1 + configs/thuban_defconfig | 1 + configs/ti816x_evm_defconfig | 1 + configs/tinker-rk3288_defconfig | 2 ++ configs/tricorder_defconfig | 1 + configs/trimslice_defconfig | 1 + configs/ts4600_defconfig | 1 + configs/turris_omnia_defconfig | 1 + configs/udoo_defconfig | 1 + configs/udoo_neo_defconfig | 1 - configs/venice2_defconfig | 1 + configs/ventana_defconfig | 1 + configs/vyasa-rk3288_defconfig | 2 ++ configs/wandboard_defconfig | 1 + configs/wb45n_defconfig | 1 + configs/wb50n_defconfig | 1 + configs/woodburn_sd_defconfig | 1 + configs/work_92105_defconfig | 1 + configs/x530_defconfig | 1 + configs/x600_defconfig | 1 + .../xilinx_zynqmp_zc1751_xm015_dc1_defconfig | 1 + .../xilinx_zynqmp_zc1751_xm018_dc4_defconfig | 1 + .../xilinx_zynqmp_zc1751_xm019_dc5_defconfig | 1 + configs/xilinx_zynqmp_zcu102_rev1_0_defconfig | 1 + configs/xilinx_zynqmp_zcu102_revA_defconfig | 1 + configs/xilinx_zynqmp_zcu102_revB_defconfig | 1 + configs/xilinx_zynqmp_zcu104_revA_defconfig | 1 + configs/xilinx_zynqmp_zcu104_revC_defconfig | 1 + configs/xilinx_zynqmp_zcu106_revA_defconfig | 1 + configs/xilinx_zynqmp_zcu111_revA_defconfig | 1 + configs/xpress_spl_defconfig | 1 + configs/zc5202_defconfig | 1 + configs/zc5601_defconfig | 1 + configs/zynq_dlc20_rev1_0_defconfig | 1 + configs/zynq_microzed_defconfig | 1 + configs/zynq_minized_defconfig | 1 + configs/zynq_zc702_defconfig | 1 + configs/zynq_zc706_defconfig | 1 + configs/zynq_zc770_xm010_defconfig | 1 + configs/zynq_zc770_xm012_defconfig | 1 + configs/zynq_zed_defconfig | 1 + configs/zynq_zybo_defconfig | 1 + configs/zynq_zybo_z7_defconfig | 1 + drivers/input/input.c | 2 +- drivers/mtd/nand/raw/Makefile | 4 +-- drivers/reset/reset-socfpga.c | 2 +- env/Kconfig | 33 +++++++++++++++++-- env/Makefile | 11 +++---- env/common.c | 6 ++-- include/configs/ls1021aiot.h | 1 - include/configs/ls1046a_common.h | 1 - include/configs/xilinx_zynqmp.h | 1 - include/env_callback.h | 4 +++ include/env_default.h | 4 +++ include/env_flags.h | 4 +++ 585 files changed, 529 insertions(+), 189 deletions(-)
diff --git a/arch/arm/mach-omap2/Kconfig b/arch/arm/mach-omap2/Kconfig index ed8056e871..d2c48d2d52 100644 --- a/arch/arm/mach-omap2/Kconfig +++ b/arch/arm/mach-omap2/Kconfig @@ -58,7 +58,6 @@ config OMAP54XX imply NAND_OMAP_ELM imply NAND_OMAP_GPMC imply SPL_DISPLAY_PRINT - imply SPL_ENV_SUPPORT imply SPL_FS_EXT4 imply SPL_FS_FAT imply SPL_GPIO_SUPPORT diff --git a/arch/arm/mach-omap2/am33xx/Kconfig b/arch/arm/mach-omap2/am33xx/Kconfig index 7f6b344c82..0f12f46d10 100644 --- a/arch/arm/mach-omap2/am33xx/Kconfig +++ b/arch/arm/mach-omap2/am33xx/Kconfig @@ -37,7 +37,6 @@ config TARGET_AM335X_EVM imply CMD_DM imply SPL_DM imply SPL_DM_SEQ_ALIAS - imply SPL_ENV_SUPPORT imply SPL_FS_EXT4 imply SPL_FS_FAT imply SPL_GPIO_SUPPORT @@ -248,7 +247,6 @@ config TARGET_AM43XX_EVM imply DM_I2C imply DM_SPI imply DM_SPI_FLASH - imply SPL_ENV_SUPPORT imply SPL_FS_EXT4 imply SPL_FS_FAT imply SPL_GPIO_SUPPORT diff --git a/board/birdland/bav335x/board.c b/board/birdland/bav335x/board.c index 8811583ac6..57b86fbc0d 100644 --- a/board/birdland/bav335x/board.c +++ b/board/birdland/bav335x/board.c @@ -159,7 +159,7 @@ int spl_start_uboot(void) if (serial_tstc() && serial_getc() == 'c') return 1;
-#ifdef CONFIG_SPL_ENV_SUPPORT +#if ENV_IS_SOMEWHERE env_init(); env_load(); if (env_get_yesno("boot_os") != 1) diff --git a/board/gateworks/gw_ventana/gw_ventana_spl.c b/board/gateworks/gw_ventana/gw_ventana_spl.c index b0891379a1..98ed0379d0 100644 --- a/board/gateworks/gw_ventana/gw_ventana_spl.c +++ b/board/gateworks/gw_ventana/gw_ventana_spl.c @@ -756,7 +756,7 @@ int spl_start_uboot(void) unsigned char ret = 1;
debug("%s\n", __func__); -#ifdef CONFIG_SPL_ENV_SUPPORT +#if ENV_IS_IN_SOMEWHERE env_init(); env_load(); debug("boot_os=%s\n", env_get("boot_os")); diff --git a/board/liebherr/display5/spl.c b/board/liebherr/display5/spl.c index 354b63e431..3fc30f5975 100644 --- a/board/liebherr/display5/spl.c +++ b/board/liebherr/display5/spl.c @@ -280,7 +280,7 @@ void board_boot_order(u32 *spl_boot_list) if (board_check_emergency_pad()) return;
-#ifdef CONFIG_SPL_ENV_SUPPORT +#if ENV_IS_IN_SOMEWHERE /* 'fastboot' */ const char *s;
@@ -312,7 +312,7 @@ int spl_start_uboot(void) if (serial_tstc() && serial_getc() == 'c') return 1;
-#ifdef CONFIG_SPL_ENV_SUPPORT +#if ENV_IS_IN_SOMEWHERE if (env_get_yesno("boot_os") != 1) return 1; #endif diff --git a/board/tcl/sl50/board.c b/board/tcl/sl50/board.c index c7eed31946..66e70aeb85 100644 --- a/board/tcl/sl50/board.c +++ b/board/tcl/sl50/board.c @@ -73,7 +73,7 @@ int spl_start_uboot(void) if (serial_tstc() && serial_getc() == 'c') return 1;
-#ifdef CONFIG_SPL_ENV_SUPPORT +#if ENV_IS_IN_SOMEWHERE env_init(); env_load(); if (env_get_yesno("boot_os") != 1) diff --git a/board/ti/am335x/board.c b/board/ti/am335x/board.c index 7eaa6cd96d..f124e88e15 100644 --- a/board/ti/am335x/board.c +++ b/board/ti/am335x/board.c @@ -249,7 +249,7 @@ int spl_start_uboot(void) return 1; #endif
-#ifdef CONFIG_SPL_ENV_SUPPORT +#if ENV_IS_IN_SOMEWHERE env_init(); env_load(); if (env_get_yesno("boot_os") != 1) diff --git a/board/ti/am57xx/board.c b/board/ti/am57xx/board.c index f78e6c2e1f..537aacda85 100644 --- a/board/ti/am57xx/board.c +++ b/board/ti/am57xx/board.c @@ -869,7 +869,7 @@ int spl_start_uboot(void) if (serial_tstc() && serial_getc() == 'c') return 1;
-#ifdef CONFIG_SPL_ENV_SUPPORT +#if ENV_IS_IN_SOMEWHERE env_init(); env_load(); if (env_get_yesno("boot_os") != 1) diff --git a/board/ti/dra7xx/evm.c b/board/ti/dra7xx/evm.c index 74d04bb1e3..f1bb7df561 100644 --- a/board/ti/dra7xx/evm.c +++ b/board/ti/dra7xx/evm.c @@ -978,7 +978,7 @@ int spl_start_uboot(void) if (serial_tstc() && serial_getc() == 'c') return 1;
-#ifdef CONFIG_SPL_ENV_SUPPORT +#if ENV_IS_IN_SOMEWHERE env_init(); env_load(); if (env_get_yesno("boot_os") != 1) diff --git a/cmd/Kconfig b/cmd/Kconfig index 98647f58b7..217c948b40 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -465,6 +465,7 @@ config CMD_ENV_EXISTS
config CMD_ENV_CALLBACK bool "env callbacks - print callbacks and their associated variables" + depends on ENV_FULL_SUPPORT help Some environment variable have callbacks defined by U_BOOT_ENV_CALLBACK. These are called when the variable changes. @@ -473,6 +474,7 @@ config CMD_ENV_CALLBACK
config CMD_ENV_FLAGS bool "env flags -print variables that have non-default flags" + depends on ENV_FULL_SUPPORT help Some environment variables have special flags that control their behaviour. For example, serial# can only be written once and cannot diff --git a/cmd/nvedit.c b/cmd/nvedit.c index 7a6ec5ae30..388cd5aae6 100644 --- a/cmd/nvedit.c +++ b/cmd/nvedit.c @@ -40,13 +40,11 @@
-#if !defined(CONFIG_SPL_BUILD) || CONFIG_IS_ENABLED(ENV_SUPPORT) #if !ENV_IS_IN_SOMEWHERE && \ !CONFIG_IS_ENABLED(ENV_IS_NOWHERE) # error Define one of CONFIG_ENV_IS_IN_{EEPROM|FLASH|MMC|FAT|EXT4|\ NAND|NVRAM|ONENAND|SATA|SPI_FLASH|REMOTE|UBI} or CONFIG_ENV_IS_NOWHERE #endif -#endif
/* * Maximum expected input data size for import command diff --git a/common/spl/Kconfig b/common/spl/Kconfig index f467eca2be..2d7b7b093f 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -162,7 +162,6 @@ config SPL_BOOTROM_SUPPORT
config SPL_BOOTCOUNT_LIMIT bool "Support bootcount in SPL" - depends on SPL_ENV_SUPPORT help On some boards, which use 'falcon' mode, it is necessary to check and increment the number of boot attempts. Such boards do not @@ -460,21 +459,8 @@ config SPL_DRIVERS_MISC_SUPPORT option to build the drivers in drivers/misc as part of an SPL build, for those that support building in SPL (not all drivers do).
-config SPL_ENV_SUPPORT - bool "Support an environment" - help - Enable environment support in SPL. The U-Boot environment provides - a number of settings (essentially name/value pairs) which can - control many aspects of U-Boot's operation. Normally this is not - needed in SPL as it has a much simpler task with less - configuration. But some boards use this to support 'Falcon' boot - on EXT2 and FAT, where SPL boots directly into Linux without - starting U-Boot first. Enabling this option will make env_get() - and env_set() available in SPL. - config SPL_SAVEENV bool "Support save environment" - depends on SPL_ENV_SUPPORT select SPL_MMC_WRITE if ENV_IS_IN_MMC help Enable save environment support in SPL after setenv. By default @@ -488,7 +474,6 @@ config SPL_SAVEENV
config SPL_ETH_SUPPORT bool "Support Ethernet" - depends on SPL_ENV_SUPPORT help Enable access to the network subsystem and associated Ethernet drivers in SPL. This permits SPL to load U-Boot over an Ethernet @@ -1270,11 +1255,6 @@ config TPL_DRIVERS_MISC_SUPPORT option to build the drivers in drivers/misc as part of an TPL build, for those that support building in TPL (not all drivers do).
-config TPL_ENV_SUPPORT - bool "Support an environment" - help - Enable environment support in TPL. See SPL_ENV_SUPPORT for details. - config TPL_GPIO_SUPPORT bool "Support GPIO in TPL" help diff --git a/common/spl/spl_ext.c b/common/spl/spl_ext.c index 2a6252229c..0ee3368659 100644 --- a/common/spl/spl_ext.c +++ b/common/spl/spl_ext.c @@ -86,7 +86,7 @@ int spl_load_image_ext_os(struct spl_image_info *spl_image, #endif return -1; } -#if defined(CONFIG_SPL_ENV_SUPPORT) +#if ENV_IS_IN_SOMEWHERE file = env_get("falcon_args_file"); if (file) { err = ext4fs_open(file, &filelen); diff --git a/common/spl/spl_fat.c b/common/spl/spl_fat.c index aa371ab52c..07a76f071e 100644 --- a/common/spl/spl_fat.c +++ b/common/spl/spl_fat.c @@ -122,7 +122,7 @@ int spl_load_image_fat_os(struct spl_image_info *spl_image, if (err) return err;
-#if defined(CONFIG_SPL_ENV_SUPPORT) && defined(CONFIG_SPL_OS_BOOT) +#if ENV_IS_IN_SOMEWHERE file = env_get("falcon_args_file"); if (file) { err = file_fat_read(file, (void *)CONFIG_SYS_SPL_ARGS_ADDR, 0); diff --git a/configs/A10-OLinuXino-Lime_defconfig b/configs/A10-OLinuXino-Lime_defconfig index 9eea922d10..3c3fecad98 100644 --- a/configs/A10-OLinuXino-Lime_defconfig +++ b/configs/A10-OLinuXino-Lime_defconfig @@ -17,6 +17,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-olinuxino-lime" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SCSI_AHCI=y CONFIG_MII=y CONFIG_SUN4I_EMAC=y diff --git a/configs/A10s-OLinuXino-M_defconfig b/configs/A10s-OLinuXino-M_defconfig index d92a70e4d0..42098fa80a 100644 --- a/configs/A10s-OLinuXino-M_defconfig +++ b/configs/A10s-OLinuXino-M_defconfig @@ -15,6 +15,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun5i-a10s-olinuxino-micro" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_MII=y CONFIG_SUN4I_EMAC=y CONFIG_AXP152_POWER=y diff --git a/configs/A13-OLinuXinoM_defconfig b/configs/A13-OLinuXinoM_defconfig index da80d35054..fc0dec5fb4 100644 --- a/configs/A13-OLinuXinoM_defconfig +++ b/configs/A13-OLinuXinoM_defconfig @@ -18,6 +18,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-olinuxino-micro" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SUNXI_NO_PMIC=y CONFIG_CONS_INDEX=2 CONFIG_USB_EHCI_HCD=y diff --git a/configs/A13-OLinuXino_defconfig b/configs/A13-OLinuXino_defconfig index dfd439a52e..b8760639b9 100644 --- a/configs/A13-OLinuXino_defconfig +++ b/configs/A13-OLinuXino_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-olinuxino" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DFU_RAM=y CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_AXP_ALDO3_VOLT=3300 diff --git a/configs/A20-OLinuXino-Lime2-eMMC_defconfig b/configs/A20-OLinuXino-Lime2-eMMC_defconfig index 7e48328290..fc91e0f60e 100644 --- a/configs/A20-OLinuXino-Lime2-eMMC_defconfig +++ b/configs/A20-OLinuXino-Lime2-eMMC_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-lime2-emmc" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SCSI_AHCI=y CONFIG_DFU_RAM=y CONFIG_FASTBOOT_CMD_OEM_FORMAT=y diff --git a/configs/A20-OLinuXino-Lime2_defconfig b/configs/A20-OLinuXino-Lime2_defconfig index 084dab0ceb..134b025887 100644 --- a/configs/A20-OLinuXino-Lime2_defconfig +++ b/configs/A20-OLinuXino-Lime2_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-lime2" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SCSI_AHCI=y CONFIG_DFU_RAM=y CONFIG_FASTBOOT_CMD_OEM_FORMAT=y diff --git a/configs/A20-OLinuXino-Lime_defconfig b/configs/A20-OLinuXino-Lime_defconfig index ffeeda414e..99d33a6e80 100644 --- a/configs/A20-OLinuXino-Lime_defconfig +++ b/configs/A20-OLinuXino-Lime_defconfig @@ -15,6 +15,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-lime" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SCSI_AHCI=y CONFIG_ETH_DESIGNWARE=y CONFIG_MII=y diff --git a/configs/A20-OLinuXino_MICRO-eMMC_defconfig b/configs/A20-OLinuXino_MICRO-eMMC_defconfig index f4c6c54cfd..e4ac729007 100644 --- a/configs/A20-OLinuXino_MICRO-eMMC_defconfig +++ b/configs/A20-OLinuXino_MICRO-eMMC_defconfig @@ -17,6 +17,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-micro-emmc" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SCSI_AHCI=y CONFIG_ETH_DESIGNWARE=y CONFIG_MII=y diff --git a/configs/A20-OLinuXino_MICRO_defconfig b/configs/A20-OLinuXino_MICRO_defconfig index 440eebbeec..535dad48b0 100644 --- a/configs/A20-OLinuXino_MICRO_defconfig +++ b/configs/A20-OLinuXino_MICRO_defconfig @@ -18,6 +18,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-micro" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SCSI_AHCI=y CONFIG_ETH_DESIGNWARE=y CONFIG_MII=y diff --git a/configs/A20-Olimex-SOM-EVB_defconfig b/configs/A20-Olimex-SOM-EVB_defconfig index 48c4c3e53a..fd6852b243 100644 --- a/configs/A20-Olimex-SOM-EVB_defconfig +++ b/configs/A20-Olimex-SOM-EVB_defconfig @@ -19,6 +19,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olimex-som-evb" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SCSI_AHCI=y CONFIG_ETH_DESIGNWARE=y CONFIG_RGMII=y diff --git a/configs/A20-Olimex-SOM204-EVB-eMMC_defconfig b/configs/A20-Olimex-SOM204-EVB-eMMC_defconfig index 193e20aa8b..7a5a4340cb 100644 --- a/configs/A20-Olimex-SOM204-EVB-eMMC_defconfig +++ b/configs/A20-Olimex-SOM204-EVB-eMMC_defconfig @@ -19,6 +19,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olimex-som204-evb-emmc" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SCSI_AHCI=y CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_PHY_ADDR=3 diff --git a/configs/A20-Olimex-SOM204-EVB_defconfig b/configs/A20-Olimex-SOM204-EVB_defconfig index 42a73c8057..8d8661c6dc 100644 --- a/configs/A20-Olimex-SOM204-EVB_defconfig +++ b/configs/A20-Olimex-SOM204-EVB_defconfig @@ -18,6 +18,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olimex-som204-evb" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SCSI_AHCI=y CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_PHY_ADDR=3 diff --git a/configs/A33-OLinuXino_defconfig b/configs/A33-OLinuXino_defconfig index 6ea4238342..409fe3651c 100644 --- a/configs/A33-OLinuXino_defconfig +++ b/configs/A33-OLinuXino_defconfig @@ -21,6 +21,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-olinuxino" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_AXP_DCDC1_VOLT=3300 CONFIG_USB_MUSB_HOST=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/Ainol_AW1_defconfig b/configs/Ainol_AW1_defconfig index 9b7f19736c..609bb22e2f 100644 --- a/configs/Ainol_AW1_defconfig +++ b/configs/Ainol_AW1_defconfig @@ -20,5 +20,6 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-ainol-aw1" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_USB_MUSB_HOST=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/Ampe_A76_defconfig b/configs/Ampe_A76_defconfig index 1810d48a0b..dddb1ae75d 100644 --- a/configs/Ampe_A76_defconfig +++ b/configs/Ampe_A76_defconfig @@ -21,6 +21,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-ampe-a76" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_CONS_INDEX=2 CONFIG_USB_MUSB_HOST=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/Auxtek-T003_defconfig b/configs/Auxtek-T003_defconfig index 2dc6c8d8e2..879b15e89e 100644 --- a/configs/Auxtek-T003_defconfig +++ b/configs/Auxtek-T003_defconfig @@ -14,6 +14,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun5i-a10s-auxtek-t003" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_AXP152_POWER=y CONFIG_CONS_INDEX=2 CONFIG_USB_EHCI_HCD=y diff --git a/configs/Auxtek-T004_defconfig b/configs/Auxtek-T004_defconfig index 4395d5b724..ebbc68d692 100644 --- a/configs/Auxtek-T004_defconfig +++ b/configs/Auxtek-T004_defconfig @@ -12,6 +12,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun5i-a10s-auxtek-t004" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_AXP152_POWER=y CONFIG_CONS_INDEX=2 CONFIG_USB_EHCI_HCD=y diff --git a/configs/B4420QDS_NAND_defconfig b/configs/B4420QDS_NAND_defconfig index 2afce5e54e..a7f3dc110d 100644 --- a/configs/B4420QDS_NAND_defconfig +++ b/configs/B4420QDS_NAND_defconfig @@ -21,7 +21,6 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_NAND_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_TEXT_BASE=0xFFFD8000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_SPL_NAND_SUPPORT=y diff --git a/configs/B4860QDS_NAND_defconfig b/configs/B4860QDS_NAND_defconfig index 8e0fb2baf0..9b3c5d7087 100644 --- a/configs/B4860QDS_NAND_defconfig +++ b/configs/B4860QDS_NAND_defconfig @@ -21,7 +21,6 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_NAND_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_TEXT_BASE=0xFFFD8000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_SPL_NAND_SUPPORT=y diff --git a/configs/BSC9131RDB_NAND_SYSCLK100_defconfig b/configs/BSC9131RDB_NAND_SYSCLK100_defconfig index b221db1748..8f179bc5a2 100644 --- a/configs/BSC9131RDB_NAND_SYSCLK100_defconfig +++ b/configs/BSC9131RDB_NAND_SYSCLK100_defconfig @@ -32,6 +32,7 @@ CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand0=ff800000.flash," CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:1m(uboot),8m(kernel),512k(dtb),-(fs)" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_FSL_CAAM=y # CONFIG_MMC is not set CONFIG_NAND=y diff --git a/configs/BSC9131RDB_NAND_defconfig b/configs/BSC9131RDB_NAND_defconfig index 921c90fffe..27a8291a6d 100644 --- a/configs/BSC9131RDB_NAND_defconfig +++ b/configs/BSC9131RDB_NAND_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand0=ff800000.flash," CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:1m(uboot),8m(kernel),512k(dtb),-(fs)" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_FSL_CAAM=y # CONFIG_MMC is not set CONFIG_NAND=y diff --git a/configs/BSC9132QDS_NAND_DDRCLK100_defconfig b/configs/BSC9132QDS_NAND_DDRCLK100_defconfig index a82544df14..75cc29a375 100644 --- a/configs/BSC9132QDS_NAND_DDRCLK100_defconfig +++ b/configs/BSC9132QDS_NAND_DDRCLK100_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_FAT=y CONFIG_MTDIDS_DEFAULT="nor0=88000000.nor,nand0=ff800000.flash," CONFIG_MTDPARTS_DEFAULT="mtdparts=88000000.nor:256k(dtb),7m(kernel),55m(fs),1m(uboot);ff800000.flash:1m(uboot),8m(kernel),512k(dtb),-(fs)" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/BSC9132QDS_NAND_DDRCLK133_defconfig b/configs/BSC9132QDS_NAND_DDRCLK133_defconfig index 037337254d..9822e58e39 100644 --- a/configs/BSC9132QDS_NAND_DDRCLK133_defconfig +++ b/configs/BSC9132QDS_NAND_DDRCLK133_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_FAT=y CONFIG_MTDIDS_DEFAULT="nor0=88000000.nor,nand0=ff800000.flash," CONFIG_MTDPARTS_DEFAULT="mtdparts=88000000.nor:256k(dtb),7m(kernel),55m(fs),1m(uboot);ff800000.flash:1m(uboot),8m(kernel),512k(dtb),-(fs)" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/Bananapi_M2_Ultra_defconfig b/configs/Bananapi_M2_Ultra_defconfig index 40b60599d5..7bee14d92c 100644 --- a/configs/Bananapi_M2_Ultra_defconfig +++ b/configs/Bananapi_M2_Ultra_defconfig @@ -13,6 +13,7 @@ CONFIG_USE_PREBOOT=y CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-r40-bananapi-m2-ultra" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SCSI_AHCI=y CONFIG_RGMII=y CONFIG_SUN8I_EMAC=y diff --git a/configs/Bananapi_defconfig b/configs/Bananapi_defconfig index abd7d3d125..8c75c2d2b9 100644 --- a/configs/Bananapi_defconfig +++ b/configs/Bananapi_defconfig @@ -15,6 +15,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-bananapi" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NETCONSOLE=y CONFIG_SCSI_AHCI=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/Bananapi_m2m_defconfig b/configs/Bananapi_m2m_defconfig index b4f3794153..a6871968a8 100644 --- a/configs/Bananapi_m2m_defconfig +++ b/configs/Bananapi_m2m_defconfig @@ -15,6 +15,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-r16-bananapi-m2m" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/Bananapro_defconfig b/configs/Bananapro_defconfig index c5d33a2e14..4f9b2702df 100644 --- a/configs/Bananapro_defconfig +++ b/configs/Bananapro_defconfig @@ -17,6 +17,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-bananapro" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NETCONSOLE=y CONFIG_SCSI_AHCI=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/C29XPCIE_NAND_defconfig b/configs/C29XPCIE_NAND_defconfig index 1a0666fcf2..1693e094a6 100644 --- a/configs/C29XPCIE_NAND_defconfig +++ b/configs/C29XPCIE_NAND_defconfig @@ -21,7 +21,6 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_TEXT_BASE=0xFF800000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y -CONFIG_TPL_ENV_SUPPORT=y CONFIG_TPL_I2C_SUPPORT=y CONFIG_TPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_TPL_NAND_SUPPORT=y @@ -35,6 +34,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_DOS_PARTITION=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_FSL_CAAM=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/CHIP_pro_defconfig b/configs/CHIP_pro_defconfig index 82994212a2..5bbbc42590 100644 --- a/configs/CHIP_pro_defconfig +++ b/configs/CHIP_pro_defconfig @@ -15,6 +15,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun5i-gr8-chip-pro" CONFIG_ENV_IS_IN_UBI=y CONFIG_ENV_UBI_PART="UBI" CONFIG_ENV_UBI_VOLUME="uboot-env" +CONFIG_SPL_ENV_IS_NOWHERE=y # CONFIG_MMC is not set CONFIG_NAND=y CONFIG_SYS_NAND_BLOCK_SIZE=0x40000 diff --git a/configs/CSQ_CS908_defconfig b/configs/CSQ_CS908_defconfig index 65b6777e0e..4ca57f4c1a 100644 --- a/configs/CSQ_CS908_defconfig +++ b/configs/CSQ_CS908_defconfig @@ -12,6 +12,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-cs908" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_ETH_DESIGNWARE=y CONFIG_MII=y CONFIG_SUN7I_GMAC=y diff --git a/configs/Chuwi_V7_CW0825_defconfig b/configs/Chuwi_V7_CW0825_defconfig index 39caa75ff3..b888fc0fab 100644 --- a/configs/Chuwi_V7_CW0825_defconfig +++ b/configs/Chuwi_V7_CW0825_defconfig @@ -20,6 +20,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-chuwi-v7-cw0825" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_USB_MUSB_HOST=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y CONFIG_VIDEO_LCD_SPI_CS="PA0" diff --git a/configs/Colombus_defconfig b/configs/Colombus_defconfig index 9065792149..2ba90baba2 100644 --- a/configs/Colombus_defconfig +++ b/configs/Colombus_defconfig @@ -22,6 +22,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-colombus" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_ETH_DESIGNWARE=y CONFIG_RGMII=y CONFIG_MII=y diff --git a/configs/Cubieboard2_defconfig b/configs/Cubieboard2_defconfig index ee5412cdb8..2eae804a80 100644 --- a/configs/Cubieboard2_defconfig +++ b/configs/Cubieboard2_defconfig @@ -14,6 +14,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-cubieboard2" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SCSI_AHCI=y CONFIG_ETH_DESIGNWARE=y CONFIG_MII=y diff --git a/configs/Cubieboard4_defconfig b/configs/Cubieboard4_defconfig index e44d79e0c2..cb8825b048 100644 --- a/configs/Cubieboard4_defconfig +++ b/configs/Cubieboard4_defconfig @@ -17,5 +17,6 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun9i-a80-cubieboard4" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_AXP809_POWER=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/Cubieboard_defconfig b/configs/Cubieboard_defconfig index 593dbe86a1..e9edb1dfb4 100644 --- a/configs/Cubieboard_defconfig +++ b/configs/Cubieboard_defconfig @@ -14,6 +14,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-cubieboard" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SCSI_AHCI=y CONFIG_MII=y CONFIG_SUN4I_EMAC=y diff --git a/configs/Cubietruck_defconfig b/configs/Cubietruck_defconfig index fe92f64644..5c048e15c0 100644 --- a/configs/Cubietruck_defconfig +++ b/configs/Cubietruck_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-cubietruck" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SCSI_AHCI=y CONFIG_DFU_RAM=y CONFIG_FASTBOOT_CMD_OEM_FORMAT=y diff --git a/configs/Cubietruck_plus_defconfig b/configs/Cubietruck_plus_defconfig index 9748805dca..ef52c8b41e 100644 --- a/configs/Cubietruck_plus_defconfig +++ b/configs/Cubietruck_plus_defconfig @@ -21,6 +21,7 @@ CONFIG_CONSOLE_MUX=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-a83t-cubietruck-plus" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_PHY_REALTEK=y CONFIG_SUN8I_EMAC=y CONFIG_AXP_DLDO3_VOLT=2500 diff --git a/configs/Empire_electronix_d709_defconfig b/configs/Empire_electronix_d709_defconfig index ff6562df5c..8b0362d2a8 100644 --- a/configs/Empire_electronix_d709_defconfig +++ b/configs/Empire_electronix_d709_defconfig @@ -22,6 +22,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-empire-electronix-d709" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_CONS_INDEX=2 CONFIG_USB_MUSB_HOST=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/Empire_electronix_m712_defconfig b/configs/Empire_electronix_m712_defconfig index 767d497b3c..e79d38cbcf 100644 --- a/configs/Empire_electronix_m712_defconfig +++ b/configs/Empire_electronix_m712_defconfig @@ -21,6 +21,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-empire-electronix-m712" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_CONS_INDEX=2 CONFIG_USB_MUSB_HOST=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/Hummingbird_A31_defconfig b/configs/Hummingbird_A31_defconfig index 44a66028bd..c1607b9272 100644 --- a/configs/Hummingbird_A31_defconfig +++ b/configs/Hummingbird_A31_defconfig @@ -14,6 +14,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-hummingbird" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_ETH_DESIGNWARE=y CONFIG_RGMII=y CONFIG_MII=y diff --git a/configs/Hyundai_A7HD_defconfig b/configs/Hyundai_A7HD_defconfig index 0fe7c11300..dc0c5112f9 100644 --- a/configs/Hyundai_A7HD_defconfig +++ b/configs/Hyundai_A7HD_defconfig @@ -21,5 +21,6 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-hyundai-a7hd" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_USB_MUSB_HOST=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/Itead_Ibox_A20_defconfig b/configs/Itead_Ibox_A20_defconfig index 01f259f45d..64937340eb 100644 --- a/configs/Itead_Ibox_A20_defconfig +++ b/configs/Itead_Ibox_A20_defconfig @@ -14,6 +14,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-itead-ibox" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SCSI_AHCI=y CONFIG_ETH_DESIGNWARE=y CONFIG_MII=y diff --git a/configs/Lamobo_R1_defconfig b/configs/Lamobo_R1_defconfig index 974ff1c76b..946fb3bf5b 100644 --- a/configs/Lamobo_R1_defconfig +++ b/configs/Lamobo_R1_defconfig @@ -16,6 +16,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-lamobo-r1" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SCSI_AHCI=y CONFIG_B53_SWITCH=y CONFIG_B53_PHY_PORTS=0x1f diff --git a/configs/LicheePi_Zero_defconfig b/configs/LicheePi_Zero_defconfig index ca0bcc0cf2..097a693f68 100644 --- a/configs/LicheePi_Zero_defconfig +++ b/configs/LicheePi_Zero_defconfig @@ -9,5 +9,6 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-v3s-licheepi-zero" +CONFIG_SPL_ENV_IS_NOWHERE=y # CONFIG_NETDEVICES is not set CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/Linksprite_pcDuino3_Nano_defconfig b/configs/Linksprite_pcDuino3_Nano_defconfig index 23651ec985..fea06b58e5 100644 --- a/configs/Linksprite_pcDuino3_Nano_defconfig +++ b/configs/Linksprite_pcDuino3_Nano_defconfig @@ -16,6 +16,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-pcduino3-nano" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SCSI_AHCI=y CONFIG_ETH_DESIGNWARE=y CONFIG_RGMII=y diff --git a/configs/Linksprite_pcDuino3_defconfig b/configs/Linksprite_pcDuino3_defconfig index 6cb36637a3..154692cf07 100644 --- a/configs/Linksprite_pcDuino3_defconfig +++ b/configs/Linksprite_pcDuino3_defconfig @@ -14,6 +14,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-pcduino3" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SCSI_AHCI=y CONFIG_ETH_DESIGNWARE=y CONFIG_MII=y diff --git a/configs/Linksprite_pcDuino_defconfig b/configs/Linksprite_pcDuino_defconfig index dd2b2802e4..ab77b0c810 100644 --- a/configs/Linksprite_pcDuino_defconfig +++ b/configs/Linksprite_pcDuino_defconfig @@ -12,6 +12,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-pcduino" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_MII=y CONFIG_SUN4I_EMAC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/MK808C_defconfig b/configs/MK808C_defconfig index 7f23f9e608..a26941768a 100644 --- a/configs/MK808C_defconfig +++ b/configs/MK808C_defconfig @@ -11,6 +11,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-mk808c" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/MPC8313ERDB_NAND_33_defconfig b/configs/MPC8313ERDB_NAND_33_defconfig index 48c1977ea4..5e0b00126e 100644 --- a/configs/MPC8313ERDB_NAND_33_defconfig +++ b/configs/MPC8313ERDB_NAND_33_defconfig @@ -150,6 +150,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=e2800000.flash" CONFIG_MTDPARTS_DEFAULT="mtdparts=e2800000.flash:512k(uboot),128k(env),6m@1m(kernel),-(fs)" # CONFIG_ENV_IS_IN_FLASH is not set CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/MPC8313ERDB_NAND_66_defconfig b/configs/MPC8313ERDB_NAND_66_defconfig index eee9227d4d..1e60ff1e93 100644 --- a/configs/MPC8313ERDB_NAND_66_defconfig +++ b/configs/MPC8313ERDB_NAND_66_defconfig @@ -149,6 +149,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=e2800000.flash" CONFIG_MTDPARTS_DEFAULT="mtdparts=e2800000.flash:512k(uboot),128k(env),6m@1m(kernel),-(fs)" # CONFIG_ENV_IS_IN_FLASH is not set CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/MSI_Primo73_defconfig b/configs/MSI_Primo73_defconfig index a4d137cd23..b40d361c29 100644 --- a/configs/MSI_Primo73_defconfig +++ b/configs/MSI_Primo73_defconfig @@ -16,4 +16,5 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-primo73" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/MSI_Primo81_defconfig b/configs/MSI_Primo81_defconfig index 12f8bd91b5..3f0eabf00c 100644 --- a/configs/MSI_Primo81_defconfig +++ b/configs/MSI_Primo81_defconfig @@ -18,6 +18,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-primo81" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_AXP_DLDO1_VOLT=3300 # CONFIG_REQUIRE_SERIAL_CONSOLE is not set CONFIG_USB_MUSB_HOST=y diff --git a/configs/Marsboard_A10_defconfig b/configs/Marsboard_A10_defconfig index d4cdcb7907..84c6981722 100644 --- a/configs/Marsboard_A10_defconfig +++ b/configs/Marsboard_A10_defconfig @@ -10,6 +10,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-marsboard" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SCSI_AHCI=y CONFIG_MII=y CONFIG_SUN4I_EMAC=y diff --git a/configs/Mele_A1000G_quad_defconfig b/configs/Mele_A1000G_quad_defconfig index 08d847989d..1bc9a5a48f 100644 --- a/configs/Mele_A1000G_quad_defconfig +++ b/configs/Mele_A1000G_quad_defconfig @@ -13,6 +13,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-mele-a1000g-quad" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_ETH_DESIGNWARE=y CONFIG_MII=y CONFIG_SUN7I_GMAC=y diff --git a/configs/Mele_A1000_defconfig b/configs/Mele_A1000_defconfig index d1cd98db90..6b6ec09a82 100644 --- a/configs/Mele_A1000_defconfig +++ b/configs/Mele_A1000_defconfig @@ -14,6 +14,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-a1000" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SCSI_AHCI=y CONFIG_MII=y CONFIG_SUN4I_EMAC=y diff --git a/configs/Mele_I7_defconfig b/configs/Mele_I7_defconfig index 3b3b35d6d5..0b3dc91d29 100644 --- a/configs/Mele_I7_defconfig +++ b/configs/Mele_I7_defconfig @@ -12,6 +12,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-i7" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_ETH_DESIGNWARE=y CONFIG_MII=y CONFIG_SUN7I_GMAC=y diff --git a/configs/Mele_M3_defconfig b/configs/Mele_M3_defconfig index 8f03d1e96a..89c1574d03 100644 --- a/configs/Mele_M3_defconfig +++ b/configs/Mele_M3_defconfig @@ -15,6 +15,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-m3" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_ETH_DESIGNWARE=y CONFIG_MII=y CONFIG_SUN7I_GMAC=y diff --git a/configs/Mele_M5_defconfig b/configs/Mele_M5_defconfig index d455a56315..65aff36c80 100644 --- a/configs/Mele_M5_defconfig +++ b/configs/Mele_M5_defconfig @@ -15,6 +15,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-m5" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SCSI_AHCI=y CONFIG_ETH_DESIGNWARE=y CONFIG_MII=y diff --git a/configs/Mele_M9_defconfig b/configs/Mele_M9_defconfig index 9865e83f06..07e9ded0f7 100644 --- a/configs/Mele_M9_defconfig +++ b/configs/Mele_M9_defconfig @@ -12,6 +12,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-m9" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_ETH_DESIGNWARE=y CONFIG_MII=y CONFIG_SUN7I_GMAC=y diff --git a/configs/Merrii_A80_Optimus_defconfig b/configs/Merrii_A80_Optimus_defconfig index b45b6cde1c..a8df69ebdf 100644 --- a/configs/Merrii_A80_Optimus_defconfig +++ b/configs/Merrii_A80_Optimus_defconfig @@ -17,5 +17,6 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun9i-a80-optimus" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_AXP809_POWER=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/Mini-X_defconfig b/configs/Mini-X_defconfig index 7d440d1813..b0757e3731 100644 --- a/configs/Mini-X_defconfig +++ b/configs/Mini-X_defconfig @@ -12,6 +12,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-mini-xplus" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/Orangepi_defconfig b/configs/Orangepi_defconfig index 1ff40a09ef..fb23872184 100644 --- a/configs/Orangepi_defconfig +++ b/configs/Orangepi_defconfig @@ -18,6 +18,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-orangepi" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SCSI_AHCI=y CONFIG_ETH_DESIGNWARE=y CONFIG_RGMII=y diff --git a/configs/Orangepi_mini_defconfig b/configs/Orangepi_mini_defconfig index af98dc8396..026eb58c3d 100644 --- a/configs/Orangepi_mini_defconfig +++ b/configs/Orangepi_mini_defconfig @@ -20,6 +20,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-orangepi-mini" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SCSI_AHCI=y CONFIG_ETH_DESIGNWARE=y CONFIG_RGMII=y diff --git a/configs/P1010RDB-PA_36BIT_NAND_defconfig b/configs/P1010RDB-PA_36BIT_NAND_defconfig index f8effe8950..c31985c5fd 100644 --- a/configs/P1010RDB-PA_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PA_36BIT_NAND_defconfig @@ -24,7 +24,6 @@ CONFIG_SPL_TEXT_BASE=0xFF800000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y CONFIG_TPL_DRIVERS_MISC_SUPPORT=y -CONFIG_TPL_ENV_SUPPORT=y CONFIG_TPL_I2C_SUPPORT=y CONFIG_TPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_TPL_NAND_SUPPORT=y @@ -43,6 +42,7 @@ CONFIG_CMD_FAT=y CONFIG_MTDIDS_DEFAULT="nand0=ff800000.flash" CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:2m(uboot-env),1m(dtb),5m(kernel),56m(fs),-(usr)" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig index 5fea3ed5c1..6da65ed227 100644 --- a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig @@ -21,7 +21,6 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_TEXT_BASE=0xD0001000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig index 73bcdc109e..a0832f39c6 100644 --- a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig @@ -22,7 +22,6 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_SPI_BOOT=y CONFIG_SPL_TEXT_BASE=0xD0001000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1010RDB-PA_NAND_defconfig b/configs/P1010RDB-PA_NAND_defconfig index 0b8b67a5a5..0e92678d50 100644 --- a/configs/P1010RDB-PA_NAND_defconfig +++ b/configs/P1010RDB-PA_NAND_defconfig @@ -23,7 +23,6 @@ CONFIG_SPL_TEXT_BASE=0xFF800000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y CONFIG_TPL_DRIVERS_MISC_SUPPORT=y -CONFIG_TPL_ENV_SUPPORT=y CONFIG_TPL_I2C_SUPPORT=y CONFIG_TPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_TPL_NAND_SUPPORT=y @@ -42,6 +41,7 @@ CONFIG_CMD_FAT=y CONFIG_MTDIDS_DEFAULT="nand0=ff800000.flash" CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:2m(uboot-env),1m(dtb),5m(kernel),56m(fs),-(usr)" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/P1010RDB-PA_SDCARD_defconfig b/configs/P1010RDB-PA_SDCARD_defconfig index 3e4088b3cb..483b1afff8 100644 --- a/configs/P1010RDB-PA_SDCARD_defconfig +++ b/configs/P1010RDB-PA_SDCARD_defconfig @@ -20,7 +20,6 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_TEXT_BASE=0xD0001000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1010RDB-PA_SPIFLASH_defconfig b/configs/P1010RDB-PA_SPIFLASH_defconfig index adc4da14eb..b4d257a138 100644 --- a/configs/P1010RDB-PA_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_SPIFLASH_defconfig @@ -21,7 +21,6 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_SPI_BOOT=y CONFIG_SPL_TEXT_BASE=0xD0001000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1010RDB-PB_36BIT_NAND_defconfig b/configs/P1010RDB-PB_36BIT_NAND_defconfig index a6ff61648f..98cc52eb69 100644 --- a/configs/P1010RDB-PB_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PB_36BIT_NAND_defconfig @@ -24,7 +24,6 @@ CONFIG_SPL_TEXT_BASE=0xFF800000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y CONFIG_TPL_DRIVERS_MISC_SUPPORT=y -CONFIG_TPL_ENV_SUPPORT=y CONFIG_TPL_I2C_SUPPORT=y CONFIG_TPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_TPL_NAND_SUPPORT=y @@ -43,6 +42,7 @@ CONFIG_CMD_FAT=y CONFIG_MTDIDS_DEFAULT="nand0=ff800000.flash" CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:2m(uboot-env),1m(dtb),5m(kernel),56m(fs),-(usr)" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig index 9b8a1e2777..03b9120dc7 100644 --- a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig @@ -21,7 +21,6 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_TEXT_BASE=0xD0001000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig index 0f10bf97a9..10438e6c9d 100644 --- a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig @@ -22,7 +22,6 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_SPI_BOOT=y CONFIG_SPL_TEXT_BASE=0xD0001000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1010RDB-PB_NAND_defconfig b/configs/P1010RDB-PB_NAND_defconfig index bc8dce25d6..cb73bfc7db 100644 --- a/configs/P1010RDB-PB_NAND_defconfig +++ b/configs/P1010RDB-PB_NAND_defconfig @@ -23,7 +23,6 @@ CONFIG_SPL_TEXT_BASE=0xFF800000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y CONFIG_TPL_DRIVERS_MISC_SUPPORT=y -CONFIG_TPL_ENV_SUPPORT=y CONFIG_TPL_I2C_SUPPORT=y CONFIG_TPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_TPL_NAND_SUPPORT=y @@ -42,6 +41,7 @@ CONFIG_CMD_FAT=y CONFIG_MTDIDS_DEFAULT="nand0=ff800000.flash" CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:2m(uboot-env),1m(dtb),5m(kernel),56m(fs),-(usr)" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/P1010RDB-PB_SDCARD_defconfig b/configs/P1010RDB-PB_SDCARD_defconfig index 944198823e..f8d9c759d1 100644 --- a/configs/P1010RDB-PB_SDCARD_defconfig +++ b/configs/P1010RDB-PB_SDCARD_defconfig @@ -20,7 +20,6 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_TEXT_BASE=0xD0001000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1010RDB-PB_SPIFLASH_defconfig b/configs/P1010RDB-PB_SPIFLASH_defconfig index b8695ec492..6acbb88263 100644 --- a/configs/P1010RDB-PB_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_SPIFLASH_defconfig @@ -21,7 +21,6 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_SPI_BOOT=y CONFIG_SPL_TEXT_BASE=0xD0001000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1020MBG-PC_36BIT_SDCARD_defconfig b/configs/P1020MBG-PC_36BIT_SDCARD_defconfig index bb21c607f3..8e39a1af4e 100644 --- a/configs/P1020MBG-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020MBG-PC_36BIT_SDCARD_defconfig @@ -21,7 +21,6 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_TEXT_BASE=0xf8f81000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1020MBG-PC_SDCARD_defconfig b/configs/P1020MBG-PC_SDCARD_defconfig index 4b9ec4d0c5..3c6c350aed 100644 --- a/configs/P1020MBG-PC_SDCARD_defconfig +++ b/configs/P1020MBG-PC_SDCARD_defconfig @@ -20,7 +20,6 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_TEXT_BASE=0xf8f81000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1020RDB-PC_36BIT_NAND_defconfig b/configs/P1020RDB-PC_36BIT_NAND_defconfig index c4e41f2010..5a3e12bf62 100644 --- a/configs/P1020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P1020RDB-PC_36BIT_NAND_defconfig @@ -23,7 +23,6 @@ CONFIG_SPL_NAND_BOOT=y CONFIG_SPL_TEXT_BASE=0xFF800000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y -CONFIG_TPL_ENV_SUPPORT=y CONFIG_TPL_I2C_SUPPORT=y CONFIG_TPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_TPL_NAND_SUPPORT=y @@ -45,6 +44,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="p1020rdb-pc_36b" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig index b21fc2159b..33454a105c 100644 --- a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig @@ -21,7 +21,6 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_TEXT_BASE=0xf8f81000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig index 2f69683379..53830019e2 100644 --- a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig @@ -22,7 +22,6 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_SPI_BOOT=y CONFIG_SPL_TEXT_BASE=0xf8f81000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1020RDB-PC_NAND_defconfig b/configs/P1020RDB-PC_NAND_defconfig index 832c96967e..15e72f4f7f 100644 --- a/configs/P1020RDB-PC_NAND_defconfig +++ b/configs/P1020RDB-PC_NAND_defconfig @@ -22,7 +22,6 @@ CONFIG_SPL_NAND_BOOT=y CONFIG_SPL_TEXT_BASE=0xFF800000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y -CONFIG_TPL_ENV_SUPPORT=y CONFIG_TPL_I2C_SUPPORT=y CONFIG_TPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_TPL_NAND_SUPPORT=y @@ -44,6 +43,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="p1020rdb-pc" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/P1020RDB-PC_SDCARD_defconfig b/configs/P1020RDB-PC_SDCARD_defconfig index 2b5537bc32..2243daecc0 100644 --- a/configs/P1020RDB-PC_SDCARD_defconfig +++ b/configs/P1020RDB-PC_SDCARD_defconfig @@ -20,7 +20,6 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_TEXT_BASE=0xf8f81000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1020RDB-PC_SPIFLASH_defconfig b/configs/P1020RDB-PC_SPIFLASH_defconfig index dc4f7d6a70..4924efecd7 100644 --- a/configs/P1020RDB-PC_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_SPIFLASH_defconfig @@ -21,7 +21,6 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_SPI_BOOT=y CONFIG_SPL_TEXT_BASE=0xf8f81000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1020RDB-PD_NAND_defconfig b/configs/P1020RDB-PD_NAND_defconfig index acbb9e0159..40aa72b82d 100644 --- a/configs/P1020RDB-PD_NAND_defconfig +++ b/configs/P1020RDB-PD_NAND_defconfig @@ -22,7 +22,6 @@ CONFIG_SPL_NAND_BOOT=y CONFIG_SPL_TEXT_BASE=0xFF800000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y -CONFIG_TPL_ENV_SUPPORT=y CONFIG_TPL_I2C_SUPPORT=y CONFIG_TPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_TPL_NAND_SUPPORT=y @@ -47,6 +46,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=ec000000.nor:128k(dtb),6016k(kernel),57088k(fs CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="p1020rdb-pd" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/P1020RDB-PD_SDCARD_defconfig b/configs/P1020RDB-PD_SDCARD_defconfig index 208138f594..4f0ff3a296 100644 --- a/configs/P1020RDB-PD_SDCARD_defconfig +++ b/configs/P1020RDB-PD_SDCARD_defconfig @@ -20,7 +20,6 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_TEXT_BASE=0xf8f81000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1020RDB-PD_SPIFLASH_defconfig b/configs/P1020RDB-PD_SPIFLASH_defconfig index 960f2718a9..abcf7f8b76 100644 --- a/configs/P1020RDB-PD_SPIFLASH_defconfig +++ b/configs/P1020RDB-PD_SPIFLASH_defconfig @@ -21,7 +21,6 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_SPI_BOOT=y CONFIG_SPL_TEXT_BASE=0xf8f81000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1020UTM-PC_36BIT_SDCARD_defconfig b/configs/P1020UTM-PC_36BIT_SDCARD_defconfig index 04aa24d2e3..b4a61c780a 100644 --- a/configs/P1020UTM-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020UTM-PC_36BIT_SDCARD_defconfig @@ -21,7 +21,6 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_TEXT_BASE=0xf8f81000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1020UTM-PC_SDCARD_defconfig b/configs/P1020UTM-PC_SDCARD_defconfig index 571889ac87..f5d3199619 100644 --- a/configs/P1020UTM-PC_SDCARD_defconfig +++ b/configs/P1020UTM-PC_SDCARD_defconfig @@ -20,7 +20,6 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_TEXT_BASE=0xf8f81000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1021RDB-PC_36BIT_NAND_defconfig b/configs/P1021RDB-PC_36BIT_NAND_defconfig index cd73bdd2fb..0015197c7b 100644 --- a/configs/P1021RDB-PC_36BIT_NAND_defconfig +++ b/configs/P1021RDB-PC_36BIT_NAND_defconfig @@ -23,7 +23,6 @@ CONFIG_SPL_NAND_BOOT=y CONFIG_SPL_TEXT_BASE=0xFF800000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y -CONFIG_TPL_ENV_SUPPORT=y CONFIG_TPL_I2C_SUPPORT=y CONFIG_TPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_TPL_NAND_SUPPORT=y @@ -47,6 +46,7 @@ CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=fef000000.nor" CONFIG_MTDPARTS_DEFAULT="mtdparts=fef000000.nor:256k(vsc7385-firmware),256k(dtb),4608k(kernel),9728k(fs),256k(qe-ucode-firmware),1280k(u-boot)" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/P1021RDB-PC_36BIT_SDCARD_defconfig b/configs/P1021RDB-PC_36BIT_SDCARD_defconfig index d30d4df9ee..c7e7a8ea5d 100644 --- a/configs/P1021RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P1021RDB-PC_36BIT_SDCARD_defconfig @@ -21,7 +21,6 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_TEXT_BASE=0xf8f81000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig index e11be022c8..3e252f4652 100644 --- a/configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig @@ -22,7 +22,6 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_SPI_BOOT=y CONFIG_SPL_TEXT_BASE=0xf8f81000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1021RDB-PC_NAND_defconfig b/configs/P1021RDB-PC_NAND_defconfig index ada720a75f..bc27028a4c 100644 --- a/configs/P1021RDB-PC_NAND_defconfig +++ b/configs/P1021RDB-PC_NAND_defconfig @@ -22,7 +22,6 @@ CONFIG_SPL_NAND_BOOT=y CONFIG_SPL_TEXT_BASE=0xFF800000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y -CONFIG_TPL_ENV_SUPPORT=y CONFIG_TPL_I2C_SUPPORT=y CONFIG_TPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_TPL_NAND_SUPPORT=y @@ -46,6 +45,7 @@ CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=ef000000.nor" CONFIG_MTDPARTS_DEFAULT="mtdparts=ef000000.nor:256k(vsc7385-firmware),256k(dtb),4608k(kernel),9728k(fs),256k(qe-ucode-firmware),1280k(u-boot)" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/P1021RDB-PC_SDCARD_defconfig b/configs/P1021RDB-PC_SDCARD_defconfig index 28830f90a2..c37818cae6 100644 --- a/configs/P1021RDB-PC_SDCARD_defconfig +++ b/configs/P1021RDB-PC_SDCARD_defconfig @@ -20,7 +20,6 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_TEXT_BASE=0xf8f81000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1021RDB-PC_SPIFLASH_defconfig b/configs/P1021RDB-PC_SPIFLASH_defconfig index 19d2b0f47f..c6adc41c1d 100644 --- a/configs/P1021RDB-PC_SPIFLASH_defconfig +++ b/configs/P1021RDB-PC_SPIFLASH_defconfig @@ -21,7 +21,6 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_SPI_BOOT=y CONFIG_SPL_TEXT_BASE=0xf8f81000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1022DS_36BIT_NAND_defconfig b/configs/P1022DS_36BIT_NAND_defconfig index 62072dc7b9..a19c08964d 100644 --- a/configs/P1022DS_36BIT_NAND_defconfig +++ b/configs/P1022DS_36BIT_NAND_defconfig @@ -21,7 +21,6 @@ CONFIG_SPL_NAND_BOOT=y CONFIG_SPL_TEXT_BASE=0xFF800000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y -CONFIG_TPL_ENV_SUPPORT=y CONFIG_TPL_I2C_SUPPORT=y CONFIG_TPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_TPL_NAND_SUPPORT=y @@ -45,6 +44,7 @@ CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=fe8000000.nor" CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:48m(ramdisk),14m(diagnostic),2m(dink),6m(kernel),58112k(fs),512k(dtb),768k(u-boot)" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/P1022DS_36BIT_SDCARD_defconfig b/configs/P1022DS_36BIT_SDCARD_defconfig index aadc417e47..bc5bea1d40 100644 --- a/configs/P1022DS_36BIT_SDCARD_defconfig +++ b/configs/P1022DS_36BIT_SDCARD_defconfig @@ -19,7 +19,6 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_TEXT_BASE=0xf8f81000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1022DS_36BIT_SPIFLASH_defconfig b/configs/P1022DS_36BIT_SPIFLASH_defconfig index e5b7cfff6d..cb72f7d571 100644 --- a/configs/P1022DS_36BIT_SPIFLASH_defconfig +++ b/configs/P1022DS_36BIT_SPIFLASH_defconfig @@ -20,7 +20,6 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_SPI_BOOT=y CONFIG_SPL_TEXT_BASE=0xf8f81000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1022DS_NAND_defconfig b/configs/P1022DS_NAND_defconfig index 8089012708..27cc46fa4b 100644 --- a/configs/P1022DS_NAND_defconfig +++ b/configs/P1022DS_NAND_defconfig @@ -20,7 +20,6 @@ CONFIG_SPL_NAND_BOOT=y CONFIG_SPL_TEXT_BASE=0xFF800000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y -CONFIG_TPL_ENV_SUPPORT=y CONFIG_TPL_I2C_SUPPORT=y CONFIG_TPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_TPL_NAND_SUPPORT=y @@ -44,6 +43,7 @@ CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=e8000000.nor" CONFIG_MTDPARTS_DEFAULT="mtdparts=e8000000.nor:48m(ramdisk),14m(diagnostic),2m(dink),6m(kernel),58112k(fs),512k(dtb),768k(u-boot)" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/P1022DS_SDCARD_defconfig b/configs/P1022DS_SDCARD_defconfig index 71e0daa60e..71ed069be9 100644 --- a/configs/P1022DS_SDCARD_defconfig +++ b/configs/P1022DS_SDCARD_defconfig @@ -18,7 +18,6 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_TEXT_BASE=0xf8f81000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1022DS_SPIFLASH_defconfig b/configs/P1022DS_SPIFLASH_defconfig index 76962987ce..4745c9db56 100644 --- a/configs/P1022DS_SPIFLASH_defconfig +++ b/configs/P1022DS_SPIFLASH_defconfig @@ -19,7 +19,6 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_SPI_BOOT=y CONFIG_SPL_TEXT_BASE=0xf8f81000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1024RDB_NAND_defconfig b/configs/P1024RDB_NAND_defconfig index a08f5d9667..5f3a168e2f 100644 --- a/configs/P1024RDB_NAND_defconfig +++ b/configs/P1024RDB_NAND_defconfig @@ -22,7 +22,6 @@ CONFIG_SPL_NAND_BOOT=y CONFIG_SPL_TEXT_BASE=0xFF800000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y -CONFIG_TPL_ENV_SUPPORT=y CONFIG_TPL_I2C_SUPPORT=y CONFIG_TPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_TPL_NAND_SUPPORT=y @@ -42,6 +41,7 @@ CONFIG_MP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/P1024RDB_SDCARD_defconfig b/configs/P1024RDB_SDCARD_defconfig index d09e71dee0..62938eae78 100644 --- a/configs/P1024RDB_SDCARD_defconfig +++ b/configs/P1024RDB_SDCARD_defconfig @@ -20,7 +20,6 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_TEXT_BASE=0xf8f81000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1024RDB_SPIFLASH_defconfig b/configs/P1024RDB_SPIFLASH_defconfig index da09d21f63..4c14adfbb7 100644 --- a/configs/P1024RDB_SPIFLASH_defconfig +++ b/configs/P1024RDB_SPIFLASH_defconfig @@ -21,7 +21,6 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_SPI_BOOT=y CONFIG_SPL_TEXT_BASE=0xf8f81000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1025RDB_NAND_defconfig b/configs/P1025RDB_NAND_defconfig index 5259a2ff43..461ed2bcbe 100644 --- a/configs/P1025RDB_NAND_defconfig +++ b/configs/P1025RDB_NAND_defconfig @@ -22,7 +22,6 @@ CONFIG_SPL_NAND_BOOT=y CONFIG_SPL_TEXT_BASE=0xFF800000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y -CONFIG_TPL_ENV_SUPPORT=y CONFIG_TPL_I2C_SUPPORT=y CONFIG_TPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_TPL_NAND_SUPPORT=y @@ -44,6 +43,7 @@ CONFIG_MP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/P1025RDB_SDCARD_defconfig b/configs/P1025RDB_SDCARD_defconfig index 485750c901..214987165f 100644 --- a/configs/P1025RDB_SDCARD_defconfig +++ b/configs/P1025RDB_SDCARD_defconfig @@ -20,7 +20,6 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_TEXT_BASE=0xf8f81000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1025RDB_SPIFLASH_defconfig b/configs/P1025RDB_SPIFLASH_defconfig index af6c7b4ee0..c9c6bbd2fe 100644 --- a/configs/P1025RDB_SPIFLASH_defconfig +++ b/configs/P1025RDB_SPIFLASH_defconfig @@ -21,7 +21,6 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_SPI_BOOT=y CONFIG_SPL_TEXT_BASE=0xf8f81000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P2020RDB-PC_36BIT_NAND_defconfig b/configs/P2020RDB-PC_36BIT_NAND_defconfig index 5e279814a1..ffb4e8d28b 100644 --- a/configs/P2020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P2020RDB-PC_36BIT_NAND_defconfig @@ -23,7 +23,6 @@ CONFIG_SPL_NAND_BOOT=y CONFIG_SPL_TEXT_BASE=0xFF800000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y -CONFIG_TPL_ENV_SUPPORT=y CONFIG_TPL_I2C_SUPPORT=y CONFIG_TPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_TPL_NAND_SUPPORT=y @@ -49,6 +48,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=fef000000.nor:256k(vsc7385-firmware),256k(dtb) CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="p2020rdb-pc_36b" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig index 49a7c8052d..b10f5365a7 100644 --- a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig @@ -21,7 +21,6 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_TEXT_BASE=0xf8f81000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig index 59fce53690..04c5d57c26 100644 --- a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig @@ -22,7 +22,6 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_SPI_BOOT=y CONFIG_SPL_TEXT_BASE=0xf8f81000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P2020RDB-PC_NAND_defconfig b/configs/P2020RDB-PC_NAND_defconfig index 3c65108d7d..860145bb70 100644 --- a/configs/P2020RDB-PC_NAND_defconfig +++ b/configs/P2020RDB-PC_NAND_defconfig @@ -22,7 +22,6 @@ CONFIG_SPL_NAND_BOOT=y CONFIG_SPL_TEXT_BASE=0xFF800000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_TPL=y -CONFIG_TPL_ENV_SUPPORT=y CONFIG_TPL_I2C_SUPPORT=y CONFIG_TPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_TPL_NAND_SUPPORT=y @@ -48,6 +47,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=ef000000.nor:256k(vsc7385-firmware),256k(dtb), CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="p2020rdb-pc" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/P2020RDB-PC_SDCARD_defconfig b/configs/P2020RDB-PC_SDCARD_defconfig index 05f42aef8a..a15c10f636 100644 --- a/configs/P2020RDB-PC_SDCARD_defconfig +++ b/configs/P2020RDB-PC_SDCARD_defconfig @@ -20,7 +20,6 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_TEXT_BASE=0xf8f81000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P2020RDB-PC_SPIFLASH_defconfig b/configs/P2020RDB-PC_SPIFLASH_defconfig index bfb7026f2d..ca8e44dd9a 100644 --- a/configs/P2020RDB-PC_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_SPIFLASH_defconfig @@ -21,7 +21,6 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_SPI_BOOT=y CONFIG_SPL_TEXT_BASE=0xf8f81000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/Sinlinx_SinA31s_defconfig b/configs/Sinlinx_SinA31s_defconfig index 3588a2c9dd..8b4ceb952a 100644 --- a/configs/Sinlinx_SinA31s_defconfig +++ b/configs/Sinlinx_SinA31s_defconfig @@ -16,6 +16,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-sina31s" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_ETH_DESIGNWARE=y CONFIG_MII=y CONFIG_SUN7I_GMAC=y diff --git a/configs/Sinlinx_SinA33_defconfig b/configs/Sinlinx_SinA33_defconfig index a7383f1eda..ab6a3ca06b 100644 --- a/configs/Sinlinx_SinA33_defconfig +++ b/configs/Sinlinx_SinA33_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_DFU=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-sinlinx-sina33" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DFU_RAM=y CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Sinovoip_BPI_M2_defconfig b/configs/Sinovoip_BPI_M2_defconfig index 691fd85f47..26c8601139 100644 --- a/configs/Sinovoip_BPI_M2_defconfig +++ b/configs/Sinovoip_BPI_M2_defconfig @@ -12,6 +12,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-sinovoip-bpi-m2" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_ETH_DESIGNWARE=y CONFIG_RGMII=y CONFIG_MII=y diff --git a/configs/Sinovoip_BPI_M3_defconfig b/configs/Sinovoip_BPI_M3_defconfig index 6ded24e294..c8197e8a58 100644 --- a/configs/Sinovoip_BPI_M3_defconfig +++ b/configs/Sinovoip_BPI_M3_defconfig @@ -22,6 +22,7 @@ CONFIG_CONSOLE_MUX=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-a83t-bananapi-m3" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_PHY_REALTEK=y CONFIG_SUN8I_EMAC=y CONFIG_AXP_DCDC5_VOLT=1200 diff --git a/configs/Sunchip_CX-A99_defconfig b/configs/Sunchip_CX-A99_defconfig index 8bc353112b..a5bbeda09e 100644 --- a/configs/Sunchip_CX-A99_defconfig +++ b/configs/Sunchip_CX-A99_defconfig @@ -17,4 +17,5 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun9i-a80-cx-a99" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/T1023RDB_NAND_defconfig b/configs/T1023RDB_NAND_defconfig index 858d998d18..5444c04904 100644 --- a/configs/T1023RDB_NAND_defconfig +++ b/configs/T1023RDB_NAND_defconfig @@ -21,7 +21,6 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_NAND_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_TEXT_BASE=0xFFFD8000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_SPL_NAND_SUPPORT=y diff --git a/configs/T1023RDB_SDCARD_defconfig b/configs/T1023RDB_SDCARD_defconfig index 4d97fdae40..d65bee17b7 100644 --- a/configs/T1023RDB_SDCARD_defconfig +++ b/configs/T1023RDB_SDCARD_defconfig @@ -20,7 +20,6 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_TEXT_BASE=0xFFFD8000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1023RDB_SPIFLASH_defconfig b/configs/T1023RDB_SPIFLASH_defconfig index a3679115b8..77e80fabbe 100644 --- a/configs/T1023RDB_SPIFLASH_defconfig +++ b/configs/T1023RDB_SPIFLASH_defconfig @@ -21,7 +21,6 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_SPI_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_TEXT_BASE=0xFFFD8000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1024QDS_NAND_defconfig b/configs/T1024QDS_NAND_defconfig index 5dccb0f550..735c964bd9 100644 --- a/configs/T1024QDS_NAND_defconfig +++ b/configs/T1024QDS_NAND_defconfig @@ -24,7 +24,6 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_NAND_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_TEXT_BASE=0xFFFD8000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_SPL_NAND_SUPPORT=y diff --git a/configs/T1024QDS_SDCARD_defconfig b/configs/T1024QDS_SDCARD_defconfig index 7b56c0db4e..1218205c06 100644 --- a/configs/T1024QDS_SDCARD_defconfig +++ b/configs/T1024QDS_SDCARD_defconfig @@ -23,7 +23,6 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_TEXT_BASE=0xFFFD8000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1024QDS_SPIFLASH_defconfig b/configs/T1024QDS_SPIFLASH_defconfig index 34cd506d02..5bc2aa1006 100644 --- a/configs/T1024QDS_SPIFLASH_defconfig +++ b/configs/T1024QDS_SPIFLASH_defconfig @@ -24,7 +24,6 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_SPI_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_TEXT_BASE=0xFFFD8000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1024RDB_NAND_defconfig b/configs/T1024RDB_NAND_defconfig index c38912dc38..adc21d5ff2 100644 --- a/configs/T1024RDB_NAND_defconfig +++ b/configs/T1024RDB_NAND_defconfig @@ -23,7 +23,6 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_NAND_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_TEXT_BASE=0xFFFD8000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_SPL_NAND_SUPPORT=y diff --git a/configs/T1024RDB_SDCARD_defconfig b/configs/T1024RDB_SDCARD_defconfig index 5215953caf..3fd50c6965 100644 --- a/configs/T1024RDB_SDCARD_defconfig +++ b/configs/T1024RDB_SDCARD_defconfig @@ -22,7 +22,6 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_TEXT_BASE=0xFFFD8000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1024RDB_SPIFLASH_defconfig b/configs/T1024RDB_SPIFLASH_defconfig index 2e6b81b0c2..59c67684c0 100644 --- a/configs/T1024RDB_SPIFLASH_defconfig +++ b/configs/T1024RDB_SPIFLASH_defconfig @@ -23,7 +23,6 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_SPI_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_TEXT_BASE=0xFFFD8000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1040D4RDB_NAND_defconfig b/configs/T1040D4RDB_NAND_defconfig index 3087cf62d2..957bc82967 100644 --- a/configs/T1040D4RDB_NAND_defconfig +++ b/configs/T1040D4RDB_NAND_defconfig @@ -23,7 +23,6 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_NAND_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_TEXT_BASE=0xFFFD8000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_SPL_NAND_SUPPORT=y diff --git a/configs/T1040D4RDB_SDCARD_defconfig b/configs/T1040D4RDB_SDCARD_defconfig index 608c09a11d..3cbe2b0264 100644 --- a/configs/T1040D4RDB_SDCARD_defconfig +++ b/configs/T1040D4RDB_SDCARD_defconfig @@ -22,7 +22,6 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_TEXT_BASE=0xFFFD8000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1040D4RDB_SPIFLASH_defconfig b/configs/T1040D4RDB_SPIFLASH_defconfig index 8c603c8a86..be933e1ea5 100644 --- a/configs/T1040D4RDB_SPIFLASH_defconfig +++ b/configs/T1040D4RDB_SPIFLASH_defconfig @@ -23,7 +23,6 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_SPI_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_TEXT_BASE=0xFFFD8000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1040RDB_NAND_defconfig b/configs/T1040RDB_NAND_defconfig index 82cec34336..8df46103da 100644 --- a/configs/T1040RDB_NAND_defconfig +++ b/configs/T1040RDB_NAND_defconfig @@ -23,7 +23,6 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_NAND_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_TEXT_BASE=0xFFFD8000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_SPL_NAND_SUPPORT=y diff --git a/configs/T1040RDB_SDCARD_defconfig b/configs/T1040RDB_SDCARD_defconfig index be0f26257f..9ffb43a297 100644 --- a/configs/T1040RDB_SDCARD_defconfig +++ b/configs/T1040RDB_SDCARD_defconfig @@ -22,7 +22,6 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_TEXT_BASE=0xFFFD8000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1040RDB_SPIFLASH_defconfig b/configs/T1040RDB_SPIFLASH_defconfig index a3ad573d38..d1d99af68e 100644 --- a/configs/T1040RDB_SPIFLASH_defconfig +++ b/configs/T1040RDB_SPIFLASH_defconfig @@ -23,7 +23,6 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_SPI_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_TEXT_BASE=0xFFFD8000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1042D4RDB_NAND_defconfig b/configs/T1042D4RDB_NAND_defconfig index 920af5b4c4..350c8a599e 100644 --- a/configs/T1042D4RDB_NAND_defconfig +++ b/configs/T1042D4RDB_NAND_defconfig @@ -24,7 +24,6 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_NAND_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_TEXT_BASE=0xFFFD8000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_SPL_NAND_SUPPORT=y diff --git a/configs/T1042D4RDB_SDCARD_defconfig b/configs/T1042D4RDB_SDCARD_defconfig index e532366218..ca2982a807 100644 --- a/configs/T1042D4RDB_SDCARD_defconfig +++ b/configs/T1042D4RDB_SDCARD_defconfig @@ -23,7 +23,6 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_TEXT_BASE=0xFFFD8000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1042D4RDB_SPIFLASH_defconfig b/configs/T1042D4RDB_SPIFLASH_defconfig index 78e4582113..9818f7644e 100644 --- a/configs/T1042D4RDB_SPIFLASH_defconfig +++ b/configs/T1042D4RDB_SPIFLASH_defconfig @@ -24,7 +24,6 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_SPI_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_TEXT_BASE=0xFFFD8000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig b/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig index ae81f93d10..764da1f972 100644 --- a/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig +++ b/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig @@ -27,7 +27,6 @@ CONFIG_SPL_FSL_PBL=y CONFIG_SPL_TEXT_BASE=0xFFFD8000 CONFIG_SPL_CRYPTO_SUPPORT=y CONFIG_SPL_HASH_SUPPORT=y -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_SPL_NAND_SUPPORT=y diff --git a/configs/T1042RDB_PI_NAND_defconfig b/configs/T1042RDB_PI_NAND_defconfig index f3ec5e624f..2821ab381f 100644 --- a/configs/T1042RDB_PI_NAND_defconfig +++ b/configs/T1042RDB_PI_NAND_defconfig @@ -24,7 +24,6 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_NAND_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_TEXT_BASE=0xFFFD8000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_SPL_NAND_SUPPORT=y diff --git a/configs/T1042RDB_PI_SDCARD_defconfig b/configs/T1042RDB_PI_SDCARD_defconfig index e5bd44e251..b4ae0e2fc8 100644 --- a/configs/T1042RDB_PI_SDCARD_defconfig +++ b/configs/T1042RDB_PI_SDCARD_defconfig @@ -23,7 +23,6 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_TEXT_BASE=0xFFFD8000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1042RDB_PI_SPIFLASH_defconfig b/configs/T1042RDB_PI_SPIFLASH_defconfig index 07e75aac1d..037e4cef53 100644 --- a/configs/T1042RDB_PI_SPIFLASH_defconfig +++ b/configs/T1042RDB_PI_SPIFLASH_defconfig @@ -24,7 +24,6 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_SPI_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_TEXT_BASE=0xFFFD8000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T2080QDS_NAND_defconfig b/configs/T2080QDS_NAND_defconfig index 0db930f733..d35a2cb16e 100644 --- a/configs/T2080QDS_NAND_defconfig +++ b/configs/T2080QDS_NAND_defconfig @@ -21,7 +21,6 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_NAND_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_TEXT_BASE=0xFFFD8000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_SPL_NAND_SUPPORT=y diff --git a/configs/T2080QDS_SDCARD_defconfig b/configs/T2080QDS_SDCARD_defconfig index f5cca80a6d..488cccbf44 100644 --- a/configs/T2080QDS_SDCARD_defconfig +++ b/configs/T2080QDS_SDCARD_defconfig @@ -20,7 +20,6 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_TEXT_BASE=0xFFFD8000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T2080QDS_SPIFLASH_defconfig b/configs/T2080QDS_SPIFLASH_defconfig index 60539f4380..a7a42d6dbd 100644 --- a/configs/T2080QDS_SPIFLASH_defconfig +++ b/configs/T2080QDS_SPIFLASH_defconfig @@ -21,7 +21,6 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_SPI_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_TEXT_BASE=0xFFFD8000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T2080RDB_NAND_defconfig b/configs/T2080RDB_NAND_defconfig index dcd57f7b3a..ff7dda7c41 100644 --- a/configs/T2080RDB_NAND_defconfig +++ b/configs/T2080RDB_NAND_defconfig @@ -20,7 +20,6 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_NAND_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_TEXT_BASE=0xFFFD8000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_SPL_NAND_SUPPORT=y diff --git a/configs/T2080RDB_SDCARD_defconfig b/configs/T2080RDB_SDCARD_defconfig index 235e8ee514..ba860e0d86 100644 --- a/configs/T2080RDB_SDCARD_defconfig +++ b/configs/T2080RDB_SDCARD_defconfig @@ -19,7 +19,6 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_TEXT_BASE=0xFFFD8000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T2080RDB_SPIFLASH_defconfig b/configs/T2080RDB_SPIFLASH_defconfig index 7b64b7d490..cd5f0cadee 100644 --- a/configs/T2080RDB_SPIFLASH_defconfig +++ b/configs/T2080RDB_SPIFLASH_defconfig @@ -20,7 +20,6 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_SPI_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_TEXT_BASE=0xFFFD8000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T2081QDS_NAND_defconfig b/configs/T2081QDS_NAND_defconfig index da722a86d9..e07ed67ac0 100644 --- a/configs/T2081QDS_NAND_defconfig +++ b/configs/T2081QDS_NAND_defconfig @@ -20,7 +20,6 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_NAND_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_TEXT_BASE=0xFFFD8000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_SPL_NAND_SUPPORT=y diff --git a/configs/T2081QDS_SDCARD_defconfig b/configs/T2081QDS_SDCARD_defconfig index 1769b55cc4..75c56b3994 100644 --- a/configs/T2081QDS_SDCARD_defconfig +++ b/configs/T2081QDS_SDCARD_defconfig @@ -19,7 +19,6 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_TEXT_BASE=0xFFFD8000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T2081QDS_SPIFLASH_defconfig b/configs/T2081QDS_SPIFLASH_defconfig index 5093fa3283..7ad7f88edf 100644 --- a/configs/T2081QDS_SPIFLASH_defconfig +++ b/configs/T2081QDS_SPIFLASH_defconfig @@ -20,7 +20,6 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_SPI_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_TEXT_BASE=0xFFFD8000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T4160QDS_NAND_defconfig b/configs/T4160QDS_NAND_defconfig index f880a46aae..5592e90884 100644 --- a/configs/T4160QDS_NAND_defconfig +++ b/configs/T4160QDS_NAND_defconfig @@ -20,7 +20,6 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_NAND_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_TEXT_BASE=0xFFFD8000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_SPL_NAND_SUPPORT=y diff --git a/configs/T4160QDS_SDCARD_defconfig b/configs/T4160QDS_SDCARD_defconfig index edf39f1c3a..4afefebf4b 100644 --- a/configs/T4160QDS_SDCARD_defconfig +++ b/configs/T4160QDS_SDCARD_defconfig @@ -19,7 +19,6 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_TEXT_BASE=0xFFFD8000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T4240QDS_NAND_defconfig b/configs/T4240QDS_NAND_defconfig index 2a98f960ca..9fce2ac65a 100644 --- a/configs/T4240QDS_NAND_defconfig +++ b/configs/T4240QDS_NAND_defconfig @@ -20,7 +20,6 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_NAND_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_TEXT_BASE=0xFFFD8000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_SPL_NAND_SUPPORT=y diff --git a/configs/T4240QDS_SDCARD_defconfig b/configs/T4240QDS_SDCARD_defconfig index 83815e58e3..0dc9e7d174 100644 --- a/configs/T4240QDS_SDCARD_defconfig +++ b/configs/T4240QDS_SDCARD_defconfig @@ -19,7 +19,6 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_TEXT_BASE=0xFFFD8000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T4240RDB_SDCARD_defconfig b/configs/T4240RDB_SDCARD_defconfig index 7f97166860..2bb1eca573 100644 --- a/configs/T4240RDB_SDCARD_defconfig +++ b/configs/T4240RDB_SDCARD_defconfig @@ -19,7 +19,6 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_MMC_BOOT=y CONFIG_SPL_FSL_PBL=y CONFIG_SPL_TEXT_BASE=0xFFFD8000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/UTOO_P66_defconfig b/configs/UTOO_P66_defconfig index 2b10629cbf..bcb4c8ae9a 100644 --- a/configs/UTOO_P66_defconfig +++ b/configs/UTOO_P66_defconfig @@ -26,6 +26,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-utoo-p66" +CONFIG_SPL_ENV_IS_NOWHERE=y # CONFIG_REQUIRE_SERIAL_CONSOLE is not set CONFIG_CONS_INDEX=2 CONFIG_USB_MUSB_HOST=y diff --git a/configs/Wexler_TAB7200_defconfig b/configs/Wexler_TAB7200_defconfig index 6413fabf84..d03c1f1c7a 100644 --- a/configs/Wexler_TAB7200_defconfig +++ b/configs/Wexler_TAB7200_defconfig @@ -19,6 +19,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-wexler-tab7200" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/Wits_Pro_A20_DKT_defconfig b/configs/Wits_Pro_A20_DKT_defconfig index 437c86795b..09f092c580 100644 --- a/configs/Wits_Pro_A20_DKT_defconfig +++ b/configs/Wits_Pro_A20_DKT_defconfig @@ -18,6 +18,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-wits-pro-a20-dkt" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SCSI_AHCI=y CONFIG_ETH_DESIGNWARE=y CONFIG_RGMII=y diff --git a/configs/Wobo_i5_defconfig b/configs/Wobo_i5_defconfig index e21e4e0ab4..3145825b7c 100644 --- a/configs/Wobo_i5_defconfig +++ b/configs/Wobo_i5_defconfig @@ -13,6 +13,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun5i-a10s-wobo-i5" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_AXP_ALDO3_VOLT=3300 CONFIG_AXP_ALDO4_VOLT=3300 CONFIG_CONS_INDEX=2 diff --git a/configs/Yones_Toptech_BD1078_defconfig b/configs/Yones_Toptech_BD1078_defconfig index 0f8c8afc29..396467af4b 100644 --- a/configs/Yones_Toptech_BD1078_defconfig +++ b/configs/Yones_Toptech_BD1078_defconfig @@ -25,5 +25,6 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-yones-toptech-bd1078" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_USB_MUSB_HOST=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/Yones_Toptech_BS1078_V2_defconfig b/configs/Yones_Toptech_BS1078_V2_defconfig index 9c8107c50d..4ecd7743cf 100644 --- a/configs/Yones_Toptech_BS1078_V2_defconfig +++ b/configs/Yones_Toptech_BS1078_V2_defconfig @@ -21,6 +21,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-yones-toptech-bs1078-v2" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_MUSB_HOST=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/a64-olinuxino_defconfig b/configs/a64-olinuxino_defconfig index 8a3561bed5..383bd1ef8b 100644 --- a/configs/a64-olinuxino_defconfig +++ b/configs/a64-olinuxino_defconfig @@ -11,6 +11,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-olinuxino" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SUN8I_EMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/ae350_rv32_xip_defconfig b/configs/ae350_rv32_xip_defconfig index 8ec72f4507..748a2a4027 100644 --- a/configs/ae350_rv32_xip_defconfig +++ b/configs/ae350_rv32_xip_defconfig @@ -17,6 +17,7 @@ CONFIG_BOOTP_PREFER_SERVERIP=y CONFIG_CMD_CACHE=y CONFIG_DEFAULT_DEVICE_TREE="ae350_32" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SPL_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_MMC=y CONFIG_FTSDC010=y diff --git a/configs/alt_defconfig b/configs/alt_defconfig index 49254e149d..670f98a528 100644 --- a/configs/alt_defconfig +++ b/configs/alt_defconfig @@ -55,6 +55,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=spi0.0:256k(u-boot-spl),512k(u-boot-env1),512k CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="r8a7794-alt-u-boot" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_CLK=y CONFIG_CLK_RENESAS=y CONFIG_DM_GPIO=y diff --git a/configs/am335x_guardian_defconfig b/configs/am335x_guardian_defconfig index 3cada51d35..2f78595034 100644 --- a/configs/am335x_guardian_defconfig +++ b/configs/am335x_guardian_defconfig @@ -21,7 +21,6 @@ CONFIG_VERSION_VARIABLE=y CONFIG_ARCH_MISC_INIT=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_SEPARATE_BSS=y -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_ETH_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MUSB_NEW_SUPPORT=y diff --git a/configs/am335x_hs_evm_defconfig b/configs/am335x_hs_evm_defconfig index f5da7f674f..ed82b2a62f 100644 --- a/configs/am335x_hs_evm_defconfig +++ b/configs/am335x_hs_evm_defconfig @@ -17,7 +17,6 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_ARCH_MISC_INIT=y CONFIG_SPL_FIT_IMAGE_TINY=y -# CONFIG_SPL_ENV_SUPPORT is not set # CONFIG_SPL_FS_EXT4 is not set CONFIG_SPL_MTD_SUPPORT=y # CONFIG_SPL_NAND_SUPPORT is not set @@ -33,6 +32,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="am335x-evm" CONFIG_OF_LIST="am335x-evm am335x-bone am335x-boneblack am335x-evmsk am335x-bonegreen am335x-icev2" CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_DFU_MMC=y CONFIG_DFU_NAND=y diff --git a/configs/am335x_hs_evm_uart_defconfig b/configs/am335x_hs_evm_uart_defconfig index 3708a6f623..e8b027af65 100644 --- a/configs/am335x_hs_evm_uart_defconfig +++ b/configs/am335x_hs_evm_uart_defconfig @@ -20,7 +20,6 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_ARCH_MISC_INIT=y CONFIG_SPL_FIT_IMAGE_TINY=y -# CONFIG_SPL_ENV_SUPPORT is not set # CONFIG_SPL_FS_EXT4 is not set CONFIG_SPL_MTD_SUPPORT=y # CONFIG_SPL_NAND_SUPPORT is not set @@ -35,6 +34,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="am335x-evm" CONFIG_OF_LIST="am335x-evm am335x-bone am335x-boneblack am335x-evmsk am335x-bonegreen am335x-icev2" CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_DFU_MMC=y CONFIG_DFU_NAND=y diff --git a/configs/am335x_igep003x_defconfig b/configs/am335x_igep003x_defconfig index 8ed52a5ffb..3de3d45a6f 100644 --- a/configs/am335x_igep003x_defconfig +++ b/configs/am335x_igep003x_defconfig @@ -60,6 +60,7 @@ CONFIG_ENV_UBI_PART="UBI" CONFIG_ENV_UBI_VOLUME="config" CONFIG_ENV_UBI_VOLUME_REDUND="config_r" CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y diff --git a/configs/am335x_shc_defconfig b/configs/am335x_shc_defconfig index 5698208f84..a31d340e77 100644 --- a/configs/am335x_shc_defconfig +++ b/configs/am335x_shc_defconfig @@ -44,6 +44,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="am335x-shc" CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_PHY_ADDR_ENABLE=y diff --git a/configs/am335x_shc_ict_defconfig b/configs/am335x_shc_ict_defconfig index 3f8a6bad03..802bd4bab1 100644 --- a/configs/am335x_shc_ict_defconfig +++ b/configs/am335x_shc_ict_defconfig @@ -45,6 +45,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="am335x-shc" CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_PHY_ADDR_ENABLE=y diff --git a/configs/am335x_shc_netboot_defconfig b/configs/am335x_shc_netboot_defconfig index d0a7d62a24..358a7023cd 100644 --- a/configs/am335x_shc_netboot_defconfig +++ b/configs/am335x_shc_netboot_defconfig @@ -22,7 +22,6 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_DEFAULT_FDT_FILE="am335x-shc" CONFIG_VERSION_VARIABLE=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_NAND_SUPPORT is not set diff --git a/configs/am335x_shc_sdboot_defconfig b/configs/am335x_shc_sdboot_defconfig index 30fa40abda..a55e84a91d 100644 --- a/configs/am335x_shc_sdboot_defconfig +++ b/configs/am335x_shc_sdboot_defconfig @@ -45,6 +45,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="am335x-shc" CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_PHY_ADDR_ENABLE=y diff --git a/configs/am335x_sl50_defconfig b/configs/am335x_sl50_defconfig index 01fc52b4ed..751fd92e30 100644 --- a/configs/am335x_sl50_defconfig +++ b/configs/am335x_sl50_defconfig @@ -16,7 +16,6 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_EXTRA_OPTIONS="EMMC_BOOT" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_NAND_SUPPORT is not set diff --git a/configs/am3517_crane_defconfig b/configs/am3517_crane_defconfig index 07067a59c3..f714ed9a8c 100644 --- a/configs/am3517_crane_defconfig +++ b/configs/am3517_crane_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_JFFS2=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y diff --git a/configs/am3517_evm_defconfig b/configs/am3517_evm_defconfig index ade4fd7c14..1fac4d97a5 100644 --- a/configs/am3517_evm_defconfig +++ b/configs/am3517_evm_defconfig @@ -44,6 +44,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="am3517-evm" # CONFIG_ENV_IS_IN_FAT is not set CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SPL_OF_TRANSLATE=y diff --git a/configs/am65x_evm_a53_defconfig b/configs/am65x_evm_a53_defconfig index 9d02dbc01a..77b776fe23 100644 --- a/configs/am65x_evm_a53_defconfig +++ b/configs/am65x_evm_a53_defconfig @@ -44,6 +44,7 @@ CONFIG_DEFAULT_DEVICE_TREE="k3-am654-base-board" CONFIG_SPL_MULTI_DTB_FIT=y CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SPL_DM=y diff --git a/configs/am65x_evm_r5_defconfig b/configs/am65x_evm_r5_defconfig index c59b7d98dc..201174d95b 100644 --- a/configs/am65x_evm_r5_defconfig +++ b/configs/am65x_evm_r5_defconfig @@ -51,6 +51,7 @@ CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y CONFIG_ENV_IS_IN_FAT=y CONFIG_ENV_FAT_INTERFACE="mmc" CONFIG_ENV_FAT_DEVICE_AND_PART="1:1" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/am65x_hs_evm_a53_defconfig b/configs/am65x_hs_evm_a53_defconfig index 87547ed9ab..f45649c4a8 100644 --- a/configs/am65x_hs_evm_a53_defconfig +++ b/configs/am65x_hs_evm_a53_defconfig @@ -48,6 +48,7 @@ CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y CONFIG_ENV_IS_IN_FAT=y CONFIG_ENV_FAT_INTERFACE="mmc" CONFIG_ENV_FAT_DEVICE_AND_PART="1:1" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/am65x_hs_evm_r5_defconfig b/configs/am65x_hs_evm_r5_defconfig index 86113b2629..1dedd7ac28 100644 --- a/configs/am65x_hs_evm_r5_defconfig +++ b/configs/am65x_hs_evm_r5_defconfig @@ -53,6 +53,7 @@ CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y CONFIG_ENV_IS_IN_FAT=y CONFIG_ENV_FAT_INTERFACE="mmc" CONFIG_ENV_FAT_DEVICE_AND_PART="1:1" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/amarula_a64_relic_defconfig b/configs/amarula_a64_relic_defconfig index 9eda731a77..37c1478cbc 100644 --- a/configs/amarula_a64_relic_defconfig +++ b/configs/amarula_a64_relic_defconfig @@ -12,6 +12,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-amarula-relic" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y CONFIG_USB_MUSB_GADGET=y diff --git a/configs/apalis-tk1_defconfig b/configs/apalis-tk1_defconfig index be0554b150..184da8fa18 100644 --- a/configs/apalis-tk1_defconfig +++ b/configs/apalis-tk1_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_LIVE=y CONFIG_DEFAULT_DEVICE_TREE="tegra124-apalis" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_IP_DEFRAG=y CONFIG_TFTP_BLOCKSIZE=16352 CONFIG_SPL_DM=y diff --git a/configs/apalis_imx6_defconfig b/configs/apalis_imx6_defconfig index 7b73265abd..785d76b9bf 100644 --- a/configs/apalis_imx6_defconfig +++ b/configs/apalis_imx6_defconfig @@ -52,6 +52,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx6-apalis" CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_IP_DEFRAG=y CONFIG_TFTP_BLOCKSIZE=4096 CONFIG_DWC_AHSATA=y diff --git a/configs/apalis_t30_defconfig b/configs/apalis_t30_defconfig index 75b5a1dca3..855bae5ede 100644 --- a/configs/apalis_t30_defconfig +++ b/configs/apalis_t30_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_LIVE=y CONFIG_DEFAULT_DEVICE_TREE="tegra30-apalis" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_IP_DEFRAG=y CONFIG_TFTP_BLOCKSIZE=16352 CONFIG_SPL_DM=y diff --git a/configs/apf27_defconfig b/configs/apf27_defconfig index 29e9e3b9a9..114cc93db9 100644 --- a/configs/apf27_defconfig +++ b/configs/apf27_defconfig @@ -39,6 +39,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=mxc_nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=mxc_nand.0:1M(u-boot)ro,512K(env),512K(env2),512K(firmware),512K(dtb),5M(kernel),-(rootfs)" CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_FPGA_XILINX=y CONFIG_FPGA_SPARTAN3=y CONFIG_MXC_GPIO=y diff --git a/configs/apx4devkit_defconfig b/configs/apx4devkit_defconfig index 138cfa648c..c0909e37e3 100644 --- a/configs/apx4devkit_defconfig +++ b/configs/apx4devkit_defconfig @@ -31,6 +31,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=gpmi-nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:128k(bootstrap),1024k(boot),768k(env),-(root)" CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_MXS_GPIO=y CONFIG_MMC_MXS=y CONFIG_NAND=y diff --git a/configs/arndale_defconfig b/configs/arndale_defconfig index 012d6f571d..636ce5c8f6 100644 --- a/configs/arndale_defconfig +++ b/configs/arndale_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_SOUND=y CONFIG_CMD_EXT4_WRITE=y CONFIG_DEFAULT_DEVICE_TREE="exynos5250-arndale" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_MMC_DW=y CONFIG_MMC_SDHCI=y diff --git a/configs/axm_defconfig b/configs/axm_defconfig index a1d374aeb5..39850a87de 100644 --- a/configs/axm_defconfig +++ b/configs/axm_defconfig @@ -51,6 +51,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9g20-taurus" CONFIG_SPL_OF_PLATDATA=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SPL_DM=y CONFIG_BLK=y CONFIG_HAVE_BLOCK_DEVICE=y diff --git a/configs/ba10_tv_box_defconfig b/configs/ba10_tv_box_defconfig index a384399b41..106e2a28a8 100644 --- a/configs/ba10_tv_box_defconfig +++ b/configs/ba10_tv_box_defconfig @@ -15,6 +15,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-ba10-tvbox" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_MII=y CONFIG_SUN4I_EMAC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/bananapi_m1_plus_defconfig b/configs/bananapi_m1_plus_defconfig index 549d13ee48..13b333c334 100644 --- a/configs/bananapi_m1_plus_defconfig +++ b/configs/bananapi_m1_plus_defconfig @@ -15,6 +15,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-bananapi-m1-plus" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NETCONSOLE=y CONFIG_SCSI_AHCI=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/bananapi_m2_berry_defconfig b/configs/bananapi_m2_berry_defconfig index 75fd0b173a..2a870b40b4 100644 --- a/configs/bananapi_m2_berry_defconfig +++ b/configs/bananapi_m2_berry_defconfig @@ -11,6 +11,7 @@ CONFIG_USE_PREBOOT=y CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-v40-bananapi-m2-berry" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SCSI_AHCI=y CONFIG_AXP_DLDO4_VOLT=2500 CONFIG_AXP_ELDO3_VOLT=1200 diff --git a/configs/bananapi_m2_plus_h3_defconfig b/configs/bananapi_m2_plus_h3_defconfig index fbfa273069..38a6c7b765 100644 --- a/configs/bananapi_m2_plus_h3_defconfig +++ b/configs/bananapi_m2_plus_h3_defconfig @@ -12,6 +12,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-bananapi-m2-plus" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SUN8I_EMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/bananapi_m2_plus_h5_defconfig b/configs/bananapi_m2_plus_h5_defconfig index 3bc83134b3..5d1e30ad7e 100644 --- a/configs/bananapi_m2_plus_h5_defconfig +++ b/configs/bananapi_m2_plus_h5_defconfig @@ -12,6 +12,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun50i-h5-bananapi-m2-plus" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SUN8I_EMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/bananapi_m2_zero_defconfig b/configs/bananapi_m2_zero_defconfig index 933ec4db43..ebb530631e 100644 --- a/configs/bananapi_m2_zero_defconfig +++ b/configs/bananapi_m2_zero_defconfig @@ -10,3 +10,4 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-h2-plus-bananapi-m2-zero" +CONFIG_SPL_ENV_IS_NOWHERE=y diff --git a/configs/bananapi_m64_defconfig b/configs/bananapi_m64_defconfig index 498b6601a5..2ef8fdbc2a 100644 --- a/configs/bananapi_m64_defconfig +++ b/configs/bananapi_m64_defconfig @@ -12,6 +12,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-bananapi-m64" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SUN8I_EMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/beaver_defconfig b/configs/beaver_defconfig index ec0850d00b..803a45a322 100644 --- a/configs/beaver_defconfig +++ b/configs/beaver_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_LIVE=y CONFIG_DEFAULT_DEVICE_TREE="tegra30-beaver" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SPL_DM=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y diff --git a/configs/beelink_gs1_defconfig b/configs/beelink_gs1_defconfig index c89fba5b83..5b7b81d500 100644 --- a/configs/beelink_gs1_defconfig +++ b/configs/beelink_gs1_defconfig @@ -13,6 +13,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun50i-h6-beelink-gs1" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_LED=y CONFIG_LED_GPIO=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/beelink_x2_defconfig b/configs/beelink_x2_defconfig index 7c62944e98..b5757bbc7c 100644 --- a/configs/beelink_x2_defconfig +++ b/configs/beelink_x2_defconfig @@ -10,6 +10,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-beelink-x2" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SUN8I_EMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/bitmain_antminer_s9_defconfig b/configs/bitmain_antminer_s9_defconfig index 14f8d769bb..9e59bf2833 100644 --- a/configs/bitmain_antminer_s9_defconfig +++ b/configs/bitmain_antminer_s9_defconfig @@ -49,6 +49,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_DEFAULT_DEVICE_TREE="bitmain-antminer-s9" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_BOOTCOUNT_LIMIT=y diff --git a/configs/brppt1_mmc_defconfig b/configs/brppt1_mmc_defconfig index d0ee6194cf..287b25332c 100644 --- a/configs/brppt1_mmc_defconfig +++ b/configs/brppt1_mmc_defconfig @@ -66,6 +66,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="am335x-brppt1-mmc" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clocks clock-names interrupt-parent interrupt-controller interrupt-cells dma-names dmas " CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SPL_DM=y diff --git a/configs/brppt1_nand_defconfig b/configs/brppt1_nand_defconfig index ff227de4b7..c493c5cb75 100644 --- a/configs/brppt1_nand_defconfig +++ b/configs/brppt1_nand_defconfig @@ -67,6 +67,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="am335x-brppt1-nand" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clocks clock-names interrupt-parent interrupt-controller interrupt-cells dma-names dmas " CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SPL_DM=y diff --git a/configs/brppt1_spi_defconfig b/configs/brppt1_spi_defconfig index a29dc0385e..66327c0f3c 100644 --- a/configs/brppt1_spi_defconfig +++ b/configs/brppt1_spi_defconfig @@ -73,6 +73,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="am335x-brppt1-spi" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clocks clock-names interrupt-parent interrupt-controller interrupt-cells dma-names dmas " CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SPL_DM=y diff --git a/configs/brsmarc1_defconfig b/configs/brsmarc1_defconfig index 8863a2d5cc..55e9b10d10 100644 --- a/configs/brsmarc1_defconfig +++ b/configs/brsmarc1_defconfig @@ -69,6 +69,7 @@ CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="am335x-brsmarc1" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_NETCONSOLE=y CONFIG_DM=y diff --git a/configs/brxre1_defconfig b/configs/brxre1_defconfig index d4169c0327..1c4bf8c6fc 100644 --- a/configs/brxre1_defconfig +++ b/configs/brxre1_defconfig @@ -62,6 +62,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="am335x-brxre1" CONFIG_OF_SPL_REMOVE_PROPS="" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_NETCONSOLE=y CONFIG_DM=y diff --git a/configs/cairo_defconfig b/configs/cairo_defconfig index f26f2c9054..2076d2ad4c 100644 --- a/configs/cairo_defconfig +++ b/configs/cairo_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_SPI=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_MTDPARTS=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_TWL4030_LED=y CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y diff --git a/configs/cardhu_defconfig b/configs/cardhu_defconfig index cc519d0755..882bbfbbee 100644 --- a/configs/cardhu_defconfig +++ b/configs/cardhu_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="tegra30-cardhu" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SPL_DM=y CONFIG_SYS_I2C_TEGRA=y CONFIG_SPI_FLASH=y diff --git a/configs/cei-tk1-som_defconfig b/configs/cei-tk1-som_defconfig index 677014028f..4256e766c9 100644 --- a/configs/cei-tk1-som_defconfig +++ b/configs/cei-tk1-som_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="tegra124-cei-tk1-som" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SPL_DM=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y diff --git a/configs/cgtqmx6eval_defconfig b/configs/cgtqmx6eval_defconfig index fd4e3077ac..44c39cc521 100644 --- a/configs/cgtqmx6eval_defconfig +++ b/configs/cgtqmx6eval_defconfig @@ -51,6 +51,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DWC_AHSATA=y CONFIG_DFU_MMC=y CONFIG_DFU_SF=y diff --git a/configs/chiliboard_defconfig b/configs/chiliboard_defconfig index f275d21d16..0315c85312 100644 --- a/configs/chiliboard_defconfig +++ b/configs/chiliboard_defconfig @@ -35,6 +35,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=8000000.nand:128k(NAND.SPL),128k(NAND.SPL.back CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="am335x-chiliboard" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_DM_GPIO=y CONFIG_MISC=y diff --git a/configs/chromebook_bob_defconfig b/configs/chromebook_bob_defconfig index 967162248c..2035537860 100644 --- a/configs/chromebook_bob_defconfig +++ b/configs/chromebook_bob_defconfig @@ -41,6 +41,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="rk3399-gru-bob" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_ROCKCHIP_GPIO=y CONFIG_I2C_CROS_EC_TUNNEL=y CONFIG_SYS_I2C_ROCKCHIP=y diff --git a/configs/chromebook_link64_defconfig b/configs/chromebook_link64_defconfig index 4bbd7a67dc..9094b71fc6 100644 --- a/configs/chromebook_link64_defconfig +++ b/configs/chromebook_link64_defconfig @@ -25,7 +25,6 @@ CONFIG_LAST_STAGE_INIT=y CONFIG_SPL_TEXT_BASE=0xfffd0000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_CPU_SUPPORT=y -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_NET_SUPPORT=y CONFIG_SPL_PCI=y diff --git a/configs/chromebook_samus_tpl_defconfig b/configs/chromebook_samus_tpl_defconfig index 973460082d..6c1e0db2fc 100644 --- a/configs/chromebook_samus_tpl_defconfig +++ b/configs/chromebook_samus_tpl_defconfig @@ -59,6 +59,8 @@ CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="chromebook_samus" +CONFIG_SPL_ENV_IS_NOWHERE=y +CONFIG_TPL_ENV_IS_NOWHERE=y # CONFIG_NET is not set CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/ci20_mmc_defconfig b/configs/ci20_mmc_defconfig index 69a449f9e7..b6c1c13864 100644 --- a/configs/ci20_mmc_defconfig +++ b/configs/ci20_mmc_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_FAT=y # CONFIG_SPL_DOS_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="ci20" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y # CONFIG_DM_WARN is not set # CONFIG_DM_DEVICE_REMOVE is not set CONFIG_JZ4780_EFUSE=y diff --git a/configs/cl-som-imx7_defconfig b/configs/cl-som-imx7_defconfig index 04d1042060..6229875dc7 100644 --- a/configs/cl-som-imx7_defconfig +++ b/configs/cl-som-imx7_defconfig @@ -49,6 +49,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx7d-sdb" # CONFIG_ENV_IS_IN_MMC is not set CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_FSL_USDHC=y diff --git a/configs/clearfog_defconfig b/configs/clearfog_defconfig index 040e6b9969..42763d69b6 100644 --- a/configs/clearfog_defconfig +++ b/configs/clearfog_defconfig @@ -41,6 +41,7 @@ CONFIG_CMD_TIME=y # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_DEFAULT_DEVICE_TREE="armada-388-clearfog" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_AHCI_MVEBU=y diff --git a/configs/cm_fx6_defconfig b/configs/cm_fx6_defconfig index fd0db4db5c..a092ea1420 100644 --- a/configs/cm_fx6_defconfig +++ b/configs/cm_fx6_defconfig @@ -54,6 +54,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx6q-cm-fx6" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DWC_AHSATA=y # CONFIG_DWC_AHSATA_AHCI is not set CONFIG_DM_KEYBOARD=y diff --git a/configs/cm_t335_defconfig b/configs/cm_t335_defconfig index ab9f1fde44..f59e8b795c 100644 --- a/configs/cm_t335_defconfig +++ b/configs/cm_t335_defconfig @@ -39,6 +39,7 @@ CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand0=nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=nand:2m(spl),1m(u-boot),1m(u-boot-env),1m(dtb),4m(splash),6m(kernel),-(rootfs)" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_CMD_PCA953X=y CONFIG_LED_STATUS=y CONFIG_LED_STATUS_GPIO=y diff --git a/configs/cm_t35_defconfig b/configs/cm_t35_defconfig index 44b66a468e..b8c1ee5ba2 100644 --- a/configs/cm_t35_defconfig +++ b/configs/cm_t35_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand0=nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=nand:512k(x-loader),1920k(u-boot),256k(u-boot-env),4m(kernel),-(fs)" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_LED_STATUS=y CONFIG_LED_STATUS_GPIO=y CONFIG_LED_STATUS0=y diff --git a/configs/cm_t43_defconfig b/configs/cm_t43_defconfig index 214a054ac4..2c859299b2 100644 --- a/configs/cm_t43_defconfig +++ b/configs/cm_t43_defconfig @@ -50,6 +50,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_MTDPARTS=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_DM_GPIO=y CONFIG_MMC_OMAP_HS=y diff --git a/configs/colibri_imx6_defconfig b/configs/colibri_imx6_defconfig index 6f8b63949c..85941fe999 100644 --- a/configs/colibri_imx6_defconfig +++ b/configs/colibri_imx6_defconfig @@ -52,6 +52,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx6-colibri" CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_IP_DEFRAG=y CONFIG_TFTP_BLOCKSIZE=16352 CONFIG_DM_GPIO=y diff --git a/configs/colibri_t20_defconfig b/configs/colibri_t20_defconfig index 73d13bbb06..075be4de90 100644 --- a/configs/colibri_t20_defconfig +++ b/configs/colibri_t20_defconfig @@ -35,6 +35,7 @@ CONFIG_CMD_UBI=y CONFIG_OF_LIVE=y CONFIG_DEFAULT_DEVICE_TREE="tegra20-colibri" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_IP_DEFRAG=y CONFIG_TFTP_BLOCKSIZE=1536 CONFIG_SPL_DM=y diff --git a/configs/colibri_t30_defconfig b/configs/colibri_t30_defconfig index 1e2268a105..148b74cd0f 100644 --- a/configs/colibri_t30_defconfig +++ b/configs/colibri_t30_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_LIVE=y CONFIG_DEFAULT_DEVICE_TREE="tegra30-colibri" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_IP_DEFRAG=y CONFIG_TFTP_BLOCKSIZE=16352 CONFIG_SPL_DM=y diff --git a/configs/colorfly_e708_q1_defconfig b/configs/colorfly_e708_q1_defconfig index 45653089f1..eb4f537c70 100644 --- a/configs/colorfly_e708_q1_defconfig +++ b/configs/colorfly_e708_q1_defconfig @@ -21,6 +21,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-colorfly-e708-q1" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_AXP_DLDO2_VOLT=1800 CONFIG_USB_MUSB_HOST=y diff --git a/configs/controlcenterdc_defconfig b/configs/controlcenterdc_defconfig index 46fe75365b..90a577856f 100644 --- a/configs/controlcenterdc_defconfig +++ b/configs/controlcenterdc_defconfig @@ -51,6 +51,7 @@ CONFIG_DEFAULT_DEVICE_TREE="armada-38x-controlcenterdc" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USE_ENV_SPI_MAX_HZ=y CONFIG_ENV_SPI_MAX_HZ=50000000 +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_SCSI_AHCI=y CONFIG_DM_GPIO=y diff --git a/configs/corvus_defconfig b/configs/corvus_defconfig index f4d45272ba..cf1a6dab2d 100644 --- a/configs/corvus_defconfig +++ b/configs/corvus_defconfig @@ -41,6 +41,7 @@ CONFIG_DOS_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9g45-corvus" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_BLK=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/da850evm_defconfig b/configs/da850evm_defconfig index cfd910ad26..86831e91cc 100644 --- a/configs/da850evm_defconfig +++ b/configs/da850evm_defconfig @@ -46,6 +46,7 @@ CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="da850-evm" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/da850evm_nand_defconfig b/configs/da850evm_nand_defconfig index 701093977e..0eafb5db26 100644 --- a/configs/da850evm_nand_defconfig +++ b/configs/da850evm_nand_defconfig @@ -43,6 +43,7 @@ CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="da850-evm" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/dalmore_defconfig b/configs/dalmore_defconfig index 4802e2d8d8..e7124bd084 100644 --- a/configs/dalmore_defconfig +++ b/configs/dalmore_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="tegra114-dalmore" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SPL_DM=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y diff --git a/configs/db-88f6720_defconfig b/configs/db-88f6720_defconfig index 8270b77309..9c2d1687d8 100644 --- a/configs/db-88f6720_defconfig +++ b/configs/db-88f6720_defconfig @@ -45,6 +45,7 @@ CONFIG_DEFAULT_DEVICE_TREE="armada-375-db" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USE_ENV_SPI_MAX_HZ=y CONFIG_ENV_SPI_MAX_HZ=50000000 +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_BLK=y diff --git a/configs/db-88f6820-amc_defconfig b/configs/db-88f6820-amc_defconfig index 82308b4196..a9046a8211 100644 --- a/configs/db-88f6820-amc_defconfig +++ b/configs/db-88f6820-amc_defconfig @@ -49,6 +49,7 @@ CONFIG_DEFAULT_DEVICE_TREE="armada-385-db-88f6820-amc" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USE_ENV_SPI_MAX_HZ=y CONFIG_ENV_SPI_MAX_HZ=50000000 +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_BLK=y # CONFIG_SPL_BLK is not set diff --git a/configs/db-88f6820-gp_defconfig b/configs/db-88f6820-gp_defconfig index 7beca5d80b..99f1c3bc23 100644 --- a/configs/db-88f6820-gp_defconfig +++ b/configs/db-88f6820-gp_defconfig @@ -50,6 +50,7 @@ CONFIG_DEFAULT_DEVICE_TREE="armada-388-gp" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USE_ENV_SPI_MAX_HZ=y CONFIG_ENV_SPI_MAX_HZ=50000000 +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_AHCI_MVEBU=y CONFIG_DM_MMC=y diff --git a/configs/db-mv784mp-gp_defconfig b/configs/db-mv784mp-gp_defconfig index 7d86e065e3..4354e25554 100644 --- a/configs/db-mv784mp-gp_defconfig +++ b/configs/db-mv784mp-gp_defconfig @@ -48,6 +48,7 @@ CONFIG_EFI_PARTITION=y CONFIG_DEFAULT_DEVICE_TREE="armada-xp-gp" CONFIG_USE_ENV_SPI_MAX_HZ=y CONFIG_ENV_SPI_MAX_HZ=50000000 +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_SATA_MV=y CONFIG_BLK=y diff --git a/configs/devkit3250_defconfig b/configs/devkit3250_defconfig index ae7be20f99..512d155550 100644 --- a/configs/devkit3250_defconfig +++ b/configs/devkit3250_defconfig @@ -32,6 +32,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_FAT=y CONFIG_CMD_JFFS2=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/devkit8000_defconfig b/configs/devkit8000_defconfig index da09b3af12..99f1890db5 100644 --- a/configs/devkit8000_defconfig +++ b/configs/devkit8000_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand0=nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=nand:512k(x-loader),1920k(u-boot),128k(u-boot-env),4m(kernel),-(fs)" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_TWL4030_LED=y CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y diff --git a/configs/dh_imx6_defconfig b/configs/dh_imx6_defconfig index f59f2e78ae..696452597c 100644 --- a/configs/dh_imx6_defconfig +++ b/configs/dh_imx6_defconfig @@ -45,6 +45,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx6q-dhcom-pdk2" CONFIG_OF_LIST="imx6q-dhcom-pdk2 imx6dl-dhcom-pdk2" CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DWC_AHSATA=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_DM_GPIO=y diff --git a/configs/difrnce_dit4350_defconfig b/configs/difrnce_dit4350_defconfig index 7e28dec718..71931d95cf 100644 --- a/configs/difrnce_dit4350_defconfig +++ b/configs/difrnce_dit4350_defconfig @@ -21,6 +21,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-difrnce-dit4350" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_CONS_INDEX=2 CONFIG_USB_MUSB_HOST=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/display5_defconfig b/configs/display5_defconfig index 8609cd5a8c..71099ea547 100644 --- a/configs/display5_defconfig +++ b/configs/display5_defconfig @@ -27,7 +27,6 @@ CONFIG_SPL_TEXT_BASE=0x00908000 CONFIG_SPL_BOOTCOUNT_LIMIT=y # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set CONFIG_SPL_DMA_SUPPORT=y -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_SAVEENV=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_OS_BOOT=y diff --git a/configs/display5_factory_defconfig b/configs/display5_factory_defconfig index 70c64260d8..2bb8ef2302 100644 --- a/configs/display5_factory_defconfig +++ b/configs/display5_factory_defconfig @@ -63,6 +63,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=02008000.spi.1:128k(SPL),1m(u-boot),64k(env1), # CONFIG_SPL_EFI_PARTITION is not set CONFIG_PARTITION_TYPE_GUID=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DFU_MMC=y CONFIG_DFU_SF=y CONFIG_SUPPORT_EMMC_BOOT=y diff --git a/configs/draco_defconfig b/configs/draco_defconfig index 4ba3bde2e6..11d486460e 100644 --- a/configs/draco_defconfig +++ b/configs/draco_defconfig @@ -59,6 +59,7 @@ CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="am335x-draco" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_ENV=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 diff --git a/configs/ds414_defconfig b/configs/ds414_defconfig index 2f365ddfb2..cea8705e08 100644 --- a/configs/ds414_defconfig +++ b/configs/ds414_defconfig @@ -46,6 +46,7 @@ CONFIG_ISO_PARTITION=y CONFIG_DEFAULT_DEVICE_TREE="armada-xp-synology-ds414" CONFIG_USE_ENV_SPI_MAX_HZ=y CONFIG_ENV_SPI_MAX_HZ=50000000 +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_BLK=y diff --git a/configs/dserve_dsrv9703c_defconfig b/configs/dserve_dsrv9703c_defconfig index c664bf5684..d9037608ad 100644 --- a/configs/dserve_dsrv9703c_defconfig +++ b/configs/dserve_dsrv9703c_defconfig @@ -20,5 +20,6 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-dserve-dsrv9703c" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_USB_MUSB_HOST=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/edminiv2_defconfig b/configs/edminiv2_defconfig index d663090992..32b571cc58 100644 --- a/configs/edminiv2_defconfig +++ b/configs/edminiv2_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_EXT2=y CONFIG_ISO_PARTITION=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_MVSATA_IDE=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/emlid_neutis_n5_devboard_defconfig b/configs/emlid_neutis_n5_devboard_defconfig index e85287e3ec..bfd588bc8e 100644 --- a/configs/emlid_neutis_n5_devboard_defconfig +++ b/configs/emlid_neutis_n5_devboard_defconfig @@ -13,3 +13,4 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun50i-h5-emlid-neutis-n5-devboard" +CONFIG_SPL_ENV_IS_NOWHERE=y diff --git a/configs/etamin_defconfig b/configs/etamin_defconfig index 31e711d32f..2a120615b8 100644 --- a/configs/etamin_defconfig +++ b/configs/etamin_defconfig @@ -60,6 +60,7 @@ CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="am335x-draco" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_ENV=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 diff --git a/configs/evb-px5_defconfig b/configs/evb-px5_defconfig index 5a06b2a99f..bb19ab98db 100644 --- a/configs/evb-px5_defconfig +++ b/configs/evb-px5_defconfig @@ -44,6 +44,8 @@ CONFIG_DEFAULT_DEVICE_TREE="rk3368-px5-evb" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names interrupt-parent" CONFIG_TPL_OF_PLATDATA=y CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y +CONFIG_TPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_TPL_DM=y CONFIG_REGMAP=y diff --git a/configs/evb-rk3229_defconfig b/configs/evb-rk3229_defconfig index 128fbcd64c..81e02bc9cd 100644 --- a/configs/evb-rk3229_defconfig +++ b/configs/evb-rk3229_defconfig @@ -33,6 +33,8 @@ CONFIG_TPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="rk3229-evb" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y +CONFIG_TPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y diff --git a/configs/evb-rk3288_defconfig b/configs/evb-rk3288_defconfig index 405fde0c80..bd5358904f 100644 --- a/configs/evb-rk3288_defconfig +++ b/configs/evb-rk3288_defconfig @@ -35,6 +35,8 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="rk3288-evb" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y +CONFIG_TPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y diff --git a/configs/evb-rk3328_defconfig b/configs/evb-rk3328_defconfig index 37610774c1..840487b116 100644 --- a/configs/evb-rk3328_defconfig +++ b/configs/evb-rk3328_defconfig @@ -36,6 +36,8 @@ CONFIG_DEFAULT_DEVICE_TREE="rk3328-evb" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_TPL_OF_PLATDATA=y CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y +CONFIG_TPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_TPL_DM=y CONFIG_REGMAP=y diff --git a/configs/evb-rk3399_defconfig b/configs/evb-rk3399_defconfig index a0d215a5f1..2a97dd8748 100644 --- a/configs/evb-rk3399_defconfig +++ b/configs/evb-rk3399_defconfig @@ -26,6 +26,8 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="rk3399-evb" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y +CONFIG_TPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y diff --git a/configs/ficus-rk3399_defconfig b/configs/ficus-rk3399_defconfig index 8b3692cdf0..9c2745db98 100644 --- a/configs/ficus-rk3399_defconfig +++ b/configs/ficus-rk3399_defconfig @@ -25,6 +25,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="rk3399-ficus" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y diff --git a/configs/firefly-rk3288_defconfig b/configs/firefly-rk3288_defconfig index 7ca522b479..54a41677be 100644 --- a/configs/firefly-rk3288_defconfig +++ b/configs/firefly-rk3288_defconfig @@ -38,6 +38,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="rk3288-firefly" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y diff --git a/configs/firefly-rk3399_defconfig b/configs/firefly-rk3399_defconfig index d022631465..c554105682 100644 --- a/configs/firefly-rk3399_defconfig +++ b/configs/firefly-rk3399_defconfig @@ -26,6 +26,8 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="rk3399-firefly" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y +CONFIG_TPL_ENV_IS_NOWHERE=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MMC_DW=y diff --git a/configs/ga10h_v1_1_defconfig b/configs/ga10h_v1_1_defconfig index b82325dfe8..65fd667c4c 100644 --- a/configs/ga10h_v1_1_defconfig +++ b/configs/ga10h_v1_1_defconfig @@ -22,6 +22,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-ga10h-v1.1" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_CONS_INDEX=5 CONFIG_USB_EHCI_HCD=y diff --git a/configs/gardena-smart-gateway-at91sam_defconfig b/configs/gardena-smart-gateway-at91sam_defconfig index c495ba4612..723c3feae2 100644 --- a/configs/gardena-smart-gateway-at91sam_defconfig +++ b/configs/gardena-smart-gateway-at91sam_defconfig @@ -55,6 +55,7 @@ CONFIG_ENV_IS_IN_UBI=y CONFIG_ENV_UBI_PART="ubi" CONFIG_ENV_UBI_VOLUME="env" CONFIG_ENV_UBI_VOLUME_REDUND="env_r" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SPL_DM=y diff --git a/configs/gose_defconfig b/configs/gose_defconfig index f9906ebfb8..aaa2dd8f7a 100644 --- a/configs/gose_defconfig +++ b/configs/gose_defconfig @@ -55,6 +55,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=spi0.0:256k(u-boot-spl),512k(u-boot-env1),512k CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="r8a7793-gose-u-boot" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_CLK=y CONFIG_CLK_RENESAS=y CONFIG_DM_GPIO=y diff --git a/configs/gt90h_v4_defconfig b/configs/gt90h_v4_defconfig index b317d4d1d7..d52fe18d2f 100644 --- a/configs/gt90h_v4_defconfig +++ b/configs/gt90h_v4_defconfig @@ -21,6 +21,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-gt90h-v4" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_CONS_INDEX=5 CONFIG_USB_MUSB_HOST=y diff --git a/configs/gwventana_emmc_defconfig b/configs/gwventana_emmc_defconfig index 5d869c08e1..f8df47ad1a 100644 --- a/configs/gwventana_emmc_defconfig +++ b/configs/gwventana_emmc_defconfig @@ -59,6 +59,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=nand:16m(uboot),1m(env),-(rootfs)" CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_DWC_AHSATA=y CONFIG_SUPPORT_EMMC_RPMB=y diff --git a/configs/gwventana_gw5904_defconfig b/configs/gwventana_gw5904_defconfig index df3d35acc4..5b1efdbc23 100644 --- a/configs/gwventana_gw5904_defconfig +++ b/configs/gwventana_gw5904_defconfig @@ -59,6 +59,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=nand:16m(uboot),1m(env),-(rootfs)" CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_DWC_AHSATA=y CONFIG_SUPPORT_EMMC_RPMB=y diff --git a/configs/gwventana_nand_defconfig b/configs/gwventana_nand_defconfig index a0d38ae97b..e44a709b89 100644 --- a/configs/gwventana_nand_defconfig +++ b/configs/gwventana_nand_defconfig @@ -62,6 +62,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=nand:16m(uboot),1m(env),-(rootfs)" CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_DWC_AHSATA=y CONFIG_SUPPORT_EMMC_RPMB=y diff --git a/configs/h8_homlet_v2_defconfig b/configs/h8_homlet_v2_defconfig index 70c566da6a..8e3f5c9afc 100644 --- a/configs/h8_homlet_v2_defconfig +++ b/configs/h8_homlet_v2_defconfig @@ -16,6 +16,7 @@ CONFIG_CONSOLE_MUX=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-a83t-allwinner-h8homlet-v2" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_AXP_DLDO4_VOLT=3300 CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/harmony_defconfig b/configs/harmony_defconfig index 04212c96fb..4dbbe68ee4 100644 --- a/configs/harmony_defconfig +++ b/configs/harmony_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_UBI=y CONFIG_OF_LIVE=y CONFIG_DEFAULT_DEVICE_TREE="tegra20-harmony" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SPL_DM=y CONFIG_MTD=y CONFIG_MTD_UBI_FASTMAP=y diff --git a/configs/helios4_defconfig b/configs/helios4_defconfig index cd6b476e10..d060a4159c 100644 --- a/configs/helios4_defconfig +++ b/configs/helios4_defconfig @@ -37,6 +37,7 @@ CONFIG_CMD_TIME=y # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_DEFAULT_DEVICE_TREE="armada-388-helios4" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_SCSI_AHCI=y diff --git a/configs/i12-tvbox_defconfig b/configs/i12-tvbox_defconfig index c512d36ba0..6c7e99e73e 100644 --- a/configs/i12-tvbox_defconfig +++ b/configs/i12-tvbox_defconfig @@ -13,6 +13,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-i12-tvbox" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_ETH_DESIGNWARE=y CONFIG_MII=y CONFIG_SUN7I_GMAC=y diff --git a/configs/iNet_3F_defconfig b/configs/iNet_3F_defconfig index 6c047ca98b..dcb38ee461 100644 --- a/configs/iNet_3F_defconfig +++ b/configs/iNet_3F_defconfig @@ -20,5 +20,6 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-inet-3f" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_USB_MUSB_HOST=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/iNet_3W_defconfig b/configs/iNet_3W_defconfig index 3b4ffe494b..da7062c25c 100644 --- a/configs/iNet_3W_defconfig +++ b/configs/iNet_3W_defconfig @@ -20,5 +20,6 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-inet-3w" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_USB_MUSB_HOST=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/iNet_86VS_defconfig b/configs/iNet_86VS_defconfig index 5fff4ad585..84fe143084 100644 --- a/configs/iNet_86VS_defconfig +++ b/configs/iNet_86VS_defconfig @@ -19,6 +19,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-inet-86vs" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_CONS_INDEX=2 CONFIG_USB_MUSB_HOST=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/iNet_D978_rev2_defconfig b/configs/iNet_D978_rev2_defconfig index d36c3eec7d..9144bc5fed 100644 --- a/configs/iNet_D978_rev2_defconfig +++ b/configs/iNet_D978_rev2_defconfig @@ -22,6 +22,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-inet-d978-rev2" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_AXP_DLDO1_VOLT=3300 # CONFIG_REQUIRE_SERIAL_CONSOLE is not set CONFIG_CONS_INDEX=5 diff --git a/configs/icnova-a20-swac_defconfig b/configs/icnova-a20-swac_defconfig index 1372c7606c..f379413953 100644 --- a/configs/icnova-a20-swac_defconfig +++ b/configs/icnova-a20-swac_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_UNZIP=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-icnova-swac" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_ETH_DESIGNWARE=y CONFIG_MII=y CONFIG_SUN7I_GMAC=y diff --git a/configs/igep00x0_defconfig b/configs/igep00x0_defconfig index 43aef5d26e..ff7fbd1773 100644 --- a/configs/igep00x0_defconfig +++ b/configs/igep00x0_defconfig @@ -46,6 +46,7 @@ CONFIG_ENV_IS_IN_UBI=y CONFIG_ENV_UBI_PART="UBI" CONFIG_ENV_UBI_VOLUME="config" CONFIG_ENV_UBI_VOLUME_REDUND="config_r" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y diff --git a/configs/imx6dl_icore_nand_defconfig b/configs/imx6dl_icore_nand_defconfig index 6eb7c7ab3a..7ccdfe32a0 100644 --- a/configs/imx6dl_icore_nand_defconfig +++ b/configs/imx6dl_icore_nand_defconfig @@ -38,6 +38,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:2m(spl),2m(uboot),1m(env),8m(kernel) CONFIG_CMD_UBI=y CONFIG_DEFAULT_DEVICE_TREE="imx6dl-icore" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SYS_I2C_MXC=y CONFIG_FSL_USDHC=y CONFIG_NAND=y diff --git a/configs/imx6dl_mamoj_defconfig b/configs/imx6dl_mamoj_defconfig index 44486cbfa3..2fa0492a30 100644 --- a/configs/imx6dl_mamoj_defconfig +++ b/configs/imx6dl_mamoj_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_PMIC=y CONFIG_CMD_EXT4_WRITE=y CONFIG_DEFAULT_DEVICE_TREE="imx6dl-mamoj" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DFU_MMC=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 diff --git a/configs/imx6q_icore_nand_defconfig b/configs/imx6q_icore_nand_defconfig index fc990a8add..65d4b488f1 100644 --- a/configs/imx6q_icore_nand_defconfig +++ b/configs/imx6q_icore_nand_defconfig @@ -39,6 +39,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:2m(spl),2m(uboot),1m(env),8m(kernel) CONFIG_CMD_UBI=y CONFIG_DEFAULT_DEVICE_TREE="imx6q-icore" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SYS_I2C_MXC=y CONFIG_FSL_USDHC=y CONFIG_NAND=y diff --git a/configs/imx6q_logic_defconfig b/configs/imx6q_logic_defconfig index 12f49db790..9b925ef9f5 100644 --- a/configs/imx6q_logic_defconfig +++ b/configs/imx6q_logic_defconfig @@ -60,6 +60,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_ENV_FAT_INTERFACE="mmc" CONFIG_ENV_FAT_DEVICE_AND_PART="0:1" CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SPL_OF_TRANSLATE=y diff --git a/configs/imx6qdl_icore_mipi_defconfig b/configs/imx6qdl_icore_mipi_defconfig index 5442ce7db4..f87e783a47 100644 --- a/configs/imx6qdl_icore_mipi_defconfig +++ b/configs/imx6qdl_icore_mipi_defconfig @@ -43,6 +43,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_DEFAULT_DEVICE_TREE="imx6q-icore-mipi" CONFIG_OF_LIST="imx6q-icore-mipi imx6dl-icore-mipi" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SYS_I2C_MXC=y CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y diff --git a/configs/imx6qdl_icore_mmc_defconfig b/configs/imx6qdl_icore_mmc_defconfig index c7544c68c8..1d22edb863 100644 --- a/configs/imx6qdl_icore_mmc_defconfig +++ b/configs/imx6qdl_icore_mmc_defconfig @@ -50,6 +50,7 @@ CONFIG_CMD_UBI=y CONFIG_DEFAULT_DEVICE_TREE="imx6q-icore" CONFIG_OF_LIST="imx6q-icore imx6dl-icore" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 CONFIG_SYS_BOOTCOUNT_MAGIC=0x0B01C041 diff --git a/configs/imx6qdl_icore_nand_defconfig b/configs/imx6qdl_icore_nand_defconfig index fc990a8add..65d4b488f1 100644 --- a/configs/imx6qdl_icore_nand_defconfig +++ b/configs/imx6qdl_icore_nand_defconfig @@ -39,6 +39,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:2m(spl),2m(uboot),1m(env),8m(kernel) CONFIG_CMD_UBI=y CONFIG_DEFAULT_DEVICE_TREE="imx6q-icore" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SYS_I2C_MXC=y CONFIG_FSL_USDHC=y CONFIG_NAND=y diff --git a/configs/imx6qdl_icore_rqs_defconfig b/configs/imx6qdl_icore_rqs_defconfig index 9f0cc0ffed..0f19484a01 100644 --- a/configs/imx6qdl_icore_rqs_defconfig +++ b/configs/imx6qdl_icore_rqs_defconfig @@ -40,6 +40,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_DEFAULT_DEVICE_TREE="imx6q-icore-rqs" CONFIG_OF_LIST="imx6q-icore-rqs imx6dl-icore-rqs" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SYS_I2C_MXC=y CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y diff --git a/configs/imx6ul_geam_mmc_defconfig b/configs/imx6ul_geam_mmc_defconfig index 620d979342..72755f2f05 100644 --- a/configs/imx6ul_geam_mmc_defconfig +++ b/configs/imx6ul_geam_mmc_defconfig @@ -37,6 +37,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_DEFAULT_DEVICE_TREE="imx6ul-geam" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SYS_I2C_MXC=y CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y diff --git a/configs/imx6ul_geam_nand_defconfig b/configs/imx6ul_geam_nand_defconfig index 94d43fdd04..408d09f061 100644 --- a/configs/imx6ul_geam_nand_defconfig +++ b/configs/imx6ul_geam_nand_defconfig @@ -40,6 +40,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:2m(spl),2m(uboot),1m(env),8m(kernel) CONFIG_CMD_UBI=y CONFIG_DEFAULT_DEVICE_TREE="imx6ul-geam" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SYS_I2C_MXC=y CONFIG_FSL_USDHC=y CONFIG_NAND=y diff --git a/configs/imx6ul_isiot_emmc_defconfig b/configs/imx6ul_isiot_emmc_defconfig index f0f53bada7..f3e1bdfcd6 100644 --- a/configs/imx6ul_isiot_emmc_defconfig +++ b/configs/imx6ul_isiot_emmc_defconfig @@ -37,6 +37,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_DEFAULT_DEVICE_TREE="imx6ul-isiot-emmc" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SYS_I2C_MXC=y CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y diff --git a/configs/imx6ul_isiot_nand_defconfig b/configs/imx6ul_isiot_nand_defconfig index 05e0498a5e..20409d3907 100644 --- a/configs/imx6ul_isiot_nand_defconfig +++ b/configs/imx6ul_isiot_nand_defconfig @@ -40,6 +40,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:2m(spl),2m(uboot),1m(env),8m(kernel) CONFIG_CMD_UBI=y CONFIG_DEFAULT_DEVICE_TREE="imx6ul-isiot-nand" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SYS_I2C_MXC=y CONFIG_FSL_USDHC=y CONFIG_NAND=y diff --git a/configs/imx8mq_evk_defconfig b/configs/imx8mq_evk_defconfig index 48b16a4e24..005060fcf4 100644 --- a/configs/imx8mq_evk_defconfig +++ b/configs/imx8mq_evk_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-imx8mq-evk" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SAVED_DRAM_TIMING_BASE=0x40000000 CONFIG_DM_GPIO=y CONFIG_DM_I2C=y diff --git a/configs/imx8qm_mek_defconfig b/configs/imx8qm_mek_defconfig index 3294931ef8..05b243366f 100644 --- a/configs/imx8qm_mek_defconfig +++ b/configs/imx8qm_mek_defconfig @@ -38,6 +38,7 @@ CONFIG_CMD_FAT=y CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-imx8qm-mek" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SPL_DM=y CONFIG_SPL_CLK=y CONFIG_CLK_IMX8=y diff --git a/configs/imx8qxp_mek_defconfig b/configs/imx8qxp_mek_defconfig index d7974e8fad..6d8a3ba330 100644 --- a/configs/imx8qxp_mek_defconfig +++ b/configs/imx8qxp_mek_defconfig @@ -42,6 +42,7 @@ CONFIG_CMD_FAT=y CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-imx8qxp-mek" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SPL_DM=y CONFIG_SPL_CLK=y CONFIG_CLK_IMX8=y diff --git a/configs/inet1_defconfig b/configs/inet1_defconfig index 3cb6664157..ce362c64d9 100644 --- a/configs/inet1_defconfig +++ b/configs/inet1_defconfig @@ -20,6 +20,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-inet1" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/inet86dz_defconfig b/configs/inet86dz_defconfig index 9038811eac..d46141c4b9 100644 --- a/configs/inet86dz_defconfig +++ b/configs/inet86dz_defconfig @@ -21,6 +21,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-inet86dz" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_CONS_INDEX=5 CONFIG_USB_MUSB_HOST=y diff --git a/configs/inet97fv2_defconfig b/configs/inet97fv2_defconfig index 2b43142bc6..5a40e689a6 100644 --- a/configs/inet97fv2_defconfig +++ b/configs/inet97fv2_defconfig @@ -19,5 +19,6 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-inet97fv2" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_USB_MUSB_HOST=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/inet98v_rev2_defconfig b/configs/inet98v_rev2_defconfig index 76baeec5f2..d72cc0be98 100644 --- a/configs/inet98v_rev2_defconfig +++ b/configs/inet98v_rev2_defconfig @@ -21,6 +21,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-inet-98v-rev2" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_CONS_INDEX=2 CONFIG_USB_MUSB_HOST=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/inet9f_rev03_defconfig b/configs/inet9f_rev03_defconfig index 771dc1fadf..1c74efa631 100644 --- a/configs/inet9f_rev03_defconfig +++ b/configs/inet9f_rev03_defconfig @@ -19,5 +19,6 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-inet9f-rev03" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_USB_MUSB_HOST=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/inet_q972_defconfig b/configs/inet_q972_defconfig index 4b26a926a6..03ec676d29 100644 --- a/configs/inet_q972_defconfig +++ b/configs/inet_q972_defconfig @@ -20,6 +20,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-inet-q972" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/j721e_evm_r5_defconfig b/configs/j721e_evm_r5_defconfig index b516f9d0e5..4296bf0a8d 100644 --- a/configs/j721e_evm_r5_defconfig +++ b/configs/j721e_evm_r5_defconfig @@ -22,7 +22,6 @@ CONFIG_SPL_TEXT_BASE=0x41c00000 CONFIG_SPL_STACK_R=y CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_EARLY_BSS=y -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_DM_MAILBOX=y CONFIG_SPL_DM_RESET=y diff --git a/configs/jesurun_q5_defconfig b/configs/jesurun_q5_defconfig index ab4a2718de..ff27cd0421 100644 --- a/configs/jesurun_q5_defconfig +++ b/configs/jesurun_q5_defconfig @@ -14,6 +14,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-jesurun-q5" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_MII=y CONFIG_SUN4I_EMAC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/jetson-tk1_defconfig b/configs/jetson-tk1_defconfig index 14351bb5d5..13fefbadc8 100644 --- a/configs/jetson-tk1_defconfig +++ b/configs/jetson-tk1_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_LIVE=y CONFIG_DEFAULT_DEVICE_TREE="tegra124-jetson-tk1" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SPL_DM=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y diff --git a/configs/k2e_evm_defconfig b/configs/k2e_evm_defconfig index 260605533e..e8c5327186 100644 --- a/configs/k2e_evm_defconfig +++ b/configs/k2e_evm_defconfig @@ -38,6 +38,7 @@ CONFIG_DEFAULT_DEVICE_TREE="keystone-k2e-evm" CONFIG_DTB_RESELECT=y CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SYS_I2C_DAVINCI=y diff --git a/configs/k2g_evm_defconfig b/configs/k2g_evm_defconfig index 27804517fe..612f845357 100644 --- a/configs/k2g_evm_defconfig +++ b/configs/k2g_evm_defconfig @@ -38,6 +38,7 @@ CONFIG_OF_LIST="keystone-k2g-generic keystone-k2g-evm keystone-k2g-ice" CONFIG_DTB_RESELECT=y CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_DFU_MMC=y CONFIG_SYS_I2C_DAVINCI=y diff --git a/configs/k2hk_evm_defconfig b/configs/k2hk_evm_defconfig index 2d5f1934d0..272c121475 100644 --- a/configs/k2hk_evm_defconfig +++ b/configs/k2hk_evm_defconfig @@ -38,6 +38,7 @@ CONFIG_DEFAULT_DEVICE_TREE="keystone-k2hk-evm" CONFIG_DTB_RESELECT=y CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SYS_I2C_DAVINCI=y diff --git a/configs/k2l_evm_defconfig b/configs/k2l_evm_defconfig index b0898b0000..3c2128cb83 100644 --- a/configs/k2l_evm_defconfig +++ b/configs/k2l_evm_defconfig @@ -38,6 +38,7 @@ CONFIG_DEFAULT_DEVICE_TREE="keystone-k2l-evm" CONFIG_DTB_RESELECT=y CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SYS_I2C_DAVINCI=y diff --git a/configs/khadas-edge-captain-rk3399_defconfig b/configs/khadas-edge-captain-rk3399_defconfig index acfd91dbe7..cf598148a8 100644 --- a/configs/khadas-edge-captain-rk3399_defconfig +++ b/configs/khadas-edge-captain-rk3399_defconfig @@ -27,6 +27,8 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="rk3399-khadas-edge-captain" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y +CONFIG_TPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y diff --git a/configs/khadas-edge-rk3399_defconfig b/configs/khadas-edge-rk3399_defconfig index b71fd3a286..c74937ff16 100644 --- a/configs/khadas-edge-rk3399_defconfig +++ b/configs/khadas-edge-rk3399_defconfig @@ -27,6 +27,8 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="rk3399-khadas-edge" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y +CONFIG_TPL_ENV_IS_NOWHERE=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MMC_DW=y diff --git a/configs/khadas-edge-v-rk3399_defconfig b/configs/khadas-edge-v-rk3399_defconfig index 0a789872dc..a47e406f05 100644 --- a/configs/khadas-edge-v-rk3399_defconfig +++ b/configs/khadas-edge-v-rk3399_defconfig @@ -27,6 +27,8 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="rk3399-khadas-edge-v" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y +CONFIG_TPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y diff --git a/configs/koelsch_defconfig b/configs/koelsch_defconfig index 86c8dba9fe..d1f9fffa2c 100644 --- a/configs/koelsch_defconfig +++ b/configs/koelsch_defconfig @@ -55,6 +55,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=spi0.0:256k(u-boot-spl),512k(u-boot-env1),512k CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="r8a7791-koelsch-u-boot" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_CLK=y CONFIG_CLK_RENESAS=y CONFIG_DM_GPIO=y diff --git a/configs/kp_imx6q_tpc_defconfig b/configs/kp_imx6q_tpc_defconfig index 578e7010e5..04040fdb99 100644 --- a/configs/kp_imx6q_tpc_defconfig +++ b/configs/kp_imx6q_tpc_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_ISO_PARTITION is not set # CONFIG_EFI_PARTITION is not set CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_PHY_ATHEROS=y diff --git a/configs/kylin-rk3036_defconfig b/configs/kylin-rk3036_defconfig index c254d3e5cf..761a13c657 100644 --- a/configs/kylin-rk3036_defconfig +++ b/configs/kylin-rk3036_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_TIME=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="rk3036-sdk" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_REGMAP=y CONFIG_SYSCON=y # CONFIG_SPL_BLK is not set diff --git a/configs/lager_defconfig b/configs/lager_defconfig index 1d10b373e0..37e214efe5 100644 --- a/configs/lager_defconfig +++ b/configs/lager_defconfig @@ -55,6 +55,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=spi0.0:256k(u-boot-spl),512k(u-boot-env1),512k CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="r8a7790-lager-u-boot" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_CLK=y CONFIG_CLK_RENESAS=y CONFIG_DM_GPIO=y diff --git a/configs/libretech_all_h3_cc_h2_plus_defconfig b/configs/libretech_all_h3_cc_h2_plus_defconfig index d9c9b6de47..741fb75922 100644 --- a/configs/libretech_all_h3_cc_h2_plus_defconfig +++ b/configs/libretech_all_h3_cc_h2_plus_defconfig @@ -11,6 +11,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-h2-plus-libretech-all-h3-cc" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SUN8I_EMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/libretech_all_h3_cc_h3_defconfig b/configs/libretech_all_h3_cc_h3_defconfig index e99dc5c172..8c5d63d5ef 100644 --- a/configs/libretech_all_h3_cc_h3_defconfig +++ b/configs/libretech_all_h3_cc_h3_defconfig @@ -11,6 +11,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-libretech-all-h3-cc" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SUN8I_EMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/libretech_all_h3_cc_h5_defconfig b/configs/libretech_all_h3_cc_h5_defconfig index 088246d60b..7a45f690a4 100644 --- a/configs/libretech_all_h3_cc_h5_defconfig +++ b/configs/libretech_all_h3_cc_h5_defconfig @@ -11,6 +11,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun50i-h5-libretech-all-h3-cc" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SUN8I_EMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/lion-rk3368_defconfig b/configs/lion-rk3368_defconfig index 77dbb281f1..acd8c4fec8 100644 --- a/configs/lion-rk3368_defconfig +++ b/configs/lion-rk3368_defconfig @@ -50,6 +50,8 @@ CONFIG_DEFAULT_DEVICE_TREE="rk3368-lion" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names interrupt-parent" CONFIG_TPL_OF_PLATDATA=y CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y +CONFIG_TPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_TPL_DM=y CONFIG_REGMAP=y diff --git a/configs/liteboard_defconfig b/configs/liteboard_defconfig index 03a0e88635..34bae1fc58 100644 --- a/configs/liteboard_defconfig +++ b/configs/liteboard_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx6ul-liteboard" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM_GPIO=y CONFIG_DM_I2C=y diff --git a/configs/ls1021aiot_sdcard_defconfig b/configs/ls1021aiot_sdcard_defconfig index 93eb83471c..3698740e49 100644 --- a/configs/ls1021aiot_sdcard_defconfig +++ b/configs/ls1021aiot_sdcard_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-iot-duart" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y diff --git a/configs/ls1021aqds_nand_defconfig b/configs/ls1021aqds_nand_defconfig index 3e0075d08d..80e1e7be09 100644 --- a/configs/ls1021aqds_nand_defconfig +++ b/configs/ls1021aqds_nand_defconfig @@ -22,7 +22,6 @@ CONFIG_MISC_INIT_R=y CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_SPL_NAND_SUPPORT=y diff --git a/configs/ls1021aqds_sdcard_ifc_defconfig b/configs/ls1021aqds_sdcard_ifc_defconfig index daabf7680b..2c9de31b77 100644 --- a/configs/ls1021aqds_sdcard_ifc_defconfig +++ b/configs/ls1021aqds_sdcard_ifc_defconfig @@ -21,7 +21,6 @@ CONFIG_MISC_INIT_R=y CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y diff --git a/configs/ls1021aqds_sdcard_qspi_defconfig b/configs/ls1021aqds_sdcard_qspi_defconfig index cc71c28259..415f3af31d 100644 --- a/configs/ls1021aqds_sdcard_qspi_defconfig +++ b/configs/ls1021aqds_sdcard_qspi_defconfig @@ -21,7 +21,6 @@ CONFIG_MISC_INIT_R=y CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y diff --git a/configs/ls1021atsn_sdcard_defconfig b/configs/ls1021atsn_sdcard_defconfig index 77a105b319..924d636d6c 100644 --- a/configs/ls1021atsn_sdcard_defconfig +++ b/configs/ls1021atsn_sdcard_defconfig @@ -20,7 +20,6 @@ CONFIG_MISC_INIT_R=y CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y diff --git a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig index ad07a98440..782d988afa 100644 --- a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig @@ -27,7 +27,6 @@ CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 CONFIG_SPL_CRYPTO_SUPPORT=y CONFIG_SPL_HASH_SUPPORT=y -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y diff --git a/configs/ls1021atwr_sdcard_ifc_defconfig b/configs/ls1021atwr_sdcard_ifc_defconfig index 1a01e5fdbc..26bf03508b 100644 --- a/configs/ls1021atwr_sdcard_ifc_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_defconfig @@ -25,7 +25,6 @@ CONFIG_MISC_INIT_R=y CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y diff --git a/configs/ls1021atwr_sdcard_qspi_defconfig b/configs/ls1021atwr_sdcard_qspi_defconfig index 2dad37e6d7..d2160b45ea 100644 --- a/configs/ls1021atwr_sdcard_qspi_defconfig +++ b/configs/ls1021atwr_sdcard_qspi_defconfig @@ -25,7 +25,6 @@ CONFIG_MISC_INIT_R=y CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y diff --git a/configs/ls1043aqds_nand_defconfig b/configs/ls1043aqds_nand_defconfig index 10d08f8d6f..4d8da18fdf 100644 --- a/configs/ls1043aqds_nand_defconfig +++ b/configs/ls1043aqds_nand_defconfig @@ -22,7 +22,6 @@ CONFIG_MISC_INIT_R=y CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xf0 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_SPL_NAND_SUPPORT=y diff --git a/configs/ls1043aqds_sdcard_ifc_defconfig b/configs/ls1043aqds_sdcard_ifc_defconfig index 5ab5ef6545..31794e1b54 100644 --- a/configs/ls1043aqds_sdcard_ifc_defconfig +++ b/configs/ls1043aqds_sdcard_ifc_defconfig @@ -23,7 +23,6 @@ CONFIG_MISC_INIT_R=y CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xf0 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y diff --git a/configs/ls1043aqds_sdcard_qspi_defconfig b/configs/ls1043aqds_sdcard_qspi_defconfig index ecd30238af..26544a3561 100644 --- a/configs/ls1043aqds_sdcard_qspi_defconfig +++ b/configs/ls1043aqds_sdcard_qspi_defconfig @@ -23,7 +23,6 @@ CONFIG_MISC_INIT_R=y CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xf0 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y diff --git a/configs/ls1043ardb_nand_SECURE_BOOT_defconfig b/configs/ls1043ardb_nand_SECURE_BOOT_defconfig index 3e2ecf414a..970235be68 100644 --- a/configs/ls1043ardb_nand_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_nand_SECURE_BOOT_defconfig @@ -24,7 +24,6 @@ CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xf0 CONFIG_SPL_CRYPTO_SUPPORT=y CONFIG_SPL_HASH_SUPPORT=y -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y diff --git a/configs/ls1043ardb_nand_defconfig b/configs/ls1043ardb_nand_defconfig index 68865fa363..15c8da27f5 100644 --- a/configs/ls1043ardb_nand_defconfig +++ b/configs/ls1043ardb_nand_defconfig @@ -22,7 +22,6 @@ CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xf0 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_SPL_NAND_SUPPORT=y diff --git a/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig b/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig index 759d3703cd..c207100746 100644 --- a/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig @@ -24,7 +24,6 @@ CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x110 CONFIG_SPL_CRYPTO_SUPPORT=y CONFIG_SPL_HASH_SUPPORT=y -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_CMD_IMLS=y diff --git a/configs/ls1043ardb_sdcard_defconfig b/configs/ls1043ardb_sdcard_defconfig index ddfa7ca430..5620d2dfbd 100644 --- a/configs/ls1043ardb_sdcard_defconfig +++ b/configs/ls1043ardb_sdcard_defconfig @@ -22,7 +22,6 @@ CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xf0 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_CMD_IMLS=y diff --git a/configs/ls1046aqds_nand_defconfig b/configs/ls1046aqds_nand_defconfig index a6b6866a8a..83e582359d 100644 --- a/configs/ls1046aqds_nand_defconfig +++ b/configs/ls1046aqds_nand_defconfig @@ -38,6 +38,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=60000000.nor:2m@0x100000(nor_bank0_uboot),40m@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-qds-duart" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y diff --git a/configs/ls1046aqds_sdcard_ifc_defconfig b/configs/ls1046aqds_sdcard_ifc_defconfig index 77dc0b015b..a72019224d 100644 --- a/configs/ls1046aqds_sdcard_ifc_defconfig +++ b/configs/ls1046aqds_sdcard_ifc_defconfig @@ -24,7 +24,6 @@ CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x110 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y diff --git a/configs/ls1046aqds_sdcard_qspi_defconfig b/configs/ls1046aqds_sdcard_qspi_defconfig index 723a04f017..b9cbe53a5e 100644 --- a/configs/ls1046aqds_sdcard_qspi_defconfig +++ b/configs/ls1046aqds_sdcard_qspi_defconfig @@ -24,7 +24,6 @@ CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x110 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y diff --git a/configs/ls1046ardb_emmc_defconfig b/configs/ls1046ardb_emmc_defconfig index 855edc726e..c76efe7c79 100644 --- a/configs/ls1046ardb_emmc_defconfig +++ b/configs/ls1046ardb_emmc_defconfig @@ -24,7 +24,6 @@ CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x110 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y diff --git a/configs/ls1046ardb_qspi_spl_defconfig b/configs/ls1046ardb_qspi_spl_defconfig index 6326c47cdb..7b9fca0a8e 100644 --- a/configs/ls1046ardb_qspi_spl_defconfig +++ b/configs/ls1046ardb_qspi_spl_defconfig @@ -22,7 +22,6 @@ CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21 CONFIG_MISC_INIT_R=y CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SPL_BOARD_INIT=y -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_SPL_NOR_SUPPORT=y diff --git a/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig b/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig index 7bf23ad7fd..283bfdb0a4 100644 --- a/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig +++ b/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig @@ -24,7 +24,6 @@ CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x110 CONFIG_SPL_CRYPTO_SUPPORT=y CONFIG_SPL_HASH_SUPPORT=y -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y diff --git a/configs/ls1046ardb_sdcard_defconfig b/configs/ls1046ardb_sdcard_defconfig index 829861b03b..57d1629657 100644 --- a/configs/ls1046ardb_sdcard_defconfig +++ b/configs/ls1046ardb_sdcard_defconfig @@ -23,7 +23,6 @@ CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x110 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y diff --git a/configs/ls1088aqds_sdcard_ifc_defconfig b/configs/ls1088aqds_sdcard_ifc_defconfig index 58a6795b6d..150d66224e 100644 --- a/configs/ls1088aqds_sdcard_ifc_defconfig +++ b/configs/ls1088aqds_sdcard_ifc_defconfig @@ -21,7 +21,6 @@ CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_TEXT_BASE=0x1800a000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x8b0 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/ls1088aqds_sdcard_qspi_defconfig b/configs/ls1088aqds_sdcard_qspi_defconfig index 5b5cbfa5d6..8be88462f7 100644 --- a/configs/ls1088aqds_sdcard_qspi_defconfig +++ b/configs/ls1088aqds_sdcard_qspi_defconfig @@ -24,7 +24,6 @@ CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_TEXT_BASE=0x1800a000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x8b0 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_CMD_GREPENV=y diff --git a/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig b/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig index 3d531295ae..5ab90e85f8 100644 --- a/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig @@ -27,7 +27,6 @@ CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x8b0 CONFIG_SPL_CRYPTO_SUPPORT=y CONFIG_SPL_HASH_SUPPORT=y -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_CMD_GREPENV=y diff --git a/configs/ls1088ardb_sdcard_qspi_defconfig b/configs/ls1088ardb_sdcard_qspi_defconfig index 51b74e7c35..3938f37697 100644 --- a/configs/ls1088ardb_sdcard_qspi_defconfig +++ b/configs/ls1088ardb_sdcard_qspi_defconfig @@ -25,7 +25,6 @@ CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_TEXT_BASE=0x1800a000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x8b0 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_CMD_GREPENV=y diff --git a/configs/ls2080aqds_nand_defconfig b/configs/ls2080aqds_nand_defconfig index 3a3694107d..6a3ae0eda4 100644 --- a/configs/ls2080aqds_nand_defconfig +++ b/configs/ls2080aqds_nand_defconfig @@ -18,7 +18,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 ramdisk_size=0x2000000 default_hugepagesz=2m hugepagesz=2m hugepages=256" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SPL_TEXT_BASE=0x1800a000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_SPL_NAND_SUPPORT=y diff --git a/configs/ls2080aqds_sdcard_defconfig b/configs/ls2080aqds_sdcard_defconfig index 9d1715f03f..5d51756efe 100644 --- a/configs/ls2080aqds_sdcard_defconfig +++ b/configs/ls2080aqds_sdcard_defconfig @@ -22,7 +22,6 @@ CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21 CONFIG_SPL_TEXT_BASE=0x1800a000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x8b0 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_CMD_GREPENV=y diff --git a/configs/ls2080ardb_nand_defconfig b/configs/ls2080ardb_nand_defconfig index 56b78feab2..174af9e51b 100644 --- a/configs/ls2080ardb_nand_defconfig +++ b/configs/ls2080ardb_nand_defconfig @@ -19,7 +19,6 @@ CONFIG_BOOTARGS="console=ttyS1,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21 # CONFIG_USE_BOOTCOMMAND is not set CONFIG_MISC_INIT_R=y CONFIG_SPL_TEXT_BASE=0x1800a000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_SPL_NAND_SUPPORT=y diff --git a/configs/m53menlo_defconfig b/configs/m53menlo_defconfig index 6d7a3dde9f..901c4a1278 100644 --- a/configs/m53menlo_defconfig +++ b/configs/m53menlo_defconfig @@ -56,6 +56,7 @@ CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx53-m53menlo" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 diff --git a/configs/maxbcm_defconfig b/configs/maxbcm_defconfig index 54f2c14aa0..3065d2eb23 100644 --- a/configs/maxbcm_defconfig +++ b/configs/maxbcm_defconfig @@ -36,6 +36,7 @@ CONFIG_CMD_TIME=y CONFIG_DEFAULT_DEVICE_TREE="armada-xp-maxbcm" CONFIG_USE_ENV_SPI_MAX_HZ=y CONFIG_ENV_SPI_MAX_HZ=50000000 +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SPL_OF_TRANSLATE=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y diff --git a/configs/mccmon6_nor_defconfig b/configs/mccmon6_nor_defconfig index 66f49c0e54..43fb9f87bc 100644 --- a/configs/mccmon6_nor_defconfig +++ b/configs/mccmon6_nor_defconfig @@ -14,7 +14,6 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/liebherr/mccmon6/mon6_imximage_nor.cf CONFIG_BOUNCE_BUFFER=y CONFIG_SPL_TEXT_BASE=0x00908000 CONFIG_SPL_BOARD_INIT=y -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_NOR_SUPPORT=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y diff --git a/configs/mccmon6_sd_defconfig b/configs/mccmon6_sd_defconfig index 501eaf6942..ffd5347cb2 100644 --- a/configs/mccmon6_sd_defconfig +++ b/configs/mccmon6_sd_defconfig @@ -15,7 +15,6 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/liebherr/mccmon6/mon6_imximage_sd.cfg CONFIG_BOUNCE_BUFFER=y CONFIG_SPL_TEXT_BASE=0x00908000 CONFIG_SPL_BOARD_INIT=y -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_NOR_SUPPORT=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y diff --git a/configs/medcom-wide_defconfig b/configs/medcom-wide_defconfig index ee9044ee7a..eb568b9ac8 100644 --- a/configs/medcom-wide_defconfig +++ b/configs/medcom-wide_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="tegra20-medcom-wide" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SPL_DM=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y diff --git a/configs/miqi-rk3288_defconfig b/configs/miqi-rk3288_defconfig index 1fee1be58a..eb2c749df7 100644 --- a/configs/miqi-rk3288_defconfig +++ b/configs/miqi-rk3288_defconfig @@ -38,6 +38,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="rk3288-miqi" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y diff --git a/configs/mixtile_loftq_defconfig b/configs/mixtile_loftq_defconfig index 04d2426361..b699827f81 100644 --- a/configs/mixtile_loftq_defconfig +++ b/configs/mixtile_loftq_defconfig @@ -14,6 +14,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-mixtile-loftq" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_ETH_DESIGNWARE=y CONFIG_RGMII=y CONFIG_MII=y diff --git a/configs/mk802_a10s_defconfig b/configs/mk802_a10s_defconfig index 396879015e..5ddc65f24c 100644 --- a/configs/mk802_a10s_defconfig +++ b/configs/mk802_a10s_defconfig @@ -13,6 +13,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun5i-a10s-mk802" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_AXP152_POWER=y CONFIG_CONS_INDEX=2 CONFIG_USB_EHCI_HCD=y diff --git a/configs/mk802_defconfig b/configs/mk802_defconfig index 416cb9a9c2..fa82171229 100644 --- a/configs/mk802_defconfig +++ b/configs/mk802_defconfig @@ -10,6 +10,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-mk802" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SUNXI_NO_PMIC=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/mk802ii_defconfig b/configs/mk802ii_defconfig index 221c2bc88b..8538b235db 100644 --- a/configs/mk802ii_defconfig +++ b/configs/mk802ii_defconfig @@ -10,6 +10,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-mk802ii" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/mx23_olinuxino_defconfig b/configs/mx23_olinuxino_defconfig index fd045ad162..e77381555d 100644 --- a/configs/mx23_olinuxino_defconfig +++ b/configs/mx23_olinuxino_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_MXS_GPIO=y CONFIG_LED_STATUS=y CONFIG_LED_STATUS_GPIO=y diff --git a/configs/mx23evk_defconfig b/configs/mx23evk_defconfig index bb04623a8f..13432035a0 100644 --- a/configs/mx23evk_defconfig +++ b/configs/mx23evk_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y # CONFIG_NET is not set CONFIG_MXS_GPIO=y CONFIG_MMC_MXS=y diff --git a/configs/mx28evk_auart_console_defconfig b/configs/mx28evk_auart_console_defconfig index d7909e2fa9..e3a0c75a5e 100644 --- a/configs/mx28evk_auart_console_defconfig +++ b/configs/mx28evk_auart_console_defconfig @@ -38,6 +38,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=gpmi-nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:3m(bootloader)ro,512k(environment),512k(redundant-environment),4m(kernel),512k(fdt),8m(ramdisk),-(filesystem)" CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_MXS_GPIO=y CONFIG_MMC_MXS=y CONFIG_NAND=y diff --git a/configs/mx28evk_defconfig b/configs/mx28evk_defconfig index 7f000c8c38..d5cfe5c9b3 100644 --- a/configs/mx28evk_defconfig +++ b/configs/mx28evk_defconfig @@ -38,6 +38,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=gpmi-nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:3m(bootloader)ro,512k(environment),512k(redundant-environment),4m(kernel),512k(fdt),8m(ramdisk),-(filesystem)" CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_MXS_GPIO=y CONFIG_MMC_MXS=y CONFIG_NAND=y diff --git a/configs/mx28evk_nand_defconfig b/configs/mx28evk_nand_defconfig index 248d8b1fc9..1f7b6da3e7 100644 --- a/configs/mx28evk_nand_defconfig +++ b/configs/mx28evk_nand_defconfig @@ -37,6 +37,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=gpmi-nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:3m(bootloader)ro,512k(environment),512k(redundant-environment),4m(kernel),512k(fdt),8m(ramdisk),-(filesystem)" CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_MXS_GPIO=y CONFIG_MMC_MXS=y CONFIG_NAND=y diff --git a/configs/mx31pdk_defconfig b/configs/mx31pdk_defconfig index 7eb07e6413..f2c6211fe1 100644 --- a/configs/mx31pdk_defconfig +++ b/configs/mx31pdk_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_MXC_GPIO=y # CONFIG_MMC is not set CONFIG_NAND=y diff --git a/configs/mx6cuboxi_defconfig b/configs/mx6cuboxi_defconfig index 3d73734609..b4156b8ed3 100644 --- a/configs/mx6cuboxi_defconfig +++ b/configs/mx6cuboxi_defconfig @@ -33,6 +33,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_DWC_AHSATA=y CONFIG_FSL_USDHC=y diff --git a/configs/mx6sabreauto_defconfig b/configs/mx6sabreauto_defconfig index 516aac1f14..e02041187a 100644 --- a/configs/mx6sabreauto_defconfig +++ b/configs/mx6sabreauto_defconfig @@ -58,6 +58,7 @@ CONFIG_MULTI_DTB_FIT=y CONFIG_SPL_MULTI_DTB_FIT=y CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DFU_MMC=y CONFIG_DFU_SF=y CONFIG_DM_GPIO=y diff --git a/configs/mx6sabresd_defconfig b/configs/mx6sabresd_defconfig index 2c88fe67c2..e36c5826ed 100644 --- a/configs/mx6sabresd_defconfig +++ b/configs/mx6sabresd_defconfig @@ -66,6 +66,7 @@ CONFIG_SPL_OF_LIST="imx6dl-sabresd imx6q-sabresd imx6qp-sabresd" CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 CONFIG_FASTBOOT_BUF_SIZE=0x10000000 diff --git a/configs/mx6slevk_spl_defconfig b/configs/mx6slevk_spl_defconfig index 9b3f2252de..c2273c09e9 100644 --- a/configs/mx6slevk_spl_defconfig +++ b/configs/mx6slevk_spl_defconfig @@ -39,6 +39,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx6sl-evk" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_DM_GPIO=y CONFIG_DM_I2C=y diff --git a/configs/mx6sxsabresd_spl_defconfig b/configs/mx6sxsabresd_spl_defconfig index 82093af750..c9f2e5c315 100644 --- a/configs/mx6sxsabresd_spl_defconfig +++ b/configs/mx6sxsabresd_spl_defconfig @@ -44,6 +44,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx6sx-sdb" CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y diff --git a/configs/mx6ul_14x14_evk_defconfig b/configs/mx6ul_14x14_evk_defconfig index c848c530a8..f5813388b7 100644 --- a/configs/mx6ul_14x14_evk_defconfig +++ b/configs/mx6ul_14x14_evk_defconfig @@ -41,6 +41,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx6ul-14x14-evk" CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y diff --git a/configs/mx6ul_9x9_evk_defconfig b/configs/mx6ul_9x9_evk_defconfig index 274fec0e58..5c5006eaa0 100644 --- a/configs/mx6ul_9x9_evk_defconfig +++ b/configs/mx6ul_9x9_evk_defconfig @@ -41,6 +41,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx6ul-9x9-evk" CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y diff --git a/configs/nanopc-t4-rk3399_defconfig b/configs/nanopc-t4-rk3399_defconfig index 1d4c8f8a02..c02f6929e1 100644 --- a/configs/nanopc-t4-rk3399_defconfig +++ b/configs/nanopc-t4-rk3399_defconfig @@ -26,6 +26,8 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="rk3399-nanopc-t4" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y +CONFIG_TPL_ENV_IS_NOWHERE=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MMC_DW=y diff --git a/configs/nanopi-m4-rk3399_defconfig b/configs/nanopi-m4-rk3399_defconfig index 7375b758a2..8a2149a326 100644 --- a/configs/nanopi-m4-rk3399_defconfig +++ b/configs/nanopi-m4-rk3399_defconfig @@ -26,6 +26,8 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="rk3399-nanopi-m4" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y +CONFIG_TPL_ENV_IS_NOWHERE=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MMC_DW=y diff --git a/configs/nanopi-neo4-rk3399_defconfig b/configs/nanopi-neo4-rk3399_defconfig index 874ee5efb6..b590f0b3e9 100644 --- a/configs/nanopi-neo4-rk3399_defconfig +++ b/configs/nanopi-neo4-rk3399_defconfig @@ -26,6 +26,8 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="rk3399-nanopi-neo4" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y +CONFIG_TPL_ENV_IS_NOWHERE=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MMC_DW=y diff --git a/configs/nanopi_a64_defconfig b/configs/nanopi_a64_defconfig index 95a9c965f7..dc7c4305ba 100644 --- a/configs/nanopi_a64_defconfig +++ b/configs/nanopi_a64_defconfig @@ -10,6 +10,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-nanopi-a64" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SUN8I_EMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/nanopi_m1_defconfig b/configs/nanopi_m1_defconfig index 7568fb1b4b..dcef11b4e1 100644 --- a/configs/nanopi_m1_defconfig +++ b/configs/nanopi_m1_defconfig @@ -10,6 +10,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-nanopi-m1" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/nanopi_m1_plus_defconfig b/configs/nanopi_m1_plus_defconfig index a359de8069..a21c21f43d 100644 --- a/configs/nanopi_m1_plus_defconfig +++ b/configs/nanopi_m1_plus_defconfig @@ -13,6 +13,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-nanopi-m1-plus" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SUN8I_EMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/nanopi_neo2_defconfig b/configs/nanopi_neo2_defconfig index cfda325442..1a21d86644 100644 --- a/configs/nanopi_neo2_defconfig +++ b/configs/nanopi_neo2_defconfig @@ -12,6 +12,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun50i-h5-nanopi-neo2" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SUN8I_EMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/nanopi_neo_air_defconfig b/configs/nanopi_neo_air_defconfig index 246658b699..f4d2d59e38 100644 --- a/configs/nanopi_neo_air_defconfig +++ b/configs/nanopi_neo_air_defconfig @@ -12,6 +12,7 @@ CONFIG_CONSOLE_MUX=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-nanopi-neo-air" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/nanopi_neo_defconfig b/configs/nanopi_neo_defconfig index fba6ff516d..8e4481da81 100644 --- a/configs/nanopi_neo_defconfig +++ b/configs/nanopi_neo_defconfig @@ -12,6 +12,7 @@ CONFIG_CONSOLE_MUX=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-nanopi-neo" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SUN8I_EMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/nanopi_neo_plus2_defconfig b/configs/nanopi_neo_plus2_defconfig index 5f78a8b63a..e3dba8f850 100644 --- a/configs/nanopi_neo_plus2_defconfig +++ b/configs/nanopi_neo_plus2_defconfig @@ -14,6 +14,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun50i-h5-nanopi-neo-plus2" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SUN8I_EMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/novena_defconfig b/configs/novena_defconfig index c928b258b1..81dde8a3c2 100644 --- a/configs/novena_defconfig +++ b/configs/novena_defconfig @@ -45,6 +45,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx6q-novena" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_DWC_AHSATA=y CONFIG_DM_GPIO=y diff --git a/configs/nyan-big_defconfig b/configs/nyan-big_defconfig index ac7b505dc7..ee35cee891 100644 --- a/configs/nyan-big_defconfig +++ b/configs/nyan-big_defconfig @@ -45,6 +45,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_LIVE=y CONFIG_DEFAULT_DEVICE_TREE="tegra124-nyan-big" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SPL_DM=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y diff --git a/configs/oceanic_5205_5inmfd_defconfig b/configs/oceanic_5205_5inmfd_defconfig index 854ada3ee2..a5257688c1 100644 --- a/configs/oceanic_5205_5inmfd_defconfig +++ b/configs/oceanic_5205_5inmfd_defconfig @@ -16,6 +16,7 @@ CONFIG_SYS_SPI_U_BOOT_OFFS=0x8000 # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-oceanic-5205-5inmfd" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SUN8I_EMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/omap35_logic_defconfig b/configs/omap35_logic_defconfig index bd1b1605c0..7148678e82 100644 --- a/configs/omap35_logic_defconfig +++ b/configs/omap35_logic_defconfig @@ -42,6 +42,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="logicpd-torpedo-35xx-devkit" # CONFIG_ENV_IS_IN_FAT is not set CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SPL_DM=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_DM_I2C=y diff --git a/configs/omap35_logic_somlv_defconfig b/configs/omap35_logic_somlv_defconfig index 8ed962c255..5caa45edd8 100644 --- a/configs/omap35_logic_somlv_defconfig +++ b/configs/omap35_logic_somlv_defconfig @@ -42,6 +42,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="logicpd-som-lv-35xx-devkit" # CONFIG_ENV_IS_IN_FAT is not set CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SPL_DM=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y diff --git a/configs/omap3_beagle_defconfig b/configs/omap3_beagle_defconfig index 44bfd5e0d4..24c9f52451 100644 --- a/configs/omap3_beagle_defconfig +++ b/configs/omap3_beagle_defconfig @@ -47,6 +47,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="omap3-beagle" CONFIG_OF_SPL_REMOVE_PROPS="clocks clock-names interrupt-parent" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SPL_OF_TRANSLATE=y diff --git a/configs/omap3_evm_defconfig b/configs/omap3_evm_defconfig index 9763b6aca1..8f58a702cf 100644 --- a/configs/omap3_evm_defconfig +++ b/configs/omap3_evm_defconfig @@ -45,6 +45,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="omap3-evm" CONFIG_OF_SPL_REMOVE_PROPS="clocks clock-names interrupt-parent" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SPL_OF_TRANSLATE=y diff --git a/configs/omap3_ha_defconfig b/configs/omap3_ha_defconfig index 49229ec1f7..37bc447b6c 100644 --- a/configs/omap3_ha_defconfig +++ b/configs/omap3_ha_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand0=nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=nand:512k(x-loader),1920k(u-boot),128k(u-boot-env),4m(kernel),-(fs)" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_TWL4030_LED=y CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y diff --git a/configs/omap3_logic_defconfig b/configs/omap3_logic_defconfig index 278ce2c2a3..266e043c06 100644 --- a/configs/omap3_logic_defconfig +++ b/configs/omap3_logic_defconfig @@ -41,6 +41,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="logicpd-torpedo-37xx-devkit" # CONFIG_ENV_IS_IN_FAT is not set CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SPL_DM=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y diff --git a/configs/omap3_logic_somlv_defconfig b/configs/omap3_logic_somlv_defconfig index d93ec395d0..39d474b197 100644 --- a/configs/omap3_logic_somlv_defconfig +++ b/configs/omap3_logic_somlv_defconfig @@ -42,6 +42,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="logicpd-som-lv-37xx-devkit" # CONFIG_ENV_IS_IN_FAT is not set CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SPL_DM=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y diff --git a/configs/omap3_overo_defconfig b/configs/omap3_overo_defconfig index 59867914cb..913ace5067 100644 --- a/configs/omap3_overo_defconfig +++ b/configs/omap3_overo_defconfig @@ -34,6 +34,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=omap2-nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=omap2-nand.0:512k(xloader),1792k(u-boot),256k(environ),8m(linux),-(rootfs)" CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_TWL4030_LED=y CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y diff --git a/configs/omap4_panda_defconfig b/configs/omap4_panda_defconfig index 806b7a5241..c7e4127f9c 100644 --- a/configs/omap4_panda_defconfig +++ b/configs/omap4_panda_defconfig @@ -28,6 +28,7 @@ CONFIG_ENV_IS_IN_FAT=y CONFIG_ENV_FAT_INTERFACE="mmc" CONFIG_ENV_FAT_DEVICE_AND_PART="0:1" CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_MMC_OMAP_HS=y CONFIG_CONS_INDEX=3 CONFIG_SYS_NS16550=y diff --git a/configs/omap4_sdp4430_defconfig b/configs/omap4_sdp4430_defconfig index 7f251acd94..f065b05166 100644 --- a/configs/omap4_sdp4430_defconfig +++ b/configs/omap4_sdp4430_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_EFI_PARTITION is not set CONFIG_SPL_PARTITION_UUIDS=y CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_MMC_OMAP_HS=y CONFIG_CONS_INDEX=3 CONFIG_SYS_NS16550=y diff --git a/configs/omapl138_lcdk_defconfig b/configs/omapl138_lcdk_defconfig index d2342c37cf..4299425be8 100644 --- a/configs/omapl138_lcdk_defconfig +++ b/configs/omapl138_lcdk_defconfig @@ -37,6 +37,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="da850-lcdk" CONFIG_SPL_OF_PLATDATA=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SPL_DM=y diff --git a/configs/opos6uldev_defconfig b/configs/opos6uldev_defconfig index 1b68b8e12f..0e42e555bf 100644 --- a/configs/opos6uldev_defconfig +++ b/configs/opos6uldev_defconfig @@ -25,7 +25,6 @@ CONFIG_VERSION_VARIABLE=y CONFIG_BOUNCE_BUFFER=y CONFIG_SPL_TEXT_BASE=0x00908000 CONFIG_SPL_BOARD_INIT=y -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/orangepi-rk3399_defconfig b/configs/orangepi-rk3399_defconfig index 7b02c59f08..df3ffe6e0f 100644 --- a/configs/orangepi-rk3399_defconfig +++ b/configs/orangepi-rk3399_defconfig @@ -26,6 +26,8 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="rk3399-orangepi" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y +CONFIG_TPL_ENV_IS_NOWHERE=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MMC_DW=y diff --git a/configs/orangepi_2_defconfig b/configs/orangepi_2_defconfig index 664b4b3541..fc0d322928 100644 --- a/configs/orangepi_2_defconfig +++ b/configs/orangepi_2_defconfig @@ -13,6 +13,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-2" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SUN8I_EMAC=y CONFIG_SY8106A_POWER=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/orangepi_lite2_defconfig b/configs/orangepi_lite2_defconfig index 0d6101fc68..b4700347f2 100644 --- a/configs/orangepi_lite2_defconfig +++ b/configs/orangepi_lite2_defconfig @@ -12,5 +12,6 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun50i-h6-orangepi-lite2" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/orangepi_lite_defconfig b/configs/orangepi_lite_defconfig index 5638c4a3a6..dc1a9108d8 100644 --- a/configs/orangepi_lite_defconfig +++ b/configs/orangepi_lite_defconfig @@ -10,6 +10,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-lite" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/orangepi_one_defconfig b/configs/orangepi_one_defconfig index 4fe81f8ab9..a2a3cb2747 100644 --- a/configs/orangepi_one_defconfig +++ b/configs/orangepi_one_defconfig @@ -10,6 +10,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-one" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SUN8I_EMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/orangepi_one_plus_defconfig b/configs/orangepi_one_plus_defconfig index 890e6abd45..dac981d9dd 100644 --- a/configs/orangepi_one_plus_defconfig +++ b/configs/orangepi_one_plus_defconfig @@ -12,5 +12,6 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun50i-h6-orangepi-one-plus" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/orangepi_pc2_defconfig b/configs/orangepi_pc2_defconfig index ba0f2d562b..a76de44b4d 100644 --- a/configs/orangepi_pc2_defconfig +++ b/configs/orangepi_pc2_defconfig @@ -15,6 +15,7 @@ CONFIG_SYS_SPI_U_BOOT_OFFS=0x8000 # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun50i-h5-orangepi-pc2" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SUN8I_EMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/orangepi_pc_defconfig b/configs/orangepi_pc_defconfig index 6ac46649c9..4205d8904d 100644 --- a/configs/orangepi_pc_defconfig +++ b/configs/orangepi_pc_defconfig @@ -11,6 +11,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-pc" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SUN8I_EMAC=y CONFIG_SY8106A_POWER=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/orangepi_pc_plus_defconfig b/configs/orangepi_pc_plus_defconfig index 685b577a31..8d10c6133b 100644 --- a/configs/orangepi_pc_plus_defconfig +++ b/configs/orangepi_pc_plus_defconfig @@ -12,6 +12,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-pc-plus" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SUN8I_EMAC=y CONFIG_SY8106A_POWER=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/orangepi_plus2e_defconfig b/configs/orangepi_plus2e_defconfig index 79da5ce235..66fa98ca7d 100644 --- a/configs/orangepi_plus2e_defconfig +++ b/configs/orangepi_plus2e_defconfig @@ -13,6 +13,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-plus2e" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SUN8I_EMAC=y CONFIG_SY8106A_POWER=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/orangepi_plus_defconfig b/configs/orangepi_plus_defconfig index 808f937b1d..7899f559ec 100644 --- a/configs/orangepi_plus_defconfig +++ b/configs/orangepi_plus_defconfig @@ -15,6 +15,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-plus" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SUN8I_EMAC=y CONFIG_SY8106A_POWER=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/orangepi_prime_defconfig b/configs/orangepi_prime_defconfig index d7b80040de..89efc9a555 100644 --- a/configs/orangepi_prime_defconfig +++ b/configs/orangepi_prime_defconfig @@ -12,6 +12,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun50i-h5-orangepi-prime" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SUN8I_EMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/orangepi_r1_defconfig b/configs/orangepi_r1_defconfig index e0a530d4b8..4f8b376fc5 100644 --- a/configs/orangepi_r1_defconfig +++ b/configs/orangepi_r1_defconfig @@ -12,6 +12,7 @@ CONFIG_CONSOLE_MUX=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x8000 # CONFIG_CMD_FLASH is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-h2-plus-orangepi-r1" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SUN8I_EMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/orangepi_win_defconfig b/configs/orangepi_win_defconfig index 28395031b7..dd9626d914 100644 --- a/configs/orangepi_win_defconfig +++ b/configs/orangepi_win_defconfig @@ -12,6 +12,7 @@ CONFIG_SYS_SPI_U_BOOT_OFFS=0x8000 # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-orangepi-win" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SUN8I_EMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/orangepi_zero_defconfig b/configs/orangepi_zero_defconfig index f8dda05c08..fc14e83e75 100644 --- a/configs/orangepi_zero_defconfig +++ b/configs/orangepi_zero_defconfig @@ -12,6 +12,7 @@ CONFIG_CONSOLE_MUX=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x8000 # CONFIG_CMD_FLASH is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-h2-plus-orangepi-zero" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SUN8I_EMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/orangepi_zero_plus2_defconfig b/configs/orangepi_zero_plus2_defconfig index 7cfb39dcdf..80e8d67e77 100644 --- a/configs/orangepi_zero_plus2_defconfig +++ b/configs/orangepi_zero_plus2_defconfig @@ -14,6 +14,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun50i-h5-orangepi-zero-plus2" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SUN8I_EMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/orangepi_zero_plus_defconfig b/configs/orangepi_zero_plus_defconfig index c63b70f20c..de66cc21df 100644 --- a/configs/orangepi_zero_plus_defconfig +++ b/configs/orangepi_zero_plus_defconfig @@ -12,6 +12,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun50i-h5-orangepi-zero-plus" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SUN8I_EMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/origen_defconfig b/configs/origen_defconfig index d9e9931e91..b442d4ea7c 100644 --- a/configs/origen_defconfig +++ b/configs/origen_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="exynos4210-origen" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DFU_MMC=y CONFIG_MMC_DW=y CONFIG_MMC_SDHCI=y diff --git a/configs/ot1200_spl_defconfig b/configs/ot1200_spl_defconfig index 35bbbfd314..f0271b9d4e 100644 --- a/configs/ot1200_spl_defconfig +++ b/configs/ot1200_spl_defconfig @@ -40,6 +40,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_DWC_AHSATA=y CONFIG_CMD_PCA953X=y diff --git a/configs/parrot_r16_defconfig b/configs/parrot_r16_defconfig index d0ef1b6fa5..91eb78bf70 100644 --- a/configs/parrot_r16_defconfig +++ b/configs/parrot_r16_defconfig @@ -17,6 +17,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-r16-parrot" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_CONS_INDEX=5 CONFIG_USB_EHCI_HCD=y diff --git a/configs/paz00_defconfig b/configs/paz00_defconfig index 3b0ca3bc2d..3dc489e1f5 100644 --- a/configs/paz00_defconfig +++ b/configs/paz00_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="tegra20-paz00" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SPL_DM=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y diff --git a/configs/pcm051_rev1_defconfig b/configs/pcm051_rev1_defconfig index 17433768f7..845c7166ac 100644 --- a/configs/pcm051_rev1_defconfig +++ b/configs/pcm051_rev1_defconfig @@ -17,7 +17,6 @@ CONFIG_SYS_EXTRA_OPTIONS="REV1" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_ARCH_MISC_INIT=y -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_ETH_SUPPORT=y CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/pcm051_rev3_defconfig b/configs/pcm051_rev3_defconfig index d85e3fc8de..65c7aa689e 100644 --- a/configs/pcm051_rev3_defconfig +++ b/configs/pcm051_rev3_defconfig @@ -17,7 +17,6 @@ CONFIG_SYS_EXTRA_OPTIONS="REV3" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_ARCH_MISC_INIT=y -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_ETH_SUPPORT=y CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/pcm058_defconfig b/configs/pcm058_defconfig index 3a2b35f461..5d40bbcc8b 100644 --- a/configs/pcm058_defconfig +++ b/configs/pcm058_defconfig @@ -43,6 +43,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=nand:16m(uboot),1m(env),-(rootfs)" CONFIG_CMD_UBI=y # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_FSL_USDHC=y CONFIG_MTD=y diff --git a/configs/peach-pi_defconfig b/configs/peach-pi_defconfig index a4848d5c7b..4b88d37b1c 100644 --- a/configs/peach-pi_defconfig +++ b/configs/peach-pi_defconfig @@ -33,6 +33,7 @@ CONFIG_DEFAULT_DEVICE_TREE="exynos5800-peach-pi" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USE_ENV_SPI_BUS=y CONFIG_ENV_SPI_BUS=1 +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_I2C_CROS_EC_TUNNEL=y CONFIG_I2C_MUX=y CONFIG_I2C_ARB_GPIO_CHALLENGE=y diff --git a/configs/peach-pit_defconfig b/configs/peach-pit_defconfig index e3bca5f61a..6a59332bb7 100644 --- a/configs/peach-pit_defconfig +++ b/configs/peach-pit_defconfig @@ -32,6 +32,7 @@ CONFIG_DEFAULT_DEVICE_TREE="exynos5420-peach-pit" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USE_ENV_SPI_BUS=y CONFIG_ENV_SPI_BUS=1 +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_I2C_CROS_EC_TUNNEL=y CONFIG_I2C_MUX=y CONFIG_I2C_ARB_GPIO_CHALLENGE=y diff --git a/configs/pengwyn_defconfig b/configs/pengwyn_defconfig index bd7d0a6d8b..89f2cb08e6 100644 --- a/configs/pengwyn_defconfig +++ b/configs/pengwyn_defconfig @@ -17,7 +17,6 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_ARCH_MISC_INIT=y -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_ETH_SUPPORT=y CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/phycore-am335x-r2-wega_defconfig b/configs/phycore-am335x-r2-wega_defconfig index 43acb55c41..801dcde255 100644 --- a/configs/phycore-am335x-r2-wega_defconfig +++ b/configs/phycore-am335x-r2-wega_defconfig @@ -52,6 +52,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_ENV_FAT_INTERFACE="mmc" CONFIG_ENV_FAT_DEVICE_AND_PART="0:1" CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DM_I2C=y diff --git a/configs/phycore-rk3288_defconfig b/configs/phycore-rk3288_defconfig index 7cfbd50c1e..2a149b645f 100644 --- a/configs/phycore-rk3288_defconfig +++ b/configs/phycore-rk3288_defconfig @@ -41,6 +41,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="rk3288-phycore-rdk" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/pico-hobbit-imx6ul_defconfig b/configs/pico-hobbit-imx6ul_defconfig index 7395598599..9948617754 100644 --- a/configs/pico-hobbit-imx6ul_defconfig +++ b/configs/pico-hobbit-imx6ul_defconfig @@ -36,6 +36,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx6ul-pico-hobbit" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DFU_MMC=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_SIZE=0x10000000 diff --git a/configs/pico-hobbit-imx7d_defconfig b/configs/pico-hobbit-imx7d_defconfig index 3869eb70cc..3441346a52 100644 --- a/configs/pico-hobbit-imx7d_defconfig +++ b/configs/pico-hobbit-imx7d_defconfig @@ -42,6 +42,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx7d-pico-hobbit" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DFU_MMC=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x82000000 diff --git a/configs/pico-imx6ul_defconfig b/configs/pico-imx6ul_defconfig index ad29af1b71..7d6e0913d0 100644 --- a/configs/pico-imx6ul_defconfig +++ b/configs/pico-imx6ul_defconfig @@ -38,6 +38,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx6ul-pico-hobbit" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DFU_MMC=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_SIZE=0x10000000 diff --git a/configs/pico-imx7d_bl33_defconfig b/configs/pico-imx7d_bl33_defconfig index a2cddfcf4f..ccf7a4618b 100644 --- a/configs/pico-imx7d_bl33_defconfig +++ b/configs/pico-imx7d_bl33_defconfig @@ -39,6 +39,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx7d-pico-pi" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DFU_MMC=y CONFIG_DM_GPIO=y diff --git a/configs/pico-imx7d_defconfig b/configs/pico-imx7d_defconfig index 3d45872a84..261862f7e8 100644 --- a/configs/pico-imx7d_defconfig +++ b/configs/pico-imx7d_defconfig @@ -42,6 +42,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx7d-pico-pi" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DFU_MMC=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x82000000 diff --git a/configs/pico-pi-imx6ul_defconfig b/configs/pico-pi-imx6ul_defconfig index 1a8a4541c6..5558ebd689 100644 --- a/configs/pico-pi-imx6ul_defconfig +++ b/configs/pico-pi-imx6ul_defconfig @@ -36,6 +36,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx6ul-pico-pi" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DFU_MMC=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_SIZE=0x10000000 diff --git a/configs/pico-pi-imx7d_defconfig b/configs/pico-pi-imx7d_defconfig index b864b537c3..d9c3366a52 100644 --- a/configs/pico-pi-imx7d_defconfig +++ b/configs/pico-pi-imx7d_defconfig @@ -42,6 +42,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx7d-pico-pi" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DFU_MMC=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x82000000 diff --git a/configs/picosam9g45_defconfig b/configs/picosam9g45_defconfig index abae023915..1bda5d2511 100644 --- a/configs/picosam9g45_defconfig +++ b/configs/picosam9g45_defconfig @@ -37,6 +37,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FAT=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_USB=y diff --git a/configs/pine64-lts_defconfig b/configs/pine64-lts_defconfig index 283c1dcdf3..9ffb7f1952 100644 --- a/configs/pine64-lts_defconfig +++ b/configs/pine64-lts_defconfig @@ -16,6 +16,7 @@ CONFIG_SYS_SPI_U_BOOT_OFFS=0x8000 # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-pine64-lts" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SUN8I_EMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/pine64_plus_defconfig b/configs/pine64_plus_defconfig index a7ea1bcc89..d83685002f 100644 --- a/configs/pine64_plus_defconfig +++ b/configs/pine64_plus_defconfig @@ -12,6 +12,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-pine64-plus" CONFIG_OF_LIST="sun50i-a64-pine64 sun50i-a64-pine64-plus" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_PHY_REALTEK=y CONFIG_RTL8211E_PINE64_GIGABIT_FIX=y CONFIG_SUN8I_EMAC=y diff --git a/configs/pine_h64_defconfig b/configs/pine_h64_defconfig index c840ca0a18..a5bd59fd29 100644 --- a/configs/pine_h64_defconfig +++ b/configs/pine_h64_defconfig @@ -14,5 +14,6 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun50i-h6-pine-h64" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/pinebook_defconfig b/configs/pinebook_defconfig index 1ed907df7a..c2049e41de 100644 --- a/configs/pinebook_defconfig +++ b/configs/pinebook_defconfig @@ -12,6 +12,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-pinebook" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_PWM=y diff --git a/configs/platinum_picon_defconfig b/configs/platinum_picon_defconfig index 886ddacba2..2a1b034e70 100644 --- a/configs/platinum_picon_defconfig +++ b/configs/platinum_picon_defconfig @@ -48,6 +48,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=gpmi-nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:14M(spl),2M(uboot),512k(env1),512k(env2),495M(ubi0),14M(res0),2M(res1),512k(res2),512k(res3),-(ubi1)" CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_FSL_USDHC=y CONFIG_NAND=y CONFIG_NAND_MXS=y diff --git a/configs/platinum_titanium_defconfig b/configs/platinum_titanium_defconfig index 2367a17dd1..6e17d35ddd 100644 --- a/configs/platinum_titanium_defconfig +++ b/configs/platinum_titanium_defconfig @@ -48,6 +48,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=gpmi-nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:14M(spl),2M(uboot),512k(env1),512k(env2),-(ubi)" CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_FSL_USDHC=y CONFIG_NAND=y CONFIG_NAND_MXS=y diff --git a/configs/plutux_defconfig b/configs/plutux_defconfig index 8ac0d40d61..f74285e6e1 100644 --- a/configs/plutux_defconfig +++ b/configs/plutux_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="tegra20-plutux" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SPL_DM=y CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/polaroid_mid2407pxe03_defconfig b/configs/polaroid_mid2407pxe03_defconfig index 012e1f2434..bc714e457c 100644 --- a/configs/polaroid_mid2407pxe03_defconfig +++ b/configs/polaroid_mid2407pxe03_defconfig @@ -21,6 +21,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-polaroid-mid2407pxe03" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_CONS_INDEX=5 CONFIG_USB_MUSB_HOST=y diff --git a/configs/polaroid_mid2809pxe04_defconfig b/configs/polaroid_mid2809pxe04_defconfig index 3564ddc9a1..216fc9d88f 100644 --- a/configs/polaroid_mid2809pxe04_defconfig +++ b/configs/polaroid_mid2809pxe04_defconfig @@ -21,6 +21,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-polaroid-mid2809pxe04" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_CONS_INDEX=5 CONFIG_USB_MUSB_HOST=y diff --git a/configs/popmetal-rk3288_defconfig b/configs/popmetal-rk3288_defconfig index efa20d0800..bc4e4d5fa2 100644 --- a/configs/popmetal-rk3288_defconfig +++ b/configs/popmetal-rk3288_defconfig @@ -39,6 +39,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="rk3288-popmetal" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/porter_defconfig b/configs/porter_defconfig index 8c802b0d19..4806cbadba 100644 --- a/configs/porter_defconfig +++ b/configs/porter_defconfig @@ -55,6 +55,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=spi0.0:256k(u-boot-spl),512k(u-boot-env1),512k CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="r8a7791-porter-u-boot" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_CLK=y CONFIG_CLK_RENESAS=y CONFIG_DM_GPIO=y diff --git a/configs/pov_protab2_ips9_defconfig b/configs/pov_protab2_ips9_defconfig index 0b6bf6dfd8..6f382bc102 100644 --- a/configs/pov_protab2_ips9_defconfig +++ b/configs/pov_protab2_ips9_defconfig @@ -20,5 +20,6 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-pov-protab2-ips9" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_USB_MUSB_HOST=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/puma-rk3399_defconfig b/configs/puma-rk3399_defconfig index faf95c5505..546af40cd1 100644 --- a/configs/puma-rk3399_defconfig +++ b/configs/puma-rk3399_defconfig @@ -44,6 +44,7 @@ CONFIG_OF_LIVE=y CONFIG_DEFAULT_DEVICE_TREE="rk3399-puma-ddr1600" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MISC=y diff --git a/configs/pxm2_defconfig b/configs/pxm2_defconfig index 201b9c9357..9056a8e1e7 100644 --- a/configs/pxm2_defconfig +++ b/configs/pxm2_defconfig @@ -61,6 +61,7 @@ CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="am335x-pxm50" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_ENV=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 diff --git a/configs/q8_a13_tablet_defconfig b/configs/q8_a13_tablet_defconfig index 4933e6f861..5fced244d3 100644 --- a/configs/q8_a13_tablet_defconfig +++ b/configs/q8_a13_tablet_defconfig @@ -21,6 +21,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-q8-tablet" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_CONS_INDEX=2 CONFIG_USB_MUSB_HOST=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/q8_a23_tablet_800x480_defconfig b/configs/q8_a23_tablet_800x480_defconfig index 59683190cc..c0b0013edf 100644 --- a/configs/q8_a23_tablet_800x480_defconfig +++ b/configs/q8_a23_tablet_800x480_defconfig @@ -21,6 +21,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-q8-tablet" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_CONS_INDEX=5 CONFIG_USB_MUSB_HOST=y diff --git a/configs/q8_a33_tablet_1024x600_defconfig b/configs/q8_a33_tablet_1024x600_defconfig index 05a82c41f8..cbce8e7666 100644 --- a/configs/q8_a33_tablet_1024x600_defconfig +++ b/configs/q8_a33_tablet_1024x600_defconfig @@ -21,6 +21,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-q8-tablet" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_CONS_INDEX=5 CONFIG_USB_MUSB_HOST=y diff --git a/configs/q8_a33_tablet_800x480_defconfig b/configs/q8_a33_tablet_800x480_defconfig index 94a680ce8b..7558fcea7a 100644 --- a/configs/q8_a33_tablet_800x480_defconfig +++ b/configs/q8_a33_tablet_800x480_defconfig @@ -21,6 +21,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-q8-tablet" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_CONS_INDEX=5 CONFIG_USB_MUSB_HOST=y diff --git a/configs/qemu-riscv32_smode_defconfig b/configs/qemu-riscv32_smode_defconfig index 7103324421..c1c3434131 100644 --- a/configs/qemu-riscv32_smode_defconfig +++ b/configs/qemu-riscv32_smode_defconfig @@ -9,3 +9,4 @@ CONFIG_DISPLAY_BOARDINFO=y CONFIG_CMD_BOOTEFI_SELFTEST=y # CONFIG_CMD_MII is not set CONFIG_OF_PRIOR_STAGE=y +CONFIG_SPL_ENV_IS_IN_NAND=y diff --git a/configs/qemu-x86_64_defconfig b/configs/qemu-x86_64_defconfig index e735ba8675..0709372e6b 100644 --- a/configs/qemu-x86_64_defconfig +++ b/configs/qemu-x86_64_defconfig @@ -27,7 +27,6 @@ CONFIG_LAST_STAGE_INIT=y CONFIG_SPL_TEXT_BASE=0xfffd0000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_CPU_SUPPORT=y -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_NET_SUPPORT=y CONFIG_SPL_PCI=y CONFIG_SPL_PCH_SUPPORT=y diff --git a/configs/r7-tv-dongle_defconfig b/configs/r7-tv-dongle_defconfig index b7d738526d..1aa2901410 100644 --- a/configs/r7-tv-dongle_defconfig +++ b/configs/r7-tv-dongle_defconfig @@ -12,6 +12,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun5i-a10s-r7-tv-dongle" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_AXP152_POWER=y CONFIG_CONS_INDEX=2 CONFIG_USB_EHCI_HCD=y diff --git a/configs/r8a7795_salvator-x_defconfig b/configs/r8a7795_salvator-x_defconfig index a33338a69f..2158902521 100644 --- a/configs/r8a7795_salvator-x_defconfig +++ b/configs/r8a7795_salvator-x_defconfig @@ -34,6 +34,7 @@ CONFIG_OF_LIST="r8a7795-salvator-x-u-boot r8a7796-salvator-x-u-boot r8a77965-sal CONFIG_MULTI_DTB_FIT_LZO=y CONFIG_MULTI_DTB_FIT_USER_DEFINED_AREA=y CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_CLK=y diff --git a/configs/r8a7795_ulcb_defconfig b/configs/r8a7795_ulcb_defconfig index 5fa760c057..6be1c6f7ca 100644 --- a/configs/r8a7795_ulcb_defconfig +++ b/configs/r8a7795_ulcb_defconfig @@ -34,6 +34,7 @@ CONFIG_OF_LIST="r8a7795-h3ulcb-u-boot r8a7796-m3ulcb-u-boot r8a77965-m3nulcb-u-b CONFIG_MULTI_DTB_FIT_LZO=y CONFIG_MULTI_DTB_FIT_USER_DEFINED_AREA=y CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_CLK=y diff --git a/configs/r8a77965_salvator-x_defconfig b/configs/r8a77965_salvator-x_defconfig index 14a10f0865..7e7c044eff 100644 --- a/configs/r8a77965_salvator-x_defconfig +++ b/configs/r8a77965_salvator-x_defconfig @@ -35,6 +35,7 @@ CONFIG_OF_LIST="r8a7795-salvator-x-u-boot r8a7796-salvator-x-u-boot r8a77965-sal CONFIG_MULTI_DTB_FIT_LZO=y CONFIG_MULTI_DTB_FIT_USER_DEFINED_AREA=y CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_CLK=y diff --git a/configs/r8a77965_ulcb_defconfig b/configs/r8a77965_ulcb_defconfig index d9b83c5abd..ff89be16ae 100644 --- a/configs/r8a77965_ulcb_defconfig +++ b/configs/r8a77965_ulcb_defconfig @@ -34,6 +34,7 @@ CONFIG_OF_LIST="r8a7795-h3ulcb-u-boot r8a7796-m3ulcb-u-boot r8a77965-m3nulcb-u-b CONFIG_MULTI_DTB_FIT_LZO=y CONFIG_MULTI_DTB_FIT_USER_DEFINED_AREA=y CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_CLK=y diff --git a/configs/r8a7796_salvator-x_defconfig b/configs/r8a7796_salvator-x_defconfig index d909aeb2b9..5aeb5feb45 100644 --- a/configs/r8a7796_salvator-x_defconfig +++ b/configs/r8a7796_salvator-x_defconfig @@ -35,6 +35,7 @@ CONFIG_OF_LIST="r8a7795-salvator-x-u-boot r8a7796-salvator-x-u-boot r8a77965-sal CONFIG_MULTI_DTB_FIT_LZO=y CONFIG_MULTI_DTB_FIT_USER_DEFINED_AREA=y CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_CLK=y diff --git a/configs/r8a7796_ulcb_defconfig b/configs/r8a7796_ulcb_defconfig index 54495394ef..af063405b2 100644 --- a/configs/r8a7796_ulcb_defconfig +++ b/configs/r8a7796_ulcb_defconfig @@ -34,6 +34,7 @@ CONFIG_OF_LIST="r8a7795-h3ulcb-u-boot r8a7796-m3ulcb-u-boot r8a77965-m3nulcb-u-b CONFIG_MULTI_DTB_FIT_LZO=y CONFIG_MULTI_DTB_FIT_USER_DEFINED_AREA=y CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_CLK=y diff --git a/configs/r8a77970_eagle_defconfig b/configs/r8a77970_eagle_defconfig index 6a5de19b22..80b85ba1b0 100644 --- a/configs/r8a77970_eagle_defconfig +++ b/configs/r8a77970_eagle_defconfig @@ -32,6 +32,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="r8a77970-eagle-u-boot" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_BLK=y diff --git a/configs/r8a77980_condor_defconfig b/configs/r8a77980_condor_defconfig index f3c7948328..de0ee38631 100644 --- a/configs/r8a77980_condor_defconfig +++ b/configs/r8a77980_condor_defconfig @@ -32,6 +32,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="r8a77980-condor-u-boot" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_BLK=y diff --git a/configs/r8a77990_ebisu_defconfig b/configs/r8a77990_ebisu_defconfig index 7fd513483c..8b063d54ee 100644 --- a/configs/r8a77990_ebisu_defconfig +++ b/configs/r8a77990_ebisu_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="r8a77990-ebisu-u-boot" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_CLK=y diff --git a/configs/r8a77995_draak_defconfig b/configs/r8a77995_draak_defconfig index 8e54013560..7de184020c 100644 --- a/configs/r8a77995_draak_defconfig +++ b/configs/r8a77995_draak_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="r8a77995-draak-u-boot" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_CLK=y diff --git a/configs/rastaban_defconfig b/configs/rastaban_defconfig index 452e761412..6751b17cec 100644 --- a/configs/rastaban_defconfig +++ b/configs/rastaban_defconfig @@ -59,6 +59,7 @@ CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="am335x-draco" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_ENV=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 diff --git a/configs/riotboard_spl_defconfig b/configs/riotboard_spl_defconfig index cf3647a8f1..8e80fc1693 100644 --- a/configs/riotboard_spl_defconfig +++ b/configs/riotboard_spl_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_FSL_USDHC=y diff --git a/configs/roc-rk3399-pc_defconfig b/configs/roc-rk3399-pc_defconfig index 28b18333d7..73324d762c 100644 --- a/configs/roc-rk3399-pc_defconfig +++ b/configs/roc-rk3399-pc_defconfig @@ -26,6 +26,8 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="rk3399-roc-pc" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y +CONFIG_TPL_ENV_IS_NOWHERE=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MMC_DW=y diff --git a/configs/rock-pi-4-rk3399_defconfig b/configs/rock-pi-4-rk3399_defconfig index 554945dd19..9259278bbf 100644 --- a/configs/rock-pi-4-rk3399_defconfig +++ b/configs/rock-pi-4-rk3399_defconfig @@ -27,6 +27,8 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="rk3399-rock-pi-4" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y +CONFIG_TPL_ENV_IS_NOWHERE=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MMC_DW=y diff --git a/configs/rock2_defconfig b/configs/rock2_defconfig index 9d5f3b59e8..3477cb015d 100644 --- a/configs/rock2_defconfig +++ b/configs/rock2_defconfig @@ -38,6 +38,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="rk3288-rock2-square" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y diff --git a/configs/rock64-rk3328_defconfig b/configs/rock64-rk3328_defconfig index 3ab0af1158..68960e9aeb 100644 --- a/configs/rock64-rk3328_defconfig +++ b/configs/rock64-rk3328_defconfig @@ -39,6 +39,8 @@ CONFIG_DEFAULT_DEVICE_TREE="rk3328-rock64" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_TPL_OF_PLATDATA=y CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y +CONFIG_TPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_TPL_DM=y CONFIG_REGMAP=y diff --git a/configs/rock960-rk3399_defconfig b/configs/rock960-rk3399_defconfig index abcc53fc8e..6aa8d17dbf 100644 --- a/configs/rock960-rk3399_defconfig +++ b/configs/rock960-rk3399_defconfig @@ -28,6 +28,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="rk3399-rock960" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MMC_DW=y diff --git a/configs/rock_defconfig b/configs/rock_defconfig index d5a57d6544..a76983229d 100644 --- a/configs/rock_defconfig +++ b/configs/rock_defconfig @@ -32,6 +32,7 @@ CONFIG_DEFAULT_DEVICE_TREE="rk3188-radxarock" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_SPL_OF_PLATDATA=y CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_REGMAP=y CONFIG_SYSCON=y # CONFIG_SPL_SIMPLE_BUS is not set diff --git a/configs/rockpro64-rk3399_defconfig b/configs/rockpro64-rk3399_defconfig index 40ebad5abb..194b00fcdb 100644 --- a/configs/rockpro64-rk3399_defconfig +++ b/configs/rockpro64-rk3399_defconfig @@ -26,6 +26,8 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="rk3399-rockpro64" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y +CONFIG_TPL_ENV_IS_NOWHERE=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MMC_DW=y diff --git a/configs/rut_defconfig b/configs/rut_defconfig index ec31d52377..c3cb51fe65 100644 --- a/configs/rut_defconfig +++ b/configs/rut_defconfig @@ -62,6 +62,7 @@ CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="am335x-rut" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_ENV=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 diff --git a/configs/sama5d27_som1_ek_mmc1_defconfig b/configs/sama5d27_som1_ek_mmc1_defconfig index 29d364ce17..7e9b7b9bc8 100644 --- a/configs/sama5d27_som1_ek_mmc1_defconfig +++ b/configs/sama5d27_som1_ek_mmc1_defconfig @@ -47,6 +47,7 @@ CONFIG_DEFAULT_DEVICE_TREE="at91-sama5d27_som1_ek" CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dmas dma-names" CONFIG_ENV_IS_IN_FAT=y CONFIG_ENV_FAT_DEVICE_AND_PART="1" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/sama5d27_som1_ek_mmc_defconfig b/configs/sama5d27_som1_ek_mmc_defconfig index bb74c63993..14a84d77fc 100644 --- a/configs/sama5d27_som1_ek_mmc_defconfig +++ b/configs/sama5d27_som1_ek_mmc_defconfig @@ -47,6 +47,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91-sama5d27_som1_ek" CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dmas dma-names" CONFIG_ENV_IS_IN_FAT=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/sama5d27_som1_ek_qspiflash_defconfig b/configs/sama5d27_som1_ek_qspiflash_defconfig index 50b7983850..8ae919f85d 100644 --- a/configs/sama5d27_som1_ek_qspiflash_defconfig +++ b/configs/sama5d27_som1_ek_qspiflash_defconfig @@ -47,6 +47,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91-sama5d27_som1_ek" CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dmas dma-names" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/sama5d2_icp_mmc_defconfig b/configs/sama5d2_icp_mmc_defconfig index 535aab5a12..99794e7263 100644 --- a/configs/sama5d2_icp_mmc_defconfig +++ b/configs/sama5d2_icp_mmc_defconfig @@ -47,6 +47,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91-sama5d2_icp" CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dmas dma-names" CONFIG_ENV_IS_IN_FAT=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/sama5d2_xplained_emmc_defconfig b/configs/sama5d2_xplained_emmc_defconfig index 92d7c5e9cf..10e2a81c8c 100644 --- a/configs/sama5d2_xplained_emmc_defconfig +++ b/configs/sama5d2_xplained_emmc_defconfig @@ -46,6 +46,7 @@ CONFIG_DEFAULT_DEVICE_TREE="at91-sama5d2_xplained" CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dmas dma-names" CONFIG_ENV_IS_IN_FAT=y CONFIG_ENV_FAT_DEVICE_AND_PART="0:1" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/sama5d2_xplained_mmc_defconfig b/configs/sama5d2_xplained_mmc_defconfig index 43990336fa..796aab6998 100644 --- a/configs/sama5d2_xplained_mmc_defconfig +++ b/configs/sama5d2_xplained_mmc_defconfig @@ -48,6 +48,7 @@ CONFIG_DEFAULT_DEVICE_TREE="at91-sama5d2_xplained" CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dmas dma-names" CONFIG_ENV_IS_IN_FAT=y CONFIG_ENV_FAT_DEVICE_AND_PART="1:1" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/sama5d2_xplained_qspiflash_defconfig b/configs/sama5d2_xplained_qspiflash_defconfig index f24dac6c4f..1176f38cea 100644 --- a/configs/sama5d2_xplained_qspiflash_defconfig +++ b/configs/sama5d2_xplained_qspiflash_defconfig @@ -47,6 +47,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91-sama5d2_xplained" CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dmas dma-names" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/sama5d2_xplained_spiflash_defconfig b/configs/sama5d2_xplained_spiflash_defconfig index 6958621cdf..59bcb348e6 100644 --- a/configs/sama5d2_xplained_spiflash_defconfig +++ b/configs/sama5d2_xplained_spiflash_defconfig @@ -48,6 +48,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91-sama5d2_xplained" CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dmas dma-names" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/sama5d3_xplained_mmc_defconfig b/configs/sama5d3_xplained_mmc_defconfig index ebd3a402ac..3b17658b8e 100644 --- a/configs/sama5d3_xplained_mmc_defconfig +++ b/configs/sama5d3_xplained_mmc_defconfig @@ -50,6 +50,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91-sama5d3_xplained" CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dmas dma-names" CONFIG_ENV_IS_IN_FAT=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/sama5d3_xplained_nandflash_defconfig b/configs/sama5d3_xplained_nandflash_defconfig index 2ebba96c23..1ba71293d5 100644 --- a/configs/sama5d3_xplained_nandflash_defconfig +++ b/configs/sama5d3_xplained_nandflash_defconfig @@ -45,6 +45,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91-sama5d3_xplained" CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dmas dma-names" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/sama5d3xek_mmc_defconfig b/configs/sama5d3xek_mmc_defconfig index 86b375f7cc..9b009cec0f 100644 --- a/configs/sama5d3xek_mmc_defconfig +++ b/configs/sama5d3xek_mmc_defconfig @@ -52,6 +52,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sama5d36ek" CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dmas dma-names" CONFIG_ENV_IS_IN_FAT=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/sama5d3xek_nandflash_defconfig b/configs/sama5d3xek_nandflash_defconfig index 120461add3..1d482d3803 100644 --- a/configs/sama5d3xek_nandflash_defconfig +++ b/configs/sama5d3xek_nandflash_defconfig @@ -46,6 +46,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sama5d36ek" CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dmas dma-names" CONFIG_ENV_IS_IN_NAND=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/sama5d3xek_spiflash_defconfig b/configs/sama5d3xek_spiflash_defconfig index b27a288b4a..1a44777119 100644 --- a/configs/sama5d3xek_spiflash_defconfig +++ b/configs/sama5d3xek_spiflash_defconfig @@ -50,6 +50,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sama5d36ek" CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dmas dma-names" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/sama5d4_xplained_mmc_defconfig b/configs/sama5d4_xplained_mmc_defconfig index f9d7389613..a32e9219fb 100644 --- a/configs/sama5d4_xplained_mmc_defconfig +++ b/configs/sama5d4_xplained_mmc_defconfig @@ -45,6 +45,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91-sama5d4_xplained" CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dma-names dmas" CONFIG_ENV_IS_IN_FAT=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_CLK=y diff --git a/configs/sama5d4_xplained_nandflash_defconfig b/configs/sama5d4_xplained_nandflash_defconfig index d25cd615d6..5e64c0f1fd 100644 --- a/configs/sama5d4_xplained_nandflash_defconfig +++ b/configs/sama5d4_xplained_nandflash_defconfig @@ -41,6 +41,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91-sama5d4_xplained" CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dma-names dmas" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_CLK=y diff --git a/configs/sama5d4_xplained_spiflash_defconfig b/configs/sama5d4_xplained_spiflash_defconfig index a2e9595088..84a62f4c61 100644 --- a/configs/sama5d4_xplained_spiflash_defconfig +++ b/configs/sama5d4_xplained_spiflash_defconfig @@ -47,6 +47,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91-sama5d4_xplained" CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dma-names dmas" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/sama5d4ek_mmc_defconfig b/configs/sama5d4ek_mmc_defconfig index 711de5572a..31f9bfac6c 100644 --- a/configs/sama5d4ek_mmc_defconfig +++ b/configs/sama5d4ek_mmc_defconfig @@ -47,6 +47,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91-sama5d4ek" CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dma-names dmas" CONFIG_ENV_IS_IN_FAT=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/sama5d4ek_nandflash_defconfig b/configs/sama5d4ek_nandflash_defconfig index 7b1f44c451..86f8d67d2e 100644 --- a/configs/sama5d4ek_nandflash_defconfig +++ b/configs/sama5d4ek_nandflash_defconfig @@ -43,6 +43,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91-sama5d4ek" CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dma-names dmas" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/sama5d4ek_spiflash_defconfig b/configs/sama5d4ek_spiflash_defconfig index aa1a492997..f726fb936e 100644 --- a/configs/sama5d4ek_spiflash_defconfig +++ b/configs/sama5d4ek_spiflash_defconfig @@ -47,6 +47,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91-sama5d4ek" CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dma-names dmas" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/sandbox_spl_defconfig b/configs/sandbox_spl_defconfig index 0b3391a2a6..b82a39f73c 100644 --- a/configs/sandbox_spl_defconfig +++ b/configs/sandbox_spl_defconfig @@ -23,7 +23,6 @@ CONFIG_SILENT_CONSOLE=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_HANDOFF=y CONFIG_SPL_BOARD_INIT=y -CONFIG_SPL_ENV_SUPPORT=y CONFIG_CMD_CPU=y CONFIG_CMD_LICENSE=y CONFIG_CMD_BOOTZ=y diff --git a/configs/sc_sps_1_defconfig b/configs/sc_sps_1_defconfig index e3fd8be605..40afb1e810 100644 --- a/configs/sc_sps_1_defconfig +++ b/configs/sc_sps_1_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_MXS_GPIO=y CONFIG_MMC_MXS=y CONFIG_PHYLIB=y diff --git a/configs/seaboard_defconfig b/configs/seaboard_defconfig index efc8586e8b..a1bb250a13 100644 --- a/configs/seaboard_defconfig +++ b/configs/seaboard_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="tegra20-seaboard" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SPL_DM=y CONFIG_SYS_I2C_TEGRA=y CONFIG_TEGRA_KEYBOARD=y diff --git a/configs/sh7752evb_defconfig b/configs/sh7752evb_defconfig index d9fa1ca57f..271279a319 100644 --- a/configs/sh7752evb_defconfig +++ b/configs/sh7752evb_defconfig @@ -34,3 +34,4 @@ CONFIG_SH_ETHER=y CONFIG_SCIF_CONSOLE=y CONFIG_SPI=y CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_SPL_ENV_IS_IN_MMC=y diff --git a/configs/silk_defconfig b/configs/silk_defconfig index 64a01651ac..b169b4a3fc 100644 --- a/configs/silk_defconfig +++ b/configs/silk_defconfig @@ -55,6 +55,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=spi0.0:256k(u-boot-spl),512k(u-boot-env1),512k CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="r8a7794-silk-u-boot" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_CLK=y CONFIG_CLK_RENESAS=y CONFIG_DM_GPIO=y diff --git a/configs/sksimx6_defconfig b/configs/sksimx6_defconfig index 7bc687f64d..1a441344f9 100644 --- a/configs/sksimx6_defconfig +++ b/configs/sksimx6_defconfig @@ -32,6 +32,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y diff --git a/configs/smartweb_defconfig b/configs/smartweb_defconfig index 9e73051def..9720207b93 100644 --- a/configs/smartweb_defconfig +++ b/configs/smartweb_defconfig @@ -43,6 +43,7 @@ CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9260-smartweb" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_CLK=y CONFIG_CLK_AT91=y CONFIG_DFU_NAND=y diff --git a/configs/smdk5250_defconfig b/configs/smdk5250_defconfig index 6c7eb9315c..40fd402521 100644 --- a/configs/smdk5250_defconfig +++ b/configs/smdk5250_defconfig @@ -34,6 +34,7 @@ CONFIG_DEFAULT_DEVICE_TREE="exynos5250-smdk5250" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USE_ENV_SPI_BUS=y CONFIG_ENV_SPI_BUS=1 +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_MMC_DW=y CONFIG_MMC_SDHCI=y diff --git a/configs/smdk5420_defconfig b/configs/smdk5420_defconfig index 714c9636cd..aac1a53e3b 100644 --- a/configs/smdk5420_defconfig +++ b/configs/smdk5420_defconfig @@ -29,6 +29,7 @@ CONFIG_DEFAULT_DEVICE_TREE="exynos5420-smdk5420" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USE_ENV_SPI_BUS=y CONFIG_ENV_SPI_BUS=1 +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_MMC_DW=y CONFIG_MMC_SDHCI=y diff --git a/configs/smdkv310_defconfig b/configs/smdkv310_defconfig index 880867fdca..6a8cb41d66 100644 --- a/configs/smdkv310_defconfig +++ b/configs/smdkv310_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_CACHE=y # CONFIG_CMD_MISC is not set CONFIG_CMD_EXT4_WRITE=y CONFIG_DEFAULT_DEVICE_TREE="exynos4210-smdkv310" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_MMC_DW=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y diff --git a/configs/snow_defconfig b/configs/snow_defconfig index e4d3703e00..73f4289906 100644 --- a/configs/snow_defconfig +++ b/configs/snow_defconfig @@ -38,6 +38,7 @@ CONFIG_DEFAULT_DEVICE_TREE="exynos5250-snow" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USE_ENV_SPI_BUS=y CONFIG_ENV_SPI_BUS=1 +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_I2C_CROS_EC_LDO=y CONFIG_I2C_MUX=y CONFIG_I2C_ARB_GPIO_CHALLENGE=y diff --git a/configs/socfpga_arria10_defconfig b/configs/socfpga_arria10_defconfig index 69e492accc..adb9d0ed01 100644 --- a/configs/socfpga_arria10_defconfig +++ b/configs/socfpga_arria10_defconfig @@ -17,7 +17,6 @@ CONFIG_DEFAULT_FDT_FILE="socfpga_arria10_socdk_sdmmc.dtb" CONFIG_VERSION_VARIABLE=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_TEXT_BASE=0xFFE00000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_FPGA_SUPPORT=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/socfpga_arria5_defconfig b/configs/socfpga_arria5_defconfig index 89e5ff8c71..41d68ebd5a 100644 --- a/configs/socfpga_arria5_defconfig +++ b/configs/socfpga_arria5_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_UBI=y # CONFIG_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="socfpga_arria5_socdk" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_MMC=y CONFIG_DM_GPIO=y diff --git a/configs/socfpga_cyclone5_defconfig b/configs/socfpga_cyclone5_defconfig index 00f2104276..71c79780bb 100644 --- a/configs/socfpga_cyclone5_defconfig +++ b/configs/socfpga_cyclone5_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_UBI=y # CONFIG_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_socdk" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_MMC=y CONFIG_DM_GPIO=y diff --git a/configs/socfpga_dbm_soc1_defconfig b/configs/socfpga_dbm_soc1_defconfig index 1877010a19..48d1bbb6e7 100644 --- a/configs/socfpga_dbm_soc1_defconfig +++ b/configs/socfpga_dbm_soc1_defconfig @@ -38,6 +38,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_dbm_soc1" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DFU_MMC=y CONFIG_DM_GPIO=y CONFIG_DWAPB_GPIO=y diff --git a/configs/socfpga_de0_nano_soc_defconfig b/configs/socfpga_de0_nano_soc_defconfig index de50f17174..4407782501 100644 --- a/configs/socfpga_de0_nano_soc_defconfig +++ b/configs/socfpga_de0_nano_soc_defconfig @@ -35,6 +35,7 @@ CONFIG_CMD_UBI=y # CONFIG_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_de0_nano_soc" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DFU_MMC=y CONFIG_DM_GPIO=y CONFIG_DWAPB_GPIO=y diff --git a/configs/socfpga_de10_nano_defconfig b/configs/socfpga_de10_nano_defconfig index 03961195ac..eba360bb24 100644 --- a/configs/socfpga_de10_nano_defconfig +++ b/configs/socfpga_de10_nano_defconfig @@ -31,6 +31,7 @@ CONFIG_MTDIDS_DEFAULT="nor0=ff705000.spi.0" # CONFIG_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_de10_nano" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DFU_MMC=y CONFIG_DM_GPIO=y CONFIG_DWAPB_GPIO=y diff --git a/configs/socfpga_de1_soc_defconfig b/configs/socfpga_de1_soc_defconfig index cb52b6ab07..38d66b56f0 100644 --- a/configs/socfpga_de1_soc_defconfig +++ b/configs/socfpga_de1_soc_defconfig @@ -30,6 +30,7 @@ CONFIG_MTDIDS_DEFAULT="nor0=ff705000.spi.0" # CONFIG_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_de1_soc" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM_GPIO=y CONFIG_DWAPB_GPIO=y CONFIG_DM_I2C=y diff --git a/configs/socfpga_is1_defconfig b/configs/socfpga_is1_defconfig index 6ea06c1104..a6236ff4d7 100644 --- a/configs/socfpga_is1_defconfig +++ b/configs/socfpga_is1_defconfig @@ -33,6 +33,7 @@ CONFIG_CMD_UBI=y # CONFIG_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_is1" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_DM_GPIO=y diff --git a/configs/socfpga_mcvevk_defconfig b/configs/socfpga_mcvevk_defconfig index 161bd6fca3..eea779154a 100644 --- a/configs/socfpga_mcvevk_defconfig +++ b/configs/socfpga_mcvevk_defconfig @@ -35,6 +35,7 @@ CONFIG_CMD_UBI=y # CONFIG_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_mcvevk" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DFU_MMC=y CONFIG_DM_GPIO=y CONFIG_DWAPB_GPIO=y diff --git a/configs/socfpga_sockit_defconfig b/configs/socfpga_sockit_defconfig index 8ec1c05571..525b2b8ed6 100644 --- a/configs/socfpga_sockit_defconfig +++ b/configs/socfpga_sockit_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_UBI=y # CONFIG_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_sockit" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_MMC=y CONFIG_DM_GPIO=y diff --git a/configs/socfpga_socrates_defconfig b/configs/socfpga_socrates_defconfig index 15f81d1a4b..840792559f 100644 --- a/configs/socfpga_socrates_defconfig +++ b/configs/socfpga_socrates_defconfig @@ -35,6 +35,7 @@ CONFIG_CMD_UBI=y # CONFIG_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_socrates" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_MMC=y CONFIG_DM_GPIO=y diff --git a/configs/socfpga_sr1500_defconfig b/configs/socfpga_sr1500_defconfig index 941bf1124a..1511633c6f 100644 --- a/configs/socfpga_sr1500_defconfig +++ b/configs/socfpga_sr1500_defconfig @@ -36,6 +36,7 @@ CONFIG_CMD_UBI=y # CONFIG_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_sr1500" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_DM_GPIO=y diff --git a/configs/socfpga_stratix10_defconfig b/configs/socfpga_stratix10_defconfig index ad83f50032..5981a7ab17 100644 --- a/configs/socfpga_stratix10_defconfig +++ b/configs/socfpga_stratix10_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="socfpga_stratix10_socdk" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SPL_ALTERA_SDRAM=y diff --git a/configs/socfpga_vining_fpga_defconfig b/configs/socfpga_vining_fpga_defconfig index 96f806ab5f..7043c73179 100644 --- a/configs/socfpga_vining_fpga_defconfig +++ b/configs/socfpga_vining_fpga_defconfig @@ -41,6 +41,7 @@ CONFIG_CMD_UBI=y # CONFIG_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_vining_fpga" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_MMC=y diff --git a/configs/sopine_baseboard_defconfig b/configs/sopine_baseboard_defconfig index 5833234b63..041ee6628a 100644 --- a/configs/sopine_baseboard_defconfig +++ b/configs/sopine_baseboard_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_SPI_U_BOOT_OFFS=0x8000 # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-sopine-baseboard" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SUN8I_EMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/spring_defconfig b/configs/spring_defconfig index bdbfc64b4c..ee40d01873 100644 --- a/configs/spring_defconfig +++ b/configs/spring_defconfig @@ -38,6 +38,7 @@ CONFIG_DEFAULT_DEVICE_TREE="exynos5250-spring" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USE_ENV_SPI_BUS=y CONFIG_ENV_SPI_BUS=1 +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_I2C_CROS_EC_LDO=y CONFIG_I2C_MUX=y CONFIG_I2C_ARB_GPIO_CHALLENGE=y diff --git a/configs/stout_defconfig b/configs/stout_defconfig index 309709f6c5..3097ac8d93 100644 --- a/configs/stout_defconfig +++ b/configs/stout_defconfig @@ -55,6 +55,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=spi0.0:256k(u-boot-spl),512k(u-boot-env1),512k CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="r8a7790-stout-u-boot" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_CLK=y CONFIG_CLK_RENESAS=y CONFIG_DM_GPIO=y diff --git a/configs/sun8i_a23_evb_defconfig b/configs/sun8i_a23_evb_defconfig index 34cbb1e0c1..19a7b26054 100644 --- a/configs/sun8i_a23_evb_defconfig +++ b/configs/sun8i_a23_evb_defconfig @@ -14,6 +14,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-evb" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_CONS_INDEX=5 CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/sunxi_Gemei_G9_defconfig b/configs/sunxi_Gemei_G9_defconfig index f3d77f1cd1..6a32137f97 100644 --- a/configs/sunxi_Gemei_G9_defconfig +++ b/configs/sunxi_Gemei_G9_defconfig @@ -17,6 +17,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-gemei-g9" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/tao3530_defconfig b/configs/tao3530_defconfig index f752e92d28..75dde4b680 100644 --- a/configs/tao3530_defconfig +++ b/configs/tao3530_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand0=nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=nand:512k(x-loader),1920k(u-boot),128k(u-boot-env),4m(kernel),-(fs)" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_TWL4030_LED=y CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y diff --git a/configs/taurus_defconfig b/configs/taurus_defconfig index 3676ecd419..97cba43dfd 100644 --- a/configs/taurus_defconfig +++ b/configs/taurus_defconfig @@ -59,6 +59,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9g20-taurus" CONFIG_SPL_OF_PLATDATA=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SPL_DM=y CONFIG_BLK=y CONFIG_CLK=y diff --git a/configs/tbs_a711_defconfig b/configs/tbs_a711_defconfig index 196c4ce400..33dcbb3496 100644 --- a/configs/tbs_a711_defconfig +++ b/configs/tbs_a711_defconfig @@ -18,6 +18,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-a83t-tbs-a711" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_AXP_DCDC5_VOLT=1200 CONFIG_USB_EHCI_HCD=y diff --git a/configs/tec-ng_defconfig b/configs/tec-ng_defconfig index 513e301710..e193d09c99 100644 --- a/configs/tec-ng_defconfig +++ b/configs/tec-ng_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="tegra30-tec-ng" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SPL_DM=y CONFIG_SYS_I2C_TEGRA=y CONFIG_SPI_FLASH=y diff --git a/configs/tec_defconfig b/configs/tec_defconfig index ab92b8429a..79ebc36db6 100644 --- a/configs/tec_defconfig +++ b/configs/tec_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="tegra20-tec" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SPL_DM=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y diff --git a/configs/teres_i_defconfig b/configs/teres_i_defconfig index cfd696f8a3..cf1f261b73 100644 --- a/configs/teres_i_defconfig +++ b/configs/teres_i_defconfig @@ -12,6 +12,7 @@ CONFIG_USE_PREBOOT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-teres-i" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_PWM=y diff --git a/configs/theadorable_debug_defconfig b/configs/theadorable_debug_defconfig index b88a922678..333c6cbd60 100644 --- a/configs/theadorable_debug_defconfig +++ b/configs/theadorable_debug_defconfig @@ -52,6 +52,7 @@ CONFIG_EFI_PARTITION=y CONFIG_DEFAULT_DEVICE_TREE="armada-xp-theadorable" CONFIG_USE_ENV_SPI_MAX_HZ=y CONFIG_ENV_SPI_MAX_HZ=50000000 +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_SATA_MV=y diff --git a/configs/thuban_defconfig b/configs/thuban_defconfig index ade82c86e3..43d5cb814e 100644 --- a/configs/thuban_defconfig +++ b/configs/thuban_defconfig @@ -59,6 +59,7 @@ CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="am335x-draco" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_ENV=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 diff --git a/configs/ti816x_evm_defconfig b/configs/ti816x_evm_defconfig index d341633fe1..982c76a1aa 100644 --- a/configs/ti816x_evm_defconfig +++ b/configs/ti816x_evm_defconfig @@ -40,6 +40,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=nand.0:128k(NAND.SPL),128k(NAND.SPL.backup1),1 CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="dm8168-evm" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_DM_GPIO=y CONFIG_DM_I2C=y diff --git a/configs/tinker-rk3288_defconfig b/configs/tinker-rk3288_defconfig index 443f4d88b9..13ba53da87 100644 --- a/configs/tinker-rk3288_defconfig +++ b/configs/tinker-rk3288_defconfig @@ -36,6 +36,8 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="rk3288-tinker" CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y +CONFIG_TPL_ENV_IS_NOWHERE=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/tricorder_defconfig b/configs/tricorder_defconfig index 53e8256b96..dce37d6404 100644 --- a/configs/tricorder_defconfig +++ b/configs/tricorder_defconfig @@ -26,6 +26,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=omap2-nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=omap2-nand.0:128k(SPL),1m(u-boot),384k(u-boot-env1),1152k(mtdoops),384k(u-boot-env2),5m(kernel),2m(fdt),-(ubi)" CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y # CONFIG_NET is not set CONFIG_LED_STATUS=y CONFIG_LED_STATUS0=y diff --git a/configs/trimslice_defconfig b/configs/trimslice_defconfig index d8ce65f053..2d249c0ab7 100644 --- a/configs/trimslice_defconfig +++ b/configs/trimslice_defconfig @@ -27,6 +27,7 @@ CONFIG_DEFAULT_DEVICE_TREE="tegra20-trimslice" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USE_ENV_SPI_MAX_HZ=y CONFIG_ENV_SPI_MAX_HZ=48000000 +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SPL_DM=y CONFIG_SYS_I2C_TEGRA=y CONFIG_SPI_FLASH=y diff --git a/configs/ts4600_defconfig b/configs/ts4600_defconfig index b52ec639d7..79cfc20969 100644 --- a/configs/ts4600_defconfig +++ b/configs/ts4600_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_MXS_GPIO=y CONFIG_MMC_MXS=y CONFIG_CONS_INDEX=0 diff --git a/configs/turris_omnia_defconfig b/configs/turris_omnia_defconfig index c0bedf4999..8c94b4da44 100644 --- a/configs/turris_omnia_defconfig +++ b/configs/turris_omnia_defconfig @@ -54,6 +54,7 @@ CONFIG_DEFAULT_DEVICE_TREE="armada-385-turris-omnia" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USE_ENV_SPI_MAX_HZ=y CONFIG_ENV_SPI_MAX_HZ=50000000 +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_AHCI_PCI=y CONFIG_AHCI_MVEBU=y diff --git a/configs/udoo_defconfig b/configs/udoo_defconfig index ea6da7aa65..5a0e105ac0 100644 --- a/configs/udoo_defconfig +++ b/configs/udoo_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_DWC_AHSATA=y CONFIG_FSL_USDHC=y diff --git a/configs/udoo_neo_defconfig b/configs/udoo_neo_defconfig index 597f557f7b..b27041f971 100644 --- a/configs/udoo_neo_defconfig +++ b/configs/udoo_neo_defconfig @@ -17,7 +17,6 @@ CONFIG_BOOTCOMMAND="run findfdt; run distro_bootcmd" CONFIG_BOUNCE_BUFFER=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_TEXT_BASE=0x00908000 -CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_FS_EXT4=y CONFIG_SPL_WATCHDOG_SUPPORT=y # CONFIG_CMD_FLASH is not set diff --git a/configs/venice2_defconfig b/configs/venice2_defconfig index 7f7befba7b..357b864cc7 100644 --- a/configs/venice2_defconfig +++ b/configs/venice2_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="tegra124-venice2" +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SPL_DM=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y diff --git a/configs/ventana_defconfig b/configs/ventana_defconfig index c16ddb97c1..d56d295758 100644 --- a/configs/ventana_defconfig +++ b/configs/ventana_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="tegra20-ventana" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SPL_DM=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y diff --git a/configs/vyasa-rk3288_defconfig b/configs/vyasa-rk3288_defconfig index c74c1457a7..ba251faef4 100644 --- a/configs/vyasa-rk3288_defconfig +++ b/configs/vyasa-rk3288_defconfig @@ -37,6 +37,8 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="rk3288-vyasa" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y +CONFIG_TPL_ENV_IS_NOWHERE=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/wandboard_defconfig b/configs/wandboard_defconfig index f07ec5f651..60fce07089 100644 --- a/configs/wandboard_defconfig +++ b/configs/wandboard_defconfig @@ -45,6 +45,7 @@ CONFIG_OF_LIST="imx6q-wandboard-revb1 imx6qp-wandboard-revd1 imx6dl-wandboard-re CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_DWC_AHSATA=y CONFIG_DM_GPIO=y diff --git a/configs/wb45n_defconfig b/configs/wb45n_defconfig index be6744b82b..59bbe45d50 100644 --- a/configs/wb45n_defconfig +++ b/configs/wb45n_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_MTDPARTS=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/wb50n_defconfig b/configs/wb50n_defconfig index ef427f350d..289fd4c0fe 100644 --- a/configs/wb50n_defconfig +++ b/configs/wb50n_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_ENV_IS_IN_NAND=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/woodburn_sd_defconfig b/configs/woodburn_sd_defconfig index 72e6ab4721..10c11ef90a 100644 --- a/configs/woodburn_sd_defconfig +++ b/configs/woodburn_sd_defconfig @@ -39,6 +39,7 @@ CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_ENV_IS_IN_FLASH=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_MXC_GPIO=y CONFIG_FSL_ESDHC_IMX=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/work_92105_defconfig b/configs/work_92105_defconfig index 5131805c4a..0b516f5715 100644 --- a/configs/work_92105_defconfig +++ b/configs/work_92105_defconfig @@ -36,6 +36,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_DOS_PARTITION=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_SPL_ENV_IS_NOWHERE=y # CONFIG_MMC is not set CONFIG_PHYLIB=y CONFIG_PHY_ADDR_ENABLE=y diff --git a/configs/x530_defconfig b/configs/x530_defconfig index 05526fe8ee..136bf921d2 100644 --- a/configs/x530_defconfig +++ b/configs/x530_defconfig @@ -45,6 +45,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_DEFAULT_DEVICE_TREE="armada-385-atl-x530" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_BLK=y CONFIG_DM_GPIO=y diff --git a/configs/x600_defconfig b/configs/x600_defconfig index e4e5c57a74..41c8247a1a 100644 --- a/configs/x600_defconfig +++ b/configs/x600_defconfig @@ -44,6 +44,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=nand:64M(ubi0),64M(ubi1)" CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_FPGA_XILINX=y CONFIG_FPGA_SPARTAN3=y diff --git a/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig b/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig index 7b1f5e9d0a..063c431de3 100644 --- a/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig @@ -43,6 +43,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="zynqmp-zc1751-xm015-dc1" CONFIG_ENV_IS_IN_FAT=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig b/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig index cc2af6dce0..c064af72e5 100644 --- a/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig @@ -35,6 +35,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="zynqmp-zc1751-xm018-dc4" CONFIG_ENV_IS_IN_FAT=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig b/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig index bf66171335..722f195b14 100644 --- a/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="zynqmp-zc1751-xm019-dc5" CONFIG_ENV_IS_IN_FAT=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig b/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig index ef291a7d38..4f994b9af1 100644 --- a/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig +++ b/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig @@ -45,6 +45,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="zynqmp-zcu102-rev1.0" CONFIG_ENV_IS_IN_FAT=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/xilinx_zynqmp_zcu102_revA_defconfig b/configs/xilinx_zynqmp_zcu102_revA_defconfig index 975e9f5eb1..833670fb60 100644 --- a/configs/xilinx_zynqmp_zcu102_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revA_defconfig @@ -45,6 +45,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="zynqmp-zcu102-revA" CONFIG_ENV_IS_IN_FAT=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/xilinx_zynqmp_zcu102_revB_defconfig b/configs/xilinx_zynqmp_zcu102_revB_defconfig index 34918aa171..950fdcefd0 100644 --- a/configs/xilinx_zynqmp_zcu102_revB_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revB_defconfig @@ -45,6 +45,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="zynqmp-zcu102-revB" CONFIG_ENV_IS_IN_FAT=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/xilinx_zynqmp_zcu104_revA_defconfig b/configs/xilinx_zynqmp_zcu104_revA_defconfig index e4090dc281..33388afcda 100644 --- a/configs/xilinx_zynqmp_zcu104_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu104_revA_defconfig @@ -39,6 +39,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="zynqmp-zcu104-revA" CONFIG_ENV_IS_IN_FAT=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/xilinx_zynqmp_zcu104_revC_defconfig b/configs/xilinx_zynqmp_zcu104_revC_defconfig index 25a2515d15..563ef36afc 100644 --- a/configs/xilinx_zynqmp_zcu104_revC_defconfig +++ b/configs/xilinx_zynqmp_zcu104_revC_defconfig @@ -39,6 +39,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="zynqmp-zcu104-revC" CONFIG_ENV_IS_IN_FAT=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/xilinx_zynqmp_zcu106_revA_defconfig b/configs/xilinx_zynqmp_zcu106_revA_defconfig index 212de924a6..efe1a5d974 100644 --- a/configs/xilinx_zynqmp_zcu106_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu106_revA_defconfig @@ -42,6 +42,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="zynqmp-zcu106-revA" CONFIG_ENV_IS_IN_FAT=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/xilinx_zynqmp_zcu111_revA_defconfig b/configs/xilinx_zynqmp_zcu111_revA_defconfig index dec894787e..5574fa426c 100644 --- a/configs/xilinx_zynqmp_zcu111_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu111_revA_defconfig @@ -38,6 +38,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="zynqmp-zcu111-revA" CONFIG_ENV_IS_IN_FAT=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/xpress_spl_defconfig b/configs/xpress_spl_defconfig index 913d577bcd..7e73fbeeb2 100644 --- a/configs/xpress_spl_defconfig +++ b/configs/xpress_spl_defconfig @@ -36,6 +36,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y diff --git a/configs/zc5202_defconfig b/configs/zc5202_defconfig index 6ba4bd54f7..c6e2c59ac2 100644 --- a/configs/zc5202_defconfig +++ b/configs/zc5202_defconfig @@ -35,6 +35,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_FSL_USDHC=y CONFIG_SPI_FLASH=y diff --git a/configs/zc5601_defconfig b/configs/zc5601_defconfig index 676691d19e..553e5d10cd 100644 --- a/configs/zc5601_defconfig +++ b/configs/zc5601_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_FSL_USDHC=y CONFIG_SPI_FLASH=y diff --git a/configs/zynq_dlc20_rev1_0_defconfig b/configs/zynq_dlc20_rev1_0_defconfig index b6751ad35b..5282464ebf 100644 --- a/configs/zynq_dlc20_rev1_0_defconfig +++ b/configs/zynq_dlc20_rev1_0_defconfig @@ -40,6 +40,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y CONFIG_DEFAULT_DEVICE_TREE="zynq-dlc20-rev1.0" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_MMC=y diff --git a/configs/zynq_microzed_defconfig b/configs/zynq_microzed_defconfig index d30581b241..4af93fb863 100644 --- a/configs/zynq_microzed_defconfig +++ b/configs/zynq_microzed_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y CONFIG_DEFAULT_DEVICE_TREE="zynq-microzed" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_MMC=y diff --git a/configs/zynq_minized_defconfig b/configs/zynq_minized_defconfig index 3c95f0aceb..23cfeb7687 100644 --- a/configs/zynq_minized_defconfig +++ b/configs/zynq_minized_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y CONFIG_DEFAULT_DEVICE_TREE="zynq-minized" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_MMC=y diff --git a/configs/zynq_zc702_defconfig b/configs/zynq_zc702_defconfig index 6b670aefc9..de5a1e5ce7 100644 --- a/configs/zynq_zc702_defconfig +++ b/configs/zynq_zc702_defconfig @@ -40,6 +40,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y CONFIG_DEFAULT_DEVICE_TREE="zynq-zc702" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_MMC=y diff --git a/configs/zynq_zc706_defconfig b/configs/zynq_zc706_defconfig index 3d0cd314c6..cb0bb6dced 100644 --- a/configs/zynq_zc706_defconfig +++ b/configs/zynq_zc706_defconfig @@ -42,6 +42,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y CONFIG_DEFAULT_DEVICE_TREE="zynq-zc706" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_MMC=y diff --git a/configs/zynq_zc770_xm010_defconfig b/configs/zynq_zc770_xm010_defconfig index 53108ff03c..ca15856771 100644 --- a/configs/zynq_zc770_xm010_defconfig +++ b/configs/zynq_zc770_xm010_defconfig @@ -37,6 +37,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="zynq-zc770-xm010" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_FPGA_XILINX=y diff --git a/configs/zynq_zc770_xm012_defconfig b/configs/zynq_zc770_xm012_defconfig index 01e3d5fb84..ab6f5535b4 100644 --- a/configs/zynq_zc770_xm012_defconfig +++ b/configs/zynq_zc770_xm012_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_CACHE=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="zynq-zc770-xm012" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_BLK=y diff --git a/configs/zynq_zed_defconfig b/configs/zynq_zed_defconfig index 9b6d754872..492374a71c 100644 --- a/configs/zynq_zed_defconfig +++ b/configs/zynq_zed_defconfig @@ -37,6 +37,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y CONFIG_DEFAULT_DEVICE_TREE="zynq-zed" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_MMC=y diff --git a/configs/zynq_zybo_defconfig b/configs/zynq_zybo_defconfig index 2abc6db0d0..b39e691129 100644 --- a/configs/zynq_zybo_defconfig +++ b/configs/zynq_zybo_defconfig @@ -37,6 +37,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y CONFIG_DEFAULT_DEVICE_TREE="zynq-zybo" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_MMC=y diff --git a/configs/zynq_zybo_z7_defconfig b/configs/zynq_zybo_z7_defconfig index eda1416a9b..ba75929e0d 100644 --- a/configs/zynq_zybo_z7_defconfig +++ b/configs/zynq_zybo_z7_defconfig @@ -37,6 +37,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y CONFIG_DEFAULT_DEVICE_TREE="zynq-zybo-z7" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SPL_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_MMC=y diff --git a/drivers/input/input.c b/drivers/input/input.c index 6ab378b979..92badc51c0 100644 --- a/drivers/input/input.c +++ b/drivers/input/input.c @@ -653,7 +653,7 @@ int input_stdio_register(struct stdio_dev *dev) int error;
error = stdio_register(dev); -#if !defined(CONFIG_SPL_BUILD) || CONFIG_IS_ENABLED(ENV_SUPPORT) +#if ENV_IS_IN_SOMEWHERE /* check if this is the standard input device */ if (!error && strcmp(env_get("stdin"), dev->name) == 0) { /* reassign the console */ diff --git a/drivers/mtd/nand/raw/Makefile b/drivers/mtd/nand/raw/Makefile index 9337f6482e..a948324456 100644 --- a/drivers/mtd/nand/raw/Makefile +++ b/drivers/mtd/nand/raw/Makefile @@ -17,9 +17,7 @@ obj-$(CONFIG_SPL_NAND_ECC) += nand_ecc.o obj-$(CONFIG_SPL_NAND_BASE) += nand_base.o obj-$(CONFIG_SPL_NAND_IDENT) += nand_ids.o nand_timings.o obj-$(CONFIG_SPL_NAND_INIT) += nand.o -ifeq ($(CONFIG_SPL_ENV_SUPPORT),y) -obj-$(CONFIG_ENV_IS_IN_NAND) += nand_util.o -endif +obj-$(CONFIG_SPL_ENV_IS_IN_NAND) += nand_util.o
else # not spl
diff --git a/drivers/reset/reset-socfpga.c b/drivers/reset/reset-socfpga.c index 93ec9cfdb6..b4ec412f04 100644 --- a/drivers/reset/reset-socfpga.c +++ b/drivers/reset/reset-socfpga.c @@ -44,7 +44,7 @@ struct socfpga_reset_data { */ static bool socfpga_reset_keep_enabled(void) { -#if !defined(CONFIG_SPL_BUILD) || CONFIG_IS_ENABLED(ENV_SUPPORT) +#if ENV_IS_IN_SOMEWHERE const char *env_str; long val;
diff --git a/env/Kconfig b/env/Kconfig index 74db2f38cc..c1a9e37b4a 100644 --- a/env/Kconfig +++ b/env/Kconfig @@ -1,5 +1,20 @@ menu "Environment"
+config ENV_FULL_SUPPORT + bool "Support all environment features" + default y + help + Enable full environment support in U-Boot, + including attributes, callbacks and flags. + +config ENV_DEFAULT + bool "Support default enviromnent" + default y + help + Enable a default enviromnent in U-Boot, + The default enviromnent if pre-populated with many variables + . + config ENV_IS_NOWHERE bool "Environment is not stored" default y if !ENV_IS_IN_EEPROM && !ENV_IS_IN_EXT4 && \ @@ -526,6 +541,7 @@ endif
config USE_DEFAULT_ENV_FILE bool "Create default environment from file" + depends on ENV_DEFAULT help Normally, the default environment is automatically generated based on the settings of various CONFIG_* options, as well @@ -549,7 +565,14 @@ config ENV_VARS_UBOOT_RUNTIME_CONFIG run-time determined information about the hardware to the environment. These will be named board_name, board_rev.
-if SPL_ENV_SUPPORT +if SPL + +config SPL_ENV_DEFAULT + bool "SPL default enviromnent" + default n + help + Similar to ENV_DEFAULT, used for SPL environment. + config SPL_ENV_IS_NOWHERE bool "SPL Environment is not stored" default y if ENV_IS_NOWHERE @@ -606,7 +629,13 @@ config SPL_ENV_IS_IN_FLASH
endif
-if TPL_ENV_SUPPORT +if TPL + +config TPL_ENV_DEFAULT + bool "TPL default enviromnent" + default n + help + Similar to ENV_DEFAULT, used for TPL environment.
config TPL_ENV_IS_NOWHERE bool "TPL Environment is not stored" diff --git a/env/Makefile b/env/Makefile index 90144d6caf..0983712f09 100644 --- a/env/Makefile +++ b/env/Makefile @@ -5,10 +5,11 @@
obj-y += common.o env.o
+obj-$(CONFIG_ENV_FULL_SUPPORT) += attr.o +obj-$(CONFIG_ENV_FULL_SUPPORT) += flags.o +obj-$(CONFIG_ENV_FULL_SUPPORT) += callback.o + ifndef CONFIG_SPL_BUILD -obj-y += attr.o -obj-y += callback.o -obj-y += flags.o obj-$(CONFIG_ENV_IS_IN_EEPROM) += eeprom.o extra-$(CONFIG_ENV_IS_EMBEDDED) += embedded.o obj-$(CONFIG_ENV_IS_IN_EEPROM) += embedded.o @@ -19,10 +20,6 @@ obj-$(CONFIG_ENV_IS_IN_ONENAND) += onenand.o obj-$(CONFIG_ENV_IS_IN_SATA) += sata.o obj-$(CONFIG_ENV_IS_IN_REMOTE) += remote.o obj-$(CONFIG_ENV_IS_IN_UBI) += ubi.o -else -obj-$(CONFIG_$(SPL_TPL_)ENV_SUPPORT) += attr.o -obj-$(CONFIG_$(SPL_TPL_)ENV_SUPPORT) += flags.o -obj-$(CONFIG_$(SPL_TPL_)ENV_SUPPORT) += callback.o endif
obj-$(CONFIG_$(SPL_TPL_)ENV_IS_NOWHERE) += nowhere.o diff --git a/env/common.c b/env/common.c index f677b5b0da..564e7e2e0b 100644 --- a/env/common.c +++ b/env/common.c @@ -24,10 +24,8 @@ DECLARE_GLOBAL_DATA_PTR; #include <env_default.h>
struct hsearch_data env_htab = { -#if !defined(CONFIG_SPL_BUILD) || CONFIG_IS_ENABLED(ENV_SUPPORT) - /* defined in flags.c, only compiled in U-Boot or - * with $(SPL_TPL_)ENV_SUPPORT - */ +#ifdef CONFIG_ENV_FULL_SUPPORT + /* defined in flags.c, only compile with ENV_FULL_SUPPORT */ .change_ok = env_flags_validate, #endif }; diff --git a/include/configs/ls1021aiot.h b/include/configs/ls1021aiot.h index ee570bc1a9..1d5d934aea 100644 --- a/include/configs/ls1021aiot.h +++ b/include/configs/ls1021aiot.h @@ -62,7 +62,6 @@ board/freescale/ls1021aiot/ls102xa_rcw_sd.cfg #define CONFIG_SPL_LIBCOMMON_SUPPORT #define CONFIG_SPL_LIBGENERIC_SUPPORT -#define CONFIG_SPL_ENV_SUPPORT #define CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT #define CONFIG_SPL_I2C_SUPPORT #define CONFIG_SPL_WATCHDOG_SUPPORT diff --git a/include/configs/ls1046a_common.h b/include/configs/ls1046a_common.h index 59c43f1ae1..dd29bfde2b 100644 --- a/include/configs/ls1046a_common.h +++ b/include/configs/ls1046a_common.h @@ -106,7 +106,6 @@ #define CONFIG_SPL_PBL_PAD #define CONFIG_SPL_LIBCOMMON_SUPPORT #define CONFIG_SPL_LIBGENERIC_SUPPORT -#define CONFIG_SPL_ENV_SUPPORT #define CONFIG_SPL_WATCHDOG_SUPPORT #define CONFIG_SPL_I2C_SUPPORT #define CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index a1c55a8306..021f810046 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -240,7 +240,6 @@
#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_DFU) # undef CONFIG_CMD_BOOTD -# define CONFIG_SPL_ENV_SUPPORT # define CONFIG_SPL_HASH_SUPPORT # define CONFIG_ENV_MAX_ENTRIES 10 #endif diff --git a/include/env_callback.h b/include/env_callback.h index 74da20eec3..93833e86f0 100644 --- a/include/env_callback.h +++ b/include/env_callback.h @@ -72,6 +72,10 @@ "serial#:serialno," \ CONFIG_ENV_CALLBACK_LIST_STATIC
+#ifdef CONFIG_ENV_FULL_SUPPORT void env_callback_init(struct env_entry *var_entry); +#else +static inline void env_callback_init(struct env_entry *var_entry) { } +#endif
#endif /* __ENV_CALLBACK_H__ */ diff --git a/include/env_default.h b/include/env_default.h index 56a8bae39a..9a95513a22 100644 --- a/include/env_default.h +++ b/include/env_default.h @@ -21,13 +21,16 @@ static char default_environment[] = { #else const uchar default_environment[] = { #endif +#if CONFIG_IS_ENABLED(ENV_DEFAULT) #ifndef CONFIG_USE_DEFAULT_ENV_FILE +#if CONFIG_IS_ENABLED(ENV_FULL_SUPPORT) #ifdef CONFIG_ENV_CALLBACK_LIST_DEFAULT ENV_CALLBACK_VAR "=" CONFIG_ENV_CALLBACK_LIST_DEFAULT "\0" #endif #ifdef CONFIG_ENV_FLAGS_LIST_DEFAULT ENV_FLAGS_VAR "=" CONFIG_ENV_FLAGS_LIST_DEFAULT "\0" #endif +#endif /* ENV_FULL_SUPPORT */ #ifdef CONFIG_USE_BOOTARGS "bootargs=" CONFIG_BOOTARGS "\0" #endif @@ -114,6 +117,7 @@ const uchar default_environment[] = { #else /* CONFIG_USE_DEFAULT_ENV_FILE */ #include "generated/defaultenv_autogenerated.h" #endif +#endif /* ENV_DEFAULT */ #ifdef DEFAULT_ENV_INSTANCE_EMBEDDED } #endif diff --git a/include/env_flags.h b/include/env_flags.h index 725841a891..9a2a2d3a53 100644 --- a/include/env_flags.h +++ b/include/env_flags.h @@ -153,7 +153,11 @@ int env_flags_validate_env_set_params(char *name, char *const val[], int count); * When adding a variable to the environment, initialize the flags for that * variable. */ +#ifdef CONFIG_ENV_FULL_SUPPORT void env_flags_init(struct env_entry *var_entry); +#else +static inline void env_flags_init(struct env_entry *var_entry) { } +#endif
/* * Validate the newval for to conform with the requirements defined by its flags
From: Patrick DELAUNAY patrick.delaunay@st.com Sent: jeudi 3 octobre 2019 09:24 To: u-boot@lists.denx.de
Add a new flag CONFIG_ENV_FULL_SUPPORT to compile all the environment features (attributes, callbacks and flags) in U-Boot, TPL and SPL.
This flag replace the existing flags for SPL and TPL (CONFIG_SPL_ENV_SUPPORT / CONFIG_TPL_ENV_SUPPORT), because the same support of environment features is mandatory for U-Boot, SPL and TPL.
To deactivate the load/save environment support in SPL / TPL, the board need to activate CONFIG_SPL_ENV_IS_NOWHERE or CONFIG_TPL_ENV_IS_NOWHERE.
With this patch, the environment is activated by default in SPL and TPL, which include the content of default_environment[] as U-boot. To avoid to increase their size, this patch also add 3 new confif : CONFIG_$(SPL_TPL_)ENV_DEFAULT. It is deactivated by default for SPL/TPL and activated by default for U-Boot, the default environment for SPL/TPL is empty and it will be populated only when it will be loaded from storage medium.
All the test on CONFIG_SPL_ENV_SUPPORT are replaced by the ENV_IS_SOMEWHERE macro, which tests if the environment is storage medium.
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com
Hi Tom,
I try to solve default environment size issue in patch =
http://patchwork.ozlabs.org/patch/1257545/ [RFC RFT PATCH] env: spl: filter the variables in default environment of SPL or TPL
But as it is not acceptable and I don't see other solution, I won't push v5 and I considere this serie abandoned.
http://patchwork.ozlabs.org/patch/1171180/
Thanks
Patrick
Dear Patrick,
In message 20191003072428.19197-1-patrick.delaunay@st.com you wrote:
This patchset follow http://patchwork.ozlabs.org/project/uboot/list/?series=131268&state=*
It follow the first proposal http://patchwork.ozlabs.org/project/uboot/list/?series=129339 "env: Add CONFIG_ENV_SUPPORT"
Do I understand correctly that all of this is obsolete and no longer needed after Tom's commit d90fc9c3de ``Revert "env: solve compilation error in SPL"'' ?
On Mon, Oct 07, 2019 at 07:56:35PM +0200, Wolfgang Denk wrote:
Dear Patrick,
So, I think there's a new topic here. I seem to recall a concern from the previous thread that we could have less restrictive environment protections in SPL/TPL than we do in full U-Boot and thus open ourselves to a potential problem. As of today, U-Boot is back to where it was prior to the problematic patch being applied. But do we not have the potential problem above and thus need to evaluate the rest of the series (as the revert was largely the same as the first patch in the series) ? Thanks!
Dear Tom,
The (potential) problem of having less restrictive/secure code in SPL than in U-Boot proper resulted from the fact that the patch series allowed different configurations of the U-Boot environment features in these stages.
After the revert of the original problem, I don't see the need for any such configuration, so if we simply do nothing we are as secure as we have been before.
When accepting this new patch series, a full review of the impacts (size, security) is needed.
Hi Wolfgang and Tom,
From: Wolfgang Denk wd@denx.de Sent: lundi 7 octobre 2019 19:57
Dear Patrick,
The revert is a solution of the intial regression.
A other solution only to correct he regression was the first patch of the serie
[U-Boot,v4,1/3] env: correct the check of env_flags_validate presence http://patchwork.ozlabs.org/patch/1171096/
But I am OK with Tom decision to just revert my initial patch.
The two other patch of the serie is a proposal after your remarks in: http://patchwork.ozlabs.org/patch/1157174/
= This scares me. Why are there different settings for SPL, TPL and = U-Boot proper? This looks conceptually broken to me - if a system = is configured to use a specific set of environment features and = extensions, then the exact same settings must be use in all of SPL, = TPL and U-Boot proper. .... = So please reconsider this whole implementation, and make sure that = only a single macro ise used everywhere to enable these features.
Today in v2010.10 with have ENV attribute / callback / flags 1/ always used in U-Boot proper 2/ optional in SPL/TPL (CONFIG_SPL_ENV_SUPPORT & CONFIG_TPL_ENV_SUPPORT)
In env:Makefile :
ifndef CONFIG_SPL_BUILD obj-y += attr.o obj-y += callback.o obj-y += flags.o else obj-$(CONFIG_$(SPL_TPL_)ENV_SUPPORT) += attr.o obj-$(CONFIG_$(SPL_TPL_)ENV_SUPPORT) += flags.o obj-$(CONFIG_$(SPL_TPL_)ENV_SUPPORT) += callback.o endif
Perhaps I not correctly understood the initial issue, but I do my best to have the same level of ENV features (CONFIG_ENV_FULL_SUPPORT activate the features and extensions= attribute / callback / flags) between U--Boot proper, SPL and TPL.
With the serie => when read from device (ENV_IS_IN....) is not supported ENV is still supported in SPL/TPL with (SPL_TPL_)ENV_IS_NOWHERE with same feature level than U-Boot (only the default env is supported) => the only remaining issue today after my serie is the size of this default environment (default_environment[]) in SPL and TPL. The content of this variable need to have the same content in SPL/TPL than in U-Boot proper ?
However if I not correctly understood the initial issue around ENV and security, and if the current ENV code behavior is enough for you,Wolfgang and Tom, or any other maintainers interested by ENV, I will abandon the serie.
PS: I can change also the serie as RFC.... to have more feedback
-- DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de The scientists of today think deeply instead of clearly. One must be sane to think clearly, but one can think deeply and be quite insane. - Nikola Tesla
Regards
Patrick
Dear Patrick,
You understood correctly: these should always be the same.
It would feel strange if it had different content, but I did not spend much time on this thought (and practical use cases) yet. In the olden days you usually wanted to have the console baud rate setting from the envrinment, and not much else. Things have changed a lot. Sorry, I can't really tell...
Patrick DELAUNAY
Patrick Delaunay
