[U-Boot] [PATCH v2 2/3] Add TI816X support
Signed-off-by: Antoine Tenart atenart@adeneo-embedded.com --- arch/arm/include/asm/arch-am33xx/clock.h | 4 + arch/arm/include/asm/arch-am33xx/clocks_ti816x.h | 136 ++++++++ arch/arm/include/asm/arch-am33xx/cpu.h | 4 + arch/arm/include/asm/arch-am33xx/cpu_ti816x.h | 194 +++++++++++ arch/arm/include/asm/arch-am33xx/ddr_defs.h | 4 + arch/arm/include/asm/arch-am33xx/ddr_defs_ti816x.h | 248 +++++++++++++ arch/arm/include/asm/arch-am33xx/hardware.h | 7 +- arch/arm/include/asm/arch-am33xx/hardware_am33xx.h | 5 + arch/arm/include/asm/arch-am33xx/hardware_ti814x.h | 5 + arch/arm/include/asm/arch-am33xx/hardware_ti816x.h | 56 +++ arch/arm/include/asm/arch-am33xx/mmc_host_def.h | 2 + arch/arm/include/asm/arch-am33xx/mux.h | 2 + arch/arm/include/asm/arch-am33xx/mux_ti816x.h | 363 ++++++++++++++++++++ 13 files changed, 1025 insertions(+), 5 deletions(-) create mode 100644 arch/arm/include/asm/arch-am33xx/clocks_ti816x.h create mode 100644 arch/arm/include/asm/arch-am33xx/cpu_ti816x.h create mode 100644 arch/arm/include/asm/arch-am33xx/ddr_defs_ti816x.h create mode 100644 arch/arm/include/asm/arch-am33xx/hardware_ti816x.h create mode 100644 arch/arm/include/asm/arch-am33xx/mux_ti816x.h
diff --git a/arch/arm/include/asm/arch-am33xx/clock.h b/arch/arm/include/asm/arch-am33xx/clock.h index ecb5901..123cc61 100644 --- a/arch/arm/include/asm/arch-am33xx/clock.h +++ b/arch/arm/include/asm/arch-am33xx/clock.h @@ -19,6 +19,10 @@ #ifndef _CLOCKS_H_ #define _CLOCKS_H_
+#if defined(CONFIG_TI816X) +#include <asm/arch/clocks_ti816x.h> +#else #include <asm/arch/clocks_am33xx.h> +#endif
#endif diff --git a/arch/arm/include/asm/arch-am33xx/clocks_ti816x.h b/arch/arm/include/asm/arch-am33xx/clocks_ti816x.h new file mode 100644 index 0000000..403db33 --- /dev/null +++ b/arch/arm/include/asm/arch-am33xx/clocks_ti816x.h @@ -0,0 +1,136 @@ +/* + * clocks_ti816x.h + * + * Copyright (C) 2013, Adeneo Embedded <www.adeneo-embedded.com> + * Antoine Tenart, atenart@adeneo-embedded.com + * + * Based on TI-PSP-04.00.02.14 : + * + * (C) Copyright 2006-2008 + * Texas Instruments, <www.ti.com> + * Richard Woodruff r-woodruff2@ti.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR /PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef _CLOCKS_TI816X_H_ +#define _CLOCKS_TI816X_H_ + +/* + * Values supported 400,531,675,796 + * + * On TI8168 rev C, use 400 or 531 MHz ! + */ +#define DDR_PLL_400 + +/* Main PLL */ +#define MAIN_N 64 +#define MAIN_P 0x1 +#define MAIN_INTFREQ1 0x8 +#define MAIN_FRACFREQ1 0x800000 +#define MAIN_MDIV1 0x2 +#define MAIN_INTFREQ2 0xE +#define MAIN_FRACFREQ2 0x0 +#define MAIN_MDIV2 0x1 +#define MAIN_INTFREQ3 0x8 +#define MAIN_FRACFREQ3 0xAAAAB0 +#define MAIN_MDIV3 0x3 +#define MAIN_INTFREQ4 0x9 +#define MAIN_FRACFREQ4 0x55554F +#define MAIN_MDIV4 0x3 +#define MAIN_INTFREQ5 0x9 +#define MAIN_FRACFREQ5 0x374BC6 +#define MAIN_MDIV5 0xC +#define MAIN_MDIV6 0x48 +#define MAIN_MDIV7 0x4 + +/* DDR PLL */ +/* For 400 MHz */ +#if defined(DDR_PLL_400) +#define DDR_N 59 +#define DDR_P 0x1 +#define DDR_MDIV1 0x4 +#define DDR_INTFREQ2 0x8 +#define DDR_FRACFREQ2 0xD99999 +#define DDR_MDIV2 0x1E +#define DDR_INTFREQ3 0x8 +#define DDR_FRACFREQ3 0x0 +#define DDR_MDIV3 0x4 +#define DDR_INTFREQ4 0xE /* Expansion DDR clk */ +#define DDR_FRACFREQ4 0x0 +#define DDR_MDIV4 0x4 +#define DDR_INTFREQ5 0xE /* Expansion DDR clk */ +#define DDR_FRACFREQ5 0x0 +#define DDR_MDIV5 0x4 +#endif + +/* For 531 MHz */ +#if defined(DDR_PLL_531) +#define DDR_N 59 +#define DDR_P 0x1 +#define DDR_MDIV1 0x3 +#define DDR_INTFREQ2 0x8 +#define DDR_FRACFREQ2 0xD99999 +#define DDR_MDIV2 0x1E +#define DDR_INTFREQ3 0x8 +#define DDR_FRACFREQ3 0x0 +#define DDR_MDIV3 0x4 +#define DDR_INTFREQ4 0xE /* Expansion DDR clk */ +#define DDR_FRACFREQ4 0x0 +#define DDR_MDIV4 0x4 +#define DDR_INTFREQ5 0xE /* Expansion DDR clk */ +#define DDR_FRACFREQ5 0x0 +#define DDR_MDIV5 0x4 +#endif + +/* For 675 MHz */ +#if defined(DDR_PLL_675) +#define DDR_N 50 +#define DDR_P 0x1 +#define DDR_MDIV1 0x2 +#define DDR_INTFREQ2 0x9 +#define DDR_FRACFREQ2 0x0 +#define DDR_MDIV2 0x19 +#define DDR_INTFREQ3 0x13 +#define DDR_FRACFREQ3 0x800000 +#define DDR_MDIV3 0x2 +#define DDR_INTFREQ4 0xE /* Expansion DDR clk */ +#define DDR_FRACFREQ4 0x0 +#define DDR_MDIV4 0x4 +#define DDR_INTFREQ5 0xE /* Expansion DDR clk */ +#define DDR_FRACFREQ5 0x0 +#define DDR_MDIV5 0x4 +#endif + +/* For 796 MHz */ +#if defined(DDR_PLL_796) +#define DDR_N 59 +#define DDR_P 0x1 +#define DDR_MDIV1 0x2 +#define DDR_INTFREQ2 0x8 +#define DDR_FRACFREQ2 0xD99999 +#define DDR_MDIV2 0x1E +#define DDR_INTFREQ3 0x8 +#define DDR_FRACFREQ3 0x0 +#define DDR_MDIV3 0x4 +#define DDR_INTFREQ4 0xE /* Expansion DDR clk */ +#define DDR_FRACFREQ4 0x0 +#define DDR_MDIV4 0x4 +#define DDR_INTFREQ5 0xE /* Expansion DDR clk */ +#define DDR_FRACFREQ5 0x0 +#define DDR_MDIV5 0x4 +#endif + +#endif /* endif _CLOCKS_TI816X_H_ */ diff --git a/arch/arm/include/asm/arch-am33xx/cpu.h b/arch/arm/include/asm/arch-am33xx/cpu.h index 13c0667..34b3aa9 100644 --- a/arch/arm/include/asm/arch-am33xx/cpu.h +++ b/arch/arm/include/asm/arch-am33xx/cpu.h @@ -25,6 +25,10 @@
#include <asm/arch/hardware.h>
+#if defined(CONFIG_TI816X) +#include <asm/arch/cpu_ti816x.h> +#endif + #define BIT(x) (1 << x) #define CL_BIT(x) (0 << x)
diff --git a/arch/arm/include/asm/arch-am33xx/cpu_ti816x.h b/arch/arm/include/asm/arch-am33xx/cpu_ti816x.h new file mode 100644 index 0000000..515dba4 --- /dev/null +++ b/arch/arm/include/asm/arch-am33xx/cpu_ti816x.h @@ -0,0 +1,194 @@ +/* + * cpu_ti816x.h + * + * Copyright (C) 2013, Adeneo Embedded <www.adeneo-embedded.com> + * Antoine Tenart, atenart@adeneo-embedded.com + * + * Based on TI-PSP-04.00.02.14 : + * + * (C) Copyright 2006 + * Texas Instruments, <www.ti.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ + +#ifndef _TI816X_CPU_H +#define _TI816X_CPU_H + +#include <asm/arch/hardware.h> + +/* Control */ +#define CONTROL_STATUS (CTRL_BASE + 0x40) + +/* PLL related registers */ +#define MAINPLL_CTRL (CTRL_BASE + 0x0400) +#define MAINPLL_PWD (CTRL_BASE + 0x0404) +#define MAINPLL_FREQ1 (CTRL_BASE + 0x0408) +#define MAINPLL_DIV1 (CTRL_BASE + 0x040C) +#define MAINPLL_FREQ2 (CTRL_BASE + 0x0410) +#define MAINPLL_DIV2 (CTRL_BASE + 0x0414) +#define MAINPLL_FREQ3 (CTRL_BASE + 0x0418) +#define MAINPLL_DIV3 (CTRL_BASE + 0x041C) +#define MAINPLL_FREQ4 (CTRL_BASE + 0x0420) +#define MAINPLL_DIV4 (CTRL_BASE + 0x0424) +#define MAINPLL_FREQ5 (CTRL_BASE + 0x0428) +#define MAINPLL_DIV5 (CTRL_BASE + 0x042C) +#define MAINPLL_DIV6 (CTRL_BASE + 0x0434) +#define MAINPLL_DIV7 (CTRL_BASE + 0x043C) + +#define DDRPLL_CTRL (CTRL_BASE + 0x0440) +#define DDRPLL_PWD (CTRL_BASE + 0x0444) +#define DDRPLL_DIV1 (CTRL_BASE + 0x044C) +#define DDRPLL_FREQ2 (CTRL_BASE + 0x0450) +#define DDRPLL_DIV2 (CTRL_BASE + 0x0454) +#define DDRPLL_FREQ3 (CTRL_BASE + 0x0458) +#define DDRPLL_DIV3 (CTRL_BASE + 0x045C) +#define DDRPLL_FREQ4 (CTRL_BASE + 0x0460) +#define DDRPLL_DIV4 (CTRL_BASE + 0x0464) +#define DDRPLL_FREQ5 (CTRL_BASE + 0x0468) +#define DDRPLL_DIV5 (CTRL_BASE + 0x046C) + +#define DDR_RCD (CTRL_BASE + 0x070C) + +/* PRCM */ +#define CM_DPLL_OFFSET (PRCM_BASE + 0x0300) + +#ifdef CONFIG_TI816X +#define CM_TIMER1_CLKSEL (CM_DPLL_OFFSET + 0x90) + +/* Timers */ +#define CM_ALWON_TIMER_0_CLKCTRL (PRCM_BASE + 0x156C) +#define CM_ALWON_TIMER_1_CLKCTRL (PRCM_BASE + 0x1570) +#define CM_ALWON_TIMER_2_CLKCTRL (PRCM_BASE + 0x1574) +#define CM_ALWON_TIMER_3_CLKCTRL (PRCM_BASE + 0x1578) +#define CM_ALWON_TIMER_4_CLKCTRL (PRCM_BASE + 0x157C) +#define CM_ALWON_TIMER_5_CLKCTRL (PRCM_BASE + 0x1580) +#define CM_ALWON_TIMER_6_CLKCTRL (PRCM_BASE + 0x1584) +#define CM_ALWON_TIMER_7_CLKCTRL (PRCM_BASE + 0x1588) +#endif + +#define CM_ALWON_WDTIMER_CLKCTRL (PRCM_BASE + 0x158C) +#define CM_ALWON_SPI_CLKCTRL (PRCM_BASE + 0x1590) +#define CM_ALWON_CONTROL_CLKCTRL (PRCM_BASE + 0x15C4) + +#define CM_ALWON_L3_SLOW_CLKSTCTRL (PRCM_BASE + 0x1400) + +#ifdef CONFIG_TI816X +#define CM_ALWON_CUST_EFUSE_CLKCTRL (PRCM_BASE + 0x1628) +#endif + +#define CM_ALWON_GPIO_0_CLKCTRL (PRCM_BASE + 0x155c) +#define CM_ALWON_GPIO_0_OPTFCLKEN_DBCLK (PRCM_BASE + 0x155c) + +#define CM_ALWON_GPIO_1_CLKCTRL (PRCM_BASE + 0x1560) +/* Ethernet */ +#define CM_ETHERNET_CLKSTCTRL (PRCM_BASE + 0x1404) +#define CM_ALWON_ETHERNET_0_CLKCTRL (PRCM_BASE + 0x15D4) +#define CM_ALWON_ETHERNET_1_CLKCTRL (PRCM_BASE + 0x15D8) + +/* UARTs */ +#define CM_ALWON_UART_0_CLKCTRL (PRCM_BASE + 0x1550) +#define CM_ALWON_UART_1_CLKCTRL (PRCM_BASE + 0x1554) +#define CM_ALWON_UART_2_CLKCTRL (PRCM_BASE + 0x1558) + +/* I2C */ +/* Note: In ti814x I2C0 and I2C2 have common clk control */ +#define CM_ALWON_I2C_0_CLKCTRL (PRCM_BASE + 0x1564) + +/* HSMMC */ +#ifdef CONFIG_TI816X +#define CM_ALWON_HSMMC_CLKCTRL (PRCM_BASE + 0x15B0) +#endif + +/*DMM & EMIF4 MMR Declaration*/ + +/* 0x420 = 0x460 - the lisa registers offset from the DMM region */ +#define DMM_PAT_BASE_ADDR (DMM_BASE + 0x420) + +#define EMIF4_0_SDRAM_ZQCR (EMIF4_0_CFG_BASE + 0xC8) +#define EMIF4_0_SDRAM_CONFIG (EMIF4_0_CFG_BASE + 0x08) +#define EMIF4_0_SDRAM_CONFIG2 (EMIF4_0_CFG_BASE + 0x0C) +#define EMIF4_0_SDRAM_REF_CTRL (EMIF4_0_CFG_BASE + 0x10) +#define EMIF4_0_SDRAM_REF_CTRL_SHADOW (EMIF4_0_CFG_BASE + 0x14) +#define EMIF4_0_SDRAM_TIM_1 (EMIF4_0_CFG_BASE + 0x18) +#define EMIF4_0_SDRAM_TIM_1_SHADOW (EMIF4_0_CFG_BASE + 0x1C) +#define EMIF4_0_SDRAM_TIM_2 (EMIF4_0_CFG_BASE + 0x20) +#define EMIF4_0_SDRAM_TIM_2_SHADOW (EMIF4_0_CFG_BASE + 0x24) +#define EMIF4_0_SDRAM_TIM_3 (EMIF4_0_CFG_BASE + 0x28) +#define EMIF4_0_SDRAM_TIM_3_SHADOW (EMIF4_0_CFG_BASE + 0x2C) +#define EMIF4_0_DDR_PHY_CTRL_1 (EMIF4_0_CFG_BASE + 0xE4) +#define EMIF4_0_DDR_PHY_CTRL_1_SHADOW (EMIF4_0_CFG_BASE + 0xE8) +#define EMIF4_0_IODFT_TLGC (EMIF4_0_CFG_BASE + 0x60) + +#define EMIF4_1_SDRAM_ZQCR (EMIF4_1_CFG_BASE + 0xC8) +#define EMIF4_1_SDRAM_CONFIG (EMIF4_1_CFG_BASE + 0x08) +#define EMIF4_1_SDRAM_CONFIG2 (EMIF4_1_CFG_BASE + 0x0C) +#define EMIF4_1_SDRAM_REF_CTRL (EMIF4_1_CFG_BASE + 0x10) +#define EMIF4_1_SDRAM_REF_CTRL_SHADOW (EMIF4_1_CFG_BASE + 0x14) +#define EMIF4_1_SDRAM_TIM_1 (EMIF4_1_CFG_BASE + 0x18) +#define EMIF4_1_SDRAM_TIM_1_SHADOW (EMIF4_1_CFG_BASE + 0x1C) +#define EMIF4_1_SDRAM_TIM_2 (EMIF4_1_CFG_BASE + 0x20) +#define EMIF4_1_SDRAM_TIM_2_SHADOW (EMIF4_1_CFG_BASE + 0x24) +#define EMIF4_1_SDRAM_TIM_3 (EMIF4_1_CFG_BASE + 0x28) +#define EMIF4_1_SDRAM_TIM_3_SHADOW (EMIF4_1_CFG_BASE + 0x2C) +#define EMIF4_1_DDR_PHY_CTRL_1 (EMIF4_1_CFG_BASE + 0xE4) +#define EMIF4_1_DDR_PHY_CTRL_1_SHADOW (EMIF4_1_CFG_BASE + 0xE8) +#define EMIF4_1_IODFT_TLGC (EMIF4_1_CFG_BASE + 0x60) + +/*EMIF4 PRCM Defintion*/ +#define CM_DEFAULT_L3_FAST_CLKSTCTRL (PRCM_BASE + 0x0508) +#define CM_DEFAULT_EMIF_0_CLKCTRL (PRCM_BASE + 0x0520) +#define CM_DEFAULT_EMIF_1_CLKCTRL (PRCM_BASE + 0x0524) +#define CM_DEFAULT_DMM_CLKCTRL (PRCM_BASE + 0x0528) +#define CM_DEFAULT_FW_CLKCTRL (PRCM_BASE + 0x052C) + +/* GPMC related */ +#define GPMC_CONFIG_CS0 (0x60) +#define GPMC_CONFIG_CS0_BAS (GPMC_BASE + GPMC_CONFIG_CS0) +#define GPMC_CONFIG1 (0x00) +#define GPMC_CONFIG2 (0x04) +#define GPMC_CONFIG3 (0x08) +#define GPMC_CONFIG4 (0x0C) +#define GPMC_CONFIG5 (0x10) +#define GPMC_CONFIG6 (0x14) +#define GPMC_CONFIG7 (0x18) + +/* WDT related */ +#define WDT_WDSC (WDT_BASE + 0x010) +#define WDT_WDST (WDT_BASE + 0x014) +#define WDT_WISR (WDT_BASE + 0x018) +#define WDT_WIER (WDT_BASE + 0x01C) +#define WDT_WWER (WDT_BASE + 0x020) +#define WDT_WCLR (WDT_BASE + 0x024) +#define WDT_WCRR (WDT_BASE + 0x028) +#define WDT_WLDR (WDT_BASE + 0x02C) +#define WDT_WTGR (WDT_BASE + 0x030) +#define WDT_WWPS (WDT_BASE + 0x034) +#define WDT_WDLY (WDT_BASE + 0x044) +#define WDT_WSPR (WDT_BASE + 0x048) +#define WDT_WIRQEOI (WDT_BASE + 0x050) +#define WDT_WIRQSTATRAW (WDT_BASE + 0x054) +#define WDT_WIRQSTAT (WDT_BASE + 0x058) +#define WDT_WIRQENSET (WDT_BASE + 0x05C) +#define WDT_WIRQENCLR (WDT_BASE + 0x060) + +#define WDT_UNFREEZE (CTRL_BASE + 0x100) + +#endif /* _TI816X_CPU_H */ diff --git a/arch/arm/include/asm/arch-am33xx/ddr_defs.h b/arch/arm/include/asm/arch-am33xx/ddr_defs.h index 15ca4c1..b959ba8 100644 --- a/arch/arm/include/asm/arch-am33xx/ddr_defs.h +++ b/arch/arm/include/asm/arch-am33xx/ddr_defs.h @@ -22,6 +22,10 @@ #include <asm/arch/hardware.h> #include <asm/emif.h>
+#if defined(CONFIG_TI816X) +#include <asm/arch/ddr_defs_ti816x.h> +#endif + /* AM335X EMIF Register values */ #define VTP_CTRL_READY (0x1 << 5) #define VTP_CTRL_ENABLE (0x1 << 6) diff --git a/arch/arm/include/asm/arch-am33xx/ddr_defs_ti816x.h b/arch/arm/include/asm/arch-am33xx/ddr_defs_ti816x.h new file mode 100644 index 0000000..b3449e0 --- /dev/null +++ b/arch/arm/include/asm/arch-am33xx/ddr_defs_ti816x.h @@ -0,0 +1,248 @@ +/* + * ddr_defs_ti816x.h + * + * ddr specific header for TI816X + * + * Copyright (C) 2013, Adeneo Embedded <www.adeneo-embedded.com> + * Antoine Tenart, atenart@adeneo-embedded.com + * + * Based on TI-PSP-04.00.02.14 : + * + * Copyright (C) 2010 Texas Instruments + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + * + */ + +#ifndef _DDR_DEFS_TI816X_H +#define _DDR_DEFS_TI816X_H + +#include <asm/arch/hardware.h> + +#ifdef CONFIG_TI816X_EVM_DDR3 + +#define CONFIG_TI816X_DDR3_796 /* Values supported 400,531,675,796 */ +#define CONFIG_TI816X_DDR3_SW_LEVELING /* Enable software leveling (DDR3) */ + +/* + * DDR3 force values. These are board dependent + */ + +/* + * Invert clock adds an additional half cycle delay on the command + * interface. The additional half cycle, is usually meant to enable + * leveling in the situation that DQS is later than CK on the board. It + * also helps provide some additional margin for leveling. + * + * For the EVM this is helping us with additional room for the write + * leveling. Since the dqs delays are very small. + */ +#define INVERT_CLOCK 1 + +/* + * CMD_SLAVE_RATIO determines where is the command placed with respect + * to the clock edge. This is a ratio, implying 0x100 is one cycle. + * Ideally the command is centered so - this should be half cycle + * delay (0x80). But if invert clock is in use, an additional half + * cycle must be added + */ +#define CMD_SLAVE_FROM_INV_CLOCK(i) (((i) == 0) ? 0x80 : 0x100) +#define CMD_SLAVE_RATIO CMD_SLAVE_FROM_INV_CLOCK(INVERT_CLOCK) + +/* + * This represents the initial value for the leveling process. The + * value is a ratio - so 0x100 represents one cycle. The real delay + * is determined through the leveling process. + * + * During the leveling process, 0x20 is subtracted from the value, so + * we have added that to the value we want to set. We also set the + * values such that byte3 completes leveling after byte2 and byte1 + * after byte0. + */ +#define WR_DQS_RATIO_0 0x20 +#define WR_DQS_RATIO_1 0x20 +#define WR_DQS_RATIO_2 0x20 +#define WR_DQS_RATIO_3 0x20 + +/* + * This represents the initial value for the leveling process. The + * value is a ratio - so 0x100 represents one cycle. The real delay + * is determined through the leveling process. + * + * During the leveling process, 0x20 is subtracted from the value, so + * we have added that to the value we want to set. We also set the + * values such that byte3 completes leveling after byte2 and byte1 + * after byte0. + */ +#define RD_GATE_RATIO_0 0x20 +#define RD_GATE_RATIO_1 0x20 +#define RD_GATE_RATIO_2 0x20 +#define RD_GATE_RATIO_3 0x20 + +/* + * data rate in MHz. The DDR clock will be 1/2 of this value + */ +#define DDR_DATA_RATE 800 + +#define USE_EMIF0 1 +#define USE_EMIF1 1 + +/* + * EMIF Paramters. Refer the EMIF register documentation and the + * memory datasheet for details + */ +/* For 400 MHz */ +#if defined(CONFIG_TI816X_DDR3_400) +#define EMIF_TIM1 0x0CCCE524 +#define EMIF_TIM2 0x30308023 +#define EMIF_TIM3 0x009F82CF +#define EMIF_SDREF 0x10000C30 +#define EMIF_SDCFG 0x62A41032 +#define EMIF_PHYCFG 0x0000010B + +#if defined(CONFIG_TI816X_DDR3_SW_LEVELING) +/* These values are obtained from the CCS app */ +#define RD_DQS_GATE 0x12A +#define RD_DQS 0x3B +#define WR_DQS 0xA6 +#endif + +#endif /* CONFIG_TI816X_DDR3_400 */ + +/* For 531 MHz */ +#if defined(CONFIG_TI816X_DDR3_531) +#define EMIF_TIM1 0x0EF136AC +#define EMIF_TIM2 0x30408063 +#define EMIF_TIM3 0x009F83AF +#define EMIF_SDREF 0x1000102E +#define EMIF_SDCFG 0x62A51832 +#define EMIF_PHYCFG 0x0000010C + +#if defined(CONFIG_TI816X_DDR3_SW_LEVELING) +/* These values are obtained from the CCS app */ +#define RD_DQS_GATE 0x13D +#define RD_DQS 0x39 +#define WR_DQS 0xB4 +#endif + +#endif /* CONFIG_TI816X_DDR_531 */ + +/* For 675 MHz */ +#if defined(CONFIG_TI816X_DDR3_675) +#define EMIF_TIM1 0x13358875 +#define EMIF_TIM2 0x5051806C +#define EMIF_TIM3 0x009F84AF +#define EMIF_SDREF 0x10001491 +#define EMIF_SDCFG 0x62A63032 +#define EMIF_PHYCFG 0x0000010F + +#if defined(CONFIG_TI816X_DDR3_SW_LEVELING) +/* These values are obtained from the CCS app */ +#define RD_DQS_GATE 0x196 +#define RD_DQS 0x39 +#define WR_DQS 0x91 + +#endif + +#endif /* CONFIG_TI816X_DDR3_675 */ + +/* For 796 MHz */ +#if defined(CONFIG_TI816X_DDR3_796) +#define EMIF_TIM1 0x1779C9FE +#define EMIF_TIM2 0x50608074 +#define EMIF_TIM3 0x009F857F +#define EMIF_SDREF 0x10001841 +#define EMIF_SDCFG 0x62A73832 +#define EMIF_PHYCFG 0x00000110 + +#if defined(CONFIG_TI816X_DDR3_SW_LEVELING) +/* These values are obtained from the CCS app */ +#define RD_DQS_GATE 0x1B3 +#define RD_DQS 0x35 +#define WR_DQS 0x93 + +#endif + +#endif /* CONFIG_TI816X_DDR_796 */ + + +#if defined(CONFIG_TI816X_DDR3_SW_LEVELING) +#define WR_DQS_RATIO_BYTE_LANE3 ((WR_DQS << 10) | WR_DQS) +#define WR_DQS_RATIO_BYTE_LANE2 ((WR_DQS << 10) | WR_DQS) +#define WR_DQS_RATIO_BYTE_LANE1 ((WR_DQS << 10) | WR_DQS) +#define WR_DQS_RATIO_BYTE_LANE0 ((WR_DQS << 10) | WR_DQS) + +#define WR_DATA_RATIO_BYTE_LANE3 (((WR_DQS + 0x40) << 10) | (WR_DQS + 0x40)) +#define WR_DATA_RATIO_BYTE_LANE2 (((WR_DQS + 0x40) << 10) | (WR_DQS + 0x40)) +#define WR_DATA_RATIO_BYTE_LANE1 (((WR_DQS + 0x40) << 10) | (WR_DQS + 0x40)) +#define WR_DATA_RATIO_BYTE_LANE0 (((WR_DQS + 0x40) << 10) | (WR_DQS + 0x40)) + +#define RD_DQS_RATIO ((RD_DQS << 10) | RD_DQS) + +#define DQS_GATE_BYTE_LANE0 ((RD_DQS_GATE << 10) | RD_DQS_GATE) +#define DQS_GATE_BYTE_LANE1 ((RD_DQS_GATE << 10) | RD_DQS_GATE) +#define DQS_GATE_BYTE_LANE2 ((RD_DQS_GATE << 10) | RD_DQS_GATE) +#define DQS_GATE_BYTE_LANE3 ((RD_DQS_GATE << 10) | RD_DQS_GATE) + +#endif /* CONFIG_TI816X_DDR3_SW_LEVELING */ + +#endif /* CONFIG_TI816X_EVM_DDR3 */ + +#ifdef CONFIG_TI816X_EVM_DDR2 + +#define INVERT_CLK_OUT 0x0 +#define CMD_SLAVE_RATIO 0x80 +/* + * DDR2 ratio values. These are board dependent + * obtained from sweep experiments + */ + +/* EVM 400 MHz clock Settings */ + +#define WR_DQS_RATIO_BYTE_LANE3 ((0x4a << 10) | 0x4a) +#define WR_DQS_RATIO_BYTE_LANE2 ((0x4a << 10) | 0x4a) +#define WR_DQS_RATIO_BYTE_LANE1 ((0x4a << 10) | 0x4a) +#define WR_DQS_RATIO_BYTE_LANE0 ((0x4a << 10) | 0x4a) + +#define WR_DATA_RATIO_BYTE_LANE3 (((0x4a + 0x40) << 10) | (0x4a + 0x40)) +#define WR_DATA_RATIO_BYTE_LANE2 (((0x4a + 0x40) << 10) | (0x4a + 0x40)) +#define WR_DATA_RATIO_BYTE_LANE1 (((0x4a + 0x40) << 10) | (0x4a + 0x40)) +#define WR_DATA_RATIO_BYTE_LANE0 (((0x4a + 0x40) << 10) | (0x4a + 0x40)) + +#define RD_DQS_RATIO ((0x40 << 10) | 0x40) + +#define DQS_GATE_BYTE_LANE0 ((0x13a << 10) | 0x13a) +#define DQS_GATE_BYTE_LANE1 ((0x13a << 10) | 0x13a) +#define DQS_GATE_BYTE_LANE2 ((0x13a << 10) | 0x13a) +#define DQS_GATE_BYTE_LANE3 ((0x13a << 10) | 0x13a) + +/* + * EMIF Paramters + */ +#define EMIF_TIM1 0xAAB15E2 +#define EMIF_TIM2 0x423631D2 +#define EMIF_TIM3 0x80032F +#define EMIF_SDREF 0x10000C30 +/* 32 bit ddr2, CL=6, CWL=5, 13 rows, 8 banks, 10 bit column, 2 CS */ +#define EMIF_SDCFG 0x43801A3A + +/* + * TI816x PG1.0 EMIF_PHYCFG 0x0000030B local odt = 3, read latency = 11 + * TI816x PG1.1 EMIF_PHYCFG 0x0000010B local odt = 1, read latency = 11 + */ +#define EMIF_PHYCFG (pg_val_ti816x(0x0000030B, 0x0000010B)) + +#endif /* CONFIG_TI816X_EVM_DDR2 */ +#endif /* _DDR_DEFS_TI816X_H */ diff --git a/arch/arm/include/asm/arch-am33xx/hardware.h b/arch/arm/include/asm/arch-am33xx/hardware.h index 5a27f9c..7f3b555 100644 --- a/arch/arm/include/asm/arch-am33xx/hardware.h +++ b/arch/arm/include/asm/arch-am33xx/hardware.h @@ -23,6 +23,8 @@ #include <asm/arch/omap.h> #ifdef CONFIG_AM33XX #include <asm/arch/hardware_am33xx.h> +#elif defined(CONFIG_TI816X) +#include <asm/arch/hardware_ti816x.h> #elif defined(CONFIG_TI814X) #include <asm/arch/hardware_ti814x.h> #endif @@ -67,15 +69,10 @@ /* DDR Base address */ #define DDR_CTRL_ADDR 0x44E10E04 #define DDR_CONTROL_BASE_ADDR 0x44E11404 -#define DDR_PHY_CMD_ADDR2 0x47C0C800 -#define DDR_PHY_DATA_ADDR2 0x47C0C8C8
/* UART */ #define DEFAULT_UART_BASE UART0_BASE
-#define DDRPHY_0_CONFIG_BASE (CTRL_BASE + 0x1400) -#define DDRPHY_CONFIG_BASE DDRPHY_0_CONFIG_BASE - /* GPMC Base address */ #define GPMC_BASE 0x50000000
diff --git a/arch/arm/include/asm/arch-am33xx/hardware_am33xx.h b/arch/arm/include/asm/arch-am33xx/hardware_am33xx.h index fa02f19..553c3bd 100644 --- a/arch/arm/include/asm/arch-am33xx/hardware_am33xx.h +++ b/arch/arm/include/asm/arch-am33xx/hardware_am33xx.h @@ -43,8 +43,13 @@ /* DDR Base address */ #define DDR_PHY_CMD_ADDR 0x44E12000 #define DDR_PHY_DATA_ADDR 0x44E120C8 +#define DDR_PHY_CMD_ADDR2 0x47C0C800 +#define DDR_PHY_DATA_ADDR2 0x47C0C8C8 #define DDR_DATA_REGS_NR 2
+#define DDRPHY_0_CONFIG_BASE (CTRL_BASE + 0x1400) +#define DDRPHY_CONFIG_BASE DDRPHY_0_CONFIG_BASE + /* CPSW Config space */ #define CPSW_MDIO_BASE 0x4A101000
diff --git a/arch/arm/include/asm/arch-am33xx/hardware_ti814x.h b/arch/arm/include/asm/arch-am33xx/hardware_ti814x.h index a950ac3..c075274 100644 --- a/arch/arm/include/asm/arch-am33xx/hardware_ti814x.h +++ b/arch/arm/include/asm/arch-am33xx/hardware_ti814x.h @@ -42,8 +42,13 @@ /* DDR Base address */ #define DDR_PHY_CMD_ADDR 0x47C0C400 #define DDR_PHY_DATA_ADDR 0x47C0C4C8 +#define DDR_PHY_CMD_ADDR2 0x47C0C800 +#define DDR_PHY_DATA_ADDR2 0x47C0C8C8 #define DDR_DATA_REGS_NR 4
+#define DDRPHY_0_CONFIG_BASE (CTRL_BASE + 0x1400) +#define DDRPHY_CONFIG_BASE DDRPHY_0_CONFIG_BASE + /* CPSW Config space */ #define CPSW_MDIO_BASE 0x4A100800
diff --git a/arch/arm/include/asm/arch-am33xx/hardware_ti816x.h b/arch/arm/include/asm/arch-am33xx/hardware_ti816x.h new file mode 100644 index 0000000..60daf55 --- /dev/null +++ b/arch/arm/include/asm/arch-am33xx/hardware_ti816x.h @@ -0,0 +1,56 @@ +/* + * hardware_ti816x.h + * + * TI816x hardware specific header + * + * Copyright (C) 2013, Adeneo Embedded <www.adeneo-embedded.com> + * Antoine Tenart, atenart@adeneo-embedded.com + * Based on TI-PSP-04.00.02.14 + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR /PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef __AM33XX_HARDWARE_TI816X_H +#define __AM33XX_HARDWARE_TI816X_H + +/* Watchdog Timer */ +#define WDT_BASE 0x480C2000 + +/* Control Module Base Address */ +#define CTRL_BASE 0x48140000 + +/* PRCM Base Address */ +#define PRCM_BASE 0x48180000 + +/* VTP Base address */ +#define VTP0_CTRL_ADDR 0x48198358 + +/* DDR Base address */ +#define DDR_PHY_CMD_ADDR 0x48198000 +#define DDR_PHY_DATA_ADDR 0x481980C8 +#define DDR_PHY_CMD_ADDR2 0x4819A000 +#define DDR_PHY_DATA_ADDR2 0x4819A0C8 +#define DDR_DATA_REGS_NR 4 + +/* UART */ +#define UART0_BASE 0x48020000 +#define UART1_BASE 0x48022000 +#define UART2_BASE 0x48024000 + +#define DDRPHY_0_CONFIG_BASE 0x48198000 +#define DDRPHY_1_CONFIG_BASE 0x4819a000 +#define DDRPHY_CONFIG_BASE ((emif == 0) ? \ + DDRPHY_0_CONFIG_BASE : DDRPHY_1_CONFIG_BASE) + +/* RTC base address */ +#define RTC_BASE 0x480C0000 + +#endif /* __AM33XX_HARDWARE_TI816X_H */ diff --git a/arch/arm/include/asm/arch-am33xx/mmc_host_def.h b/arch/arm/include/asm/arch-am33xx/mmc_host_def.h index e0a3b8b..09d7a77 100644 --- a/arch/arm/include/asm/arch-am33xx/mmc_host_def.h +++ b/arch/arm/include/asm/arch-am33xx/mmc_host_def.h @@ -155,6 +155,8 @@ typedef struct hsmmc { /* Clock Configurations and Macros */ #ifdef CONFIG_AM33XX #define MMC_CLOCK_REFERENCE 96 /* MHz */ +#elif defined(CONFIG_TI816X) +#define MMC_CLOCK_REFERENCE 48 /* MHz */ #elif defined(CONFIG_TI814X) #define MMC_CLOCK_REFERENCE 192 /* MHz */ #endif diff --git a/arch/arm/include/asm/arch-am33xx/mux.h b/arch/arm/include/asm/arch-am33xx/mux.h index 1c6b65f..4caa4d8 100644 --- a/arch/arm/include/asm/arch-am33xx/mux.h +++ b/arch/arm/include/asm/arch-am33xx/mux.h @@ -23,6 +23,8 @@ #include <asm/arch/mux_am33xx.h> #elif defined(CONFIG_TI814X) #include <asm/arch/mux_ti814x.h> +#elif defined(CONFIG_TI816X) +#include <asm/arch/mux_ti816x.h> #endif
struct module_pin_mux { diff --git a/arch/arm/include/asm/arch-am33xx/mux_ti816x.h b/arch/arm/include/asm/arch-am33xx/mux_ti816x.h new file mode 100644 index 0000000..0fcd49e --- /dev/null +++ b/arch/arm/include/asm/arch-am33xx/mux_ti816x.h @@ -0,0 +1,363 @@ +/* + * mux_ti816x.h + * + * Copyright (C) 2013, Adeneo Embedded <www.adeneo-embedded.com> + * Antoine Tenart, atenart@adeneo-embedded.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation version 2. + * + * This program is distributed "as is" WITHOUT ANY WARRANTY of any + * kind, whether express or implied; without even the implied warranty + * of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef _MUX_TI816X_H_ +#define _MUX_TI816X_H_ + +#include <common.h> +#include <asm/io.h> + +#define MUX_CFG(value, offset) \ + __raw_writel(value, (CTRL_BASE + offset)); + +#define PULLDOWN_EN (0x0 << 4) /* Pull Down Selection */ +#define PULLUP_EN (0x1 << 4) /* Pull Up Selection */ +#define PULLUDEN (0x0 << 3) /* Pull up enabled */ +#define PULLUDDIS (0x1 << 3) /* Pull up disabled */ +#define MODE(val) val /* used for Readability */ + + +/* + * PAD CONTROL OFFSETS + * Field names corresponds to the pad signal name + */ +struct pad_signals { + int pincntl1; + int pincntl2; + int pincntl3; + int pincntl4; + int pincntl5; + int pincntl6; + int pincntl7; + int pincntl8; + int pincntl9; + int pincntl10; + int pincntl11; + int pincntl12; + int pincntl13; + int pincntl14; + int pincntl15; + int pincntl16; + int pincntl17; + int pincntl18; + int pincntl19; + int pincntl20; + int pincntl21; + int pincntl22; + int pincntl23; + int pincntl24; + int pincntl25; + int pincntl26; + int pincntl27; + int pincntl28; + int pincntl29; + int pincntl30; + int pincntl31; + int pincntl32; + int pincntl33; + int pincntl34; + int pincntl35; + int pincntl36; + int pincntl37; + int pincntl38; + int pincntl39; + int pincntl40; + int pincntl41; + int pincntl42; + int pincntl43; + int pincntl44; + int pincntl45; + int pincntl46; + int pincntl47; + int pincntl48; + int pincntl49; + int pincntl50; + int pincntl51; + int pincntl52; + int pincntl53; + int pincntl54; + int pincntl55; + int pincntl56; + int pincntl57; + int pincntl58; + int pincntl59; + int pincntl60; + int pincntl61; + int pincntl62; + int pincntl63; + int pincntl64; + int pincntl65; + int pincntl66; + int pincntl67; + int pincntl68; + int pincntl69; + int pincntl70; + int pincntl71; + int pincntl72; + int pincntl73; + int pincntl74; + int pincntl75; + int pincntl76; + int pincntl77; + int pincntl78; + int pincntl79; + int pincntl80; + int pincntl81; + int pincntl82; + int pincntl83; + int pincntl84; + int pincntl85; + int pincntl86; + int pincntl87; + int pincntl88; + int pincntl89; + int pincntl90; + int pincntl91; + int pincntl92; + int pincntl93; + int pincntl94; + int pincntl95; + int pincntl96; + int pincntl97; + int pincntl98; + int pincntl99; + int pincntl100; + int pincntl101; + int pincntl102; + int pincntl103; + int pincntl104; + int pincntl105; + int pincntl106; + int pincntl107; + int pincntl108; + int pincntl109; + int pincntl110; + int pincntl111; + int pincntl112; + int pincntl113; + int pincntl114; + int pincntl115; + int pincntl116; + int pincntl117; + int pincntl118; + int pincntl119; + int pincntl120; + int pincntl121; + int pincntl122; + int pincntl123; + int pincntl124; + int pincntl125; + int pincntl126; + int pincntl127; + int pincntl128; + int pincntl129; + int pincntl130; + int pincntl131; + int pincntl132; + int pincntl133; + int pincntl134; + int pincntl135; + int pincntl136; + int pincntl137; + int pincntl138; + int pincntl139; + int pincntl140; + int pincntl141; + int pincntl142; + int pincntl143; + int pincntl144; + int pincntl145; + int pincntl146; + int pincntl147; + int pincntl148; + int pincntl149; + int pincntl150; + int pincntl151; + int pincntl152; + int pincntl153; + int pincntl154; + int pincntl155; + int pincntl156; + int pincntl157; + int pincntl158; + int pincntl159; + int pincntl160; + int pincntl161; + int pincntl162; + int pincntl163; + int pincntl164; + int pincntl165; + int pincntl166; + int pincntl167; + int pincntl168; + int pincntl169; + int pincntl170; + int pincntl171; + int pincntl172; + int pincntl173; + int pincntl174; + int pincntl175; + int pincntl176; + int pincntl177; + int pincntl178; + int pincntl179; + int pincntl180; + int pincntl181; + int pincntl182; + int pincntl183; + int pincntl184; + int pincntl185; + int pincntl186; + int pincntl187; + int pincntl188; + int pincntl189; + int pincntl190; + int pincntl191; + int pincntl192; + int pincntl193; + int pincntl194; + int pincntl195; + int pincntl196; + int pincntl197; + int pincntl198; + int pincntl199; + int pincntl200; + int pincntl201; + int pincntl202; + int pincntl203; + int pincntl204; + int pincntl205; + int pincntl206; + int pincntl207; + int pincntl208; + int pincntl209; + int pincntl210; + int pincntl211; + int pincntl212; + int pincntl213; + int pincntl214; + int pincntl215; + int pincntl216; + int pincntl217; + int pincntl218; + int pincntl219; + int pincntl220; + int pincntl221; + int pincntl222; + int pincntl223; + int pincntl224; + int pincntl225; + int pincntl226; + int pincntl227; + int pincntl228; + int pincntl229; + int pincntl230; + int pincntl231; + int pincntl232; + int pincntl233; + int pincntl234; + int pincntl235; + int pincntl236; + int pincntl237; + int pincntl238; + int pincntl239; + int pincntl240; + int pincntl241; + int pincntl242; + int pincntl243; + int pincntl244; + int pincntl245; + int pincntl246; + int pincntl247; + int pincntl248; + int pincntl249; + int pincntl250; + int pincntl251; + int pincntl252; + int pincntl253; + int pincntl254; + int pincntl255; + int pincntl256; + int pincntl257; + int pincntl258; + int pincntl259; + int pincntl260; + int pincntl261; + int pincntl262; + int pincntl263; + int pincntl264; + int pincntl265; + int pincntl266; + int pincntl267; + int pincntl268; + int pincntl269; + int pincntl270; + int pincntl271; + int pincntl272; + int pincntl273; + int pincntl274; + int pincntl275; + int pincntl276; + int pincntl277; + int pincntl278; + int pincntl279; + int pincntl280; + int pincntl281; + int pincntl282; + int pincntl283; + int pincntl284; + int pincntl285; + int pincntl286; + int pincntl287; + int pincntl288; + int pincntl289; + int pincntl290; + int pincntl291; + int pincntl292; + int pincntl293; + int pincntl294; + int pincntl295; + int pincntl296; + int pincntl297; + int pincntl298; + int pincntl299; + int pincntl300; + int pincntl301; + int pincntl302; + int pincntl303; + int pincntl304; + int pincntl305; + int pincntl306; + int pincntl307; + int pincntl308; + int pincntl309; + int pincntl310; + int pincntl311; + int pincntl312; + int pincntl313; + int pincntl314; + int pincntl315; + int pincntl316; + int pincntl317; + int pincntl318; + int pincntl319; + int pincntl320; + int pincntl321; + int pincntl322; + int pincntl323; +}; + +#endif /* endif _MUX_TI816X_H_ */
TENART Antoine
