[U-Boot] [PATCH 0/3] Add raw read support and use it in pxa3xx NAND driver
When using 2kiB-pages NAND chips requesting an 8-bit strength ECC, the layout used is a bit particular and it happens that the ECC engine tries to correct uncorrectable errors on empty pages, producing bitflips.
To avoid such situation, raw read support is added to the pxa3xx_nand driver, and then used to re-read the page (in raw mode) upon uncorrectable error detection to know if there is an actual ECC mismatch or if the page is empty. This way we avoid seeing the bitflips created by the hardware ECC engine.
Once this done, we can revert the hack that was done in the driver to enlarge the last spare area for this layout to 64B instead of 32B, breaking U-Boot/Linux compatibility and preventing the BootROM to boot from NAND.
Thanks, Miquèl
Miquel Raynal (3): mtd: nand: pxa3xx: add raw read support mtd: nand: pxa3xx: re-read a page in raw mode on uncorrectable error mtd: rawnand: pxa3xx: fix 2kiB pages with 8b strength chips layout
drivers/mtd/nand/raw/pxa3xx_nand.c | 143 +++++++++++++++++++++++++---- 1 file changed, 124 insertions(+), 19 deletions(-)
Raw read support is added by editing a few code sections:
->handle_data_pio() includes the ECC bytes that are not consumed anymore by the ECC engine.
->prepare_set_command() is changed so that the ECC bytes are requested as part of the data I/O length.
->drain_fifo() shall also avoid checking the R/B pin too often when in raw mode.
->read_page_raw()/->read_oob_raw() are written from scratch.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com --- drivers/mtd/nand/raw/pxa3xx_nand.c | 98 ++++++++++++++++++++++++++++-- 1 file changed, 92 insertions(+), 6 deletions(-)
diff --git a/drivers/mtd/nand/raw/pxa3xx_nand.c b/drivers/mtd/nand/raw/pxa3xx_nand.c index 4c783f1e1e..454597355b 100644 --- a/drivers/mtd/nand/raw/pxa3xx_nand.c +++ b/drivers/mtd/nand/raw/pxa3xx_nand.c @@ -195,6 +195,7 @@ struct pxa3xx_nand_info {
int cs; int use_ecc; /* use HW ECC ? */ + int force_raw; /* prevent use_ecc to be set */ int ecc_bch; /* using BCH ECC? */ int use_spare; /* use spare ? */ int need_wait; @@ -579,7 +580,7 @@ static void disable_int(struct pxa3xx_nand_info *info, uint32_t int_mask)
static void drain_fifo(struct pxa3xx_nand_info *info, void *data, int len) { - if (info->ecc_bch) { + if (info->ecc_bch && !info->force_raw) { u32 ts;
/* @@ -612,12 +613,22 @@ static void drain_fifo(struct pxa3xx_nand_info *info, void *data, int len)
static void handle_data_pio(struct pxa3xx_nand_info *info) { + int data_len = info->step_chunk_size; + + /* + * In raw mode, include the spare area and the ECC bytes that are not + * consumed by the controller in the data section. Do not reorganize + * here, do it in the ->read_page_raw() handler instead. + */ + if (info->force_raw) + data_len += info->step_spare_size + info->ecc_size; + switch (info->state) { case STATE_PIO_WRITING: if (info->step_chunk_size) writesl(info->mmio_base + NDDB, info->data_buff + info->data_buff_pos, - DIV_ROUND_UP(info->step_chunk_size, 4)); + DIV_ROUND_UP(data_len, 4));
if (info->step_spare_size) writesl(info->mmio_base + NDDB, @@ -628,7 +639,10 @@ static void handle_data_pio(struct pxa3xx_nand_info *info) if (info->step_chunk_size) drain_fifo(info, info->data_buff + info->data_buff_pos, - DIV_ROUND_UP(info->step_chunk_size, 4)); + DIV_ROUND_UP(data_len, 4)); + + if (info->force_raw) + break;
if (info->step_spare_size) drain_fifo(info, @@ -642,7 +656,7 @@ static void handle_data_pio(struct pxa3xx_nand_info *info) }
/* Update buffer pointers for multi-page read/write */ - info->data_buff_pos += info->step_chunk_size; + info->data_buff_pos += data_len; info->oob_buff_pos += info->step_spare_size; }
@@ -796,7 +810,8 @@ static void prepare_start_command(struct pxa3xx_nand_info *info, int command) case NAND_CMD_READ0: case NAND_CMD_READOOB: case NAND_CMD_PAGEPROG: - info->use_ecc = 1; + if (!info->force_raw) + info->use_ecc = 1; break; case NAND_CMD_PARAM: info->use_spare = 0; @@ -866,7 +881,13 @@ static int prepare_set_command(struct pxa3xx_nand_info *info, int command, * which is either naked-read or last-read according to the * state. */ - if (mtd->writesize == info->chunk_size) { + if (info->force_raw) { + info->ndcb0 |= NDCB0_DBC | (NAND_CMD_READSTART << 8) | + NDCB0_LEN_OVRD | + NDCB0_EXT_CMD_TYPE(ext_cmd_type); + info->ndcb3 = info->step_chunk_size + + info->step_spare_size + info->ecc_size; + } else if (mtd->writesize == info->chunk_size) { info->ndcb0 |= NDCB0_DBC | (NAND_CMD_READSTART << 8); } else if (mtd->writesize > info->chunk_size) { info->ndcb0 |= NDCB0_DBC | (NAND_CMD_READSTART << 8) @@ -1238,6 +1259,69 @@ static int pxa3xx_nand_read_page_hwecc(struct mtd_info *mtd, return info->max_bitflips; }
+static int pxa3xx_nand_read_page_raw(struct mtd_info *mtd, + struct nand_chip *chip, uint8_t *buf, + int oob_required, int page) +{ + struct pxa3xx_nand_host *host = chip->priv; + struct pxa3xx_nand_info *info = host->info_data; + int chunk, ecc_off_buf; + + if (!info->ecc_bch) + return -ENOTSUPP; + + /* + * Set the force_raw boolean, then re-call ->cmdfunc() that will run + * pxa3xx_nand_start(), which will actually disable the ECC engine. + */ + info->force_raw = true; + chip->cmdfunc(mtd, NAND_CMD_READ0, 0x00, page); + + ecc_off_buf = (info->nfullchunks * info->spare_size) + + info->last_spare_size; + for (chunk = 0; chunk < info->nfullchunks; chunk++) { + chip->read_buf(mtd, + buf + (chunk * info->chunk_size), + info->chunk_size); + chip->read_buf(mtd, + chip->oob_poi + + (chunk * (info->spare_size)), + info->spare_size); + chip->read_buf(mtd, + chip->oob_poi + ecc_off_buf + + (chunk * (info->ecc_size)), + info->ecc_size - 2); + } + + if (info->ntotalchunks > info->nfullchunks) { + chip->read_buf(mtd, + buf + (info->nfullchunks * info->chunk_size), + info->last_chunk_size); + chip->read_buf(mtd, + chip->oob_poi + + (info->nfullchunks * (info->spare_size)), + info->last_spare_size); + chip->read_buf(mtd, + chip->oob_poi + ecc_off_buf + + (info->nfullchunks * (info->ecc_size)), + info->ecc_size - 2); + } + + info->force_raw = false; + + return 0; +} + +static int pxa3xx_nand_read_oob_raw(struct mtd_info *mtd, + struct nand_chip *chip, int page) +{ + /* Invalidate page cache */ + chip->pagebuf = -1; + + return chip->ecc.read_page_raw(mtd, chip, chip->buffers->databuf, true, + page); +} + static uint8_t pxa3xx_nand_read_byte(struct mtd_info *mtd) { struct nand_chip *chip = mtd_to_nand(mtd); @@ -1669,6 +1753,8 @@ static int alloc_nand_resource(struct pxa3xx_nand_info *info)
nand_set_controller_data(chip, host); chip->ecc.read_page = pxa3xx_nand_read_page_hwecc; + chip->ecc.read_page_raw = pxa3xx_nand_read_page_raw; + chip->ecc.read_oob_raw = pxa3xx_nand_read_oob_raw; chip->ecc.write_page = pxa3xx_nand_write_page_hwecc; chip->controller = &info->controller; chip->waitfunc = pxa3xx_nand_waitfunc;
This only applies on BCH path.
When an empty page is read, it triggers an uncorrectable error. While this is expected, the ECC engine might produce itself bitflips in the read data under certain layouts. To overcome this situation, always re-read the entire page in raw mode and check for the whole page to be empty.
Also report the right number of bitflips if there are any.
Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com --- drivers/mtd/nand/raw/pxa3xx_nand.c | 27 +++++++++++++++++++++++---- 1 file changed, 23 insertions(+), 4 deletions(-)
diff --git a/drivers/mtd/nand/raw/pxa3xx_nand.c b/drivers/mtd/nand/raw/pxa3xx_nand.c index 454597355b..492485b1d0 100644 --- a/drivers/mtd/nand/raw/pxa3xx_nand.c +++ b/drivers/mtd/nand/raw/pxa3xx_nand.c @@ -1237,6 +1237,7 @@ static int pxa3xx_nand_read_page_hwecc(struct mtd_info *mtd, { struct pxa3xx_nand_host *host = nand_get_controller_data(chip); struct pxa3xx_nand_info *info = host->info_data; + int bf;
chip->read_buf(mtd, buf, mtd->writesize); chip->read_buf(mtd, chip->oob_poi, mtd->oobsize); @@ -1244,12 +1245,30 @@ static int pxa3xx_nand_read_page_hwecc(struct mtd_info *mtd, if (info->retcode == ERR_CORERR && info->use_ecc) { mtd->ecc_stats.corrected += info->ecc_err_cnt;
- } else if (info->retcode == ERR_UNCORERR) { + } else if (info->retcode == ERR_UNCORERR && info->ecc_bch) { /* - * for blank page (all 0xff), HW will calculate its ECC as - * 0, which is different from the ECC information within - * OOB, ignore such uncorrectable errors + * Empty pages will trigger uncorrectable errors. Re-read the + * entire page in raw mode and check for bits not being "1". + * If there are more than the supported strength, then it means + * this is an actual uncorrectable error. */ + chip->ecc.read_page_raw(mtd, chip, buf, oob_required, page); + bf = nand_check_erased_ecc_chunk(buf, mtd->writesize, + chip->oob_poi, mtd->oobsize, + NULL, 0, chip->ecc.strength); + if (bf < 0) { + mtd->ecc_stats.failed++; + } else if (bf) { + mtd->ecc_stats.corrected += bf; + info->max_bitflips = max_t(unsigned int, + info->max_bitflips, bf); + info->retcode = ERR_CORERR; + } else { + info->retcode = ERR_NONE; + } + + } else if (info->retcode == ERR_UNCORERR && !info->ecc_bch) { + /* Raw read is not supported with Hamming ECC engine */ if (is_buf_blank(buf, mtd->writesize)) info->retcode = ERR_NONE; else
The initial layout for such NAND chips was the following:
+----------------------------------------------------------------------------+ | 1024 (data) | 30 (ECC) | 1024 (data) | 30 (ECC) | 32 (free OOB) | 30 (ECC) | +----------------------------------------------------------------------------+
This layout has a weakness: reading empty pages trigger ECC errors (this is expected), but the hardware ECC engine tries to correct the data anyway and creates itself bitflips, hence bitflips are detected in erased pages while actually there are none in the NAND chip.
Two solutions have been found at the same time. One was to enlarge the free OOB area to 64 bytes, changing the layout to be:
+----------------------------------------------------------------------------+ | 1024 (data) | 30 (ECC) | 1024 (data) | 30 (ECC) | 64 (free OOB) | 30 (ECC) | +----------------------------------------------------------------------------+ ^^
The very big drawbacks of this solution are: 1/ It prevents booting from NAND. 2/ The current Linux driver (marvell_nand) does not have such problem because it already re-reads possible empty pages in raw mode before checking for bitflips. Using different layouts in U-Boot and Linux would simply not work.
As this driver does support raw reads now and uses it to check for empty pages, let's forget about this broken hack and return to the initial layout with only 32 free OOB bytes.
Fixes: ac56a3b30c ("mtd: nand: pxa3xx: add support for 2KB 8-bit flash") Signed-off-by: Miquel Raynal miquel.raynal@bootlin.com --- drivers/mtd/nand/raw/pxa3xx_nand.c | 18 +++++++++--------- 1 file changed, 9 insertions(+), 9 deletions(-)
diff --git a/drivers/mtd/nand/raw/pxa3xx_nand.c b/drivers/mtd/nand/raw/pxa3xx_nand.c index 492485b1d0..4d2712df4c 100644 --- a/drivers/mtd/nand/raw/pxa3xx_nand.c +++ b/drivers/mtd/nand/raw/pxa3xx_nand.c @@ -327,14 +327,14 @@ static struct nand_ecclayout ecc_layout_2KB_bch4bit = { static struct nand_ecclayout ecc_layout_2KB_bch8bit = { .eccbytes = 64, .eccpos = { - 64, 65, 66, 67, 68, 69, 70, 71, - 72, 73, 74, 75, 76, 77, 78, 79, - 80, 81, 82, 83, 84, 85, 86, 87, - 88, 89, 90, 91, 92, 93, 94, 95, - 96, 97, 98, 99, 100, 101, 102, 103, - 104, 105, 106, 107, 108, 109, 110, 111, - 112, 113, 114, 115, 116, 117, 118, 119, - 120, 121, 122, 123, 124, 125, 126, 127}, + 32, 33, 34, 35, 36, 37, 38, 39, + 40, 41, 42, 43, 44, 45, 46, 47, + 48, 49, 50, 51, 52, 53, 54, 55, + 56, 57, 58, 59, 60, 61, 62, 63, + 64, 65, 66, 67, 68, 69, 70, 71, + 72, 73, 74, 75, 76, 77, 78, 79, + 80, 81, 82, 83, 84, 85, 86, 87, + 88, 89, 90, 91, 92, 93, 94, 95}, .oobfree = { {1, 4}, {6, 26} } };
@@ -1591,7 +1591,7 @@ static int pxa_ecc_init(struct pxa3xx_nand_info *info, info->chunk_size = 1024; info->spare_size = 0; info->last_chunk_size = 1024; - info->last_spare_size = 64; + info->last_spare_size = 32; info->ecc_size = 32; ecc->mode = NAND_ECC_HW; ecc->size = info->chunk_size;
On Thu, Oct 11, 2018 at 9:16 PM Miquel Raynal miquel.raynal@bootlin.com wrote:
Thanks, Miquèl
Acked-by: Jagan Teki jagan@openedev.com
Thanks, Miquèl
Applied to u-boot-spi/master
Jagan Teki
Miquel Raynal
