[PATCH 1/3] arm: dts: Resync dts for BeagleBone and derivatives
Sync BeagleBone dts files & TPS dtsi files with Linux v5.17 and include the SanCloud BBE Extended WiFi dts added in v5.18-rc1. Also pull in changes to am33xx-l4.dtsi needed to support the BeagleBone Blue.
The change to use the cpsw switch driver (commit c477358e66a3 in Linux) is excluded from the sync as u-boot does not recognise the new compatible string.
Signed-off-by: Paul Barker paul.barker@sancloud.com --- arch/arm/dts/Makefile | 5 + arch/arm/dts/am335x-bone-common.dtsi | 5 + arch/arm/dts/am335x-boneblack-common.dtsi | 139 ---- ...common.dtsi => am335x-boneblack-hdmi.dtsi} | 28 - arch/arm/dts/am335x-boneblack-wireless.dts | 111 ++++ arch/arm/dts/am335x-boneblack.dts | 1 + arch/arm/dts/am335x-boneblue.dts | 617 ++++++++++++++++++ arch/arm/dts/am335x-bonegreen-wireless.dts | 127 ++++ ...be.dts => am335x-sancloud-bbe-common.dtsi} | 74 +-- .../dts/am335x-sancloud-bbe-extended-wifi.dts | 113 ++++ arch/arm/dts/am335x-sancloud-bbe-lite.dts | 50 ++ arch/arm/dts/am335x-sancloud-bbe.dts | 96 +-- arch/arm/dts/am33xx-l4.dtsi | 27 + arch/arm/dts/tps6507x.dtsi | 5 +- arch/arm/dts/tps65217.dtsi | 20 +- arch/arm/dts/tps65910.dtsi | 5 +- 16 files changed, 1082 insertions(+), 341 deletions(-) copy arch/arm/dts/{am335x-boneblack-common.dtsi => am335x-boneblack-hdmi.dtsi} (90%) create mode 100644 arch/arm/dts/am335x-boneblack-wireless.dts create mode 100644 arch/arm/dts/am335x-boneblue.dts create mode 100644 arch/arm/dts/am335x-bonegreen-wireless.dts copy arch/arm/dts/{am335x-sancloud-bbe.dts => am335x-sancloud-bbe-common.dtsi} (60%) create mode 100644 arch/arm/dts/am335x-sancloud-bbe-extended-wifi.dts create mode 100644 arch/arm/dts/am335x-sancloud-bbe-lite.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index cd9a820f9569..47a2b6e39f85 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -375,6 +375,8 @@ dtb-$(CONFIG_AM33XX) += \ am335x-baltos.dtb \ am335x-bone.dtb \ am335x-boneblack.dtb \ + am335x-boneblack-wireless.dtb \ + am335x-boneblue.dtb \ am335x-brppt1-mmc.dtb \ am335x-brppt1-nand.dtb \ am335x-brppt1-spi.dtb \ @@ -384,11 +386,14 @@ dtb-$(CONFIG_AM33XX) += \ am335x-evm.dtb \ am335x-evmsk.dtb \ am335x-bonegreen.dtb \ + am335x-bonegreen-wireless.dtb \ am335x-icev2.dtb \ am335x-pocketbeagle.dtb \ am335x-pxm50.dtb \ am335x-rut.dtb \ am335x-sancloud-bbe.dtb \ + am335x-sancloud-bbe-lite.dtb \ + am335x-sancloud-bbe-extended-wifi.dtb \ am335x-shc.dtb \ am335x-pdu001.dtb \ am335x-chiliboard.dtb \ diff --git a/arch/arm/dts/am335x-bone-common.dtsi b/arch/arm/dts/am335x-bone-common.dtsi index 35ec1a8df870..43fe03d096ac 100644 --- a/arch/arm/dts/am335x-bone-common.dtsi +++ b/arch/arm/dts/am335x-bone-common.dtsi @@ -397,4 +397,9 @@ &rtc { clocks = <&clk_32768_ck>, <&clk_24mhz_clkctrl AM3_CLK_24MHZ_CLKDIV32K_CLKCTRL 0>; clock-names = "ext-clk", "int-clk"; + system-power-controller; +}; + +&pruss_tm { + status = "okay"; }; diff --git a/arch/arm/dts/am335x-boneblack-common.dtsi b/arch/arm/dts/am335x-boneblack-common.dtsi index 64c3e9269f40..a7a8c61ef9b2 100644 --- a/arch/arm/dts/am335x-boneblack-common.dtsi +++ b/arch/arm/dts/am335x-boneblack-common.dtsi @@ -3,9 +3,6 @@ * Copyright (C) 2012 Texas Instruments Incorporated - https://www.ti.com/ */
-#include <dt-bindings/display/tda998x.h> -#include <dt-bindings/interrupt-controller/irq.h> - &ldo3_reg { regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; @@ -25,145 +22,9 @@ non-removable; };
-&am33xx_pinmux { - nxp_hdmi_bonelt_pins: nxp_hdmi_bonelt_pins { - pinctrl-single,pins = < - AM33XX_PADCONF(AM335X_PIN_XDMA_EVENT_INTR0, PIN_OUTPUT_PULLDOWN, MUX_MODE3) - AM33XX_PADCONF(AM335X_PIN_LCD_DATA0, PIN_OUTPUT, MUX_MODE0) - AM33XX_PADCONF(AM335X_PIN_LCD_DATA1, PIN_OUTPUT, MUX_MODE0) - AM33XX_PADCONF(AM335X_PIN_LCD_DATA2, PIN_OUTPUT, MUX_MODE0) - AM33XX_PADCONF(AM335X_PIN_LCD_DATA3, PIN_OUTPUT, MUX_MODE0) - AM33XX_PADCONF(AM335X_PIN_LCD_DATA4, PIN_OUTPUT, MUX_MODE0) - AM33XX_PADCONF(AM335X_PIN_LCD_DATA5, PIN_OUTPUT, MUX_MODE0) - AM33XX_PADCONF(AM335X_PIN_LCD_DATA6, PIN_OUTPUT, MUX_MODE0) - AM33XX_PADCONF(AM335X_PIN_LCD_DATA7, PIN_OUTPUT, MUX_MODE0) - AM33XX_PADCONF(AM335X_PIN_LCD_DATA8, PIN_OUTPUT, MUX_MODE0) - AM33XX_PADCONF(AM335X_PIN_LCD_DATA9, PIN_OUTPUT, MUX_MODE0) - AM33XX_PADCONF(AM335X_PIN_LCD_DATA10, PIN_OUTPUT, MUX_MODE0) - AM33XX_PADCONF(AM335X_PIN_LCD_DATA11, PIN_OUTPUT, MUX_MODE0) - AM33XX_PADCONF(AM335X_PIN_LCD_DATA12, PIN_OUTPUT, MUX_MODE0) - AM33XX_PADCONF(AM335X_PIN_LCD_DATA13, PIN_OUTPUT, MUX_MODE0) - AM33XX_PADCONF(AM335X_PIN_LCD_DATA14, PIN_OUTPUT, MUX_MODE0) - AM33XX_PADCONF(AM335X_PIN_LCD_DATA15, PIN_OUTPUT, MUX_MODE0) - AM33XX_PADCONF(AM335X_PIN_LCD_VSYNC, PIN_OUTPUT_PULLDOWN, MUX_MODE0) - AM33XX_PADCONF(AM335X_PIN_LCD_HSYNC, PIN_OUTPUT_PULLDOWN, MUX_MODE0) - AM33XX_PADCONF(AM335X_PIN_LCD_PCLK, PIN_OUTPUT_PULLDOWN, MUX_MODE0) - AM33XX_PADCONF(AM335X_PIN_LCD_AC_BIAS_EN, PIN_OUTPUT_PULLDOWN, MUX_MODE0) - >; - }; - - nxp_hdmi_bonelt_off_pins: nxp_hdmi_bonelt_off_pins { - pinctrl-single,pins = < - AM33XX_PADCONF(AM335X_PIN_XDMA_EVENT_INTR0, PIN_OUTPUT_PULLDOWN, MUX_MODE3) - >; - }; - - mcasp0_pins: mcasp0_pins { - pinctrl-single,pins = < - AM33XX_PADCONF(AM335X_PIN_MCASP0_AHCLKX, PIN_INPUT_PULLUP, MUX_MODE0) /* mcasp0_ahcklx.mcasp0_ahclkx */ - AM33XX_PADCONF(AM335X_PIN_MCASP0_AHCLKR, PIN_OUTPUT_PULLDOWN, MUX_MODE2) /* mcasp0_ahclkr.mcasp0_axr2*/ - AM33XX_PADCONF(AM335X_PIN_MCASP0_FSX, PIN_OUTPUT_PULLUP, MUX_MODE0) - AM33XX_PADCONF(AM335X_PIN_MCASP0_ACLKX, PIN_OUTPUT_PULLDOWN, MUX_MODE0) - AM33XX_PADCONF(AM335X_PIN_GPMC_A11, PIN_OUTPUT_PULLDOWN, MUX_MODE7) /* gpmc_a11.GPIO1_27 */ - >; - }; -}; - -&lcdc { - status = "okay"; - - /* If you want to get 24 bit RGB and 16 BGR mode instead of - * current 16 bit RGB and 24 BGR modes, set the propety - * below to "crossed" and uncomment the video-ports -property - * in tda19988 node. - */ - blue-and-red-wiring = "straight"; - - port { - lcdc_0: endpoint@0 { - remote-endpoint = <&hdmi_0>; - }; - }; -}; - -&i2c0 { - tda19988: tda19988@70 { - compatible = "nxp,tda998x"; - reg = <0x70>; - nxp,calib-gpios = <&gpio1 25 0>; - interrupts-extended = <&gpio1 25 IRQ_TYPE_LEVEL_LOW>; - - pinctrl-names = "default", "off"; - pinctrl-0 = <&nxp_hdmi_bonelt_pins>; - pinctrl-1 = <&nxp_hdmi_bonelt_off_pins>; - - /* Convert 24bit BGR to RGB, e.g. cross red and blue wiring */ - /* video-ports = <0x234501>; */ - - #sound-dai-cells = <0>; - audio-ports = < TDA998x_I2S 0x03>; - - ports { - port@0 { - hdmi_0: endpoint@0 { - remote-endpoint = <&lcdc_0>; - }; - }; - }; - }; -}; - -&rtc { - system-power-controller; -}; - -&mcasp0 { - #sound-dai-cells = <0>; - pinctrl-names = "default"; - pinctrl-0 = <&mcasp0_pins>; - status = "okay"; - op-mode = <0>; /* MCASP_IIS_MODE */ - tdm-slots = <2>; - serial-dir = < /* 0: INACTIVE, 1: TX, 2: RX */ - 0 0 1 0 - >; - tx-num-evt = <32>; - rx-num-evt = <32>; -}; - / { memory@80000000 { device_type = "memory"; reg = <0x80000000 0x20000000>; /* 512 MB */ }; - - clk_mcasp0_fixed: clk_mcasp0_fixed { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <24576000>; - }; - - clk_mcasp0: clk_mcasp0 { - #clock-cells = <0>; - compatible = "gpio-gate-clock"; - clocks = <&clk_mcasp0_fixed>; - enable-gpios = <&gpio1 27 0>; /* BeagleBone Black Clk enable on GPIO1_27 */ - }; - - sound { - compatible = "simple-audio-card"; - simple-audio-card,name = "TI BeagleBone Black"; - simple-audio-card,format = "i2s"; - simple-audio-card,bitclock-master = <&dailink0_master>; - simple-audio-card,frame-master = <&dailink0_master>; - - dailink0_master: simple-audio-card,cpu { - sound-dai = <&mcasp0>; - clocks = <&clk_mcasp0>; - }; - - simple-audio-card,codec { - sound-dai = <&tda19988>; - }; - }; }; diff --git a/arch/arm/dts/am335x-boneblack-common.dtsi b/arch/arm/dts/am335x-boneblack-hdmi.dtsi similarity index 90% copy from arch/arm/dts/am335x-boneblack-common.dtsi copy to arch/arm/dts/am335x-boneblack-hdmi.dtsi index 64c3e9269f40..7cfddada9348 100644 --- a/arch/arm/dts/am335x-boneblack-common.dtsi +++ b/arch/arm/dts/am335x-boneblack-hdmi.dtsi @@ -6,25 +6,6 @@ #include <dt-bindings/display/tda998x.h> #include <dt-bindings/interrupt-controller/irq.h>
-&ldo3_reg { - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; -}; - -&mmc1 { - vmmc-supply = <&vmmcsd_fixed>; -}; - -&mmc2 { - vmmc-supply = <&vmmcsd_fixed>; - pinctrl-names = "default"; - pinctrl-0 = <&emmc_pins>; - bus-width = <8>; - status = "okay"; - non-removable; -}; - &am33xx_pinmux { nxp_hdmi_bonelt_pins: nxp_hdmi_bonelt_pins { pinctrl-single,pins = < @@ -113,10 +94,6 @@ }; };
-&rtc { - system-power-controller; -}; - &mcasp0 { #sound-dai-cells = <0>; pinctrl-names = "default"; @@ -132,11 +109,6 @@ };
/ { - memory@80000000 { - device_type = "memory"; - reg = <0x80000000 0x20000000>; /* 512 MB */ - }; - clk_mcasp0_fixed: clk_mcasp0_fixed { #clock-cells = <0>; compatible = "fixed-clock"; diff --git a/arch/arm/dts/am335x-boneblack-wireless.dts b/arch/arm/dts/am335x-boneblack-wireless.dts new file mode 100644 index 000000000000..8b2b24c80670 --- /dev/null +++ b/arch/arm/dts/am335x-boneblack-wireless.dts @@ -0,0 +1,111 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * Copyright (C) 2012 Texas Instruments Incorporated - https://www.ti.com/ + */ +/dts-v1/; + +#include "am33xx.dtsi" +#include "am335x-bone-common.dtsi" +#include "am335x-boneblack-common.dtsi" +#include "am335x-boneblack-hdmi.dtsi" +#include <dt-bindings/interrupt-controller/irq.h> + +/ { + model = "TI AM335x BeagleBone Black Wireless"; + compatible = "ti,am335x-bone-black-wireless", "ti,am335x-bone-black", "ti,am335x-bone", "ti,am33xx"; + + wlan_en_reg: fixedregulator@2 { + compatible = "regulator-fixed"; + regulator-name = "wlan-en-regulator"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + startup-delay-us= <70000>; + + /* WL_EN */ + gpio = <&gpio3 9 0>; + enable-active-high; + }; +}; + +&am33xx_pinmux { + bt_pins: pinmux_bt_pins { + pinctrl-single,pins = < + AM33XX_PADCONF(AM335X_PIN_MII1_TXD0, PIN_OUTPUT_PULLUP, MUX_MODE7) /* gmii1_txd0.gpio0_28 - BT_EN */ + >; + }; + + mmc3_pins: pinmux_mmc3_pins { + pinctrl-single,pins = < + AM33XX_PADCONF(AM335X_PIN_MII1_RXD1, PIN_INPUT_PULLUP, MUX_MODE6 ) /* (L15) gmii1_rxd1.mmc2_clk */ + AM33XX_PADCONF(AM335X_PIN_MII1_TX_EN, PIN_INPUT_PULLUP, MUX_MODE6 ) /* (J16) gmii1_txen.mmc2_cmd */ + AM33XX_PADCONF(AM335X_PIN_MII1_RX_DV, PIN_INPUT_PULLUP, MUX_MODE5 ) /* (J17) gmii1_rxdv.mmc2_dat0 */ + AM33XX_PADCONF(AM335X_PIN_MII1_TXD3, PIN_INPUT_PULLUP, MUX_MODE5 ) /* (J18) gmii1_txd3.mmc2_dat1 */ + AM33XX_PADCONF(AM335X_PIN_MII1_TXD2, PIN_INPUT_PULLUP, MUX_MODE5 ) /* (K15) gmii1_txd2.mmc2_dat2 */ + AM33XX_PADCONF(AM335X_PIN_MII1_COL, PIN_INPUT_PULLUP, MUX_MODE5 ) /* (H16) gmii1_col.mmc2_dat3 */ + >; + }; + + uart3_pins: pinmux_uart3_pins { + pinctrl-single,pins = < + AM33XX_PADCONF(AM335X_PIN_MII1_RXD3, PIN_INPUT_PULLUP, MUX_MODE1) /* gmii1_rxd3.uart3_rxd */ + AM33XX_PADCONF(AM335X_PIN_MII1_RXD2, PIN_OUTPUT_PULLDOWN, MUX_MODE1) /* gmii1_rxd2.uart3_txd */ + AM33XX_PADCONF(AM335X_PIN_MDIO, PIN_INPUT, MUX_MODE3) /* mdio_data.uart3_ctsn */ + AM33XX_PADCONF(AM335X_PIN_MDC, PIN_OUTPUT_PULLDOWN, MUX_MODE3) /* mdio_clk.uart3_rtsn */ + >; + }; + + wl18xx_pins: pinmux_wl18xx_pins { + pinctrl-single,pins = < + AM33XX_PADCONF(AM335X_PIN_MII1_TX_CLK, PIN_OUTPUT_PULLDOWN, MUX_MODE7) /* gmii1_txclk.gpio3_9 WL_EN */ + AM33XX_PADCONF(AM335X_PIN_RMII1_REF_CLK, PIN_INPUT_PULLDOWN, MUX_MODE7) /* rmii1_refclk.gpio0_29 WL_IRQ */ + AM33XX_PADCONF(AM335X_PIN_MII1_RX_CLK, PIN_OUTPUT_PULLUP, MUX_MODE7) /* gmii1_rxclk.gpio3_10 LS_BUF_EN */ + >; + }; +}; + +&mac { + status = "disabled"; +}; + +&mmc3 { + dmas = <&edma_xbar 12 0 1 + &edma_xbar 13 0 2>; + dma-names = "tx", "rx"; + status = "okay"; + vmmc-supply = <&wlan_en_reg>; + bus-width = <4>; + non-removable; + cap-power-off-card; + keep-power-in-suspend; + pinctrl-names = "default"; + pinctrl-0 = <&mmc3_pins &wl18xx_pins>; + + #address-cells = <1>; + #size-cells = <0>; + wlcore: wlcore@2 { + compatible = "ti,wl1835"; + reg = <2>; + interrupt-parent = <&gpio0>; + interrupts = <29 IRQ_TYPE_EDGE_RISING>; + }; +}; + +&uart3 { + pinctrl-names = "default"; + pinctrl-0 = <&uart3_pins &bt_pins>; + status = "okay"; + + bluetooth { + compatible = "ti,wl1835-st"; + enable-gpios = <&gpio0 28 GPIO_ACTIVE_HIGH>; + }; +}; + +&gpio3 { + ls-buf-en-hog { + gpio-hog; + gpios = <10 GPIO_ACTIVE_HIGH>; + output-high; + line-name = "LS_BUF_EN"; + }; +}; diff --git a/arch/arm/dts/am335x-boneblack.dts b/arch/arm/dts/am335x-boneblack.dts index e2ee8b8c07bc..9312197316f0 100644 --- a/arch/arm/dts/am335x-boneblack.dts +++ b/arch/arm/dts/am335x-boneblack.dts @@ -7,6 +7,7 @@ #include "am33xx.dtsi" #include "am335x-bone-common.dtsi" #include "am335x-boneblack-common.dtsi" +#include "am335x-boneblack-hdmi.dtsi"
/ { model = "TI AM335x BeagleBone Black"; diff --git a/arch/arm/dts/am335x-boneblue.dts b/arch/arm/dts/am335x-boneblue.dts new file mode 100644 index 000000000000..856fdf58b0f4 --- /dev/null +++ b/arch/arm/dts/am335x-boneblue.dts @@ -0,0 +1,617 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * Copyright (C) 2012 Texas Instruments Incorporated - https://www.ti.com/ + */ +/dts-v1/; + +#include "am33xx.dtsi" +#include "am335x-osd335x-common.dtsi" +#include <dt-bindings/interrupt-controller/irq.h> + +/ { + model = "TI AM335x BeagleBone Blue"; + compatible = "ti,am335x-bone-blue", "ti,am33xx"; + + chosen { + stdout-path = &uart0; + tick-timer = &timer2; + }; + + leds { + pinctrl-names = "default"; + pinctrl-0 = <&user_leds_s0>; + + compatible = "gpio-leds"; + + usr_0_led { + label = "beaglebone:green:usr0"; + gpios = <&gpio1 21 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + default-state = "off"; + }; + + usr_1_led { + label = "beaglebone:green:usr1"; + gpios = <&gpio1 22 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "mmc0"; + default-state = "off"; + }; + + usr_2_led { + label = "beaglebone:green:usr2"; + gpios = <&gpio1 23 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "cpu0"; + default-state = "off"; + }; + + usr_3_led { + label = "beaglebone:green:usr3"; + gpios = <&gpio1 24 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "mmc1"; + default-state = "off"; + }; + + wifi_led { + label = "wifi"; + gpios = <&gpio0 19 GPIO_ACTIVE_HIGH>; + default-state = "off"; + linux,default-trigger = "phy0assoc"; + }; + + red_led { + label = "red"; + gpios = <&gpio2 2 GPIO_ACTIVE_HIGH>; + default-state = "off"; + }; + + green_led { + label = "green"; + gpios = <&gpio2 3 GPIO_ACTIVE_HIGH>; + default-state = "off"; + }; + + batt_1_led { + label = "bat25"; + gpios = <&gpio0 27 GPIO_ACTIVE_HIGH>; + default-state = "off"; + }; + + batt_2_led { + label = "bat50"; + gpios = <&gpio0 11 GPIO_ACTIVE_HIGH>; + default-state = "off"; + }; + + batt_3_led { + label = "bat75"; + gpios = <&gpio1 29 GPIO_ACTIVE_HIGH>; + default-state = "off"; + }; + + batt_4_led { + label = "bat100"; + gpios = <&gpio0 26 GPIO_ACTIVE_HIGH>; + default-state = "off"; + }; + }; + + vmmcsd_fixed: fixedregulator0 { + compatible = "regulator-fixed"; + regulator-name = "vmmcsd_fixed"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + wlan_en_reg: fixedregulator@2 { + compatible = "regulator-fixed"; + regulator-name = "wlan-en-regulator"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + startup-delay-us= <70000>; + + /* WL_EN */ + gpio = <&gpio3 9 0>; + enable-active-high; + }; +}; + +&am33xx_pinmux { + user_leds_s0: user_leds_s0 { + pinctrl-single,pins = < + AM33XX_PADCONF(AM335X_PIN_GPMC_A5, PIN_OUTPUT, MUX_MODE7) /* (V15) gpmc_a5.gpio1[21] - USR_LED_0 */ + AM33XX_PADCONF(AM335X_PIN_GPMC_A6, PIN_OUTPUT, MUX_MODE7) /* (U15) gpmc_a6.gpio1[22] - USR_LED_1 */ + AM33XX_PADCONF(AM335X_PIN_GPMC_A7, PIN_OUTPUT, MUX_MODE7) /* (T15) gpmc_a7.gpio1[23] - USR_LED_2 */ + AM33XX_PADCONF(AM335X_PIN_GPMC_A8, PIN_OUTPUT, MUX_MODE7) /* (V16) gpmc_a8.gpio1[24] - USR_LED_3 */ + AM33XX_PADCONF(AM335X_PIN_XDMA_EVENT_INTR0, PIN_OUTPUT, MUX_MODE7) /* (A15) xdma_event_intr0.gpio0[19] - WIFI_LED */ + AM33XX_PADCONF(AM335X_PIN_GPMC_ADVN_ALE, PIN_OUTPUT, MUX_MODE7) /* (R7) gpmc_advn_ale.gpio2[2] - P8.7, LED_RED, GP1_PIN_5 */ + AM33XX_PADCONF(AM335X_PIN_GPMC_OEN_REN, PIN_OUTPUT, MUX_MODE7) /* (T7) gpmc_oen_ren.gpio2[3] - P8.8, LED_GREEN, GP1_PIN_6 */ + AM33XX_PADCONF(AM335X_PIN_GPMC_AD11, PIN_OUTPUT, MUX_MODE7) /* (U12) gpmc_ad11.gpio0[27] - P8.17, BATT_LED_1 */ + AM33XX_PADCONF(AM335X_PIN_LCD_DATA15, PIN_OUTPUT, MUX_MODE7) /* (T5) lcd_data15.gpio0[11] - P8.32, BATT_LED_2 */ + AM33XX_PADCONF(AM335X_PIN_GPMC_CSN0, PIN_OUTPUT, MUX_MODE7) /* (V6) gpmc_csn0.gpio1[29] - P8.26, BATT_LED_3 */ + AM33XX_PADCONF(AM335X_PIN_GPMC_AD10, PIN_OUTPUT, MUX_MODE7) /* (T11) gpmc_ad10.gpio0[26] - P8.14, BATT_LED_4 */ + + >; + }; + + i2c2_pins: pinmux_i2c2_pins { + pinctrl-single,pins = < + AM33XX_PADCONF(AM335X_PIN_UART1_CTSN, PIN_INPUT_PULLUP, MUX_MODE3) /* (D18) uart1_ctsn.I2C2_SDA */ + AM33XX_PADCONF(AM335X_PIN_UART1_RTSN, PIN_INPUT_PULLUP, MUX_MODE3) /* (D17) uart1_rtsn.I2C2_SCL */ + >; + }; + + /* UT0 */ + uart0_pins: pinmux_uart0_pins { + pinctrl-single,pins = < + AM33XX_PADCONF(AM335X_PIN_UART0_RXD, PIN_INPUT_PULLUP, MUX_MODE0) + AM33XX_PADCONF(AM335X_PIN_UART0_TXD, PIN_OUTPUT_PULLDOWN, MUX_MODE0) + >; + }; + + /* UT1 */ + uart1_pins: pinmux_uart1_pins { + pinctrl-single,pins = < + AM33XX_PADCONF(AM335X_PIN_UART1_RXD, PIN_INPUT_PULLUP, MUX_MODE0) + AM33XX_PADCONF(AM335X_PIN_UART1_TXD, PIN_OUTPUT_PULLDOWN, MUX_MODE0) + >; + }; + + /* GPS */ + uart2_pins: pinmux_uart2_pins { + pinctrl-single,pins = < + AM33XX_PADCONF(AM335X_PIN_SPI0_SCLK, PIN_INPUT_PULLUP, MUX_MODE1) /* (A17) spi0_sclk.uart2_rxd */ + AM33XX_PADCONF(AM335X_PIN_SPI0_D0, PIN_OUTPUT_PULLDOWN, MUX_MODE1) /* (B17) spi0_d0.uart2_txd */ + >; + }; + + /* DSM2 */ + uart4_pins: pinmux_uart4_pins { + pinctrl-single,pins = < + AM33XX_PADCONF(AM335X_PIN_GPMC_WAIT0, PIN_INPUT_PULLUP, MUX_MODE6) /* (T17) gpmc_wait0.uart4_rxd */ + >; + }; + + /* UT5 */ + uart5_pins: pinmux_uart5_pins { + pinctrl-single,pins = < + AM33XX_PADCONF(AM335X_PIN_LCD_DATA9, PIN_INPUT_PULLUP, MUX_MODE4) /* (U2) lcd_data9.uart5_rxd */ + AM33XX_PADCONF(AM335X_PIN_LCD_DATA8, PIN_OUTPUT_PULLDOWN, MUX_MODE4) /* (U1) lcd_data8.uart5_txd */ + >; + }; + + mmc1_pins: pinmux_mmc1_pins { + pinctrl-single,pins = < + AM33XX_PADCONF(AM335X_PIN_SPI0_CS1, PIN_INPUT, MUX_MODE7) /* (C15) spi0_cs1.gpio0[6] */ + >; + }; + + mmc2_pins: pinmux_mmc2_pins { + pinctrl-single,pins = < + AM33XX_PADCONF(AM335X_PIN_GPMC_CSN1, PIN_INPUT_PULLUP, MUX_MODE2) /* (U9) gpmc_csn1.mmc1_clk */ + AM33XX_PADCONF(AM335X_PIN_GPMC_CSN2, PIN_INPUT_PULLUP, MUX_MODE2) /* (V9) gpmc_csn2.mmc1_cmd */ + AM33XX_PADCONF(AM335X_PIN_GPMC_AD0, PIN_INPUT_PULLUP, MUX_MODE1) /* (U7) gpmc_ad0.mmc1_dat0 */ + AM33XX_PADCONF(AM335X_PIN_GPMC_AD1, PIN_INPUT_PULLUP, MUX_MODE1) /* (V7) gpmc_ad1.mmc1_dat1 */ + AM33XX_PADCONF(AM335X_PIN_GPMC_AD2, PIN_INPUT_PULLUP, MUX_MODE1) /* (R8) gpmc_ad2.mmc1_dat2 */ + AM33XX_PADCONF(AM335X_PIN_GPMC_AD3, PIN_INPUT_PULLUP, MUX_MODE1) /* (T8) gpmc_ad3.mmc1_dat3 */ + AM33XX_PADCONF(AM335X_PIN_GPMC_AD4, PIN_INPUT_PULLUP, MUX_MODE1) /* (U8) gpmc_ad4.mmc1_dat4 */ + AM33XX_PADCONF(AM335X_PIN_GPMC_AD5, PIN_INPUT_PULLUP, MUX_MODE1) /* (V8) gpmc_ad5.mmc1_dat5 */ + AM33XX_PADCONF(AM335X_PIN_GPMC_AD6, PIN_INPUT_PULLUP, MUX_MODE1) /* (R9) gpmc_ad6.mmc1_dat6 */ + AM33XX_PADCONF(AM335X_PIN_GPMC_AD7, PIN_INPUT_PULLUP, MUX_MODE1) /* (T9) gpmc_ad7.mmc1_dat7 */ + >; + }; + + mmc3_pins: pinmux_mmc3_pins { + pinctrl-single,pins = < + AM33XX_PADCONF(AM335X_PIN_MII1_RXD1, PIN_INPUT_PULLUP, MUX_MODE6) /* (L15) gmii1_rxd1.mmc2_clk */ + AM33XX_PADCONF(AM335X_PIN_MII1_TX_EN, PIN_INPUT_PULLUP, MUX_MODE6) /* (J16) gmii1_txen.mmc2_cmd */ + AM33XX_PADCONF(AM335X_PIN_MII1_RX_DV, PIN_INPUT_PULLUP, MUX_MODE5) /* (J17) gmii1_rxdv.mmc2_dat0 */ + AM33XX_PADCONF(AM335X_PIN_MII1_TXD3, PIN_INPUT_PULLUP, MUX_MODE5) /* (J18) gmii1_txd3.mmc2_dat1 */ + AM33XX_PADCONF(AM335X_PIN_MII1_TXD2, PIN_INPUT_PULLUP, MUX_MODE5) /* (K15) gmii1_txd2.mmc2_dat2 */ + AM33XX_PADCONF(AM335X_PIN_MII1_COL, PIN_INPUT_PULLUP, MUX_MODE5) /* (H16) gmii1_col.mmc2_dat3 */ + >; + }; + + bt_pins: pinmux_bt_pins { + pinctrl-single,pins = < + AM33XX_PADCONF(AM335X_PIN_MII1_TXD0, PIN_OUTPUT_PULLUP, MUX_MODE7) /* (K17) gmii1_txd0.gpio0[28] - BT_EN */ + >; + }; + + uart3_pins: pinmux_uart3_pins { + pinctrl-single,pins = < + AM33XX_PADCONF(AM335X_PIN_MII1_RXD3, PIN_INPUT_PULLUP, MUX_MODE1) /* (L17) gmii1_rxd3.uart3_rxd */ + AM33XX_PADCONF(AM335X_PIN_MII1_RXD2, PIN_OUTPUT_PULLDOWN, MUX_MODE1) /* (L16) gmii1_rxd2.uart3_txd */ + AM33XX_PADCONF(AM335X_PIN_MDIO, PIN_INPUT, MUX_MODE3) /* (M17) mdio_data.uart3_ctsn */ + AM33XX_PADCONF(AM335X_PIN_MDC, PIN_OUTPUT_PULLDOWN, MUX_MODE3) /* (M18) mdio_clk.uart3_rtsn */ + >; + }; + + wl18xx_pins: pinmux_wl18xx_pins { + pinctrl-single,pins = < + AM33XX_PADCONF(AM335X_PIN_MII1_TX_CLK, PIN_OUTPUT_PULLDOWN, MUX_MODE7) /* (K18) gmii1_txclk.gpio3[9] - WL_EN */ + AM33XX_PADCONF(AM335X_PIN_MII1_TXD1, PIN_INPUT_PULLDOWN, MUX_MODE7) /* (K16) gmii1_txd1.gpio0[21] - WL_IRQ */ + AM33XX_PADCONF(AM335X_PIN_MII1_RX_CLK, PIN_OUTPUT_PULLUP, MUX_MODE7) /* (L18) gmii1_rxclk.gpio3[10] - LS_BUF_EN */ + >; + }; + + /* DCAN */ + dcan1_pins: pinmux_dcan1_pins { + pinctrl-single,pins = < + AM33XX_PADCONF(AM335X_PIN_UART0_RTSN, PIN_INPUT, MUX_MODE2) /* (E17) uart0_rtsn.dcan1_rx */ + AM33XX_PADCONF(AM335X_PIN_UART0_CTSN, PIN_OUTPUT, MUX_MODE2) /* (E18) uart0_ctsn.dcan1_tx */ + AM33XX_PADCONF(AM335X_PIN_MII1_RXD0, PIN_OUTPUT, MUX_MODE7) /* (M16) gmii1_rxd0.gpio2[21] */ + >; + }; + + /* E1 */ + eqep0_pins: pinmux_eqep0_pins { + pinctrl-single,pins = < + AM33XX_PADCONF(AM335X_PIN_MCASP0_AXR0, PIN_INPUT, MUX_MODE1) /* (B12) mcasp0_aclkr.eQEP0A_in */ + AM33XX_PADCONF(AM335X_PIN_MCASP0_FSR, PIN_INPUT, MUX_MODE1) /* (C13) mcasp0_fsr.eQEP0B_in */ + >; + }; + + /* E2 */ + eqep1_pins: pinmux_eqep1_pins { + pinctrl-single,pins = < + AM33XX_PADCONF(AM335X_PIN_LCD_DATA12, PIN_INPUT, MUX_MODE2) /* (V2) lcd_data12.eQEP1A_in */ + AM33XX_PADCONF(AM335X_PIN_LCD_DATA13, PIN_INPUT, MUX_MODE2) /* (V3) lcd_data13.eQEP1B_in */ + >; + }; + + /* E3 */ + eqep2_pins: pinmux_eqep2_pins { + pinctrl-single,pins = < + AM33XX_PADCONF(AM335X_PIN_GPMC_AD12, PIN_INPUT, MUX_MODE4) /* (T12) gpmc_ad12.eQEP2A_in */ + AM33XX_PADCONF(AM335X_PIN_GPMC_AD13, PIN_INPUT, MUX_MODE4) /* (R12) gpmc_ad13.eQEP2B_in */ + >; + }; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pins>; + + status = "okay"; +}; + +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&uart1_pins>; + + status = "okay"; +}; + +&uart2 { + pinctrl-names = "default"; + pinctrl-0 = <&uart2_pins>; + + status = "okay"; +}; + +&uart4 { + pinctrl-names = "default"; + pinctrl-0 = <&uart4_pins>; + + status = "okay"; +}; + +&uart5 { + pinctrl-names = "default"; + pinctrl-0 = <&uart5_pins>; + + status = "okay"; +}; + +&usb0 { + dr_mode = "peripheral"; + interrupts-extended = <&intc 18 &tps 0>; + interrupt-names = "mc", "vbus"; +}; + +&usb1 { + dr_mode = "host"; +}; + +&i2c0 { + baseboard_eeprom: baseboard_eeprom@50 { + compatible = "atmel,24c256"; + reg = <0x50>; + + #address-cells = <1>; + #size-cells = <1>; + baseboard_data: baseboard_data@0 { + reg = <0 0x100>; + }; + }; +}; + +&i2c2 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c2_pins>; + + status = "okay"; + clock-frequency = <400000>; + + mpu9250@68 { + compatible = "invensense,mpu9250"; + reg = <0x68>; + interrupt-parent = <&gpio3>; + interrupts = <21 IRQ_TYPE_EDGE_RISING>; + i2c-gate { + #address-cells = <1>; + #size-cells = <0>; + ax8975@c { + compatible = "asahi-kasei,ak8975"; + reg = <0x0c>; + }; + }; + }; + + pressure@76 { + compatible = "bosch,bmp280"; + reg = <0x76>; + }; +}; + +/include/ "tps65217.dtsi" + +&tps { + /delete-property/ ti,pmic-shutdown-controller; + + charger { + interrupts = <0>, <1>; + interrupt-names = "USB", "AC"; + status = "okay"; + }; +}; + +&mmc1 { + status = "okay"; + vmmc-supply = <&vmmcsd_fixed>; + bus-width = <4>; + pinctrl-names = "default"; + pinctrl-0 = <&mmc1_pins>; + cd-gpios = <&gpio0 6 GPIO_ACTIVE_LOW>; +}; + +&mmc2 { + status = "okay"; + vmmc-supply = <&vmmcsd_fixed>; + bus-width = <8>; + pinctrl-names = "default"; + pinctrl-0 = <&mmc2_pins>; +}; + +&mmc3 { + dmas = <&edma_xbar 12 0 1 + &edma_xbar 13 0 2>; + dma-names = "tx", "rx"; + status = "okay"; + vmmc-supply = <&wlan_en_reg>; + bus-width = <4>; + non-removable; + cap-power-off-card; + keep-power-in-suspend; + pinctrl-names = "default"; + pinctrl-0 = <&mmc3_pins &wl18xx_pins>; + + #address-cells = <1>; + #size-cells = <0>; + wlcore: wlcore@2 { + compatible = "ti,wl1835"; + reg = <2>; + interrupt-parent = <&gpio0>; + interrupts = <21 IRQ_TYPE_EDGE_RISING>; + }; +}; + +&tscadc { + status = "okay"; + adc { + ti,adc-channels = <0 1 2 3 4 5 6 7>; + }; +}; + +&uart3 { + pinctrl-names = "default"; + pinctrl-0 = <&uart3_pins &bt_pins>; + status = "okay"; + + bluetooth { + compatible = "ti,wl1835-st"; + enable-gpios = <&gpio0 28 GPIO_ACTIVE_HIGH>; + }; +}; + +&rtc { + system-power-controller; + clocks = <&clk_32768_ck>, <&clk_24mhz_clkctrl AM3_CLK_24MHZ_CLKDIV32K_CLKCTRL 0>; + clock-names = "ext-clk", "int-clk"; +}; + +&dcan1 { + pinctrl-names = "default"; + pinctrl-0 = <&dcan1_pins>; + status = "okay"; +}; + +&gpio0 { + gpio-line-names = + "UART3_CTS", /* M17 */ + "UART3_RTS", /* M18 */ + "UART2_RX", /* A17 */ + "UART2_TX", /* B17 */ + "I2C1_SDA", /* B16 */ + "I2C1_SCL", /* A16 */ + "MMC0_CD", /* C15 */ + "SPI1_SS2", /* C18 */ + "EQEP_1A", /* V2 */ + "EQEP_1B", /* V3 */ + "MDIR_2B", /* V4 */ + "BATT_LED_2", /* T5 */ + "I2C2_SDA", /* D18 */ + "I2C2_SCL", /* D17 */ + "UART1_RX", /* D16 */ + "UART1_TX", /* D15 */ + "MMC2_DAT1", /* J18 */ + "MMC2_DAT2", /* K15 */ + "NC", /* F16 */ + "WIFI_LED", /* A15 */ + "MOT_STBY", /* D14 */ + "WLAN_IRQ", /* K16 */ + "PWM_2A", /* U10 */ + "PWM_2B", /* T10 */ + "", + "", + "BATT_LED_4", /* T11 */ + "BATT_LED_1", /* U12 */ + "BT_EN", /* K17 */ + "SPI1_SS1", /* H18 */ + "UART4_RX", /* T17 */ + "MDIR_1B"; /* U17 */ +}; + +&gpio1 { + gpio-line-names = + "MMC1_DAT0", /* U7 */ + "MMC1_DAT1", /* V7 */ + "MMC1_DAT2", /* R8 */ + "MMC1_DAT3", /* T8 */ + "MMC1_DAT4", /* U8 */ + "MMC1_DAT5", /* V8 */ + "MMC1_DAT6", /* R9 */ + "MMC1_DAT7", /* T9 */ + "DCAN1_TX", /* E18 */ + "DCAN1_RX", /* E17 */ + "UART0_RX", /* E15 */ + "UART0_TX", /* E16 */ + "EQEP_2A", /* T12 */ + "EQEP_2B", /* R12 */ + "PRU_E_A", /* V13 */ + "PRU_E_B", /* U13 */ + "MDIR_2A", /* R13 */ + "GPIO1_17", /* V14 */ + "PWM_1A", /* U14 */ + "PWM_1B", /* T14 */ + "EMMC_RST", /* R14 */ + "USR_LED_0", /* V15 */ + "USR_LED_1", /* U15 */ + "USR_LED_2", /* T15 */ + "USR_LED_3", /* V16 */ + "GPIO1_25", /* U16 */ + "MCASP0_AXR0", /* T16 */ + "MCASP0_AXR1", /* V17 */ + "MCASP0_ACLKR", /* U18 */ + "BATT_LED_3", /* V6 */ + "MMC1_CLK", /* U9 */ + "MMC1_CMD"; /* V9 */ +}; + +&gpio2 { + gpio-line-names = + "MDIR_1A", /* T13 */ + "MCASP0_FSR", /* V12 */ + "LED_RED", /* R7 */ + "LED_GREEN", /* T7 */ + "MODE_BTN", /* U6 */ + "PAUSE_BTN", /* T6 */ + "MDIR_4A", /* R1 */ + "MDIR_4B", /* R2 */ + "MDIR_3B", /* R3 */ + "MDIR_3A", /* R4 */ + "SVO7", /* T1 */ + "SVO8", /* T2 */ + "SVO5", /* T3 */ + "SVO6", /* T4 */ + "UART5_TX", /* U1 */ + "UART5_RX", /* U2 */ + "SERVO_EN", /* U3 */ + "NC", /* U4 */ + "UART3_RX", /* L17 */ + "UART3_TX", /* L16 */ + "MMC2_CLK", /* L15 */ + "DCAN1_SILENT", /* M16 */ + "SVO1", /* U5 */ + "SVO3", /* R5 */ + "SVO2", /* V5 */ + "SVO4", /* R6 */ + "MMC0_DAT3", /* F17 */ + "MMC0_DAT2", /* F18 */ + "MMC0_DAT1", /* G15 */ + "MMC0_DAT0", /* G16 */ + "MMC0_CLK", /* G17 */ + "MMC0_CMD"; /* G18 */ +}; + +&gpio3 { + gpio-line-names = + "MMC2_DAT3", /* H16 */ + "GPIO3_1", /* H17 */ + "GPIO3_2", /* J15 */ + "MMC2_CMD", /* J16 */ + "MMC2_DAT0", /* J17 */ + "I2C0_SDA", /* C17 */ + "I2C0_SCL", /* C16 */ + "EMU1", /* C14 */ + "EMU0", /* B14 */ + "WL_EN", /* K18 */ + "WL_BT_OE", /* L18 */ + "", + "", + "NC", /* F15 */ + "SPI1_SCK", /* A13 */ + "SPI1_MISO", /* B13 */ + "SPI1_MOSI", /* D12 */ + "GPIO3_17", /* C12 */ + "EQEP_0A", /* B12 */ + "EQEP_0B", /* C13 */ + "GPIO3_20", /* D13 */ + "IMU_INT", /* A14 */ + "", + "", + "", + "", + "", + "", + "", + "", + "", + ""; + + ls-buf-en-hog { + gpio-hog; + gpios = <10 GPIO_ACTIVE_HIGH>; + output-high; + }; +}; + +&epwmss0 { + status = "okay"; +}; + +&eqep0 { + pinctrl-names = "default"; + pinctrl-0 = <&eqep0_pins>; + status = "okay"; +}; + +&epwmss1 { + status = "okay"; +}; + +&eqep1 { + pinctrl-names = "default"; + pinctrl-0 = <&eqep1_pins>; + status = "okay"; +}; + +&epwmss2 { + status = "okay"; +}; + +&eqep2 { + pinctrl-names = "default"; + pinctrl-0 = <&eqep2_pins>; + status = "okay"; +}; diff --git a/arch/arm/dts/am335x-bonegreen-wireless.dts b/arch/arm/dts/am335x-bonegreen-wireless.dts new file mode 100644 index 000000000000..74db0fc39397 --- /dev/null +++ b/arch/arm/dts/am335x-bonegreen-wireless.dts @@ -0,0 +1,127 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * Copyright (C) 2012 Texas Instruments Incorporated - https://www.ti.com/ + */ +/dts-v1/; + +#include "am33xx.dtsi" +#include "am335x-bone-common.dtsi" +#include "am335x-bonegreen-common.dtsi" +#include <dt-bindings/interrupt-controller/irq.h> + +/ { + model = "TI AM335x BeagleBone Green Wireless"; + compatible = "ti,am335x-bone-green-wireless", "ti,am335x-bone-green", "ti,am335x-bone-black", "ti,am335x-bone", "ti,am33xx"; + + wlan_en_reg: fixedregulator@2 { + compatible = "regulator-fixed"; + regulator-name = "wlan-en-regulator"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + startup-delay-us= <70000>; + + /* WL_EN */ + gpio = <&gpio0 26 0>; + enable-active-high; + }; +}; + +&am33xx_pinmux { + bt_pins: pinmux_bt_pins { + pinctrl-single,pins = < + AM33XX_PADCONF(AM335X_PIN_GPMC_BEN1, PIN_OUTPUT_PULLUP, MUX_MODE7) /* gpmc_ad12.gpio1_28 BT_EN */ + >; + }; + + mmc3_pins: pinmux_mmc3_pins { + pinctrl-single,pins = < + AM33XX_PADCONF(AM335X_PIN_GPMC_AD12, PIN_INPUT_PULLUP, MUX_MODE3) /* gpmc_ad12.mmc2_dat0 */ + AM33XX_PADCONF(AM335X_PIN_GPMC_AD13, PIN_INPUT_PULLUP, MUX_MODE3) /* gpmc_ad13.mmc2_dat1 */ + AM33XX_PADCONF(AM335X_PIN_GPMC_AD14, PIN_INPUT_PULLUP, MUX_MODE3) /* gpmc_ad14.mmc2_dat2 */ + AM33XX_PADCONF(AM335X_PIN_GPMC_AD15, PIN_INPUT_PULLUP, MUX_MODE3) /* gpmc_ad15.mmc2_dat3 */ + AM33XX_PADCONF(AM335X_PIN_GPMC_CSN3, PIN_INPUT_PULLUP, MUX_MODE3) /* gpmc_csn3.mmc2_cmd */ + AM33XX_PADCONF(AM335X_PIN_GPMC_CLK, PIN_INPUT_PULLUP, MUX_MODE3) /* gpmc_clk.mmc2_clk */ + >; + }; + + uart3_pins: pinmux_uart3_pins { + pinctrl-single,pins = < + AM33XX_PADCONF(AM335X_PIN_MII1_RXD3, PIN_INPUT_PULLUP, MUX_MODE1) /* gmii1_rxd3.uart3_rxd */ + AM33XX_PADCONF(AM335X_PIN_MII1_RXD2, PIN_OUTPUT_PULLDOWN, MUX_MODE1) /* gmii1_rxd2.uart3_txd */ + AM33XX_PADCONF(AM335X_PIN_MDIO, PIN_INPUT, MUX_MODE3) /* mdio_data.uart3_ctsn */ + AM33XX_PADCONF(AM335X_PIN_MDC, PIN_OUTPUT_PULLDOWN, MUX_MODE3) /* mdio_clk.uart3_rtsn */ + >; + }; + + wl18xx_pins: pinmux_wl18xx_pins { + pinctrl-single,pins = < + AM33XX_PADCONF(AM335X_PIN_GPMC_AD10, PIN_OUTPUT_PULLDOWN, MUX_MODE7) /* gpmc_ad10.gpio0_26 WL_EN */ + AM33XX_PADCONF(AM335X_PIN_GPMC_AD11, PIN_INPUT_PULLDOWN, MUX_MODE7) /* gpmc_ad11.gpio0_27 WL_IRQ */ + AM33XX_PADCONF(AM335X_PIN_GPMC_CSN0, PIN_OUTPUT_PULLUP, MUX_MODE7) /* gpmc_csn0.gpio1_29 LS_BUF_EN */ + >; + }; +}; + +&mac { + status = "disabled"; +}; + +&mmc3 { + dmas = <&edma_xbar 12 0 1 + &edma_xbar 13 0 2>; + dma-names = "tx", "rx"; + status = "okay"; + vmmc-supply = <&wlan_en_reg>; + bus-width = <4>; + non-removable; + cap-power-off-card; + keep-power-in-suspend; + pinctrl-names = "default"; + pinctrl-0 = <&mmc3_pins &wl18xx_pins>; + + #address-cells = <1>; + #size-cells = <0>; + wlcore: wlcore@2 { + compatible = "ti,wl1835"; + reg = <2>; + interrupt-parent = <&gpio0>; + interrupts = <27 IRQ_TYPE_EDGE_RISING>; + }; +}; + +&uart3 { + pinctrl-names = "default"; + pinctrl-0 = <&uart3_pins &bt_pins>; + status = "okay"; + + bluetooth { + compatible = "ti,wl1835-st"; + enable-gpios = <&gpio1 28 GPIO_ACTIVE_HIGH>; + }; +}; + +&gpio1 { + ls-buf-en-hog { + gpio-hog; + gpios = <29 GPIO_ACTIVE_HIGH>; + output-high; + line-name = "LS_BUF_EN"; + }; +}; + +/* BT_AUD_OUT from wl1835 has to be pulled low when WL_EN is activated.*/ +/* in case it isn't, wilink8 ends up in one of the test modes that */ +/* intruces various issues (elp wkaeup timeouts etc.) */ +/* On the BBGW this pin is routed through the level shifter (U21) that */ +/* introduces a pullup on the line and wilink8 ends up in a bad state. */ +/* use a gpio hog to force this pin low. An alternative may be adding */ +/* an external pulldown on U21 pin 4. */ + +&gpio3 { + bt-aud-in-hog { + gpio-hog; + gpios = <16 GPIO_ACTIVE_HIGH>; + output-low; + line-name = "MCASP0_AHCLKR"; + }; +}; diff --git a/arch/arm/dts/am335x-sancloud-bbe.dts b/arch/arm/dts/am335x-sancloud-bbe-common.dtsi similarity index 60% copy from arch/arm/dts/am335x-sancloud-bbe.dts copy to arch/arm/dts/am335x-sancloud-bbe-common.dtsi index 275ba339adf4..21b601fa4c12 100644 --- a/arch/arm/dts/am335x-sancloud-bbe.dts +++ b/arch/arm/dts/am335x-sancloud-bbe-common.dtsi @@ -2,21 +2,8 @@ /* * Copyright (C) 2012 Texas Instruments Incorporated - https://www.ti.com/ */ -/dts-v1/; - -#include "am33xx.dtsi" -#include "am335x-bone-common.dtsi" -#include "am335x-boneblack-common.dtsi" -#include <dt-bindings/interrupt-controller/irq.h> - -/ { - model = "SanCloud BeagleBone Enhanced"; - compatible = "sancloud,am335x-boneenhanced", "ti,am335x-bone-black", "ti,am335x-bone", "ti,am33xx"; -};
&am33xx_pinmux { - pinctrl-names = "default"; - cpsw_default: cpsw_default { pinctrl-single,pins = < /* Slave 1 */ @@ -53,85 +40,28 @@ >; };
- davinci_mdio_default: davinci_mdio_default { - pinctrl-single,pins = < - /* MDIO */ - AM33XX_PADCONF(AM335X_PIN_MDIO, PIN_INPUT_PULLUP | SLEWCTRL_FAST, MUX_MODE0) - AM33XX_PADCONF(AM335X_PIN_MDC, PIN_OUTPUT_PULLUP, MUX_MODE0) - >; - }; - - davinci_mdio_sleep: davinci_mdio_sleep { - pinctrl-single,pins = < - /* MDIO reset value */ - AM33XX_PADCONF(AM335X_PIN_MDIO, PIN_INPUT_PULLDOWN, MUX_MODE7) - AM33XX_PADCONF(AM335X_PIN_MDC, PIN_INPUT_PULLDOWN, MUX_MODE7) - >; - }; - usb_hub_ctrl: usb_hub_ctrl { pinctrl-single,pins = < AM33XX_PADCONF(AM335X_PIN_RMII1_REF_CLK, PIN_OUTPUT_PULLUP, MUX_MODE7) /* rmii1_refclk.gpio0_29 */ >; }; - - mpu6050_pins: pinmux_mpu6050_pins { - pinctrl-single,pins = < - AM33XX_PADCONF(AM335X_PIN_UART0_CTSN, PIN_INPUT, MUX_MODE7) /* uart0_ctsn.gpio1_8 */ - >; - }; - - lps3331ap_pins: pinmux_lps3331ap_pins { - pinctrl-single,pins = < - AM33XX_PADCONF(AM335X_PIN_GPMC_A10, PIN_INPUT, MUX_MODE7) /* gpmc_a10.gpio1_26 */ - >; - }; };
&mac { - pinctrl-names = "default", "sleep"; pinctrl-0 = <&cpsw_default>; pinctrl-1 = <&cpsw_sleep>; - status = "okay"; -}; - -&davinci_mdio { - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&davinci_mdio_default>; - pinctrl-1 = <&davinci_mdio_sleep>; - status = "okay"; - - ethphy0: ethernet-phy@0 { - reg = <0>; - }; };
&cpsw_emac0 { - phy-handle = <ðphy0>; phy-mode = "rgmii-id"; };
&i2c0 { - lps331ap: barometer@5c { - compatible = "st,lps331ap-press"; - st,drdy-int-pin = <1>; - reg = <0x5c>; - interrupt-parent = <&gpio1>; - interrupts = <26 IRQ_TYPE_EDGE_RISING>; - }; - - mpu6050: accelerometer@68 { - compatible = "invensense,mpu6050"; - reg = <0x68>; - interrupt-parent = <&gpio0>; - interrupts = <2 IRQ_TYPE_EDGE_RISING>; - orientation = <0xff 0 0 0 1 0 0 0 0xff>; - }; - usb2512b: usb-hub@2c { + pinctrl-names = "default"; + pinctrl-0 = <&usb_hub_ctrl>; compatible = "microchip,usb2512b"; reg = <0x2c>; reset-gpios = <&gpio0 29 GPIO_ACTIVE_LOW>; - /* wifi on port 4 */ }; }; diff --git a/arch/arm/dts/am335x-sancloud-bbe-extended-wifi.dts b/arch/arm/dts/am335x-sancloud-bbe-extended-wifi.dts new file mode 100644 index 000000000000..246a1a9b3e44 --- /dev/null +++ b/arch/arm/dts/am335x-sancloud-bbe-extended-wifi.dts @@ -0,0 +1,113 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * Copyright (C) 2021 Sancloud Ltd + * Copyright (C) 2012 Texas Instruments Incorporated - http://www.ti.com/ + */ +/dts-v1/; + +#include "am33xx.dtsi" +#include "am335x-bone-common.dtsi" +#include "am335x-boneblack-common.dtsi" +#include "am335x-sancloud-bbe-common.dtsi" +#include <dt-bindings/interrupt-controller/irq.h> + +/ { + model = "SanCloud BeagleBone Enhanced Extended WiFi"; + compatible = "sancloud,am335x-boneenhanced", + "ti,am335x-bone-black", + "ti,am335x-bone", + "ti,am33xx"; + + wlan_en_reg: fixedregulator@2 { + compatible = "regulator-fixed"; + regulator-name = "wlan-en-regulator"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + startup-delay-us= <100000>; + }; +}; + +&am33xx_pinmux { + mmc3_pins: pinmux_mmc3_pins { + pinctrl-single,pins = < + /* gpmc_a9.gpio1_25: RADIO_EN */ + AM33XX_PADCONF(AM335X_PIN_GPMC_A9, PIN_OUTPUT_PULLUP, MUX_MODE7) + + /* gpmc_ad12.mmc2_dat0 */ + AM33XX_PADCONF(AM335X_PIN_GPMC_AD12, PIN_INPUT_PULLUP, MUX_MODE3) + + /* gpmc_ad13.mmc2_dat1 */ + AM33XX_PADCONF(AM335X_PIN_GPMC_AD13, PIN_INPUT_PULLUP, MUX_MODE3) + + /* gpmc_ad14.mmc2_dat2 */ + AM33XX_PADCONF(AM335X_PIN_GPMC_AD14, PIN_INPUT_PULLUP, MUX_MODE3) + + /* gpmc_ad15.mmc2_dat3 */ + AM33XX_PADCONF(AM335X_PIN_GPMC_AD15, PIN_INPUT_PULLUP, MUX_MODE3) + + /* gpmc_csn3.mmc2_cmd */ + AM33XX_PADCONF(AM335X_PIN_GPMC_CSN3, PIN_INPUT_PULLUP, MUX_MODE3) + + /* gpmc_clk.mmc2_clk */ + AM33XX_PADCONF(AM335X_PIN_GPMC_CLK, PIN_INPUT_PULLUP, MUX_MODE3) + >; + }; + + bluetooth_pins: pinmux_bluetooth_pins { + pinctrl-single,pins = < + /* event_intr0.gpio0_19 */ + AM33XX_PADCONF(AM335X_PIN_XDMA_EVENT_INTR0, PIN_INPUT_PULLUP, MUX_MODE7) + >; + }; + + uart1_pins: pinmux_uart1_pins { + pinctrl-single,pins = < + /* uart1_rxd */ + AM33XX_PADCONF(AM335X_PIN_UART1_RXD, PIN_INPUT, MUX_MODE0) + + /* uart1_txd */ + AM33XX_PADCONF(AM335X_PIN_UART1_TXD, PIN_INPUT, MUX_MODE0) + + /* uart1_ctsn */ + AM33XX_PADCONF(AM335X_PIN_UART1_CTSN, PIN_INPUT_PULLDOWN, MUX_MODE0) + + /* uart1_rtsn */ + AM33XX_PADCONF(AM335X_PIN_UART1_RTSN, PIN_OUTPUT_PULLDOWN, MUX_MODE0) + >; + }; +}; + +&i2c2 { + status = "disabled"; +}; + +&mmc3 { + status = "okay"; + vmmc-supply = <&wlan_en_reg>; + bus-width = <4>; + non-removable; + cap-power-off-card; + ti,needs-special-hs-handling; + keep-power-in-suspend; + pinctrl-names = "default"; + pinctrl-0 = <&mmc3_pins>; + dmas = <&edma_xbar 12 0 1 + &edma_xbar 13 0 2>; + dma-names = "tx", "rx"; + clock-frequency = <50000000>; + max-frequency = <50000000>; +}; + +&uart1 { + status = "okay"; + + bluetooth { + pinctrl-names = "default"; + pinctrl-0 = <&uart1_pins &bluetooth_pins>; + compatible = "qcom,qca6174-bt"; + enable-gpios = <&gpio1 25 GPIO_ACTIVE_HIGH>; + clocks = <&l4ls_clkctrl AM3_L4LS_UART2_CLKCTRL 0>; + interrupt-parent = <&gpio0>; + interrupts = <19 IRQ_TYPE_EDGE_RISING>; + }; +}; diff --git a/arch/arm/dts/am335x-sancloud-bbe-lite.dts b/arch/arm/dts/am335x-sancloud-bbe-lite.dts new file mode 100644 index 000000000000..d6ef19311a91 --- /dev/null +++ b/arch/arm/dts/am335x-sancloud-bbe-lite.dts @@ -0,0 +1,50 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * Copyright (C) 2012 Texas Instruments Incorporated - http://www.ti.com/ + * Copyright (C) 2021 SanCloud Ltd + */ +/dts-v1/; + +#include "am33xx.dtsi" +#include "am335x-bone-common.dtsi" +#include "am335x-boneblack-common.dtsi" +#include "am335x-sancloud-bbe-common.dtsi" + +/ { + model = "SanCloud BeagleBone Enhanced Lite"; + compatible = "sancloud,am335x-boneenhanced", + "ti,am335x-bone-black", + "ti,am335x-bone", + "ti,am33xx"; +}; + +&am33xx_pinmux { + bb_spi0_pins: pinmux_bb_spi0_pins { + pinctrl-single,pins = < + AM33XX_PADCONF(AM335X_PIN_SPI0_SCLK, PIN_INPUT, MUX_MODE0) + AM33XX_PADCONF(AM335X_PIN_SPI0_D0, PIN_INPUT, MUX_MODE0) + AM33XX_PADCONF(AM335X_PIN_SPI0_D1, PIN_INPUT, MUX_MODE0) + AM33XX_PADCONF(AM335X_PIN_SPI0_CS0, PIN_INPUT, MUX_MODE0) + >; + }; +}; + +&spi0 { + #address-cells = <1>; + #size-cells = <0>; + + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&bb_spi0_pins>; + + channel@0 { + #address-cells = <1>; + #size-cells = <0>; + + compatible = "micron,spi-authenta"; + + reg = <0>; + spi-max-frequency = <16000000>; + spi-cpha; + }; +}; diff --git a/arch/arm/dts/am335x-sancloud-bbe.dts b/arch/arm/dts/am335x-sancloud-bbe.dts index 275ba339adf4..efbe93135dbe 100644 --- a/arch/arm/dts/am335x-sancloud-bbe.dts +++ b/arch/arm/dts/am335x-sancloud-bbe.dts @@ -7,6 +7,8 @@ #include "am33xx.dtsi" #include "am335x-bone-common.dtsi" #include "am335x-boneblack-common.dtsi" +#include "am335x-boneblack-hdmi.dtsi" +#include "am335x-sancloud-bbe-common.dtsi" #include <dt-bindings/interrupt-controller/irq.h>
/ { @@ -15,66 +17,6 @@ };
&am33xx_pinmux { - pinctrl-names = "default"; - - cpsw_default: cpsw_default { - pinctrl-single,pins = < - /* Slave 1 */ - AM33XX_PADCONF(AM335X_PIN_MII1_TX_EN, PIN_OUTPUT_PULLDOWN, MUX_MODE2) /* mii1_txen.rgmii1_tctl */ - AM33XX_PADCONF(AM335X_PIN_MII1_RX_DV, PIN_INPUT_PULLDOWN, MUX_MODE2) /* mii1_rxdv.rgmii1_rctl */ - AM33XX_PADCONF(AM335X_PIN_MII1_TXD3, PIN_OUTPUT_PULLDOWN, MUX_MODE2) /* mii1_txd3.rgmii1_td3 */ - AM33XX_PADCONF(AM335X_PIN_MII1_TXD2, PIN_OUTPUT_PULLDOWN, MUX_MODE2) /* mii1_txd2.rgmii1_td2 */ - AM33XX_PADCONF(AM335X_PIN_MII1_TXD1, PIN_OUTPUT_PULLDOWN, MUX_MODE2) /* mii1_txd1.rgmii1_td1 */ - AM33XX_PADCONF(AM335X_PIN_MII1_TXD0, PIN_OUTPUT_PULLDOWN, MUX_MODE2) /* mii1_txd0.rgmii1_td0 */ - AM33XX_PADCONF(AM335X_PIN_MII1_TX_CLK, PIN_OUTPUT_PULLDOWN, MUX_MODE2) /* mii1_txclk.rgmii1_tclk */ - AM33XX_PADCONF(AM335X_PIN_MII1_RX_CLK, PIN_INPUT_PULLDOWN, MUX_MODE2) /* mii1_rxclk.rgmii1_rclk */ - AM33XX_PADCONF(AM335X_PIN_MII1_RXD3, PIN_INPUT_PULLDOWN, MUX_MODE2) /* mii1_rxd3.rgmii1_rd3 */ - AM33XX_PADCONF(AM335X_PIN_MII1_RXD2, PIN_INPUT_PULLDOWN, MUX_MODE2) /* mii1_rxd2.rgmii1_rd2 */ - AM33XX_PADCONF(AM335X_PIN_MII1_RXD1, PIN_INPUT_PULLDOWN, MUX_MODE2) /* mii1_rxd1.rgmii1_rd1 */ - AM33XX_PADCONF(AM335X_PIN_MII1_RXD0, PIN_INPUT_PULLDOWN, MUX_MODE2) /* mii1_rxd0.rgmii1_rd0 */ - >; - }; - - cpsw_sleep: cpsw_sleep { - pinctrl-single,pins = < - /* Slave 1 reset value */ - AM33XX_PADCONF(AM335X_PIN_MII1_TX_EN, PIN_INPUT_PULLDOWN, MUX_MODE7) - AM33XX_PADCONF(AM335X_PIN_MII1_RX_DV, PIN_INPUT_PULLDOWN, MUX_MODE7) - AM33XX_PADCONF(AM335X_PIN_MII1_TXD3, PIN_INPUT_PULLDOWN, MUX_MODE7) - AM33XX_PADCONF(AM335X_PIN_MII1_TXD2, PIN_INPUT_PULLDOWN, MUX_MODE7) - AM33XX_PADCONF(AM335X_PIN_MII1_TXD1, PIN_INPUT_PULLDOWN, MUX_MODE7) - AM33XX_PADCONF(AM335X_PIN_MII1_TXD0, PIN_INPUT_PULLDOWN, MUX_MODE7) - AM33XX_PADCONF(AM335X_PIN_MII1_TX_CLK, PIN_INPUT_PULLDOWN, MUX_MODE7) - AM33XX_PADCONF(AM335X_PIN_MII1_RX_CLK, PIN_INPUT_PULLDOWN, MUX_MODE7) - AM33XX_PADCONF(AM335X_PIN_MII1_RXD3, PIN_INPUT_PULLDOWN, MUX_MODE7) - AM33XX_PADCONF(AM335X_PIN_MII1_RXD2, PIN_INPUT_PULLDOWN, MUX_MODE7) - AM33XX_PADCONF(AM335X_PIN_MII1_RXD1, PIN_INPUT_PULLDOWN, MUX_MODE7) - AM33XX_PADCONF(AM335X_PIN_MII1_RXD0, PIN_INPUT_PULLDOWN, MUX_MODE7) - >; - }; - - davinci_mdio_default: davinci_mdio_default { - pinctrl-single,pins = < - /* MDIO */ - AM33XX_PADCONF(AM335X_PIN_MDIO, PIN_INPUT_PULLUP | SLEWCTRL_FAST, MUX_MODE0) - AM33XX_PADCONF(AM335X_PIN_MDC, PIN_OUTPUT_PULLUP, MUX_MODE0) - >; - }; - - davinci_mdio_sleep: davinci_mdio_sleep { - pinctrl-single,pins = < - /* MDIO reset value */ - AM33XX_PADCONF(AM335X_PIN_MDIO, PIN_INPUT_PULLDOWN, MUX_MODE7) - AM33XX_PADCONF(AM335X_PIN_MDC, PIN_INPUT_PULLDOWN, MUX_MODE7) - >; - }; - - usb_hub_ctrl: usb_hub_ctrl { - pinctrl-single,pins = < - AM33XX_PADCONF(AM335X_PIN_RMII1_REF_CLK, PIN_OUTPUT_PULLUP, MUX_MODE7) /* rmii1_refclk.gpio0_29 */ - >; - }; - mpu6050_pins: pinmux_mpu6050_pins { pinctrl-single,pins = < AM33XX_PADCONF(AM335X_PIN_UART0_CTSN, PIN_INPUT, MUX_MODE7) /* uart0_ctsn.gpio1_8 */ @@ -88,31 +30,10 @@ }; };
-&mac { - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&cpsw_default>; - pinctrl-1 = <&cpsw_sleep>; - status = "okay"; -}; - -&davinci_mdio { - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&davinci_mdio_default>; - pinctrl-1 = <&davinci_mdio_sleep>; - status = "okay"; - - ethphy0: ethernet-phy@0 { - reg = <0>; - }; -}; - -&cpsw_emac0 { - phy-handle = <ðphy0>; - phy-mode = "rgmii-id"; -}; - &i2c0 { lps331ap: barometer@5c { + pinctrl-names = "default"; + pinctrl-0 = <&lps3331ap_pins>; compatible = "st,lps331ap-press"; st,drdy-int-pin = <1>; reg = <0x5c>; @@ -121,17 +42,12 @@ };
mpu6050: accelerometer@68 { + pinctrl-names = "default"; + pinctrl-0 = <&mpu6050_pins>; compatible = "invensense,mpu6050"; reg = <0x68>; interrupt-parent = <&gpio0>; interrupts = <2 IRQ_TYPE_EDGE_RISING>; orientation = <0xff 0 0 0 1 0 0 0 0xff>; }; - - usb2512b: usb-hub@2c { - compatible = "microchip,usb2512b"; - reg = <0x2c>; - reset-gpios = <&gpio0 29 GPIO_ACTIVE_LOW>; - /* wifi on port 4 */ - }; }; diff --git a/arch/arm/dts/am33xx-l4.dtsi b/arch/arm/dts/am33xx-l4.dtsi index e678673317af..5892612efa80 100644 --- a/arch/arm/dts/am33xx-l4.dtsi +++ b/arch/arm/dts/am33xx-l4.dtsi @@ -1810,6 +1810,15 @@ status = "disabled"; };
+ eqep0: counter@180 { + compatible = "ti,am3352-eqep"; + reg = <0x180 0x80>; + clocks = <&l4ls_gclk>; + clock-names = "sysclkout"; + interrupts = <79>; + status = "disabled"; + }; + ehrpwm0: pwm@200 { compatible = "ti,am3352-ehrpwm", "ti,am33xx-ehrpwm"; @@ -1862,6 +1871,15 @@ status = "disabled"; };
+ eqep1: counter@180 { + compatible = "ti,am3352-eqep"; + reg = <0x180 0x80>; + clocks = <&l4ls_gclk>; + clock-names = "sysclkout"; + interrupts = <88>; + status = "disabled"; + }; + ehrpwm1: pwm@200 { compatible = "ti,am3352-ehrpwm", "ti,am33xx-ehrpwm"; @@ -1914,6 +1932,15 @@ status = "disabled"; };
+ eqep2: counter@180 { + compatible = "ti,am3352-eqep"; + reg = <0x180 0x80>; + clocks = <&l4ls_gclk>; + clock-names = "sysclkout"; + interrupts = <89>; + status = "disabled"; + }; + ehrpwm2: pwm@200 { compatible = "ti,am3352-ehrpwm", "ti,am33xx-ehrpwm"; diff --git a/arch/arm/dts/tps6507x.dtsi b/arch/arm/dts/tps6507x.dtsi index 4c326e591e5a..db4809d308f9 100644 --- a/arch/arm/dts/tps6507x.dtsi +++ b/arch/arm/dts/tps6507x.dtsi @@ -1,9 +1,6 @@ +// SPDX-License-Identifier: GPL-2.0-only /* * Copyright (C) 2013 Texas Instruments Incorporated - http://www.ti.com/ - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. */
/* diff --git a/arch/arm/dts/tps65217.dtsi b/arch/arm/dts/tps65217.dtsi index a63272422d76..0d463de5650f 100644 --- a/arch/arm/dts/tps65217.dtsi +++ b/arch/arm/dts/tps65217.dtsi @@ -1,9 +1,6 @@ +// SPDX-License-Identifier: GPL-2.0-only /* * Copyright (C) 2012 Texas Instruments Incorporated - http://www.ti.com/ - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. */
/* @@ -13,6 +10,21 @@
&tps { compatible = "ti,tps65217"; + interrupt-controller; + #interrupt-cells = <1>; + + charger { + compatible = "ti,tps65217-charger"; + interrupts = <0>, <1>; + interrupt-names = "USB", "AC"; + status = "disabled"; + }; + + pwrbutton { + compatible = "ti,tps65217-pwrbutton"; + interrupts = <2>; + status = "disabled"; + };
regulators { #address-cells = <1>; diff --git a/arch/arm/dts/tps65910.dtsi b/arch/arm/dts/tps65910.dtsi index b0ac6657a170..a941d1e62328 100644 --- a/arch/arm/dts/tps65910.dtsi +++ b/arch/arm/dts/tps65910.dtsi @@ -1,9 +1,6 @@ +// SPDX-License-Identifier: GPL-2.0-only /* * Copyright (C) 2012 Texas Instruments Incorporated - http://www.ti.com/ - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. */
The Sancloud BeagleBone Enhanced Lite (BBE Lite) has its own devicetree file and the board can be identified by the 2nd letter of the config string within the common EEPROM.
Signed-off-by: Paul Barker paul.barker@sancloud.com --- board/ti/am335x/board.c | 10 ++++++++-- include/configs/am335x_evm.h | 2 ++ 2 files changed, 10 insertions(+), 2 deletions(-)
diff --git a/board/ti/am335x/board.c b/board/ti/am335x/board.c index 9b7067040a68..dd54f4d457a6 100644 --- a/board/ti/am335x/board.c +++ b/board/ti/am335x/board.c @@ -825,8 +825,14 @@ int board_late_init(void)
if (board_is_bbg1()) name = "BBG1"; - if (board_is_bben()) - name = "BBEN"; + if (board_is_bben()) { + char subtype_id = board_ti_get_config()[1]; + + if (subtype_id == 'L') + name = "BBELITE"; + else + name = "BBEN"; + } set_board_info_env(name);
/* diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index cbb7b91139d0..746d11b0a9b2 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -134,6 +134,8 @@ "setenv fdtfile am335x-boneblue.dtb; fi; " \ "if test $board_name = BBEN; then " \ "setenv fdtfile am335x-sancloud-bbe.dtb; fi; " \ + "if test $board_name = BBELITE; then " \ + "setenv fdtfile am335x-sancloud-bbe-lite.dtb; fi; " \ "if test $board_name = A33515BB; then " \ "setenv fdtfile am335x-evm.dtb; fi; " \ "if test $board_name = A335X_SK; then " \
The Sancloud BeagleBone Enhanced Extended WiFi (BBE Extended WiFi) has its own devicetree file and the board can be identified by the 2nd letter of the config string within the common EEPROM.
diff --git a/board/ti/am335x/board.c b/board/ti/am335x/board.c index dd54f4d457a6..7c0545892c95 100644 --- a/board/ti/am335x/board.c +++ b/board/ti/am335x/board.c @@ -828,10 +828,16 @@ int board_late_init(void) if (board_is_bben()) { char subtype_id = board_ti_get_config()[1];
- if (subtype_id == 'L') + switch (subtype_id) { + case 'L': name = "BBELITE"; - else + break; + case 'I': + name = "BBE_EX_WIFI"; + break; + default: name = "BBEN"; + } } set_board_info_env(name);
diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index 746d11b0a9b2..fd5b209a52db 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -136,6 +136,8 @@ "setenv fdtfile am335x-sancloud-bbe.dtb; fi; " \ "if test $board_name = BBELITE; then " \ "setenv fdtfile am335x-sancloud-bbe-lite.dtb; fi; " \ + "if test $board_name = BBE_EX_WIFI; then " \ + "setenv fdtfile am335x-sancloud-bbe-extended-wifi.dtb; fi; " \ "if test $board_name = A33515BB; then " \ "setenv fdtfile am335x-evm.dtb; fi; " \ "if test $board_name = A335X_SK; then " \
Paul Barker
