[U-Boot] [PATH V3] usb: dwc2: invalidate the dcache before starting the DMA
We should invalidate the dcache before starting the DMA. In case there are any dirty lines from the DMA buffer in the cache, subsequent cache-line replacements may corrupt the buffer in memory while the DMA is still going on. Cache-line replacement can happen if the CPU tries to bring some other memory locations into the cache while the DMA is going on.
Signed-off-by: Eddie Cai eddie.cai.linux@gmail.com Reviewed-by: Stefan Brüns stefan.bruens@rwth-aachen.de --- drivers/usb/host/dwc2.c | 19 +++++++++++++------ 1 file changed, 13 insertions(+), 6 deletions(-)
diff --git a/drivers/usb/host/dwc2.c b/drivers/usb/host/dwc2.c index 5ac602e..f295843 100644 --- a/drivers/usb/host/dwc2.c +++ b/drivers/usb/host/dwc2.c @@ -811,12 +811,19 @@ static int transfer_chunk(struct dwc2_hc_regs *hc_regs, void *aligned_buffer, (*pid << DWC2_HCTSIZ_PID_OFFSET), &hc_regs->hctsiz);
- if (!in && xfer_len) { - memcpy(aligned_buffer, buffer, xfer_len); - - flush_dcache_range((unsigned long)aligned_buffer, - (unsigned long)aligned_buffer + - roundup(xfer_len, ARCH_DMA_MINALIGN)); + if (xfer_len) { + if (in) { + invalidate_dcache_range( + (uintptr_t)aligned_buffer, + (uintptr_t)aligned_buffer + + roundup(xfer_len, ARCH_DMA_MINALIGN)); + } else { + memcpy(aligned_buffer, buffer, xfer_len); + flush_dcache_range( + (uintptr_t)aligned_buffer, + (uintptr_t)aligned_buffer + + roundup(xfer_len, ARCH_DMA_MINALIGN)); + } }
writel(phys_to_bus((unsigned long)aligned_buffer), &hc_regs->hcdma);
Applied, thanks.
Eddie Cai
