[U-Boot] Pull request u-boot-blackfin.git (sf branch)
The following changes since commit 4d3c95f5ea7c737a21cd6b9c59435ee693b3f127:
zfs: Add ZFS filesystem support (2012-08-09 23:42:20 +0200)
git://www.denx.de/git/u-boot-blackfin.git sf
for you to fetch changes up to 4a4cb4e11149158c9eabb1537a1eaee7372ce491:
sf: spansion: Add support for S25FL256S (2012-08-14 11:45:50 -0400)
---------------------------------------------------------------- Marek Vasut (1): cmd_spi: remove superfluous semicolon
Michal Simek (2): sf: stmicro: add support for N25Q128A sf: spansion: Add support for S25FL256S
Rajeshwari Shinde (1): sf: winbond: add W25Q32
Stephan Linz (2): sf: stmicro: support JEDEC standard two-byte signature sf: stmicro: add support N25Q128 parts
Stephen Warren (1): sf: winbond: fix page_size
common/cmd_spi.c | 2 +- drivers/mtd/spi/spansion.c | 7 +++++++ drivers/mtd/spi/stmicro.c | 39 +++++++++++++++++++++++++++------------ drivers/mtd/spi/winbond.c | 7 ++++++- 4 files changed, 41 insertions(+), 14 deletions(-)
Dear Mike Frysinger,
Applied, thanks.
how about
http://patchwork.ozlabs.org/patch/177896/ and http://patchwork.ozlabs.org/patch/178691/
I think they are required for new at91sam9x5 board support for serial flash booting.
Best regards
Andreas Bießmann
Hi Mike Frysinger,
how about
These two patches are needed for supporting new at91sam9x5 board with serial flash booting.
Would these patches can be merged? Or else, the at91sam9x5 serial flash can not work.
Btw, in e-mail, I see you merged: spi: add atmel at25df321 serial flash support (http://patchwork.ozlabs.org/patch/177896/) but I don't find it on your git tree.
Best regards
Andreas Bießmann
Hi Mike Frysinger,
On 9/5/2012 9:54, Bo Shen wrote:
Hi Mike Frysinger,
how about
Ping.
Best regards
Andreas Bießmann
On 10.09.2012 09:14, Bo Shen wrote:
Hi Mike Frysinger,
Hi Mike Frysinger,
how about
Ping.
Any update here?
Is it Ok for you that I pick those two patches and push them through u-boot-atmel for this upcoming release?
Best regards
Andreas Bießmann
Andreas Bießmann
Bo Shen
Mike Frysinger
