Re: [U-Boot] U-Boot Digest, Vol 47, Issue 24
Message: 54 Date: Thu, 19 Apr 2012 09:13:38 +0200 From: Albert ARIBAUD albert.u.boot@aribaud.net Subject: [U-Boot] [ARM] [STATUS] Increasingly high build failures To: "U-Boot@lists.denx.de" U-Boot@lists.denx.de Cc: Simon Guinot simon.guinot@sequanux.org Message-ID: 4F8FBB22.5000205@aribaud.net Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Folks,
I just did another round of ./MAKEALL arm with MG/CS 2011.09-69, and the failure rate is rising to say the least, with 277 boards failing out of 278. :(
Basically, the issues are, in order of impact:
- Now 264 'uses variable-size enums yet the output is to use 32-bit
enums' errors. That's a raise! Probably caused by some commonly included .h, but as the issue is at link stage and only refers to library intrinsics, tracing the culprit may take time. However, I cannot keep on ignoring this warning now, and thus I will look for a general solution, probably along the lines of enabling variable-size enums throughout the U-Boot codebase at least for toolchains that complain about it.
- 6 warnings are 'ap20.c:44:18: warning: array subscript is above array
bounds'. Last changed was in commit 03c609f6. Simon Glass, as you are listed as author of the commit, please have a look.
Albert,
Looks like you CC'd Simon Guinot instead of Simon Glass. I've CC'd the correct Simon. ;)
This change (ap20.c) went in a _long_ time ago, and hasn't produced any warnings until now?
As Wolfgang said, what toolset are you using? I tried TOT U-Boot master with gcc 4.4.1, 4.2.2 (ELDK4.2), and 4.6.1, and don't see any warnings at all for ap20.c in any build (Seaboard, Harmony, etc.).
Tom
- netspace_v2 board causing the only error case: Undefined or
unsupported LaCie KW board variant. Simon Guinot, as you are listed as the board maintainer, can you have a look?
This pretty much covers the immediate actions, but extrapolating from the situation, I would advise any and all contributors whose first name is Simon and last name initial is G to watch out for issues. :)
Amicalement,
Albert.
Le 19/04/2012 18:59, Tom Warren a écrit :
Albert,
I actually intended to Cc: both, as I though eache one had something to do. :)
As I said in the followup discussion with Wolfgang, I had a double issue, with the commit I was using and with the toolchain. The only real issue is the enums one, and I am looking into it.
Amicalement,
Albert ARIBAUD
Tom Warren
