[U-Boot] [PATCH] spl: fix debug prints for tiny printf
Tiny printf does not support %.*s and %lX. Since tiny printf should be very common in SPL, replace these by %32s (for printing image name) and %lx.
Signed-off-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com ---
common/spl/spl.c | 14 ++++++-------- 1 file changed, 6 insertions(+), 8 deletions(-)
diff --git a/common/spl/spl.c b/common/spl/spl.c index 292e659c9a..12f9359c0a 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -185,9 +185,8 @@ static int spl_load_fit_image(struct spl_image_info *spl_image, spl_image->os = IH_OS_U_BOOT; spl_image->name = "U-Boot";
- debug("spl: payload image: %.*s load addr: 0x%lx size: %d\n", - (int)sizeof(spl_image->name), spl_image->name, - spl_image->load_addr, spl_image->size); + debug("spl: payload image: %32s load addr: 0x%lx size: %d\n", + spl_image->name, spl_image->load_addr, spl_image->size);
#ifdef CONFIG_SPL_FIT_SIGNATURE images.verify = 1; @@ -256,9 +255,8 @@ int spl_parse_image_header(struct spl_image_info *spl_image, } spl_image->os = image_get_os(header); spl_image->name = image_get_name(header); - debug("spl: payload image: %.*s load addr: 0x%lx size: %d\n", - IH_NMLEN, spl_image->name, - spl_image->load_addr, spl_image->size); + debug("spl: payload image: %32s load addr: 0x%lx size: %d\n", + spl_image->name, spl_image->load_addr, spl_image->size); #else /* LEGACY image not supported */ debug("Legacy boot image support not enabled, proceeding to other boot methods\n"); @@ -314,7 +312,7 @@ __weak void __noreturn jump_to_image_no_args(struct spl_image_info *spl_image) image_entry_noargs_t image_entry = (image_entry_noargs_t)spl_image->entry_point;
- debug("image entry point: 0x%lX\n", spl_image->entry_point); + debug("image entry point: 0x%lx\n", spl_image->entry_point); image_entry(); }
@@ -554,7 +552,7 @@ void board_init_r(gd_t *dummy1, ulong dummy2) debug("Unsupported OS image.. Jumping nevertheless..\n"); } #if CONFIG_VAL(SYS_MALLOC_F_LEN) && !defined(CONFIG_SYS_SPL_MALLOC_SIZE) - debug("SPL malloc() used %#lx bytes (%ld KB)\n", gd->malloc_ptr, + debug("SPL malloc() used 0x%lx bytes (%ld KB)\n", gd->malloc_ptr, gd->malloc_ptr / 1024); #endif #ifdef CONFIG_BOOTSTAGE_STASH
On 2 November 2018 at 14:49, Simon Goldschmidt simon.k.r.goldschmidt@gmail.com wrote:
Great, I had a patch locally for this, thanks!
- Simon
Signed-off-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com Reviewed-by: Simon Glass sjg@chromium.org
Simon Goldschmidt
