[PATCH v2] arm: dts: imx8m: move CAAM nodes into common u-boot.dtsi
Move the crypto and sec_jr* nodes from board-specific u-boot.dtsi files into the common files. Additionally protect the nodes with ifdef CONFIG_FSL_CAAM as they don't serve any purpose if that is not enabled.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- v2: - fix invalid ifdef - add rb tags from Fabio and Peng --- arch/arm/dts/imx8mm-evk-u-boot.dtsi | 16 --------------- .../dts/imx8mm-kontron-bl-common-u-boot.dtsi | 16 --------------- arch/arm/dts/imx8mm-u-boot.dtsi | 20 +++++++++++++++++++ arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi | 16 --------------- arch/arm/dts/imx8mn-u-boot.dtsi | 20 +++++++++++++++++++ arch/arm/dts/imx8mp-beacon-kit-u-boot.dtsi | 16 --------------- arch/arm/dts/imx8mp-evk-u-boot.dtsi | 16 --------------- .../imx8mp-icore-mx8mp-edimm2.2-u-boot.dtsi | 16 --------------- arch/arm/dts/imx8mp-u-boot.dtsi | 20 +++++++++++++++++++ .../dts/imx8mp-verdin-wifi-dev-u-boot.dtsi | 16 --------------- 10 files changed, 60 insertions(+), 112 deletions(-)
diff --git a/arch/arm/dts/imx8mm-evk-u-boot.dtsi b/arch/arm/dts/imx8mm-evk-u-boot.dtsi index 155670da18d1..9a5b0795133b 100644 --- a/arch/arm/dts/imx8mm-evk-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-evk-u-boot.dtsi @@ -65,22 +65,6 @@ bootph-pre-ram; };
-&crypto { - bootph-pre-ram; -}; - -&sec_jr0 { - bootph-pre-ram; -}; - -&sec_jr1 { - bootph-pre-ram; -}; - -&sec_jr2 { - bootph-pre-ram; -}; - &usbmisc1 { bootph-pre-ram; }; diff --git a/arch/arm/dts/imx8mm-kontron-bl-common-u-boot.dtsi b/arch/arm/dts/imx8mm-kontron-bl-common-u-boot.dtsi index 1ad9d49a1118..ae542fdcffad 100644 --- a/arch/arm/dts/imx8mm-kontron-bl-common-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-kontron-bl-common-u-boot.dtsi @@ -18,22 +18,6 @@ }; };
-&crypto { - bootph-pre-ram; -}; - -&sec_jr0 { - bootph-pre-ram; -}; - -&sec_jr1 { - bootph-pre-ram; -}; - -&sec_jr2 { - bootph-pre-ram; -}; - &i2c1 { bootph-pre-ram; bootph-all; diff --git a/arch/arm/dts/imx8mm-u-boot.dtsi b/arch/arm/dts/imx8mm-u-boot.dtsi index a843bb851eaf..0bd7ad980b66 100644 --- a/arch/arm/dts/imx8mm-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-u-boot.dtsi @@ -18,6 +18,12 @@ #endif };
+#ifdef CONFIG_FSL_CAAM +&crypto { + bootph-pre-ram; +}; +#endif + &soc { bootph-all; bootph-pre-ram; @@ -216,6 +222,20 @@ bootph-pre-ram; };
+#ifdef CONFIG_FSL_CAAM +&sec_jr0 { + bootph-pre-ram; +}; + +&sec_jr1 { + bootph-pre-ram; +}; + +&sec_jr2 { + bootph-pre-ram; +}; +#endif + &spba1 { bootph-all; bootph-pre-ram; diff --git a/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi b/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi index 315714f39848..c31f3dec3de4 100644 --- a/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi @@ -57,22 +57,6 @@ bootph-pre-ram; };
-&crypto { - bootph-pre-ram; -}; - -&sec_jr0 { - bootph-pre-ram; -}; - -&sec_jr1 { - bootph-pre-ram; -}; - -&sec_jr2 { - bootph-pre-ram; -}; - &usdhc1 { bootph-pre-ram; }; diff --git a/arch/arm/dts/imx8mn-u-boot.dtsi b/arch/arm/dts/imx8mn-u-boot.dtsi index 86c9a6cd67f0..3a9e4c16281e 100644 --- a/arch/arm/dts/imx8mn-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-u-boot.dtsi @@ -54,6 +54,12 @@ /delete-property/ assigned-clock-rates; };
+#ifdef CONFIG_FSL_CAAM +&crypto { + bootph-pre-ram; +}; +#endif + &iomuxc { bootph-pre-ram; }; @@ -63,6 +69,20 @@ bootph-all; };
+#ifdef CONFIG_FSL_CAAM +&sec_jr0 { + bootph-pre-ram; +}; + +&sec_jr1 { + bootph-pre-ram; +}; + +&sec_jr2 { + bootph-pre-ram; +}; +#endif + &spba1 { bootph-pre-ram; }; diff --git a/arch/arm/dts/imx8mp-beacon-kit-u-boot.dtsi b/arch/arm/dts/imx8mp-beacon-kit-u-boot.dtsi index c69f7c9c32c0..393fd8ec2e5b 100644 --- a/arch/arm/dts/imx8mp-beacon-kit-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-beacon-kit-u-boot.dtsi @@ -21,10 +21,6 @@ bootph-pre-ram; };
-&crypto { - bootph-pre-ram; -}; - &eqos { /delete-property/ assigned-clocks; /delete-property/ assigned-clock-parents; @@ -131,18 +127,6 @@ u-boot,off-on-delay-us = <20000>; };
-&sec_jr0 { - bootph-pre-ram; -}; - -&sec_jr1 { - bootph-pre-ram; -}; - -&sec_jr2 { - bootph-pre-ram; -}; - &tpm { compatible = "tcg,tpm_tis-spi"; }; diff --git a/arch/arm/dts/imx8mp-evk-u-boot.dtsi b/arch/arm/dts/imx8mp-evk-u-boot.dtsi index 17965c58ba10..6d9b229989ac 100644 --- a/arch/arm/dts/imx8mp-evk-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-evk-u-boot.dtsi @@ -65,22 +65,6 @@ bootph-pre-ram; };
-&crypto { - bootph-pre-ram; -}; - -&sec_jr0 { - bootph-pre-ram; -}; - -&sec_jr1 { - bootph-pre-ram; -}; - -&sec_jr2 { - bootph-pre-ram; -}; - &i2c1 { bootph-pre-ram; }; diff --git a/arch/arm/dts/imx8mp-icore-mx8mp-edimm2.2-u-boot.dtsi b/arch/arm/dts/imx8mp-icore-mx8mp-edimm2.2-u-boot.dtsi index fe20938af536..cf2a87a9b903 100644 --- a/arch/arm/dts/imx8mp-icore-mx8mp-edimm2.2-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-icore-mx8mp-edimm2.2-u-boot.dtsi @@ -62,22 +62,6 @@ bootph-pre-ram; };
-&crypto { - bootph-pre-ram; -}; - -&sec_jr0 { - bootph-pre-ram; -}; - -&sec_jr1 { - bootph-pre-ram; -}; - -&sec_jr2 { - bootph-pre-ram; -}; - &i2c1 { bootph-pre-ram; }; diff --git a/arch/arm/dts/imx8mp-u-boot.dtsi b/arch/arm/dts/imx8mp-u-boot.dtsi index b2f213e3e706..afaf64ee9cd8 100644 --- a/arch/arm/dts/imx8mp-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-u-boot.dtsi @@ -19,6 +19,12 @@ #endif };
+#ifdef CONFIG_FSL_CAAM +&crypto { + bootph-pre-ram; +}; +#endif + &soc { bootph-all; bootph-pre-ram; @@ -62,6 +68,20 @@ bootph-pre-ram; };
+#ifdef CONFIG_FSL_CAAM +&sec_jr0 { + bootph-pre-ram; +}; + +&sec_jr1 { + bootph-pre-ram; +}; + +&sec_jr2 { + bootph-pre-ram; +}; +#endif + &binman { u-boot-spl-ddr { filename = "u-boot-spl-ddr.bin"; diff --git a/arch/arm/dts/imx8mp-verdin-wifi-dev-u-boot.dtsi b/arch/arm/dts/imx8mp-verdin-wifi-dev-u-boot.dtsi index fc87d3f4035b..2a1aa1935a76 100644 --- a/arch/arm/dts/imx8mp-verdin-wifi-dev-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-verdin-wifi-dev-u-boot.dtsi @@ -28,10 +28,6 @@
-&crypto { - bootph-pre-ram; -}; - &gpio1 { bootph-pre-ram; }; @@ -140,18 +136,6 @@ bootph-pre-ram; };
-&sec_jr0 { - bootph-pre-ram; -}; - -&sec_jr1 { - bootph-pre-ram; -}; - -&sec_jr2 { - bootph-pre-ram; -}; - &uart3 { bootph-pre-ram; };
Hi Tim
Thanks!
Reviewed-by: Marcel Ziswiler marcel.ziswiler@toradex.com
diff --git a/arch/arm/dts/imx8mm-evk-u-boot.dtsi b/arch/arm/dts/imx8mm-evk-u-boot.dtsi index 155670da18d1..9a5b0795133b 100644 --- a/arch/arm/dts/imx8mm-evk-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-evk-u-boot.dtsi @@ -65,22 +65,6 @@ bootph-pre-ram; }; -&crypto { - bootph-pre-ram; -};
&usbmisc1 { bootph-pre-ram; }; diff --git a/arch/arm/dts/imx8mm-kontron-bl-common-u-boot.dtsi b/arch/arm/dts/imx8mm-kontron-bl-common-u- boot.dtsi index 1ad9d49a1118..ae542fdcffad 100644 --- a/arch/arm/dts/imx8mm-kontron-bl-common-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-kontron-bl-common-u-boot.dtsi @@ -18,22 +18,6 @@ }; }; -&crypto { - bootph-pre-ram; -};
&i2c1 { bootph-pre-ram; bootph-all; diff --git a/arch/arm/dts/imx8mm-u-boot.dtsi b/arch/arm/dts/imx8mm-u-boot.dtsi index a843bb851eaf..0bd7ad980b66 100644 --- a/arch/arm/dts/imx8mm-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-u-boot.dtsi @@ -18,6 +18,12 @@ #endif }; +#ifdef CONFIG_FSL_CAAM +&crypto { + bootph-pre-ram; +}; +#endif
&soc { bootph-all; bootph-pre-ram; @@ -216,6 +222,20 @@ bootph-pre-ram; }; +#ifdef CONFIG_FSL_CAAM +&sec_jr0 { + bootph-pre-ram; +};
&spba1 { bootph-all; bootph-pre-ram; diff --git a/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi b/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi index 315714f39848..c31f3dec3de4 100644 --- a/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi @@ -57,22 +57,6 @@ bootph-pre-ram; }; -&crypto { - bootph-pre-ram; -};
&usdhc1 { bootph-pre-ram; }; diff --git a/arch/arm/dts/imx8mn-u-boot.dtsi b/arch/arm/dts/imx8mn-u-boot.dtsi index 86c9a6cd67f0..3a9e4c16281e 100644 --- a/arch/arm/dts/imx8mn-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-u-boot.dtsi @@ -54,6 +54,12 @@ /delete-property/ assigned-clock-rates; }; +#ifdef CONFIG_FSL_CAAM +&crypto { + bootph-pre-ram; +}; +#endif
&iomuxc { bootph-pre-ram; }; @@ -63,6 +69,20 @@ bootph-all; }; +#ifdef CONFIG_FSL_CAAM +&sec_jr0 { + bootph-pre-ram; +};
&spba1 { bootph-pre-ram; }; diff --git a/arch/arm/dts/imx8mp-beacon-kit-u-boot.dtsi b/arch/arm/dts/imx8mp-beacon-kit-u-boot.dtsi index c69f7c9c32c0..393fd8ec2e5b 100644 --- a/arch/arm/dts/imx8mp-beacon-kit-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-beacon-kit-u-boot.dtsi @@ -21,10 +21,6 @@ bootph-pre-ram; }; -&crypto { - bootph-pre-ram; -};
&eqos { /delete-property/ assigned-clocks; /delete-property/ assigned-clock-parents; @@ -131,18 +127,6 @@ u-boot,off-on-delay-us = <20000>; }; -&sec_jr0 { - bootph-pre-ram; -};
&tpm { compatible = "tcg,tpm_tis-spi"; }; diff --git a/arch/arm/dts/imx8mp-evk-u-boot.dtsi b/arch/arm/dts/imx8mp-evk-u-boot.dtsi index 17965c58ba10..6d9b229989ac 100644 --- a/arch/arm/dts/imx8mp-evk-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-evk-u-boot.dtsi @@ -65,22 +65,6 @@ bootph-pre-ram; }; -&crypto { - bootph-pre-ram; -};
&i2c1 { bootph-pre-ram; }; diff --git a/arch/arm/dts/imx8mp-icore-mx8mp-edimm2.2-u-boot.dtsi b/arch/arm/dts/imx8mp-icore-mx8mp-edimm2.2- u-boot.dtsi index fe20938af536..cf2a87a9b903 100644 --- a/arch/arm/dts/imx8mp-icore-mx8mp-edimm2.2-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-icore-mx8mp-edimm2.2-u-boot.dtsi @@ -62,22 +62,6 @@ bootph-pre-ram; }; -&crypto { - bootph-pre-ram; -};
&i2c1 { bootph-pre-ram; }; diff --git a/arch/arm/dts/imx8mp-u-boot.dtsi b/arch/arm/dts/imx8mp-u-boot.dtsi index b2f213e3e706..afaf64ee9cd8 100644 --- a/arch/arm/dts/imx8mp-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-u-boot.dtsi @@ -19,6 +19,12 @@ #endif }; +#ifdef CONFIG_FSL_CAAM +&crypto { + bootph-pre-ram; +}; +#endif
&soc { bootph-all; bootph-pre-ram; @@ -62,6 +68,20 @@ bootph-pre-ram; }; +#ifdef CONFIG_FSL_CAAM +&sec_jr0 { + bootph-pre-ram; +};
&binman { u-boot-spl-ddr { filename = "u-boot-spl-ddr.bin"; diff --git a/arch/arm/dts/imx8mp-verdin-wifi-dev-u-boot.dtsi b/arch/arm/dts/imx8mp-verdin-wifi-dev-u- boot.dtsi index fc87d3f4035b..2a1aa1935a76 100644 --- a/arch/arm/dts/imx8mp-verdin-wifi-dev-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-verdin-wifi-dev-u-boot.dtsi @@ -28,10 +28,6 @@ }; -&crypto { - bootph-pre-ram; -};
&gpio1 { bootph-pre-ram; }; @@ -140,18 +136,6 @@ bootph-pre-ram; }; -&sec_jr0 { - bootph-pre-ram; -};
Cheers
Marcel
Move the crypto and sec_jr* nodes from board-specific u-boot.dtsi files into the common files. Additionally protect the nodes with ifdef CONFIG_FSL_CAAM as they don't serve any purpose if that is not enabled. Signed-off-by: Tim Harvey tharvey@gateworks.com Reviewed-by: Marcel Ziswiler marcel.ziswiler@toradex.com
Best regards, Stefano Babic
Marcel Ziswiler
sbabic@denx.de
Tim Harvey
