[PATCH] clock_imx8mm: Add a stub for imx8mp_fec_interface_init()
When CONFIG_DWC_ETH_QOS_IMX=y and CONFIG_FEC_MXC is not selected, the following warning is seen:
arch/arm/mach-imx/imx8m/clock_imx8mm.c: In function 'board_interface_eth_init': arch/arm/mach-imx/imx8m/clock_imx8mm.c:914:24: warning: implicit declaration of function 'imx8mp_fec_interface_init; did you mean 'imx8mp_eqos_interface_init'? [-Wimplicit-function-declaration]
Fix it by adding a stub for imx8mp_fec_interface_init() to handle this case.
This follows the same approach done on imx8mp_eqos_interface_init().
Signed-off-by: Fabio Estevam festevam@denx.de --- arch/arm/mach-imx/imx8m/clock_imx8mm.c | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/arch/arm/mach-imx/imx8m/clock_imx8mm.c b/arch/arm/mach-imx/imx8m/clock_imx8mm.c index 986870799d36..5cf97a5ea952 100644 --- a/arch/arm/mach-imx/imx8m/clock_imx8mm.c +++ b/arch/arm/mach-imx/imx8m/clock_imx8mm.c @@ -904,6 +904,13 @@ static int imx8mp_fec_interface_init(struct udevice *dev,
return 0; } +#else +static int imx8mp_fec_interface_init(struct udevice *dev, + phy_interface_t interface_type, + bool mx8mp) +{ + return 0; +} #endif
int board_interface_eth_init(struct udevice *dev, phy_interface_t interface_type)
Applied to u-boot-imx next, thanks.
Fabio Estevam
