[PATCH] net: eth-uclass: Change uclass driver name to ethernet
dev_read_alias_seq() used uc_drv->name compared to alias stem string, Ethernet's alias stem uses "ethernet", which does not match the eth-uclass driver name "eth", can not get the correct index of ethernet alias namer. So it seems change uclass driver name to match the alias stem is a more reasonable way.
Signed-off-by: David Wu david.wu@rock-chips.com --- net/eth-uclass.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/net/eth-uclass.c b/net/eth-uclass.c index e14695c0f1..7dd962db64 100644 --- a/net/eth-uclass.c +++ b/net/eth-uclass.c @@ -594,7 +594,7 @@ static int eth_pre_remove(struct udevice *dev) }
UCLASS_DRIVER(eth) = { - .name = "eth", + .name = "ethernet", .id = UCLASS_ETH, .post_bind = eth_post_bind, .pre_unbind = eth_pre_unbind,
Hi David,
Should change this one too ^
.name = "eth",
-- 2.19.1
David Wu
