[PATCH] arm: cmd_stm32prog: Fix the CONFIG_IS_ENABLED() usage
Add parentheses around CONFIG_IS_ENABLED() in the if statement, to fix potential build failures.
Signed-off-by: Bin Meng bmeng.cn@gmail.com
--- Fixes the issue as seen with Azure: https://dev.azure.com/bmeng/GitHub/_build/results?buildId=251&view=logs&...
arch/arm/mach-stm32mp/cmd_stm32prog/cmd_stm32prog.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-stm32mp/cmd_stm32prog/cmd_stm32prog.c b/arch/arm/mach-stm32mp/cmd_stm32prog/cmd_stm32prog.c index 0722e4a..cbf0120 100644 --- a/arch/arm/mach-stm32mp/cmd_stm32prog/cmd_stm32prog.c +++ b/arch/arm/mach-stm32mp/cmd_stm32prog/cmd_stm32prog.c @@ -147,7 +147,7 @@ static int do_stm32prog(struct cmd_tbl *cmdtp, int flag, int argc, /* Try bootm for legacy and FIT format image */ if (genimg_get_format((void *)uimage) != IMAGE_FORMAT_INVALID) do_bootm(cmdtp, 0, 4, bootm_argv); - else if CONFIG_IS_ENABLED(CMD_BOOTZ) + else if (CONFIG_IS_ENABLED(CMD_BOOTZ)) do_bootz(cmdtp, 0, 4, bootm_argv); }
Hi Bin,
From: Bin Meng bmeng.cn@gmail.com Sent: mercredi 8 juillet 2020 09:19
Fixes the issue as seen with Azure: https://dev.azure.com/bmeng/GitHub/_build/results?buildId=251&view=logs&... 47dc8-3759-5480-c2ba-b1f5a74bd12e&t=3906ed62-68d1-5fd5-bbe4-e8a557f9b32f
}else if (CONFIG_IS_ENABLED(CMD_BOOTZ)) do_bootz(cmdtp, 0, 4, bootm_argv);
-- 2.7.4
Reviewed-by: Patrick Delaunay patrick.delaunay@st.com
Thanks
Patrick
On Thu, Jul 9, 2020 at 1:32 AM Patrick DELAUNAY patrick.delaunay@st.com wrote:
Hi Bin,
-- 2.7.4
applied to u-boot-x86, thanks!
Bin Meng
Patrick DELAUNAY
