[PATCH V2] arm: stm32mp1: Set soc_type, soc_pkg, soc_rev env variables
Split up get_soc_name(), clean the decoding up a bit, and set up environment variables which contain the SoC type, package, revision. This is useful on SoMs, where multiple SoC options are populated.
Signed-off-by: Marek Vasut marex@denx.de Cc: Patrick Delaunay patrick.delaunay@st.com Cc: Patrice Chotard patrice.chotard@st.com --- V2: Fix pkg = 0 , which should be *pkg = 0 --- arch/arm/mach-stm32mp/cpu.c | 105 ++++++++++++++++++------------------ 1 file changed, 53 insertions(+), 52 deletions(-)
diff --git a/arch/arm/mach-stm32mp/cpu.c b/arch/arm/mach-stm32mp/cpu.c index bc2db535beb..ba8771940ef 100644 --- a/arch/arm/mach-stm32mp/cpu.c +++ b/arch/arm/mach-stm32mp/cpu.c @@ -352,89 +352,78 @@ u32 get_cpu_package(void) return get_otp(BSEC_OTP_PKG, PKG_SHIFT, PKG_MASK); }
-void get_soc_name(char name[SOC_NAME_SIZE]) +static const char * const soc_type[] = { + "????", + "151C", "151A", "151F", "151D", + "153C", "153A", "153F", "153D", + "157C", "157A", "157F", "157D" +}; + +static const char * const soc_pkg[] = { "??", "AD", "AC", "AB", "AA" }; +static const char * const soc_rev[] = { "?", "A", "B", "Z" }; + +static void get_cpu_string_offsets(unsigned int *type, unsigned int *pkg, + unsigned int *rev) { - char *cpu_s, *cpu_r, *pkg; + u32 cpu_type = get_cpu_type(); + u32 ct = cpu_type & ~(BIT(7) | BIT(0)); + u32 cm = ((cpu_type & BIT(7)) >> 6) | (cpu_type & BIT(0)); + u32 cp = get_cpu_package();
- /* MPUs Part Numbers */ - switch (get_cpu_type()) { - case CPU_STM32MP157Fxx: - cpu_s = "157F"; - break; - case CPU_STM32MP157Dxx: - cpu_s = "157D"; - break; - case CPU_STM32MP157Cxx: - cpu_s = "157C"; - break; - case CPU_STM32MP157Axx: - cpu_s = "157A"; - break; - case CPU_STM32MP153Fxx: - cpu_s = "153F"; - break; - case CPU_STM32MP153Dxx: - cpu_s = "153D"; + /* Bits 0 and 7 are the ACDF, 00:C 01:A 10:F 11:D */ + switch (ct) { + case CPU_STM32MP151Cxx: + *type = cm + 1; break; case CPU_STM32MP153Cxx: - cpu_s = "153C"; - break; - case CPU_STM32MP153Axx: - cpu_s = "153A"; - break; - case CPU_STM32MP151Fxx: - cpu_s = "151F"; - break; - case CPU_STM32MP151Dxx: - cpu_s = "151D"; + *type = cm + 5; break; - case CPU_STM32MP151Cxx: - cpu_s = "151C"; - break; - case CPU_STM32MP151Axx: - cpu_s = "151A"; + case CPU_STM32MP157Cxx: + *type = cm + 9; break; default: - cpu_s = "????"; + *type = 0; break; }
/* Package */ - switch (get_cpu_package()) { + switch (cp) { case PKG_AA_LBGA448: - pkg = "AA"; - break; case PKG_AB_LBGA354: - pkg = "AB"; - break; case PKG_AC_TFBGA361: - pkg = "AC"; - break; case PKG_AD_TFBGA257: - pkg = "AD"; + *pkg = cp; break; default: - pkg = "??"; + *pkg = 0; break; }
- /* REVISION */ + /* Revision */ switch (get_cpu_rev()) { case CPU_REVA: - cpu_r = "A"; + *rev = 1; break; case CPU_REVB: - cpu_r = "B"; + *rev = 2; break; case CPU_REVZ: - cpu_r = "Z"; + *rev = 3; break; default: - cpu_r = "?"; + *rev = 0; break; } +} + +void get_soc_name(char name[SOC_NAME_SIZE]) +{ + unsigned int type, pkg, rev;
- snprintf(name, SOC_NAME_SIZE, "STM32MP%s%s Rev.%s", cpu_s, pkg, cpu_r); + get_cpu_string_offsets(&type, &pkg, &rev); + + snprintf(name, SOC_NAME_SIZE, "STM32MP%s%s Rev.%s", + soc_type[type], soc_pkg[pkg], soc_rev[rev]); }
#if defined(CONFIG_DISPLAY_CPUINFO) @@ -626,11 +615,23 @@ static int setup_serial_number(void) return 0; }
+static void setup_soc_type_pkg_rev(void) +{ + unsigned int type, pkg, rev; + + get_cpu_string_offsets(&type, &pkg, &rev); + + env_set("soc_type", soc_type[type]); + env_set("soc_pkg", soc_pkg[pkg]); + env_set("soc_rev", soc_rev[rev]); +} + int arch_misc_init(void) { setup_boot_mode(); setup_mac_address(); setup_serial_number(); + setup_soc_type_pkg_rev();
return 0; }
Hi Marek,
Reviewed-by: Patrick Delaunay patrick.delaunay@foss.st.com
Thanks Patrick
Hi Marek
On 4/9/21 2:43 PM, Patrick DELAUNAY wrote:
Hi Marek,
Thanks Patrick
Applied to u-boot-stm/master
Thanks Patrice
Patrice CHOTARD
Patrick DELAUNAY
