[U-Boot] [PATCH] Kconfig: Fix SPL_LOAD_FIT description
Both the SPL_LOAD_FIT and SPL_LOAD_FIT_FULL have the same description. Adjust the description to make it clear which one is which.
Signed-off-by: Marek Vasut marex@denx.de Cc: Tom Rini trini@konsulko.com --- Kconfig | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/Kconfig b/Kconfig index 5f5c5ccfd6..82bdb40ee9 100644 --- a/Kconfig +++ b/Kconfig @@ -388,7 +388,7 @@ config SPL_FIT_SIGNATURE select SPL_RSA
config SPL_LOAD_FIT - bool "Enable SPL loading U-Boot as a FIT" + bool "Enable SPL loading U-Boot as a FIT (basic fitImage features)" select SPL_FIT help Normally with the SPL framework a legacy image is generated as part @@ -399,7 +399,7 @@ config SPL_LOAD_FIT and passing the correct one to U-Boot.
config SPL_LOAD_FIT_FULL - bool "Enable SPL loading U-Boot as a FIT" + bool "Enable SPL loading U-Boot as a FIT (full fitImage features)" select SPL_FIT help Normally with the SPL framework a legacy image is generated as part
