Re: [U-Boot-Users] [DNX#2006081742000098] [PATCH 5/6 ] Unified variable names and consolidat [...]
Hello list,
inside the automatic U-Boot patch tracking system a new ticket [DNX#2006081742000098] was created:
<snip>
Subject: [PATCH] Unified variable names and consolidated macro for MPC8349EMDS
board/mpc8349emds/mpc8349emds.c | 10 +++++++--- board/mpc8349emds/pci.c | 18 +++++++++++------- include/configs/MPC8349EMDS.h | 11 +++++++++++ 3 files changed, 29 insertions(+), 10 deletions(-)
dac81baaa582cf3e59fd7d16ec0d3a6b0e036d6e diff --git a/board/mpc8349emds/mpc8349emds.c b/board/mpc8349emds/mpc8349emds.c index b5ccb53..4e4f65d 100644 --- a/board/mpc8349emds/mpc8349emds.c +++ b/board/mpc8349emds/mpc8349emds.c @@ -5,6 +5,10 @@
- project.
- History :
- 20060601 Daveliu (daveliu@freescale.com)
Unified variable names with mpc83xx
@@ -168,7 +172,7 @@ #if defined(CFG_BR2_PRELIM) \ void sdram_init(void) { volatile immap_t *immap = (immap_t *)CFG_IMMRBAR;
- volatile lbus8349_t *lbc= &immap->lbus;
volatile lbus83xx_t *lbc= &immap->lbus; uint *sdram_addr = (uint *)CFG_LBC_SDRAM_BASE;
puts("\n SDRAM on Local Bus: ");
@@ -246,7 +250,7 @@ #if defined(CONFIG_DDR_ECC) && defined(C void ecc_print_status(void) { volatile immap_t *immap = (immap_t *)CFG_IMMRBAR;
- volatile ddr8349_t *ddr = &immap->ddr;
volatile ddr83xx_t *ddr = &immap->ddr;
printf("\nECC mode: %s\n\n", (ddr->sdram_cfg & SDRAM_CFG_ECC_EN)
? "ON" : "OFF");
@@ -321,7 +325,7 @@ void ecc_print_status(void) int do_ecc ( cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { volatile immap_t *immap = (immap_t *)CFG_IMMRBAR;
- volatile ddr83xx_t *ddr = &immap->ddr; volatile u32 val; u64 *addr, count, val64; register u64 *i;
diff --git a/board/mpc8349emds/pci.c b/board/mpc8349emds/pci.c index 63e4405..d98203b 100644 --- a/board/mpc8349emds/pci.c +++ b/board/mpc8349emds/pci.c @@ -2,6 +2,10 @@
- project.
- History:
@@ -72,7 +76,7 @@ pib_init(void) /* * Assign PIB PMC slot to desired PCI bus */
- mpc8349_i2c = (i2c_t*)(CFG_IMMRBAR + CFG_I2C2_OFFSET);
mpc83xx_i2c = (i2c_t*)(CFG_IMMRBAR + CFG_I2C2_OFFSET); i2c_init(CFG_I2C_SPEED, CFG_I2C_SLAVE);
val8 = 0;
@@ -130,18 +134,18 @@ void pci_init_board(void) { volatile immap_t * immr;
- volatile clk8349_t * clk;
- volatile law8349_t * pci_law;
- volatile pot8349_t * pci_pot;
- volatile pcictrl8349_t * pci_ctrl;
- volatile pciconf8349_t * pci_conf;
volatile clk83xx_t * clk;
volatile law83xx_t * pci_law;
volatile pot83xx_t * pci_pot;
volatile pcictrl83xx_t * pci_ctrl;
volatile pciconf83xx_t * pci_conf; u16 reg16; u32 reg32; u32 dev; struct pci_controller * hose;
immr = (immap_t *)CFG_IMMRBAR;
- clk = (clk8349_t *)&immr->clk;
</snip>
Your U-Boot support team
DENX Support System
