[U-Boot] [PATCH] mx6qsabrelite: No need to set the direction for GPIO3_23 again
There is a 'gpio_direction_output(87, 0);' call previously, so the GPIO direction is already established.
Use gpio_set_value() for changing the GPIO output then.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- board/freescale/mx6qsabrelite/mx6qsabrelite.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/board/freescale/mx6qsabrelite/mx6qsabrelite.c b/board/freescale/mx6qsabrelite/mx6qsabrelite.c index 1d09a72..2155d87 100644 --- a/board/freescale/mx6qsabrelite/mx6qsabrelite.c +++ b/board/freescale/mx6qsabrelite/mx6qsabrelite.c @@ -135,7 +135,7 @@ static void setup_iomux_enet(void)
/* Need delay 10ms according to KSZ9021 spec */ udelay(1000 * 10); - gpio_direction_output(87, 1); /* GPIO 3-23 */ + gpio_set_value(87, 1); /* GPIO 3-23 */
imx_iomux_v3_setup_multiple_pads(enet_pads2, ARRAY_SIZE(enet_pads2)); }
Signed-off-by: Fabio Estevamfabio.estevam@freescale.com
Acked-by: Dirk Behme dirk.behme@googlemail.com
Thanks
Dirk
Applied to u-boot-imx, thanks.
Best regards, Stefano Babic
Dirk Behme
Fabio Estevam
Stefano Babic
