[PATCHv5 00/18] powerpc: convert p1010, p1020 and p2020 RDB boards to DM_ETH
This patchset is to convert P1010, P1020 and P2020 RDB boards to DM_ETH.
V5: Merged the following thread: https://patchwork.ozlabs.org/project/uboot/list/?series=174343&archive=b...
Hou Zhiqiang (16): net: fsl_mdio: Change to use virtual address net: fsl_mdio: Correct the MII management register block address net: tsec: convert to use DM_MDIO when DM_ETH enabled net: tsec: Add fixed-link PHY support net: tsec: Add the compatible string "gianfar" support powerpc: mpc8xxx: Don't compile cpu_eth_init() when DM_ETH enabled fsl: p1_p2_rdb: Move vsc7835 firmware uploading to board_early_init_r() configs: p1_p2_rdb: Add the default address of vsc7385 firmware dts: powerpc: p1020rdb: Add eTSEC DT nodes powerpc: p1_p2_rdb: Don't compile board_eth_init() when DM_ETH enabled configs: P1020RDB: Enable DM_ETH config dts: powerpc: p1010rdb: Add eTSEC DT nodes powerpc: p1010rdb: Compile legacy ethernet init function when no DM_ETH configs: P1010RDB: Enable DM_ETH config dts: powerpc: p2020rdb: Add eTSEC DT nodes configs: P2020RDB: Enable DM_ETH config
Vladimir Oltean (2): phy: make phy_connect_fixed work with a null mdio bus configs: enable DM_MDIO for LS1021A-TWR and LS1021A-TSN
arch/powerpc/cpu/mpc8xxx/cpu.c | 2 + arch/powerpc/dts/p1010rdb-pa.dts | 1 + arch/powerpc/dts/p1010rdb-pa_36b.dts | 1 + arch/powerpc/dts/p1010rdb.dtsi | 50 +++++++++++++++ arch/powerpc/dts/p1010si-post.dtsi | 25 ++++++++ arch/powerpc/dts/p1020-post.dtsi | 20 +++++- arch/powerpc/dts/p1020rdb-pc.dts | 1 + arch/powerpc/dts/p1020rdb-pc.dtsi | 55 ++++++++++++++++ arch/powerpc/dts/p1020rdb-pc_36b.dts | 1 + arch/powerpc/dts/p1020rdb-pd.dts | 45 ++++++++++++++ arch/powerpc/dts/p2020-post.dtsi | 8 ++- arch/powerpc/dts/p2020rdb-pc.dts | 1 + arch/powerpc/dts/p2020rdb-pc.dtsi | 50 +++++++++++++++ arch/powerpc/dts/p2020rdb-pc_36b.dts | 1 + arch/powerpc/dts/pq3-etsec1-0.dtsi | 28 +++++++++ arch/powerpc/dts/pq3-etsec1-1.dtsi | 28 +++++++++ arch/powerpc/dts/pq3-etsec1-2.dtsi | 28 +++++++++ arch/powerpc/dts/pq3-etsec1-3.dtsi | 28 +++++++++ arch/powerpc/dts/pq3-etsec2-0.dtsi | 35 +++++++++++ arch/powerpc/dts/pq3-etsec2-1.dtsi | 35 +++++++++++ arch/powerpc/dts/pq3-etsec2-2.dtsi | 35 +++++++++++ arch/powerpc/dts/pq3-etsec2-grp2-0.dtsi | 16 +++++ arch/powerpc/dts/pq3-etsec2-grp2-1.dtsi | 16 +++++ arch/powerpc/dts/pq3-etsec2-grp2-2.dtsi | 16 +++++ board/freescale/p1010rdb/p1010rdb.c | 2 + board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c | 37 ++++++----- configs/P1010RDB-PA_36BIT_NAND_defconfig | 2 + configs/P1010RDB-PA_36BIT_NOR_defconfig | 2 + configs/P1010RDB-PA_36BIT_SDCARD_defconfig | 2 + configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig | 2 + configs/P1010RDB-PA_NAND_defconfig | 2 + configs/P1010RDB-PA_NOR_defconfig | 2 + configs/P1010RDB-PA_SDCARD_defconfig | 2 + configs/P1010RDB-PA_SPIFLASH_defconfig | 2 + configs/P1010RDB-PB_36BIT_NAND_defconfig | 2 + configs/P1010RDB-PB_36BIT_NOR_defconfig | 2 + configs/P1010RDB-PB_36BIT_SDCARD_defconfig | 2 + configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig | 2 + configs/P1010RDB-PB_NAND_defconfig | 2 + configs/P1010RDB-PB_NOR_defconfig | 2 + configs/P1010RDB-PB_SDCARD_defconfig | 2 + configs/P1010RDB-PB_SPIFLASH_defconfig | 2 + configs/P1020RDB-PC_36BIT_NAND_defconfig | 3 + configs/P1020RDB-PC_36BIT_SDCARD_defconfig | 3 + configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig | 3 + configs/P1020RDB-PC_36BIT_defconfig | 3 + configs/P1020RDB-PC_NAND_defconfig | 3 + configs/P1020RDB-PC_SDCARD_defconfig | 3 + configs/P1020RDB-PC_SPIFLASH_defconfig | 3 + configs/P1020RDB-PC_defconfig | 3 + configs/P1020RDB-PD_NAND_defconfig | 3 + configs/P1020RDB-PD_SDCARD_defconfig | 3 + configs/P1020RDB-PD_SPIFLASH_defconfig | 3 + configs/P1020RDB-PD_defconfig | 3 + configs/P2020RDB-PC_36BIT_NAND_defconfig | 3 + configs/P2020RDB-PC_36BIT_SDCARD_defconfig | 3 + configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig | 3 + configs/P2020RDB-PC_36BIT_defconfig | 3 + configs/P2020RDB-PC_NAND_defconfig | 3 + configs/P2020RDB-PC_SDCARD_defconfig | 3 + configs/P2020RDB-PC_SPIFLASH_defconfig | 3 + configs/P2020RDB-PC_defconfig | 3 + configs/ls1021atsn_qspi_defconfig | 1 + configs/ls1021atsn_sdcard_defconfig | 1 + configs/ls1021atwr_nor_SECURE_BOOT_defconfig | 1 + configs/ls1021atwr_nor_defconfig | 1 + configs/ls1021atwr_nor_lpuart_defconfig | 1 + configs/ls1021atwr_qspi_defconfig | 1 + ...s1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 1 + configs/ls1021atwr_sdcard_ifc_defconfig | 1 + configs/ls1021atwr_sdcard_qspi_defconfig | 1 + doc/device-tree-bindings/net/fsl-tsec-phy.txt | 2 +- drivers/net/fsl_mdio.c | 28 +++++++-- drivers/net/phy/phy.c | 4 +- drivers/net/tsec.c | 62 ++++++++----------- include/configs/p1_p2_rdb_pc.h | 2 + include/fsl_mdio.h | 4 ++ include/tsec.h | 4 ++ 78 files changed, 707 insertions(+), 65 deletions(-) create mode 100644 arch/powerpc/dts/p1020rdb-pc.dtsi create mode 100644 arch/powerpc/dts/p2020rdb-pc.dtsi create mode 100644 arch/powerpc/dts/pq3-etsec1-0.dtsi create mode 100644 arch/powerpc/dts/pq3-etsec1-1.dtsi create mode 100644 arch/powerpc/dts/pq3-etsec1-2.dtsi create mode 100644 arch/powerpc/dts/pq3-etsec1-3.dtsi create mode 100644 arch/powerpc/dts/pq3-etsec2-0.dtsi create mode 100644 arch/powerpc/dts/pq3-etsec2-1.dtsi create mode 100644 arch/powerpc/dts/pq3-etsec2-2.dtsi create mode 100644 arch/powerpc/dts/pq3-etsec2-grp2-0.dtsi create mode 100644 arch/powerpc/dts/pq3-etsec2-grp2-1.dtsi create mode 100644 arch/powerpc/dts/pq3-etsec2-grp2-2.dtsi
It is utterly pointless to require an MDIO bus pointer for a fixed PHY device. The fixed.c implementation does not require it, only phy_device_create. Fix that.
Signed-off-by: Vladimir Oltean vladimir.oltean@nxp.com Reviewed-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- V5: - Pick from https://patchwork.ozlabs.org/project/uboot/patch/20200503185227.28731-2-olte....
drivers/net/phy/phy.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/net/phy/phy.c b/drivers/net/phy/phy.c index cce09c47f9..a2dd86dba2 100644 --- a/drivers/net/phy/phy.c +++ b/drivers/net/phy/phy.c @@ -664,7 +664,7 @@ static struct phy_device *phy_device_create(struct mii_dev *bus, int addr, dev = malloc(sizeof(*dev)); if (!dev) { printf("Failed to allocate PHY device for %s:%d\n", - bus->name, addr); + bus ? bus->name : "(null bus)", addr); return NULL; }
@@ -692,7 +692,7 @@ static struct phy_device *phy_device_create(struct mii_dev *bus, int addr, return NULL; }
- if (addr >= 0 && addr < PHY_MAX_ADDR) + if (addr >= 0 && addr < PHY_MAX_ADDR && phy_id != PHY_FIXED_ID) bus->phymap[addr] = dev;
return dev;
The tsec driver now requires DM_MDIO when DM_ETH is enabled. To avoid build errors, enable DM_MDIO in these boards' configs before we actually add DM_MDIO support to tsec.
Signed-off-by: Vladimir Oltean vladimir.oltean@nxp.com Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- V5: - Pick from https://patchwork.ozlabs.org/project/uboot/patch/20200503185227.28731-3-olte....
configs/ls1021atsn_qspi_defconfig | 1 + configs/ls1021atsn_sdcard_defconfig | 1 + configs/ls1021atwr_nor_SECURE_BOOT_defconfig | 1 + configs/ls1021atwr_nor_defconfig | 1 + configs/ls1021atwr_nor_lpuart_defconfig | 1 + configs/ls1021atwr_qspi_defconfig | 1 + configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 1 + configs/ls1021atwr_sdcard_ifc_defconfig | 1 + configs/ls1021atwr_sdcard_qspi_defconfig | 1 + 9 files changed, 9 insertions(+)
diff --git a/configs/ls1021atsn_qspi_defconfig b/configs/ls1021atsn_qspi_defconfig index a62e04e92a..9a659c5512 100644 --- a/configs/ls1021atsn_qspi_defconfig +++ b/configs/ls1021atsn_qspi_defconfig @@ -43,6 +43,7 @@ CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y CONFIG_PHY_FIXED=y CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y CONFIG_PHY_GIGE=y CONFIG_MII=y CONFIG_TSEC_ENET=y diff --git a/configs/ls1021atsn_sdcard_defconfig b/configs/ls1021atsn_sdcard_defconfig index db4f0ab796..235265bd74 100644 --- a/configs/ls1021atsn_sdcard_defconfig +++ b/configs/ls1021atsn_sdcard_defconfig @@ -54,6 +54,7 @@ CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y CONFIG_PHY_FIXED=y CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y CONFIG_PHY_GIGE=y CONFIG_MII=y CONFIG_TSEC_ENET=y diff --git a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig index 0bf4aad102..8946bc1a70 100644 --- a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig @@ -45,6 +45,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_PHY_ATHEROS=y CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y diff --git a/configs/ls1021atwr_nor_defconfig b/configs/ls1021atwr_nor_defconfig index 5507dbe3c1..12b39703d4 100644 --- a/configs/ls1021atwr_nor_defconfig +++ b/configs/ls1021atwr_nor_defconfig @@ -47,6 +47,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_PHY_ATHEROS=y CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y diff --git a/configs/ls1021atwr_nor_lpuart_defconfig b/configs/ls1021atwr_nor_lpuart_defconfig index cdf81957a8..84b724930f 100644 --- a/configs/ls1021atwr_nor_lpuart_defconfig +++ b/configs/ls1021atwr_nor_lpuart_defconfig @@ -49,6 +49,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_PHY_ATHEROS=y CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y diff --git a/configs/ls1021atwr_qspi_defconfig b/configs/ls1021atwr_qspi_defconfig index 4c82d66899..52a4c5106b 100644 --- a/configs/ls1021atwr_qspi_defconfig +++ b/configs/ls1021atwr_qspi_defconfig @@ -50,6 +50,7 @@ CONFIG_SPI_FLASH_ATMEL=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHY_ATHEROS=y CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y diff --git a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig index 9039ccc8f2..f6db8850c4 100644 --- a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig @@ -60,6 +60,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_PHY_ATHEROS=y CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y diff --git a/configs/ls1021atwr_sdcard_ifc_defconfig b/configs/ls1021atwr_sdcard_ifc_defconfig index 478d3df1b8..f011b9ef50 100644 --- a/configs/ls1021atwr_sdcard_ifc_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_defconfig @@ -62,6 +62,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_PHY_ATHEROS=y CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y diff --git a/configs/ls1021atwr_sdcard_qspi_defconfig b/configs/ls1021atwr_sdcard_qspi_defconfig index de783a8d3d..524ea054aa 100644 --- a/configs/ls1021atwr_sdcard_qspi_defconfig +++ b/configs/ls1021atwr_sdcard_qspi_defconfig @@ -61,6 +61,7 @@ CONFIG_SPI_FLASH_ATMEL=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHY_ATHEROS=y CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y
The series doesn't build at this patch for ls1021a family, and is broken until 05/18 "net: tsec: convert to use DM_MDIO when DM_ETH enabled". The reason is that fsl_pq_mdio_init is defined in drivers/net/fsl_mdio.c only when CONFIG_DM_MDIO=n.
arm-none-linux-gnueabihf-ld.bfd: drivers/net/built-in.o: in function `tsec_probe': drivers/net/tsec.c:870: undefined reference to `fsl_pq_mdio_init' make: *** [Makefile:1762: u-boot] Error 1
The build is finally fixed in 05/18 when you delete fsl_pq_mdio_init() from tsec.c which is not really needed.
I don't think it's a good idea to break the build in between patches, it destroys bisectability. I think you would need to add one more patch, right before this one, that adds a dummy definition for this function. You can then remove it in the "net: tsec: convert to use DM_MDIO when DM_ETH enabled".
Like this:
diff --git a/drivers/net/fsl_mdio.c b/drivers/net/fsl_mdio.c index 43040d4c3f89..4128b30f7412 100644 --- a/drivers/net/fsl_mdio.c +++ b/drivers/net/fsl_mdio.c @@ -149,6 +149,12 @@ int fsl_pq_mdio_init(bd_t *bis, struct fsl_pq_mdio_info *info) return mdio_register(bus); } #else /* CONFIG_DM_MDIO */ + +int fsl_pq_mdio_init(bd_t *bis, struct fsl_pq_mdio_info *info) +{ + return 0; +} + #if defined(CONFIG_PHYLIB) static int tsec_mdio_read(struct udevice *dev, int addr, int devad, int reg) {
This is really fixing an issue of commit 2932c5a802a9 ("net: tsec: fsl_mdio: add DM MDIO support"), maybe you could even add a Fixes: tag for that.
V5:
diff --git a/configs/ls1021atsn_qspi_defconfig b/configs/ls1021atsn_qspi_defconfig index a62e04e92a..9a659c5512 100644 --- a/configs/ls1021atsn_qspi_defconfig +++ b/configs/ls1021atsn_qspi_defconfig @@ -43,6 +43,7 @@ CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y CONFIG_PHY_FIXED=y CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y CONFIG_PHY_GIGE=y CONFIG_MII=y CONFIG_TSEC_ENET=y diff --git a/configs/ls1021atsn_sdcard_defconfig b/configs/ls1021atsn_sdcard_defconfig index db4f0ab796..235265bd74 100644 --- a/configs/ls1021atsn_sdcard_defconfig +++ b/configs/ls1021atsn_sdcard_defconfig @@ -54,6 +54,7 @@ CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y CONFIG_PHY_FIXED=y CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y CONFIG_PHY_GIGE=y CONFIG_MII=y CONFIG_TSEC_ENET=y diff --git a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig index 0bf4aad102..8946bc1a70 100644 --- a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig @@ -45,6 +45,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_PHY_ATHEROS=y CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y diff --git a/configs/ls1021atwr_nor_defconfig b/configs/ls1021atwr_nor_defconfig index 5507dbe3c1..12b39703d4 100644 --- a/configs/ls1021atwr_nor_defconfig +++ b/configs/ls1021atwr_nor_defconfig @@ -47,6 +47,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_PHY_ATHEROS=y CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y diff --git a/configs/ls1021atwr_nor_lpuart_defconfig b/configs/ls1021atwr_nor_lpuart_defconfig index cdf81957a8..84b724930f 100644 --- a/configs/ls1021atwr_nor_lpuart_defconfig +++ b/configs/ls1021atwr_nor_lpuart_defconfig @@ -49,6 +49,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_PHY_ATHEROS=y CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y diff --git a/configs/ls1021atwr_qspi_defconfig b/configs/ls1021atwr_qspi_defconfig index 4c82d66899..52a4c5106b 100644 --- a/configs/ls1021atwr_qspi_defconfig +++ b/configs/ls1021atwr_qspi_defconfig @@ -50,6 +50,7 @@ CONFIG_SPI_FLASH_ATMEL=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHY_ATHEROS=y CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y diff --git a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig index 9039ccc8f2..f6db8850c4 100644 --- a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig @@ -60,6 +60,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_PHY_ATHEROS=y CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y diff --git a/configs/ls1021atwr_sdcard_ifc_defconfig b/configs/ls1021atwr_sdcard_ifc_defconfig index 478d3df1b8..f011b9ef50 100644 --- a/configs/ls1021atwr_sdcard_ifc_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_defconfig @@ -62,6 +62,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_PHY_ATHEROS=y CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y diff --git a/configs/ls1021atwr_sdcard_qspi_defconfig b/configs/ls1021atwr_sdcard_qspi_defconfig index de783a8d3d..524ea054aa 100644 --- a/configs/ls1021atwr_sdcard_qspi_defconfig +++ b/configs/ls1021atwr_sdcard_qspi_defconfig @@ -61,6 +61,7 @@ CONFIG_SPI_FLASH_ATMEL=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHY_ATHEROS=y CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y -- 2.25.1
Thanks! -Vladimir
Hi Vladimir,
Sorry, I missed your email!
-----Original Message----- From: Vladimir Oltean olteanv@gmail.com Sent: 2020年7月16日 23:34 To: Z.q. Hou zhiqiang.hou@nxp.com Cc: u-boot@lists.denx.de; bmeng.cn@gmail.com; Priyanka Jain priyanka.jain@nxp.com; Vladimir Oltean vladimir.oltean@nxp.com Subject: Re: [PATCHv5 02/18] configs: enable DM_MDIO for LS1021A-TWR and LS1021A-TSN
avoid
Like this:
+int fsl_pq_mdio_init(bd_t *bis, struct fsl_pq_mdio_info *info) {
Instead of adding a fix patch, I'd like to move this patch to the tail of this series.
Thanks, Zhiqiang
V5:
- Pick from
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fpatch work.ozlabs.org%2Fproject%2Fuboot%2Fpatch%2F20200503185227.28731- 3-olteanv%40gmail.com%2F&data=02%7C01%7CZhiqiang.Hou%40nxp. com%7Cd458470893954ef37a3308d8299da29b%7C686ea1d3bc2b4c6fa92c d99c5c301635%7C0%7C0%7C637305104294481939&sdata=4zfV%2F% 2FjH%2Bi%2FlyyPpCI9164ntFzYVIqOchTufKwtZe0g%3D&reserved=0.
Thanks! -Vladimir
Use virtual address to access the MII block registers instead of physical address.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com Reviewed-by: Vladimir Oltean vladimir.oltean@nxp.com --- V5: - No change.
drivers/net/fsl_mdio.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/fsl_mdio.c b/drivers/net/fsl_mdio.c index 43040d4c3f..e52daa214d 100644 --- a/drivers/net/fsl_mdio.c +++ b/drivers/net/fsl_mdio.c @@ -213,7 +213,7 @@ static int tsec_mdio_probe(struct udevice *dev) printf("dev_get_priv(dev %p) = NULL\n", dev); return -1; } - priv->regs = (void *)(uintptr_t)dev_read_addr(dev); + priv->regs = dev_remap_addr(dev); debug("%s priv %p @ regs %p, pdata %p\n", __func__, priv, priv->regs, pdata);
The MII management register block offset is different between gianfar and etsec2 compatible devices, this patch is to fix this issue by adding driver data for different compatible string.
Fixes: 2932c5a802a9 ("net: tsec: fsl_mdio: add DM MDIO support") Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com Reviewed-by: Vladimir Oltean vladimir.oltean@nxp.com --- V5: - No change.
drivers/net/fsl_mdio.c | 28 ++++++++++++++++++++++------ include/fsl_mdio.h | 4 ++++ 2 files changed, 26 insertions(+), 6 deletions(-)
diff --git a/drivers/net/fsl_mdio.c b/drivers/net/fsl_mdio.c index e52daa214d..5b615d50f6 100644 --- a/drivers/net/fsl_mdio.c +++ b/drivers/net/fsl_mdio.c @@ -11,6 +11,7 @@ #include <fsl_mdio.h> #include <asm/io.h> #include <linux/errno.h> +#include <tsec.h>
#ifdef CONFIG_DM_MDIO struct tsec_mdio_priv { @@ -190,17 +191,30 @@ static const struct mdio_ops tsec_mdio_ops = { .reset = tsec_mdio_reset, };
+static struct fsl_pq_mdio_data etsec2_data = { + .mdio_regs_off = TSEC_MDIO_REGS_OFFSET, +}; + +static struct fsl_pq_mdio_data gianfar_data = { + .mdio_regs_off = 0x0, +}; + +static struct fsl_pq_mdio_data fman_data = { + .mdio_regs_off = 0x0, +}; + static const struct udevice_id tsec_mdio_ids[] = { - { .compatible = "fsl,gianfar-tbi" }, - { .compatible = "fsl,gianfar-mdio" }, - { .compatible = "fsl,etsec2-tbi" }, - { .compatible = "fsl,etsec2-mdio" }, - { .compatible = "fsl,fman-mdio" }, + { .compatible = "fsl,gianfar-tbi", .data = (ulong)&gianfar_data }, + { .compatible = "fsl,gianfar-mdio", .data = (ulong)&gianfar_data }, + { .compatible = "fsl,etsec2-tbi", .data = (ulong)&etsec2_data }, + { .compatible = "fsl,etsec2-mdio", .data = (ulong)&etsec2_data }, + { .compatible = "fsl,fman-mdio", .data = (ulong)&fman_data }, {} };
static int tsec_mdio_probe(struct udevice *dev) { + struct fsl_pq_mdio_data *data; struct tsec_mdio_priv *priv = (dev) ? dev_get_priv(dev) : NULL; struct mdio_perdev_priv *pdata = (dev) ? dev_get_uclass_priv(dev) : NULL; @@ -213,7 +227,9 @@ static int tsec_mdio_probe(struct udevice *dev) printf("dev_get_priv(dev %p) = NULL\n", dev); return -1; } - priv->regs = dev_remap_addr(dev); + + data = (struct fsl_pq_mdio_data *)dev_get_driver_data(dev); + priv->regs = dev_remap_addr(dev) + data->mdio_regs_off; debug("%s priv %p @ regs %p, pdata %p\n", __func__, priv, priv->regs, pdata);
diff --git a/include/fsl_mdio.h b/include/fsl_mdio.h index 8857d50910..cd612c0954 100644 --- a/include/fsl_mdio.h +++ b/include/fsl_mdio.h @@ -55,6 +55,10 @@ int memac_mdio_read(struct mii_dev *bus, int port_addr, int dev_addr, int regnum); int memac_mdio_reset(struct mii_dev *bus);
+struct fsl_pq_mdio_data { + u32 mdio_regs_off; +}; + struct fsl_pq_mdio_info { struct tsec_mii_mng __iomem *regs; char *name;
For the platforms on which the eTSEC driver uses DM_ETH, convert its MDIO controller code to also use DM_MDIO.
Note that for handling the TBI PHY (the MAC PCS for SGMII), we still don't register a udevice for it, since we can drive it locally and there is no point in doing otherwise.
Signed-off-by: Vladimir Oltean vladimir.oltean@nxp.com Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- V5: - No change.
drivers/net/tsec.c | 43 ++++++++++--------------------------------- 1 file changed, 10 insertions(+), 33 deletions(-)
diff --git a/drivers/net/tsec.c b/drivers/net/tsec.c index 3d75acb6b4..babe44691e 100644 --- a/drivers/net/tsec.c +++ b/drivers/net/tsec.c @@ -18,6 +18,7 @@ #include <linux/bitops.h> #include <linux/delay.h> #include <linux/errno.h> +#include <miiphy.h> #include <asm/processor.h> #include <asm/io.h>
@@ -681,8 +682,12 @@ static int init_phy(struct tsec_private *priv) if (priv->interface == PHY_INTERFACE_MODE_SGMII) tsec_configure_serdes(priv);
+#ifdef CONFIG_DM_ETH + phydev = dm_eth_phy_connect(priv->dev); +#else phydev = phy_connect(priv->bus, priv->phyaddr, priv->dev, priv->interface); +#endif if (!phydev) return 0;
@@ -787,14 +792,17 @@ int tsec_standard_init(bd_t *bis) return tsec_eth_init(bis, tsec_info, ARRAY_SIZE(tsec_info)); } #else /* CONFIG_DM_ETH */ + +#ifndef CONFIG_DM_MDIO +#error "TSEC with DM_ETH also requires DM_MDIO" +#endif + int tsec_probe(struct udevice *dev) { struct eth_pdata *pdata = dev_get_platdata(dev); struct tsec_private *priv = dev_get_priv(dev); - struct tsec_mii_mng __iomem *ext_phyregs_mii; struct ofnode_phandle_args phandle_args; u32 tbiaddr = CONFIG_SYS_TBIPA_VALUE; - struct fsl_pq_mdio_info mdio_info; const char *phy_mode; fdt_addr_t reg; ofnode parent; @@ -803,31 +811,6 @@ int tsec_probe(struct udevice *dev) pdata->iobase = (phys_addr_t)dev_read_addr(dev); priv->regs = dev_remap_addr(dev);
- if (dev_read_phandle_with_args(dev, "phy-handle", NULL, 0, 0, - &phandle_args)) { - printf("phy-handle does not exist under tsec %s\n", dev->name); - return -ENOENT; - } else { - int reg = ofnode_read_u32_default(phandle_args.node, "reg", 0); - - priv->phyaddr = reg; - } - - parent = ofnode_get_parent(phandle_args.node); - if (!ofnode_valid(parent)) { - printf("No parent node for PHY?\n"); - return -ENOENT; - } - - reg = ofnode_get_addr_index(parent, 0); - if (reg == FDT_ADDR_T_NONE) { - printf("No 'reg' property of MII for external PHY\n"); - return -ENOENT; - } - - ext_phyregs_mii = map_physmem(reg + TSEC_MDIO_REGS_OFFSET, 0, - MAP_NOCACHE); - ret = dev_read_phandle_with_args(dev, "tbi-handle", NULL, 0, 0, &phandle_args); if (ret == 0) { @@ -865,12 +848,6 @@ int tsec_probe(struct udevice *dev) if (priv->interface == PHY_INTERFACE_MODE_SGMII) priv->flags |= TSEC_SGMII;
- mdio_info.regs = ext_phyregs_mii; - mdio_info.name = (char *)dev->name; - ret = fsl_pq_mdio_init(NULL, &mdio_info); - if (ret) - return ret; - /* Reset the MAC */ setbits_be32(&priv->regs->maccfg1, MACCFG1_SOFT_RESET); udelay(2); /* Soft Reset must be asserted for 3 TX clocks */
The info of fixed-link PHY is described in DT node instead of getting from MII, so detect the fixed-link PHY DT node first, if it doesn't exist then probe the MII.
drivers/net/tsec.c | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/drivers/net/tsec.c b/drivers/net/tsec.c index babe44691e..cb3e56d439 100644 --- a/drivers/net/tsec.c +++ b/drivers/net/tsec.c @@ -683,7 +683,10 @@ static int init_phy(struct tsec_private *priv) tsec_configure_serdes(priv);
#ifdef CONFIG_DM_ETH - phydev = dm_eth_phy_connect(priv->dev); + if (ofnode_valid(ofnode_find_subnode(priv->dev->node, "fixed-link"))) + phydev = phy_connect(NULL, 0, priv->dev, priv->interface); + else + phydev = dm_eth_phy_connect(priv->dev); #else phydev = phy_connect(priv->bus, priv->phyaddr, priv->dev, priv->interface);
Add compatible string "gianfar" support and update the device-tree-bindings doc.
doc/device-tree-bindings/net/fsl-tsec-phy.txt | 2 +- drivers/net/tsec.c | 16 ++++++++++++++-- include/tsec.h | 4 ++++ 3 files changed, 19 insertions(+), 3 deletions(-)
diff --git a/doc/device-tree-bindings/net/fsl-tsec-phy.txt b/doc/device-tree-bindings/net/fsl-tsec-phy.txt index 8e8574bc97..a44c5fd9d9 100644 --- a/doc/device-tree-bindings/net/fsl-tsec-phy.txt +++ b/doc/device-tree-bindings/net/fsl-tsec-phy.txt @@ -2,7 +2,7 @@
Properties:
- - compatible : Should be "fsl,etsec2" + - compatible : Should be "fsl,etsec2" or "gianfar" - reg : Offset and length of the register set for the device - phy-handle : See ethernet.txt file in the same directory. - phy-connection-type : See ethernet.txt file in the same directory. This diff --git a/drivers/net/tsec.c b/drivers/net/tsec.c index cb3e56d439..22658506b2 100644 --- a/drivers/net/tsec.c +++ b/drivers/net/tsec.c @@ -806,11 +806,14 @@ int tsec_probe(struct udevice *dev) struct tsec_private *priv = dev_get_priv(dev); struct ofnode_phandle_args phandle_args; u32 tbiaddr = CONFIG_SYS_TBIPA_VALUE; + struct tsec_data *data; const char *phy_mode; fdt_addr_t reg; ofnode parent; int ret;
+ data = (struct tsec_data *)dev_get_driver_data(dev); + pdata->iobase = (phys_addr_t)dev_read_addr(dev); priv->regs = dev_remap_addr(dev);
@@ -831,7 +834,7 @@ int tsec_probe(struct udevice *dev) return -ENOENT; }
- priv->phyregs_sgmii = map_physmem(reg + TSEC_MDIO_REGS_OFFSET, + priv->phyregs_sgmii = map_physmem(reg + data->mdio_regs_off, 0, MAP_NOCACHE); }
@@ -883,8 +886,17 @@ static const struct eth_ops tsec_ops = { .mcast = tsec_mcast_addr, };
+static struct tsec_data etsec2_data = { + .mdio_regs_off = TSEC_MDIO_REGS_OFFSET, +}; + +static struct tsec_data gianfar_data = { + .mdio_regs_off = 0x0, +}; + static const struct udevice_id tsec_ids[] = { - { .compatible = "fsl,etsec2" }, + { .compatible = "fsl,etsec2", .data = (ulong)&etsec2_data }, + { .compatible = "gianfar", .data = (ulong)&gianfar_data }, { } };
diff --git a/include/tsec.h b/include/tsec.h index b17fa957df..047dd3c373 100644 --- a/include/tsec.h +++ b/include/tsec.h @@ -394,6 +394,10 @@ struct tsec {
#define TX_BUF_CNT 2
+struct tsec_data { + u32 mdio_regs_off; +}; + struct tsec_private { struct txbd8 __iomem txbd[TX_BUF_CNT]; struct rxbd8 __iomem rxbd[PKTBUFSRX];
The cpu_eth_init() is only used by the legacy ethernet driver framework.
arch/powerpc/cpu/mpc8xxx/cpu.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/powerpc/cpu/mpc8xxx/cpu.c b/arch/powerpc/cpu/mpc8xxx/cpu.c index da0a80e6fc..b904943b0e 100644 --- a/arch/powerpc/cpu/mpc8xxx/cpu.c +++ b/arch/powerpc/cpu/mpc8xxx/cpu.c @@ -347,6 +347,7 @@ int fixup_cpu(void) * Initializes on-chip ethernet controllers. * to override, implement board_eth_init() */ +#ifndef CONFIG_DM_ETH int cpu_eth_init(bd_t *bis) { #if defined(CONFIG_ETHER_ON_FCC) @@ -370,3 +371,4 @@ int cpu_eth_init(bd_t *bis) #endif return 0; } +#endif
Move vsc7835 firmware uploading to board_early_init_r(), so that the switch also can work in DM eTSEC driver.
board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c | 35 +++++++++++---------- 1 file changed, 18 insertions(+), 17 deletions(-)
diff --git a/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c b/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c index 1353debc0e..3dd6178708 100644 --- a/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c +++ b/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c @@ -316,6 +316,10 @@ int board_early_init_r(void) { const unsigned int flashbase = CONFIG_SYS_FLASH_BASE; int flash_esel = find_tlb_idx((void *)flashbase, 1); +#ifdef CONFIG_VSC7385_ENET + unsigned int vscfw_addr; + char *tmp; +#endif
/* * Remap Boot flash region to caching-inhibited @@ -338,6 +342,20 @@ int board_early_init_r(void) set_tlb(1, flashbase, CONFIG_SYS_FLASH_BASE_PHYS, /* tlb, epn, rpn */ MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G,/* perms, wimge */ 0, flash_esel, BOOKE_PAGESZ_64M, 1);/* ts, esel, tsize, iprot */ + +#ifdef CONFIG_VSC7385_ENET + /* If a VSC7385 microcode image is present, then upload it. */ + tmp = env_get("vscfw_addr"); + if (tmp) { + vscfw_addr = simple_strtoul(tmp, NULL, 16); + printf("uploading VSC7385 microcode from %x\n", vscfw_addr); + if (vsc7385_upload_firmware((void *)vscfw_addr, + CONFIG_VSC7385_IMAGE_SIZE)) + puts("Failure uploading VSC7385 microcode.\n"); + } else { + puts("No address specified for VSC7385 microcode.\n"); + } +#endif return 0; }
@@ -348,10 +366,6 @@ int board_eth_init(bd_t *bis) ccsr_gur_t *gur __attribute__((unused)) = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); int num = 0; -#ifdef CONFIG_VSC7385_ENET - char *tmp; - unsigned int vscfw_addr; -#endif
#ifdef CONFIG_TSEC1 SET_STD_TSEC_INFO(tsec_info[num], 1); @@ -375,19 +389,6 @@ int board_eth_init(bd_t *bis) return 0; }
-#ifdef CONFIG_VSC7385_ENET - /* If a VSC7385 microcode image is present, then upload it. */ - tmp = env_get("vscfw_addr"); - if (tmp) { - vscfw_addr = simple_strtoul(tmp, NULL, 16); - printf("uploading VSC7385 microcode from %x\n", vscfw_addr); - if (vsc7385_upload_firmware((void *) vscfw_addr, - CONFIG_VSC7385_IMAGE_SIZE)) - puts("Failure uploading VSC7385 microcode.\n"); - } else - puts("No address specified for VSC7385 microcode.\n"); -#endif - mdio_info.regs = TSEC_GET_MDIO_REGS_BASE(1); mdio_info.name = DEFAULT_MII_NAME;
Add the environment 'vscfw_addr' to assign a default address for vsc7385 firmware uploading.
include/configs/p1_p2_rdb_pc.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index 219e5d216b..6e00491cd8 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -460,6 +460,7 @@
/* Vsc7385 switch */ #ifdef CONFIG_VSC7385_ENET +#define __VSCFW_ADDR "vscfw_addr=ef000000" #define CONFIG_SYS_VSC7385_BASE 0xffb00000
#ifdef CONFIG_PHYS_64BIT @@ -819,6 +820,7 @@ i2c mw 18 3 __SW_BOOT_MASK 1; reset "ramdisk_size=120000\0" \ "map_lowernorbank=i2c dev 1; i2c mw 18 1 02 1; i2c mw 18 3 fd 1\0" \ "map_uppernorbank=i2c dev 1; i2c mw 18 1 00 1; i2c mw 18 3 fd 1\0" \ +__stringify(__VSCFW_ADDR)"\0" \ __stringify(__NOR_RST_CMD)"\0" \ __stringify(__SPI_RST_CMD)"\0" \ __stringify(__SD_RST_CMD)"\0" \
P1020RDB implements 3 enhanced three-speed Ethernet controllers, and the connection is shown below: eTSEC1: Connected to RGMII switch VSC7385 eTSEC2: Connected to SGMII PHY VSC8221 eTSEC3: Connected to SGMII PHY AR8021
arch/powerpc/dts/p1020-post.dtsi | 20 ++++++++- arch/powerpc/dts/p1020rdb-pc.dts | 1 + arch/powerpc/dts/p1020rdb-pc.dtsi | 55 +++++++++++++++++++++++++ arch/powerpc/dts/p1020rdb-pc_36b.dts | 1 + arch/powerpc/dts/p1020rdb-pd.dts | 45 ++++++++++++++++++++ arch/powerpc/dts/pq3-etsec2-0.dtsi | 35 ++++++++++++++++ arch/powerpc/dts/pq3-etsec2-1.dtsi | 35 ++++++++++++++++ arch/powerpc/dts/pq3-etsec2-2.dtsi | 35 ++++++++++++++++ arch/powerpc/dts/pq3-etsec2-grp2-0.dtsi | 16 +++++++ arch/powerpc/dts/pq3-etsec2-grp2-1.dtsi | 16 +++++++ arch/powerpc/dts/pq3-etsec2-grp2-2.dtsi | 16 +++++++ 11 files changed, 273 insertions(+), 2 deletions(-) create mode 100644 arch/powerpc/dts/p1020rdb-pc.dtsi create mode 100644 arch/powerpc/dts/pq3-etsec2-0.dtsi create mode 100644 arch/powerpc/dts/pq3-etsec2-1.dtsi create mode 100644 arch/powerpc/dts/pq3-etsec2-2.dtsi create mode 100644 arch/powerpc/dts/pq3-etsec2-grp2-0.dtsi create mode 100644 arch/powerpc/dts/pq3-etsec2-grp2-1.dtsi create mode 100644 arch/powerpc/dts/pq3-etsec2-grp2-2.dtsi
diff --git a/arch/powerpc/dts/p1020-post.dtsi b/arch/powerpc/dts/p1020-post.dtsi index 1dce8e86e9..c73539ad5c 100644 --- a/arch/powerpc/dts/p1020-post.dtsi +++ b/arch/powerpc/dts/p1020-post.dtsi @@ -44,10 +44,26 @@ clock-frequency = <0>; };
- /include/ "pq3-i2c-0.dtsi" - /include/ "pq3-i2c-1.dtsi" +/include/ "pq3-i2c-0.dtsi" +/include/ "pq3-i2c-1.dtsi" + +/include/ "pq3-etsec2-0.dtsi" + enet0: enet0_grp2: ethernet@b0000 { + }; + +/include/ "pq3-etsec2-1.dtsi" + enet1: enet1_grp2: ethernet@b1000 { + }; + +/include/ "pq3-etsec2-2.dtsi" + enet2: enet2_grp2: ethernet@b2000 { + }; };
+/include/ "pq3-etsec2-grp2-0.dtsi" +/include/ "pq3-etsec2-grp2-1.dtsi" +/include/ "pq3-etsec2-grp2-2.dtsi" + /* PCIe controller base address 0x9000 */ &pci1 { compatible = "fsl,pcie-p1_p2", "fsl,pcie-fsl-qoriq"; diff --git a/arch/powerpc/dts/p1020rdb-pc.dts b/arch/powerpc/dts/p1020rdb-pc.dts index 7ebaa619df..715330dc50 100644 --- a/arch/powerpc/dts/p1020rdb-pc.dts +++ b/arch/powerpc/dts/p1020rdb-pc.dts @@ -32,4 +32,5 @@ }; };
+/include/ "p1020rdb-pc.dtsi" /include/ "p1020-post.dtsi" diff --git a/arch/powerpc/dts/p1020rdb-pc.dtsi b/arch/powerpc/dts/p1020rdb-pc.dtsi new file mode 100644 index 0000000000..6bf424fd3f --- /dev/null +++ b/arch/powerpc/dts/p1020rdb-pc.dtsi @@ -0,0 +1,55 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * P1020 RDB-PC Device Tree Source stub (no addresses or top-level ranges) + * + * Copyright 2012 Freescale Semiconductor Inc. + * Copyright 2020 NXP + */ + +&soc { + mdio@24000 { + phy0: ethernet-phy@0 { + interrupt-parent = <&mpic>; + interrupts = <3 1 0 0>; + reg = <0x0>; + }; + + phy1: ethernet-phy@1 { + interrupt-parent = <&mpic>; + interrupts = <2 1 0 0>; + reg = <0x1>; + }; + + tbi0: tbi-phy@11 { + device_type = "tbi-phy"; + reg = <0x11>; + }; + }; + + mdio@25000 { + tbi1: tbi-phy@11 { + reg = <0x11>; + device_type = "tbi-phy"; + }; + }; + + enet0: ethernet@b0000 { + phy-connection-type = "rgmii-id"; + fixed-link { + speed = <1000>; + full-duplex; + }; + + }; + + enet1: ethernet@b1000 { + phy-handle = <&phy0>; + tbi-handle = <&tbi1>; + phy-connection-type = "sgmii"; + }; + + enet2: ethernet@b2000 { + phy-handle = <&phy1>; + phy-connection-type = "rgmii-id"; + }; +}; diff --git a/arch/powerpc/dts/p1020rdb-pc_36b.dts b/arch/powerpc/dts/p1020rdb-pc_36b.dts index c0e5ef4cf4..7680b7c7e1 100644 --- a/arch/powerpc/dts/p1020rdb-pc_36b.dts +++ b/arch/powerpc/dts/p1020rdb-pc_36b.dts @@ -32,4 +32,5 @@ }; };
+/include/ "p1020rdb-pc.dtsi" /include/ "p1020-post.dtsi" diff --git a/arch/powerpc/dts/p1020rdb-pd.dts b/arch/powerpc/dts/p1020rdb-pd.dts index 21174a09be..e0e8993dab 100644 --- a/arch/powerpc/dts/p1020rdb-pd.dts +++ b/arch/powerpc/dts/p1020rdb-pd.dts @@ -17,6 +17,51 @@
soc: soc@ffe00000 { ranges = <0x0 0x0 0xffe00000 0x100000>; + + mdio@24000 { + phy0: ethernet-phy@0 { + interrupts = <3 1 0 0>; + reg = <0x0>; + }; + + phy1: ethernet-phy@1 { + interrupts = <2 1 0 0>; + reg = <0x1>; + }; + }; + + mdio@25000 { + tbi1: tbi-phy@11 { + reg = <0x11>; + device_type = "tbi-phy"; + }; + }; + + mdio@26000 { + tbi2: tbi-phy@11 { + reg = <0x11>; + device_type = "tbi-phy"; + }; + }; + + enet0: ethernet@b0000 { + phy-connection-type = "rgmii-id"; + fixed-link { + speed = <1000>; + full-duplex; + }; + }; + + enet1: ethernet@b1000 { + phy-handle = <&phy0>; + tbi-handle = <&tbi1>; + phy-connection-type = "sgmii"; + }; + + enet2: ethernet@b2000 { + phy-handle = <&phy1>; + phy-connection-type = "rgmii-id"; + }; };
pci1: pcie@ffe09000 { diff --git a/arch/powerpc/dts/pq3-etsec2-0.dtsi b/arch/powerpc/dts/pq3-etsec2-0.dtsi new file mode 100644 index 0000000000..f9d3d04650 --- /dev/null +++ b/arch/powerpc/dts/pq3-etsec2-0.dtsi @@ -0,0 +1,35 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * PQ3 eTSEC2 device tree stub [ @ offsets 0x24000/0xb0000 ] + * + * Copyright 2011 Freescale Semiconductor Inc. + * Copyright 2020 NXP + */ + +mdio@24000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,etsec2-mdio"; + reg = <0x24000 0x1000 0xb0030 0x4>; +}; + +ethernet@b0000 { + #address-cells = <1>; + #size-cells = <1>; + device_type = "network"; + model = "eTSEC"; + compatible = "fsl,etsec2"; + reg = <0xb0000 0x1000>; + fsl,num_rx_queues = <0x8>; + fsl,num_tx_queues = <0x8>; + fsl,magic-packet; + local-mac-address = [ 00 00 00 00 00 00 ]; + ranges; + + queue-group@b0000 { + #address-cells = <1>; + #size-cells = <1>; + reg = <0xb0000 0x1000>; + interrupts = <29 2 0 0 30 2 0 0 34 2 0 0>; + }; +}; diff --git a/arch/powerpc/dts/pq3-etsec2-1.dtsi b/arch/powerpc/dts/pq3-etsec2-1.dtsi new file mode 100644 index 0000000000..6c01481909 --- /dev/null +++ b/arch/powerpc/dts/pq3-etsec2-1.dtsi @@ -0,0 +1,35 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * PQ3 eTSEC2 device tree stub [ @ offsets 0x25000/0xb1000 ] + * + * Copyright 2011 Freescale Semiconductor Inc. + * Copyright 2020 NXP + */ + +mdio@25000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,etsec2-tbi"; + reg = <0x25000 0x1000 0xb1030 0x4>; +}; + +ethernet@b1000 { + #address-cells = <1>; + #size-cells = <1>; + device_type = "network"; + model = "eTSEC"; + compatible = "fsl,etsec2"; + reg = <0xb1000 0x1000>; + fsl,num_rx_queues = <0x8>; + fsl,num_tx_queues = <0x8>; + fsl,magic-packet; + local-mac-address = [ 00 00 00 00 00 00 ]; + ranges; + + queue-group@b1000 { + #address-cells = <1>; + #size-cells = <1>; + reg = <0xb1000 0x1000>; + interrupts = <35 2 0 0 36 2 0 0 40 2 0 0>; + }; +}; diff --git a/arch/powerpc/dts/pq3-etsec2-2.dtsi b/arch/powerpc/dts/pq3-etsec2-2.dtsi new file mode 100644 index 0000000000..2a597c0db6 --- /dev/null +++ b/arch/powerpc/dts/pq3-etsec2-2.dtsi @@ -0,0 +1,35 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * PQ3 eTSEC2 device tree stub [ @ offsets 0x26000/0xb2000 ] + * + * Copyright 2011 Freescale Semiconductor Inc. + * Copyright 2020 NXP + */ + +mdio@26000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,etsec2-tbi"; + reg = <0x26000 0x1000 0xb1030 0x4>; +}; + +ethernet@b2000 { + #address-cells = <1>; + #size-cells = <1>; + device_type = "network"; + model = "eTSEC"; + compatible = "fsl,etsec2"; + reg = <0xb2000 0x1000>; + fsl,num_rx_queues = <0x8>; + fsl,num_tx_queues = <0x8>; + fsl,magic-packet; + local-mac-address = [ 00 00 00 00 00 00 ]; + ranges; + + queue-group@b2000 { + #address-cells = <1>; + #size-cells = <1>; + reg = <0xb2000 0x1000>; + interrupts = <31 2 0 0 32 2 0 0 33 2 0 0>; + }; +}; diff --git a/arch/powerpc/dts/pq3-etsec2-grp2-0.dtsi b/arch/powerpc/dts/pq3-etsec2-grp2-0.dtsi new file mode 100644 index 0000000000..16752a7c45 --- /dev/null +++ b/arch/powerpc/dts/pq3-etsec2-grp2-0.dtsi @@ -0,0 +1,16 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * PQ3 eTSEC2 Group 2 device tree stub [ @ offsets 0xb4000 ] + * + * Copyright 2011 Freescale Semiconductor Inc. + * Copyright 2020 NXP + */ + +&enet0_grp2 { + queue-group@b4000 { + #address-cells = <1>; + #size-cells = <1>; + reg = <0xb4000 0x1000>; + interrupts = <17 2 0 0 18 2 0 0 24 2 0 0>; + }; +}; diff --git a/arch/powerpc/dts/pq3-etsec2-grp2-1.dtsi b/arch/powerpc/dts/pq3-etsec2-grp2-1.dtsi new file mode 100644 index 0000000000..0464938424 --- /dev/null +++ b/arch/powerpc/dts/pq3-etsec2-grp2-1.dtsi @@ -0,0 +1,16 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * PQ3 eTSEC2 Group 2 device tree stub [ @ offsets 0xb5000 ] + * + * Copyright 2011 Freescale Semiconductor Inc. + * Copyright 2020 NXP + */ + +&enet1_grp2 { + queue-group@b5000 { + #address-cells = <1>; + #size-cells = <1>; + reg = <0xb5000 0x1000>; + interrupts = <51 2 0 0 52 2 0 0 67 2 0 0>; + }; +}; diff --git a/arch/powerpc/dts/pq3-etsec2-grp2-2.dtsi b/arch/powerpc/dts/pq3-etsec2-grp2-2.dtsi new file mode 100644 index 0000000000..fe8003c44a --- /dev/null +++ b/arch/powerpc/dts/pq3-etsec2-grp2-2.dtsi @@ -0,0 +1,16 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * PQ3 eTSEC2 Group 2 device tree stub [ @ offsets 0xb6000 ] + * + * Copyright 2011 Freescale Semiconductor Inc. + * Copyright 2020 NXP + */ + +&enet2_grp2 { + queue-group@b6000 { + #address-cells = <1>; + #size-cells = <1>; + reg = <0xb6000 0x1000>; + interrupts = <25 2 0 0 26 2 0 0 27 2 0 0>; + }; +};
The board_eth_init() is only used by legacy ethernet driver framework, so do not compile it when DM_ETH config has been selected.
board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c b/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c index 3dd6178708..41585cf342 100644 --- a/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c +++ b/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c @@ -359,6 +359,7 @@ int board_early_init_r(void) return 0; }
+#ifndef CONFIG_DM_ETH int board_eth_init(bd_t *bis) { struct fsl_pq_mdio_info mdio_info; @@ -406,6 +407,7 @@ int board_eth_init(bd_t *bis)
return pci_eth_init(bis); } +#endif
#if defined(CONFIG_QE) && \ (defined(CONFIG_TARGET_P1025RDB) || defined(CONFIG_TARGET_P1021RDB))
Enable the DM_ETH and DM_MDIO config.
On P1020RDB, the eTSEC1 is connecting with a switch VSC7385, so also enable the fixed PHY support.
configs/P1020RDB-PC_36BIT_NAND_defconfig | 3 +++ configs/P1020RDB-PC_36BIT_SDCARD_defconfig | 3 +++ configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig | 3 +++ configs/P1020RDB-PC_36BIT_defconfig | 3 +++ configs/P1020RDB-PC_NAND_defconfig | 3 +++ configs/P1020RDB-PC_SDCARD_defconfig | 3 +++ configs/P1020RDB-PC_SPIFLASH_defconfig | 3 +++ configs/P1020RDB-PC_defconfig | 3 +++ configs/P1020RDB-PD_NAND_defconfig | 3 +++ configs/P1020RDB-PD_SDCARD_defconfig | 3 +++ configs/P1020RDB-PD_SPIFLASH_defconfig | 3 +++ configs/P1020RDB-PD_defconfig | 3 +++ 12 files changed, 36 insertions(+)
diff --git a/configs/P1020RDB-PC_36BIT_NAND_defconfig b/configs/P1020RDB-PC_36BIT_NAND_defconfig index 6ee52fe5e7..139a0be37e 100644 --- a/configs/P1020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P1020RDB-PC_36BIT_NAND_defconfig @@ -61,6 +61,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y +CONFIG_PHY_FIXED=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y CONFIG_PHY_DAVICOM=y @@ -72,8 +73,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig index 489b91d8e7..f533225f26 100644 --- a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig @@ -56,6 +56,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y +CONFIG_PHY_FIXED=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y CONFIG_PHY_DAVICOM=y @@ -67,8 +68,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig index 4a8e4e3726..f3e87f0669 100644 --- a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig @@ -58,6 +58,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y +CONFIG_PHY_FIXED=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y CONFIG_PHY_DAVICOM=y @@ -69,8 +70,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P1020RDB-PC_36BIT_defconfig b/configs/P1020RDB-PC_36BIT_defconfig index f9a4b735ca..04c355585d 100644 --- a/configs/P1020RDB-PC_36BIT_defconfig +++ b/configs/P1020RDB-PC_36BIT_defconfig @@ -45,6 +45,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y +CONFIG_PHY_FIXED=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y CONFIG_PHY_DAVICOM=y @@ -56,8 +57,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P1020RDB-PC_NAND_defconfig b/configs/P1020RDB-PC_NAND_defconfig index 5c8231cba2..ee663c5861 100644 --- a/configs/P1020RDB-PC_NAND_defconfig +++ b/configs/P1020RDB-PC_NAND_defconfig @@ -60,6 +60,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y +CONFIG_PHY_FIXED=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y CONFIG_PHY_DAVICOM=y @@ -71,8 +72,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P1020RDB-PC_SDCARD_defconfig b/configs/P1020RDB-PC_SDCARD_defconfig index ad2bb90a49..cabd6c6022 100644 --- a/configs/P1020RDB-PC_SDCARD_defconfig +++ b/configs/P1020RDB-PC_SDCARD_defconfig @@ -55,6 +55,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y +CONFIG_PHY_FIXED=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y CONFIG_PHY_DAVICOM=y @@ -66,8 +67,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P1020RDB-PC_SPIFLASH_defconfig b/configs/P1020RDB-PC_SPIFLASH_defconfig index b8055e49b0..28a097b0ed 100644 --- a/configs/P1020RDB-PC_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_SPIFLASH_defconfig @@ -57,6 +57,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y +CONFIG_PHY_FIXED=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y CONFIG_PHY_DAVICOM=y @@ -68,8 +69,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P1020RDB-PC_defconfig b/configs/P1020RDB-PC_defconfig index a71985374e..580b4ef5c5 100644 --- a/configs/P1020RDB-PC_defconfig +++ b/configs/P1020RDB-PC_defconfig @@ -44,6 +44,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y +CONFIG_PHY_FIXED=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y CONFIG_PHY_DAVICOM=y @@ -55,8 +56,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P1020RDB-PD_NAND_defconfig b/configs/P1020RDB-PD_NAND_defconfig index 0043fd5f66..f1352d53d5 100644 --- a/configs/P1020RDB-PD_NAND_defconfig +++ b/configs/P1020RDB-PD_NAND_defconfig @@ -64,6 +64,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y +CONFIG_PHY_FIXED=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y CONFIG_PHY_DAVICOM=y @@ -75,8 +76,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P1020RDB-PD_SDCARD_defconfig b/configs/P1020RDB-PD_SDCARD_defconfig index cb0a8aec65..bba6a0ce95 100644 --- a/configs/P1020RDB-PD_SDCARD_defconfig +++ b/configs/P1020RDB-PD_SDCARD_defconfig @@ -59,6 +59,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y +CONFIG_PHY_FIXED=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y CONFIG_PHY_DAVICOM=y @@ -70,8 +71,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P1020RDB-PD_SPIFLASH_defconfig b/configs/P1020RDB-PD_SPIFLASH_defconfig index 35e60ca856..3125fa1e9f 100644 --- a/configs/P1020RDB-PD_SPIFLASH_defconfig +++ b/configs/P1020RDB-PD_SPIFLASH_defconfig @@ -61,6 +61,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y +CONFIG_PHY_FIXED=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y CONFIG_PHY_DAVICOM=y @@ -72,8 +73,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P1020RDB-PD_defconfig b/configs/P1020RDB-PD_defconfig index d7f19c3d96..d3a7afb0b4 100644 --- a/configs/P1020RDB-PD_defconfig +++ b/configs/P1020RDB-PD_defconfig @@ -48,6 +48,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y +CONFIG_PHY_FIXED=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y CONFIG_PHY_DAVICOM=y @@ -59,8 +60,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y
P1010RDB implements 3 enhanced three-speed Ethernet controllers, and the connection is shown below: eTSEC1: Connected to RGMII PHY AR8033 eTSEC2: Connected to SGMII PHY AR8033 eTSEC3: Connected to SGMII PHY AR8033
arch/powerpc/dts/p1010rdb-pa.dts | 1 + arch/powerpc/dts/p1010rdb-pa_36b.dts | 1 + arch/powerpc/dts/p1010rdb.dtsi | 50 ++++++++++++++++++++++++++++ arch/powerpc/dts/p1010si-post.dtsi | 25 ++++++++++++++ 4 files changed, 77 insertions(+)
diff --git a/arch/powerpc/dts/p1010rdb-pa.dts b/arch/powerpc/dts/p1010rdb-pa.dts index c66c4923ac..360d254d91 100644 --- a/arch/powerpc/dts/p1010rdb-pa.dts +++ b/arch/powerpc/dts/p1010rdb-pa.dts @@ -15,3 +15,4 @@ };
/include/ "p1010si-post.dtsi" +/include/ "p1010rdb.dtsi" diff --git a/arch/powerpc/dts/p1010rdb-pa_36b.dts b/arch/powerpc/dts/p1010rdb-pa_36b.dts index b943de7cbb..062086a8c0 100644 --- a/arch/powerpc/dts/p1010rdb-pa_36b.dts +++ b/arch/powerpc/dts/p1010rdb-pa_36b.dts @@ -15,3 +15,4 @@ };
/include/ "p1010si-post.dtsi" +/include/ "p1010rdb.dtsi" diff --git a/arch/powerpc/dts/p1010rdb.dtsi b/arch/powerpc/dts/p1010rdb.dtsi index 4f58ee2446..5964270878 100644 --- a/arch/powerpc/dts/p1010rdb.dtsi +++ b/arch/powerpc/dts/p1010rdb.dtsi @@ -5,6 +5,56 @@ * Copyright 2020 NXP */ &soc { + mdio@24000 { + phy0: ethernet-phy@0 { + reg = <0x1>; + }; + + phy1: ethernet-phy@1 { + reg = <0x0>; + }; + + phy2: ethernet-phy@2 { + reg = <0x2>; + }; + + tbi-phy@3 { + device_type = "tbi-phy"; + reg = <0x3>; + }; + }; + + mdio@25000 { + tbi0: tbi-phy@11 { + reg = <0x11>; + device_type = "tbi-phy"; + }; + }; + + mdio@26000 { + tbi1: tbi-phy@11 { + reg = <0x11>; + device_type = "tbi-phy"; + }; + }; + + enet0: ethernet@b0000 { + phy-handle = <&phy0>; + phy-connection-type = "rgmii-id"; + }; + + enet1: ethernet@b1000 { + phy-handle = <&phy1>; + tbi-handle = <&tbi0>; + phy-connection-type = "sgmii"; + }; + + enet2: ethernet@b2000 { + phy-handle = <&phy2>; + tbi-handle = <&tbi1>; + phy-connection-type = "sgmii"; + }; + i2c@3000 { rtc@68 { compatible = "pericom,pt7c4338"; diff --git a/arch/powerpc/dts/p1010si-post.dtsi b/arch/powerpc/dts/p1010si-post.dtsi index 0289441381..f825208056 100644 --- a/arch/powerpc/dts/p1010si-post.dtsi +++ b/arch/powerpc/dts/p1010si-post.dtsi @@ -25,6 +25,31 @@ }; /include/ "pq3-i2c-0.dtsi" /include/ "pq3-i2c-1.dtsi" + +/include/ "pq3-etsec2-0.dtsi" + enet0: ethernet@b0000 { + queue-group@b0000 { + fsl,rx-bit-map = <0xff>; + fsl,tx-bit-map = <0xff>; + }; + }; + +/include/ "pq3-etsec2-1.dtsi" + enet1: ethernet@b1000 { + queue-group@b1000 { + fsl,rx-bit-map = <0xff>; + fsl,tx-bit-map = <0xff>; + }; + }; + +/include/ "pq3-etsec2-2.dtsi" + enet2: ethernet@b2000 { + queue-group@b2000 { + fsl,rx-bit-map = <0xff>; + fsl,tx-bit-map = <0xff>; + }; + + }; };
/* controller at 0x9000 */
board/freescale/p1010rdb/p1010rdb.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/board/freescale/p1010rdb/p1010rdb.c b/board/freescale/p1010rdb/p1010rdb.c index 66ccc0bd1e..309f4daa88 100644 --- a/board/freescale/p1010rdb/p1010rdb.c +++ b/board/freescale/p1010rdb/p1010rdb.c @@ -484,6 +484,7 @@ int checkboard(void) return 0; }
+#ifndef CONFIG_DM_ETH int board_eth_init(bd_t *bis) { #ifdef CONFIG_TSEC_ENET @@ -524,6 +525,7 @@ int board_eth_init(bd_t *bis)
#if defined(CONFIG_OF_BOARD_SETUP) void fdt_del_flexcan(void *blob)
configs/P1010RDB-PA_36BIT_NAND_defconfig | 2 ++ configs/P1010RDB-PA_36BIT_NOR_defconfig | 2 ++ configs/P1010RDB-PA_36BIT_SDCARD_defconfig | 2 ++ configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig | 2 ++ configs/P1010RDB-PA_NAND_defconfig | 2 ++ configs/P1010RDB-PA_NOR_defconfig | 2 ++ configs/P1010RDB-PA_SDCARD_defconfig | 2 ++ configs/P1010RDB-PA_SPIFLASH_defconfig | 2 ++ configs/P1010RDB-PB_36BIT_NAND_defconfig | 2 ++ configs/P1010RDB-PB_36BIT_NOR_defconfig | 2 ++ configs/P1010RDB-PB_36BIT_SDCARD_defconfig | 2 ++ configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig | 2 ++ configs/P1010RDB-PB_NAND_defconfig | 2 ++ configs/P1010RDB-PB_NOR_defconfig | 2 ++ configs/P1010RDB-PB_SDCARD_defconfig | 2 ++ configs/P1010RDB-PB_SPIFLASH_defconfig | 2 ++ 16 files changed, 32 insertions(+)
diff --git a/configs/P1010RDB-PA_36BIT_NAND_defconfig b/configs/P1010RDB-PA_36BIT_NAND_defconfig index da04cab014..bd31e7c8fa 100644 --- a/configs/P1010RDB-PA_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PA_36BIT_NAND_defconfig @@ -72,8 +72,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P1010RDB-PA_36BIT_NOR_defconfig b/configs/P1010RDB-PA_36BIT_NOR_defconfig index e6edd395e7..f5c5f0ead5 100644 --- a/configs/P1010RDB-PA_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PA_36BIT_NOR_defconfig @@ -54,8 +54,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig index dcd606b0c2..229365a1eb 100644 --- a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig @@ -66,8 +66,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig index c0800c8d7d..147198fb88 100644 --- a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig @@ -68,8 +68,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P1010RDB-PA_NAND_defconfig b/configs/P1010RDB-PA_NAND_defconfig index 29ba692ca1..1f2472a338 100644 --- a/configs/P1010RDB-PA_NAND_defconfig +++ b/configs/P1010RDB-PA_NAND_defconfig @@ -71,8 +71,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P1010RDB-PA_NOR_defconfig b/configs/P1010RDB-PA_NOR_defconfig index d8f87b5dac..35232a87fc 100644 --- a/configs/P1010RDB-PA_NOR_defconfig +++ b/configs/P1010RDB-PA_NOR_defconfig @@ -53,8 +53,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P1010RDB-PA_SDCARD_defconfig b/configs/P1010RDB-PA_SDCARD_defconfig index 9711082529..6a46e3a253 100644 --- a/configs/P1010RDB-PA_SDCARD_defconfig +++ b/configs/P1010RDB-PA_SDCARD_defconfig @@ -65,8 +65,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P1010RDB-PA_SPIFLASH_defconfig b/configs/P1010RDB-PA_SPIFLASH_defconfig index de2ac2235f..6c7c12efc1 100644 --- a/configs/P1010RDB-PA_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_SPIFLASH_defconfig @@ -67,8 +67,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P1010RDB-PB_36BIT_NAND_defconfig b/configs/P1010RDB-PB_36BIT_NAND_defconfig index 9f4876dd13..832f7ce431 100644 --- a/configs/P1010RDB-PB_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PB_36BIT_NAND_defconfig @@ -72,8 +72,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P1010RDB-PB_36BIT_NOR_defconfig b/configs/P1010RDB-PB_36BIT_NOR_defconfig index e85af32e2c..61afaf67ac 100644 --- a/configs/P1010RDB-PB_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PB_36BIT_NOR_defconfig @@ -54,8 +54,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig index 45feab4ee4..8f483b4398 100644 --- a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig @@ -66,8 +66,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig index 3cd94f84ea..447ef19530 100644 --- a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig @@ -68,8 +68,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P1010RDB-PB_NAND_defconfig b/configs/P1010RDB-PB_NAND_defconfig index ddfe7b43a1..d8aae17e84 100644 --- a/configs/P1010RDB-PB_NAND_defconfig +++ b/configs/P1010RDB-PB_NAND_defconfig @@ -71,8 +71,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P1010RDB-PB_NOR_defconfig b/configs/P1010RDB-PB_NOR_defconfig index 6011f8a9d8..632afeaa89 100644 --- a/configs/P1010RDB-PB_NOR_defconfig +++ b/configs/P1010RDB-PB_NOR_defconfig @@ -53,8 +53,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P1010RDB-PB_SDCARD_defconfig b/configs/P1010RDB-PB_SDCARD_defconfig index 65f86fff60..4ba919b206 100644 --- a/configs/P1010RDB-PB_SDCARD_defconfig +++ b/configs/P1010RDB-PB_SDCARD_defconfig @@ -65,8 +65,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P1010RDB-PB_SPIFLASH_defconfig b/configs/P1010RDB-PB_SPIFLASH_defconfig index f71ee19ba6..d5b9aca56d 100644 --- a/configs/P1010RDB-PB_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_SPIFLASH_defconfig @@ -67,8 +67,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y
P2020RDB implements 3 enhanced three-speed Ethernet controllers, and the connection is shown below: eTSEC1: Connected to RGMII switch VSC7385 eTSEC2: Connected to SGMII PHY VSC8221 eTSEC3: Connected to SGMII PHY AR8021
arch/powerpc/dts/p2020-post.dtsi | 8 +++-- arch/powerpc/dts/p2020rdb-pc.dts | 1 + arch/powerpc/dts/p2020rdb-pc.dtsi | 50 ++++++++++++++++++++++++++++ arch/powerpc/dts/p2020rdb-pc_36b.dts | 1 + arch/powerpc/dts/pq3-etsec1-0.dtsi | 28 ++++++++++++++++ arch/powerpc/dts/pq3-etsec1-1.dtsi | 28 ++++++++++++++++ arch/powerpc/dts/pq3-etsec1-2.dtsi | 28 ++++++++++++++++ arch/powerpc/dts/pq3-etsec1-3.dtsi | 28 ++++++++++++++++ 8 files changed, 170 insertions(+), 2 deletions(-) create mode 100644 arch/powerpc/dts/p2020rdb-pc.dtsi create mode 100644 arch/powerpc/dts/pq3-etsec1-0.dtsi create mode 100644 arch/powerpc/dts/pq3-etsec1-1.dtsi create mode 100644 arch/powerpc/dts/pq3-etsec1-2.dtsi create mode 100644 arch/powerpc/dts/pq3-etsec1-3.dtsi
diff --git a/arch/powerpc/dts/p2020-post.dtsi b/arch/powerpc/dts/p2020-post.dtsi index 4ed093dad4..11945295d1 100644 --- a/arch/powerpc/dts/p2020-post.dtsi +++ b/arch/powerpc/dts/p2020-post.dtsi @@ -38,8 +38,12 @@ clock-frequency = <0>; };
- /include/ "pq3-i2c-0.dtsi" - /include/ "pq3-i2c-1.dtsi" +/include/ "pq3-i2c-0.dtsi" +/include/ "pq3-i2c-1.dtsi" + +/include/ "pq3-etsec1-0.dtsi" +/include/ "pq3-etsec1-1.dtsi" +/include/ "pq3-etsec1-2.dtsi" };
/* PCIe controller base address 0x8000 */ diff --git a/arch/powerpc/dts/p2020rdb-pc.dts b/arch/powerpc/dts/p2020rdb-pc.dts index 08befd4c59..f3f6be1080 100644 --- a/arch/powerpc/dts/p2020rdb-pc.dts +++ b/arch/powerpc/dts/p2020rdb-pc.dts @@ -37,4 +37,5 @@ }; };
+/include/ "p2020rdb-pc.dtsi" /include/ "p2020-post.dtsi" diff --git a/arch/powerpc/dts/p2020rdb-pc.dtsi b/arch/powerpc/dts/p2020rdb-pc.dtsi new file mode 100644 index 0000000000..0d2acc746e --- /dev/null +++ b/arch/powerpc/dts/p2020rdb-pc.dtsi @@ -0,0 +1,50 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * P2020 RDB-PC Device Tree Source stub (no addresses or top-level ranges) + * + * Copyright 2011 Freescale Semiconductor Inc. + * Copyright 2020 NXP + */ + +&soc { + mdio@24520 { + phy0: ethernet-phy@0 { + interrupts = <3 1 0 0>; + reg = <0x0>; + }; + phy1: ethernet-phy@1 { + interrupts = <2 1 0 0>; + reg = <0x1>; + }; + }; + + mdio@25520 { + tbi0: tbi-phy@11 { + reg = <0x11>; + device_type = "tbi-phy"; + }; + }; + + mdio@26520 { + status = "disabled"; + }; + + enet0: ethernet@24000 { + phy-connection-type = "rgmii-id"; + fixed-link { + speed = <1000>; + full-duplex; + }; + }; + + enet1: ethernet@25000 { + tbi-handle = <&tbi0>; + phy-handle = <&phy0>; + phy-connection-type = "sgmii"; + }; + + enet2: ethernet@26000 { + phy-handle = <&phy1>; + phy-connection-type = "rgmii-id"; + }; +}; diff --git a/arch/powerpc/dts/p2020rdb-pc_36b.dts b/arch/powerpc/dts/p2020rdb-pc_36b.dts index 04b2519e1a..6d983b7d71 100644 --- a/arch/powerpc/dts/p2020rdb-pc_36b.dts +++ b/arch/powerpc/dts/p2020rdb-pc_36b.dts @@ -37,4 +37,5 @@ }; };
+/include/ "p2020rdb-pc.dtsi" /include/ "p2020-post.dtsi" diff --git a/arch/powerpc/dts/pq3-etsec1-0.dtsi b/arch/powerpc/dts/pq3-etsec1-0.dtsi new file mode 100644 index 0000000000..8800243f34 --- /dev/null +++ b/arch/powerpc/dts/pq3-etsec1-0.dtsi @@ -0,0 +1,28 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * PQ3 eTSEC device tree stub [ @ offsets 0x24000 ] + * + * Copyright 2011-2012 Freescale Semiconductor Inc. + * Copyright 2020 NXP + */ + +ethernet@24000 { + #address-cells = <1>; + #size-cells = <1>; + cell-index = <0>; + device_type = "network"; + model = "eTSEC"; + compatible = "gianfar"; + reg = <0x24000 0x1000>; + ranges = <0x0 0x24000 0x1000>; + fsl,magic-packet; + local-mac-address = [ 00 00 00 00 00 00 ]; + interrupts = <29 2 0 0 30 2 0 0 34 2 0 0>; +}; + +mdio@24520 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,gianfar-mdio"; + reg = <0x24520 0x20>; +}; diff --git a/arch/powerpc/dts/pq3-etsec1-1.dtsi b/arch/powerpc/dts/pq3-etsec1-1.dtsi new file mode 100644 index 0000000000..2bc62d1a57 --- /dev/null +++ b/arch/powerpc/dts/pq3-etsec1-1.dtsi @@ -0,0 +1,28 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * PQ3 eTSEC device tree stub [ @ offsets 0x25000 ] + * + * Copyright 2011-2012 Freescale Semiconductor Inc. + * Copyright 2020 NXP + */ + +ethernet@25000 { + #address-cells = <1>; + #size-cells = <1>; + cell-index = <1>; + device_type = "network"; + model = "eTSEC"; + compatible = "gianfar"; + reg = <0x25000 0x1000>; + ranges = <0x0 0x25000 0x1000>; + fsl,magic-packet; + local-mac-address = [ 00 00 00 00 00 00 ]; + interrupts = <35 2 0 0 36 2 0 0 40 2 0 0>; +}; + +mdio@25520 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,gianfar-tbi"; + reg = <0x25520 0x20>; +}; diff --git a/arch/powerpc/dts/pq3-etsec1-2.dtsi b/arch/powerpc/dts/pq3-etsec1-2.dtsi new file mode 100644 index 0000000000..d45865fe03 --- /dev/null +++ b/arch/powerpc/dts/pq3-etsec1-2.dtsi @@ -0,0 +1,28 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * PQ3 eTSEC device tree stub [ @ offsets 0x26000 ] + * + * Copyright 2011-2012 Freescale Semiconductor Inc. + * Copyright 2020 NXP + */ + +ethernet@26000 { + #address-cells = <1>; + #size-cells = <1>; + cell-index = <2>; + device_type = "network"; + model = "eTSEC"; + compatible = "gianfar"; + reg = <0x26000 0x1000>; + ranges = <0x0 0x26000 0x1000>; + fsl,magic-packet; + local-mac-address = [ 00 00 00 00 00 00 ]; + interrupts = <31 2 0 0 32 2 0 0 33 2 0 0>; +}; + +mdio@26520 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,gianfar-tbi"; + reg = <0x26520 0x20>; +}; diff --git a/arch/powerpc/dts/pq3-etsec1-3.dtsi b/arch/powerpc/dts/pq3-etsec1-3.dtsi new file mode 100644 index 0000000000..853a27359d --- /dev/null +++ b/arch/powerpc/dts/pq3-etsec1-3.dtsi @@ -0,0 +1,28 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * PQ3 eTSEC device tree stub [ @ offsets 0x27000 ] + * + * Copyright 2011-2012 Freescale Semiconductor Inc. + * Copyright 2020 NXP + */ + +ethernet@27000 { + #address-cells = <1>; + #size-cells = <1>; + cell-index = <3>; + device_type = "network"; + model = "eTSEC"; + compatible = "gianfar"; + reg = <0x27000 0x1000>; + ranges = <0x0 0x27000 0x1000>; + fsl,magic-packet; + local-mac-address = [ 00 00 00 00 00 00 ]; + interrupts = <37 2 0 0 38 2 0 0 39 2 0 0>; +}; + +mdio@27520 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,gianfar-tbi"; + reg = <0x27520 0x20>; +};
On P2020RDB, the eTSEC1 is connecting with a switch VSC7385, so also enable the fixed PHY support.
configs/P2020RDB-PC_36BIT_NAND_defconfig | 3 +++ configs/P2020RDB-PC_36BIT_SDCARD_defconfig | 3 +++ configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig | 3 +++ configs/P2020RDB-PC_36BIT_defconfig | 3 +++ configs/P2020RDB-PC_NAND_defconfig | 3 +++ configs/P2020RDB-PC_SDCARD_defconfig | 3 +++ configs/P2020RDB-PC_SPIFLASH_defconfig | 3 +++ configs/P2020RDB-PC_defconfig | 3 +++ 8 files changed, 24 insertions(+)
diff --git a/configs/P2020RDB-PC_36BIT_NAND_defconfig b/configs/P2020RDB-PC_36BIT_NAND_defconfig index 3e6ea64ee3..4cd689f55d 100644 --- a/configs/P2020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P2020RDB-PC_36BIT_NAND_defconfig @@ -66,6 +66,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y +CONFIG_PHY_FIXED=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y CONFIG_PHY_DAVICOM=y @@ -77,8 +78,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig index 187cbee0d6..f46463a297 100644 --- a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig @@ -61,6 +61,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y +CONFIG_PHY_FIXED=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y CONFIG_PHY_DAVICOM=y @@ -72,8 +73,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig index 88c9224001..73d1be1013 100644 --- a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig @@ -63,6 +63,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y +CONFIG_PHY_FIXED=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y CONFIG_PHY_DAVICOM=y @@ -74,8 +75,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P2020RDB-PC_36BIT_defconfig b/configs/P2020RDB-PC_36BIT_defconfig index 88e24c30ba..21a0e85f98 100644 --- a/configs/P2020RDB-PC_36BIT_defconfig +++ b/configs/P2020RDB-PC_36BIT_defconfig @@ -50,6 +50,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y +CONFIG_PHY_FIXED=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y CONFIG_PHY_DAVICOM=y @@ -61,8 +62,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P2020RDB-PC_NAND_defconfig b/configs/P2020RDB-PC_NAND_defconfig index dda34dd43e..800c728ed3 100644 --- a/configs/P2020RDB-PC_NAND_defconfig +++ b/configs/P2020RDB-PC_NAND_defconfig @@ -65,6 +65,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y +CONFIG_PHY_FIXED=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y CONFIG_PHY_DAVICOM=y @@ -76,8 +77,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P2020RDB-PC_SDCARD_defconfig b/configs/P2020RDB-PC_SDCARD_defconfig index c2b6ad5f32..81cbac2fe8 100644 --- a/configs/P2020RDB-PC_SDCARD_defconfig +++ b/configs/P2020RDB-PC_SDCARD_defconfig @@ -60,6 +60,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y +CONFIG_PHY_FIXED=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y CONFIG_PHY_DAVICOM=y @@ -71,8 +72,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P2020RDB-PC_SPIFLASH_defconfig b/configs/P2020RDB-PC_SPIFLASH_defconfig index 3ec208ee00..89308a503b 100644 --- a/configs/P2020RDB-PC_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_SPIFLASH_defconfig @@ -62,6 +62,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y +CONFIG_PHY_FIXED=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y CONFIG_PHY_DAVICOM=y @@ -73,8 +74,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y diff --git a/configs/P2020RDB-PC_defconfig b/configs/P2020RDB-PC_defconfig index 0f0a6ad810..66fc3b0a14 100644 --- a/configs/P2020RDB-PC_defconfig +++ b/configs/P2020RDB-PC_defconfig @@ -49,6 +49,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y +CONFIG_PHY_FIXED=y CONFIG_PHY_ATHEROS=y CONFIG_PHY_BROADCOM=y CONFIG_PHY_DAVICOM=y @@ -60,8 +61,10 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_PHY_GIGE=y CONFIG_E1000=y +CONFIG_DM_ETH=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_DM_MDIO=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y
Vladimir Oltean
Z.q. Hou
Zhiqiang Hou
