[U-Boot] [PATCH] dtbo: Fix dtbo generation rules
Take the first prerequisite (dts overlay file) instead of standard input.
Not sure how this was designed to take overlay as input. What I have done was simply add overlay to arch/arm/dts folder and add target with .dtbo suffix.
--- scripts/Makefile.lib | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/scripts/Makefile.lib b/scripts/Makefile.lib index a5b57fc6b98a..34b3fed6a0ba 100644 --- a/scripts/Makefile.lib +++ b/scripts/Makefile.lib @@ -317,7 +317,7 @@ quiet_cmd_dtco = DTCO $@ # No generation of assembly file either # Modified for U-Boot cmd_dtco = mkdir -p $(dir ${dtc-tmp}) ; \ - $(CPP) $(dtc_cpp_flags) -x assembler-with-cpp -o $(dtc-tmp) - ; \ + $(CPP) $(dtc_cpp_flags) -x assembler-with-cpp -o $(dtc-tmp) $< ; \ $(DTC) -@ -O dtb -o $@ -b 0 \ -i $(dir $<) $(DTC_FLAGS) \ -d $(depfile).dtc.tmp $(dtc-tmp) ; \
- $(CPP) $(dtc_cpp_flags) -x assembler-with-cpp -o $(dtc-tmp) $< ; \ $(DTC) -@ -O dtb -o $@ -b 0 \ -i $(dir $<) $(DTC_FLAGS) \ -d $(depfile).dtc.tmp $(dtc-tmp) ; \
Any issue with this?
Thanks, Michal
Michal Simek
Michal Simek
