[PATCH] engicam: Rename board dir, px30_core to px30
Engicam hardware design solutions are based on System On Modules(SoM) with various SoCs like i.MX6, i.MX8 and PX30 etc.
The current directory structure uses the simplest way to understand these designs by listing each of these SoC in board/engicam/SoC and inside SoC directory has SoM file name as a board file name.
Right now all of the SoC's follow a similar approach except px30. So rename px30_core to px30.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Note: This patch is on top of https://patchwork.ozlabs.org/project/uboot/cover/20210804090551.90819-1-jaga...
arch/arm/mach-rockchip/px30/Kconfig | 2 +- board/engicam/{px30_core => px30}/Kconfig | 2 +- board/engicam/{px30_core => px30}/MAINTAINERS | 0 board/engicam/{px30_core => px30}/Makefile | 0 board/engicam/{px30_core => px30}/px30_core.c | 0 5 files changed, 2 insertions(+), 2 deletions(-) rename board/engicam/{px30_core => px30}/Kconfig (90%) rename board/engicam/{px30_core => px30}/MAINTAINERS (100%) rename board/engicam/{px30_core => px30}/Makefile (100%) rename board/engicam/{px30_core => px30}/px30_core.c (100%)
diff --git a/arch/arm/mach-rockchip/px30/Kconfig b/arch/arm/mach-rockchip/px30/Kconfig index 98e09019a2..7b9b380dfa 100644 --- a/arch/arm/mach-rockchip/px30/Kconfig +++ b/arch/arm/mach-rockchip/px30/Kconfig @@ -68,7 +68,7 @@ config DEBUG_UART_CHANNEL For using the UART for early debugging the route to use needs to be declared (0 or 1).
-source "board/engicam/px30_core/Kconfig" +source "board/engicam/px30/Kconfig" source "board/hardkernel/odroid_go2/Kconfig" source "board/rockchip/evb_px30/Kconfig"
diff --git a/board/engicam/px30_core/Kconfig b/board/engicam/px30/Kconfig similarity index 90% rename from board/engicam/px30_core/Kconfig rename to board/engicam/px30/Kconfig index a03be78369..10a7ec203f 100644 --- a/board/engicam/px30_core/Kconfig +++ b/board/engicam/px30/Kconfig @@ -1,7 +1,7 @@ if TARGET_PX30_CORE
config SYS_BOARD - default "px30_core" + default "px30"
config SYS_VENDOR default "engicam" diff --git a/board/engicam/px30_core/MAINTAINERS b/board/engicam/px30/MAINTAINERS similarity index 100% rename from board/engicam/px30_core/MAINTAINERS rename to board/engicam/px30/MAINTAINERS diff --git a/board/engicam/px30_core/Makefile b/board/engicam/px30/Makefile similarity index 100% rename from board/engicam/px30_core/Makefile rename to board/engicam/px30/Makefile diff --git a/board/engicam/px30_core/px30_core.c b/board/engicam/px30/px30_core.c similarity index 100% rename from board/engicam/px30_core/px30_core.c rename to board/engicam/px30/px30_core.c
Hi Jagan,
Please add 'rockchip' prefix in the subject.
Thanks,
- Kever
config SYS_BOARD
default "px30"
Jagan Teki
Kever Yang
