[U-Boot] [PATCH 00/35] Blackfin updates for 2010.09
A few minor bug fixes here and there, but the really exciting development is the import of the GPIO/PORTMUX layer from the Blackfin Linux port. This greatly simplifies code throughout the tree when device drivers need to do things through GPIOs or deal with pin muxing.
Hoan Hoang (1): Blackfin: ibf-dsp561: enable AX88180 net driver
Michael Hennerich (1): Blackfin: bf527-ad7160-eval: new board support
Mike Frysinger (33): Blackfin: clean up trace buffer handling when crashing Blackfin: implement bootcount support Blackfin: expand EVT1 usage documentation a bit more Blackfin: bf537-stamp: drop old spi_flash driver Blackfin: update anomaly lists to latest sheets Blackfin: set up simple NMI handlers for anomaly 05000219 Blackfin: import gpio/portmux layer from Linux Blackfin: unify custom gpio commands Blackfin: back out status_led.h stubs Blackfin: switch to common GPIO LED driver Blackfin: bf537-stamp: use common spi boot workaround code Blackfin: convert gpio flash logic to common gpio layer Blackfin: bfin_mac: convert to portmux framework Blackfin: bfin_nand: convert to portmux framework Blackfin: bfin_sdh: convert to portmux framework Blackfin: pata_bfin: convert to portmux framework Blackfin: serial: convert to portmux framework Blackfin: bfin_spi: convert to portmux framework Blackfin: bfin_spi: support gpios as chip selects Blackfin: bf533-stamp: convert eth/flash swap logic to gpio framework Blackfin: blackstamp: convert eth/flash swap logic to gpio framework Blackfin: bf533-stamp: scrub unused code Blackfin: bf518f-ezbrd: handle different PHYs dynamically Blackfin: bf518f-ezbrd: convert to portmux framework Blackfin: bf548-ezkit: convert to portmux framework Blackfin: bf527-ezkit: convert to portmux framework Blackfin: cm-bf548: convert to portmux framework Blackfin: bf561: use DMA for Core B L1 regions Blackfin: unify default I2C settings for ADI boards Blackfin: bfin_mac: remove space from name Blackfin: enable IP defrag for ADI boards Blackfin: drop old u-boot.lds clean target Blackfin: bf561-acvilon: drop unused env redund define
MAINTAINERS | 2 + MAKEALL | 1 + Makefile | 1 - arch/blackfin/cpu/Makefile | 3 + arch/blackfin/cpu/bootcount.c | 34 + arch/blackfin/cpu/cmd_gpio.c | 120 +++ arch/blackfin/cpu/cpu.c | 4 +- arch/blackfin/cpu/cpu.h | 2 + arch/blackfin/cpu/gpio.c | 854 ++++++++++++++++ arch/blackfin/cpu/initcode.c | 32 +- arch/blackfin/cpu/interrupt.S | 5 + arch/blackfin/cpu/serial.h | 19 + arch/blackfin/cpu/traps.c | 76 +- arch/blackfin/include/asm/blackfin_local.h | 10 +- arch/blackfin/include/asm/gpio.h | 201 ++++ arch/blackfin/include/asm/mach-bf527/anomaly.h | 196 +++-- arch/blackfin/include/asm/mach-bf527/def_local.h | 4 + arch/blackfin/include/asm/mach-bf527/gpio.h | 65 ++ arch/blackfin/include/asm/mach-bf527/portmux.h | 220 ++++ arch/blackfin/include/asm/mach-bf533/anomaly.h | 111 ++- arch/blackfin/include/asm/mach-bf533/def_local.h | 4 + arch/blackfin/include/asm/mach-bf533/gpio.h | 31 + arch/blackfin/include/asm/mach-bf533/portmux.h | 71 ++ arch/blackfin/include/asm/mach-bf537/anomaly.h | 85 ++- arch/blackfin/include/asm/mach-bf537/def_local.h | 4 + arch/blackfin/include/asm/mach-bf537/gpio.h | 65 ++ arch/blackfin/include/asm/mach-bf537/portmux.h | 152 +++ arch/blackfin/include/asm/mach-bf548/anomaly.h | 96 ++- arch/blackfin/include/asm/mach-bf548/def_local.h | 4 + arch/blackfin/include/asm/mach-bf548/gpio.h | 203 ++++ arch/blackfin/include/asm/mach-bf548/portmux.h | 320 ++++++ arch/blackfin/include/asm/mach-bf561/anomaly.h | 132 ++- arch/blackfin/include/asm/mach-bf561/def_local.h | 4 + arch/blackfin/include/asm/mach-bf561/gpio.h | 65 ++ arch/blackfin/include/asm/mach-bf561/portmux.h | 97 ++ arch/blackfin/include/asm/portmux.h | 1194 ++++++++++++++++++++++ arch/blackfin/include/asm/system.h | 2 + board/bf518f-ezbrd/bf518f-ezbrd.c | 41 +- board/bf526-ezbrd/Makefile | 1 - board/bf526-ezbrd/status-led.c | 56 - board/bf527-ad7160-eval/Makefile | 54 + board/bf527-ad7160-eval/bf527-ad7160-eval.c | 25 + board/bf527-ad7160-eval/config.mk | 33 + board/bf527-ezkit/bf527-ezkit.c | 7 +- board/bf527-ezkit/video.c | 13 +- board/bf533-stamp/bf533-stamp.c | 84 +-- board/bf533-stamp/bf533-stamp.h | 53 - board/bf533-stamp/ide-cf.c | 10 +- board/bf537-stamp/Makefile | 3 +- board/bf537-stamp/bf537-stamp.c | 7 +- board/bf537-stamp/cmd_bf537led.c | 201 ---- board/bf537-stamp/spi_flash.c | 996 ------------------ board/bf548-ezkit/bf548-ezkit.c | 64 +- board/bf548-ezkit/video.c | 27 +- board/blackstamp/blackstamp.c | 12 +- board/cm-bf527/Makefile | 2 +- board/cm-bf527/gpio.c | 74 -- board/cm-bf527/gpio_cfi_flash.c | 21 +- board/cm-bf537e/Makefile | 2 +- board/cm-bf537e/flash.c | 34 - board/cm-bf537e/gpio_cfi_flash.c | 18 +- board/cm-bf537u/Makefile | 2 +- board/cm-bf537u/flash.c | 34 - board/cm-bf537u/gpio_cfi_flash.c | 18 +- board/cm-bf548/cm-bf548.c | 55 +- board/cm-bf548/video.c | 33 +- board/ibf-dsp561/ibf-dsp561.c | 8 + board/tcm-bf537/Makefile | 2 +- board/tcm-bf537/flash.c | 37 - board/tcm-bf537/gpio_cfi_flash.c | 20 +- boards.cfg | 1 + drivers/block/pata_bfin.c | 25 +- drivers/mmc/bfin_sdh.c | 18 +- drivers/mtd/nand/bfin_nand.c | 16 +- drivers/net/bfin_mac.c | 49 +- drivers/spi/bfin_spi.c | 292 ++---- include/configs/bf518f-ezbrd.h | 22 +- include/configs/bf526-ezbrd.h | 14 +- include/configs/bf527-ad7160-eval.h | 148 +++ include/configs/bf527-ezkit.h | 2 - include/configs/bf533-ezkit.h | 2 - include/configs/bf533-stamp.h | 18 +- include/configs/bf537-pnav.h | 2 - include/configs/bf537-stamp.h | 4 - include/configs/bf538f-ezkit.h | 2 - include/configs/bf548-ezkit.h | 2 - include/configs/bf561-acvilon.h | 1 - include/configs/bf561-ezkit.h | 2 - include/configs/bfin_adi_common.h | 15 + include/configs/cm-bf527.h | 2 - include/configs/cm-bf537e.h | 2 - include/configs/cm-bf537u.h | 2 - include/configs/cm-bf548.h | 2 - include/configs/ibf-dsp561.h | 14 +- include/configs/tcm-bf518.h | 2 - include/configs/tcm-bf537.h | 2 - include/status_led.h | 3 - 97 files changed, 4896 insertions(+), 2304 deletions(-) create mode 100644 arch/blackfin/cpu/bootcount.c create mode 100644 arch/blackfin/cpu/cmd_gpio.c create mode 100644 arch/blackfin/cpu/gpio.c create mode 100644 arch/blackfin/include/asm/gpio.h create mode 100644 arch/blackfin/include/asm/mach-bf527/gpio.h create mode 100644 arch/blackfin/include/asm/mach-bf527/portmux.h create mode 100644 arch/blackfin/include/asm/mach-bf533/gpio.h create mode 100644 arch/blackfin/include/asm/mach-bf533/portmux.h create mode 100644 arch/blackfin/include/asm/mach-bf537/gpio.h create mode 100644 arch/blackfin/include/asm/mach-bf537/portmux.h create mode 100644 arch/blackfin/include/asm/mach-bf548/gpio.h create mode 100644 arch/blackfin/include/asm/mach-bf548/portmux.h create mode 100644 arch/blackfin/include/asm/mach-bf561/gpio.h create mode 100644 arch/blackfin/include/asm/mach-bf561/portmux.h create mode 100644 arch/blackfin/include/asm/portmux.h delete mode 100644 board/bf526-ezbrd/status-led.c create mode 100644 board/bf527-ad7160-eval/Makefile create mode 100644 board/bf527-ad7160-eval/bf527-ad7160-eval.c create mode 100644 board/bf527-ad7160-eval/config.mk delete mode 100644 board/bf533-stamp/bf533-stamp.h delete mode 100644 board/bf537-stamp/cmd_bf537led.c delete mode 100644 board/bf537-stamp/spi_flash.c delete mode 100644 board/cm-bf527/gpio.c delete mode 100644 board/cm-bf537e/flash.c delete mode 100644 board/cm-bf537u/flash.c delete mode 100644 board/tcm-bf537/flash.c create mode 100644 include/configs/bf527-ad7160-eval.h
Avoid banging on the trace MMRs when debugging is disabled, avoid calling the funcs multiple times in a row, disable the trace buffer earlier in the exception handler to avoid eating more user entries, and dump the buffer before calling the kgdb hook. This way we maximize useful debugging info up front rather than needing external tools (like gdb/serial/etc...).
Signed-off-by: Mike Frysinger vapier@gentoo.org --- arch/blackfin/cpu/cpu.h | 1 + arch/blackfin/cpu/traps.c | 76 ++++++++++++++++++++++++++++---------------- 2 files changed, 49 insertions(+), 28 deletions(-)
diff --git a/arch/blackfin/cpu/cpu.h b/arch/blackfin/cpu/cpu.h index 0a13c28..c8bec11 100644 --- a/arch/blackfin/cpu/cpu.h +++ b/arch/blackfin/cpu/cpu.h @@ -29,6 +29,7 @@
void board_reset(void) __attribute__((__weak__)); void bfin_reset_or_hang(void) __attribute__((__noreturn__)); +void bfin_dump(struct pt_regs *reg); void bfin_panic(struct pt_regs *reg); void dump(struct pt_regs *regs);
diff --git a/arch/blackfin/cpu/traps.c b/arch/blackfin/cpu/traps.c index caaea94..09388aa 100644 --- a/arch/blackfin/cpu/traps.c +++ b/arch/blackfin/cpu/traps.c @@ -29,14 +29,26 @@ #include <asm/deferred.h> #include "cpu.h"
+#ifdef CONFIG_DEBUG_DUMP +# define ENABLE_DUMP 1 +#else +# define ENABLE_DUMP 0 +#endif + #define trace_buffer_save(x) \ do { \ + if (!ENABLE_DUMP) \ + break; \ (x) = bfin_read_TBUFCTL(); \ bfin_write_TBUFCTL((x) & ~TBUFEN); \ } while (0)
#define trace_buffer_restore(x) \ - bfin_write_TBUFCTL((x)) + do { \ + if (!ENABLE_DUMP) \ + break; \ + bfin_write_TBUFCTL((x)); \ + } while (0);
/* The purpose of this map is to provide a mapping of address<->cplb settings * rather than an exact map of what is actually addressable on the part. This @@ -82,8 +94,16 @@ int trap_c(struct pt_regs *regs, uint32_t level) { uint32_t ret = 0; uint32_t trapnr = (regs->seqstat & EXCAUSE); + unsigned long tflags; bool data = false;
+ /* + * Keep the trace buffer so that a miss here points people + * to the right place (their code). Crashes here rarely + * happen. If they do, only the Blackfin maintainer cares. + */ + trace_buffer_save(tflags); + switch (trapnr) { /* 0x26 - Data CPLB Miss */ case VEC_CPLB_M: @@ -97,7 +117,7 @@ int trap_c(struct pt_regs *regs, uint32_t level) */ if (last_cplb_fault_retx != regs->retx) { last_cplb_fault_retx = regs->retx; - return ret; + break; } }
@@ -110,7 +130,6 @@ int trap_c(struct pt_regs *regs, uint32_t level) uint32_t new_cplb_addr = 0, new_cplb_data = 0; static size_t last_evicted; size_t i; - unsigned long tflags;
#ifdef CONFIG_EXCEPTION_DEFER /* This should never happen */ @@ -118,13 +137,6 @@ int trap_c(struct pt_regs *regs, uint32_t level) bfin_panic(regs); #endif
- /* - * Keep the trace buffer so that a miss here points people - * to the right place (their code). Crashes here rarely - * happen. If they do, only the Blackfin maintainer cares. - */ - trace_buffer_save(tflags); - new_cplb_addr = (data ? bfin_read_DCPLB_FAULT_ADDR() : bfin_read_ICPLB_FAULT_ADDR()) & ~(4 * 1024 * 1024 - 1);
for (i = 0; i < ARRAY_SIZE(bfin_memory_map); ++i) { @@ -180,7 +192,6 @@ int trap_c(struct pt_regs *regs, uint32_t level) for (i = 0; i < 16; ++i) debug("%2i 0x%p 0x%08X\n", i, *CPLB_ADDR++, *CPLB_DATA++);
- trace_buffer_restore(tflags); break; } #ifdef CONFIG_CMD_KGDB @@ -208,23 +219,21 @@ int trap_c(struct pt_regs *regs, uint32_t level) #ifdef CONFIG_CMD_KGDB if (level == 3) { /* We need to handle this at EVT5, so try again */ + bfin_dump(regs); ret = 1; break; } if (debugger_exception_handler && (*debugger_exception_handler)(regs)) - return 0; + break; #endif bfin_panic(regs); } + + trace_buffer_restore(tflags); + return ret; }
-#ifdef CONFIG_DEBUG_DUMP -# define ENABLE_DUMP 1 -#else -# define ENABLE_DUMP 0 -#endif - #ifndef CONFIG_KALLSYMS const char *symbol_lookup(unsigned long addr, unsigned long *caddr) { @@ -364,17 +373,14 @@ void dump(struct pt_regs *fp) printf("\n"); }
-void dump_bfin_trace_buffer(void) +static void _dump_bfin_trace_buffer(void) { char buf[150]; - unsigned long tflags; int i = 0;
if (!ENABLE_DUMP) return;
- trace_buffer_save(tflags); - printf("Hardware Trace:\n");
if (bfin_read_TBUFSTAT() & TBUFCNT) { @@ -385,16 +391,21 @@ void dump_bfin_trace_buffer(void) printf(" Source : %s\n", buf); } } +}
+void dump_bfin_trace_buffer(void) +{ + unsigned long tflags; + trace_buffer_save(tflags); + _dump_bfin_trace_buffer(); trace_buffer_restore(tflags); }
-void bfin_panic(struct pt_regs *regs) +void bfin_dump(struct pt_regs *regs) { - if (ENABLE_DUMP) { - unsigned long tflags; - trace_buffer_save(tflags); - } + unsigned long tflags; + + trace_buffer_save(tflags);
puts( "\n" @@ -404,7 +415,16 @@ void bfin_panic(struct pt_regs *regs) "\n" ); dump(regs); - dump_bfin_trace_buffer(); + _dump_bfin_trace_buffer(); puts("\n"); + + trace_buffer_restore(tflags); +} + +void bfin_panic(struct pt_regs *regs) +{ + unsigned long tflags; + trace_buffer_save(tflags); + bfin_dump(regs); bfin_reset_or_hang(); }
The default storage location for bootcount is EVT0. This version uses one 32bit value and combines the magic/count value in the upper/lower 16bits. If there is demand for more, should be easy to do.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- arch/blackfin/cpu/Makefile | 1 + arch/blackfin/cpu/bootcount.c | 34 ++++++++++++++++++++++++++++++++++ 2 files changed, 35 insertions(+), 0 deletions(-) create mode 100644 arch/blackfin/cpu/bootcount.c
diff --git a/arch/blackfin/cpu/Makefile b/arch/blackfin/cpu/Makefile index 211b8d5..50c1eea 100644 --- a/arch/blackfin/cpu/Makefile +++ b/arch/blackfin/cpu/Makefile @@ -17,6 +17,7 @@ EXTRA := CEXTRA := initcode.o SEXTRA := start.o SOBJS := interrupt.o cache.o +COBJS-$(CONFIG_BOOTCOUNT_LIMIT) += bootcount.o COBJS-y += cpu.o COBJS-y += interrupts.o COBJS-$(CONFIG_JTAG_CONSOLE) += jtag-console.o diff --git a/arch/blackfin/cpu/bootcount.c b/arch/blackfin/cpu/bootcount.c new file mode 100644 index 0000000..6cf6dd5 --- /dev/null +++ b/arch/blackfin/cpu/bootcount.c @@ -0,0 +1,34 @@ +/* + * functions for handling bootcount support + * + * Copyright (c) 2010 Analog Devices Inc. + * + * Licensed under the 2-clause BSD. + */ + +/* This version uses one 32bit storage and combines the magic/count */ + +#include <common.h> + +/* We abuse the EVT0 MMR for bootcount storage by default */ +#ifndef CONFIG_SYS_BOOTCOUNT_ADDR +# define CONFIG_SYS_BOOTCOUNT_ADDR EVT0 +#endif + +#define MAGIC_MASK 0xffff0000 +#define COUNT_MASK 0x0000ffff + +void bootcount_store(ulong cnt) +{ + ulong magic = (BOOTCOUNT_MAGIC & MAGIC_MASK) | (cnt & COUNT_MASK); + bfin_write32(CONFIG_SYS_BOOTCOUNT_ADDR, magic); +} + +ulong bootcount_load(void) +{ + ulong magic = bfin_read32(CONFIG_SYS_BOOTCOUNT_ADDR); + if ((magic & MAGIC_MASK) == (BOOTCOUNT_MAGIC & MAGIC_MASK)) + return magic & COUNT_MASK; + else + return 0; +}
Signed-off-by: Mike Frysinger vapier@gentoo.org --- arch/blackfin/cpu/initcode.c | 7 ++++++- 1 files changed, 6 insertions(+), 1 deletions(-)
diff --git a/arch/blackfin/cpu/initcode.c b/arch/blackfin/cpu/initcode.c index 5f80ad6..9453d5d 100644 --- a/arch/blackfin/cpu/initcode.c +++ b/arch/blackfin/cpu/initcode.c @@ -675,7 +675,12 @@ void initcode(ADI_BOOT_DATA *bs)
#ifdef CONFIG_BFIN_BOOTROM_USES_EVT1 serial_putc('I'); - /* tell the bootrom where our entry point is */ + /* Tell the bootrom where our entry point is so that it knows + * where to jump to when finishing processing the LDR. This + * allows us to avoid small jump blocks in the LDR, and also + * works around anomaly 05000389 (init address in external + * memory causes bootrom to trigger external addressing IVHW). + */ if (CONFIG_BFIN_BOOT_MODE != BFIN_BOOT_BYPASS) bfin_write_EVT1(CONFIG_SYS_MONITOR_BASE); #endif
- /* Tell the bootrom where our entry point is so that it knows
- * where to jump to when finishing processing the LDR. This
- * allows us to avoid small jump blocks in the LDR, and also
- * works around anomaly 05000389 (init address in external
- * memory causes bootrom to trigger external addressing IVHW).
The comment format is like the kernel's one.
/* * Comment */
Best regards, Aldo Brett.
The new common spi framework and spi flash subsystem provides all the same functionality as the old Blackfin-specific driver, so punt the old one as it has been sticking around long enough.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- board/bf537-stamp/Makefile | 1 - board/bf537-stamp/spi_flash.c | 996 ----------------------------------------- 2 files changed, 0 insertions(+), 997 deletions(-) delete mode 100644 board/bf537-stamp/spi_flash.c
diff --git a/board/bf537-stamp/Makefile b/board/bf537-stamp/Makefile index f728e2c..0e15062 100644 --- a/board/bf537-stamp/Makefile +++ b/board/bf537-stamp/Makefile @@ -31,7 +31,6 @@ LIB = $(obj)lib$(BOARD).a
COBJS-y := $(BOARD).o cmd_bf537led.o COBJS-$(CONFIG_BFIN_IDE) += ide-cf.o -COBJS-$(CONFIG_CMD_EEPROM) += spi_flash.o COBJS-$(CONFIG_POST) += post.o post-memory.o
SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) diff --git a/board/bf537-stamp/spi_flash.c b/board/bf537-stamp/spi_flash.c deleted file mode 100644 index 7b753ad..0000000 --- a/board/bf537-stamp/spi_flash.c +++ /dev/null @@ -1,996 +0,0 @@ -/* - * SPI flash driver - * - * Enter bugs at http://blackfin.uclinux.org/ - * - * Copyright (c) 2005-2008 Analog Devices Inc. - * - * Licensed under the GPL-2 or later. - */ - -/* Configuration options: - * CONFIG_SPI_BAUD - value to load into SPI_BAUD (divisor of SCLK to get SPI CLK) - * CONFIG_SPI_FLASH_SLOW_READ - force usage of the slower read - * WARNING: make sure your SCLK + SPI_BAUD is slow enough - */ - -#include <common.h> -#include <malloc.h> -#include <asm/io.h> -#include <asm/mach-common/bits/spi.h> -#include <asm/mach-common/bits/dma.h> - -/* Forcibly phase out these */ -#ifdef CONFIG_SPI_FLASH_NUM_SECTORS -# error do not set CONFIG_SPI_FLASH_NUM_SECTORS -#endif -#ifdef CONFIG_SPI_FLASH_SECTOR_SIZE -# error do not set CONFIG_SPI_FLASH_SECTOR_SIZE -#endif - -#if defined(CONFIG_SPI) - -struct flash_info { - char *name; - uint16_t id; - uint16_t ext_id; - unsigned sector_size; - unsigned num_sectors; -}; - -/* SPI Speeds: 50 MHz / 33 MHz */ -static struct flash_info flash_spansion_serial_flash[] = { - { "S25FL016", 0x0215, 0, 64 * 1024, 32 }, - { "S25FL032", 0x0216, 0, 64 * 1024, 64 }, - { "S25FL064", 0x0217, 0, 64 * 1024, 128 }, - { "S25FL128-00", 0x2018, 0x0301, 64 * 1024, 256 }, /* Package marking FL128PIF */ - { "S25FL128-01", 0x2018, 0x0300, 128 * 1024, 64 }, /* Package marking FL128PIFL */ - { NULL, 0, 0, 0, 0 } -}; - -/* SPI Speeds: 50 MHz / 20 MHz */ -static struct flash_info flash_st_serial_flash[] = { - { "m25p05", 0x2010, 0, 32 * 1024, 2 }, - { "m25p10", 0x2011, 0, 32 * 1024, 4 }, - { "m25p20", 0x2012, 0, 64 * 1024, 4 }, - { "m25p40", 0x2013, 0, 64 * 1024, 8 }, - { "m25p80", 0x20FF, 0, 64 * 1024, 16 }, - { "m25p16", 0x2015, 0, 64 * 1024, 32 }, - { "m25p32", 0x2016, 0, 64 * 1024, 64 }, - { "m25p64", 0x2017, 0, 64 * 1024, 128 }, - { "m25p128", 0x2018, 0, 256 * 1024, 64 }, - { NULL, 0, 0, 0, 0 } -}; - -/* SPI Speeds: 20 MHz / 40 MHz */ -static struct flash_info flash_sst_serial_flash[] = { - { "SST25WF512", 0x2501, 0, 4 * 1024, 128 }, - { "SST25WF010", 0x2502, 0, 4 * 1024, 256 }, - { "SST25WF020", 0x2503, 0, 4 * 1024, 512 }, - { "SST25WF040", 0x2504, 0, 4 * 1024, 1024 }, - { NULL, 0, 0, 0, 0 } -}; - -/* SPI Speeds: 66 MHz / 33 MHz */ -static struct flash_info flash_atmel_dataflash[] = { - { "AT45DB011x", 0x0c, 0, 264, 512 }, - { "AT45DB021x", 0x14, 0, 264, 1025 }, - { "AT45DB041x", 0x1c, 0, 264, 2048 }, - { "AT45DB081x", 0x24, 0, 264, 4096 }, - { "AT45DB161x", 0x2c, 0, 528, 4096 }, - { "AT45DB321x", 0x34, 0, 528, 8192 }, - { "AT45DB642x", 0x3c, 0, 1056, 8192 }, - { NULL, 0, 0, 0, 0 } -}; - -/* SPI Speed: 50 MHz / 25 MHz or 40 MHz / 20 MHz */ -static struct flash_info flash_winbond_serial_flash[] = { - { "W25X10", 0x3011, 0, 16 * 256, 32 }, - { "W25X20", 0x3012, 0, 16 * 256, 64 }, - { "W25X40", 0x3013, 0, 16 * 256, 128 }, - { "W25X80", 0x3014, 0, 16 * 256, 256 }, - { "W25P80", 0x2014, 0, 256 * 256, 16 }, - { "W25P16", 0x2015, 0, 256 * 256, 32 }, - { NULL, 0, 0, 0, 0 } -}; - -struct flash_ops { - uint8_t read, write, erase, status; -}; - -#ifdef CONFIG_SPI_FLASH_SLOW_READ -# define OP_READ 0x03 -#else -# define OP_READ 0x0B -#endif -static struct flash_ops flash_st_ops = { - .read = OP_READ, - .write = 0x02, - .erase = 0xD8, - .status = 0x05, -}; - -static struct flash_ops flash_sst_ops = { - .read = OP_READ, - .write = 0x02, - .erase = 0x20, - .status = 0x05, -}; - -static struct flash_ops flash_atmel_ops = { - .read = OP_READ, - .write = 0x82, - .erase = 0x81, - .status = 0xD7, -}; - -static struct flash_ops flash_winbond_ops = { - .read = OP_READ, - .write = 0x02, - .erase = 0x20, - .status = 0x05, -}; - -struct manufacturer_info { - const char *name; - uint8_t id; - struct flash_info *flashes; - struct flash_ops *ops; -}; - -static struct { - struct manufacturer_info *manufacturer; - struct flash_info *flash; - struct flash_ops *ops; - uint8_t manufacturer_id, device_id1, device_id2, device_extid1, device_extid2; - unsigned int write_length; - unsigned long sector_size, num_sectors; -} flash; - -enum { - JED_MANU_SPANSION = 0x01, - JED_MANU_ST = 0x20, - JED_MANU_SST = 0xBF, - JED_MANU_ATMEL = 0x1F, - JED_MANU_WINBOND = 0xEF, -}; - -static struct manufacturer_info flash_manufacturers[] = { - { - .name = "Spansion", - .id = JED_MANU_SPANSION, - .flashes = flash_spansion_serial_flash, - .ops = &flash_st_ops, - }, - { - .name = "ST", - .id = JED_MANU_ST, - .flashes = flash_st_serial_flash, - .ops = &flash_st_ops, - }, - { - .name = "SST", - .id = JED_MANU_SST, - .flashes = flash_sst_serial_flash, - .ops = &flash_sst_ops, - }, - { - .name = "Atmel", - .id = JED_MANU_ATMEL, - .flashes = flash_atmel_dataflash, - .ops = &flash_atmel_ops, - }, - { - .name = "Winbond", - .id = JED_MANU_WINBOND, - .flashes = flash_winbond_serial_flash, - .ops = &flash_winbond_ops, - }, -}; - -#define TIMEOUT 5000 /* timeout of 5 seconds */ - -/* If part has multiple SPI flashes, assume SPI0 as that is - * the one we can boot off of ... - */ -#ifndef pSPI_CTL -# define pSPI_CTL pSPI0_CTL -# define pSPI_BAUD pSPI0_BAUD -# define pSPI_FLG pSPI0_FLG -# define pSPI_RDBR pSPI0_RDBR -# define pSPI_STAT pSPI0_STAT -# define pSPI_TDBR pSPI0_TDBR -#endif - -/* Default to the SPI SSEL that we boot off of: - * BF54x, BF537, (everything new?): SSEL1 - * BF51x, BF533, BF561: SSEL2 - */ -#ifndef CONFIG_SPI_FLASH_SSEL -# define CONFIG_SPI_FLASH_SSEL BFIN_BOOT_SPI_SSEL -#endif -#define SSEL_MASK (1 << CONFIG_SPI_FLASH_SSEL) - -static void SPI_INIT(void) -{ - /* [#3541] This delay appears to be necessary, but not sure - * exactly why as the history behind it is non-existant. - */ - *pSPI_CTL = 0; - udelay(CONFIG_CCLK_HZ / 25000000); - - /* enable SPI pins: SSEL, MOSI, MISO, SCK */ -#ifdef __ADSPBF54x__ - *pPORTE_FER |= (PE0 | PE1 | PE2 | PE4); -#elif defined(__ADSPBF534__) || defined(__ADSPBF536__) || defined(__ADSPBF537__) - *pPORTF_FER |= (PF10 | PF11 | PF12 | PF13); -#elif defined(__ADSPBF52x__) - bfin_write_PORTG_MUX((bfin_read_PORTG_MUX() & ~PORT_x_MUX_0_MASK) | PORT_x_MUX_0_FUNC_3); - bfin_write_PORTG_FER(bfin_read_PORTG_FER() | PG1 | PG2 | PG3 | PG4); -#elif defined(__ADSPBF51x__) - bfin_write_PORTG_MUX((bfin_read_PORTG_MUX() & ~PORT_x_MUX_7_MASK) | PORT_x_MUX_7_FUNC_1); - bfin_write_PORTG_FER(bfin_read_PORTG_FER() | PG12 | PG13 | PG14 | PG15); -#endif - - /* initate communication upon write of TDBR */ - *pSPI_CTL = (SPE | MSTR | CPHA | CPOL | TDBR_CORE); - *pSPI_BAUD = CONFIG_SPI_BAUD; -} - -static void SPI_DEINIT(void) -{ - *pSPI_CTL = 0; - *pSPI_BAUD = 0; - SSYNC(); -} - -static void SPI_ON(void) -{ - /* toggle SSEL to reset the device so it'll take a new command */ - *pSPI_FLG = 0xFF00 | SSEL_MASK; - SSYNC(); - - *pSPI_FLG = ((0xFF & ~SSEL_MASK) << 8) | SSEL_MASK; - SSYNC(); -} - -static void SPI_OFF(void) -{ - /* put SPI settings back to reset state */ - *pSPI_FLG = 0xFF00; - SSYNC(); -} - -static uint8_t spi_write_read_byte(uint8_t transmit) -{ - *pSPI_TDBR = transmit; - SSYNC(); - - while ((*pSPI_STAT & TXS)) - if (ctrlc()) - break; - while (!(*pSPI_STAT & SPIF)) - if (ctrlc()) - break; - while (!(*pSPI_STAT & RXS)) - if (ctrlc()) - break; - - /* Read dummy to empty the receive register */ - return *pSPI_RDBR; -} - -static uint8_t read_status_register(void) -{ - uint8_t status_register; - - /* send instruction to read status register */ - SPI_ON(); - spi_write_read_byte(flash.ops->status); - /* send dummy to receive the status register */ - status_register = spi_write_read_byte(0); - SPI_OFF(); - - return status_register; -} - -static int wait_for_ready_status(void) -{ - ulong start = get_timer(0); - - while (get_timer(0) - start < TIMEOUT) { - switch (flash.manufacturer_id) { - case JED_MANU_SPANSION: - case JED_MANU_ST: - case JED_MANU_SST: - case JED_MANU_WINBOND: - if (!(read_status_register() & 0x01)) - return 0; - break; - - case JED_MANU_ATMEL: - if (read_status_register() & 0x80) - return 0; - break; - } - - if (ctrlc()) { - puts("\nAbort\n"); - return -1; - } - } - - puts("Timeout\n"); - return -1; -} - -static int enable_writing(void) -{ - ulong start; - - if (flash.manufacturer_id == JED_MANU_ATMEL) - return 0; - - /* A write enable instruction must previously have been executed */ - SPI_ON(); - spi_write_read_byte(0x06); - SPI_OFF(); - - /* The status register will be polled to check the write enable latch "WREN" */ - start = get_timer(0); - while (get_timer(0) - start < TIMEOUT) { - if (read_status_register() & 0x02) - return 0; - - if (ctrlc()) { - puts("\nAbort\n"); - return -1; - } - } - - puts("Timeout\n"); - return -1; -} - -static void write_status_register(uint8_t val) -{ - if (flash.manufacturer_id != JED_MANU_SST) - hang(); - - if (enable_writing()) - return; - - /* send instruction to write status register */ - SPI_ON(); - spi_write_read_byte(0x01); - /* and clear it! */ - spi_write_read_byte(val); - SPI_OFF(); -} - -/* Request and read the manufacturer and device id of parts which - * are compatible with the JEDEC standard (JEP106) and use that to - * setup other operating conditions. - */ -static int spi_detect_part(void) -{ - uint16_t dev_id, dev_extid; - size_t i; - - static char called_init; - if (called_init) - return 0; - -#ifdef CONFIG_SPI_FLASH_M25P80 - flash.manufacturer_id = JED_MANU_ST; - flash.device_id1 = 0x20; - flash.device_id2 = 0xFF; -#else - SPI_ON(); - - /* Send the request for the part identification */ - spi_write_read_byte(0x9F); - - /* Now read in the manufacturer id bytes */ - do { - flash.manufacturer_id = spi_write_read_byte(0); - if (flash.manufacturer_id == 0x7F) - puts("Warning: unhandled manufacturer continuation byte!\n"); - } while (flash.manufacturer_id == 0x7F); - - /* Now read in the first device id byte */ - flash.device_id1 = spi_write_read_byte(0); - - /* Now read in the second device id byte */ - flash.device_id2 = spi_write_read_byte(0); - - /* Read extended device ids */ - flash.device_extid1 = spi_write_read_byte(0); - flash.device_extid2 = spi_write_read_byte(0); - - SPI_OFF(); -#endif - - dev_id = (flash.device_id1 << 8) | flash.device_id2; - dev_extid = (flash.device_extid1 << 8) | flash.device_extid2; - - for (i = 0; i < ARRAY_SIZE(flash_manufacturers); ++i) { - if (flash.manufacturer_id == flash_manufacturers[i].id) - break; - } - if (i == ARRAY_SIZE(flash_manufacturers)) - goto unknown; - - flash.manufacturer = &flash_manufacturers[i]; - flash.ops = flash_manufacturers[i].ops; - - switch (flash.manufacturer_id) { - case JED_MANU_SPANSION: - case JED_MANU_ST: - case JED_MANU_SST: - case JED_MANU_WINBOND: - for (i = 0; flash.manufacturer->flashes[i].name; ++i) { - if (dev_id == flash.manufacturer->flashes[i].id && - (flash.manufacturer->flashes[i].ext_id == 0 || - flash.manufacturer->flashes[i].ext_id == dev_extid)) - break; - } - if (!flash.manufacturer->flashes[i].name) - goto unknown; - - flash.flash = &flash.manufacturer->flashes[i]; - flash.sector_size = flash.flash->sector_size; - flash.num_sectors = flash.flash->num_sectors; - - if (flash.manufacturer_id == JED_MANU_SST) - flash.write_length = 1; /* pwnt :( */ - else - flash.write_length = 256; - break; - - case JED_MANU_ATMEL: { - uint8_t status = read_status_register(); - - for (i = 0; flash.manufacturer->flashes[i].name; ++i) { - if ((status & 0x3c) == flash.manufacturer->flashes[i].id) - break; - } - if (!flash.manufacturer->flashes[i].name) - goto unknown; - - flash.flash = &flash.manufacturer->flashes[i]; - flash.sector_size = flash.flash->sector_size; - flash.num_sectors = flash.flash->num_sectors; - - /* see if flash is in "power of 2" mode */ - if (status & 0x1) - flash.sector_size &= ~(1 << (ffs(flash.sector_size) - 1)); - - flash.write_length = flash.sector_size; - break; - } - } - - /* the SST parts power up with software protection enabled by default */ - if (flash.manufacturer_id == JED_MANU_SST) - write_status_register(0); - - called_init = 1; - return 0; - - unknown: - printf("Unknown SPI device: 0x%02X 0x%02X 0x%02X\n", - flash.manufacturer_id, flash.device_id1, flash.device_id2); - return 1; -} - -/* - * Function: spi_init_f - * Description: Init SPI-Controller (ROM part) - * return: --- - */ -void spi_init_f(void) -{ -} - -/* - * Function: spi_init_r - * Description: Init SPI-Controller (RAM part) - - * The malloc engine is ready and we can move our buffers to - * normal RAM - * return: --- - */ -void spi_init_r(void) -{ -#if defined(CONFIG_POST) && (CONFIG_POST & CONFIG_SYS_POST_SPI) - /* Our testing strategy here is pretty basic: - * - fill src memory with an 8-bit pattern - * - write the src memory to the SPI flash - * - read the SPI flash into the dst memory - * - compare src and dst memory regions - * - repeat a few times - * The variations we test for: - * - change the 8-bit pattern a bit - * - change the read/write block size so we know: - * - writes smaller/equal/larger than the buffer work - * - writes smaller/equal/larger than the sector work - * - change the SPI offsets so we know: - * - writing partial sectors works - */ - uint8_t *mem_src, *mem_dst; - size_t i, c, l, o; - size_t test_count, errors; - uint8_t pattern; - - SPI_INIT(); - - if (spi_detect_part()) - goto out; - eeprom_info(); - - ulong lengths[] = { - flash.write_length, - flash.write_length * 2, - flash.write_length / 2, - flash.sector_size, - flash.sector_size * 2, - flash.sector_size / 2 - }; - ulong offsets[] = { - 0, - flash.write_length, - flash.write_length * 2, - flash.write_length / 2, - flash.write_length / 4, - flash.sector_size, - flash.sector_size * 2, - flash.sector_size / 2, - flash.sector_size / 4, - }; - - /* the exact addresses are arbitrary ... they just need to not overlap */ - mem_src = (void *)(0); - mem_dst = (void *)(max(flash.write_length, flash.sector_size) * 2); - - test_count = 0; - errors = 0; - pattern = 0x00; - - for (i = 0; i < 16; ++i) { /* 16 = 8 bits * 2 iterations */ - for (l = 0; l < ARRAY_SIZE(lengths); ++l) { - for (o = 0; o < ARRAY_SIZE(offsets); ++o) { - ulong len = lengths[l]; - ulong off = offsets[o]; - - printf("Testing pattern 0x%02X of length %5lu and offset %5lu: ", pattern, len, off); - - /* setup the source memory region */ - memset(mem_src, pattern, len); - - test_count += 4; - for (c = 0; c < 4; ++c) { /* 4 is just a random repeat count */ - if (ctrlc()) { - puts("\nAbort\n"); - goto out; - } - - /* make sure background fill pattern != pattern */ - memset(mem_dst, pattern ^ 0xFF, len); - - /* write out the source memory and then read it back and compare */ - eeprom_write(0, off, mem_src, len); - eeprom_read(0, off, mem_dst, len); - - if (memcmp(mem_src, mem_dst, len)) { - for (c = 0; c < len; ++c) - if (mem_src[c] != mem_dst[c]) - break; - printf(" FAIL @ offset %u, skipping repeats ", c); - ++errors; - break; - } - - /* XXX: should shrink write region here to test with - * leading/trailing canaries so we know surrounding - * bytes don't get screwed. - */ - } - puts("\n"); - } - } - - /* invert the pattern every other run and shift out bits slowly */ - pattern ^= 0xFF; - if (i % 2) - pattern = (pattern | 0x01) << 1; - } - - if (errors) - printf("SPI FAIL: Out of %i tests, there were %i errors ;(\n", test_count, errors); - else - printf("SPI PASS: %i tests worked!\n", test_count); - - out: - SPI_DEINIT(); - -#endif -} - -static void transmit_address(uint32_t addr) -{ - /* Send the highest byte of the 24 bit address at first */ - spi_write_read_byte(addr >> 16); - /* Send the middle byte of the 24 bit address at second */ - spi_write_read_byte(addr >> 8); - /* Send the lowest byte of the 24 bit address finally */ - spi_write_read_byte(addr); -} - -/* - * Read a value from flash for verify purpose - * Inputs: unsigned long ulStart - holds the SPI start address - * int pnData - pointer to store value read from flash - * long lCount - number of elements to read - */ -#ifdef CONFIG_SPI_READFLASH_NODMA -static int read_flash(unsigned long address, long count, uchar *buffer) -{ - size_t i, j; - - /* Send the read command to SPI device */ - SPI_ON(); - spi_write_read_byte(flash.ops->read); - transmit_address(address); - -#ifndef CONFIG_SPI_FLASH_SLOW_READ - /* Send dummy byte when doing SPI fast reads */ - spi_write_read_byte(0); -#endif - - /* After the SPI device address has been placed on the MOSI pin the data can be */ - /* received on the MISO pin. */ - j = flash.sector_size << 1; - for (i = 1; i <= count; ++i) { - *buffer++ = spi_write_read_byte(0); - if (!j--) { - puts("."); - j = flash.sector_size; - } - } - - SPI_OFF(); - - return 0; -} -#else - -#ifdef __ADSPBF54x__ -#define bfin_write_DMA_SPI_IRQ_STATUS bfin_write_DMA4_IRQ_STATUS -#define bfin_read_DMA_SPI_IRQ_STATUS bfin_read_DMA4_IRQ_STATUS -#define bfin_write_DMA_SPI_CURR_DESC_PTR bfin_write_DMA4_CURR_DESC_PTR -#define bfin_write_DMA_SPI_CONFIG bfin_write_DMA4_CONFIG -#elif defined(__ADSPBF533__) || defined(__ADSPBF532__) || defined(__ADSPBF531__) || \ - defined(__ADSPBF538__) || defined(__ADSPBF539__) -#define bfin_write_DMA_SPI_IRQ_STATUS bfin_write_DMA5_IRQ_STATUS -#define bfin_read_DMA_SPI_IRQ_STATUS bfin_read_DMA5_IRQ_STATUS -#define bfin_write_DMA_SPI_CURR_DESC_PTR bfin_write_DMA5_CURR_DESC_PTR -#define bfin_write_DMA_SPI_CONFIG bfin_write_DMA5_CONFIG -#elif defined(__ADSPBF561__) -#define bfin_write_DMA_SPI_IRQ_STATUS bfin_write_DMA16_IRQ_STATUS -#define bfin_read_DMA_SPI_IRQ_STATUS bfin_read_DMA16_IRQ_STATUS -#define bfin_write_DMA_SPI_CURR_DESC_PTR bfin_write_DMA16_CURR_DESC_PTR -#define bfin_write_DMA_SPI_CONFIG bfin_write_DMA16_CONFIG -#elif defined(__ADSPBF537__) || defined(__ADSPBF536__) || defined(__ADSPBF534__) || \ - defined(__ADSPBF52x__) || defined(__ADSPBF51x__) -#define bfin_write_DMA_SPI_IRQ_STATUS bfin_write_DMA7_IRQ_STATUS -#define bfin_read_DMA_SPI_IRQ_STATUS bfin_read_DMA7_IRQ_STATUS -#define bfin_write_DMA_SPI_CURR_DESC_PTR bfin_write_DMA7_CURR_DESC_PTR -#define bfin_write_DMA_SPI_CONFIG bfin_write_DMA7_CONFIG -#else -#error "Please provide SPI DMA channel defines" -#endif - -struct dmadesc_array { - unsigned long start_addr; - unsigned short cfg; - unsigned short x_count; - short x_modify; - unsigned short y_count; - short y_modify; -} __attribute__((packed)); - -/* - * Read a value from flash for verify purpose - * Inputs: unsigned long ulStart - holds the SPI start address - * int pnData - pointer to store value read from flash - * long lCount - number of elements to read - */ - -static int read_flash(unsigned long address, long count, uchar *buffer) -{ - unsigned int ndsize; - struct dmadesc_array dma[2]; - /* Send the read command to SPI device */ - - if (!count) - return 0; - - dma[0].start_addr = (unsigned long)buffer; - dma[0].x_modify = 1; - if (count <= 65536) { - blackfin_dcache_flush_invalidate_range(buffer, buffer + count); - ndsize = NDSIZE_5; - dma[0].cfg = NDSIZE_0 | WNR | WDSIZE_8 | FLOW_STOP | DMAEN | DI_EN; - dma[0].x_count = count; - } else { - blackfin_dcache_flush_invalidate_range(buffer, buffer + 65536 - 1); - ndsize = NDSIZE_7; - dma[0].cfg = NDSIZE_5 | WNR | WDSIZE_8 | FLOW_ARRAY | DMAEN | DMA2D; - dma[0].x_count = 0; /* 2^16 */ - dma[0].y_count = count >> 16; /* count / 2^16 */ - dma[0].y_modify = 1; - dma[1].start_addr = (unsigned long)(buffer + (count & ~0xFFFF)); - dma[1].cfg = NDSIZE_0 | WNR | WDSIZE_8 | FLOW_STOP | DMAEN | DI_EN; - dma[1].x_count = count & 0xFFFF; /* count % 2^16 */ - dma[1].x_modify = 1; - } - - bfin_write_DMA_SPI_CONFIG(0); - bfin_write_DMA_SPI_IRQ_STATUS(DMA_DONE | DMA_ERR); - bfin_write_DMA_SPI_CURR_DESC_PTR(dma); - - SPI_ON(); - - spi_write_read_byte(flash.ops->read); - transmit_address(address); - -#ifndef CONFIG_SPI_FLASH_SLOW_READ - /* Send dummy byte when doing SPI fast reads */ - spi_write_read_byte(0); -#endif - - bfin_write_DMA_SPI_CONFIG(ndsize | FLOW_ARRAY | DMAEN); - *pSPI_CTL = (MSTR | CPHA | CPOL | RDBR_DMA | SPE | SZ); - SSYNC(); - - /* - * We already invalidated the first 64k, - * now while we just wait invalidate the remaining part. - * Its not likely that the DMA is going to overtake - */ - if (count > 65536) - blackfin_dcache_flush_invalidate_range(buffer + 65536, - buffer + count); - - while (!(bfin_read_DMA_SPI_IRQ_STATUS() & DMA_DONE)) - if (ctrlc()) - break; - - SPI_OFF(); - - *pSPI_CTL = 0; - - bfin_write_DMA_SPI_CONFIG(0); - - *pSPI_CTL = (SPE | MSTR | CPHA | CPOL | TDBR_CORE); - - return 0; -} -#endif - -static long address_to_sector(unsigned long address) -{ - if (address > (flash.num_sectors * flash.sector_size) - 1) - return -1; - return address / flash.sector_size; -} - -static int erase_sector(int address) -{ - /* sector gets checked in higher function, so assume it's valid - * here and figure out the offset of the sector in flash - */ - if (enable_writing()) - return -1; - - /* - * Send the erase block command to the flash followed by the 24 address - * to point to the start of a sector - */ - SPI_ON(); - spi_write_read_byte(flash.ops->erase); - transmit_address(address); - SPI_OFF(); - - return wait_for_ready_status(); -} - -/* Write [count] bytes out of [buffer] into the given SPI [address] */ -static long write_flash(unsigned long address, long count, uchar *buffer) -{ - long i, write_buffer_size; - - if (enable_writing()) - return -1; - - /* Send write command followed by the 24 bit address */ - SPI_ON(); - spi_write_read_byte(flash.ops->write); - transmit_address(address); - - /* Shoot out a single write buffer */ - write_buffer_size = min(count, flash.write_length); - for (i = 0; i < write_buffer_size; ++i) - spi_write_read_byte(buffer[i]); - - SPI_OFF(); - - /* Wait for the flash to do its thing */ - if (wait_for_ready_status()) { - puts("SPI Program Time out! "); - return -1; - } - - return i; -} - -/* Write [count] bytes out of [buffer] into the given SPI [address] */ -static int write_sector(unsigned long address, long count, uchar *buffer) -{ - long write_cnt; - - while (count != 0) { - write_cnt = write_flash(address, count, buffer); - if (write_cnt == -1) - return -1; - - /* Now that we've sent some bytes out to the flash, update - * our counters a bit - */ - count -= write_cnt; - address += write_cnt; - buffer += write_cnt; - } - - /* return the appropriate error code */ - return 0; -} - -/* - * Function: spi_write - */ -ssize_t spi_write(uchar *addr, int alen, uchar *buffer, int len) -{ - unsigned long offset; - int start_sector, end_sector; - int start_byte, end_byte; - uchar *temp = NULL; - int num, ret = 0; - - SPI_INIT(); - - if (spi_detect_part()) - goto out; - - offset = addr[0] << 16 | addr[1] << 8 | addr[2]; - - /* Get the start block number */ - start_sector = address_to_sector(offset); - if (start_sector == -1) { - puts("Invalid sector! "); - goto out; - } - end_sector = address_to_sector(offset + len - 1); - if (end_sector == -1) { - puts("Invalid sector! "); - goto out; - } - - /* Since flashes operate in sector units but the eeprom command - * operates as a continuous stream of bytes, we need to emulate - * the eeprom behavior. So here we read in the sector, overlay - * any bytes we're actually modifying, erase the sector, and - * then write back out the new sector. - */ - temp = malloc(flash.sector_size); - if (!temp) { - puts("Malloc for sector failed! "); - goto out; - } - - for (num = start_sector; num <= end_sector; num++) { - unsigned long address = num * flash.sector_size; - - /* XXX: should add an optimization when spanning sectors: - * No point in reading in a sector if we're going to be - * clobbering the whole thing. Need to also add a test - * case to make sure the optimization is correct. - */ - if (read_flash(address, flash.sector_size, temp)) { - puts("Read sector failed! "); - len = 0; - break; - } - - start_byte = max(address, offset); - end_byte = address + flash.sector_size - 1; - if (end_byte > (offset + len)) - end_byte = (offset + len - 1); - - memcpy(temp + start_byte - address, - buffer + start_byte - offset, - end_byte - start_byte + 1); - - if (erase_sector(address)) { - puts("Erase sector failed! "); - goto out; - } - - if (write_sector(address, flash.sector_size, temp)) { - puts("Write sector failed! "); - goto out; - } - - puts("."); - } - - ret = len; - - out: - free(temp); - - SPI_DEINIT(); - - return ret; -} - -/* - * Function: spi_read - */ -ssize_t spi_read(uchar *addr, int alen, uchar *buffer, int len) -{ - unsigned long offset; - - SPI_INIT(); - - if (spi_detect_part()) - len = 0; - else { - offset = addr[0] << 16 | addr[1] << 8 | addr[2]; - read_flash(offset, len, buffer); - } - - SPI_DEINIT(); - - return len; -} - -/* - * Spit out some useful information about the SPI eeprom - */ -int eeprom_info(void) -{ - int ret = 0; - - SPI_INIT(); - - if (spi_detect_part()) - ret = 1; - else - printf("SPI Device: %s 0x%02X (%s) 0x%02X 0x%02X\n" - "Parameters: num sectors = %lu, sector size = %lu, write size = %i\n" - "Flash Size: %lu mbit (%lu mbyte)\n" - "Status: 0x%02X\n", - flash.flash->name, flash.manufacturer_id, flash.manufacturer->name, - flash.device_id1, flash.device_id2, flash.num_sectors, - flash.sector_size, flash.write_length, - (flash.num_sectors * flash.sector_size) >> 17, - (flash.num_sectors * flash.sector_size) >> 20, - read_status_register()); - - SPI_DEINIT(); - - return ret; -} - -#endif
Signed-off-by: Mike Frysinger vapier@gentoo.org --- arch/blackfin/include/asm/mach-bf527/anomaly.h | 196 ++++++++++++++++-------- arch/blackfin/include/asm/mach-bf533/anomaly.h | 111 +++++++++----- arch/blackfin/include/asm/mach-bf537/anomaly.h | 85 ++++++++--- arch/blackfin/include/asm/mach-bf548/anomaly.h | 96 +++++++++++-- arch/blackfin/include/asm/mach-bf561/anomaly.h | 132 ++++++++++------ 5 files changed, 437 insertions(+), 183 deletions(-)
diff --git a/arch/blackfin/include/asm/mach-bf527/anomaly.h b/arch/blackfin/include/asm/mach-bf527/anomaly.h index 0fd7e31..9358afa 100644 --- a/arch/blackfin/include/asm/mach-bf527/anomaly.h +++ b/arch/blackfin/include/asm/mach-bf527/anomaly.h @@ -1,19 +1,28 @@ /* - * File: include/asm-blackfin/mach-bf527/anomaly.h - * Bugs: Enter bugs at http://blackfin.uclinux.org/ + * DO NOT EDIT THIS FILE + * This file is under version control at + * svn://sources.blackfin.uclinux.org/toolchain/trunk/proc-defs/header-frags/ + * and can be replaced with that version at any time + * DO NOT EDIT THIS FILE * - * Copyright (C) 2004-2009 Analog Devices Inc. - * Licensed under the GPL-2 or later. + * Copyright 2004-2010 Analog Devices Inc. + * Licensed under the ADI BSD license. + * https://docs.blackfin.uclinux.org/doku.php?id=adi_bsd */
/* This file should be up to date with: - * - Revision B, 08/12/2008; ADSP-BF526 Blackfin Processor Anomaly List - * - Revision F, 03/03/2009; ADSP-BF527 Blackfin Processor Anomaly List + * - Revision E, 03/15/2010; ADSP-BF526 Blackfin Processor Anomaly List + * - Revision G, 08/25/2009; ADSP-BF527 Blackfin Processor Anomaly List */
#ifndef _MACH_ANOMALY_H_ #define _MACH_ANOMALY_H_
+/* We do not support old silicon - sorry */ +#if __SILICON_REVISION__ < 0 +# error will not work on BF526/BF527 silicon version +#endif + #if defined(__ADSPBF522__) || defined(__ADSPBF524__) || defined(__ADSPBF526__) # define ANOMALY_BF526 1 #else @@ -25,10 +34,14 @@ # define ANOMALY_BF527 0 #endif
-/* Multi-issue instruction with dsp32shiftimm in slot1 and P-reg store in slot 2 not supported */ +#define _ANOMALY_BF526(rev526) (ANOMALY_BF526 && __SILICON_REVISION__ rev526) +#define _ANOMALY_BF527(rev527) (ANOMALY_BF527 && __SILICON_REVISION__ rev527) +#define _ANOMALY_BF526_BF527(rev526, rev527) (_ANOMALY_BF526(rev526) || _ANOMALY_BF527(rev527)) + +/* Multi-Issue Instruction with dsp32shiftimm in slot1 and P-reg Store in slot2 Not Supported */ #define ANOMALY_05000074 (1) /* DMA_RUN Bit Is Not Valid after a Peripheral Receive Channel DMA Stops */ -#define ANOMALY_05000119 (1) /* note: brokenness is noted in documentation, not anomaly sheet */ +#define ANOMALY_05000119 (1) /* Rx.H Cannot Be Used to Access 16-bit System MMR Registers */ #define ANOMALY_05000122 (1) /* False Hardware Error from an Access in the Shadow of a Conditional Branch */ @@ -40,167 +53,226 @@ /* False Hardware Errors Caused by Fetches at the Boundary of Reserved Memory */ #define ANOMALY_05000310 (1) /* PPI Is Level-Sensitive on First Transfer In Single Frame Sync Modes */ -#define ANOMALY_05000313 (__SILICON_REVISION__ < 2) +#define ANOMALY_05000313 (_ANOMALY_BF526_BF527(< 1, < 2)) /* Incorrect Access of OTP_STATUS During otp_write() Function */ -#define ANOMALY_05000328 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) +#define ANOMALY_05000328 (_ANOMALY_BF527(< 2)) /* Host DMA Boot Modes Are Not Functional */ #define ANOMALY_05000330 (__SILICON_REVISION__ < 2) /* Disallowed Configuration Prevents Subsequent Allowed Configuration on Host DMA Port */ -#define ANOMALY_05000337 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) +#define ANOMALY_05000337 (_ANOMALY_BF527(< 2)) /* Ethernet MAC MDIO Reads Do Not Meet IEEE Specification */ -#define ANOMALY_05000341 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) +#define ANOMALY_05000341 (_ANOMALY_BF527(< 2)) /* TWI May Not Operate Correctly Under Certain Signal Termination Conditions */ -#define ANOMALY_05000342 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) +#define ANOMALY_05000342 (_ANOMALY_BF527(< 2)) /* USB Calibration Value Is Not Initialized */ -#define ANOMALY_05000346 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) +#define ANOMALY_05000346 (_ANOMALY_BF526_BF527(< 1, < 2)) /* USB Calibration Value to use */ #define ANOMALY_05000346_value 0xE510 /* Preboot Routine Incorrectly Alters Reset Value of USB Register */ -#define ANOMALY_05000347 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) +#define ANOMALY_05000347 (_ANOMALY_BF527(< 2)) /* Security Features Are Not Functional */ -#define ANOMALY_05000348 (ANOMALY_BF527 && __SILICON_REVISION__ < 1) +#define ANOMALY_05000348 (_ANOMALY_BF527(< 1)) /* bfrom_SysControl() Firmware Function Performs Improper System Reset */ -#define ANOMALY_05000353 (ANOMALY_BF526) +#define ANOMALY_05000353 (_ANOMALY_BF526(< 1)) /* Regulator Programming Blocked when Hibernate Wakeup Source Remains Active */ -#define ANOMALY_05000355 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) +#define ANOMALY_05000355 (_ANOMALY_BF527(< 2)) /* Serial Port (SPORT) Multichannel Transmit Failure when Channel 0 Is Disabled */ -#define ANOMALY_05000357 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) +#define ANOMALY_05000357 (_ANOMALY_BF527(< 2)) /* Incorrect Revision Number in DSPID Register */ -#define ANOMALY_05000364 (ANOMALY_BF527 && __SILICON_REVISION__ == 1) +#define ANOMALY_05000364 (_ANOMALY_BF527(== 1)) /* PPI Underflow Error Goes Undetected in ITU-R 656 Mode */ #define ANOMALY_05000366 (1) /* Incorrect Default CSEL Value in PLL_DIV */ -#define ANOMALY_05000368 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) +#define ANOMALY_05000368 (_ANOMALY_BF527(< 2)) /* Possible RETS Register Corruption when Subroutine Is under 5 Cycles in Duration */ -#define ANOMALY_05000371 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) +#define ANOMALY_05000371 (_ANOMALY_BF527(< 2)) /* Authentication Fails To Initiate */ -#define ANOMALY_05000376 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) +#define ANOMALY_05000376 (_ANOMALY_BF527(< 2)) /* Data Read From L3 Memory by USB DMA May be Corrupted */ -#define ANOMALY_05000380 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) +#define ANOMALY_05000380 (_ANOMALY_BF527(< 2)) /* 8-Bit NAND Flash Boot Mode Not Functional */ -#define ANOMALY_05000382 (__SILICON_REVISION__ < 2) +#define ANOMALY_05000382 (_ANOMALY_BF526_BF527(< 1, < 2)) /* Boot from OTP Memory Not Functional */ -#define ANOMALY_05000385 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) +#define ANOMALY_05000385 (_ANOMALY_BF527(< 2)) /* bfrom_SysControl() Firmware Routine Not Functional */ -#define ANOMALY_05000386 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) +#define ANOMALY_05000386 (_ANOMALY_BF527(< 2)) /* Programmable Preboot Settings Not Functional */ -#define ANOMALY_05000387 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) +#define ANOMALY_05000387 (_ANOMALY_BF527(< 2)) /* CRC32 Checksum Support Not Functional */ -#define ANOMALY_05000388 (__SILICON_REVISION__ < 2) +#define ANOMALY_05000388 (_ANOMALY_BF526_BF527(< 1, < 2)) /* Reset Vector Must Not Be in SDRAM Memory Space */ -#define ANOMALY_05000389 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) +#define ANOMALY_05000389 (_ANOMALY_BF527(< 2)) /* pTempCurrent Not Present in ADI_BOOT_DATA Structure */ -#define ANOMALY_05000392 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) +#define ANOMALY_05000392 (_ANOMALY_BF527(< 2)) /* Deprecated Value of dTempByteCount in ADI_BOOT_DATA Structure */ -#define ANOMALY_05000393 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) +#define ANOMALY_05000393 (_ANOMALY_BF527(< 2)) /* Log Buffer Not Functional */ -#define ANOMALY_05000394 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) +#define ANOMALY_05000394 (_ANOMALY_BF527(< 2)) /* Hook Routine Not Functional */ -#define ANOMALY_05000395 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) +#define ANOMALY_05000395 (_ANOMALY_BF527(< 2)) /* Header Indirect Bit Not Functional */ -#define ANOMALY_05000396 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) +#define ANOMALY_05000396 (_ANOMALY_BF527(< 2)) /* BK_ONES, BK_ZEROS, and BK_DATECODE Constants Not Functional */ -#define ANOMALY_05000397 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) +#define ANOMALY_05000397 (_ANOMALY_BF527(< 2)) /* SWRESET, DFRESET and WDRESET Bits in the SYSCR Register Not Functional */ -#define ANOMALY_05000398 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) +#define ANOMALY_05000398 (_ANOMALY_BF527(< 2)) /* BCODE_NOBOOT in BCODE Field of SYSCR Register Not Functional */ -#define ANOMALY_05000399 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) +#define ANOMALY_05000399 (_ANOMALY_BF527(< 2)) /* PPI Data Signals D0 and D8 do not Tristate After Disabling PPI */ -#define ANOMALY_05000401 (__SILICON_REVISION__ < 2) +#define ANOMALY_05000401 (_ANOMALY_BF526_BF527(< 1, < 2)) /* Level-Sensitive External GPIO Wakeups May Cause Indefinite Stall */ -#define ANOMALY_05000403 (__SILICON_REVISION__ < 2) +#define ANOMALY_05000403 (_ANOMALY_BF526_BF527(< 1, < 2)) /* Lockbox SESR Disallows Certain User Interrupts */ -#define ANOMALY_05000404 (__SILICON_REVISION__ < 2) +#define ANOMALY_05000404 (_ANOMALY_BF526_BF527(< 1, < 2)) /* Lockbox SESR Firmware Does Not Save/Restore Full Context */ #define ANOMALY_05000405 (1) /* Lockbox SESR Firmware Arguments Are Not Retained After First Initialization */ -#define ANOMALY_05000407 (__SILICON_REVISION__ < 2) +#define ANOMALY_05000407 (_ANOMALY_BF526_BF527(< 1, < 2)) /* Lockbox Firmware Memory Cleanup Routine Does not Clear Registers */ #define ANOMALY_05000408 (1) /* Lockbox firmware leaves MDMA0 channel enabled */ -#define ANOMALY_05000409 (__SILICON_REVISION__ < 2) +#define ANOMALY_05000409 (_ANOMALY_BF526_BF527(< 1, < 2)) /* Incorrect Default Internal Voltage Regulator Setting */ -#define ANOMALY_05000410 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) +#define ANOMALY_05000410 (_ANOMALY_BF527(< 2)) /* bfrom_SysControl() Firmware Function Cannot be Used to Enter Power Saving Modes */ -#define ANOMALY_05000411 (__SILICON_REVISION__ < 2) +#define ANOMALY_05000411 (_ANOMALY_BF526_BF527(< 1, < 2)) /* OTP_CHECK_FOR_PREV_WRITE Bit is Not Functional in bfrom_OtpWrite() API */ -#define ANOMALY_05000414 (__SILICON_REVISION__ < 2) +#define ANOMALY_05000414 (_ANOMALY_BF526_BF527(< 1, < 2)) /* DEB2_URGENT Bit Not Functional */ -#define ANOMALY_05000415 (__SILICON_REVISION__ < 2) +#define ANOMALY_05000415 (_ANOMALY_BF526_BF527(< 1, < 2)) /* Speculative Fetches Can Cause Undesired External FIFO Operations */ #define ANOMALY_05000416 (1) /* SPORT0 Ignores External TSCLK0 on PG14 When TMR6 is an Output */ -#define ANOMALY_05000417 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) +#define ANOMALY_05000417 (_ANOMALY_BF527(< 2)) /* PPI Timing Requirements tSFSPE and tHFSPE Do Not Meet Data Sheet Specifications */ -#define ANOMALY_05000418 (__SILICON_REVISION__ < 2) +#define ANOMALY_05000418 (_ANOMALY_BF526_BF527(< 1, < 2)) /* USB PLL_STABLE Bit May Not Accurately Reflect the USB PLL's Status */ -#define ANOMALY_05000420 (__SILICON_REVISION__ < 2) +#define ANOMALY_05000420 (_ANOMALY_BF526_BF527(< 1, < 2)) /* TWI Fall Time (Tof) May Violate the Minimum I2C Specification */ #define ANOMALY_05000421 (1) /* TWI Input Capacitance (Ci) May Violate the Maximum I2C Specification */ -#define ANOMALY_05000422 (ANOMALY_BF527 && __SILICON_REVISION__ > 1) +#define ANOMALY_05000422 (_ANOMALY_BF526_BF527(> 0, > 1)) /* Certain Ethernet Frames With Errors are Misclassified in RMII Mode */ -#define ANOMALY_05000423 (__SILICON_REVISION__ < 2) +#define ANOMALY_05000423 (_ANOMALY_BF526_BF527(< 1, < 2)) /* Internal Voltage Regulator Not Trimmed */ -#define ANOMALY_05000424 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) +#define ANOMALY_05000424 (_ANOMALY_BF527(< 2)) /* Multichannel SPORT Channel Misalignment Under Specific Configuration */ -#define ANOMALY_05000425 (__SILICON_REVISION__ < 2) +#define ANOMALY_05000425 (_ANOMALY_BF526_BF527(< 1, < 2)) /* Speculative Fetches of Indirect-Pointer Instructions Can Cause False Hardware Errors */ #define ANOMALY_05000426 (1) /* WB_EDGE Bit in NFC_IRQSTAT Incorrectly Reflects Buffer Status Instead of IRQ Status */ -#define ANOMALY_05000429 (__SILICON_REVISION__ < 2) +#define ANOMALY_05000429 (_ANOMALY_BF526_BF527(< 1, < 2)) /* Software System Reset Corrupts PLL_LOCKCNT Register */ -#define ANOMALY_05000430 (ANOMALY_BF527 && __SILICON_REVISION__ > 1) +#define ANOMALY_05000430 (_ANOMALY_BF527(> 1)) /* Incorrect Use of Stack in Lockbox Firmware During Authentication */ #define ANOMALY_05000431 (1) /* bfrom_SysControl() Does Not Clear SIC_IWR1 Before Executing PLL Programming Sequence */ -#define ANOMALY_05000432 (ANOMALY_BF526) +#define ANOMALY_05000432 (_ANOMALY_BF526(< 1)) +/* SW Breakpoints Ignored Upon Return From Lockbox Authentication */ +#define ANOMALY_05000434 (1) /* Certain SIC Registers are not Reset After Soft or Core Double Fault Reset */ -#define ANOMALY_05000435 ((ANOMALY_BF526 && __SILICON_REVISION__ < 1) || ANOMALY_BF527) +#define ANOMALY_05000435 (_ANOMALY_BF526_BF527(< 1, >= 0)) /* Preboot Cannot be Used to Alter the PLL_DIV Register */ -#define ANOMALY_05000439 (1) +#define ANOMALY_05000439 (_ANOMALY_BF526_BF527(< 1, >= 0)) /* bfrom_SysControl() Cannot be Used to Write the PLL_DIV Register */ -#define ANOMALY_05000440 (1) +#define ANOMALY_05000440 (_ANOMALY_BF526_BF527(< 1, >= 0)) /* OTP Write Accesses Not Supported */ -#define ANOMALY_05000442 (__SILICON_REVISION__ < 1) +#define ANOMALY_05000442 (_ANOMALY_BF527(< 1)) /* IFLUSH Instruction at End of Hardware Loop Causes Infinite Stall */ #define ANOMALY_05000443 (1) /* The WURESET Bit in the SYSCR Register is not Functional */ #define ANOMALY_05000445 (1) +/* USB DMA Mode 1 Short Packet Data Corruption */ +#define ANOMALY_05000450 (1) /* BCODE_QUICKBOOT, BCODE_ALLBOOT, and BCODE_FULLBOOT Settings in SYSCR Register Not Functional */ #define ANOMALY_05000451 (1) /* Incorrect Default Hysteresis Setting for RESET, NMI, and BMODE Signals */ -#define ANOMALY_05000452 (1) +#define ANOMALY_05000452 (_ANOMALY_BF526_BF527(< 1, >= 0)) /* USB Receive Interrupt Is Not Generated in DMA Mode 1 */ #define ANOMALY_05000456 (1) /* Host DMA Port Responds to Certain Bus Activity Without HOST_CE Assertion */ #define ANOMALY_05000457 (1) +/* USB DMA Mode 1 Failure When Multiple USB DMA Channels Are Concurrently Enabled */ +#define ANOMALY_05000460 (1) +/* False Hardware Error when RETI Points to Invalid Memory */ +#define ANOMALY_05000461 (1) +/* Synchronization Problem at Startup May Cause SPORT Transmit Channels to Misalign */ +#define ANOMALY_05000462 (1) +/* USB Rx DMA hang */ +#define ANOMALY_05000465 (1) +/* TxPktRdy Bit Not Set for Transmit Endpoint When Core and DMA Access USB Endpoint FIFOs Simultaneously */ +#define ANOMALY_05000466 (1) +/* Possible RX data corruption when control & data EP FIFOs are accessed via the core */ +#define ANOMALY_05000467 (1) +/* PLL Latches Incorrect Settings During Reset */ +#define ANOMALY_05000469 (1) +/* Incorrect Default MSEL Value in PLL_CTL */ +#define ANOMALY_05000472 (_ANOMALY_BF526(>= 0)) +/* Interrupted 32-Bit SPORT Data Register Access Results In Underflow */ +#define ANOMALY_05000473 (1) +/* Possible Lockup Condition whem Modifying PLL from External Memory */ +#define ANOMALY_05000475 (1) +/* TESTSET Instruction Cannot Be Interrupted */ +#define ANOMALY_05000477 (1) +/* Reads of ITEST_COMMAND and ITEST_DATA Registers Cause Cache Corruption */ +#define ANOMALY_05000481 (1) +/* Possible USB Data Corruption When Multiple Endpoints Are Accessed by the Core */ +#define ANOMALY_05000483 (1) +/* PLL_CTL Change Using bfrom_SysControl() Can Result in Processor Overclocking */ +#define ANOMALY_05000485 (_ANOMALY_BF526_BF527(< 2, < 3)) +/* IFLUSH sucks at life */ +#define ANOMALY_05000491 (1)
/* Anomalies that don't exist on this proc */ +#define ANOMALY_05000099 (0) +#define ANOMALY_05000120 (0) #define ANOMALY_05000125 (0) +#define ANOMALY_05000149 (0) #define ANOMALY_05000158 (0) #define ANOMALY_05000171 (0) +#define ANOMALY_05000179 (0) +#define ANOMALY_05000182 (0) #define ANOMALY_05000183 (0) +#define ANOMALY_05000189 (0) #define ANOMALY_05000198 (0) +#define ANOMALY_05000202 (0) +#define ANOMALY_05000215 (0) +#define ANOMALY_05000219 (0) +#define ANOMALY_05000220 (0) #define ANOMALY_05000227 (0) #define ANOMALY_05000230 (0) +#define ANOMALY_05000231 (0) +#define ANOMALY_05000233 (0) +#define ANOMALY_05000234 (0) #define ANOMALY_05000242 (0) #define ANOMALY_05000244 (0) +#define ANOMALY_05000248 (0) +#define ANOMALY_05000250 (0) +#define ANOMALY_05000257 (0) #define ANOMALY_05000261 (0) #define ANOMALY_05000263 (0) #define ANOMALY_05000266 (0) #define ANOMALY_05000273 (0) +#define ANOMALY_05000274 (0) #define ANOMALY_05000278 (0) +#define ANOMALY_05000281 (0) +#define ANOMALY_05000283 (0) #define ANOMALY_05000285 (0) +#define ANOMALY_05000287 (0) +#define ANOMALY_05000301 (0) #define ANOMALY_05000305 (0) #define ANOMALY_05000307 (0) #define ANOMALY_05000311 (0) #define ANOMALY_05000312 (0) +#define ANOMALY_05000315 (0) #define ANOMALY_05000323 (0) #define ANOMALY_05000362 (1) #define ANOMALY_05000363 (0) +#define ANOMALY_05000400 (0) +#define ANOMALY_05000402 (0) #define ANOMALY_05000412 (0) #define ANOMALY_05000447 (0) #define ANOMALY_05000448 (0) +#define ANOMALY_05000474 (0)
#endif diff --git a/arch/blackfin/include/asm/mach-bf533/anomaly.h b/arch/blackfin/include/asm/mach-bf533/anomaly.h index c98747f..78f8721 100644 --- a/arch/blackfin/include/asm/mach-bf533/anomaly.h +++ b/arch/blackfin/include/asm/mach-bf533/anomaly.h @@ -1,9 +1,13 @@ /* - * File: include/asm-blackfin/mach-bf533/anomaly.h - * Bugs: Enter bugs at http://blackfin.uclinux.org/ + * DO NOT EDIT THIS FILE + * This file is under version control at + * svn://sources.blackfin.uclinux.org/toolchain/trunk/proc-defs/header-frags/ + * and can be replaced with that version at any time + * DO NOT EDIT THIS FILE * - * Copyright (C) 2004-2009 Analog Devices Inc. - * Licensed under the GPL-2 or later. + * Copyright 2004-2010 Analog Devices Inc. + * Licensed under the ADI BSD license. + * https://docs.blackfin.uclinux.org/doku.php?id=adi_bsd */
/* This file should be up to date with: @@ -34,7 +38,7 @@ # define ANOMALY_BF533 0 #endif
-/* Multi-issue instruction with dsp32shiftimm in slot1 and P-reg store in slot 2 not supported */ +/* Multi-Issue Instruction with dsp32shiftimm in slot1 and P-reg Store in slot2 Not Supported */ #define ANOMALY_05000074 (1) /* UART Line Status Register (UART_LSR) Bits Are Not Updated at the Same Time */ #define ANOMALY_05000099 (__SILICON_REVISION__ < 5) @@ -46,7 +50,7 @@ #define ANOMALY_05000122 (1) /* Instruction DMA Can Cause Data Cache Fills to Fail (Boot Implications) */ #define ANOMALY_05000158 (__SILICON_REVISION__ < 5) -/* PPI Data Lengths Between 8 and 16 Do Not Zero Out Upper Bits */ +/* PPI Data Lengths between 8 and 16 Do Not Zero Out Upper Bits */ #define ANOMALY_05000166 (1) /* Turning SPORTs on while External Frame Sync Is Active May Corrupt Data */ #define ANOMALY_05000167 (1) @@ -56,13 +60,13 @@ #define ANOMALY_05000180 (1) /* Timer Pin Limitations for PPI TX Modes with External Frame Syncs */ #define ANOMALY_05000183 (__SILICON_REVISION__ < 4) -/* False Protection Exceptions */ +/* False Protection Exceptions when Speculative Fetch Is Cancelled */ #define ANOMALY_05000189 (__SILICON_REVISION__ < 4) /* False I/O Pin Interrupts on Edge-Sensitive Inputs When Polarity Setting Is Changed */ #define ANOMALY_05000193 (__SILICON_REVISION__ < 4) /* Restarting SPORT in Specific Modes May Cause Data Corruption */ #define ANOMALY_05000194 (__SILICON_REVISION__ < 4) -/* Failing MMR Accesses When Stalled by Preceding Memory Read */ +/* Failing MMR Accesses when Preceding Memory Read Stalls */ #define ANOMALY_05000198 (__SILICON_REVISION__ < 5) /* Current DMA Address Shows Wrong Value During Carry Fix */ #define ANOMALY_05000199 (__SILICON_REVISION__ < 4) @@ -74,7 +78,7 @@ #define ANOMALY_05000202 (__SILICON_REVISION__ < 5) /* Specific Sequence That Can Cause DMA Error or DMA Stopping */ #define ANOMALY_05000203 (__SILICON_REVISION__ < 4) -/* Incorrect data read with write-through cache and allocate cache lines on reads only mode */ +/* Incorrect Data Read with Writethrough "Allocate Cache Lines on Reads Only" Cache Mode */ #define ANOMALY_05000204 (__SILICON_REVISION__ < 4 && ANOMALY_BF533) /* Recovery from "Brown-Out" Condition */ #define ANOMALY_05000207 (__SILICON_REVISION__ < 4) @@ -106,7 +110,7 @@ #define ANOMALY_05000244 (__SILICON_REVISION__ < 5) /* False Hardware Error from an Access in the Shadow of a Conditional Branch */ #define ANOMALY_05000245 (1) -/* Data CPLBs Should Prevent Spurious Hardware Errors */ +/* Data CPLBs Should Prevent False Hardware Errors */ #define ANOMALY_05000246 (__SILICON_REVISION__ < 5) /* Incorrect Bit Shift of Data Word in Multichannel (TDM) Mode in Certain Conditions */ #define ANOMALY_05000250 (__SILICON_REVISION__ == 4) @@ -148,21 +152,21 @@ #define ANOMALY_05000277 (__SILICON_REVISION__ < 6) /* Disabling Peripherals with DMA Running May Cause DMA System Instability */ #define ANOMALY_05000278 (__SILICON_REVISION__ < 6) -/* False Hardware Error Exception When ISR Context Is Not Restored */ +/* False Hardware Error Exception when ISR Context Is Not Restored */ #define ANOMALY_05000281 (__SILICON_REVISION__ < 6) /* Memory DMA Corruption with 32-Bit Data and Traffic Control */ #define ANOMALY_05000282 (__SILICON_REVISION__ < 6) -/* System MMR Write Is Stalled Indefinitely When Killed in a Particular Stage */ +/* System MMR Write Is Stalled Indefinitely when Killed in a Particular Stage */ #define ANOMALY_05000283 (__SILICON_REVISION__ < 6) /* SPORTs May Receive Bad Data If FIFOs Fill Up */ #define ANOMALY_05000288 (__SILICON_REVISION__ < 6) /* Memory-To-Memory DMA Source/Destination Descriptors Must Be in Same Memory Space */ #define ANOMALY_05000301 (__SILICON_REVISION__ < 6) -/* SSYNCs After Writes To DMA MMR Registers May Not Be Handled Correctly */ +/* SSYNCs after Writes to DMA MMR Registers May Not Be Handled Correctly */ #define ANOMALY_05000302 (__SILICON_REVISION__ < 5) /* SPORT_HYS Bit in PLL_CTL Register Is Not Functional */ #define ANOMALY_05000305 (__SILICON_REVISION__ < 5) -/* New Feature: Additional PPI Frame Sync Sampling Options (Not Available On Older Silicon) */ +/* ALT_TIMING Bit in PPI_CONTROL Register Is Not Functional */ #define ANOMALY_05000306 (__SILICON_REVISION__ < 5) /* SCKELOW Bit Does Not Maintain State Through Hibernate */ #define ANOMALY_05000307 (1) /* note: brokenness is noted in documentation, not anomaly sheet */ @@ -170,11 +174,11 @@ #define ANOMALY_05000310 (1) /* Erroneous Flag (GPIO) Pin Operations under Specific Sequences */ #define ANOMALY_05000311 (__SILICON_REVISION__ < 6) -/* Errors When SSYNC, CSYNC, or Loads to LT, LB and LC Registers Are Interrupted */ +/* Errors when SSYNC, CSYNC, or Loads to LT, LB and LC Registers Are Interrupted */ #define ANOMALY_05000312 (__SILICON_REVISION__ < 6) /* PPI Is Level-Sensitive on First Transfer In Single Frame Sync Modes */ #define ANOMALY_05000313 (__SILICON_REVISION__ < 6) -/* Killed System MMR Write Completes Erroneously On Next System MMR Access */ +/* Killed System MMR Write Completes Erroneously on Next System MMR Access */ #define ANOMALY_05000315 (__SILICON_REVISION__ < 6) /* Internal Voltage Regulator Values of 1.05V, 1.10V and 1.15V Not Allowed for LQFP Packages */ #define ANOMALY_05000319 ((ANOMALY_BF531 || ANOMALY_BF532) && __SILICON_REVISION__ < 6) @@ -200,6 +204,18 @@ #define ANOMALY_05000426 (1) /* IFLUSH Instruction at End of Hardware Loop Causes Infinite Stall */ #define ANOMALY_05000443 (1) +/* False Hardware Error when RETI Points to Invalid Memory */ +#define ANOMALY_05000461 (1) +/* Interrupted 32-Bit SPORT Data Register Access Results In Underflow */ +#define ANOMALY_05000473 (1) +/* Possible Lockup Condition whem Modifying PLL from External Memory */ +#define ANOMALY_05000475 (1) +/* TESTSET Instruction Cannot Be Interrupted */ +#define ANOMALY_05000477 (1) +/* Reads of ITEST_COMMAND and ITEST_DATA Registers Cause Cache Corruption */ +#define ANOMALY_05000481 (1) +/* IFLUSH sucks at life */ +#define ANOMALY_05000491 (1)
/* These anomalies have been "phased" out of analog.com anomaly sheets and are * here to show running on older silicon just isn't feasible. @@ -213,17 +229,17 @@ #define ANOMALY_05000070 (__SILICON_REVISION__ < 2) /* Writing FIO_DIR can corrupt a programmable flag's data */ #define ANOMALY_05000079 (__SILICON_REVISION__ < 2) -/* Timer Auto-Baud Mode requires the UART clock to be enabled */ +/* Timer Auto-Baud Mode requires the UART clock to be enabled. */ #define ANOMALY_05000086 (__SILICON_REVISION__ < 2) /* Internal Clocking Modes on SPORT0 not supported */ #define ANOMALY_05000088 (__SILICON_REVISION__ < 2) /* Internal voltage regulator does not wake up from an RTC wakeup */ #define ANOMALY_05000092 (__SILICON_REVISION__ < 2) -/* The IFLUSH instruction must be preceded by a CSYNC instruction */ +/* The IFLUSH Instruction Must Be Preceded by a CSYNC Instruction */ #define ANOMALY_05000093 (__SILICON_REVISION__ < 2) -/* Vectoring to an instruction that is presently being filled into the instruction cache may cause erroneous behavior */ +/* Vectoring to instruction that is being filled into the i-cache may cause erroneous behavior */ #define ANOMALY_05000095 (__SILICON_REVISION__ < 2) -/* PREFETCH, FLUSH, and FLUSHINV must be followed by a CSYNC */ +/* PREFETCH, FLUSH, and FLUSHINV Instructions Must Be Followed by a CSYNC Instruction */ #define ANOMALY_05000096 (__SILICON_REVISION__ < 2) /* Performance Monitor 0 and 1 are swapped when monitoring memory events */ #define ANOMALY_05000097 (__SILICON_REVISION__ < 2) @@ -233,45 +249,45 @@ #define ANOMALY_05000100 (__SILICON_REVISION__ < 2) /* Reading X_MODIFY or Y_MODIFY while DMA channel is active */ #define ANOMALY_05000101 (__SILICON_REVISION__ < 2) -/* Descriptor-based MemDMA may lock up with 32-bit transfers or if transfers span 64KB buffers */ +/* Descriptor MemDMA may lock up with 32-bit transfers or if transfers span 64KB buffers */ #define ANOMALY_05000102 (__SILICON_REVISION__ < 2) -/* Incorrect value written to the cycle counters */ +/* Incorrect Value Written to the Cycle Counters */ #define ANOMALY_05000103 (__SILICON_REVISION__ < 2) -/* Stores to L1 Data memory incorrect when a specific sequence is followed */ +/* Stores to L1 Data Memory Incorrect when a Specific Sequence Is Followed */ #define ANOMALY_05000104 (__SILICON_REVISION__ < 2) /* Programmable Flag (PF3) functionality not supported in all PPI modes */ #define ANOMALY_05000106 (__SILICON_REVISION__ < 2) /* Data store can be lost when targeting a cache line fill */ #define ANOMALY_05000107 (__SILICON_REVISION__ < 2) -/* Reserved bits in SYSCFG register not set at power on */ +/* Reserved Bits in SYSCFG Register Not Set at Power-On */ #define ANOMALY_05000109 (__SILICON_REVISION__ < 3) /* Infinite Core Stall */ #define ANOMALY_05000114 (__SILICON_REVISION__ < 2) -/* PPI_FSx may glitch when generated by the on chip Timers */ +/* PPI_FSx may glitch when generated by the on chip Timers. */ #define ANOMALY_05000115 (__SILICON_REVISION__ < 2) -/* Trace Buffers may record discontinuities into emulation mode and/or exception, NMI, reset handlers */ +/* Trace Buffers May Contain Errors in Emulation Mode and/or Exception, NMI, Reset Handlers */ #define ANOMALY_05000116 (__SILICON_REVISION__ < 3) /* DTEST registers allow access to Data Cache when DTEST_COMMAND< 14 >= 0 */ #define ANOMALY_05000117 (__SILICON_REVISION__ < 2) /* Booting from an 8-bit or 24-bit Addressable SPI device is not supported */ #define ANOMALY_05000118 (__SILICON_REVISION__ < 2) -/* DTEST_COMMAND initiated memory access may be incorrect if data cache or DMA is active */ +/* DTEST_COMMAND Initiated Memory Access May Be Incorrect If Data Cache or DMA Is Active */ #define ANOMALY_05000123 (__SILICON_REVISION__ < 3) /* DMA Lock-up at CCLK to SCLK ratios of 4:1, 2:1, or 1:1 */ #define ANOMALY_05000124 (__SILICON_REVISION__ < 3) -/* Erroneous exception when enabling cache */ +/* Erroneous Exception when Enabling Cache */ #define ANOMALY_05000125 (__SILICON_REVISION__ < 3) /* SPI clock polarity and phase bits incorrect during booting */ #define ANOMALY_05000126 (__SILICON_REVISION__ < 3) -/* DMEM_CONTROL is not set on Reset */ +/* DMEM_CONTROL<12> Is Not Set on Reset */ #define ANOMALY_05000137 (__SILICON_REVISION__ < 3) /* SPI boot will not complete if there is a zero fill block in the loader file */ #define ANOMALY_05000138 (__SILICON_REVISION__ == 2) -/* Timerx_Config must be set for using the PPI in GP output mode with internal Frame Syncs */ +/* TIMERx_CONFIG[5] must be set for PPI in GP output mode with internal Frame Syncs */ #define ANOMALY_05000139 (__SILICON_REVISION__ < 2) /* Allowing the SPORT RX FIFO to fill will cause an overflow */ #define ANOMALY_05000140 (__SILICON_REVISION__ < 3) -/* An Infinite Stall occurs with a particular sequence of consecutive dual dag events */ +/* Infinite Stall may occur with a particular sequence of consecutive dual dag events */ #define ANOMALY_05000141 (__SILICON_REVISION__ < 3) /* Interrupts may be lost when a programmable input flag is configured to be edge sensitive */ #define ANOMALY_05000142 (__SILICON_REVISION__ < 3) @@ -285,7 +301,7 @@ #define ANOMALY_05000146 (__SILICON_REVISION__ < 3) /* Source MDMA descriptor may stop with a DMA Error near beginning of descriptor fetch */ #define ANOMALY_05000147 (__SILICON_REVISION__ < 3) -/* When booting from a 16-bit asynchronous memory device, the upper 8-bits of each word must be 0x00 */ +/* When booting from 16-bit asynchronous memory, the upper 8 bits of each word must be 0x00 */ #define ANOMALY_05000148 (__SILICON_REVISION__ < 3) /* Frame Delay in SPORT Multichannel Mode */ #define ANOMALY_05000153 (__SILICON_REVISION__ < 3) @@ -293,13 +309,13 @@ #define ANOMALY_05000154 (__SILICON_REVISION__ < 3) /* Timer1 can not be used for PWMOUT mode when a certain PPI mode is in use */ #define ANOMALY_05000155 (__SILICON_REVISION__ < 3) -/* Killed 32-bit MMR write leads to next system MMR access thinking it should be 32-bit */ +/* Killed 32-Bit MMR Write Leads to Next System MMR Access Thinking It Should Be 32-Bit */ #define ANOMALY_05000157 (__SILICON_REVISION__ < 3) -/* SPORT transmit data is not gated by external frame sync in certain conditions */ +/* SPORT Transmit Data Is Not Gated by External Frame Sync in Certain Conditions */ #define ANOMALY_05000163 (__SILICON_REVISION__ < 3) -/* SDRAM auto-refresh and subsequent Power Ups */ +/* Undefined Behavior when Power-Up Sequence Is Issued to SDRAM during Auto-Refresh */ #define ANOMALY_05000168 (__SILICON_REVISION__ < 3) -/* DATA CPLB page miss can result in lost write-through cache data writes */ +/* DATA CPLB Page Miss Can Result in Lost Write-Through Data Cache Writes */ #define ANOMALY_05000169 (__SILICON_REVISION__ < 3) /* DMA vs Core accesses to external memory */ #define ANOMALY_05000173 (__SILICON_REVISION__ < 3) @@ -307,32 +323,47 @@ #define ANOMALY_05000174 (__SILICON_REVISION__ < 3) /* Overlapping Sequencer and Memory Stalls */ #define ANOMALY_05000175 (__SILICON_REVISION__ < 3) -/* Multiplication of (-1) by (-1) followed by an accumulator saturation */ +/* Overflow Bit Asserted when Multiplication of -1 by -1 Followed by Accumulator Saturation */ #define ANOMALY_05000176 (__SILICON_REVISION__ < 3) -/* Disabling the PPI resets the PPI configuration registers */ +/* Disabling the PPI Resets the PPI Configuration Registers */ #define ANOMALY_05000181 (__SILICON_REVISION__ < 3) -/* PPI TX Mode with 2 External Frame Syncs */ +/* Early PPI Transmit when FS1 Asserts before FS2 in TX Mode with 2 External Frame Syncs */ #define ANOMALY_05000185 (__SILICON_REVISION__ < 3) /* PPI does not invert the Driving PPICLK edge in Transmit Modes */ #define ANOMALY_05000191 (__SILICON_REVISION__ < 3) -/* In PPI Transmit Modes with External Frame Syncs POLC */ +/* In PPI Transmit Modes with External Frame Syncs POLC bit must be set to 1 */ #define ANOMALY_05000192 (__SILICON_REVISION__ < 3) /* Internal Voltage Regulator may not start up */ #define ANOMALY_05000206 (__SILICON_REVISION__ < 3)
/* Anomalies that don't exist on this proc */ +#define ANOMALY_05000120 (0) +#define ANOMALY_05000149 (0) #define ANOMALY_05000171 (0) +#define ANOMALY_05000182 (0) +#define ANOMALY_05000220 (0) +#define ANOMALY_05000248 (0) #define ANOMALY_05000266 (0) +#define ANOMALY_05000274 (0) +#define ANOMALY_05000287 (0) #define ANOMALY_05000323 (0) #define ANOMALY_05000353 (1) #define ANOMALY_05000362 (1) +#define ANOMALY_05000364 (0) #define ANOMALY_05000380 (0) #define ANOMALY_05000386 (1) +#define ANOMALY_05000389 (0) #define ANOMALY_05000412 (0) #define ANOMALY_05000430 (0) #define ANOMALY_05000432 (0) #define ANOMALY_05000435 (0) #define ANOMALY_05000447 (0) #define ANOMALY_05000448 (0) +#define ANOMALY_05000456 (0) +#define ANOMALY_05000450 (0) +#define ANOMALY_05000465 (0) +#define ANOMALY_05000467 (0) +#define ANOMALY_05000474 (0) +#define ANOMALY_05000485 (0)
#endif diff --git a/arch/blackfin/include/asm/mach-bf537/anomaly.h b/arch/blackfin/include/asm/mach-bf537/anomaly.h index b7f1a3f..43df6af 100644 --- a/arch/blackfin/include/asm/mach-bf537/anomaly.h +++ b/arch/blackfin/include/asm/mach-bf537/anomaly.h @@ -1,9 +1,13 @@ /* - * File: include/asm-blackfin/mach-bf537/anomaly.h - * Bugs: Enter bugs at http://blackfin.uclinux.org/ + * DO NOT EDIT THIS FILE + * This file is under version control at + * svn://sources.blackfin.uclinux.org/toolchain/trunk/proc-defs/header-frags/ + * and can be replaced with that version at any time + * DO NOT EDIT THIS FILE * - * Copyright (C) 2004-2009 Analog Devices Inc. - * Licensed under the GPL-2 or later. + * Copyright 2004-2010 Analog Devices Inc. + * Licensed under the ADI BSD license. + * https://docs.blackfin.uclinux.org/doku.php?id=adi_bsd */
/* This file should be up to date with: @@ -34,13 +38,13 @@ # define ANOMALY_BF537 0 #endif
-/* Multi-issue instruction with dsp32shiftimm in slot1 and P-reg store in slot 2 not supported */ +/* Multi-Issue Instruction with dsp32shiftimm in slot1 and P-reg Store in slot2 Not Supported */ #define ANOMALY_05000074 (1) /* DMA_RUN Bit Is Not Valid after a Peripheral Receive Channel DMA Stops */ #define ANOMALY_05000119 (1) /* Rx.H Cannot Be Used to Access 16-bit System MMR Registers */ #define ANOMALY_05000122 (1) -/* Killed 32-bit MMR write leads to next system MMR access thinking it should be 32-bit */ +/* Killed 32-Bit MMR Write Leads to Next System MMR Access Thinking It Should Be 32-Bit */ #define ANOMALY_05000157 (__SILICON_REVISION__ < 2) /* PPI_DELAY Not Functional in PPI Modes with 0 Frame Syncs */ #define ANOMALY_05000180 (1) @@ -50,11 +54,11 @@ #define ANOMALY_05000244 (__SILICON_REVISION__ < 3) /* False Hardware Error from an Access in the Shadow of a Conditional Branch */ #define ANOMALY_05000245 (1) -/* CLKIN Buffer Output Enable Reset Behavior Is Changed */ +/* Buffered CLKIN Output Is Disabled by Default */ #define ANOMALY_05000247 (1) /* Incorrect Bit Shift of Data Word in Multichannel (TDM) Mode in Certain Conditions */ #define ANOMALY_05000250 (__SILICON_REVISION__ < 3) -/* EMAC Tx DMA error after an early frame abort */ +/* EMAC TX DMA Error After an Early Frame Abort */ #define ANOMALY_05000252 (__SILICON_REVISION__ < 3) /* Maximum External Clock Speed for Timers */ #define ANOMALY_05000253 (__SILICON_REVISION__ < 3) @@ -62,7 +66,7 @@ #define ANOMALY_05000254 (__SILICON_REVISION__ > 2) /* Entering Hibernate State with RTC Seconds Interrupt Not Functional */ #define ANOMALY_05000255 (__SILICON_REVISION__ < 3) -/* EMAC MDIO input latched on wrong MDC edge */ +/* EMAC MDIO Input Latched on Wrong MDC Edge */ #define ANOMALY_05000256 (__SILICON_REVISION__ < 3) /* Interrupt/Exception During Short Hardware Loop May Cause Bad Instruction Fetches */ #define ANOMALY_05000257 (__SILICON_REVISION__ < 3) @@ -80,7 +84,7 @@ #define ANOMALY_05000264 (__SILICON_REVISION__ < 3) /* Sensitivity To Noise with Slow Input Edge Rates on External SPORT TX and RX Clocks */ #define ANOMALY_05000265 (1) -/* Memory DMA error when peripheral DMA is running with non-zero DEB_TRAFFIC_PERIOD */ +/* Memory DMA Error when Peripheral DMA Is Running with Non-Zero DEB_TRAFFIC_PERIOD */ #define ANOMALY_05000268 (__SILICON_REVISION__ < 3) /* High I/O Activity Causes Output Voltage of Internal Voltage Regulator (Vddint) to Decrease */ #define ANOMALY_05000270 (__SILICON_REVISION__ < 3) @@ -92,15 +96,15 @@ #define ANOMALY_05000277 (__SILICON_REVISION__ < 3) /* Disabling Peripherals with DMA Running May Cause DMA System Instability */ #define ANOMALY_05000278 (((ANOMALY_BF536 || ANOMALY_BF537) && __SILICON_REVISION__ < 3) || (ANOMALY_BF534 && __SILICON_REVISION__ < 2)) -/* SPI Master boot mode does not work well with Atmel Data flash devices */ +/* SPI Master Boot Mode Does Not Work Well with Atmel Data Flash Devices */ #define ANOMALY_05000280 (1) -/* False Hardware Error Exception When ISR Context Is Not Restored */ +/* False Hardware Error Exception when ISR Context Is Not Restored */ #define ANOMALY_05000281 (__SILICON_REVISION__ < 3) /* Memory DMA Corruption with 32-Bit Data and Traffic Control */ #define ANOMALY_05000282 (__SILICON_REVISION__ < 3) -/* System MMR Write Is Stalled Indefinitely When Killed in a Particular Stage */ +/* System MMR Write Is Stalled Indefinitely when Killed in a Particular Stage */ #define ANOMALY_05000283 (__SILICON_REVISION__ < 3) -/* New Feature: EMAC TX DMA Word Alignment (Not Available On Older Silicon) */ +/* TXDWA Bit in EMAC_SYSCTL Register Is Not Functional */ #define ANOMALY_05000285 (__SILICON_REVISION__ < 3) /* SPORTs May Receive Bad Data If FIFOs Fill Up */ #define ANOMALY_05000288 (__SILICON_REVISION__ < 3) @@ -112,25 +116,25 @@ #define ANOMALY_05000305 (__SILICON_REVISION__ < 3) /* SCKELOW Bit Does Not Maintain State Through Hibernate */ #define ANOMALY_05000307 (__SILICON_REVISION__ < 3) -/* Writing UART_THR while UART clock is disabled sends erroneous start bit */ +/* Writing UART_THR While UART Clock Is Disabled Sends Erroneous Start Bit */ #define ANOMALY_05000309 (__SILICON_REVISION__ < 3) /* False Hardware Errors Caused by Fetches at the Boundary of Reserved Memory */ #define ANOMALY_05000310 (1) -/* Errors When SSYNC, CSYNC, or Loads to LT, LB and LC Registers Are Interrupted */ +/* Errors when SSYNC, CSYNC, or Loads to LT, LB and LC Registers Are Interrupted */ #define ANOMALY_05000312 (1) /* PPI Is Level-Sensitive on First Transfer In Single Frame Sync Modes */ #define ANOMALY_05000313 (1) -/* Killed System MMR Write Completes Erroneously On Next System MMR Access */ +/* Killed System MMR Write Completes Erroneously on Next System MMR Access */ #define ANOMALY_05000315 (__SILICON_REVISION__ < 3) -/* EMAC RMII mode: collisions occur in Full Duplex mode */ +/* EMAC RMII Mode: Collisions Occur in Full Duplex Mode */ #define ANOMALY_05000316 (__SILICON_REVISION__ < 3) -/* EMAC RMII mode: TX frames in half duplex fail with status No Carrier */ +/* EMAC RMII Mode: TX Frames in Half Duplex Fail with Status "No Carrier" */ #define ANOMALY_05000321 (__SILICON_REVISION__ < 3) -/* EMAC RMII mode at 10-Base-T speed: RX frames not received properly */ +/* EMAC RMII Mode at 10-Base-T Speed: RX Frames Not Received Properly */ #define ANOMALY_05000322 (1) /* Ethernet MAC MDIO Reads Do Not Meet IEEE Specification */ #define ANOMALY_05000341 (__SILICON_REVISION__ >= 3) -/* New Feature: UART Remains Enabled after UART Boot */ +/* UART Gets Disabled after UART Boot */ #define ANOMALY_05000350 (__SILICON_REVISION__ >= 3) /* Regulator Programming Blocked when Hibernate Wakeup Source Remains Active */ #define ANOMALY_05000355 (1) @@ -143,7 +147,7 @@ /* Possible RETS Register Corruption when Subroutine Is under 5 Cycles in Duration */ #define ANOMALY_05000371 (1) /* SSYNC Stalls Processor when Executed from Non-Cacheable Memory */ -#define ANOMALY_05000402 (__SILICON_REVISION__ >= 5) +#define ANOMALY_05000402 (__SILICON_REVISION__ == 2) /* Level-Sensitive External GPIO Wakeups May Cause Indefinite Stall */ #define ANOMALY_05000403 (1) /* Speculative Fetches Can Cause Undesired External FIFO Operations */ @@ -154,29 +158,66 @@ #define ANOMALY_05000426 (1) /* IFLUSH Instruction at End of Hardware Loop Causes Infinite Stall */ #define ANOMALY_05000443 (1) +/* False Hardware Error when RETI Points to Invalid Memory */ +#define ANOMALY_05000461 (1) +/* Interrupted 32-Bit SPORT Data Register Access Results In Underflow */ +#define ANOMALY_05000473 (1) +/* Possible Lockup Condition whem Modifying PLL from External Memory */ +#define ANOMALY_05000475 (1) +/* TESTSET Instruction Cannot Be Interrupted */ +#define ANOMALY_05000477 (1) +/* Reads of ITEST_COMMAND and ITEST_DATA Registers Cause Cache Corruption */ +#define ANOMALY_05000481 (1) +/* IFLUSH sucks at life */ +#define ANOMALY_05000491 (1)
/* Anomalies that don't exist on this proc */ +#define ANOMALY_05000099 (0) +#define ANOMALY_05000120 (0) #define ANOMALY_05000125 (0) +#define ANOMALY_05000149 (0) #define ANOMALY_05000158 (0) #define ANOMALY_05000171 (0) +#define ANOMALY_05000179 (0) +#define ANOMALY_05000182 (0) #define ANOMALY_05000183 (0) +#define ANOMALY_05000189 (0) #define ANOMALY_05000198 (0) +#define ANOMALY_05000202 (0) +#define ANOMALY_05000215 (0) +#define ANOMALY_05000219 (0) +#define ANOMALY_05000220 (0) #define ANOMALY_05000227 (0) #define ANOMALY_05000230 (0) +#define ANOMALY_05000231 (0) +#define ANOMALY_05000233 (0) +#define ANOMALY_05000234 (0) #define ANOMALY_05000242 (0) +#define ANOMALY_05000248 (0) #define ANOMALY_05000266 (0) +#define ANOMALY_05000274 (0) +#define ANOMALY_05000287 (0) #define ANOMALY_05000311 (0) #define ANOMALY_05000323 (0) #define ANOMALY_05000353 (1) #define ANOMALY_05000362 (1) #define ANOMALY_05000363 (0) +#define ANOMALY_05000364 (0) #define ANOMALY_05000380 (0) #define ANOMALY_05000386 (1) +#define ANOMALY_05000389 (0) +#define ANOMALY_05000400 (0) #define ANOMALY_05000412 (0) #define ANOMALY_05000430 (0) #define ANOMALY_05000432 (0) #define ANOMALY_05000435 (0) #define ANOMALY_05000447 (0) #define ANOMALY_05000448 (0) +#define ANOMALY_05000456 (0) +#define ANOMALY_05000450 (0) +#define ANOMALY_05000465 (0) +#define ANOMALY_05000467 (0) +#define ANOMALY_05000474 (0) +#define ANOMALY_05000485 (0)
#endif diff --git a/arch/blackfin/include/asm/mach-bf548/anomaly.h b/arch/blackfin/include/asm/mach-bf548/anomaly.h index 192dd67..7bda09c 100644 --- a/arch/blackfin/include/asm/mach-bf548/anomaly.h +++ b/arch/blackfin/include/asm/mach-bf548/anomaly.h @@ -1,41 +1,54 @@ /* - * File: include/asm-blackfin/mach-bf548/anomaly.h - * Bugs: Enter bugs at http://blackfin.uclinux.org/ + * DO NOT EDIT THIS FILE + * This file is under version control at + * svn://sources.blackfin.uclinux.org/toolchain/trunk/proc-defs/header-frags/ + * and can be replaced with that version at any time + * DO NOT EDIT THIS FILE * - * Copyright (C) 2004-2009 Analog Devices Inc. - * Licensed under the GPL-2 or later. + * Copyright 2004-2010 Analog Devices Inc. + * Licensed under the ADI BSD license. + * https://docs.blackfin.uclinux.org/doku.php?id=adi_bsd */
/* This file should be up to date with: - * - Revision H, 01/16/2009; ADSP-BF542/BF544/BF547/BF548/BF549 Blackfin Processor Anomaly List + * - Revision I, 07/23/2009; ADSP-BF542/BF544/BF547/BF548/BF549 Blackfin Processor Anomaly List */
-/* Multi-issue instruction with dsp32shiftimm in slot1 and P-reg store in slot 2 not supported */ +/* We do not support 0.0 or 0.1 silicon - sorry */ +/* XXX: let u-boot slide +#if __SILICON_REVISION__ < 2 +# error will not work on BF548 silicon version 0.0, or 0.1 +#endif +*/ + +/* Multi-Issue Instruction with dsp32shiftimm in slot1 and P-reg Store in slot2 Not Supported */ #define ANOMALY_05000074 (1) /* DMA_RUN Bit Is Not Valid after a Peripheral Receive Channel DMA Stops */ #define ANOMALY_05000119 (1) /* Rx.H Cannot Be Used to Access 16-bit System MMR Registers */ #define ANOMALY_05000122 (1) +/* Data Corruption/Core Hang with L2/L3 Configured in Writeback Cache Mode */ +#define ANOMALY_05000220 (1) /* False Hardware Error from an Access in the Shadow of a Conditional Branch */ #define ANOMALY_05000245 (1) /* Sensitivity To Noise with Slow Input Edge Rates on External SPORT TX and RX Clocks */ #define ANOMALY_05000265 (1) /* Certain Data Cache Writethrough Modes Fail for Vddint <= 0.9V */ #define ANOMALY_05000272 (1) -/* False Hardware Error Exception When ISR Context Is Not Restored */ +/* False Hardware Error Exception when ISR Context Is Not Restored */ #define ANOMALY_05000281 (__SILICON_REVISION__ < 1) /* SSYNCs After Writes To CAN/DMA MMR Registers Are Not Always Handled Correctly */ #define ANOMALY_05000304 (__SILICON_REVISION__ < 1) /* False Hardware Errors Caused by Fetches at the Boundary of Reserved Memory */ #define ANOMALY_05000310 (1) -/* Errors When SSYNC, CSYNC, or Loads to LT, LB and LC Registers Are Interrupted */ +/* Errors when SSYNC, CSYNC, or Loads to LT, LB and LC Registers Are Interrupted */ #define ANOMALY_05000312 (__SILICON_REVISION__ < 1) /* TWI Slave Boot Mode Is Not Functional */ #define ANOMALY_05000324 (__SILICON_REVISION__ < 1) -/* External FIFO Boot Mode Is Not Functional */ +/* FIFO Boot Mode Not Functional */ #define ANOMALY_05000325 (__SILICON_REVISION__ < 2) /* Data Lost When Core and DMA Accesses Are Made to the USB FIFO Simultaneously */ #define ANOMALY_05000327 (__SILICON_REVISION__ < 1) @@ -157,6 +170,8 @@ #define ANOMALY_05000430 (__SILICON_REVISION__ >= 2) /* Incorrect Use of Stack in Lockbox Firmware During Authentication */ #define ANOMALY_05000431 (__SILICON_REVISION__ < 3) +/* SW Breakpoints Ignored Upon Return From Lockbox Authentication */ +#define ANOMALY_05000434 (1) /* OTP Write Accesses Not Supported */ #define ANOMALY_05000442 (__SILICON_REVISION__ < 1) /* IFLUSH Instruction at End of Hardware Loop Causes Infinite Stall */ @@ -170,32 +185,93 @@ /* Reduced Timing Margins on DDR Output Setup and Hold (tDS and tDH) */ #define ANOMALY_05000449 (__SILICON_REVISION__ == 1) /* USB DMA Mode 1 Short Packet Data Corruption */ -#define ANOMALY_05000450 (1 +#define ANOMALY_05000450 (1) +/* Incorrect Default Hysteresis Setting for RESET, NMI, and BMODE Signals */ +#define ANOMALY_05000452 (__SILICON_REVISION__ < 1) +/* USB Receive Interrupt Is Not Generated in DMA Mode 1 */ +#define ANOMALY_05000456 (1) +/* Host DMA Port Responds to Certain Bus Activity Without HOST_CE Assertion */ +#define ANOMALY_05000457 (1) +/* USB DMA Mode 1 Failure When Multiple USB DMA Channels Are Concurrently Enabled */ +#define ANOMALY_05000460 (1) +/* False Hardware Error when RETI Points to Invalid Memory */ +#define ANOMALY_05000461 (1) +/* Synchronization Problem at Startup May Cause SPORT Transmit Channels to Misalign */ +#define ANOMALY_05000462 (1) +/* USB DMA RX Data Corruption */ +#define ANOMALY_05000463 (1) +/* USB TX DMA Hang */ +#define ANOMALY_05000464 (1) +/* USB Rx DMA hang */ +#define ANOMALY_05000465 (1) +/* TxPktRdy Bit Not Set for Transmit Endpoint When Core and DMA Access USB Endpoint FIFOs Simultaneously */ +#define ANOMALY_05000466 (1) +/* Possible RX data corruption when control & data EP FIFOs are accessed via the core */ +#define ANOMALY_05000467 (1) +/* Interrupted 32-Bit SPORT Data Register Access Results In Underflow */ +#define ANOMALY_05000473 (1) +/* Access to DDR-SDRAM causes system hang under certain PLL/VR settings */ +#define ANOMALY_05000474 (1) +/* TESTSET Instruction Cannot Be Interrupted */ +#define ANOMALY_05000477 (1) +/* Reads of ITEST_COMMAND and ITEST_DATA Registers Cause Cache Corruption */ +#define ANOMALY_05000481 (1) +/* Possible USB Data Corruption When Multiple Endpoints Are Accessed by the Core */ +#define ANOMALY_05000483 (1) +/* PLL_CTL Change Using bfrom_SysControl() Can Result in Processor Overclocking */ +#define ANOMALY_05000485 (__SILICON_REVISION__ >= 2) +/* IFLUSH sucks at life */ +#define ANOMALY_05000491 (1)
/* Anomalies that don't exist on this proc */ +#define ANOMALY_05000099 (0) +#define ANOMALY_05000120 (0) #define ANOMALY_05000125 (0) +#define ANOMALY_05000149 (0) #define ANOMALY_05000158 (0) #define ANOMALY_05000171 (0) +#define ANOMALY_05000179 (0) +#define ANOMALY_05000182 (0) #define ANOMALY_05000183 (0) +#define ANOMALY_05000189 (0) #define ANOMALY_05000198 (0) +#define ANOMALY_05000202 (0) +#define ANOMALY_05000215 (0) +#define ANOMALY_05000219 (0) #define ANOMALY_05000227 (0) #define ANOMALY_05000230 (0) +#define ANOMALY_05000231 (0) +#define ANOMALY_05000233 (0) +#define ANOMALY_05000234 (0) #define ANOMALY_05000242 (0) #define ANOMALY_05000244 (0) +#define ANOMALY_05000248 (0) +#define ANOMALY_05000250 (0) +#define ANOMALY_05000254 (0) +#define ANOMALY_05000257 (0) #define ANOMALY_05000261 (0) #define ANOMALY_05000263 (0) #define ANOMALY_05000266 (0) #define ANOMALY_05000273 (0) +#define ANOMALY_05000274 (0) #define ANOMALY_05000278 (0) +#define ANOMALY_05000283 (0) +#define ANOMALY_05000287 (0) +#define ANOMALY_05000301 (0) #define ANOMALY_05000305 (0) #define ANOMALY_05000307 (0) #define ANOMALY_05000311 (0) +#define ANOMALY_05000315 (0) #define ANOMALY_05000323 (0) #define ANOMALY_05000362 (1) #define ANOMALY_05000363 (0) +#define ANOMALY_05000364 (0) #define ANOMALY_05000380 (0) +#define ANOMALY_05000400 (0) +#define ANOMALY_05000402 (0) #define ANOMALY_05000412 (0) #define ANOMALY_05000432 (0) #define ANOMALY_05000435 (0) +#define ANOMALY_05000475 (0)
#endif diff --git a/arch/blackfin/include/asm/mach-bf561/anomaly.h b/arch/blackfin/include/asm/mach-bf561/anomaly.h index e4aa20c..4c108c9 100644 --- a/arch/blackfin/include/asm/mach-bf561/anomaly.h +++ b/arch/blackfin/include/asm/mach-bf561/anomaly.h @@ -1,9 +1,13 @@ /* - * File: include/asm-blackfin/mach-bf561/anomaly.h - * Bugs: Enter bugs at http://blackfin.uclinux.org/ + * DO NOT EDIT THIS FILE + * This file is under version control at + * svn://sources.blackfin.uclinux.org/toolchain/trunk/proc-defs/header-frags/ + * and can be replaced with that version at any time + * DO NOT EDIT THIS FILE * - * Copyright (C) 2004-2009 Analog Devices Inc. - * Licensed under the GPL-2 or later. + * Copyright 2004-2010 Analog Devices Inc. + * Licensed under the ADI BSD license. + * https://docs.blackfin.uclinux.org/doku.php?id=adi_bsd */
/* This file should be up to date with: @@ -18,19 +22,19 @@ # error will not work on BF561 silicon version 0.0, 0.1, 0.2, or 0.4 #endif
-/* Multi-issue instruction with dsp32shiftimm in slot1 and P-reg store in slot 2 not supported */ +/* Multi-Issue Instruction with dsp32shiftimm in slot1 and P-reg Store in slot2 Not Supported */ #define ANOMALY_05000074 (1) /* UART Line Status Register (UART_LSR) Bits Are Not Updated at the Same Time */ #define ANOMALY_05000099 (__SILICON_REVISION__ < 5) -/* Trace Buffers may record discontinuities into emulation mode and/or exception, NMI, reset handlers */ +/* Trace Buffers May Contain Errors in Emulation Mode and/or Exception, NMI, Reset Handlers */ #define ANOMALY_05000116 (__SILICON_REVISION__ < 3) -/* Testset instructions restricted to 32-bit aligned memory locations */ +/* TESTSET Instructions Restricted to 32-Bit Aligned Memory Locations */ #define ANOMALY_05000120 (1) /* Rx.H Cannot Be Used to Access 16-bit System MMR Registers */ #define ANOMALY_05000122 (1) -/* Erroneous exception when enabling cache */ +/* Erroneous Exception when Enabling Cache */ #define ANOMALY_05000125 (__SILICON_REVISION__ < 3) -/* Signbits instruction not functional under certain conditions */ +/* SIGNBITS Instruction Not Functional under Certain Conditions */ #define ANOMALY_05000127 (1) /* Two bits in the Watchpoint Status Register (WPSTAT) are swapped */ #define ANOMALY_05000134 (__SILICON_REVISION__ < 3) @@ -40,7 +44,7 @@ #define ANOMALY_05000136 (__SILICON_REVISION__ < 3) /* Allowing the SPORT RX FIFO to fill will cause an overflow */ #define ANOMALY_05000140 (__SILICON_REVISION__ < 3) -/* An Infinite Stall occurs with a particular sequence of consecutive dual dag events */ +/* Infinite Stall may occur with a particular sequence of consecutive dual dag events */ #define ANOMALY_05000141 (__SILICON_REVISION__ < 3) /* Interrupts may be lost when a programmable input flag is configured to be edge sensitive */ #define ANOMALY_05000142 (__SILICON_REVISION__ < 3) @@ -52,7 +56,7 @@ #define ANOMALY_05000146 (__SILICON_REVISION__ < 3) /* Source MDMA descriptor may stop with a DMA Error near beginning of descriptor fetch */ #define ANOMALY_05000147 (__SILICON_REVISION__ < 3) -/* IMDMA S1/D1 channel may stall */ +/* IMDMA S1/D1 Channel May Stall */ #define ANOMALY_05000149 (1) /* DMA engine may lose data due to incorrect handshaking */ #define ANOMALY_05000150 (__SILICON_REVISION__ < 3) @@ -66,7 +70,7 @@ #define ANOMALY_05000154 (__SILICON_REVISION__ < 3) /* Timers in PWM-Out Mode with PPI GP Receive (Input) Mode with 0 Frame Syncs */ #define ANOMALY_05000156 (__SILICON_REVISION__ < 4) -/* Killed 32-bit MMR write leads to next system MMR access thinking it should be 32-bit */ +/* Killed 32-Bit MMR Write Leads to Next System MMR Access Thinking It Should Be 32-Bit */ #define ANOMALY_05000157 (__SILICON_REVISION__ < 3) /* DMA Lock-up at CCLK to SCLK ratios of 4:1, 2:1, or 1:1 */ #define ANOMALY_05000159 (__SILICON_REVISION__ < 3) @@ -76,17 +80,17 @@ #define ANOMALY_05000161 (__SILICON_REVISION__ < 3) /* DMEM_CONTROL<12> is not set on Reset */ #define ANOMALY_05000162 (__SILICON_REVISION__ < 3) -/* SPORT transmit data is not gated by external frame sync in certain conditions */ +/* SPORT Transmit Data Is Not Gated by External Frame Sync in Certain Conditions */ #define ANOMALY_05000163 (__SILICON_REVISION__ < 3) -/* PPI Data Lengths Between 8 and 16 Do Not Zero Out Upper Bits */ +/* PPI Data Lengths between 8 and 16 Do Not Zero Out Upper Bits */ #define ANOMALY_05000166 (1) /* Turning SPORTs on while External Frame Sync Is Active May Corrupt Data */ #define ANOMALY_05000167 (1) -/* SDRAM auto-refresh and subsequent Power Ups */ +/* Undefined Behavior when Power-Up Sequence Is Issued to SDRAM during Auto-Refresh */ #define ANOMALY_05000168 (__SILICON_REVISION__ < 5) -/* DATA CPLB page miss can result in lost write-through cache data writes */ +/* DATA CPLB Page Miss Can Result in Lost Write-Through Data Cache Writes */ #define ANOMALY_05000169 (__SILICON_REVISION__ < 5) -/* Boot-ROM code modifies SICA_IWRx wakeup registers */ +/* Boot-ROM Modifies SICA_IWRx Wakeup Registers */ #define ANOMALY_05000171 (__SILICON_REVISION__ < 5) /* DSPID register values incorrect */ #define ANOMALY_05000172 (__SILICON_REVISION__ < 3) @@ -96,29 +100,29 @@ #define ANOMALY_05000174 (__SILICON_REVISION__ < 5) /* Overlapping Sequencer and Memory Stalls */ #define ANOMALY_05000175 (__SILICON_REVISION__ < 5) -/* Multiplication of (-1) by (-1) followed by an accumulator saturation */ +/* Overflow Bit Asserted when Multiplication of -1 by -1 Followed by Accumulator Saturation */ #define ANOMALY_05000176 (__SILICON_REVISION__ < 5) /* PPI_COUNT Cannot Be Programmed to 0 in General Purpose TX or RX Modes */ #define ANOMALY_05000179 (__SILICON_REVISION__ < 5) /* PPI_DELAY Not Functional in PPI Modes with 0 Frame Syncs */ #define ANOMALY_05000180 (1) -/* Disabling the PPI resets the PPI configuration registers */ +/* Disabling the PPI Resets the PPI Configuration Registers */ #define ANOMALY_05000181 (__SILICON_REVISION__ < 5) -/* IMDMA does not operate to full speed for 600MHz and higher devices */ +/* Internal Memory DMA Does Not Operate at Full Speed */ #define ANOMALY_05000182 (1) -/* Timer Pin limitations for PPI TX Modes with External Frame Syncs */ +/* Timer Pin Limitations for PPI TX Modes with External Frame Syncs */ #define ANOMALY_05000184 (__SILICON_REVISION__ < 5) -/* PPI TX Mode with 2 External Frame Syncs */ +/* Early PPI Transmit when FS1 Asserts before FS2 in TX Mode with 2 External Frame Syncs */ #define ANOMALY_05000185 (__SILICON_REVISION__ < 5) -/* PPI packing with Data Length greater than 8 bits (not a meaningful mode) */ +/* Upper PPI Pins Driven when PPI Packing Enabled and Data Length >8 Bits */ #define ANOMALY_05000186 (__SILICON_REVISION__ < 5) /* IMDMA Corrupted Data after a Halt */ #define ANOMALY_05000187 (1) /* IMDMA Restrictions on Descriptor and Buffer Placement in Memory */ #define ANOMALY_05000188 (__SILICON_REVISION__ < 5) -/* False Protection Exceptions */ +/* False Protection Exceptions when Speculative Fetch Is Cancelled */ #define ANOMALY_05000189 (__SILICON_REVISION__ < 5) -/* PPI not functional at core voltage < 1Volt */ +/* PPI Not Functional at Core Voltage < 1Volt */ #define ANOMALY_05000190 (1) /* PPI does not invert the Driving PPICLK edge in Transmit Modes */ #define ANOMALY_05000191 (__SILICON_REVISION__ < 3) @@ -126,7 +130,7 @@ #define ANOMALY_05000193 (__SILICON_REVISION__ < 5) /* Restarting SPORT in Specific Modes May Cause Data Corruption */ #define ANOMALY_05000194 (__SILICON_REVISION__ < 5) -/* Failing MMR Accesses When Stalled by Preceding Memory Read */ +/* Failing MMR Accesses when Preceding Memory Read Stalls */ #define ANOMALY_05000198 (__SILICON_REVISION__ < 5) /* Current DMA Address Shows Wrong Value During Carry Fix */ #define ANOMALY_05000199 (__SILICON_REVISION__ < 5) @@ -134,9 +138,9 @@ #define ANOMALY_05000200 (__SILICON_REVISION__ < 5) /* Possible Infinite Stall with Specific Dual-DAG Situation */ #define ANOMALY_05000202 (__SILICON_REVISION__ < 5) -/* Incorrect data read with write-through cache and allocate cache lines on reads only mode */ +/* Incorrect Data Read with Writethrough "Allocate Cache Lines on Reads Only" Cache Mode */ #define ANOMALY_05000204 (__SILICON_REVISION__ < 5) -/* Specific sequence that can cause DMA error or DMA stopping */ +/* Specific Sequence that Can Cause DMA Error or DMA Stopping */ #define ANOMALY_05000205 (__SILICON_REVISION__ < 5) /* Recovery from "Brown-Out" Condition */ #define ANOMALY_05000207 (__SILICON_REVISION__ < 5) @@ -148,8 +152,8 @@ #define ANOMALY_05000215 (__SILICON_REVISION__ < 5) /* NMI Event at Boot Time Results in Unpredictable State */ #define ANOMALY_05000219 (__SILICON_REVISION__ < 5) -/* Data Corruption with Cached External Memory and Non-Cached On-Chip L2 Memory */ -#define ANOMALY_05000220 (__SILICON_REVISION__ < 5) +/* Data Corruption/Core Hang with L2/L3 Configured in Writeback Cache Mode */ +#define ANOMALY_05000220 (__SILICON_REVISION__ < 4) /* Incorrect Pulse-Width of UART Start Bit */ #define ANOMALY_05000225 (__SILICON_REVISION__ < 5) /* Scratchpad Memory Bank Reads May Return Incorrect Data */ @@ -158,7 +162,7 @@ #define ANOMALY_05000230 (__SILICON_REVISION__ < 5) /* UART STB Bit Incorrectly Affects Receiver Setting */ #define ANOMALY_05000231 (__SILICON_REVISION__ < 5) -/* SPORT data transmit lines are incorrectly driven in multichannel mode */ +/* SPORT Data Transmit Lines Are Incorrectly Driven in Multichannel Mode */ #define ANOMALY_05000232 (__SILICON_REVISION__ < 5) /* DF Bit in PLL_CTL Register Does Not Respond to Hardware Reset */ #define ANOMALY_05000242 (__SILICON_REVISION__ < 5) @@ -166,7 +170,7 @@ #define ANOMALY_05000244 (__SILICON_REVISION__ < 5) /* False Hardware Error from an Access in the Shadow of a Conditional Branch */ #define ANOMALY_05000245 (__SILICON_REVISION__ < 5) -/* TESTSET operation forces stall on the other core */ +/* TESTSET Operation Forces Stall on the Other Core */ #define ANOMALY_05000248 (__SILICON_REVISION__ < 5) /* Incorrect Bit Shift of Data Word in Multichannel (TDM) Mode in Certain Conditions */ #define ANOMALY_05000250 (__SILICON_REVISION__ > 2 && __SILICON_REVISION__ < 5) @@ -192,9 +196,9 @@ #define ANOMALY_05000264 (__SILICON_REVISION__ < 5) /* Sensitivity To Noise with Slow Input Edge Rates on External SPORT TX and RX Clocks */ #define ANOMALY_05000265 (__SILICON_REVISION__ < 5) -/* IMDMA destination IRQ status must be read prior to using IMDMA */ +/* IMDMA Destination IRQ Status Must Be Read Prior to Using IMDMA */ #define ANOMALY_05000266 (__SILICON_REVISION__ > 3) -/* IMDMA may corrupt data under certain conditions */ +/* IMDMA May Corrupt Data under Certain Conditions */ #define ANOMALY_05000267 (1) /* High I/O Activity Causes Output Voltage of Internal Voltage Regulator (Vddint) to Increase */ #define ANOMALY_05000269 (1) @@ -202,7 +206,7 @@ #define ANOMALY_05000270 (1) /* Certain Data Cache Writethrough Modes Fail for Vddint <= 0.9V */ #define ANOMALY_05000272 (1) -/* Data cache write back to external synchronous memory may be lost */ +/* Data Cache Write Back to External Synchronous Memory May Be Lost */ #define ANOMALY_05000274 (1) /* PPI Timing and Sampling Information Updates */ #define ANOMALY_05000275 (__SILICON_REVISION__ > 2) @@ -212,17 +216,21 @@ #define ANOMALY_05000277 (__SILICON_REVISION__ < 3) /* Disabling Peripherals with DMA Running May Cause DMA System Instability */ #define ANOMALY_05000278 (__SILICON_REVISION__ < 5) -/* False Hardware Error Exception When ISR Context Is Not Restored */ -#define ANOMALY_05000281 (__SILICON_REVISION__ < 5) -/* System MMR Write Is Stalled Indefinitely When Killed in a Particular Stage */ +/* False Hardware Error Exception when ISR Context Is Not Restored */ +/* Temporarily walk around for bug 5423 till this issue is confirmed by + * official anomaly document. It looks 05000281 still exists on bf561 + * v0.5. + */ +#define ANOMALY_05000281 (__SILICON_REVISION__ <= 5) +/* System MMR Write Is Stalled Indefinitely when Killed in a Particular Stage */ #define ANOMALY_05000283 (1) -/* A read will receive incorrect data under certain conditions */ +/* Reads Will Receive Incorrect Data under Certain Conditions */ #define ANOMALY_05000287 (__SILICON_REVISION__ < 5) /* SPORTs May Receive Bad Data If FIFOs Fill Up */ #define ANOMALY_05000288 (__SILICON_REVISION__ < 5) /* Memory-To-Memory DMA Source/Destination Descriptors Must Be in Same Memory Space */ #define ANOMALY_05000301 (1) -/* SSYNCs After Writes To DMA MMR Registers May Not Be Handled Correctly */ +/* SSYNCs after Writes to DMA MMR Registers May Not Be Handled Correctly */ #define ANOMALY_05000302 (1) /* SPORT_HYS Bit in PLL_CTL Register Is Not Functional */ #define ANOMALY_05000305 (__SILICON_REVISION__ < 5) @@ -230,25 +238,25 @@ #define ANOMALY_05000307 (__SILICON_REVISION__ < 5) /* False Hardware Errors Caused by Fetches at the Boundary of Reserved Memory */ #define ANOMALY_05000310 (1) -/* Errors When SSYNC, CSYNC, or Loads to LT, LB and LC Registers Are Interrupted */ +/* Errors when SSYNC, CSYNC, or Loads to LT, LB and LC Registers Are Interrupted */ #define ANOMALY_05000312 (1) /* PPI Is Level-Sensitive on First Transfer In Single Frame Sync Modes */ #define ANOMALY_05000313 (1) -/* Killed System MMR Write Completes Erroneously On Next System MMR Access */ +/* Killed System MMR Write Completes Erroneously on Next System MMR Access */ #define ANOMALY_05000315 (1) -/* PF2 Output Remains Asserted After SPI Master Boot */ +/* PF2 Output Remains Asserted after SPI Master Boot */ #define ANOMALY_05000320 (__SILICON_REVISION__ > 3) -/* Erroneous GPIO Flag Pin Operations Under Specific Sequences */ +/* Erroneous GPIO Flag Pin Operations under Specific Sequences */ #define ANOMALY_05000323 (1) -/* SPORT Secondary Receive Channel Not Functional When Word Length Exceeds 16 Bits */ +/* SPORT Secondary Receive Channel Not Functional when Word Length >16 Bits */ #define ANOMALY_05000326 (__SILICON_REVISION__ > 3) -/* New Feature: 24-Bit SPI Boot Mode Support (Not Available On Older Silicon) */ +/* 24-Bit SPI Boot Mode Is Not Functional */ #define ANOMALY_05000331 (__SILICON_REVISION__ < 5) -/* New Feature: Slave SPI Boot Mode Supported (Not Available On Older Silicon) */ +/* Slave SPI Boot Mode Is Not Functional */ #define ANOMALY_05000332 (__SILICON_REVISION__ < 5) -/* Flag Data Register Writes One SCLK Cycle After Edge Is Detected May Clear Interrupt Status */ +/* Flag Data Register Writes One SCLK Cycle after Edge Is Detected May Clear Interrupt Status */ #define ANOMALY_05000333 (__SILICON_REVISION__ < 5) -/* New Feature: Additional PPI Frame Sync Sampling Options (Not Available on Older Silicon) */ +/* ALT_TIMING Bit in PLL_CTL Register Is Not Functional */ #define ANOMALY_05000339 (__SILICON_REVISION__ < 5) /* Memory DMA FIFO Causes Throughput Degradation on Writes to External Memory */ #define ANOMALY_05000343 (__SILICON_REVISION__ < 5) @@ -262,6 +270,8 @@ #define ANOMALY_05000366 (1) /* Possible RETS Register Corruption when Subroutine Is under 5 Cycles in Duration */ #define ANOMALY_05000371 (1) +/* SSYNC Stalls Processor when Executed from Non-Cacheable Memory */ +#define ANOMALY_05000402 (__SILICON_REVISION__ == 4) /* Level-Sensitive External GPIO Wakeups May Cause Indefinite Stall */ #define ANOMALY_05000403 (1) /* TESTSET Instruction Causes Data Corruption with Writeback Data Cache Enabled */ @@ -276,19 +286,43 @@ #define ANOMALY_05000428 (__SILICON_REVISION__ > 3) /* IFLUSH Instruction at End of Hardware Loop Causes Infinite Stall */ #define ANOMALY_05000443 (1) +/* False Hardware Error when RETI Points to Invalid Memory */ +#define ANOMALY_05000461 (1) +/* Interrupted 32-Bit SPORT Data Register Access Results In Underflow */ +#define ANOMALY_05000473 (1) +/* Possible Lockup Condition whem Modifying PLL from External Memory */ +#define ANOMALY_05000475 (__SILICON_REVISION__ < 4) +/* TESTSET Instruction Cannot Be Interrupted */ +#define ANOMALY_05000477 (1) +/* Reads of ITEST_COMMAND and ITEST_DATA Registers Cause Cache Corruption */ +#define ANOMALY_05000481 (1) +/* IFLUSH sucks at life */ +#define ANOMALY_05000491 (1)
/* Anomalies that don't exist on this proc */ +#define ANOMALY_05000119 (0) #define ANOMALY_05000158 (0) #define ANOMALY_05000183 (0) +#define ANOMALY_05000233 (0) +#define ANOMALY_05000234 (0) #define ANOMALY_05000273 (0) #define ANOMALY_05000311 (0) #define ANOMALY_05000353 (1) +#define ANOMALY_05000364 (0) #define ANOMALY_05000380 (0) #define ANOMALY_05000386 (1) +#define ANOMALY_05000389 (0) +#define ANOMALY_05000400 (0) #define ANOMALY_05000430 (0) #define ANOMALY_05000432 (0) #define ANOMALY_05000435 (0) #define ANOMALY_05000447 (0) #define ANOMALY_05000448 (0) +#define ANOMALY_05000456 (0) +#define ANOMALY_05000450 (0) +#define ANOMALY_05000465 (0) +#define ANOMALY_05000467 (0) +#define ANOMALY_05000474 (0) +#define ANOMALY_05000485 (0)
#endif
Older on-chip Blackfin bootroms do not create a dummy NMI handler, so set up one ourselves when anomaly 05000219 applies.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- arch/blackfin/cpu/cpu.c | 4 +++- arch/blackfin/cpu/cpu.h | 1 + arch/blackfin/cpu/initcode.c | 25 +++++++++++++++++++++++++ arch/blackfin/cpu/interrupt.S | 5 +++++ 4 files changed, 34 insertions(+), 1 deletions(-)
diff --git a/arch/blackfin/cpu/cpu.c b/arch/blackfin/cpu/cpu.c index 2c8fd86..18dbdf7 100644 --- a/arch/blackfin/cpu/cpu.c +++ b/arch/blackfin/cpu/cpu.c @@ -91,7 +91,9 @@ int irq_init(void) #else bfin_write_SIC_IMASK(0); #endif - bfin_write_EVT2(evt_default); /* NMI */ + /* Set up a dummy NMI handler if needed. */ + if (CONFIG_BFIN_BOOT_MODE == BFIN_BOOT_BYPASS || ANOMALY_05000219) + bfin_write_EVT2(evt_nmi); /* NMI */ bfin_write_EVT5(evt_default); /* hardware error */ bfin_write_EVT6(evt_default); /* core timer */ bfin_write_EVT7(evt_default); diff --git a/arch/blackfin/cpu/cpu.h b/arch/blackfin/cpu/cpu.h index c8bec11..ba85e0b 100644 --- a/arch/blackfin/cpu/cpu.h +++ b/arch/blackfin/cpu/cpu.h @@ -34,6 +34,7 @@ void bfin_panic(struct pt_regs *reg); void dump(struct pt_regs *regs);
asmlinkage void trap(void); +asmlinkage void evt_nmi(void); asmlinkage void evt_default(void);
#endif diff --git a/arch/blackfin/cpu/initcode.c b/arch/blackfin/cpu/initcode.c index 9453d5d..007f5ce 100644 --- a/arch/blackfin/cpu/initcode.c +++ b/arch/blackfin/cpu/initcode.c @@ -101,6 +101,28 @@ static inline void serial_putc(char c) continue; }
+__attribute__((always_inline)) static inline void +program_nmi_handler(void) +{ + u32 tmp1, tmp2; + + /* Older bootroms don't create a dummy NMI handler, + * so make one ourselves ASAP in case it fires. + */ + if (CONFIG_BFIN_BOOT_MODE != BFIN_BOOT_BYPASS && !ANOMALY_05000219) + return; + + asm volatile ( + "%0 = RETS;" /* Save current RETS */ + "CALL 1f;" /* Figure out current PC */ + "RTN;" /* The simple NMI handler */ + "1:" + "%1 = RETS;" /* Load addr of NMI handler */ + "RETS = %0;" /* Restore RETS */ + "[%2] = %1;" /* Write NMI handler */ + : "=r"(tmp1), "=r"(tmp2) : "ab"(EVT2) + ); +}
/* Max SCLK can be 133MHz ... dividing that by (2*4) gives * us a freq of 16MHz for SPI which should generally be @@ -640,6 +662,9 @@ void initcode(ADI_BOOT_DATA *bs) { ADI_BOOT_DATA bootstruct_scratch;
+ /* Setup NMI handler before anything else */ + program_nmi_handler(); + serial_init();
serial_putc('A'); diff --git a/arch/blackfin/cpu/interrupt.S b/arch/blackfin/cpu/interrupt.S index 69bba3f..0e5e59e 100644 --- a/arch/blackfin/cpu/interrupt.S +++ b/arch/blackfin/cpu/interrupt.S @@ -150,3 +150,8 @@ ENTRY(_evt_default) RESTORE_ALL_SYS rti; ENDPROC(_evt_default) + +/* NMI handler */ +ENTRY(_evt_nmi) + rtn; +ENDPROC(_evt_nmi)
Signed-off-by: Hoan Hoang hnhoan@i-syst.com Signed-off-by: Mike Frysinger vapier@gentoo.org --- board/ibf-dsp561/ibf-dsp561.c | 8 ++++++++ include/configs/ibf-dsp561.h | 12 ++++++++++++ 2 files changed, 20 insertions(+), 0 deletions(-)
diff --git a/board/ibf-dsp561/ibf-dsp561.c b/board/ibf-dsp561/ibf-dsp561.c index b5bebd4..d2ac7a5 100644 --- a/board/ibf-dsp561/ibf-dsp561.c +++ b/board/ibf-dsp561/ibf-dsp561.c @@ -7,6 +7,7 @@ */
#include <common.h> +#include <netdev.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -16,3 +17,10 @@ int checkboard(void) printf(" Support: http://www.i-syst.com/%5Cn"); return 0; } + +#ifdef CONFIG_DRIVER_AX88180 +int board_eth_init(bd_t *bis) +{ + return ax88180_initialize(bis); +} +#endif diff --git a/include/configs/ibf-dsp561.h b/include/configs/ibf-dsp561.h index 2eef5ef..5601416 100644 --- a/include/configs/ibf-dsp561.h +++ b/include/configs/ibf-dsp561.h @@ -58,6 +58,18 @@
/* + * Network Settings + */ +#define ADI_CMDS_NETWORK 1 +#define CONFIG_NET_MULTI +#define CONFIG_DRIVER_AX88180 1 +#define AX88180_BASE 0x2c000000 +#define CONFIG_HOSTNAME ibf-dsp561 +/* Uncomment next line to use fixed MAC address */ +/* #define CONFIG_ETHADDR 02:80:ad:20:31:e8 */ + + +/* * Flash Settings */ #define CONFIG_SYS_FLASH_CFI /* The flash is CFI compatible */
The current pinmux handling has spread throughout Blackfin drivers and board code and is getting hideous to maintain. So import the gpio and portmux layer from the Blackfin Linux code. This should spur a serious of cleanups across the Blackfin tree.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- arch/blackfin/cpu/Makefile | 1 + arch/blackfin/cpu/gpio.c | 854 ++++++++++++++++ arch/blackfin/include/asm/gpio.h | 201 ++++ arch/blackfin/include/asm/mach-bf527/def_local.h | 4 + arch/blackfin/include/asm/mach-bf527/gpio.h | 65 ++ arch/blackfin/include/asm/mach-bf527/portmux.h | 220 ++++ arch/blackfin/include/asm/mach-bf533/def_local.h | 4 + arch/blackfin/include/asm/mach-bf533/gpio.h | 31 + arch/blackfin/include/asm/mach-bf533/portmux.h | 71 ++ arch/blackfin/include/asm/mach-bf537/def_local.h | 4 + arch/blackfin/include/asm/mach-bf537/gpio.h | 65 ++ arch/blackfin/include/asm/mach-bf537/portmux.h | 152 +++ arch/blackfin/include/asm/mach-bf548/def_local.h | 4 + arch/blackfin/include/asm/mach-bf548/gpio.h | 203 ++++ arch/blackfin/include/asm/mach-bf548/portmux.h | 320 ++++++ arch/blackfin/include/asm/mach-bf561/def_local.h | 4 + arch/blackfin/include/asm/mach-bf561/gpio.h | 65 ++ arch/blackfin/include/asm/mach-bf561/portmux.h | 97 ++ arch/blackfin/include/asm/portmux.h | 1194 ++++++++++++++++++++++ arch/blackfin/include/asm/system.h | 2 + 20 files changed, 3561 insertions(+), 0 deletions(-) create mode 100644 arch/blackfin/cpu/gpio.c create mode 100644 arch/blackfin/include/asm/gpio.h create mode 100644 arch/blackfin/include/asm/mach-bf527/gpio.h create mode 100644 arch/blackfin/include/asm/mach-bf527/portmux.h create mode 100644 arch/blackfin/include/asm/mach-bf533/gpio.h create mode 100644 arch/blackfin/include/asm/mach-bf533/portmux.h create mode 100644 arch/blackfin/include/asm/mach-bf537/gpio.h create mode 100644 arch/blackfin/include/asm/mach-bf537/portmux.h create mode 100644 arch/blackfin/include/asm/mach-bf548/gpio.h create mode 100644 arch/blackfin/include/asm/mach-bf548/portmux.h create mode 100644 arch/blackfin/include/asm/mach-bf561/gpio.h create mode 100644 arch/blackfin/include/asm/mach-bf561/portmux.h create mode 100644 arch/blackfin/include/asm/portmux.h
diff --git a/arch/blackfin/cpu/Makefile b/arch/blackfin/cpu/Makefile index 50c1eea..91797c7 100644 --- a/arch/blackfin/cpu/Makefile +++ b/arch/blackfin/cpu/Makefile @@ -19,6 +19,7 @@ SEXTRA := start.o SOBJS := interrupt.o cache.o COBJS-$(CONFIG_BOOTCOUNT_LIMIT) += bootcount.o COBJS-y += cpu.o +COBJS-y += gpio.o COBJS-y += interrupts.o COBJS-$(CONFIG_JTAG_CONSOLE) += jtag-console.o COBJS-y += os_log.o diff --git a/arch/blackfin/cpu/gpio.c b/arch/blackfin/cpu/gpio.c new file mode 100644 index 0000000..488ca11 --- /dev/null +++ b/arch/blackfin/cpu/gpio.c @@ -0,0 +1,854 @@ +/* + * GPIO Abstraction Layer + * + * Copyright 2006-2010 Analog Devices Inc. + * + * Licensed under the GPL-2 or later + */ + +#include <common.h> +#include <asm/errno.h> +#include <asm/gpio.h> +#include <asm/portmux.h> + +#if ANOMALY_05000311 || ANOMALY_05000323 +enum { + AWA_data = SYSCR, + AWA_data_clear = SYSCR, + AWA_data_set = SYSCR, + AWA_toggle = SYSCR, + AWA_maska = UART_SCR, + AWA_maska_clear = UART_SCR, + AWA_maska_set = UART_SCR, + AWA_maska_toggle = UART_SCR, + AWA_maskb = UART_GCTL, + AWA_maskb_clear = UART_GCTL, + AWA_maskb_set = UART_GCTL, + AWA_maskb_toggle = UART_GCTL, + AWA_dir = SPORT1_STAT, + AWA_polar = SPORT1_STAT, + AWA_edge = SPORT1_STAT, + AWA_both = SPORT1_STAT, +#if ANOMALY_05000311 + AWA_inen = TIMER_ENABLE, +#elif ANOMALY_05000323 + AWA_inen = DMA1_1_CONFIG, +#endif +}; + /* Anomaly Workaround */ +#define AWA_DUMMY_READ(name) bfin_read16(AWA_ ## name) +#else +#define AWA_DUMMY_READ(...) do { } while (0) +#endif + +static struct gpio_port_t * const gpio_array[] = { +#if defined(BF533_FAMILY) + (struct gpio_port_t *) FIO_FLAG_D, +#elif defined(CONFIG_BF52x) || defined(BF537_FAMILY) || defined(CONFIG_BF51x) \ + || defined(BF538_FAMILY) + (struct gpio_port_t *) PORTFIO, +# if !defined(BF538_FAMILY) + (struct gpio_port_t *) PORTGIO, + (struct gpio_port_t *) PORTHIO, +# endif +#elif defined(BF561_FAMILY) + (struct gpio_port_t *) FIO0_FLAG_D, + (struct gpio_port_t *) FIO1_FLAG_D, + (struct gpio_port_t *) FIO2_FLAG_D, +#elif defined(CONFIG_BF54x) + (struct gpio_port_t *)PORTA_FER, + (struct gpio_port_t *)PORTB_FER, + (struct gpio_port_t *)PORTC_FER, + (struct gpio_port_t *)PORTD_FER, + (struct gpio_port_t *)PORTE_FER, + (struct gpio_port_t *)PORTF_FER, + (struct gpio_port_t *)PORTG_FER, + (struct gpio_port_t *)PORTH_FER, + (struct gpio_port_t *)PORTI_FER, + (struct gpio_port_t *)PORTJ_FER, +#else +# error no gpio arrays defined +#endif +}; + +#if defined(CONFIG_BF52x) || defined(BF537_FAMILY) || defined(CONFIG_BF51x) +static unsigned short * const port_fer[] = { + (unsigned short *) PORTF_FER, + (unsigned short *) PORTG_FER, + (unsigned short *) PORTH_FER, +}; + +# if !defined(BF537_FAMILY) +static unsigned short * const port_mux[] = { + (unsigned short *) PORTF_MUX, + (unsigned short *) PORTG_MUX, + (unsigned short *) PORTH_MUX, +}; + +static const +u8 pmux_offset[][16] = { +# if defined(CONFIG_BF52x) + { 0, 0, 0, 0, 0, 0, 0, 0, 2, 2, 4, 6, 8, 8, 10, 10 }, /* PORTF */ + { 0, 0, 0, 0, 0, 2, 2, 4, 4, 6, 8, 10, 10, 10, 12, 12 }, /* PORTG */ + { 0, 0, 0, 0, 0, 0, 0, 0, 2, 4, 4, 4, 4, 4, 4, 4 }, /* PORTH */ +# elif defined(CONFIG_BF51x) + { 0, 2, 2, 2, 2, 2, 2, 4, 6, 6, 6, 8, 8, 8, 8, 10 }, /* PORTF */ + { 0, 0, 0, 2, 4, 6, 6, 6, 8, 10, 10, 12, 14, 14, 14, 14 }, /* PORTG */ + { 0, 0, 0, 0, 2, 2, 4, 6, 10, 10, 10, 10, 10, 10, 10, 10 }, /* PORTH */ +# endif +}; +# endif + +#elif defined(BF538_FAMILY) +static unsigned short * const port_fer[] = { + (unsigned short *) PORTCIO_FER, + (unsigned short *) PORTDIO_FER, + (unsigned short *) PORTEIO_FER, +}; +#endif + +#ifdef CONFIG_BFIN_GPIO_TRACK +#define RESOURCE_LABEL_SIZE 16 + +static struct str_ident { + char name[RESOURCE_LABEL_SIZE]; +} str_ident[MAX_RESOURCES]; + +static void gpio_error(unsigned gpio) +{ + printf("bfin-gpio: GPIO %d wasn't requested!\n", gpio); +} + +static void set_label(unsigned short ident, const char *label) +{ + if (label) { + strncpy(str_ident[ident].name, label, + RESOURCE_LABEL_SIZE); + str_ident[ident].name[RESOURCE_LABEL_SIZE - 1] = 0; + } +} + +static char *get_label(unsigned short ident) +{ + return (*str_ident[ident].name ? str_ident[ident].name : "UNKNOWN"); +} + +static int cmp_label(unsigned short ident, const char *label) +{ + if (label == NULL) + printf("bfin-gpio: please provide none-null label\n"); + + if (label) + return strcmp(str_ident[ident].name, label); + else + return -EINVAL; +} + +#define map_entry(m, i) reserved_##m##_map[gpio_bank(i)] +#define is_reserved(m, i, e) (map_entry(m, i) & gpio_bit(i)) +#define reserve(m, i) (map_entry(m, i) |= gpio_bit(i)) +#define unreserve(m, i) (map_entry(m, i) &= ~gpio_bit(i)) +#define DECLARE_RESERVED_MAP(m, c) static unsigned short reserved_##m##_map[c] +#else +#define is_reserved(m, i, e) (!(e)) +#define reserve(m, i) +#define unreserve(m, i) +#define DECLARE_RESERVED_MAP(m, c) +#define gpio_error(gpio) +#define set_label(...) +#define get_label(...) "" +#define cmp_label(...) 1 +#endif + +DECLARE_RESERVED_MAP(gpio, GPIO_BANK_NUM); +DECLARE_RESERVED_MAP(peri, gpio_bank(MAX_RESOURCES)); + +inline int check_gpio(unsigned gpio) +{ +#if defined(CONFIG_BF54x) + if (gpio == GPIO_PB15 || gpio == GPIO_PC14 || gpio == GPIO_PC15 + || gpio == GPIO_PH14 || gpio == GPIO_PH15 + || gpio == GPIO_PJ14 || gpio == GPIO_PJ15) + return -EINVAL; +#endif + if (gpio >= MAX_BLACKFIN_GPIOS) + return -EINVAL; + return 0; +} + +static void port_setup(unsigned gpio, unsigned short usage) +{ +#if defined(BF538_FAMILY) + /* + * BF538/9 Port C,D and E are special. + * Inverted PORT_FER polarity on CDE and no PORF_FER on F + * Regular PORT F GPIOs are handled here, CDE are exclusively + * managed by GPIOLIB + */ + + if (gpio < MAX_BLACKFIN_GPIOS || gpio >= MAX_RESOURCES) + return; + + gpio -= MAX_BLACKFIN_GPIOS; + + if (usage == GPIO_USAGE) + *port_fer[gpio_bank(gpio)] |= gpio_bit(gpio); + else + *port_fer[gpio_bank(gpio)] &= ~gpio_bit(gpio); + SSYNC(); + return; +#endif + + if (check_gpio(gpio)) + return; + +#if defined(CONFIG_BF52x) || defined(BF537_FAMILY) || defined(CONFIG_BF51x) + if (usage == GPIO_USAGE) + *port_fer[gpio_bank(gpio)] &= ~gpio_bit(gpio); + else + *port_fer[gpio_bank(gpio)] |= gpio_bit(gpio); + SSYNC(); +#elif defined(CONFIG_BF54x) + if (usage == GPIO_USAGE) + gpio_array[gpio_bank(gpio)]->port_fer &= ~gpio_bit(gpio); + else + gpio_array[gpio_bank(gpio)]->port_fer |= gpio_bit(gpio); + SSYNC(); +#endif +} + +#ifdef BF537_FAMILY +static struct { + unsigned short res; + unsigned short offset; +} port_mux_lut[] = { + {.res = P_PPI0_D13, .offset = 11}, + {.res = P_PPI0_D14, .offset = 11}, + {.res = P_PPI0_D15, .offset = 11}, + {.res = P_SPORT1_TFS, .offset = 11}, + {.res = P_SPORT1_TSCLK, .offset = 11}, + {.res = P_SPORT1_DTPRI, .offset = 11}, + {.res = P_PPI0_D10, .offset = 10}, + {.res = P_PPI0_D11, .offset = 10}, + {.res = P_PPI0_D12, .offset = 10}, + {.res = P_SPORT1_RSCLK, .offset = 10}, + {.res = P_SPORT1_RFS, .offset = 10}, + {.res = P_SPORT1_DRPRI, .offset = 10}, + {.res = P_PPI0_D8, .offset = 9}, + {.res = P_PPI0_D9, .offset = 9}, + {.res = P_SPORT1_DRSEC, .offset = 9}, + {.res = P_SPORT1_DTSEC, .offset = 9}, + {.res = P_TMR2, .offset = 8}, + {.res = P_PPI0_FS3, .offset = 8}, + {.res = P_TMR3, .offset = 7}, + {.res = P_SPI0_SSEL4, .offset = 7}, + {.res = P_TMR4, .offset = 6}, + {.res = P_SPI0_SSEL5, .offset = 6}, + {.res = P_TMR5, .offset = 5}, + {.res = P_SPI0_SSEL6, .offset = 5}, + {.res = P_UART1_RX, .offset = 4}, + {.res = P_UART1_TX, .offset = 4}, + {.res = P_TMR6, .offset = 4}, + {.res = P_TMR7, .offset = 4}, + {.res = P_UART0_RX, .offset = 3}, + {.res = P_UART0_TX, .offset = 3}, + {.res = P_DMAR0, .offset = 3}, + {.res = P_DMAR1, .offset = 3}, + {.res = P_SPORT0_DTSEC, .offset = 1}, + {.res = P_SPORT0_DRSEC, .offset = 1}, + {.res = P_CAN0_RX, .offset = 1}, + {.res = P_CAN0_TX, .offset = 1}, + {.res = P_SPI0_SSEL7, .offset = 1}, + {.res = P_SPORT0_TFS, .offset = 0}, + {.res = P_SPORT0_DTPRI, .offset = 0}, + {.res = P_SPI0_SSEL2, .offset = 0}, + {.res = P_SPI0_SSEL3, .offset = 0}, +}; + +static void portmux_setup(unsigned short per) +{ + u16 y, offset, muxreg; + u16 function = P_FUNCT2MUX(per); + + for (y = 0; y < ARRAY_SIZE(port_mux_lut); y++) { + if (port_mux_lut[y].res == per) { + + /* SET PORTMUX REG */ + + offset = port_mux_lut[y].offset; + muxreg = bfin_read_PORT_MUX(); + + if (offset != 1) + muxreg &= ~(1 << offset); + else + muxreg &= ~(3 << 1); + + muxreg |= (function << offset); + bfin_write_PORT_MUX(muxreg); + } + } +} +#elif defined(CONFIG_BF54x) +inline void portmux_setup(unsigned short per) +{ + u32 pmux; + u16 ident = P_IDENT(per); + u16 function = P_FUNCT2MUX(per); + + pmux = gpio_array[gpio_bank(ident)]->port_mux; + + pmux &= ~(0x3 << (2 * gpio_sub_n(ident))); + pmux |= (function & 0x3) << (2 * gpio_sub_n(ident)); + + gpio_array[gpio_bank(ident)]->port_mux = pmux; +} + +inline u16 get_portmux(unsigned short per) +{ + u32 pmux; + u16 ident = P_IDENT(per); + + pmux = gpio_array[gpio_bank(ident)]->port_mux; + + return (pmux >> (2 * gpio_sub_n(ident)) & 0x3); +} +#elif defined(CONFIG_BF52x) || defined(CONFIG_BF51x) +inline void portmux_setup(unsigned short per) +{ + u16 pmux, ident = P_IDENT(per), function = P_FUNCT2MUX(per); + u8 offset = pmux_offset[gpio_bank(ident)][gpio_sub_n(ident)]; + + pmux = *port_mux[gpio_bank(ident)]; + pmux &= ~(3 << offset); + pmux |= (function & 3) << offset; + *port_mux[gpio_bank(ident)] = pmux; + SSYNC(); +} +#else +# define portmux_setup(...) do { } while (0) +#endif + +#ifndef CONFIG_BF54x +/*********************************************************** +* +* FUNCTIONS: Blackfin General Purpose Ports Access Functions +* +* INPUTS/OUTPUTS: +* gpio - GPIO Number between 0 and MAX_BLACKFIN_GPIOS +* +* +* DESCRIPTION: These functions abstract direct register access +* to Blackfin processor General Purpose +* Ports Regsiters +* +* CAUTION: These functions do not belong to the GPIO Driver API +************************************************************* +* MODIFICATION HISTORY : +**************************************************************/ + +/* Set a specific bit */ + +#define SET_GPIO(name) \ +void set_gpio_ ## name(unsigned gpio, unsigned short arg) \ +{ \ + unsigned long flags; \ + local_irq_save(flags); \ + if (arg) \ + gpio_array[gpio_bank(gpio)]->name |= gpio_bit(gpio); \ + else \ + gpio_array[gpio_bank(gpio)]->name &= ~gpio_bit(gpio); \ + AWA_DUMMY_READ(name); \ + local_irq_restore(flags); \ +} + +SET_GPIO(dir) /* set_gpio_dir() */ +SET_GPIO(inen) /* set_gpio_inen() */ +SET_GPIO(polar) /* set_gpio_polar() */ +SET_GPIO(edge) /* set_gpio_edge() */ +SET_GPIO(both) /* set_gpio_both() */ + + +#define SET_GPIO_SC(name) \ +void set_gpio_ ## name(unsigned gpio, unsigned short arg) \ +{ \ + unsigned long flags; \ + if (ANOMALY_05000311 || ANOMALY_05000323) \ + local_irq_save(flags); \ + if (arg) \ + gpio_array[gpio_bank(gpio)]->name ## _set = gpio_bit(gpio); \ + else \ + gpio_array[gpio_bank(gpio)]->name ## _clear = gpio_bit(gpio); \ + if (ANOMALY_05000311 || ANOMALY_05000323) { \ + AWA_DUMMY_READ(name); \ + local_irq_restore(flags); \ + } \ +} + +SET_GPIO_SC(maska) +SET_GPIO_SC(maskb) +SET_GPIO_SC(data) + +void set_gpio_toggle(unsigned gpio) +{ + unsigned long flags; + if (ANOMALY_05000311 || ANOMALY_05000323) + local_irq_save(flags); + gpio_array[gpio_bank(gpio)]->toggle = gpio_bit(gpio); + if (ANOMALY_05000311 || ANOMALY_05000323) { + AWA_DUMMY_READ(toggle); + local_irq_restore(flags); + } +} + +/* Set current PORT date (16-bit word) */ + +#define SET_GPIO_P(name) \ +void set_gpiop_ ## name(unsigned gpio, unsigned short arg) \ +{ \ + unsigned long flags; \ + if (ANOMALY_05000311 || ANOMALY_05000323) \ + local_irq_save(flags); \ + gpio_array[gpio_bank(gpio)]->name = arg; \ + if (ANOMALY_05000311 || ANOMALY_05000323) { \ + AWA_DUMMY_READ(name); \ + local_irq_restore(flags); \ + } \ +} + +SET_GPIO_P(data) +SET_GPIO_P(dir) +SET_GPIO_P(inen) +SET_GPIO_P(polar) +SET_GPIO_P(edge) +SET_GPIO_P(both) +SET_GPIO_P(maska) +SET_GPIO_P(maskb) + +/* Get a specific bit */ +#define GET_GPIO(name) \ +unsigned short get_gpio_ ## name(unsigned gpio) \ +{ \ + unsigned long flags; \ + unsigned short ret; \ + if (ANOMALY_05000311 || ANOMALY_05000323) \ + local_irq_save(flags); \ + ret = 0x01 & (gpio_array[gpio_bank(gpio)]->name >> gpio_sub_n(gpio)); \ + if (ANOMALY_05000311 || ANOMALY_05000323) { \ + AWA_DUMMY_READ(name); \ + local_irq_restore(flags); \ + } \ + return ret; \ +} + +GET_GPIO(data) +GET_GPIO(dir) +GET_GPIO(inen) +GET_GPIO(polar) +GET_GPIO(edge) +GET_GPIO(both) +GET_GPIO(maska) +GET_GPIO(maskb) + +/* Get current PORT date (16-bit word) */ + +#define GET_GPIO_P(name) \ +unsigned short get_gpiop_ ## name(unsigned gpio) \ +{ \ + unsigned long flags; \ + unsigned short ret; \ + if (ANOMALY_05000311 || ANOMALY_05000323) \ + local_irq_save(flags); \ + ret = (gpio_array[gpio_bank(gpio)]->name); \ + if (ANOMALY_05000311 || ANOMALY_05000323) { \ + AWA_DUMMY_READ(name); \ + local_irq_restore(flags); \ + } \ + return ret; \ +} + +GET_GPIO_P(data) +GET_GPIO_P(dir) +GET_GPIO_P(inen) +GET_GPIO_P(polar) +GET_GPIO_P(edge) +GET_GPIO_P(both) +GET_GPIO_P(maska) +GET_GPIO_P(maskb) + +#else /* CONFIG_BF54x */ + +unsigned short get_gpio_dir(unsigned gpio) +{ + return (0x01 & (gpio_array[gpio_bank(gpio)]->dir_clear >> gpio_sub_n(gpio))); +} + +#endif /* CONFIG_BF54x */ + +/*********************************************************** +* +* FUNCTIONS: Blackfin Peripheral Resource Allocation +* and PortMux Setup +* +* INPUTS/OUTPUTS: +* per Peripheral Identifier +* label String +* +* DESCRIPTION: Blackfin Peripheral Resource Allocation and Setup API +* +* CAUTION: +************************************************************* +* MODIFICATION HISTORY : +**************************************************************/ + +int peripheral_request(unsigned short per, const char *label) +{ + unsigned short ident = P_IDENT(per); + + /* + * Don't cares are pins with only one dedicated function + */ + + if (per & P_DONTCARE) + return 0; + + if (!(per & P_DEFINED)) + return -ENODEV; + + BUG_ON(ident >= MAX_RESOURCES); + + /* If a pin can be muxed as either GPIO or peripheral, make + * sure it is not already a GPIO pin when we request it. + */ + if (unlikely(!check_gpio(ident) && is_reserved(gpio, ident, 1))) { + printf("%s: Peripheral %d is already reserved as GPIO by %s !\n", + __func__, ident, get_label(ident)); + return -EBUSY; + } + + if (unlikely(is_reserved(peri, ident, 1))) { + + /* + * Pin functions like AMC address strobes my + * be requested and used by several drivers + */ + +#ifdef CONFIG_BF54x + if (!((per & P_MAYSHARE) && get_portmux(per) == P_FUNCT2MUX(per))) { +#else + if (!(per & P_MAYSHARE)) { +#endif + /* + * Allow that the identical pin function can + * be requested from the same driver twice + */ + + if (cmp_label(ident, label) == 0) + goto anyway; + + printf("%s: Peripheral %d function %d is already reserved by %s !\n", + __func__, ident, P_FUNCT2MUX(per), get_label(ident)); + return -EBUSY; + } + } + + anyway: + reserve(peri, ident); + + portmux_setup(per); + port_setup(ident, PERIPHERAL_USAGE); + + set_label(ident, label); + + return 0; +} + +int peripheral_request_list(const unsigned short per[], const char *label) +{ + u16 cnt; + int ret; + + for (cnt = 0; per[cnt] != 0; cnt++) { + + ret = peripheral_request(per[cnt], label); + + if (ret < 0) { + for ( ; cnt > 0; cnt--) + peripheral_free(per[cnt - 1]); + + return ret; + } + } + + return 0; +} + +void peripheral_free(unsigned short per) +{ + unsigned short ident = P_IDENT(per); + + if (per & P_DONTCARE) + return; + + if (!(per & P_DEFINED)) + return; + + if (unlikely(!is_reserved(peri, ident, 0))) + return; + + if (!(per & P_MAYSHARE)) + port_setup(ident, GPIO_USAGE); + + unreserve(peri, ident); + + set_label(ident, "free"); +} + +void peripheral_free_list(const unsigned short per[]) +{ + u16 cnt; + for (cnt = 0; per[cnt] != 0; cnt++) + peripheral_free(per[cnt]); +} + +/*********************************************************** +* +* FUNCTIONS: Blackfin GPIO Driver +* +* INPUTS/OUTPUTS: +* gpio PIO Number between 0 and MAX_BLACKFIN_GPIOS +* label String +* +* DESCRIPTION: Blackfin GPIO Driver API +* +* CAUTION: +************************************************************* +* MODIFICATION HISTORY : +**************************************************************/ + +int bfin_gpio_request(unsigned gpio, const char *label) +{ + if (check_gpio(gpio) < 0) + return -EINVAL; + + /* + * Allow that the identical GPIO can + * be requested from the same driver twice + * Do nothing and return - + */ + + if (cmp_label(gpio, label) == 0) + return 0; + + if (unlikely(is_reserved(gpio, gpio, 1))) { + printf("bfin-gpio: GPIO %d is already reserved by %s !\n", + gpio, get_label(gpio)); + return -EBUSY; + } + if (unlikely(is_reserved(peri, gpio, 1))) { + printf("bfin-gpio: GPIO %d is already reserved as Peripheral by %s !\n", + gpio, get_label(gpio)); + return -EBUSY; + } +#ifndef CONFIG_BF54x + else { /* Reset POLAR setting when acquiring a gpio for the first time */ + set_gpio_polar(gpio, 0); + } +#endif + + reserve(gpio, gpio); + set_label(gpio, label); + + port_setup(gpio, GPIO_USAGE); + + return 0; +} + +void bfin_gpio_free(unsigned gpio) +{ + if (check_gpio(gpio) < 0) + return; + + if (unlikely(!is_reserved(gpio, gpio, 0))) { + gpio_error(gpio); + return; + } + + unreserve(gpio, gpio); + + set_label(gpio, "free"); +} + +#ifdef BFIN_SPECIAL_GPIO_BANKS +DECLARE_RESERVED_MAP(special_gpio, gpio_bank(MAX_RESOURCES)); + +int bfin_special_gpio_request(unsigned gpio, const char *label) +{ + /* + * Allow that the identical GPIO can + * be requested from the same driver twice + * Do nothing and return - + */ + + if (cmp_label(gpio, label) == 0) + return 0; + + if (unlikely(is_reserved(special_gpio, gpio, 1))) { + printf("bfin-gpio: GPIO %d is already reserved by %s !\n", + gpio, get_label(gpio)); + return -EBUSY; + } + if (unlikely(is_reserved(peri, gpio, 1))) { + printf("bfin-gpio: GPIO %d is already reserved as Peripheral by %s !\n", + gpio, get_label(gpio)); + + return -EBUSY; + } + + reserve(special_gpio, gpio); + reserve(peri, gpio); + + set_label(gpio, label); + port_setup(gpio, GPIO_USAGE); + + return 0; +} + +void bfin_special_gpio_free(unsigned gpio) +{ + if (unlikely(!is_reserved(special_gpio, gpio, 0))) { + gpio_error(gpio); + return; + } + + reserve(special_gpio, gpio); + reserve(peri, gpio); + set_label(gpio, "free"); +} +#endif + +static inline void __bfin_gpio_direction_input(unsigned gpio) +{ +#ifdef CONFIG_BF54x + gpio_array[gpio_bank(gpio)]->dir_clear = gpio_bit(gpio); +#else + gpio_array[gpio_bank(gpio)]->dir &= ~gpio_bit(gpio); +#endif + gpio_array[gpio_bank(gpio)]->inen |= gpio_bit(gpio); +} + +int bfin_gpio_direction_input(unsigned gpio) +{ + unsigned long flags; + + if (!is_reserved(gpio, gpio, 0)) { + gpio_error(gpio); + return -EINVAL; + } + + local_irq_save(flags); + __bfin_gpio_direction_input(gpio); + AWA_DUMMY_READ(inen); + local_irq_restore(flags); + + return 0; +} + +void bfin_gpio_toggle_value(unsigned gpio) +{ +#ifdef CONFIG_BF54x + gpio_set_value(gpio, !gpio_get_value(gpio)); +#else + gpio_array[gpio_bank(gpio)]->toggle = gpio_bit(gpio); +#endif +} + +void bfin_gpio_set_value(unsigned gpio, int arg) +{ + if (arg) + gpio_array[gpio_bank(gpio)]->data_set = gpio_bit(gpio); + else + gpio_array[gpio_bank(gpio)]->data_clear = gpio_bit(gpio); +} + +int bfin_gpio_direction_output(unsigned gpio, int value) +{ + unsigned long flags; + + if (!is_reserved(gpio, gpio, 0)) { + gpio_error(gpio); + return -EINVAL; + } + + local_irq_save(flags); + + gpio_array[gpio_bank(gpio)]->inen &= ~gpio_bit(gpio); + gpio_set_value(gpio, value); +#ifdef CONFIG_BF54x + gpio_array[gpio_bank(gpio)]->dir_set = gpio_bit(gpio); +#else + gpio_array[gpio_bank(gpio)]->dir |= gpio_bit(gpio); +#endif + + AWA_DUMMY_READ(dir); + local_irq_restore(flags); + + return 0; +} + +int bfin_gpio_get_value(unsigned gpio) +{ +#ifdef CONFIG_BF54x + return (1 & (gpio_array[gpio_bank(gpio)]->data >> gpio_sub_n(gpio))); +#else + unsigned long flags; + + if (unlikely(get_gpio_edge(gpio))) { + int ret; + local_irq_save(flags); + set_gpio_edge(gpio, 0); + ret = get_gpio_data(gpio); + set_gpio_edge(gpio, 1); + local_irq_restore(flags); + return ret; + } else + return get_gpio_data(gpio); +#endif +} + +/* If we are booting from SPI and our board lacks a strong enough pull up, + * the core can reset and execute the bootrom faster than the resistor can + * pull the signal logically high. To work around this (common) error in + * board design, we explicitly set the pin back to GPIO mode, force /CS + * high, and wait for the electrons to do their thing. + * + * This function only makes sense to be called from reset code, but it + * lives here as we need to force all the GPIO states w/out going through + * BUG() checks and such. + */ +void bfin_reset_boot_spi_cs(unsigned short pin) +{ + unsigned short gpio = P_IDENT(pin); + port_setup(gpio, GPIO_USAGE); + gpio_array[gpio_bank(gpio)]->data_set = gpio_bit(gpio); + AWA_DUMMY_READ(data_set); + udelay(1); +} + +#ifdef CONFIG_BFIN_GPIO_TRACK +void bfin_gpio_labels(void) +{ + int c, gpio; + + for (c = 0; c < MAX_RESOURCES; c++) { + gpio = is_reserved(gpio, c, 1); + if (!check_gpio(c) && gpio) + printf("GPIO_%d:\t%s\tGPIO %s\n", c, + get_label(c), + get_gpio_dir(c) ? "OUTPUT" : "INPUT"); + else if (is_reserved(peri, c, 1)) + printf("GPIO_%d:\t%s\tPeripheral\n", c, get_label(c)); + else + continue; + } +} +#endif diff --git a/arch/blackfin/include/asm/gpio.h b/arch/blackfin/include/asm/gpio.h new file mode 100644 index 0000000..b650ef0 --- /dev/null +++ b/arch/blackfin/include/asm/gpio.h @@ -0,0 +1,201 @@ +/* + * Copyright 2006-2009 Analog Devices Inc. + * + * Licensed under the GPL-2 or later. + */ + +#ifndef __ARCH_BLACKFIN_GPIO_H__ +#define __ARCH_BLACKFIN_GPIO_H__ + +#define gpio_bank(x) ((x) >> 4) +#define gpio_bit(x) (1<<((x) & 0xF)) +#define gpio_sub_n(x) ((x) & 0xF) + +#define GPIO_BANKSIZE 16 +#define GPIO_BANK_NUM DIV_ROUND_UP(MAX_BLACKFIN_GPIOS, GPIO_BANKSIZE) + +#define GPIO_0 0 +#define GPIO_1 1 +#define GPIO_2 2 +#define GPIO_3 3 +#define GPIO_4 4 +#define GPIO_5 5 +#define GPIO_6 6 +#define GPIO_7 7 +#define GPIO_8 8 +#define GPIO_9 9 +#define GPIO_10 10 +#define GPIO_11 11 +#define GPIO_12 12 +#define GPIO_13 13 +#define GPIO_14 14 +#define GPIO_15 15 +#define GPIO_16 16 +#define GPIO_17 17 +#define GPIO_18 18 +#define GPIO_19 19 +#define GPIO_20 20 +#define GPIO_21 21 +#define GPIO_22 22 +#define GPIO_23 23 +#define GPIO_24 24 +#define GPIO_25 25 +#define GPIO_26 26 +#define GPIO_27 27 +#define GPIO_28 28 +#define GPIO_29 29 +#define GPIO_30 30 +#define GPIO_31 31 +#define GPIO_32 32 +#define GPIO_33 33 +#define GPIO_34 34 +#define GPIO_35 35 +#define GPIO_36 36 +#define GPIO_37 37 +#define GPIO_38 38 +#define GPIO_39 39 +#define GPIO_40 40 +#define GPIO_41 41 +#define GPIO_42 42 +#define GPIO_43 43 +#define GPIO_44 44 +#define GPIO_45 45 +#define GPIO_46 46 +#define GPIO_47 47 + +#define PERIPHERAL_USAGE 1 +#define GPIO_USAGE 0 + +#ifndef __ASSEMBLY__ + +#ifndef CONFIG_BF54x +void set_gpio_dir(unsigned, unsigned short); +void set_gpio_inen(unsigned, unsigned short); +void set_gpio_polar(unsigned, unsigned short); +void set_gpio_edge(unsigned, unsigned short); +void set_gpio_both(unsigned, unsigned short); +void set_gpio_data(unsigned, unsigned short); +void set_gpio_maska(unsigned, unsigned short); +void set_gpio_maskb(unsigned, unsigned short); +void set_gpio_toggle(unsigned); +void set_gpiop_dir(unsigned, unsigned short); +void set_gpiop_inen(unsigned, unsigned short); +void set_gpiop_polar(unsigned, unsigned short); +void set_gpiop_edge(unsigned, unsigned short); +void set_gpiop_both(unsigned, unsigned short); +void set_gpiop_data(unsigned, unsigned short); +void set_gpiop_maska(unsigned, unsigned short); +void set_gpiop_maskb(unsigned, unsigned short); +unsigned short get_gpio_dir(unsigned); +unsigned short get_gpio_inen(unsigned); +unsigned short get_gpio_polar(unsigned); +unsigned short get_gpio_edge(unsigned); +unsigned short get_gpio_both(unsigned); +unsigned short get_gpio_maska(unsigned); +unsigned short get_gpio_maskb(unsigned); +unsigned short get_gpio_data(unsigned); +unsigned short get_gpiop_dir(unsigned); +unsigned short get_gpiop_inen(unsigned); +unsigned short get_gpiop_polar(unsigned); +unsigned short get_gpiop_edge(unsigned); +unsigned short get_gpiop_both(unsigned); +unsigned short get_gpiop_maska(unsigned); +unsigned short get_gpiop_maskb(unsigned); +unsigned short get_gpiop_data(unsigned); + +struct gpio_port_t { + unsigned short data; + unsigned short dummy1; + unsigned short data_clear; + unsigned short dummy2; + unsigned short data_set; + unsigned short dummy3; + unsigned short toggle; + unsigned short dummy4; + unsigned short maska; + unsigned short dummy5; + unsigned short maska_clear; + unsigned short dummy6; + unsigned short maska_set; + unsigned short dummy7; + unsigned short maska_toggle; + unsigned short dummy8; + unsigned short maskb; + unsigned short dummy9; + unsigned short maskb_clear; + unsigned short dummy10; + unsigned short maskb_set; + unsigned short dummy11; + unsigned short maskb_toggle; + unsigned short dummy12; + unsigned short dir; + unsigned short dummy13; + unsigned short polar; + unsigned short dummy14; + unsigned short edge; + unsigned short dummy15; + unsigned short both; + unsigned short dummy16; + unsigned short inen; +}; +#endif + +#ifdef CONFIG_BFIN_GPIO_TRACK +void bfin_gpio_labels(void); +#else +#define bfin_gpio_labels() +#define bfin_gpio_request(gpio, label) bfin_gpio_request(gpio) +#define bfin_special_gpio_request(gpio, label) bfin_special_gpio_request(gpio) +#endif + +#ifdef BFIN_SPECIAL_GPIO_BANKS +void bfin_special_gpio_free(unsigned gpio); +int bfin_special_gpio_request(unsigned gpio, const char *label); +#endif + +int bfin_gpio_request(unsigned gpio, const char *label); +void bfin_gpio_free(unsigned gpio); +int bfin_gpio_direction_input(unsigned gpio); +int bfin_gpio_direction_output(unsigned gpio, int value); +int bfin_gpio_get_value(unsigned gpio); +void bfin_gpio_set_value(unsigned gpio, int value); +void bfin_gpio_toggle_value(unsigned gpio); + +static inline int gpio_request(unsigned gpio, const char *label) +{ + return bfin_gpio_request(gpio, label); +} + +static inline void gpio_free(unsigned gpio) +{ + return bfin_gpio_free(gpio); +} + +static inline int gpio_direction_input(unsigned gpio) +{ + return bfin_gpio_direction_input(gpio); +} + +static inline int gpio_direction_output(unsigned gpio, int value) +{ + return bfin_gpio_direction_output(gpio, value); +} + +static inline int gpio_get_value(unsigned gpio) +{ + return bfin_gpio_get_value(gpio); +} + +static inline void gpio_set_value(unsigned gpio, int value) +{ + return bfin_gpio_set_value(gpio, value); +} + +static inline int gpio_is_valid(int number) +{ + return number >= 0 && number < MAX_BLACKFIN_GPIOS; +} + +#endif /* __ASSEMBLY__ */ + +#endif /* __ARCH_BLACKFIN_GPIO_H__ */ diff --git a/arch/blackfin/include/asm/mach-bf527/def_local.h b/arch/blackfin/include/asm/mach-bf527/def_local.h index 81eca83..1ffa239 100644 --- a/arch/blackfin/include/asm/mach-bf527/def_local.h +++ b/arch/blackfin/include/asm/mach-bf527/def_local.h @@ -1,2 +1,6 @@ +#include "gpio.h" #include "mem_map.h" +#include "portmux.h" #include "ports.h" + +#define CONFIG_BF52x 1 /* Linux glue */ diff --git a/arch/blackfin/include/asm/mach-bf527/gpio.h b/arch/blackfin/include/asm/mach-bf527/gpio.h new file mode 100644 index 0000000..f80c299 --- /dev/null +++ b/arch/blackfin/include/asm/mach-bf527/gpio.h @@ -0,0 +1,65 @@ +/* + * Copyright (C) 2008 Analog Devices Inc. + * Licensed under the GPL-2 or later. + */ + + +#ifndef _MACH_GPIO_H_ +#define _MACH_GPIO_H_ + +#define MAX_BLACKFIN_GPIOS 48 + +#define GPIO_PF0 0 +#define GPIO_PF1 1 +#define GPIO_PF2 2 +#define GPIO_PF3 3 +#define GPIO_PF4 4 +#define GPIO_PF5 5 +#define GPIO_PF6 6 +#define GPIO_PF7 7 +#define GPIO_PF8 8 +#define GPIO_PF9 9 +#define GPIO_PF10 10 +#define GPIO_PF11 11 +#define GPIO_PF12 12 +#define GPIO_PF13 13 +#define GPIO_PF14 14 +#define GPIO_PF15 15 +#define GPIO_PG0 16 +#define GPIO_PG1 17 +#define GPIO_PG2 18 +#define GPIO_PG3 19 +#define GPIO_PG4 20 +#define GPIO_PG5 21 +#define GPIO_PG6 22 +#define GPIO_PG7 23 +#define GPIO_PG8 24 +#define GPIO_PG9 25 +#define GPIO_PG10 26 +#define GPIO_PG11 27 +#define GPIO_PG12 28 +#define GPIO_PG13 29 +#define GPIO_PG14 30 +#define GPIO_PG15 31 +#define GPIO_PH0 32 +#define GPIO_PH1 33 +#define GPIO_PH2 34 +#define GPIO_PH3 35 +#define GPIO_PH4 36 +#define GPIO_PH5 37 +#define GPIO_PH6 38 +#define GPIO_PH7 39 +#define GPIO_PH8 40 +#define GPIO_PH9 41 +#define GPIO_PH10 42 +#define GPIO_PH11 43 +#define GPIO_PH12 44 +#define GPIO_PH13 45 +#define GPIO_PH14 46 +#define GPIO_PH15 47 + +#define PORT_F GPIO_PF0 +#define PORT_G GPIO_PG0 +#define PORT_H GPIO_PH0 + +#endif /* _MACH_GPIO_H_ */ diff --git a/arch/blackfin/include/asm/mach-bf527/portmux.h b/arch/blackfin/include/asm/mach-bf527/portmux.h new file mode 100644 index 0000000..aa16558 --- /dev/null +++ b/arch/blackfin/include/asm/mach-bf527/portmux.h @@ -0,0 +1,220 @@ +/* + * Copyright 2007-2009 Analog Devices Inc. + * + * Licensed under the GPL-2 or later + */ + +#ifndef _MACH_PORTMUX_H_ +#define _MACH_PORTMUX_H_ + +#define MAX_RESOURCES MAX_BLACKFIN_GPIOS + +#define P_PPI0_D0 (P_DEFINED | P_IDENT(GPIO_PF0) | P_FUNCT(0)) +#define P_PPI0_D1 (P_DEFINED | P_IDENT(GPIO_PF1) | P_FUNCT(0)) +#define P_PPI0_D2 (P_DEFINED | P_IDENT(GPIO_PF2) | P_FUNCT(0)) +#define P_PPI0_D3 (P_DEFINED | P_IDENT(GPIO_PF3) | P_FUNCT(0)) +#define P_PPI0_D4 (P_DEFINED | P_IDENT(GPIO_PF4) | P_FUNCT(0)) +#define P_PPI0_D5 (P_DEFINED | P_IDENT(GPIO_PF5) | P_FUNCT(0)) +#define P_PPI0_D6 (P_DEFINED | P_IDENT(GPIO_PF6) | P_FUNCT(0)) +#define P_PPI0_D7 (P_DEFINED | P_IDENT(GPIO_PF7) | P_FUNCT(0)) +#define P_PPI0_D8 (P_DEFINED | P_IDENT(GPIO_PF8) | P_FUNCT(0)) +#define P_PPI0_D9 (P_DEFINED | P_IDENT(GPIO_PF9) | P_FUNCT(0)) +#define P_PPI0_D10 (P_DEFINED | P_IDENT(GPIO_PF10) | P_FUNCT(0)) +#define P_PPI0_D11 (P_DEFINED | P_IDENT(GPIO_PF11) | P_FUNCT(0)) +#define P_PPI0_D12 (P_DEFINED | P_IDENT(GPIO_PF12) | P_FUNCT(0)) +#define P_PPI0_D13 (P_DEFINED | P_IDENT(GPIO_PF13) | P_FUNCT(0)) +#define P_PPI0_D14 (P_DEFINED | P_IDENT(GPIO_PF14) | P_FUNCT(0)) +#define P_PPI0_D15 (P_DEFINED | P_IDENT(GPIO_PF15) | P_FUNCT(0)) + +#if !defined(CONFIG_BF527_SPORT0_PORTG) +#define P_SPORT0_DRPRI (P_DEFINED | P_IDENT(GPIO_PF0) | P_FUNCT(1)) +#define P_SPORT0_RFS (P_DEFINED | P_IDENT(GPIO_PF1) | P_FUNCT(1)) +#define P_SPORT0_RSCLK (P_DEFINED | P_IDENT(GPIO_PF2) | P_FUNCT(1)) +#define P_SPORT0_DTPRI (P_DEFINED | P_IDENT(GPIO_PF3) | P_FUNCT(1)) +#define P_SPORT0_TFS (P_DEFINED | P_IDENT(GPIO_PF4) | P_FUNCT(1)) +#define P_SPORT0_TSCLK (P_DEFINED | P_IDENT(GPIO_PF5) | P_FUNCT(1)) +#define P_SPORT0_DTSEC (P_DEFINED | P_IDENT(GPIO_PF6) | P_FUNCT(1)) +#define P_SPORT0_DRSEC (P_DEFINED | P_IDENT(GPIO_PF7) | P_FUNCT(1)) +#else +#define P_SPORT0_DTPRI (P_DEFINED | P_IDENT(GPIO_PG6) | P_FUNCT(0)) +#define P_SPORT0_DRSEC (P_DEFINED | P_IDENT(GPIO_PG3) | P_FUNCT(1)) +#define P_SPORT0_DTSEC (P_DEFINED | P_IDENT(GPIO_PG4) | P_FUNCT(1)) +#define P_SPORT0_DRPRI (P_DEFINED | P_IDENT(GPIO_PG7) | P_FUNCT(1)) +#define P_SPORT0_RFS (P_DEFINED | P_IDENT(GPIO_PG8) | P_FUNCT(1)) +#define P_SPORT0_RSCLK (P_DEFINED | P_IDENT(GPIO_PG9) | P_FUNCT(1)) +#if !defined(CONFIG_BF527_SPORT0_TSCLK_PG14) +#define P_SPORT0_TSCLK (P_DEFINED | P_IDENT(GPIO_PG10) | P_FUNCT(1)) +#else +#define P_SPORT0_TSCLK (P_DEFINED | P_IDENT(GPIO_PG14) | P_FUNCT(0)) +#endif +#define P_SPORT0_TFS (P_DEFINED | P_IDENT(GPIO_PG15) | P_FUNCT(0)) +#endif + +#define P_SPORT1_DRPRI (P_DEFINED | P_IDENT(GPIO_PF8) | P_FUNCT(1)) +#define P_SPORT1_RSCLK (P_DEFINED | P_IDENT(GPIO_PF9) | P_FUNCT(1)) +#define P_SPORT1_RFS (P_DEFINED | P_IDENT(GPIO_PF10) | P_FUNCT(1)) +#define P_SPORT1_TFS (P_DEFINED | P_IDENT(GPIO_PF11) | P_FUNCT(1)) +#define P_SPORT1_DTPRI (P_DEFINED | P_IDENT(GPIO_PF12) | P_FUNCT(1)) +#define P_SPORT1_TSCLK (P_DEFINED | P_IDENT(GPIO_PF13) | P_FUNCT(1)) +#define P_SPORT1_DTSEC (P_DEFINED | P_IDENT(GPIO_PF14) | P_FUNCT(1)) +#define P_SPORT1_DRSEC (P_DEFINED | P_IDENT(GPIO_PF15) | P_FUNCT(1)) + +#define P_SPI0_SSEL6 (P_DEFINED | P_IDENT(GPIO_PF9) | P_FUNCT(2)) +#define P_SPI0_SSEL7 (P_DEFINED | P_IDENT(GPIO_PF10) | P_FUNCT(2)) + +#define P_SPI0_SSEL2 (P_DEFINED | P_IDENT(GPIO_PF12) | P_FUNCT(2)) +#define P_SPI0_SSEL3 (P_DEFINED | P_IDENT(GPIO_PF13) | P_FUNCT(2)) + +#if !defined(CONFIG_BF527_UART1_PORTG) +#define P_UART1_TX (P_DEFINED | P_IDENT(GPIO_PF14) | P_FUNCT(2)) +#define P_UART1_RX (P_DEFINED | P_IDENT(GPIO_PF15) | P_FUNCT(2)) +#else +#define P_UART1_TX (P_DEFINED | P_IDENT(GPIO_PG12) | P_FUNCT(1)) +#define P_UART1_RX (P_DEFINED | P_IDENT(GPIO_PG13) | P_FUNCT(1)) +#endif + +#define P_CNT_CZM (P_DEFINED | P_IDENT(GPIO_PF11) | P_FUNCT(3)) +#define P_CNT_CDG (P_DEFINED | P_IDENT(GPIO_PF12) | P_FUNCT(3)) +#define P_CNT_CUD (P_DEFINED | P_IDENT(GPIO_PF13) | P_FUNCT(3)) + +#define P_HWAIT (P_DONTCARE) + +#define GPIO_DEFAULT_BOOT_SPI_CS GPIO_PG1 +#define P_DEFAULT_BOOT_SPI_CS P_SPI0_SSEL1 + +#define P_SPI0_SS (P_DEFINED | P_IDENT(GPIO_PG1) | P_FUNCT(0)) +#define P_SPI0_SSEL1 (P_DEFINED | P_IDENT(GPIO_PG1) | P_FUNCT(2)) +#define P_SPI0_SCK (P_DEFINED | P_IDENT(GPIO_PG2) | P_FUNCT(2)) +#define P_SPI0_MISO (P_DEFINED | P_IDENT(GPIO_PG3) | P_FUNCT(2)) +#define P_SPI0_MOSI (P_DEFINED | P_IDENT(GPIO_PG4) | P_FUNCT(2)) +#define P_TMR1 (P_DEFINED | P_IDENT(GPIO_PG5) | P_FUNCT(0)) +#define P_PPI0_FS2 (P_DEFINED | P_IDENT(GPIO_PG5) | P_FUNCT(0)) +#define P_TMR3 (P_DEFINED | P_IDENT(GPIO_PG7) | P_FUNCT(0)) +#define P_TMR4 (P_DEFINED | P_IDENT(GPIO_PG8) | P_FUNCT(0)) +#define P_TMR5 (P_DEFINED | P_IDENT(GPIO_PG9) | P_FUNCT(0)) +#define P_TMR6 (P_DEFINED | P_IDENT(GPIO_PG10) | P_FUNCT(0)) +/* #define P_TMR7 (P_DEFINED | P_IDENT(GPIO_PG11) | P_FUNCT(0)) */ +#define P_DMAR1 (P_DEFINED | P_IDENT(GPIO_PG12) | P_FUNCT(0)) +#define P_DMAR0 (P_DEFINED | P_IDENT(GPIO_PG13) | P_FUNCT(0)) +#define P_TMR2 (P_DEFINED | P_IDENT(GPIO_PG6) | P_FUNCT(1)) +#define P_TMR7 (P_DEFINED | P_IDENT(GPIO_PG11) | P_FUNCT(1)) +#define P_MDC (P_DEFINED | P_IDENT(GPIO_PG14) | P_FUNCT(1)) +#define P_RMII0_MDINT (P_DEFINED | P_IDENT(GPIO_PG15) | P_FUNCT(1)) +#define P_MII0_PHYINT (P_DEFINED | P_IDENT(GPIO_PG15) | P_FUNCT(1)) + +#define P_PPI0_FS3 (P_DEFINED | P_IDENT(GPIO_PG6) | P_FUNCT(2)) +#define P_UART0_TX (P_DEFINED | P_IDENT(GPIO_PG7) | P_FUNCT(2)) +#define P_UART0_RX (P_DEFINED | P_IDENT(GPIO_PG8) | P_FUNCT(2)) + +#define P_HOST_WR (P_DEFINED | P_IDENT(GPIO_PG11) | P_FUNCT(2)) +#define P_HOST_ACK (P_DEFINED | P_IDENT(GPIO_PG12) | P_FUNCT(2)) +#define P_HOST_ADDR (P_DEFINED | P_IDENT(GPIO_PG13) | P_FUNCT(2)) +#define P_HOST_RD (P_DEFINED | P_IDENT(GPIO_PG14) | P_FUNCT(2)) +#define P_HOST_CE (P_DEFINED | P_IDENT(GPIO_PG15) | P_FUNCT(2)) + +#if defined(CONFIG_BF527_NAND_D_PORTF) +#define P_NAND_D0 (P_DEFINED | P_IDENT(GPIO_PF0) | P_FUNCT(2)) +#define P_NAND_D1 (P_DEFINED | P_IDENT(GPIO_PF1) | P_FUNCT(2)) +#define P_NAND_D2 (P_DEFINED | P_IDENT(GPIO_PF2) | P_FUNCT(2)) +#define P_NAND_D3 (P_DEFINED | P_IDENT(GPIO_PF3) | P_FUNCT(2)) +#define P_NAND_D4 (P_DEFINED | P_IDENT(GPIO_PF4) | P_FUNCT(2)) +#define P_NAND_D5 (P_DEFINED | P_IDENT(GPIO_PF5) | P_FUNCT(2)) +#define P_NAND_D6 (P_DEFINED | P_IDENT(GPIO_PF6) | P_FUNCT(2)) +#define P_NAND_D7 (P_DEFINED | P_IDENT(GPIO_PF7) | P_FUNCT(2)) +#else /*if defined(CONFIG_BF527_NAND_D_PORTH)*/ +#define P_NAND_D0 (P_DEFINED | P_IDENT(GPIO_PH0) | P_FUNCT(0)) +#define P_NAND_D1 (P_DEFINED | P_IDENT(GPIO_PH1) | P_FUNCT(0)) +#define P_NAND_D2 (P_DEFINED | P_IDENT(GPIO_PH2) | P_FUNCT(0)) +#define P_NAND_D3 (P_DEFINED | P_IDENT(GPIO_PH3) | P_FUNCT(0)) +#define P_NAND_D4 (P_DEFINED | P_IDENT(GPIO_PH4) | P_FUNCT(0)) +#define P_NAND_D5 (P_DEFINED | P_IDENT(GPIO_PH5) | P_FUNCT(0)) +#define P_NAND_D6 (P_DEFINED | P_IDENT(GPIO_PH6) | P_FUNCT(0)) +#define P_NAND_D7 (P_DEFINED | P_IDENT(GPIO_PH7) | P_FUNCT(0)) +#endif + +#define P_SPI0_SSEL4 (P_DEFINED | P_IDENT(GPIO_PH8) | P_FUNCT(0)) +#define P_SPI0_SSEL5 (P_DEFINED | P_IDENT(GPIO_PH9) | P_FUNCT(0)) +#define P_NAND_CE (P_DEFINED | P_IDENT(GPIO_PH10) | P_FUNCT(0)) +#define P_NAND_WE (P_DEFINED | P_IDENT(GPIO_PH11) | P_FUNCT(0)) +#define P_NAND_RE (P_DEFINED | P_IDENT(GPIO_PH12) | P_FUNCT(0)) +#define P_NAND_RB (P_DEFINED | P_IDENT(GPIO_PH13) | P_FUNCT(0)) +#define P_NAND_CLE (P_DEFINED | P_IDENT(GPIO_PH14) | P_FUNCT(0)) +#define P_NAND_ALE (P_DEFINED | P_IDENT(GPIO_PH15) | P_FUNCT(0)) + +#define P_HOST_D0 (P_DEFINED | P_IDENT(GPIO_PH0) | P_FUNCT(2)) +#define P_HOST_D1 (P_DEFINED | P_IDENT(GPIO_PH1) | P_FUNCT(2)) +#define P_HOST_D2 (P_DEFINED | P_IDENT(GPIO_PH2) | P_FUNCT(2)) +#define P_HOST_D3 (P_DEFINED | P_IDENT(GPIO_PH3) | P_FUNCT(2)) +#define P_HOST_D4 (P_DEFINED | P_IDENT(GPIO_PH4) | P_FUNCT(2)) +#define P_HOST_D5 (P_DEFINED | P_IDENT(GPIO_PH5) | P_FUNCT(2)) +#define P_HOST_D6 (P_DEFINED | P_IDENT(GPIO_PH6) | P_FUNCT(2)) +#define P_HOST_D7 (P_DEFINED | P_IDENT(GPIO_PH7) | P_FUNCT(2)) +#define P_HOST_D8 (P_DEFINED | P_IDENT(GPIO_PH8) | P_FUNCT(2)) +#define P_HOST_D9 (P_DEFINED | P_IDENT(GPIO_PH9) | P_FUNCT(2)) +#define P_HOST_D10 (P_DEFINED | P_IDENT(GPIO_PH10) | P_FUNCT(2)) +#define P_HOST_D11 (P_DEFINED | P_IDENT(GPIO_PH11) | P_FUNCT(2)) +#define P_HOST_D12 (P_DEFINED | P_IDENT(GPIO_PH12) | P_FUNCT(2)) +#define P_HOST_D13 (P_DEFINED | P_IDENT(GPIO_PH13) | P_FUNCT(2)) +#define P_HOST_D14 (P_DEFINED | P_IDENT(GPIO_PH14) | P_FUNCT(2)) +#define P_HOST_D15 (P_DEFINED | P_IDENT(GPIO_PH15) | P_FUNCT(2)) + +#define P_MII0_ETxD0 (P_DEFINED | P_IDENT(GPIO_PH5) | P_FUNCT(1)) +#define P_MII0_ETxD1 (P_DEFINED | P_IDENT(GPIO_PH7) | P_FUNCT(1)) +#define P_MII0_ETxD2 (P_DEFINED | P_IDENT(GPIO_PH9) | P_FUNCT(1)) +#define P_MII0_ETxD3 (P_DEFINED | P_IDENT(GPIO_PH11) | P_FUNCT(1)) +#define P_MII0_ETxEN (P_DEFINED | P_IDENT(GPIO_PH3) | P_FUNCT(1)) +#define P_MII0_TxCLK (P_DEFINED | P_IDENT(GPIO_PH4) | P_FUNCT(1)) +#define P_MII0_COL (P_DEFINED | P_IDENT(GPIO_PH15) | P_FUNCT(1)) +#define P_MII0_ERxD0 (P_DEFINED | P_IDENT(GPIO_PH6) | P_FUNCT(1)) +#define P_MII0_ERxD1 (P_DEFINED | P_IDENT(GPIO_PH8) | P_FUNCT(1)) +#define P_MII0_ERxD2 (P_DEFINED | P_IDENT(GPIO_PH10) | P_FUNCT(1)) +#define P_MII0_ERxD3 (P_DEFINED | P_IDENT(GPIO_PH12) | P_FUNCT(1)) +#define P_MII0_ERxDV (P_DEFINED | P_IDENT(GPIO_PH14) | P_FUNCT(1)) +#define P_MII0_ERxCLK (P_DEFINED | P_IDENT(GPIO_PH13) | P_FUNCT(1)) +#define P_MII0_ERxER (P_DEFINED | P_IDENT(GPIO_PH1) | P_FUNCT(1)) +#define P_MII0_CRS (P_DEFINED | P_IDENT(GPIO_PH0) | P_FUNCT(1)) +#define P_RMII0_REF_CLK (P_DEFINED | P_IDENT(GPIO_PH4) | P_FUNCT(1)) +#define P_RMII0_CRS_DV (P_DEFINED | P_IDENT(GPIO_PH0) | P_FUNCT(1)) +#define P_MDIO (P_DEFINED | P_IDENT(GPIO_PH2) | P_FUNCT(1)) + +#define P_TWI0_SCL (P_DONTCARE) +#define P_TWI0_SDA (P_DONTCARE) +#define P_PPI0_FS1 (P_DONTCARE) +#define P_TMR0 (P_DONTCARE) +#define P_TMRCLK (P_DONTCARE) +#define P_PPI0_CLK (P_DONTCARE) + +#define P_MII0 {\ + P_MII0_ETxD0, \ + P_MII0_ETxD1, \ + P_MII0_ETxD2, \ + P_MII0_ETxD3, \ + P_MII0_ETxEN, \ + P_MII0_TxCLK, \ + P_MII0_PHYINT, \ + P_MII0_COL, \ + P_MII0_ERxD0, \ + P_MII0_ERxD1, \ + P_MII0_ERxD2, \ + P_MII0_ERxD3, \ + P_MII0_ERxDV, \ + P_MII0_ERxCLK, \ + P_MII0_ERxER, \ + P_MII0_CRS, \ + P_MDC, \ + P_MDIO, 0} + +#define P_RMII0 {\ + P_MII0_ETxD0, \ + P_MII0_ETxD1, \ + P_MII0_ETxEN, \ + P_MII0_ERxD0, \ + P_MII0_ERxD1, \ + P_MII0_ERxER, \ + P_RMII0_REF_CLK, \ + P_RMII0_MDINT, \ + P_RMII0_CRS_DV, \ + P_MDC, \ + P_MDIO, 0} + +#endif /* _MACH_PORTMUX_H_ */ diff --git a/arch/blackfin/include/asm/mach-bf533/def_local.h b/arch/blackfin/include/asm/mach-bf533/def_local.h index 14c111f..c545b54 100644 --- a/arch/blackfin/include/asm/mach-bf533/def_local.h +++ b/arch/blackfin/include/asm/mach-bf533/def_local.h @@ -1 +1,5 @@ +#include "gpio.h" +#include "portmux.h" #include "ports.h" + +#define BF533_FAMILY 1 /* Linux glue */ diff --git a/arch/blackfin/include/asm/mach-bf533/gpio.h b/arch/blackfin/include/asm/mach-bf533/gpio.h new file mode 100644 index 0000000..e02416d --- /dev/null +++ b/arch/blackfin/include/asm/mach-bf533/gpio.h @@ -0,0 +1,31 @@ +/* + * Copyright (C) 2008 Analog Devices Inc. + * Licensed under the GPL-2 or later. + */ + + +#ifndef _MACH_GPIO_H_ +#define _MACH_GPIO_H_ + +#define MAX_BLACKFIN_GPIOS 16 + +#define GPIO_PF0 0 +#define GPIO_PF1 1 +#define GPIO_PF2 2 +#define GPIO_PF3 3 +#define GPIO_PF4 4 +#define GPIO_PF5 5 +#define GPIO_PF6 6 +#define GPIO_PF7 7 +#define GPIO_PF8 8 +#define GPIO_PF9 9 +#define GPIO_PF10 10 +#define GPIO_PF11 11 +#define GPIO_PF12 12 +#define GPIO_PF13 13 +#define GPIO_PF14 14 +#define GPIO_PF15 15 + +#define PORT_F GPIO_PF0 + +#endif /* _MACH_GPIO_H_ */ diff --git a/arch/blackfin/include/asm/mach-bf533/portmux.h b/arch/blackfin/include/asm/mach-bf533/portmux.h new file mode 100644 index 0000000..96f5d91 --- /dev/null +++ b/arch/blackfin/include/asm/mach-bf533/portmux.h @@ -0,0 +1,71 @@ +/* + * Copyright 2007-2009 Analog Devices Inc. + * + * Licensed under the GPL-2 or later + */ + +#ifndef _MACH_PORTMUX_H_ +#define _MACH_PORTMUX_H_ + +#define MAX_RESOURCES MAX_BLACKFIN_GPIOS + +#define P_PPI0_CLK (P_DONTCARE) +#define P_PPI0_FS1 (P_DONTCARE) +#define P_PPI0_FS2 (P_DONTCARE) +#define P_PPI0_FS3 (P_DEFINED | P_IDENT(GPIO_PF3)) +#define P_PPI0_D15 (P_DEFINED | P_IDENT(GPIO_PF4)) +#define P_PPI0_D14 (P_DEFINED | P_IDENT(GPIO_PF5)) +#define P_PPI0_D13 (P_DEFINED | P_IDENT(GPIO_PF6)) +#define P_PPI0_D12 (P_DEFINED | P_IDENT(GPIO_PF7)) +#define P_PPI0_D11 (P_DEFINED | P_IDENT(GPIO_PF8)) +#define P_PPI0_D10 (P_DEFINED | P_IDENT(GPIO_PF9)) +#define P_PPI0_D9 (P_DEFINED | P_IDENT(GPIO_PF10)) +#define P_PPI0_D8 (P_DEFINED | P_IDENT(GPIO_PF11)) +#define P_PPI0_D0 (P_DONTCARE) +#define P_PPI0_D1 (P_DONTCARE) +#define P_PPI0_D2 (P_DONTCARE) +#define P_PPI0_D3 (P_DONTCARE) +#define P_PPI0_D4 (P_DEFINED | P_IDENT(GPIO_PF15)) +#define P_PPI0_D5 (P_DEFINED | P_IDENT(GPIO_PF14)) +#define P_PPI0_D6 (P_DEFINED | P_IDENT(GPIO_PF13)) +#define P_PPI0_D7 (P_DEFINED | P_IDENT(GPIO_PF12)) + +#define P_SPORT1_TSCLK (P_DONTCARE) +#define P_SPORT1_RSCLK (P_DONTCARE) +#define P_SPORT0_TSCLK (P_DONTCARE) +#define P_SPORT0_RSCLK (P_DONTCARE) +#define P_UART0_RX (P_DONTCARE) +#define P_UART0_TX (P_DONTCARE) +#define P_SPORT1_DRSEC (P_DONTCARE) +#define P_SPORT1_RFS (P_DONTCARE) +#define P_SPORT1_DTPRI (P_DONTCARE) +#define P_SPORT1_DTSEC (P_DONTCARE) +#define P_SPORT1_TFS (P_DONTCARE) +#define P_SPORT1_DRPRI (P_DONTCARE) +#define P_SPORT0_DRSEC (P_DONTCARE) +#define P_SPORT0_RFS (P_DONTCARE) +#define P_SPORT0_DTPRI (P_DONTCARE) +#define P_SPORT0_DTSEC (P_DONTCARE) +#define P_SPORT0_TFS (P_DONTCARE) +#define P_SPORT0_DRPRI (P_DONTCARE) + +#define P_SPI0_MOSI (P_DONTCARE) +#define P_SPI0_MISO (P_DONTCARE) +#define P_SPI0_SCK (P_DONTCARE) +#define P_SPI0_SSEL7 (P_DEFINED | P_IDENT(GPIO_PF7)) +#define P_SPI0_SSEL6 (P_DEFINED | P_IDENT(GPIO_PF6)) +#define P_SPI0_SSEL5 (P_DEFINED | P_IDENT(GPIO_PF5)) +#define P_SPI0_SSEL4 (P_DEFINED | P_IDENT(GPIO_PF4)) +#define P_SPI0_SSEL3 (P_DEFINED | P_IDENT(GPIO_PF3)) +#define P_SPI0_SSEL2 (P_DEFINED | P_IDENT(GPIO_PF2)) +#define P_SPI0_SSEL1 (P_DEFINED | P_IDENT(GPIO_PF1)) +#define P_SPI0_SS (P_DEFINED | P_IDENT(GPIO_PF0)) +#define GPIO_DEFAULT_BOOT_SPI_CS GPIO_PF2 +#define P_DEFAULT_BOOT_SPI_CS P_SPI0_SSEL2 + +#define P_TMR2 (P_DONTCARE) +#define P_TMR1 (P_DONTCARE) +#define P_TMR0 (P_DONTCARE) +#define P_TMRCLK (P_DEFINED | P_IDENT(GPIO_PF1)) + +#endif /* _MACH_PORTMUX_H_ */ diff --git a/arch/blackfin/include/asm/mach-bf537/def_local.h b/arch/blackfin/include/asm/mach-bf537/def_local.h index 14c111f..e210db9 100644 --- a/arch/blackfin/include/asm/mach-bf537/def_local.h +++ b/arch/blackfin/include/asm/mach-bf537/def_local.h @@ -1 +1,5 @@ +#include "gpio.h" +#include "portmux.h" #include "ports.h" + +#define BF537_FAMILY 1 /* Linux glue */ diff --git a/arch/blackfin/include/asm/mach-bf537/gpio.h b/arch/blackfin/include/asm/mach-bf537/gpio.h new file mode 100644 index 0000000..f80c299 --- /dev/null +++ b/arch/blackfin/include/asm/mach-bf537/gpio.h @@ -0,0 +1,65 @@ +/* + * Copyright (C) 2008 Analog Devices Inc. + * Licensed under the GPL-2 or later. + */ + + +#ifndef _MACH_GPIO_H_ +#define _MACH_GPIO_H_ + +#define MAX_BLACKFIN_GPIOS 48 + +#define GPIO_PF0 0 +#define GPIO_PF1 1 +#define GPIO_PF2 2 +#define GPIO_PF3 3 +#define GPIO_PF4 4 +#define GPIO_PF5 5 +#define GPIO_PF6 6 +#define GPIO_PF7 7 +#define GPIO_PF8 8 +#define GPIO_PF9 9 +#define GPIO_PF10 10 +#define GPIO_PF11 11 +#define GPIO_PF12 12 +#define GPIO_PF13 13 +#define GPIO_PF14 14 +#define GPIO_PF15 15 +#define GPIO_PG0 16 +#define GPIO_PG1 17 +#define GPIO_PG2 18 +#define GPIO_PG3 19 +#define GPIO_PG4 20 +#define GPIO_PG5 21 +#define GPIO_PG6 22 +#define GPIO_PG7 23 +#define GPIO_PG8 24 +#define GPIO_PG9 25 +#define GPIO_PG10 26 +#define GPIO_PG11 27 +#define GPIO_PG12 28 +#define GPIO_PG13 29 +#define GPIO_PG14 30 +#define GPIO_PG15 31 +#define GPIO_PH0 32 +#define GPIO_PH1 33 +#define GPIO_PH2 34 +#define GPIO_PH3 35 +#define GPIO_PH4 36 +#define GPIO_PH5 37 +#define GPIO_PH6 38 +#define GPIO_PH7 39 +#define GPIO_PH8 40 +#define GPIO_PH9 41 +#define GPIO_PH10 42 +#define GPIO_PH11 43 +#define GPIO_PH12 44 +#define GPIO_PH13 45 +#define GPIO_PH14 46 +#define GPIO_PH15 47 + +#define PORT_F GPIO_PF0 +#define PORT_G GPIO_PG0 +#define PORT_H GPIO_PH0 + +#endif /* _MACH_GPIO_H_ */ diff --git a/arch/blackfin/include/asm/mach-bf537/portmux.h b/arch/blackfin/include/asm/mach-bf537/portmux.h new file mode 100644 index 0000000..71d9eae --- /dev/null +++ b/arch/blackfin/include/asm/mach-bf537/portmux.h @@ -0,0 +1,152 @@ +/* + * Copyright 2007-2009 Analog Devices Inc. + * + * Licensed under the GPL-2 or later + */ + +#ifndef _MACH_PORTMUX_H_ +#define _MACH_PORTMUX_H_ + +#define MAX_RESOURCES (MAX_BLACKFIN_GPIOS + GPIO_BANKSIZE) /* We additionally handle PORTJ */ + +#define P_UART0_TX (P_DEFINED | P_IDENT(GPIO_PF0) | P_FUNCT(0)) +#define P_UART0_RX (P_DEFINED | P_IDENT(GPIO_PF1) | P_FUNCT(0)) +#define P_UART1_TX (P_DEFINED | P_IDENT(GPIO_PF2) | P_FUNCT(0)) +#define P_UART1_RX (P_DEFINED | P_IDENT(GPIO_PF3) | P_FUNCT(0)) +#define P_TMR5 (P_DEFINED | P_IDENT(GPIO_PF4) | P_FUNCT(0)) +#define P_TMR4 (P_DEFINED | P_IDENT(GPIO_PF5) | P_FUNCT(0)) +#define P_TMR3 (P_DEFINED | P_IDENT(GPIO_PF6) | P_FUNCT(0)) +#define P_TMR2 (P_DEFINED | P_IDENT(GPIO_PF7) | P_FUNCT(0)) +#define P_TMR1 (P_DEFINED | P_IDENT(GPIO_PF8) | P_FUNCT(0)) +#define P_TMR0 (P_DEFINED | P_IDENT(GPIO_PF9) | P_FUNCT(0)) +#define P_SPI0_SSEL1 (P_DEFINED | P_IDENT(GPIO_PF10) | P_FUNCT(0)) +#define P_SPI0_MOSI (P_DEFINED | P_IDENT(GPIO_PF11) | P_FUNCT(0)) +#define P_SPI0_MISO (P_DEFINED | P_IDENT(GPIO_PF12) | P_FUNCT(0)) +#define P_SPI0_SCK (P_DEFINED | P_IDENT(GPIO_PF13) | P_FUNCT(0)) +#define P_SPI0_SS (P_DEFINED | P_IDENT(GPIO_PF14) | P_FUNCT(0)) +#define P_PPI0_CLK (P_DEFINED | P_IDENT(GPIO_PF15) | P_FUNCT(0)) +#define P_DMAR0 (P_DEFINED | P_IDENT(GPIO_PF0) | P_FUNCT(1)) +#define P_DMAR1 (P_DEFINED | P_IDENT(GPIO_PF1) | P_FUNCT(1)) +#define P_TMR7 (P_DEFINED | P_IDENT(GPIO_PF2) | P_FUNCT(1)) +#define P_TMR6 (P_DEFINED | P_IDENT(GPIO_PF3) | P_FUNCT(1)) +#define P_SPI0_SSEL6 (P_DEFINED | P_IDENT(GPIO_PF4) | P_FUNCT(1)) +#define P_SPI0_SSEL5 (P_DEFINED | P_IDENT(GPIO_PF5) | P_FUNCT(1)) +#define P_SPI0_SSEL4 (P_DEFINED | P_IDENT(GPIO_PF6) | P_FUNCT(1)) +#define P_PPI0_FS3 (P_DEFINED | P_IDENT(GPIO_PF7) | P_FUNCT(1)) +#define P_PPI0_FS2 (P_DEFINED | P_IDENT(GPIO_PF8) | P_FUNCT(1)) +#define P_PPI0_FS1 (P_DEFINED | P_IDENT(GPIO_PF9) | P_FUNCT(1)) +#define P_TACLK0 (P_DEFINED | P_IDENT(GPIO_PF14) | P_FUNCT(1)) +#define P_TMRCLK (P_DEFINED | P_IDENT(GPIO_PF15) | P_FUNCT(1)) +#define GPIO_DEFAULT_BOOT_SPI_CS GPIO_PF10 +#define P_DEFAULT_BOOT_SPI_CS P_SPI0_SSEL1 + +#define P_PPI0_D0 (P_DEFINED | P_IDENT(GPIO_PG0) | P_FUNCT(0)) +#define P_PPI0_D1 (P_DEFINED | P_IDENT(GPIO_PG1) | P_FUNCT(0)) +#define P_PPI0_D2 (P_DEFINED | P_IDENT(GPIO_PG2) | P_FUNCT(0)) +#define P_PPI0_D3 (P_DEFINED | P_IDENT(GPIO_PG3) | P_FUNCT(0)) +#define P_PPI0_D4 (P_DEFINED | P_IDENT(GPIO_PG4) | P_FUNCT(0)) +#define P_PPI0_D5 (P_DEFINED | P_IDENT(GPIO_PG5) | P_FUNCT(0)) +#define P_PPI0_D6 (P_DEFINED | P_IDENT(GPIO_PG6) | P_FUNCT(0)) +#define P_PPI0_D7 (P_DEFINED | P_IDENT(GPIO_PG7) | P_FUNCT(0)) +#define P_PPI0_D8 (P_DEFINED | P_IDENT(GPIO_PG8) | P_FUNCT(0)) +#define P_PPI0_D9 (P_DEFINED | P_IDENT(GPIO_PG9) | P_FUNCT(0)) +#define P_PPI0_D10 (P_DEFINED | P_IDENT(GPIO_PG10) | P_FUNCT(0)) +#define P_PPI0_D11 (P_DEFINED | P_IDENT(GPIO_PG11) | P_FUNCT(0)) +#define P_PPI0_D12 (P_DEFINED | P_IDENT(GPIO_PG12) | P_FUNCT(0)) +#define P_PPI0_D13 (P_DEFINED | P_IDENT(GPIO_PG13) | P_FUNCT(0)) +#define P_PPI0_D14 (P_DEFINED | P_IDENT(GPIO_PG14) | P_FUNCT(0)) +#define P_PPI0_D15 (P_DEFINED | P_IDENT(GPIO_PG15) | P_FUNCT(0)) +#define P_SPORT1_DRSEC (P_DEFINED | P_IDENT(GPIO_PG8) | P_FUNCT(1)) +#define P_SPORT1_DTSEC (P_DEFINED | P_IDENT(GPIO_PG9) | P_FUNCT(1)) +#define P_SPORT1_RSCLK (P_DEFINED | P_IDENT(GPIO_PG10) | P_FUNCT(1)) +#define P_SPORT1_RFS (P_DEFINED | P_IDENT(GPIO_PG11) | P_FUNCT(1)) +#define P_SPORT1_DRPRI (P_DEFINED | P_IDENT(GPIO_PG12) | P_FUNCT(1)) +#define P_SPORT1_TSCLK (P_DEFINED | P_IDENT(GPIO_PG13) | P_FUNCT(1)) +#define P_SPORT1_TFS (P_DEFINED | P_IDENT(GPIO_PG14) | P_FUNCT(1)) +#define P_SPORT1_DTPRI (P_DEFINED | P_IDENT(GPIO_PG15) | P_FUNCT(1)) + +#define P_MII0_ETxD0 (P_DEFINED | P_IDENT(GPIO_PH0) | P_FUNCT(0)) +#define P_MII0_ETxD1 (P_DEFINED | P_IDENT(GPIO_PH1) | P_FUNCT(0)) +#define P_MII0_ETxD2 (P_DEFINED | P_IDENT(GPIO_PH2) | P_FUNCT(0)) +#define P_MII0_ETxD3 (P_DEFINED | P_IDENT(GPIO_PH3) | P_FUNCT(0)) +#define P_MII0_ETxEN (P_DEFINED | P_IDENT(GPIO_PH4) | P_FUNCT(0)) +#define P_MII0_TxCLK (P_DEFINED | P_IDENT(GPIO_PH5) | P_FUNCT(0)) +#define P_MII0_PHYINT (P_DEFINED | P_IDENT(GPIO_PH6) | P_FUNCT(0)) +#define P_MII0_COL (P_DEFINED | P_IDENT(GPIO_PH7) | P_FUNCT(0)) +#define P_MII0_ERxD0 (P_DEFINED | P_IDENT(GPIO_PH8) | P_FUNCT(0)) +#define P_MII0_ERxD1 (P_DEFINED | P_IDENT(GPIO_PH9) | P_FUNCT(0)) +#define P_MII0_ERxD2 (P_DEFINED | P_IDENT(GPIO_PH10) | P_FUNCT(0)) +#define P_MII0_ERxD3 (P_DEFINED | P_IDENT(GPIO_PH11) | P_FUNCT(0)) +#define P_MII0_ERxDV (P_DEFINED | P_IDENT(GPIO_PH12) | P_FUNCT(0)) +#define P_MII0_ERxCLK (P_DEFINED | P_IDENT(GPIO_PH13) | P_FUNCT(0)) +#define P_MII0_ERxER (P_DEFINED | P_IDENT(GPIO_PH14) | P_FUNCT(0)) +#define P_MII0_CRS (P_DEFINED | P_IDENT(GPIO_PH15) | P_FUNCT(0)) +#define P_RMII0_REF_CLK (P_DEFINED | P_IDENT(GPIO_PH5) | P_FUNCT(1)) +#define P_RMII0_MDINT (P_DEFINED | P_IDENT(GPIO_PH6) | P_FUNCT(1)) +#define P_RMII0_CRS_DV (P_DEFINED | P_IDENT(GPIO_PH15) | P_FUNCT(1)) + +#define PORT_PJ0 (GPIO_PH15 + 1) +#define PORT_PJ1 (GPIO_PH15 + 2) +#define PORT_PJ2 (GPIO_PH15 + 3) +#define PORT_PJ3 (GPIO_PH15 + 4) +#define PORT_PJ4 (GPIO_PH15 + 5) +#define PORT_PJ5 (GPIO_PH15 + 6) +#define PORT_PJ6 (GPIO_PH15 + 7) +#define PORT_PJ7 (GPIO_PH15 + 8) +#define PORT_PJ8 (GPIO_PH15 + 9) +#define PORT_PJ9 (GPIO_PH15 + 10) +#define PORT_PJ10 (GPIO_PH15 + 11) +#define PORT_PJ11 (GPIO_PH15 + 12) + +#define P_MDC (P_DEFINED | P_IDENT(PORT_PJ0) | P_FUNCT(0)) +#define P_MDIO (P_DEFINED | P_IDENT(PORT_PJ1) | P_FUNCT(0)) +#define P_TWI0_SCL (P_DEFINED | P_IDENT(PORT_PJ2) | P_FUNCT(0)) +#define P_TWI0_SDA (P_DEFINED | P_IDENT(PORT_PJ3) | P_FUNCT(0)) +#define P_SPORT0_DRSEC (P_DEFINED | P_IDENT(PORT_PJ4) | P_FUNCT(0)) +#define P_SPORT0_DTSEC (P_DEFINED | P_IDENT(PORT_PJ5) | P_FUNCT(0)) +#define P_SPORT0_RSCLK (P_DEFINED | P_IDENT(PORT_PJ6) | P_FUNCT(0)) +#define P_SPORT0_RFS (P_DEFINED | P_IDENT(PORT_PJ7) | P_FUNCT(0)) +#define P_SPORT0_DRPRI (P_DEFINED | P_IDENT(PORT_PJ8) | P_FUNCT(0)) +#define P_SPORT0_TSCLK (P_DEFINED | P_IDENT(PORT_PJ9) | P_FUNCT(0)) +#define P_SPORT0_TFS (P_DEFINED | P_IDENT(PORT_PJ10) | P_FUNCT(0)) +#define P_SPORT0_DTPRI (P_DEFINED | P_IDENT(PORT_PJ11) | P_FUNCT(0)) +#define P_CAN0_RX (P_DEFINED | P_IDENT(PORT_PJ4) | P_FUNCT(1)) +#define P_CAN0_TX (P_DEFINED | P_IDENT(PORT_PJ5) | P_FUNCT(1)) +#define P_SPI0_SSEL3 (P_DEFINED | P_IDENT(PORT_PJ10) | P_FUNCT(1)) +#define P_SPI0_SSEL2 (P_DEFINED | P_IDENT(PORT_PJ11) | P_FUNCT(1)) +#define P_SPI0_SSEL7 (P_DEFINED | P_IDENT(PORT_PJ5) | P_FUNCT(2)) + +#define P_MII0 {\ + P_MII0_ETxD0, \ + P_MII0_ETxD1, \ + P_MII0_ETxD2, \ + P_MII0_ETxD3, \ + P_MII0_ETxEN, \ + P_MII0_TxCLK, \ + P_MII0_PHYINT, \ + P_MII0_COL, \ + P_MII0_ERxD0, \ + P_MII0_ERxD1, \ + P_MII0_ERxD2, \ + P_MII0_ERxD3, \ + P_MII0_ERxDV, \ + P_MII0_ERxCLK, \ + P_MII0_ERxER, \ + P_MII0_CRS, \ + P_MDC, \ + P_MDIO, 0} + +#define P_RMII0 {\ + P_MII0_ETxD0, \ + P_MII0_ETxD1, \ + P_MII0_ETxEN, \ + P_MII0_ERxD0, \ + P_MII0_ERxD1, \ + P_MII0_ERxER, \ + P_RMII0_REF_CLK, \ + P_RMII0_MDINT, \ + P_RMII0_CRS_DV, \ + P_MDC, \ + P_MDIO, 0} + +#endif /* _MACH_PORTMUX_H_ */ diff --git a/arch/blackfin/include/asm/mach-bf548/def_local.h b/arch/blackfin/include/asm/mach-bf548/def_local.h index 81eca83..f1e69a7 100644 --- a/arch/blackfin/include/asm/mach-bf548/def_local.h +++ b/arch/blackfin/include/asm/mach-bf548/def_local.h @@ -1,2 +1,6 @@ +#include "gpio.h" #include "mem_map.h" +#include "portmux.h" #include "ports.h" + +#define CONFIG_BF54x 1 /* Linux glue */ diff --git a/arch/blackfin/include/asm/mach-bf548/gpio.h b/arch/blackfin/include/asm/mach-bf548/gpio.h new file mode 100644 index 0000000..28037e3 --- /dev/null +++ b/arch/blackfin/include/asm/mach-bf548/gpio.h @@ -0,0 +1,203 @@ +/* + * Copyright 2007-2009 Analog Devices Inc. + * Licensed under the GPL-2 or later. + */ + + +#ifndef _MACH_GPIO_H_ +#define _MACH_GPIO_H_ + +#define GPIO_PA0 0 +#define GPIO_PA1 1 +#define GPIO_PA2 2 +#define GPIO_PA3 3 +#define GPIO_PA4 4 +#define GPIO_PA5 5 +#define GPIO_PA6 6 +#define GPIO_PA7 7 +#define GPIO_PA8 8 +#define GPIO_PA9 9 +#define GPIO_PA10 10 +#define GPIO_PA11 11 +#define GPIO_PA12 12 +#define GPIO_PA13 13 +#define GPIO_PA14 14 +#define GPIO_PA15 15 +#define GPIO_PB0 16 +#define GPIO_PB1 17 +#define GPIO_PB2 18 +#define GPIO_PB3 19 +#define GPIO_PB4 20 +#define GPIO_PB5 21 +#define GPIO_PB6 22 +#define GPIO_PB7 23 +#define GPIO_PB8 24 +#define GPIO_PB9 25 +#define GPIO_PB10 26 +#define GPIO_PB11 27 +#define GPIO_PB12 28 +#define GPIO_PB13 29 +#define GPIO_PB14 30 +#define GPIO_PB15 31 /* N/A */ +#define GPIO_PC0 32 +#define GPIO_PC1 33 +#define GPIO_PC2 34 +#define GPIO_PC3 35 +#define GPIO_PC4 36 +#define GPIO_PC5 37 +#define GPIO_PC6 38 +#define GPIO_PC7 39 +#define GPIO_PC8 40 +#define GPIO_PC9 41 +#define GPIO_PC10 42 +#define GPIO_PC11 43 +#define GPIO_PC12 44 +#define GPIO_PC13 45 +#define GPIO_PC14 46 /* N/A */ +#define GPIO_PC15 47 /* N/A */ +#define GPIO_PD0 48 +#define GPIO_PD1 49 +#define GPIO_PD2 50 +#define GPIO_PD3 51 +#define GPIO_PD4 52 +#define GPIO_PD5 53 +#define GPIO_PD6 54 +#define GPIO_PD7 55 +#define GPIO_PD8 56 +#define GPIO_PD9 57 +#define GPIO_PD10 58 +#define GPIO_PD11 59 +#define GPIO_PD12 60 +#define GPIO_PD13 61 +#define GPIO_PD14 62 +#define GPIO_PD15 63 +#define GPIO_PE0 64 +#define GPIO_PE1 65 +#define GPIO_PE2 66 +#define GPIO_PE3 67 +#define GPIO_PE4 68 +#define GPIO_PE5 69 +#define GPIO_PE6 70 +#define GPIO_PE7 71 +#define GPIO_PE8 72 +#define GPIO_PE9 73 +#define GPIO_PE10 74 +#define GPIO_PE11 75 +#define GPIO_PE12 76 +#define GPIO_PE13 77 +#define GPIO_PE14 78 +#define GPIO_PE15 79 +#define GPIO_PF0 80 +#define GPIO_PF1 81 +#define GPIO_PF2 82 +#define GPIO_PF3 83 +#define GPIO_PF4 84 +#define GPIO_PF5 85 +#define GPIO_PF6 86 +#define GPIO_PF7 87 +#define GPIO_PF8 88 +#define GPIO_PF9 89 +#define GPIO_PF10 90 +#define GPIO_PF11 91 +#define GPIO_PF12 92 +#define GPIO_PF13 93 +#define GPIO_PF14 94 +#define GPIO_PF15 95 +#define GPIO_PG0 96 +#define GPIO_PG1 97 +#define GPIO_PG2 98 +#define GPIO_PG3 99 +#define GPIO_PG4 100 +#define GPIO_PG5 101 +#define GPIO_PG6 102 +#define GPIO_PG7 103 +#define GPIO_PG8 104 +#define GPIO_PG9 105 +#define GPIO_PG10 106 +#define GPIO_PG11 107 +#define GPIO_PG12 108 +#define GPIO_PG13 109 +#define GPIO_PG14 110 +#define GPIO_PG15 111 +#define GPIO_PH0 112 +#define GPIO_PH1 113 +#define GPIO_PH2 114 +#define GPIO_PH3 115 +#define GPIO_PH4 116 +#define GPIO_PH5 117 +#define GPIO_PH6 118 +#define GPIO_PH7 119 +#define GPIO_PH8 120 +#define GPIO_PH9 121 +#define GPIO_PH10 122 +#define GPIO_PH11 123 +#define GPIO_PH12 124 +#define GPIO_PH13 125 +#define GPIO_PH14 126 /* N/A */ +#define GPIO_PH15 127 /* N/A */ +#define GPIO_PI0 128 +#define GPIO_PI1 129 +#define GPIO_PI2 130 +#define GPIO_PI3 131 +#define GPIO_PI4 132 +#define GPIO_PI5 133 +#define GPIO_PI6 134 +#define GPIO_PI7 135 +#define GPIO_PI8 136 +#define GPIO_PI9 137 +#define GPIO_PI10 138 +#define GPIO_PI11 139 +#define GPIO_PI12 140 +#define GPIO_PI13 141 +#define GPIO_PI14 142 +#define GPIO_PI15 143 +#define GPIO_PJ0 144 +#define GPIO_PJ1 145 +#define GPIO_PJ2 146 +#define GPIO_PJ3 147 +#define GPIO_PJ4 148 +#define GPIO_PJ5 149 +#define GPIO_PJ6 150 +#define GPIO_PJ7 151 +#define GPIO_PJ8 152 +#define GPIO_PJ9 153 +#define GPIO_PJ10 154 +#define GPIO_PJ11 155 +#define GPIO_PJ12 156 +#define GPIO_PJ13 157 +#define GPIO_PJ14 158 /* N/A */ +#define GPIO_PJ15 159 /* N/A */ + +#define MAX_BLACKFIN_GPIOS 160 + +#ifndef __ASSEMBLY__ + +struct gpio_port_t { + unsigned short port_fer; + unsigned short dummy1; + unsigned short data; + unsigned short dummy2; + unsigned short data_set; + unsigned short dummy3; + unsigned short data_clear; + unsigned short dummy4; + unsigned short dir_set; + unsigned short dummy5; + unsigned short dir_clear; + unsigned short dummy6; + unsigned short inen; + unsigned short dummy7; + unsigned int port_mux; +}; + +struct gpio_port_s { + unsigned short fer; + unsigned short data; + unsigned short dir; + unsigned short inen; + unsigned int mux; +}; + +#endif + +#endif /* _MACH_GPIO_H_ */ diff --git a/arch/blackfin/include/asm/mach-bf548/portmux.h b/arch/blackfin/include/asm/mach-bf548/portmux.h new file mode 100644 index 0000000..e222462 --- /dev/null +++ b/arch/blackfin/include/asm/mach-bf548/portmux.h @@ -0,0 +1,320 @@ +/* + * Copyright 2007-2009 Analog Devices Inc. + * + * Licensed under the GPL-2 or later. + */ + +#ifndef _MACH_PORTMUX_H_ +#define _MACH_PORTMUX_H_ + +#define MAX_RESOURCES MAX_BLACKFIN_GPIOS + +#define P_SPORT2_TFS (P_DEFINED | P_IDENT(GPIO_PA0) | P_FUNCT(0)) +#define P_SPORT2_DTSEC (P_DEFINED | P_IDENT(GPIO_PA1) | P_FUNCT(0)) +#define P_SPORT2_DTPRI (P_DEFINED | P_IDENT(GPIO_PA2) | P_FUNCT(0)) +#define P_SPORT2_TSCLK (P_DEFINED | P_IDENT(GPIO_PA3) | P_FUNCT(0)) +#define P_SPORT2_RFS (P_DEFINED | P_IDENT(GPIO_PA4) | P_FUNCT(0)) +#define P_SPORT2_DRSEC (P_DEFINED | P_IDENT(GPIO_PA5) | P_FUNCT(0)) +#define P_SPORT2_DRPRI (P_DEFINED | P_IDENT(GPIO_PA6) | P_FUNCT(0)) +#define P_SPORT2_RSCLK (P_DEFINED | P_IDENT(GPIO_PA7) | P_FUNCT(0)) +#define P_SPORT3_TFS (P_DEFINED | P_IDENT(GPIO_PA8) | P_FUNCT(0)) +#define P_SPORT3_DTSEC (P_DEFINED | P_IDENT(GPIO_PA9) | P_FUNCT(0)) +#define P_SPORT3_DTPRI (P_DEFINED | P_IDENT(GPIO_PA10) | P_FUNCT(0)) +#define P_SPORT3_TSCLK (P_DEFINED | P_IDENT(GPIO_PA11) | P_FUNCT(0)) +#define P_SPORT3_RFS (P_DEFINED | P_IDENT(GPIO_PA12) | P_FUNCT(0)) +#define P_SPORT3_DRSEC (P_DEFINED | P_IDENT(GPIO_PA13) | P_FUNCT(0)) +#define P_SPORT3_DRPRI (P_DEFINED | P_IDENT(GPIO_PA14) | P_FUNCT(0)) +#define P_SPORT3_RSCLK (P_DEFINED | P_IDENT(GPIO_PA15) | P_FUNCT(0)) +#define P_TMR4 (P_DEFINED | P_IDENT(GPIO_PA1) | P_FUNCT(1)) +#define P_TMR5 (P_DEFINED | P_IDENT(GPIO_PA5) | P_FUNCT(1)) +#define P_TMR6 (P_DEFINED | P_IDENT(GPIO_PA9) | P_FUNCT(1)) +#define P_TMR7 (P_DEFINED | P_IDENT(GPIO_PA13) | P_FUNCT(1)) + +#define P_TWI1_SCL (P_DEFINED | P_IDENT(GPIO_PB0) | P_FUNCT(0)) +#define P_TWI1_SDA (P_DEFINED | P_IDENT(GPIO_PB1) | P_FUNCT(0)) +#define P_UART3_RTS (P_DEFINED | P_IDENT(GPIO_PB2) | P_FUNCT(0)) +#define P_UART3_CTS (P_DEFINED | P_IDENT(GPIO_PB3) | P_FUNCT(0)) +#define P_UART2_TX (P_DEFINED | P_IDENT(GPIO_PB4) | P_FUNCT(0)) +#define P_UART2_RX (P_DEFINED | P_IDENT(GPIO_PB5) | P_FUNCT(0)) +#define P_UART3_TX (P_DEFINED | P_IDENT(GPIO_PB6) | P_FUNCT(0)) +#define P_UART3_RX (P_DEFINED | P_IDENT(GPIO_PB7) | P_FUNCT(0)) +#define P_SPI2_SS (P_DEFINED | P_IDENT(GPIO_PB8) | P_FUNCT(0)) +#define P_SPI2_SSEL1 (P_DEFINED | P_IDENT(GPIO_PB9) | P_FUNCT(0)) +#define P_SPI2_SSEL2 (P_DEFINED | P_IDENT(GPIO_PB10) | P_FUNCT(0)) +#define P_SPI2_SSEL3 (P_DEFINED | P_IDENT(GPIO_PB11) | P_FUNCT(0)) +#define P_SPI2_SCK (P_DEFINED | P_IDENT(GPIO_PB12) | P_FUNCT(0)) +#define P_SPI2_MOSI (P_DEFINED | P_IDENT(GPIO_PB13) | P_FUNCT(0)) +#define P_SPI2_MISO (P_DEFINED | P_IDENT(GPIO_PB14) | P_FUNCT(0)) +#define P_TMR0 (P_DEFINED | P_IDENT(GPIO_PB8) | P_FUNCT(1)) +#define P_TMR1 (P_DEFINED | P_IDENT(GPIO_PB9) | P_FUNCT(1)) +#define P_TMR2 (P_DEFINED | P_IDENT(GPIO_PB10) | P_FUNCT(1)) +#define P_TMR3 (P_DEFINED | P_IDENT(GPIO_PB11) | P_FUNCT(1)) + +#define P_SPORT0_TFS (P_DEFINED | P_IDENT(GPIO_PC0) | P_FUNCT(0)) +#define P_SPORT0_DTSEC (P_DEFINED | P_IDENT(GPIO_PC1) | P_FUNCT(0)) +#define P_SPORT0_DTPRI (P_DEFINED | P_IDENT(GPIO_PC2) | P_FUNCT(0)) +#define P_SPORT0_TSCLK (P_DEFINED | P_IDENT(GPIO_PC3) | P_FUNCT(0)) +#define P_SPORT0_RFS (P_DEFINED | P_IDENT(GPIO_PC4) | P_FUNCT(0)) +#define P_SPORT0_DRSEC (P_DEFINED | P_IDENT(GPIO_PC5) | P_FUNCT(0)) +#define P_SPORT0_DRPRI (P_DEFINED | P_IDENT(GPIO_PC6) | P_FUNCT(0)) +#define P_SPORT0_RSCLK (P_DEFINED | P_IDENT(GPIO_PC7) | P_FUNCT(0)) +#define P_SD_D0 (P_DEFINED | P_IDENT(GPIO_PC8) | P_FUNCT(0)) +#define P_SD_D1 (P_DEFINED | P_IDENT(GPIO_PC9) | P_FUNCT(0)) +#define P_SD_D2 (P_DEFINED | P_IDENT(GPIO_PC10) | P_FUNCT(0)) +#define P_SD_D3 (P_DEFINED | P_IDENT(GPIO_PC11) | P_FUNCT(0)) +#define P_SD_CLK (P_DEFINED | P_IDENT(GPIO_PC12) | P_FUNCT(0)) +#define P_SD_CMD (P_DEFINED | P_IDENT(GPIO_PC13) | P_FUNCT(0)) +#define P_MMCLK (P_DEFINED | P_IDENT(GPIO_PC1) | P_FUNCT(1)) +#define P_MBCLK (P_DEFINED | P_IDENT(GPIO_PC5) | P_FUNCT(1)) + +#define P_PPI1_D0 (P_DEFINED | P_IDENT(GPIO_PD0) | P_FUNCT(0)) +#define P_PPI1_D1 (P_DEFINED | P_IDENT(GPIO_PD1) | P_FUNCT(0)) +#define P_PPI1_D2 (P_DEFINED | P_IDENT(GPIO_PD2) | P_FUNCT(0)) +#define P_PPI1_D3 (P_DEFINED | P_IDENT(GPIO_PD3) | P_FUNCT(0)) +#define P_PPI1_D4 (P_DEFINED | P_IDENT(GPIO_PD4) | P_FUNCT(0)) +#define P_PPI1_D5 (P_DEFINED | P_IDENT(GPIO_PD5) | P_FUNCT(0)) +#define P_PPI1_D6 (P_DEFINED | P_IDENT(GPIO_PD6) | P_FUNCT(0)) +#define P_PPI1_D7 (P_DEFINED | P_IDENT(GPIO_PD7) | P_FUNCT(0)) +#define P_PPI1_D8 (P_DEFINED | P_IDENT(GPIO_PD8) | P_FUNCT(0)) +#define P_PPI1_D9 (P_DEFINED | P_IDENT(GPIO_PD9) | P_FUNCT(0)) +#define P_PPI1_D10 (P_DEFINED | P_IDENT(GPIO_PD10) | P_FUNCT(0)) +#define P_PPI1_D11 (P_DEFINED | P_IDENT(GPIO_PD11) | P_FUNCT(0)) +#define P_PPI1_D12 (P_DEFINED | P_IDENT(GPIO_PD12) | P_FUNCT(0)) +#define P_PPI1_D13 (P_DEFINED | P_IDENT(GPIO_PD13) | P_FUNCT(0)) +#define P_PPI1_D14 (P_DEFINED | P_IDENT(GPIO_PD14) | P_FUNCT(0)) +#define P_PPI1_D15 (P_DEFINED | P_IDENT(GPIO_PD15) | P_FUNCT(0)) + +#define P_HOST_D8 (P_DEFINED | P_IDENT(GPIO_PD0) | P_FUNCT(1)) +#define P_HOST_D9 (P_DEFINED | P_IDENT(GPIO_PD1) | P_FUNCT(1)) +#define P_HOST_D10 (P_DEFINED | P_IDENT(GPIO_PD2) | P_FUNCT(1)) +#define P_HOST_D11 (P_DEFINED | P_IDENT(GPIO_PD3) | P_FUNCT(1)) +#define P_HOST_D12 (P_DEFINED | P_IDENT(GPIO_PD4) | P_FUNCT(1)) +#define P_HOST_D13 (P_DEFINED | P_IDENT(GPIO_PD5) | P_FUNCT(1)) +#define P_HOST_D14 (P_DEFINED | P_IDENT(GPIO_PD6) | P_FUNCT(1)) +#define P_HOST_D15 (P_DEFINED | P_IDENT(GPIO_PD7) | P_FUNCT(1)) +#define P_HOST_D0 (P_DEFINED | P_IDENT(GPIO_PD8) | P_FUNCT(1)) +#define P_HOST_D1 (P_DEFINED | P_IDENT(GPIO_PD9) | P_FUNCT(1)) +#define P_HOST_D2 (P_DEFINED | P_IDENT(GPIO_PD10) | P_FUNCT(1)) +#define P_HOST_D3 (P_DEFINED | P_IDENT(GPIO_PD11) | P_FUNCT(1)) +#define P_HOST_D4 (P_DEFINED | P_IDENT(GPIO_PD12) | P_FUNCT(1)) +#define P_HOST_D5 (P_DEFINED | P_IDENT(GPIO_PD13) | P_FUNCT(1)) +#define P_HOST_D6 (P_DEFINED | P_IDENT(GPIO_PD14) | P_FUNCT(1)) +#define P_HOST_D7 (P_DEFINED | P_IDENT(GPIO_PD15) | P_FUNCT(1)) +#define P_SPORT1_TFS (P_DEFINED | P_IDENT(GPIO_PD0) | P_FUNCT(2)) +#define P_SPORT1_DTSEC (P_DEFINED | P_IDENT(GPIO_PD1) | P_FUNCT(2)) +#define P_SPORT1_DTPRI (P_DEFINED | P_IDENT(GPIO_PD2) | P_FUNCT(2)) +#define P_SPORT1_TSCLK (P_DEFINED | P_IDENT(GPIO_PD3) | P_FUNCT(2)) +#define P_SPORT1_RFS (P_DEFINED | P_IDENT(GPIO_PD4) | P_FUNCT(2)) +#define P_SPORT1_DRSEC (P_DEFINED | P_IDENT(GPIO_PD5) | P_FUNCT(2)) +#define P_SPORT1_DRPRI (P_DEFINED | P_IDENT(GPIO_PD6) | P_FUNCT(2)) +#define P_SPORT1_RSCLK (P_DEFINED | P_IDENT(GPIO_PD7) | P_FUNCT(2)) +#define P_PPI2_D0 (P_DEFINED | P_IDENT(GPIO_PD8) | P_FUNCT(2)) +#define P_PPI2_D1 (P_DEFINED | P_IDENT(GPIO_PD9) | P_FUNCT(2)) +#define P_PPI2_D2 (P_DEFINED | P_IDENT(GPIO_PD10) | P_FUNCT(2)) +#define P_PPI2_D3 (P_DEFINED | P_IDENT(GPIO_PD11) | P_FUNCT(2)) +#define P_PPI2_D4 (P_DEFINED | P_IDENT(GPIO_PD12) | P_FUNCT(2)) +#define P_PPI2_D5 (P_DEFINED | P_IDENT(GPIO_PD13) | P_FUNCT(2)) +#define P_PPI2_D6 (P_DEFINED | P_IDENT(GPIO_PD14) | P_FUNCT(2)) +#define P_PPI2_D7 (P_DEFINED | P_IDENT(GPIO_PD15) | P_FUNCT(2)) +#define P_PPI0_D18 (P_DEFINED | P_IDENT(GPIO_PD0) | P_FUNCT(3)) +#define P_PPI0_D19 (P_DEFINED | P_IDENT(GPIO_PD1) | P_FUNCT(3)) +#define P_PPI0_D20 (P_DEFINED | P_IDENT(GPIO_PD2) | P_FUNCT(3)) +#define P_PPI0_D21 (P_DEFINED | P_IDENT(GPIO_PD3) | P_FUNCT(3)) +#define P_PPI0_D22 (P_DEFINED | P_IDENT(GPIO_PD4) | P_FUNCT(3)) +#define P_PPI0_D23 (P_DEFINED | P_IDENT(GPIO_PD5) | P_FUNCT(3)) +#define P_KEY_ROW0 (P_DEFINED | P_IDENT(GPIO_PD8) | P_FUNCT(3)) +#define P_KEY_ROW1 (P_DEFINED | P_IDENT(GPIO_PD9) | P_FUNCT(3)) +#define P_KEY_ROW2 (P_DEFINED | P_IDENT(GPIO_PD10) | P_FUNCT(3)) +#define P_KEY_ROW3 (P_DEFINED | P_IDENT(GPIO_PD11) | P_FUNCT(3)) +#define P_KEY_COL0 (P_DEFINED | P_IDENT(GPIO_PD12) | P_FUNCT(3)) +#define P_KEY_COL1 (P_DEFINED | P_IDENT(GPIO_PD13) | P_FUNCT(3)) +#define P_KEY_COL2 (P_DEFINED | P_IDENT(GPIO_PD14) | P_FUNCT(3)) +#define P_KEY_COL3 (P_DEFINED | P_IDENT(GPIO_PD15) | P_FUNCT(3)) + +#define GPIO_DEFAULT_BOOT_SPI_CS GPIO_PE4 +#define P_DEFAULT_BOOT_SPI_CS P_SPI0_SSEL1 +#define P_SPI0_SCK (P_DEFINED | P_IDENT(GPIO_PE0) | P_FUNCT(0)) +#define P_SPI0_MISO (P_DEFINED | P_IDENT(GPIO_PE1) | P_FUNCT(0)) +#define P_SPI0_MOSI (P_DEFINED | P_IDENT(GPIO_PE2) | P_FUNCT(0)) +#define P_SPI0_SS (P_DEFINED | P_IDENT(GPIO_PE3) | P_FUNCT(0)) +#define P_SPI0_SSEL1 (P_DEFINED | P_IDENT(GPIO_PE4) | P_FUNCT(0)) +#define P_SPI0_SSEL2 (P_DEFINED | P_IDENT(GPIO_PE5) | P_FUNCT(0)) +#define P_SPI0_SSEL3 (P_DEFINED | P_IDENT(GPIO_PE6) | P_FUNCT(0)) +#define P_UART0_TX (P_DEFINED | P_IDENT(GPIO_PE7) | P_FUNCT(0)) +#define P_UART0_RX (P_DEFINED | P_IDENT(GPIO_PE8) | P_FUNCT(0)) +#define P_UART1_RTS (P_DEFINED | P_IDENT(GPIO_PE9) | P_FUNCT(0)) +#define P_UART1_CTS (P_DEFINED | P_IDENT(GPIO_PE10) | P_FUNCT(0)) +#define P_PPI1_CLK (P_DEFINED | P_IDENT(GPIO_PE11) | P_FUNCT(0)) +#define P_PPI1_FS1 (P_DEFINED | P_IDENT(GPIO_PE12) | P_FUNCT(0)) +#define P_PPI1_FS2 (P_DEFINED | P_IDENT(GPIO_PE13) | P_FUNCT(0)) +#define P_TWI0_SCL (P_DEFINED | P_IDENT(GPIO_PE14) | P_FUNCT(0)) +#define P_TWI0_SDA (P_DEFINED | P_IDENT(GPIO_PE15) | P_FUNCT(0)) +#define P_KEY_COL7 (P_DEFINED | P_IDENT(GPIO_PE0) | P_FUNCT(1)) +#define P_KEY_ROW6 (P_DEFINED | P_IDENT(GPIO_PE1) | P_FUNCT(1)) +#define P_KEY_COL6 (P_DEFINED | P_IDENT(GPIO_PE2) | P_FUNCT(1)) +#define P_KEY_ROW5 (P_DEFINED | P_IDENT(GPIO_PE3) | P_FUNCT(1)) +#define P_KEY_COL5 (P_DEFINED | P_IDENT(GPIO_PE4) | P_FUNCT(1)) +#define P_KEY_ROW4 (P_DEFINED | P_IDENT(GPIO_PE5) | P_FUNCT(1)) +#define P_KEY_COL4 (P_DEFINED | P_IDENT(GPIO_PE6) | P_FUNCT(1)) +#define P_KEY_ROW7 (P_DEFINED | P_IDENT(GPIO_PE7) | P_FUNCT(1)) + +#define P_PPI0_D0 (P_DEFINED | P_IDENT(GPIO_PF0) | P_FUNCT(0)) +#define P_PPI0_D1 (P_DEFINED | P_IDENT(GPIO_PF1) | P_FUNCT(0)) +#define P_PPI0_D2 (P_DEFINED | P_IDENT(GPIO_PF2) | P_FUNCT(0)) +#define P_PPI0_D3 (P_DEFINED | P_IDENT(GPIO_PF3) | P_FUNCT(0)) +#define P_PPI0_D4 (P_DEFINED | P_IDENT(GPIO_PF4) | P_FUNCT(0)) +#define P_PPI0_D5 (P_DEFINED | P_IDENT(GPIO_PF5) | P_FUNCT(0)) +#define P_PPI0_D6 (P_DEFINED | P_IDENT(GPIO_PF6) | P_FUNCT(0)) +#define P_PPI0_D7 (P_DEFINED | P_IDENT(GPIO_PF7) | P_FUNCT(0)) +#define P_PPI0_D8 (P_DEFINED | P_IDENT(GPIO_PF8) | P_FUNCT(0)) +#define P_PPI0_D9 (P_DEFINED | P_IDENT(GPIO_PF9) | P_FUNCT(0)) +#define P_PPI0_D10 (P_DEFINED | P_IDENT(GPIO_PF10) | P_FUNCT(0)) +#define P_PPI0_D11 (P_DEFINED | P_IDENT(GPIO_PF11) | P_FUNCT(0)) +#define P_PPI0_D12 (P_DEFINED | P_IDENT(GPIO_PF12) | P_FUNCT(0)) +#define P_PPI0_D13 (P_DEFINED | P_IDENT(GPIO_PF13) | P_FUNCT(0)) +#define P_PPI0_D14 (P_DEFINED | P_IDENT(GPIO_PF14) | P_FUNCT(0)) +#define P_PPI0_D15 (P_DEFINED | P_IDENT(GPIO_PF15) | P_FUNCT(0)) + +#ifdef CONFIG_BF548_ATAPI_ALTERNATIVE_PORT +# define P_ATAPI_D0A (P_DEFINED | P_IDENT(GPIO_PF0) | P_FUNCT(1)) +# define P_ATAPI_D1A (P_DEFINED | P_IDENT(GPIO_PF1) | P_FUNCT(1)) +# define P_ATAPI_D2A (P_DEFINED | P_IDENT(GPIO_PF2) | P_FUNCT(1)) +# define P_ATAPI_D3A (P_DEFINED | P_IDENT(GPIO_PF3) | P_FUNCT(1)) +# define P_ATAPI_D4A (P_DEFINED | P_IDENT(GPIO_PF4) | P_FUNCT(1)) +# define P_ATAPI_D5A (P_DEFINED | P_IDENT(GPIO_PF5) | P_FUNCT(1)) +# define P_ATAPI_D6A (P_DEFINED | P_IDENT(GPIO_PF6) | P_FUNCT(1)) +# define P_ATAPI_D7A (P_DEFINED | P_IDENT(GPIO_PF7) | P_FUNCT(1)) +# define P_ATAPI_D8A (P_DEFINED | P_IDENT(GPIO_PF8) | P_FUNCT(1)) +# define P_ATAPI_D9A (P_DEFINED | P_IDENT(GPIO_PF9) | P_FUNCT(1)) +# define P_ATAPI_D10A (P_DEFINED | P_IDENT(GPIO_PF10) | P_FUNCT(1)) +# define P_ATAPI_D11A (P_DEFINED | P_IDENT(GPIO_PF11) | P_FUNCT(1)) +# define P_ATAPI_D12A (P_DEFINED | P_IDENT(GPIO_PF12) | P_FUNCT(1)) +# define P_ATAPI_D13A (P_DEFINED | P_IDENT(GPIO_PF13) | P_FUNCT(1)) +# define P_ATAPI_D14A (P_DEFINED | P_IDENT(GPIO_PF14) | P_FUNCT(1)) +# define P_ATAPI_D15A (P_DEFINED | P_IDENT(GPIO_PF15) | P_FUNCT(1)) +#else +# define P_ATAPI_D0A (P_DONTCARE) +# define P_ATAPI_D1A (P_DONTCARE) +# define P_ATAPI_D2A (P_DONTCARE) +# define P_ATAPI_D3A (P_DONTCARE) +# define P_ATAPI_D4A (P_DONTCARE) +# define P_ATAPI_D5A (P_DONTCARE) +# define P_ATAPI_D6A (P_DONTCARE) +# define P_ATAPI_D7A (P_DONTCARE) +# define P_ATAPI_D8A (P_DONTCARE) +# define P_ATAPI_D9A (P_DONTCARE) +# define P_ATAPI_D10A (P_DONTCARE) +# define P_ATAPI_D11A (P_DONTCARE) +# define P_ATAPI_D12A (P_DONTCARE) +# define P_ATAPI_D13A (P_DONTCARE) +# define P_ATAPI_D14A (P_DONTCARE) +# define P_ATAPI_D15A (P_DONTCARE) +#endif + +#define P_PPI0_CLK (P_DEFINED | P_IDENT(GPIO_PG0) | P_FUNCT(0)) +#define P_PPI0_FS1 (P_DEFINED | P_IDENT(GPIO_PG1) | P_FUNCT(0)) +#define P_PPI0_FS2 (P_DEFINED | P_IDENT(GPIO_PG2) | P_FUNCT(0)) +#define P_PPI0_D16 (P_DEFINED | P_IDENT(GPIO_PG3) | P_FUNCT(0)) +#define P_PPI0_D17 (P_DEFINED | P_IDENT(GPIO_PG4) | P_FUNCT(0)) +#define P_SPI1_SSEL1 (P_DEFINED | P_IDENT(GPIO_PG5) | P_FUNCT(0)) +#define P_SPI1_SSEL2 (P_DEFINED | P_IDENT(GPIO_PG6) | P_FUNCT(0)) +#define P_SPI1_SSEL3 (P_DEFINED | P_IDENT(GPIO_PG7) | P_FUNCT(0)) +#define P_SPI1_SCK (P_DEFINED | P_IDENT(GPIO_PG8) | P_FUNCT(0)) +#define P_SPI1_MISO (P_DEFINED | P_IDENT(GPIO_PG9) | P_FUNCT(0)) +#define P_SPI1_MOSI (P_DEFINED | P_IDENT(GPIO_PG10) | P_FUNCT(0)) +#define P_SPI1_SS (P_DEFINED | P_IDENT(GPIO_PG11) | P_FUNCT(0)) +#define P_CAN0_TX (P_DEFINED | P_IDENT(GPIO_PG12) | P_FUNCT(0)) +#define P_CAN0_RX (P_DEFINED | P_IDENT(GPIO_PG13) | P_FUNCT(0)) +#define P_CAN1_TX (P_DEFINED | P_IDENT(GPIO_PG14) | P_FUNCT(0)) +#define P_CAN1_RX (P_DEFINED | P_IDENT(GPIO_PG15) | P_FUNCT(0)) +#ifdef CONFIG_BF548_ATAPI_ALTERNATIVE_PORT +# define P_ATAPI_A0A (P_DEFINED | P_IDENT(GPIO_PG2) | P_FUNCT(1)) +# define P_ATAPI_A1A (P_DEFINED | P_IDENT(GPIO_PG3) | P_FUNCT(1)) +# define P_ATAPI_A2A (P_DEFINED | P_IDENT(GPIO_PG4) | P_FUNCT(1)) +#else +# define P_ATAPI_A0A (P_DONTCARE) +# define P_ATAPI_A1A (P_DONTCARE) +# define P_ATAPI_A2A (P_DONTCARE) +#endif +#define P_HOST_CE (P_DEFINED | P_IDENT(GPIO_PG5) | P_FUNCT(1)) +#define P_HOST_RD (P_DEFINED | P_IDENT(GPIO_PG6) | P_FUNCT(1)) +#define P_HOST_WR (P_DEFINED | P_IDENT(GPIO_PG7) | P_FUNCT(1)) +#define P_MTXONB (P_DEFINED | P_IDENT(GPIO_PG11) | P_FUNCT(1)) +#define P_PPI2_FS2 (P_DEFINED | P_IDENT(GPIO_PG5) | P_FUNCT(2)) +#define P_PPI2_FS1 (P_DEFINED | P_IDENT(GPIO_PG6) | P_FUNCT(2)) +#define P_PPI2_CLK (P_DEFINED | P_IDENT(GPIO_PG7) | P_FUNCT(2)) +#define P_CNT_CZM (P_DEFINED | P_IDENT(GPIO_PG5) | P_FUNCT(3)) + +#define P_UART1_TX (P_DEFINED | P_IDENT(GPIO_PH0) | P_FUNCT(0)) +#define P_UART1_RX (P_DEFINED | P_IDENT(GPIO_PH1) | P_FUNCT(0)) +#define P_ATAPI_RESET (P_DEFINED | P_IDENT(GPIO_PH2) | P_FUNCT(0)) +#define P_HOST_ADDR (P_DEFINED | P_IDENT(GPIO_PH3) | P_FUNCT(0)) +#define P_HOST_ACK (P_DEFINED | P_IDENT(GPIO_PH4) | P_FUNCT(0)) +#define P_MTX (P_DEFINED | P_IDENT(GPIO_PH5) | P_FUNCT(0)) +#define P_MRX (P_DEFINED | P_IDENT(GPIO_PH6) | P_FUNCT(0)) +#define P_MRXONB (P_DEFINED | P_IDENT(GPIO_PH7) | P_FUNCT(0)) +#define P_A4 (P_MAYSHARE | P_DEFINED | P_IDENT(GPIO_PH8) | P_FUNCT(0)) +#define P_A5 (P_MAYSHARE | P_DEFINED | P_IDENT(GPIO_PH9) | P_FUNCT(0)) +#define P_A6 (P_MAYSHARE | P_DEFINED | P_IDENT(GPIO_PH10) | P_FUNCT(0)) +#define P_A7 (P_MAYSHARE | P_DEFINED | P_IDENT(GPIO_PH11) | P_FUNCT(0)) +#define P_A8 (P_MAYSHARE | P_DEFINED | P_IDENT(GPIO_PH12) | P_FUNCT(0)) +#define P_A9 (P_MAYSHARE | P_DEFINED | P_IDENT(GPIO_PH13) | P_FUNCT(0)) +#define P_PPI1_FS3 (P_DEFINED | P_IDENT(GPIO_PH0) | P_FUNCT(1)) +#define P_PPI2_FS3 (P_DEFINED | P_IDENT(GPIO_PH1) | P_FUNCT(1)) +#define P_TMR8 (P_DEFINED | P_IDENT(GPIO_PH2) | P_FUNCT(1)) +#define P_TMR9 (P_DEFINED | P_IDENT(GPIO_PH3) | P_FUNCT(1)) +#define P_TMR10 (P_DEFINED | P_IDENT(GPIO_PH4) | P_FUNCT(1)) +#define P_DMAR0 (P_DEFINED | P_IDENT(GPIO_PH5) | P_FUNCT(1)) +#define P_DMAR1 (P_DEFINED | P_IDENT(GPIO_PH6) | P_FUNCT(1)) +#define P_PPI0_FS3 (P_DEFINED | P_IDENT(GPIO_PH2) | P_FUNCT(2)) +#define P_CNT_CDG (P_DEFINED | P_IDENT(GPIO_PH3) | P_FUNCT(2)) +#define P_CNT_CUD (P_DEFINED | P_IDENT(GPIO_PH4) | P_FUNCT(2)) + +#define P_A10 (P_MAYSHARE | P_DEFINED | P_IDENT(GPIO_PI0) | P_FUNCT(0)) +#define P_A11 (P_MAYSHARE | P_DEFINED | P_IDENT(GPIO_PI1) | P_FUNCT(0)) +#define P_A12 (P_MAYSHARE | P_DEFINED | P_IDENT(GPIO_PI2) | P_FUNCT(0)) +#define P_A13 (P_MAYSHARE | P_DEFINED | P_IDENT(GPIO_PI3) | P_FUNCT(0)) +#define P_A14 (P_MAYSHARE | P_DEFINED | P_IDENT(GPIO_PI4) | P_FUNCT(0)) +#define P_A15 (P_MAYSHARE | P_DEFINED | P_IDENT(GPIO_PI5) | P_FUNCT(0)) +#define P_A16 (P_MAYSHARE | P_DEFINED | P_IDENT(GPIO_PI6) | P_FUNCT(0)) +#define P_A17 (P_MAYSHARE | P_DEFINED | P_IDENT(GPIO_PI7) | P_FUNCT(0)) +#define P_A18 (P_MAYSHARE | P_DEFINED | P_IDENT(GPIO_PI8) | P_FUNCT(0)) +#define P_A19 (P_MAYSHARE | P_DEFINED | P_IDENT(GPIO_PI9) | P_FUNCT(0)) +#define P_A20 (P_MAYSHARE | P_DEFINED | P_IDENT(GPIO_PI10) | P_FUNCT(0)) +#define P_A21 (P_MAYSHARE | P_DEFINED | P_IDENT(GPIO_PI11) | P_FUNCT(0)) +#define P_A22 (P_MAYSHARE | P_DEFINED | P_IDENT(GPIO_PI12) | P_FUNCT(0)) +#define P_A23 (P_MAYSHARE | P_DEFINED | P_IDENT(GPIO_PI13) | P_FUNCT(0)) +#define P_A24 (P_MAYSHARE | P_DEFINED | P_IDENT(GPIO_PI14) | P_FUNCT(0)) +#define P_A25 (P_MAYSHARE | P_DEFINED | P_IDENT(GPIO_PI15) | P_FUNCT(0)) +#define P_NOR_CLK (P_DEFINED | P_IDENT(GPIO_PI15) | P_FUNCT(1)) + +#define P_AMC_ARDY_NOR_WAIT (P_DEFINED | P_IDENT(GPIO_PJ0) | P_FUNCT(0)) +#define P_NAND_CE (P_DEFINED | P_IDENT(GPIO_PJ1) | P_FUNCT(0)) +#define P_NAND_RB (P_DEFINED | P_IDENT(GPIO_PJ2) | P_FUNCT(0)) +#define P_ATAPI_DIOR (P_DEFINED | P_IDENT(GPIO_PJ3) | P_FUNCT(0)) +#define P_ATAPI_DIOW (P_DEFINED | P_IDENT(GPIO_PJ4) | P_FUNCT(0)) +#define P_ATAPI_CS0 (P_DEFINED | P_IDENT(GPIO_PJ5) | P_FUNCT(0)) +#define P_ATAPI_CS1 (P_DEFINED | P_IDENT(GPIO_PJ6) | P_FUNCT(0)) +#define P_ATAPI_DMACK (P_DEFINED | P_IDENT(GPIO_PJ7) | P_FUNCT(0)) +#define P_ATAPI_DMARQ (P_DEFINED | P_IDENT(GPIO_PJ8) | P_FUNCT(0)) +#define P_ATAPI_INTRQ (P_DEFINED | P_IDENT(GPIO_PJ9) | P_FUNCT(0)) +#define P_ATAPI_IORDY (P_DEFINED | P_IDENT(GPIO_PJ10) | P_FUNCT(0)) +#define P_AMC_BR (P_DEFINED | P_IDENT(GPIO_PJ11) | P_FUNCT(0)) +#define P_AMC_BG (P_DEFINED | P_IDENT(GPIO_PJ12) | P_FUNCT(0)) +#define P_AMC_BGH (P_DEFINED | P_IDENT(GPIO_PJ13) | P_FUNCT(0)) + + +#define P_NAND_D0 (P_DONTCARE) +#define P_NAND_D1 (P_DONTCARE) +#define P_NAND_D2 (P_DONTCARE) +#define P_NAND_D3 (P_DONTCARE) +#define P_NAND_D4 (P_DONTCARE) +#define P_NAND_D5 (P_DONTCARE) +#define P_NAND_D6 (P_DONTCARE) +#define P_NAND_D7 (P_DONTCARE) +#define P_NAND_WE (P_DONTCARE) +#define P_NAND_RE (P_DONTCARE) +#define P_NAND_CLE (P_DONTCARE) +#define P_NAND_ALE (P_DONTCARE) + +#endif /* _MACH_PORTMUX_H_ */ diff --git a/arch/blackfin/include/asm/mach-bf561/def_local.h b/arch/blackfin/include/asm/mach-bf561/def_local.h index 597dcec..08e37e5 100644 --- a/arch/blackfin/include/asm/mach-bf561/def_local.h +++ b/arch/blackfin/include/asm/mach-bf561/def_local.h @@ -9,4 +9,8 @@ #define bfin_write_WDOG_CTL(val) bfin_write_WDOGA_CTL(val) #define bfin_write_WDOG_STAT(val) bfin_write_WDOGA_STAT(val)
+#include "gpio.h" +#include "portmux.h" #include "ports.h" + +#define BF561_FAMILY 1 /* Linux glue */ diff --git a/arch/blackfin/include/asm/mach-bf561/gpio.h b/arch/blackfin/include/asm/mach-bf561/gpio.h new file mode 100644 index 0000000..4f8aa5d --- /dev/null +++ b/arch/blackfin/include/asm/mach-bf561/gpio.h @@ -0,0 +1,65 @@ +/* + * Copyright (C) 2008 Analog Devices Inc. + * Licensed under the GPL-2 or later. + */ + + +#ifndef _MACH_GPIO_H_ +#define _MACH_GPIO_H_ + +#define MAX_BLACKFIN_GPIOS 48 + +#define GPIO_PF0 0 +#define GPIO_PF1 1 +#define GPIO_PF2 2 +#define GPIO_PF3 3 +#define GPIO_PF4 4 +#define GPIO_PF5 5 +#define GPIO_PF6 6 +#define GPIO_PF7 7 +#define GPIO_PF8 8 +#define GPIO_PF9 9 +#define GPIO_PF10 10 +#define GPIO_PF11 11 +#define GPIO_PF12 12 +#define GPIO_PF13 13 +#define GPIO_PF14 14 +#define GPIO_PF15 15 +#define GPIO_PF16 16 +#define GPIO_PF17 17 +#define GPIO_PF18 18 +#define GPIO_PF19 19 +#define GPIO_PF20 20 +#define GPIO_PF21 21 +#define GPIO_PF22 22 +#define GPIO_PF23 23 +#define GPIO_PF24 24 +#define GPIO_PF25 25 +#define GPIO_PF26 26 +#define GPIO_PF27 27 +#define GPIO_PF28 28 +#define GPIO_PF29 29 +#define GPIO_PF30 30 +#define GPIO_PF31 31 +#define GPIO_PF32 32 +#define GPIO_PF33 33 +#define GPIO_PF34 34 +#define GPIO_PF35 35 +#define GPIO_PF36 36 +#define GPIO_PF37 37 +#define GPIO_PF38 38 +#define GPIO_PF39 39 +#define GPIO_PF40 40 +#define GPIO_PF41 41 +#define GPIO_PF42 42 +#define GPIO_PF43 43 +#define GPIO_PF44 44 +#define GPIO_PF45 45 +#define GPIO_PF46 46 +#define GPIO_PF47 47 + +#define PORT_FIO0 GPIO_0 +#define PORT_FIO1 GPIO_16 +#define PORT_FIO2 GPIO_32 + +#endif /* _MACH_GPIO_H_ */ diff --git a/arch/blackfin/include/asm/mach-bf561/portmux.h b/arch/blackfin/include/asm/mach-bf561/portmux.h new file mode 100644 index 0000000..2339ffd --- /dev/null +++ b/arch/blackfin/include/asm/mach-bf561/portmux.h @@ -0,0 +1,97 @@ +/* + * Copyright 2007-2009 Analog Devices Inc. + * + * Licensed under the GPL-2 or later. + */ + +#ifndef _MACH_PORTMUX_H_ +#define _MACH_PORTMUX_H_ + +#define MAX_RESOURCES MAX_BLACKFIN_GPIOS + +#define P_PPI0_CLK (P_DONTCARE) +#define P_PPI0_FS1 (P_DONTCARE) +#define P_PPI0_FS2 (P_DONTCARE) +#define P_PPI0_FS3 (P_DONTCARE) +#define P_PPI0_D15 (P_DEFINED | P_IDENT(GPIO_PF47)) +#define P_PPI0_D14 (P_DEFINED | P_IDENT(GPIO_PF46)) +#define P_PPI0_D13 (P_DEFINED | P_IDENT(GPIO_PF45)) +#define P_PPI0_D12 (P_DEFINED | P_IDENT(GPIO_PF44)) +#define P_PPI0_D11 (P_DEFINED | P_IDENT(GPIO_PF43)) +#define P_PPI0_D10 (P_DEFINED | P_IDENT(GPIO_PF42)) +#define P_PPI0_D9 (P_DEFINED | P_IDENT(GPIO_PF41)) +#define P_PPI0_D8 (P_DEFINED | P_IDENT(GPIO_PF40)) +#define P_PPI0_D0 (P_DONTCARE) +#define P_PPI0_D1 (P_DONTCARE) +#define P_PPI0_D2 (P_DONTCARE) +#define P_PPI0_D3 (P_DONTCARE) +#define P_PPI0_D4 (P_DONTCARE) +#define P_PPI0_D5 (P_DONTCARE) +#define P_PPI0_D6 (P_DONTCARE) +#define P_PPI0_D7 (P_DONTCARE) +#define P_PPI1_CLK (P_DONTCARE) +#define P_PPI1_FS1 (P_DONTCARE) +#define P_PPI1_FS2 (P_DONTCARE) +#define P_PPI1_FS3 (P_DONTCARE) +#define P_PPI1_D15 (P_DEFINED | P_IDENT(GPIO_PF39)) +#define P_PPI1_D14 (P_DEFINED | P_IDENT(GPIO_PF38)) +#define P_PPI1_D13 (P_DEFINED | P_IDENT(GPIO_PF37)) +#define P_PPI1_D12 (P_DEFINED | P_IDENT(GPIO_PF36)) +#define P_PPI1_D11 (P_DEFINED | P_IDENT(GPIO_PF35)) +#define P_PPI1_D10 (P_DEFINED | P_IDENT(GPIO_PF34)) +#define P_PPI1_D9 (P_DEFINED | P_IDENT(GPIO_PF33)) +#define P_PPI1_D8 (P_DEFINED | P_IDENT(GPIO_PF32)) +#define P_PPI1_D0 (P_DONTCARE) +#define P_PPI1_D1 (P_DONTCARE) +#define P_PPI1_D2 (P_DONTCARE) +#define P_PPI1_D3 (P_DONTCARE) +#define P_PPI1_D4 (P_DONTCARE) +#define P_PPI1_D5 (P_DONTCARE) +#define P_PPI1_D6 (P_DONTCARE) +#define P_PPI1_D7 (P_DONTCARE) +#define P_SPORT1_TSCLK (P_DEFINED | P_IDENT(GPIO_PF31)) +#define P_SPORT1_RSCLK (P_DEFINED | P_IDENT(GPIO_PF30)) +#define P_SPORT0_TSCLK (P_DEFINED | P_IDENT(GPIO_PF29)) +#define P_SPORT0_RSCLK (P_DEFINED | P_IDENT(GPIO_PF28)) +#define P_UART0_RX (P_DEFINED | P_IDENT(GPIO_PF27)) +#define P_UART0_TX (P_DEFINED | P_IDENT(GPIO_PF26)) +#define P_SPORT1_DRSEC (P_DEFINED | P_IDENT(GPIO_PF25)) +#define P_SPORT1_RFS (P_DEFINED | P_IDENT(GPIO_PF24)) +#define P_SPORT1_DTPRI (P_DEFINED | P_IDENT(GPIO_PF23)) +#define P_SPORT1_DTSEC (P_DEFINED | P_IDENT(GPIO_PF22)) +#define P_SPORT1_TFS (P_DEFINED | P_IDENT(GPIO_PF21)) +#define P_SPORT1_DRPRI (P_DONTCARE) +#define P_SPORT0_DRSEC (P_DEFINED | P_IDENT(GPIO_PF20)) +#define P_SPORT0_RFS (P_DEFINED | P_IDENT(GPIO_PF19)) +#define P_SPORT0_DTPRI (P_DEFINED | P_IDENT(GPIO_PF18)) +#define P_SPORT0_DTSEC (P_DEFINED | P_IDENT(GPIO_PF17)) +#define P_SPORT0_TFS (P_DEFINED | P_IDENT(GPIO_PF16)) +#define P_SPORT0_DRPRI (P_DONTCARE) +#define P_TMRCLK (P_DEFINED | P_IDENT(GPIO_PF15)) +#define P_SPI0_SSEL7 (P_DEFINED | P_IDENT(GPIO_PF7)) +#define P_SPI0_SSEL6 (P_DEFINED | P_IDENT(GPIO_PF6)) +#define P_SPI0_SSEL5 (P_DEFINED | P_IDENT(GPIO_PF5)) +#define P_SPI0_SSEL4 (P_DEFINED | P_IDENT(GPIO_PF4)) +#define P_SPI0_SSEL3 (P_DEFINED | P_IDENT(GPIO_PF3)) +#define P_SPI0_SSEL2 (P_DEFINED | P_IDENT(GPIO_PF2)) +#define P_SPI0_SSEL1 (P_DEFINED | P_IDENT(GPIO_PF1)) +#define P_SPI0_SS (P_DEFINED | P_IDENT(GPIO_PF0)) +#define P_TMR11 (P_DONTCARE) +#define P_TMR10 (P_DONTCARE) +#define P_TMR9 (P_DONTCARE) +#define P_TMR8 (P_DONTCARE) +#define P_TMR7 (P_DEFINED | P_IDENT(GPIO_PF7)) +#define P_TMR6 (P_DEFINED | P_IDENT(GPIO_PF6)) +#define P_TMR5 (P_DEFINED | P_IDENT(GPIO_PF5)) +#define P_TMR4 (P_DEFINED | P_IDENT(GPIO_PF4)) +#define P_TMR3 (P_DEFINED | P_IDENT(GPIO_PF3)) +#define P_TMR2 (P_DEFINED | P_IDENT(GPIO_PF2)) +#define P_TMR1 (P_DEFINED | P_IDENT(GPIO_PF1)) +#define P_TMR0 (P_DEFINED | P_IDENT(GPIO_PF0)) +#define P_SPI0_MOSI (P_DONTCARE) +#define P_SPI0_MISO (P_DONTCARE) +#define P_SPI0_SCK (P_DONTCARE) +#define GPIO_DEFAULT_BOOT_SPI_CS GPIO_PF2 +#define P_DEFAULT_BOOT_SPI_CS P_SPI0_SSEL2 + +#endif /* _MACH_PORTMUX_H_ */ diff --git a/arch/blackfin/include/asm/portmux.h b/arch/blackfin/include/asm/portmux.h new file mode 100644 index 0000000..b17207f --- /dev/null +++ b/arch/blackfin/include/asm/portmux.h @@ -0,0 +1,1194 @@ +/* + * Common header file for Blackfin family of processors + * + * Copyright 2007-2008 Analog Devices Inc. + * + * Licensed under the GPL-2 or later. + */ + +#ifndef _PORTMUX_H_ +#define _PORTMUX_H_ + +#define P_IDENT(x) ((x) & 0x1FF) +#define P_FUNCT(x) (((x) & 0x3) << 9) +#define P_FUNCT2MUX(x) (((x) >> 9) & 0x3) +#define P_DEFINED 0x8000 +#define P_UNDEF 0x4000 +#define P_MAYSHARE 0x2000 +#define P_DONTCARE 0x1000 + +#ifndef CONFIG_BFIN_GPIO_TRACK +#define peripheral_request(per, label) peripheral_request(per) +#define peripheral_request_list(per, label) peripheral_request_list(per) +#endif + +int peripheral_request(unsigned short per, const char *label); +void peripheral_free(unsigned short per); +int peripheral_request_list(const unsigned short per[], const char *label); +void peripheral_free_list(const unsigned short per[]); + +#include <asm/blackfin.h> + +#ifndef P_SPORT2_TFS +#define P_SPORT2_TFS P_UNDEF +#endif + +#ifndef P_SPORT2_DTSEC +#define P_SPORT2_DTSEC P_UNDEF +#endif + +#ifndef P_SPORT2_DTPRI +#define P_SPORT2_DTPRI P_UNDEF +#endif + +#ifndef P_SPORT2_TSCLK +#define P_SPORT2_TSCLK P_UNDEF +#endif + +#ifndef P_SPORT2_RFS +#define P_SPORT2_RFS P_UNDEF +#endif + +#ifndef P_SPORT2_DRSEC +#define P_SPORT2_DRSEC P_UNDEF +#endif + +#ifndef P_SPORT2_DRPRI +#define P_SPORT2_DRPRI P_UNDEF +#endif + +#ifndef P_SPORT2_RSCLK +#define P_SPORT2_RSCLK P_UNDEF +#endif + +#ifndef P_SPORT3_TFS +#define P_SPORT3_TFS P_UNDEF +#endif + +#ifndef P_SPORT3_DTSEC +#define P_SPORT3_DTSEC P_UNDEF +#endif + +#ifndef P_SPORT3_DTPRI +#define P_SPORT3_DTPRI P_UNDEF +#endif + +#ifndef P_SPORT3_TSCLK +#define P_SPORT3_TSCLK P_UNDEF +#endif + +#ifndef P_SPORT3_RFS +#define P_SPORT3_RFS P_UNDEF +#endif + +#ifndef P_SPORT3_DRSEC +#define P_SPORT3_DRSEC P_UNDEF +#endif + +#ifndef P_SPORT3_DRPRI +#define P_SPORT3_DRPRI P_UNDEF +#endif + +#ifndef P_SPORT3_RSCLK +#define P_SPORT3_RSCLK P_UNDEF +#endif + +#ifndef P_TMR4 +#define P_TMR4 P_UNDEF +#endif + +#ifndef P_TMR5 +#define P_TMR5 P_UNDEF +#endif + +#ifndef P_TMR6 +#define P_TMR6 P_UNDEF +#endif + +#ifndef P_TMR7 +#define P_TMR7 P_UNDEF +#endif + +#ifndef P_TWI1_SCL +#define P_TWI1_SCL P_UNDEF +#endif + +#ifndef P_TWI1_SDA +#define P_TWI1_SDA P_UNDEF +#endif + +#ifndef P_UART3_RTS +#define P_UART3_RTS P_UNDEF +#endif + +#ifndef P_UART3_CTS +#define P_UART3_CTS P_UNDEF +#endif + +#ifndef P_UART2_TX +#define P_UART2_TX P_UNDEF +#endif + +#ifndef P_UART2_RX +#define P_UART2_RX P_UNDEF +#endif + +#ifndef P_UART3_TX +#define P_UART3_TX P_UNDEF +#endif + +#ifndef P_UART3_RX +#define P_UART3_RX P_UNDEF +#endif + +#ifndef P_SPI2_SS +#define P_SPI2_SS P_UNDEF +#endif + +#ifndef P_SPI2_SSEL1 +#define P_SPI2_SSEL1 P_UNDEF +#endif + +#ifndef P_SPI2_SSEL2 +#define P_SPI2_SSEL2 P_UNDEF +#endif + +#ifndef P_SPI2_SSEL3 +#define P_SPI2_SSEL3 P_UNDEF +#endif + +#ifndef P_SPI2_SSEL4 +#define P_SPI2_SSEL4 P_UNDEF +#endif + +#ifndef P_SPI2_SSEL5 +#define P_SPI2_SSEL5 P_UNDEF +#endif + +#ifndef P_SPI2_SSEL6 +#define P_SPI2_SSEL6 P_UNDEF +#endif + +#ifndef P_SPI2_SSEL7 +#define P_SPI2_SSEL7 P_UNDEF +#endif + +#ifndef P_SPI2_SCK +#define P_SPI2_SCK P_UNDEF +#endif + +#ifndef P_SPI2_MOSI +#define P_SPI2_MOSI P_UNDEF +#endif + +#ifndef P_SPI2_MISO +#define P_SPI2_MISO P_UNDEF +#endif + +#ifndef P_TMR0 +#define P_TMR0 P_UNDEF +#endif + +#ifndef P_TMR1 +#define P_TMR1 P_UNDEF +#endif + +#ifndef P_TMR2 +#define P_TMR2 P_UNDEF +#endif + +#ifndef P_TMR3 +#define P_TMR3 P_UNDEF +#endif + +#ifndef P_SPORT0_TFS +#define P_SPORT0_TFS P_UNDEF +#endif + +#ifndef P_SPORT0_DTSEC +#define P_SPORT0_DTSEC P_UNDEF +#endif + +#ifndef P_SPORT0_DTPRI +#define P_SPORT0_DTPRI P_UNDEF +#endif + +#ifndef P_SPORT0_TSCLK +#define P_SPORT0_TSCLK P_UNDEF +#endif + +#ifndef P_SPORT0_RFS +#define P_SPORT0_RFS P_UNDEF +#endif + +#ifndef P_SPORT0_DRSEC +#define P_SPORT0_DRSEC P_UNDEF +#endif + +#ifndef P_SPORT0_DRPRI +#define P_SPORT0_DRPRI P_UNDEF +#endif + +#ifndef P_SPORT0_RSCLK +#define P_SPORT0_RSCLK P_UNDEF +#endif + +#ifndef P_SD_D0 +#define P_SD_D0 P_UNDEF +#endif + +#ifndef P_SD_D1 +#define P_SD_D1 P_UNDEF +#endif + +#ifndef P_SD_D2 +#define P_SD_D2 P_UNDEF +#endif + +#ifndef P_SD_D3 +#define P_SD_D3 P_UNDEF +#endif + +#ifndef P_SD_CLK +#define P_SD_CLK P_UNDEF +#endif + +#ifndef P_SD_CMD +#define P_SD_CMD P_UNDEF +#endif + +#ifndef P_MMCLK +#define P_MMCLK P_UNDEF +#endif + +#ifndef P_MBCLK +#define P_MBCLK P_UNDEF +#endif + +#ifndef P_PPI1_D0 +#define P_PPI1_D0 P_UNDEF +#endif + +#ifndef P_PPI1_D1 +#define P_PPI1_D1 P_UNDEF +#endif + +#ifndef P_PPI1_D2 +#define P_PPI1_D2 P_UNDEF +#endif + +#ifndef P_PPI1_D3 +#define P_PPI1_D3 P_UNDEF +#endif + +#ifndef P_PPI1_D4 +#define P_PPI1_D4 P_UNDEF +#endif + +#ifndef P_PPI1_D5 +#define P_PPI1_D5 P_UNDEF +#endif + +#ifndef P_PPI1_D6 +#define P_PPI1_D6 P_UNDEF +#endif + +#ifndef P_PPI1_D7 +#define P_PPI1_D7 P_UNDEF +#endif + +#ifndef P_PPI1_D8 +#define P_PPI1_D8 P_UNDEF +#endif + +#ifndef P_PPI1_D9 +#define P_PPI1_D9 P_UNDEF +#endif + +#ifndef P_PPI1_D10 +#define P_PPI1_D10 P_UNDEF +#endif + +#ifndef P_PPI1_D11 +#define P_PPI1_D11 P_UNDEF +#endif + +#ifndef P_PPI1_D12 +#define P_PPI1_D12 P_UNDEF +#endif + +#ifndef P_PPI1_D13 +#define P_PPI1_D13 P_UNDEF +#endif + +#ifndef P_PPI1_D14 +#define P_PPI1_D14 P_UNDEF +#endif + +#ifndef P_PPI1_D15 +#define P_PPI1_D15 P_UNDEF +#endif + +#ifndef P_HOST_D8 +#define P_HOST_D8 P_UNDEF +#endif + +#ifndef P_HOST_D9 +#define P_HOST_D9 P_UNDEF +#endif + +#ifndef P_HOST_D10 +#define P_HOST_D10 P_UNDEF +#endif + +#ifndef P_HOST_D11 +#define P_HOST_D11 P_UNDEF +#endif + +#ifndef P_HOST_D12 +#define P_HOST_D12 P_UNDEF +#endif + +#ifndef P_HOST_D13 +#define P_HOST_D13 P_UNDEF +#endif + +#ifndef P_HOST_D14 +#define P_HOST_D14 P_UNDEF +#endif + +#ifndef P_HOST_D15 +#define P_HOST_D15 P_UNDEF +#endif + +#ifndef P_HOST_D0 +#define P_HOST_D0 P_UNDEF +#endif + +#ifndef P_HOST_D1 +#define P_HOST_D1 P_UNDEF +#endif + +#ifndef P_HOST_D2 +#define P_HOST_D2 P_UNDEF +#endif + +#ifndef P_HOST_D3 +#define P_HOST_D3 P_UNDEF +#endif + +#ifndef P_HOST_D4 +#define P_HOST_D4 P_UNDEF +#endif + +#ifndef P_HOST_D5 +#define P_HOST_D5 P_UNDEF +#endif + +#ifndef P_HOST_D6 +#define P_HOST_D6 P_UNDEF +#endif + +#ifndef P_HOST_D7 +#define P_HOST_D7 P_UNDEF +#endif + +#ifndef P_SPORT1_TFS +#define P_SPORT1_TFS P_UNDEF +#endif + +#ifndef P_SPORT1_DTSEC +#define P_SPORT1_DTSEC P_UNDEF +#endif + +#ifndef P_SPORT1_DTPRI +#define P_SPORT1_DTPRI P_UNDEF +#endif + +#ifndef P_SPORT1_TSCLK +#define P_SPORT1_TSCLK P_UNDEF +#endif + +#ifndef P_SPORT1_RFS +#define P_SPORT1_RFS P_UNDEF +#endif + +#ifndef P_SPORT1_DRSEC +#define P_SPORT1_DRSEC P_UNDEF +#endif + +#ifndef P_SPORT1_DRPRI +#define P_SPORT1_DRPRI P_UNDEF +#endif + +#ifndef P_SPORT1_RSCLK +#define P_SPORT1_RSCLK P_UNDEF +#endif + +#ifndef P_PPI2_D0 +#define P_PPI2_D0 P_UNDEF +#endif + +#ifndef P_PPI2_D1 +#define P_PPI2_D1 P_UNDEF +#endif + +#ifndef P_PPI2_D2 +#define P_PPI2_D2 P_UNDEF +#endif + +#ifndef P_PPI2_D3 +#define P_PPI2_D3 P_UNDEF +#endif + +#ifndef P_PPI2_D4 +#define P_PPI2_D4 P_UNDEF +#endif + +#ifndef P_PPI2_D5 +#define P_PPI2_D5 P_UNDEF +#endif + +#ifndef P_PPI2_D6 +#define P_PPI2_D6 P_UNDEF +#endif + +#ifndef P_PPI2_D7 +#define P_PPI2_D7 P_UNDEF +#endif + +#ifndef P_PPI0_D18 +#define P_PPI0_D18 P_UNDEF +#endif + +#ifndef P_PPI0_D19 +#define P_PPI0_D19 P_UNDEF +#endif + +#ifndef P_PPI0_D20 +#define P_PPI0_D20 P_UNDEF +#endif + +#ifndef P_PPI0_D21 +#define P_PPI0_D21 P_UNDEF +#endif + +#ifndef P_PPI0_D22 +#define P_PPI0_D22 P_UNDEF +#endif + +#ifndef P_PPI0_D23 +#define P_PPI0_D23 P_UNDEF +#endif + +#ifndef P_KEY_ROW0 +#define P_KEY_ROW0 P_UNDEF +#endif + +#ifndef P_KEY_ROW1 +#define P_KEY_ROW1 P_UNDEF +#endif + +#ifndef P_KEY_ROW2 +#define P_KEY_ROW2 P_UNDEF +#endif + +#ifndef P_KEY_ROW3 +#define P_KEY_ROW3 P_UNDEF +#endif + +#ifndef P_KEY_COL0 +#define P_KEY_COL0 P_UNDEF +#endif + +#ifndef P_KEY_COL1 +#define P_KEY_COL1 P_UNDEF +#endif + +#ifndef P_KEY_COL2 +#define P_KEY_COL2 P_UNDEF +#endif + +#ifndef P_KEY_COL3 +#define P_KEY_COL3 P_UNDEF +#endif + +#ifndef P_SPI0_SCK +#define P_SPI0_SCK P_UNDEF +#endif + +#ifndef P_SPI0_MISO +#define P_SPI0_MISO P_UNDEF +#endif + +#ifndef P_SPI0_MOSI +#define P_SPI0_MOSI P_UNDEF +#endif + +#ifndef P_SPI0_SS +#define P_SPI0_SS P_UNDEF +#endif + +#ifndef P_SPI0_SSEL1 +#define P_SPI0_SSEL1 P_UNDEF +#endif + +#ifndef P_SPI0_SSEL2 +#define P_SPI0_SSEL2 P_UNDEF +#endif + +#ifndef P_SPI0_SSEL3 +#define P_SPI0_SSEL3 P_UNDEF +#endif + +#ifndef P_SPI0_SSEL4 +#define P_SPI0_SSEL4 P_UNDEF +#endif + +#ifndef P_SPI0_SSEL5 +#define P_SPI0_SSEL5 P_UNDEF +#endif + +#ifndef P_SPI0_SSEL6 +#define P_SPI0_SSEL6 P_UNDEF +#endif + +#ifndef P_SPI0_SSEL7 +#define P_SPI0_SSEL7 P_UNDEF +#endif + +#ifndef P_UART0_TX +#define P_UART0_TX P_UNDEF +#endif + +#ifndef P_UART0_RX +#define P_UART0_RX P_UNDEF +#endif + +#ifndef P_UART1_RTS +#define P_UART1_RTS P_UNDEF +#endif + +#ifndef P_UART1_CTS +#define P_UART1_CTS P_UNDEF +#endif + +#ifndef P_PPI1_CLK +#define P_PPI1_CLK P_UNDEF +#endif + +#ifndef P_PPI1_FS1 +#define P_PPI1_FS1 P_UNDEF +#endif + +#ifndef P_PPI1_FS2 +#define P_PPI1_FS2 P_UNDEF +#endif + +#ifndef P_TWI0_SCL +#define P_TWI0_SCL P_UNDEF +#endif + +#ifndef P_TWI0_SDA +#define P_TWI0_SDA P_UNDEF +#endif + +#ifndef P_KEY_COL7 +#define P_KEY_COL7 P_UNDEF +#endif + +#ifndef P_KEY_ROW6 +#define P_KEY_ROW6 P_UNDEF +#endif + +#ifndef P_KEY_COL6 +#define P_KEY_COL6 P_UNDEF +#endif + +#ifndef P_KEY_ROW5 +#define P_KEY_ROW5 P_UNDEF +#endif + +#ifndef P_KEY_COL5 +#define P_KEY_COL5 P_UNDEF +#endif + +#ifndef P_KEY_ROW4 +#define P_KEY_ROW4 P_UNDEF +#endif + +#ifndef P_KEY_COL4 +#define P_KEY_COL4 P_UNDEF +#endif + +#ifndef P_KEY_ROW7 +#define P_KEY_ROW7 P_UNDEF +#endif + +#ifndef P_PPI0_D0 +#define P_PPI0_D0 P_UNDEF +#endif + +#ifndef P_PPI0_D1 +#define P_PPI0_D1 P_UNDEF +#endif + +#ifndef P_PPI0_D2 +#define P_PPI0_D2 P_UNDEF +#endif + +#ifndef P_PPI0_D3 +#define P_PPI0_D3 P_UNDEF +#endif + +#ifndef P_PPI0_D4 +#define P_PPI0_D4 P_UNDEF +#endif + +#ifndef P_PPI0_D5 +#define P_PPI0_D5 P_UNDEF +#endif + +#ifndef P_PPI0_D6 +#define P_PPI0_D6 P_UNDEF +#endif + +#ifndef P_PPI0_D7 +#define P_PPI0_D7 P_UNDEF +#endif + +#ifndef P_PPI0_D8 +#define P_PPI0_D8 P_UNDEF +#endif + +#ifndef P_PPI0_D9 +#define P_PPI0_D9 P_UNDEF +#endif + +#ifndef P_PPI0_D10 +#define P_PPI0_D10 P_UNDEF +#endif + +#ifndef P_PPI0_D11 +#define P_PPI0_D11 P_UNDEF +#endif + +#ifndef P_PPI0_D12 +#define P_PPI0_D12 P_UNDEF +#endif + +#ifndef P_PPI0_D13 +#define P_PPI0_D13 P_UNDEF +#endif + +#ifndef P_PPI0_D14 +#define P_PPI0_D14 P_UNDEF +#endif + +#ifndef P_PPI0_D15 +#define P_PPI0_D15 P_UNDEF +#endif + +#ifndef P_ATAPI_D0A +#define P_ATAPI_D0A P_UNDEF +#endif + +#ifndef P_ATAPI_D1A +#define P_ATAPI_D1A P_UNDEF +#endif + +#ifndef P_ATAPI_D2A +#define P_ATAPI_D2A P_UNDEF +#endif + +#ifndef P_ATAPI_D3A +#define P_ATAPI_D3A P_UNDEF +#endif + +#ifndef P_ATAPI_D4A +#define P_ATAPI_D4A P_UNDEF +#endif + +#ifndef P_ATAPI_D5A +#define P_ATAPI_D5A P_UNDEF +#endif + +#ifndef P_ATAPI_D6A +#define P_ATAPI_D6A P_UNDEF +#endif + +#ifndef P_ATAPI_D7A +#define P_ATAPI_D7A P_UNDEF +#endif + +#ifndef P_ATAPI_D8A +#define P_ATAPI_D8A P_UNDEF +#endif + +#ifndef P_ATAPI_D9A +#define P_ATAPI_D9A P_UNDEF +#endif + +#ifndef P_ATAPI_D10A +#define P_ATAPI_D10A P_UNDEF +#endif + +#ifndef P_ATAPI_D11A +#define P_ATAPI_D11A P_UNDEF +#endif + +#ifndef P_ATAPI_D12A +#define P_ATAPI_D12A P_UNDEF +#endif + +#ifndef P_ATAPI_D13A +#define P_ATAPI_D13A P_UNDEF +#endif + +#ifndef P_ATAPI_D14A +#define P_ATAPI_D14A P_UNDEF +#endif + +#ifndef P_ATAPI_D15A +#define P_ATAPI_D15A P_UNDEF +#endif + +#ifndef P_PPI0_CLK +#define P_PPI0_CLK P_UNDEF +#endif + +#ifndef P_PPI0_FS1 +#define P_PPI0_FS1 P_UNDEF +#endif + +#ifndef P_PPI0_FS2 +#define P_PPI0_FS2 P_UNDEF +#endif + +#ifndef P_PPI0_D16 +#define P_PPI0_D16 P_UNDEF +#endif + +#ifndef P_PPI0_D17 +#define P_PPI0_D17 P_UNDEF +#endif + +#ifndef P_SPI1_SSEL1 +#define P_SPI1_SSEL1 P_UNDEF +#endif + +#ifndef P_SPI1_SSEL2 +#define P_SPI1_SSEL2 P_UNDEF +#endif + +#ifndef P_SPI1_SSEL3 +#define P_SPI1_SSEL3 P_UNDEF +#endif + + +#ifndef P_SPI1_SSEL4 +#define P_SPI1_SSEL4 P_UNDEF +#endif + +#ifndef P_SPI1_SSEL5 +#define P_SPI1_SSEL5 P_UNDEF +#endif + +#ifndef P_SPI1_SSEL6 +#define P_SPI1_SSEL6 P_UNDEF +#endif + +#ifndef P_SPI1_SSEL7 +#define P_SPI1_SSEL7 P_UNDEF +#endif + +#ifndef P_SPI1_SCK +#define P_SPI1_SCK P_UNDEF +#endif + +#ifndef P_SPI1_MISO +#define P_SPI1_MISO P_UNDEF +#endif + +#ifndef P_SPI1_MOSI +#define P_SPI1_MOSI P_UNDEF +#endif + +#ifndef P_SPI1_SS +#define P_SPI1_SS P_UNDEF +#endif + +#ifndef P_CAN0_TX +#define P_CAN0_TX P_UNDEF +#endif + +#ifndef P_CAN0_RX +#define P_CAN0_RX P_UNDEF +#endif + +#ifndef P_CAN1_TX +#define P_CAN1_TX P_UNDEF +#endif + +#ifndef P_CAN1_RX +#define P_CAN1_RX P_UNDEF +#endif + +#ifndef P_ATAPI_A0A +#define P_ATAPI_A0A P_UNDEF +#endif + +#ifndef P_ATAPI_A1A +#define P_ATAPI_A1A P_UNDEF +#endif + +#ifndef P_ATAPI_A2A +#define P_ATAPI_A2A P_UNDEF +#endif + +#ifndef P_HOST_CE +#define P_HOST_CE P_UNDEF +#endif + +#ifndef P_HOST_RD +#define P_HOST_RD P_UNDEF +#endif + +#ifndef P_HOST_WR +#define P_HOST_WR P_UNDEF +#endif + +#ifndef P_MTXONB +#define P_MTXONB P_UNDEF +#endif + +#ifndef P_PPI2_FS2 +#define P_PPI2_FS2 P_UNDEF +#endif + +#ifndef P_PPI2_FS1 +#define P_PPI2_FS1 P_UNDEF +#endif + +#ifndef P_PPI2_CLK +#define P_PPI2_CLK P_UNDEF +#endif + +#ifndef P_CNT_CZM +#define P_CNT_CZM P_UNDEF +#endif + +#ifndef P_UART1_TX +#define P_UART1_TX P_UNDEF +#endif + +#ifndef P_UART1_RX +#define P_UART1_RX P_UNDEF +#endif + +#ifndef P_ATAPI_RESET +#define P_ATAPI_RESET P_UNDEF +#endif + +#ifndef P_HOST_ADDR +#define P_HOST_ADDR P_UNDEF +#endif + +#ifndef P_HOST_ACK +#define P_HOST_ACK P_UNDEF +#endif + +#ifndef P_MTX +#define P_MTX P_UNDEF +#endif + +#ifndef P_MRX +#define P_MRX P_UNDEF +#endif + +#ifndef P_MRXONB +#define P_MRXONB P_UNDEF +#endif + +#ifndef P_A4 +#define P_A4 P_UNDEF +#endif + +#ifndef P_A5 +#define P_A5 P_UNDEF +#endif + +#ifndef P_A6 +#define P_A6 P_UNDEF +#endif + +#ifndef P_A7 +#define P_A7 P_UNDEF +#endif + +#ifndef P_A8 +#define P_A8 P_UNDEF +#endif + +#ifndef P_A9 +#define P_A9 P_UNDEF +#endif + +#ifndef P_PPI1_FS3 +#define P_PPI1_FS3 P_UNDEF +#endif + +#ifndef P_PPI2_FS3 +#define P_PPI2_FS3 P_UNDEF +#endif + +#ifndef P_TMR8 +#define P_TMR8 P_UNDEF +#endif + +#ifndef P_TMR9 +#define P_TMR9 P_UNDEF +#endif + +#ifndef P_TMR10 +#define P_TMR10 P_UNDEF +#endif +#ifndef P_TMR11 +#define P_TMR11 P_UNDEF +#endif + +#ifndef P_DMAR0 +#define P_DMAR0 P_UNDEF +#endif + +#ifndef P_DMAR1 +#define P_DMAR1 P_UNDEF +#endif + +#ifndef P_PPI0_FS3 +#define P_PPI0_FS3 P_UNDEF +#endif + +#ifndef P_CNT_CDG +#define P_CNT_CDG P_UNDEF +#endif + +#ifndef P_CNT_CUD +#define P_CNT_CUD P_UNDEF +#endif + +#ifndef P_A10 +#define P_A10 P_UNDEF +#endif + +#ifndef P_A11 +#define P_A11 P_UNDEF +#endif + +#ifndef P_A12 +#define P_A12 P_UNDEF +#endif + +#ifndef P_A13 +#define P_A13 P_UNDEF +#endif + +#ifndef P_A14 +#define P_A14 P_UNDEF +#endif + +#ifndef P_A15 +#define P_A15 P_UNDEF +#endif + +#ifndef P_A16 +#define P_A16 P_UNDEF +#endif + +#ifndef P_A17 +#define P_A17 P_UNDEF +#endif + +#ifndef P_A18 +#define P_A18 P_UNDEF +#endif + +#ifndef P_A19 +#define P_A19 P_UNDEF +#endif + +#ifndef P_A20 +#define P_A20 P_UNDEF +#endif + +#ifndef P_A21 +#define P_A21 P_UNDEF +#endif + +#ifndef P_A22 +#define P_A22 P_UNDEF +#endif + +#ifndef P_A23 +#define P_A23 P_UNDEF +#endif + +#ifndef P_A24 +#define P_A24 P_UNDEF +#endif + +#ifndef P_A25 +#define P_A25 P_UNDEF +#endif + +#ifndef P_NOR_CLK +#define P_NOR_CLK P_UNDEF +#endif + +#ifndef P_TMRCLK +#define P_TMRCLK P_UNDEF +#endif + +#ifndef P_AMC_ARDY_NOR_WAIT +#define P_AMC_ARDY_NOR_WAIT P_UNDEF +#endif + +#ifndef P_NAND_CE +#define P_NAND_CE P_UNDEF +#endif + +#ifndef P_NAND_RB +#define P_NAND_RB P_UNDEF +#endif + +#ifndef P_ATAPI_DIOR +#define P_ATAPI_DIOR P_UNDEF +#endif + +#ifndef P_ATAPI_DIOW +#define P_ATAPI_DIOW P_UNDEF +#endif + +#ifndef P_ATAPI_CS0 +#define P_ATAPI_CS0 P_UNDEF +#endif + +#ifndef P_ATAPI_CS1 +#define P_ATAPI_CS1 P_UNDEF +#endif + +#ifndef P_ATAPI_DMACK +#define P_ATAPI_DMACK P_UNDEF +#endif + +#ifndef P_ATAPI_DMARQ +#define P_ATAPI_DMARQ P_UNDEF +#endif + +#ifndef P_ATAPI_INTRQ +#define P_ATAPI_INTRQ P_UNDEF +#endif + +#ifndef P_ATAPI_IORDY +#define P_ATAPI_IORDY P_UNDEF +#endif + +#ifndef P_AMC_BR +#define P_AMC_BR P_UNDEF +#endif + +#ifndef P_AMC_BG +#define P_AMC_BG P_UNDEF +#endif + +#ifndef P_AMC_BGH +#define P_AMC_BGH P_UNDEF +#endif + +/* EMAC */ + +#ifndef P_MII0_ETxD0 +#define P_MII0_ETxD0 P_UNDEF +#endif + +#ifndef P_MII0_ETxD1 +#define P_MII0_ETxD1 P_UNDEF +#endif + +#ifndef P_MII0_ETxD2 +#define P_MII0_ETxD2 P_UNDEF +#endif + +#ifndef P_MII0_ETxD3 +#define P_MII0_ETxD3 P_UNDEF +#endif + +#ifndef P_MII0_ETxEN +#define P_MII0_ETxEN P_UNDEF +#endif + +#ifndef P_MII0_TxCLK +#define P_MII0_TxCLK P_UNDEF +#endif + +#ifndef P_MII0_PHYINT +#define P_MII0_PHYINT P_UNDEF +#endif + +#ifndef P_MII0_COL +#define P_MII0_COL P_UNDEF +#endif + +#ifndef P_MII0_ERxD0 +#define P_MII0_ERxD0 P_UNDEF +#endif + +#ifndef P_MII0_ERxD1 +#define P_MII0_ERxD1 P_UNDEF +#endif + +#ifndef P_MII0_ERxD2 +#define P_MII0_ERxD2 P_UNDEF +#endif + +#ifndef P_MII0_ERxD3 +#define P_MII0_ERxD3 P_UNDEF +#endif + +#ifndef P_MII0_ERxDV +#define P_MII0_ERxDV P_UNDEF +#endif + +#ifndef P_MII0_ERxCLK +#define P_MII0_ERxCLK P_UNDEF +#endif + +#ifndef P_MII0_ERxER +#define P_MII0_ERxER P_UNDEF +#endif + +#ifndef P_MII0_CRS +#define P_MII0_CRS P_UNDEF +#endif + +#ifndef P_RMII0_REF_CLK +#define P_RMII0_REF_CLK P_UNDEF +#endif + +#ifndef P_RMII0_MDINT +#define P_RMII0_MDINT P_UNDEF +#endif + +#ifndef P_RMII0_CRS_DV +#define P_RMII0_CRS_DV P_UNDEF +#endif + +#ifndef P_MDC +#define P_MDC P_UNDEF +#endif + +#ifndef P_MDIO +#define P_MDIO P_UNDEF +#endif + +#endif /* _PORTMUX_H_ */ diff --git a/arch/blackfin/include/asm/system.h b/arch/blackfin/include/asm/system.h index 6bc7208..952438e 100644 --- a/arch/blackfin/include/asm/system.h +++ b/arch/blackfin/include/asm/system.h @@ -118,4 +118,6 @@ static inline unsigned long __xchg(unsigned long x, volatile void *ptr, return tmp; }
+void bfin_reset_boot_spi_cs(unsigned short pin); + #endif /* _BLACKFIN_SYSTEM_H */
Now that we have a unified gpio layer, the misc partial gpio commands can be unified and made complete (support all possible gpios).
Signed-off-by: Mike Frysinger vapier@gentoo.org --- arch/blackfin/cpu/Makefile | 1 + arch/blackfin/cpu/cmd_gpio.c | 120 ++++++++++++++++++++++ board/bf537-stamp/Makefile | 2 +- board/bf537-stamp/cmd_bf537led.c | 201 ------------------------------------- board/cm-bf527/Makefile | 2 +- board/cm-bf527/gpio.c | 74 -------------- board/cm-bf537e/Makefile | 2 +- board/cm-bf537e/flash.c | 34 ------ board/cm-bf537u/Makefile | 2 +- board/cm-bf537u/flash.c | 34 ------ board/tcm-bf537/Makefile | 2 +- board/tcm-bf537/flash.c | 37 ------- include/configs/bf537-stamp.h | 2 - include/configs/bfin_adi_common.h | 1 + 14 files changed, 127 insertions(+), 387 deletions(-) create mode 100644 arch/blackfin/cpu/cmd_gpio.c delete mode 100644 board/bf537-stamp/cmd_bf537led.c delete mode 100644 board/cm-bf527/gpio.c delete mode 100644 board/cm-bf537e/flash.c delete mode 100644 board/cm-bf537u/flash.c delete mode 100644 board/tcm-bf537/flash.c
diff --git a/arch/blackfin/cpu/Makefile b/arch/blackfin/cpu/Makefile index 91797c7..b7f991d 100644 --- a/arch/blackfin/cpu/Makefile +++ b/arch/blackfin/cpu/Makefile @@ -18,6 +18,7 @@ CEXTRA := initcode.o SEXTRA := start.o SOBJS := interrupt.o cache.o COBJS-$(CONFIG_BOOTCOUNT_LIMIT) += bootcount.o +COBJS-$(CONFIG_CMD_GPIO) += cmd_gpio.o COBJS-y += cpu.o COBJS-y += gpio.o COBJS-y += interrupts.o diff --git a/arch/blackfin/cpu/cmd_gpio.c b/arch/blackfin/cpu/cmd_gpio.c new file mode 100644 index 0000000..9e505b6 --- /dev/null +++ b/arch/blackfin/cpu/cmd_gpio.c @@ -0,0 +1,120 @@ +/* + * Control GPIO pins on the fly + * + * Copyright (c) 2008-2010 Analog Devices Inc. + * + * Licensed under the GPL-2 or later. + */ + +#include <common.h> +#include <command.h> + +#include <asm/blackfin.h> +#include <asm/gpio.h> + +enum { + GPIO_INPUT, + GPIO_SET, + GPIO_CLEAR, + GPIO_TOGGLE, +}; + +int do_gpio(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + if (argc == 2 && !strcmp(argv[1], "status")) { + bfin_gpio_labels(); + return 0; + } + + if (argc != 3) { + show_usage: + printf("Usage:\n%s\n", cmdtp->usage); + return 1; + } + + /* parse the behavior */ + ulong sub_cmd; + switch (argv[1][0]) { + case 'i': sub_cmd = GPIO_INPUT; break; + case 's': sub_cmd = GPIO_SET; break; + case 'c': sub_cmd = GPIO_CLEAR; break; + case 't': sub_cmd = GPIO_TOGGLE; break; + default: goto show_usage; + } + + /* parse the pin with format: [p][port]<#> */ + const char *str_pin = argv[2]; + + /* grab the [p]<port> portion */ + ulong port_base; + if (*str_pin == 'p') ++str_pin; + switch (*str_pin) { +#ifdef GPIO_PA0 + case 'a': port_base = GPIO_PA0; break; +#endif +#ifdef GPIO_PB0 + case 'b': port_base = GPIO_PB0; break; +#endif +#ifdef GPIO_PC0 + case 'c': port_base = GPIO_PC0; break; +#endif +#ifdef GPIO_PD0 + case 'd': port_base = GPIO_PD0; break; +#endif +#ifdef GPIO_PE0 + case 'e': port_base = GPIO_PE0; break; +#endif +#ifdef GPIO_PF0 + case 'f': port_base = GPIO_PF0; break; +#endif +#ifdef GPIO_PG0 + case 'g': port_base = GPIO_PG0; break; +#endif +#ifdef GPIO_PH0 + case 'h': port_base = GPIO_PH0; break; +#endif +#ifdef GPIO_PI0 + case 'i': port_base = GPIO_PI0; break; +#endif +#ifdef GPIO_PJ + case 'j': port_base = GPIO_PJ0; break; +#endif + default: goto show_usage; + } + + /* grab the <#> portion */ + ulong pin = simple_strtoul(str_pin + 1, NULL, 10); + if (pin > 15) + goto show_usage; + + /* grab the pin before we tweak it */ + ulong gpio = port_base + pin; + gpio_request(gpio, "cmd_gpio"); + + /* finally, let's do it: set direction and exec command */ + if (sub_cmd == GPIO_INPUT) { + gpio_direction_input(gpio); + printf("gpio: pin %lu on port %c set to input\n", pin, *str_pin); + return 0; + } + + ulong value; + switch (sub_cmd) { + case GPIO_SET: value = 1; break; + case GPIO_CLEAR: value = 0; break; + case GPIO_TOGGLE: value = !gpio_get_value(gpio); break; + default: goto show_usage; + } + gpio_direction_output(gpio, value); + printf("gpio: pin %lu on port %c (gpio %lu) value is %lu\n", + pin, *str_pin, gpio, value); + + gpio_free(gpio); + + return 0; +} + +U_BOOT_CMD(gpio, 3, 0, do_gpio, + "set/clear/toggle gpio output pins", + "<set|clear|toggle> <port><pin>\n" + " - set/clear/toggle the specified pin (e.g. PF10)"); diff --git a/board/bf537-stamp/Makefile b/board/bf537-stamp/Makefile index 0e15062..4f8985b 100644 --- a/board/bf537-stamp/Makefile +++ b/board/bf537-stamp/Makefile @@ -29,7 +29,7 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib$(BOARD).a
-COBJS-y := $(BOARD).o cmd_bf537led.o +COBJS-y := $(BOARD).o COBJS-$(CONFIG_BFIN_IDE) += ide-cf.o COBJS-$(CONFIG_POST) += post.o post-memory.o
diff --git a/board/bf537-stamp/cmd_bf537led.c b/board/bf537-stamp/cmd_bf537led.c deleted file mode 100644 index 7d8f3ea..0000000 --- a/board/bf537-stamp/cmd_bf537led.c +++ /dev/null @@ -1,201 +0,0 @@ -/* - * U-boot - cmd_bf537led.c - * - * Copyright (C) 2006 Aaron Gage, Ocean Optics Inc. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ -#include <common.h> -#include <config.h> -#include <command.h> -#include <asm/blackfin.h> -#include <asm/string.h> -#ifdef CONFIG_BF537_STAMP_LEDCMD - -/* Define the command usage in a reusable way */ -#define USAGE_LONG \ - "led <number> <action>\n" \ - " <number> - Index (0-5) of LED to change, or "all"\n" \ - " <action> - Must be one of:\n" \ - " on off toggle" - -/* Number of LEDs supported by the board */ -#define NUMBER_LEDS 6 -/* The BF537 stamp has 6 LEDs. This mask indicates that all should be lit. */ -#define LED_ALL_MASK 0x003F - -void show_cmd_usage(void); -void set_led_state(int index, int state); -void configure_GPIO_to_output(int index); - -/* Map of LEDs according to their GPIO ports. This can be rearranged or - * otherwise changed to account for different GPIO configurations. - */ -int led_ports[] = { PF6, PF7, PF8, PF9, PF10, PF11 }; - -#define ACTION_TOGGLE -1 -#define ACTION_OFF 0 -#define ACTION_ON 1 - -#define LED_STATE_OFF 0 -#define LED_STATE_ON 1 - -/* This is a trivial atoi implementation since we don't have one available */ -int atoi(char *string) -{ - int length; - int retval = 0; - int i; - int sign = 1; - - length = strlen(string); - for (i = 0; i < length; i++) { - if (0 == i && string[0] == '-') { - sign = -1; - continue; - } - if (string[i] > '9' || string[i] < '0') { - break; - } - retval *= 10; - retval += string[i] - '0'; - } - retval *= sign; - return retval; -} - -int do_bf537led(cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[]) -{ - int led_mask = 0; - int led_current_state = 0; - int action = ACTION_OFF; - int temp; - - if (3 != argc) { - /* Not enough arguments, so just show usage information */ - show_cmd_usage(); - return 1; - } - - if (strcmp(argv[1], "all") == 0) { - led_mask = LED_ALL_MASK; - } else { - temp = atoi(argv[1]); - if (temp < 0 || temp >= NUMBER_LEDS) { - printf("Invalid LED number [%s]\n", argv[1]); - show_cmd_usage(); - return 2; - } - led_mask |= (1 << temp); - } - - if (strcmp(argv[2], "off") == 0) { - action = ACTION_OFF; - } else if (strcmp(argv[2], "on") == 0) { - action = ACTION_ON; - } else if (strcmp(argv[2], "toggle") == 0) { - action = ACTION_TOGGLE; - } else { - printf("Invalid action [%s]\n", argv[2]); - show_cmd_usage(); - return 3; - } - - for (temp = 0; temp < NUMBER_LEDS; temp++) { - if ((led_mask & (1 << temp)) > 0) { - /* - * It is possible that the user has wired one of PF6-PF11 to - * something other than an LED, so this will only change a pin - * to output if the user has indicated a state change. This may - * happen a lot, but this way is safer than just setting all pins - * to output. - */ - configure_GPIO_to_output(temp); - - led_current_state = - ((*pPORTFIO & led_ports[temp]) > - 0) ? LED_STATE_ON : LED_STATE_OFF; - /* - printf("LED state for index %d (%x) is %d\n", temp, led_ports[temp], - led_current_state); - printf("*pPORTFIO is %x\n", *pPORTFIO); - */ - if (ACTION_ON == action - || (ACTION_TOGGLE == action - && 0 == led_current_state)) { - printf("Turning LED %d on\n", temp); - set_led_state(temp, LED_STATE_ON); - } else { - printf("Turning LED %d off\n", temp); - set_led_state(temp, LED_STATE_OFF); - } - } - } - - return 0; -} - -/* - * The GPIO pins that go to the LEDs on the BF537 stamp must be configured - * as output. This function simply configures them that way. This could - * be done to all of the GPIO lines at once, but if a user is using a - * custom board, this will try to be nice and only change the GPIO lines - * that the user specifically names. - */ -void configure_GPIO_to_output(int index) -{ - int port; - - port = led_ports[index]; - - /* Clear the Port F Function Enable Register */ - *pPORTF_FER &= ~port; - /* Set the Port F I/O direction register */ - *pPORTFIO_DIR |= port; - /* Clear the Port F I/O Input Enable Register */ - *pPORTFIO_INEN &= ~port; -} - -/* Enforce the given state on the GPIO line for the indicated LED */ -void set_led_state(int index, int state) -{ - int port; - - port = led_ports[index]; - - if (LED_STATE_OFF == state) { - /* Clear the bit to turn off the LED */ - *pPORTFIO &= ~port; - } else { - /* Set the bit to turn on the LED */ - *pPORTFIO |= port; - } -} - -/* Display usage information */ -void show_cmd_usage() -{ - printf("Usage:\n%s\n", USAGE_LONG); -} - -/* Register information for u-boot to find this command */ -U_BOOT_CMD(led, 3, 1, do_bf537led, - "Control BF537 stamp LEDs", USAGE_LONG); - -#endif diff --git a/board/cm-bf527/Makefile b/board/cm-bf527/Makefile index c2cd244..bad018a 100644 --- a/board/cm-bf527/Makefile +++ b/board/cm-bf527/Makefile @@ -29,7 +29,7 @@ include $(TOPDIR)/config.mk
-COBJS-y := $(BOARD).o gpio.o gpio_cfi_flash.o +COBJS-y := $(BOARD).o gpio_cfi_flash.o
SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) OBJS := $(addprefix $(obj),$(COBJS-y)) diff --git a/board/cm-bf527/gpio.c b/board/cm-bf527/gpio.c deleted file mode 100644 index 7e0babe..0000000 --- a/board/cm-bf527/gpio.c +++ /dev/null @@ -1,74 +0,0 @@ -/* - * Control GPIO pins on the fly - * - * Copyright (c) 2008 Analog Devices Inc. - * - * Licensed under the GPL-2 or later. - */ - -#include <common.h> -#include <command.h> - -#include <asm/blackfin.h> - -int do_gpio(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{ - if (argc != 3) { - show_usage: - printf("Usage:\n%s\n", cmdtp->usage); - return 1; - } - - /* parse the behavior */ - ulong port_cmd = 0; - switch (argv[1][0]) { - case 'i': break; - case 's': port_cmd = (PORTFIO_SET - PORTFIO); break; - case 'c': port_cmd = (PORTFIO_CLEAR - PORTFIO); break; - case 't': port_cmd = (PORTFIO_TOGGLE - PORTFIO); break; - default: goto show_usage; - } - - /* parse the pin with format: [p]<fgh><#> */ - const char *str_pin = argv[2]; - - /* grab the [p]<fgh> portion */ - ulong port_base; - if (*str_pin == 'p') ++str_pin; - switch (*str_pin) { - case 'f': port_base = PORTFIO; break; - case 'g': port_base = PORTGIO; break; - case 'h': port_base = PORTHIO; break; - default: goto show_usage; - } - - /* grab the <#> portion */ - ulong pin = simple_strtoul(str_pin+1, NULL, 10); - ulong pin_mask = (1 << pin); - if (pin > 15) - goto show_usage; - - /* finally, let's do it: set direction and exec command */ - switch (*str_pin) { - case 'f': bfin_write_PORTF_FER(bfin_read_PORTF_FER() & ~pin_mask); break; - case 'g': bfin_write_PORTG_FER(bfin_read_PORTG_FER() & ~pin_mask); break; - case 'h': bfin_write_PORTH_FER(bfin_read_PORTH_FER() & ~pin_mask); break; - } - - ulong port_dir = port_base + (PORTFIO_DIR - PORTFIO); - if (argv[1][0] == 'i') - bfin_write16(port_dir, bfin_read16(port_dir) & ~pin_mask); - else { - bfin_write16(port_dir, bfin_read16(port_dir) | pin_mask); - bfin_write16(port_base + port_cmd, pin_mask); - } - - printf("gpio: pin %li on port %c has been %c\n", pin, *str_pin, argv[1][0]); - - return 0; -} - -U_BOOT_CMD(gpio, 3, 0, do_gpio, - "gpio - set/clear/toggle gpio output pins\n", - "<s|c|t> <port><pin>\n" - " - set/clear/toggle the specified pin\n"); diff --git a/board/cm-bf537e/Makefile b/board/cm-bf537e/Makefile index 3812ba1..bad018a 100644 --- a/board/cm-bf537e/Makefile +++ b/board/cm-bf537e/Makefile @@ -29,7 +29,7 @@ include $(TOPDIR)/config.mk
-COBJS-y := $(BOARD).o flash.o gpio_cfi_flash.o +COBJS-y := $(BOARD).o gpio_cfi_flash.o
SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) OBJS := $(addprefix $(obj),$(COBJS-y)) diff --git a/board/cm-bf537e/flash.c b/board/cm-bf537e/flash.c deleted file mode 100644 index a4c1ec0..0000000 --- a/board/cm-bf537e/flash.c +++ /dev/null @@ -1,34 +0,0 @@ -/* - * flash.c - helper commands for working with GPIO-assisted flash - * - * Copyright (c) 2005-2009 Analog Devices Inc. - * - * Licensed under the GPL-2 or later. - */ - -#include <common.h> -#include <command.h> -#include <asm/blackfin.h> -#include "gpio_cfi_flash.h" - -int do_pf(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{ - ulong faddr = CONFIG_SYS_FLASH_BASE; - ushort data; - ulong dflg; - - if (argc > 1) { - dflg = simple_strtoul(argv[1], NULL, 16); - faddr |= (dflg << 21); - gpio_cfi_flash_swizzle((void *)faddr); - } else { - data = bfin_read_PORTFIO(); - printf("Port F data %04x (PF4:%i)\n", data, !!(data & PF4)); - } - - return 0; -} - -U_BOOT_CMD(pf, 3, 0, do_pf, - "set/clear PF4 GPIO flash bank switch\n", - "<pf4> - set PF4 GPIO pin state\n"); diff --git a/board/cm-bf537u/Makefile b/board/cm-bf537u/Makefile index 3812ba1..bad018a 100644 --- a/board/cm-bf537u/Makefile +++ b/board/cm-bf537u/Makefile @@ -29,7 +29,7 @@ include $(TOPDIR)/config.mk
SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) OBJS := $(addprefix $(obj),$(COBJS-y)) diff --git a/board/cm-bf537u/flash.c b/board/cm-bf537u/flash.c deleted file mode 100644 index 52abe79..0000000 --- a/board/cm-bf537u/flash.c +++ /dev/null @@ -1,34 +0,0 @@ -/* - * flash.c - helper commands for working with GPIO-assisted flash - * - * Copyright (c) 2005-2009 Analog Devices Inc. - * - * Licensed under the GPL-2 or later. - */ - -#include <common.h> -#include <command.h> -#include <asm/blackfin.h> -#include "gpio_cfi_flash.h" - -int do_ph(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{ - ulong faddr = CONFIG_SYS_FLASH_BASE; - ushort data; - ulong dflg; - - if (argc > 1) { - dflg = simple_strtoul(argv[1], NULL, 16); - faddr |= (dflg << 21); - gpio_cfi_flash_swizzle((void *)faddr); - } else { - data = bfin_read_PORTHIO(); - printf("Port H data %04x (PH0:%i)\n", data, !!(data & PH0)); - } - - return 0; -} - -U_BOOT_CMD(ph, 3, 0, do_ph, - "set/clear PH0 GPIO flash bank switch\n", - "<ph0> - set PH0 GPIO pin state\n"); diff --git a/board/tcm-bf537/Makefile b/board/tcm-bf537/Makefile index 3812ba1..bad018a 100644 --- a/board/tcm-bf537/Makefile +++ b/board/tcm-bf537/Makefile @@ -29,7 +29,7 @@ include $(TOPDIR)/config.mk
SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) OBJS := $(addprefix $(obj),$(COBJS-y)) diff --git a/board/tcm-bf537/flash.c b/board/tcm-bf537/flash.c deleted file mode 100644 index 14055c6..0000000 --- a/board/tcm-bf537/flash.c +++ /dev/null @@ -1,37 +0,0 @@ -/* - * flash.c - helper commands for working with GPIO-assisted flash - * - * Copyright (c) 2005-2009 Analog Devices Inc. - * - * Licensed under the GPL-2 or later. - */ - -#include <common.h> -#include <command.h> -#include <asm/blackfin.h> -#include "gpio_cfi_flash.h" - -int do_pf(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{ - ulong faddr = CONFIG_SYS_FLASH_BASE; - ushort data; - ulong dflg; - - if (argc == 3) { - dflg = simple_strtoul(argv[1], NULL, 16); - faddr |= (dflg << 21); - dflg = simple_strtoul(argv[2], NULL, 16); - faddr |= (dflg << 22); - gpio_cfi_flash_swizzle((void *)faddr); - } else { - data = bfin_read_PORTFIO(); - printf("Port F data %04x (PF4:%i PF5:%i)\n", data, - !!(data & PF4), !!(data & PF5)); - } - - return 0; -} - -U_BOOT_CMD(pf, 3, 0, do_pf, - "set/clear PF4/PF5 GPIO flash bank switch\n", - "<pf4> <pf5> - set PF4/PF5 GPIO pin state\n"); diff --git a/include/configs/bf537-stamp.h b/include/configs/bf537-stamp.h index 92ceb38..cba4ac0 100644 --- a/include/configs/bf537-stamp.h +++ b/include/configs/bf537-stamp.h @@ -268,8 +268,6 @@ #define CONFIG_RTC_BFIN #define CONFIG_UART_CONSOLE 0
-/* #define CONFIG_BF537_STAMP_LEDCMD 1 */ - /* Define if want to do post memory test */ #undef CONFIG_POST #ifdef CONFIG_POST diff --git a/include/configs/bfin_adi_common.h b/include/configs/bfin_adi_common.h index 1896cf5..fa1e694 100644 --- a/include/configs/bfin_adi_common.h +++ b/include/configs/bfin_adi_common.h @@ -83,6 +83,7 @@ # define CONFIG_CMD_CPLBINFO # define CONFIG_CMD_ELF # define CONFIG_ELF_SIMPLE_LOAD +# define CONFIG_CMD_GPIO # define CONFIG_CMD_KGDB # define CONFIG_CMD_REGINFO # define CONFIG_CMD_STRINGS
When boards define CONFIG_BOARD_SPECIFIC_LED, the common led definitions are OK for Blackfin boards. So switch the few boards using these over to the common code.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- include/configs/bf526-ezbrd.h | 6 ------ include/configs/bf533-stamp.h | 6 ------ include/status_led.h | 3 --- 3 files changed, 0 insertions(+), 15 deletions(-)
diff --git a/include/configs/bf526-ezbrd.h b/include/configs/bf526-ezbrd.h index 711fa27..52aeb5c 100644 --- a/include/configs/bf526-ezbrd.h +++ b/include/configs/bf526-ezbrd.h @@ -161,12 +161,6 @@ /* #define CONFIG_STATUS_LED */ #ifdef CONFIG_STATUS_LED #define CONFIG_BOARD_SPECIFIC_LED -#ifndef __ASSEMBLY__ -typedef unsigned int led_id_t; -void __led_init(led_id_t mask, int state); -void __led_set(led_id_t mask, int state); -void __led_toggle(led_id_t mask); -#endif /* use LED0 to indicate booting/alive */ #define STATUS_LED_BOOT 0 #define STATUS_LED_BIT 1 diff --git a/include/configs/bf533-stamp.h b/include/configs/bf533-stamp.h index 80c4884..d5e82ca 100644 --- a/include/configs/bf533-stamp.h +++ b/include/configs/bf533-stamp.h @@ -231,12 +231,6 @@ /* #define CONFIG_STATUS_LED */ #ifdef CONFIG_STATUS_LED #define CONFIG_BOARD_SPECIFIC_LED -#ifndef __ASSEMBLY__ -typedef unsigned int led_id_t; -void __led_init(led_id_t mask, int state); -void __led_set(led_id_t mask, int state); -void __led_toggle(led_id_t mask); -#endif /* use LED1 to indicate booting/alive */ #define STATUS_LED_BOOT 0 #define STATUS_LED_BIT 1 diff --git a/include/status_led.h b/include/status_led.h index 9dbf01f..f213595 100644 --- a/include/status_led.h +++ b/include/status_led.h @@ -346,9 +346,6 @@ void status_led_set (int led, int state); #elif defined(CONFIG_NIOS2) /* XXX empty just to avoid the error */ /************************************************************************/ -#elif defined(CONFIG_BLACKFIN) -/* XXX empty just to avoid the error */ -/************************************************************************/ #elif defined(CONFIG_V38B)
# define STATUS_LED_BIT 0x0010 /* Timer7 GPIO */
Now that we have a unified gpio layer, the different status led implementations can be switched to the common gpio led driver.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- board/bf526-ezbrd/Makefile | 1 - board/bf526-ezbrd/status-led.c | 56 --------------------------------------- board/bf533-stamp/bf533-stamp.c | 37 ------------------------- include/configs/bf526-ezbrd.h | 6 +++- include/configs/bf533-stamp.h | 10 ++++--- 5 files changed, 10 insertions(+), 100 deletions(-) delete mode 100644 board/bf526-ezbrd/status-led.c
diff --git a/board/bf526-ezbrd/Makefile b/board/bf526-ezbrd/Makefile index a9ff760..f2bd2c2 100644 --- a/board/bf526-ezbrd/Makefile +++ b/board/bf526-ezbrd/Makefile @@ -30,7 +30,6 @@ include $(TOPDIR)/config.mk LIB = $(obj)lib$(BOARD).a
COBJS-y := $(BOARD).o -COBJS-$(CONFIG_STATUS_LED) += status-led.o
SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) OBJS := $(addprefix $(obj),$(COBJS-y)) diff --git a/board/bf526-ezbrd/status-led.c b/board/bf526-ezbrd/status-led.c deleted file mode 100644 index 6327022..0000000 --- a/board/bf526-ezbrd/status-led.c +++ /dev/null @@ -1,56 +0,0 @@ -/* - * U-boot - status leds - * - * Copyright (c) 2005-2009 Analog Devices Inc. - * - * Licensed under the GPL-2 or later. - */ - -#include <common.h> -#include <config.h> -#include <command.h> -#include <status_led.h> - -static void set_led_f(int pf, int state) -{ - switch (state) { - case STATUS_LED_OFF: bfin_write_PORTFIO_CLEAR(pf); break; - case STATUS_LED_BLINKING: bfin_write_PORTFIO_TOGGLE(pf); break; - case STATUS_LED_ON: bfin_write_PORTFIO_SET(pf); break; - } -} -static void set_led_g(int pf, int state) -{ - switch (state) { - case STATUS_LED_OFF: bfin_write_PORTGIO_CLEAR(pf); break; - case STATUS_LED_BLINKING: bfin_write_PORTGIO_TOGGLE(pf); break; - case STATUS_LED_ON: bfin_write_PORTGIO_SET(pf); break; - } -} - -static void set_leds(led_id_t mask, int state) -{ - if (mask & 0x1) set_led_f(PF8, state); - if (mask & 0x2) set_led_g(PG11, state); - if (mask & 0x4) set_led_g(PG12, state); -} - -void __led_init(led_id_t mask, int state) -{ - bfin_write_PORTF_FER(bfin_read_PORTF_FER() & ~(PF8)); - bfin_write_PORTG_FER(bfin_read_PORTG_FER() & ~(PG11 | PG12)); - bfin_write_PORTFIO_INEN(bfin_read_PORTFIO_INEN() & ~(PF8)); - bfin_write_PORTGIO_INEN(bfin_read_PORTGIO_INEN() & ~(PG11 | PG12)); - bfin_write_PORTFIO_DIR(bfin_read_PORTFIO_DIR() | (PF8)); - bfin_write_PORTGIO_DIR(bfin_read_PORTGIO_DIR() | (PG11 | PG12)); -} - -void __led_set(led_id_t mask, int state) -{ - set_leds(mask, state); -} - -void __led_toggle(led_id_t mask) -{ - set_leds(mask, STATUS_LED_BLINKING); -} diff --git a/board/bf533-stamp/bf533-stamp.c b/board/bf533-stamp/bf533-stamp.c index 4abad08..fd10eae 100644 --- a/board/bf533-stamp/bf533-stamp.c +++ b/board/bf533-stamp/bf533-stamp.c @@ -134,43 +134,6 @@ void show_boot_progress(int status) } #endif
-#ifdef CONFIG_STATUS_LED -#include <status_led.h> - -static void set_led(int pf, int state) -{ - switch (state) { - case STATUS_LED_OFF: bfin_write_FIO_FLAG_S(pf); break; - case STATUS_LED_BLINKING: bfin_write_FIO_FLAG_T(pf); break; - case STATUS_LED_ON: bfin_write_FIO_FLAG_C(pf); break; - } -} - -static void set_leds(led_id_t mask, int state) -{ - if (mask & 0x1) set_led(PF2, state); - if (mask & 0x2) set_led(PF3, state); - if (mask & 0x4) set_led(PF4, state); -} - -void __led_init(led_id_t mask, int state) -{ - bfin_write_FIO_INEN(bfin_read_FIO_INEN() & ~(PF2 | PF3 | PF4)); - bfin_write_FIO_DIR(bfin_read_FIO_DIR() | (PF2 | PF3 | PF4)); -} - -void __led_set(led_id_t mask, int state) -{ - set_leds(mask, state); -} - -void __led_toggle(led_id_t mask) -{ - set_leds(mask, STATUS_LED_BLINKING); -} - -#endif - #ifdef CONFIG_SMC91111 int board_eth_init(bd_t *bis) { diff --git a/include/configs/bf526-ezbrd.h b/include/configs/bf526-ezbrd.h index 52aeb5c..ecda216 100644 --- a/include/configs/bf526-ezbrd.h +++ b/include/configs/bf526-ezbrd.h @@ -160,17 +160,19 @@ /* define to enable run status via led */ /* #define CONFIG_STATUS_LED */ #ifdef CONFIG_STATUS_LED +#define CONFIG_GPIO_LED #define CONFIG_BOARD_SPECIFIC_LED /* use LED0 to indicate booting/alive */ #define STATUS_LED_BOOT 0 -#define STATUS_LED_BIT 1 +#define STATUS_LED_BIT GPIO_PF8 #define STATUS_LED_STATE STATUS_LED_ON #define STATUS_LED_PERIOD (CONFIG_SYS_HZ / 4) /* use LED1 to indicate crash */ #define STATUS_LED_CRASH 1 -#define STATUS_LED_BIT1 2 +#define STATUS_LED_BIT1 GPIO_PG11 #define STATUS_LED_STATE1 STATUS_LED_ON #define STATUS_LED_PERIOD1 (CONFIG_SYS_HZ / 2) +/* #define STATUS_LED_BIT2 GPIO_PG12 */ #endif
diff --git a/include/configs/bf533-stamp.h b/include/configs/bf533-stamp.h index d5e82ca..2ec9c42 100644 --- a/include/configs/bf533-stamp.h +++ b/include/configs/bf533-stamp.h @@ -230,17 +230,19 @@ /* define to enable run status via led */ /* #define CONFIG_STATUS_LED */ #ifdef CONFIG_STATUS_LED +#define CONFIG_GPIO_LED #define CONFIG_BOARD_SPECIFIC_LED -/* use LED1 to indicate booting/alive */ +/* use LED0 to indicate booting/alive */ #define STATUS_LED_BOOT 0 -#define STATUS_LED_BIT 1 +#define STATUS_LED_BIT GPIO_PF2 #define STATUS_LED_STATE STATUS_LED_ON #define STATUS_LED_PERIOD (CONFIG_SYS_HZ / 4) -/* use LED2 to indicate crash */ +/* use LED1 to indicate crash */ #define STATUS_LED_CRASH 1 -#define STATUS_LED_BIT1 2 +#define STATUS_LED_BIT1 GPIO_PF3 #define STATUS_LED_STATE1 STATUS_LED_ON #define STATUS_LED_PERIOD1 (CONFIG_SYS_HZ / 2) +/* #define STATUS_LED_BIT2 GPIO_PF4 */ #endif
/* define to enable splash screen support */
The common gpio code provides a function for handling the spi boot workaround logic, so switch over to that rather than bang on the gpio MMRs directly.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- board/bf537-stamp/bf537-stamp.c | 7 ++----- 1 files changed, 2 insertions(+), 5 deletions(-)
diff --git a/board/bf537-stamp/bf537-stamp.c b/board/bf537-stamp/bf537-stamp.c index 3911be6..ec888d4 100644 --- a/board/bf537-stamp/bf537-stamp.c +++ b/board/bf537-stamp/bf537-stamp.c @@ -46,11 +46,8 @@ int checkboard(void) void board_reset(void) { /* workaround for weak pull ups on ssel */ - if (CONFIG_BFIN_BOOT_MODE == BFIN_BOOT_SPI_MASTER) { - bfin_write_PORTF_FER(bfin_read_PORTF_FER() & ~PF10); - bfin_write_PORTFIO_SET(PF10); - udelay(1); - } + if (CONFIG_BFIN_BOOT_MODE == BFIN_BOOT_SPI_MASTER) + bfin_reset_boot_spi_cs(GPIO_PF10); }
#ifdef CONFIG_BFIN_MAC
Use the common gpio layer rather than bang on MMRs directly.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- board/cm-bf527/gpio_cfi_flash.c | 21 +++++++++------------ board/cm-bf537e/gpio_cfi_flash.c | 18 ++++++++---------- board/cm-bf537u/gpio_cfi_flash.c | 18 ++++++++---------- board/tcm-bf537/gpio_cfi_flash.c | 20 +++++++++----------- 4 files changed, 34 insertions(+), 43 deletions(-)
diff --git a/board/cm-bf527/gpio_cfi_flash.c b/board/cm-bf527/gpio_cfi_flash.c index 7167680..f8ccc07 100644 --- a/board/cm-bf527/gpio_cfi_flash.c +++ b/board/cm-bf527/gpio_cfi_flash.c @@ -8,12 +8,13 @@
#include <common.h> #include <asm/blackfin.h> +#include <asm/gpio.h> #include <asm/io.h> #include "gpio_cfi_flash.h"
-#define GPIO_PIN_1 PH9 +#define GPIO_PIN_1 GPIO_PH9 #define GPIO_MASK_1 (1 << 21) -#define GPIO_PIN_2 PG11 +#define GPIO_PIN_2 GPIO_PG11 #define GPIO_MASK_2 (1 << 22) #define GPIO_MASK (GPIO_MASK_1 | GPIO_MASK_2)
@@ -21,16 +22,10 @@ void *gpio_cfi_flash_swizzle(void *vaddr) { unsigned long addr = (unsigned long)vaddr;
- if (addr & GPIO_MASK_1) - bfin_write_PORTHIO_SET(GPIO_PIN_1); - else - bfin_write_PORTHIO_CLEAR(GPIO_PIN_1); + gpio_set_value(GPIO_PIN_1, addr & GPIO_MASK_1);
#ifdef GPIO_MASK_2 - if (addr & GPIO_MASK_2) - bfin_write_PORTGIO_SET(GPIO_PIN_2); - else - bfin_write_PORTGIO_CLEAR(GPIO_PIN_2); + gpio_set_value(GPIO_PIN_2, addr & GPIO_MASK_2); #endif
SSYNC(); @@ -57,7 +52,9 @@ MAKE_FLASH(64, q) /* flash_write64() flash_read64() */
void gpio_cfi_flash_init(void) { - bfin_write_PORTHIO_DIR(bfin_read_PORTHIO_DIR() | GPIO_PIN_1); - bfin_write_PORTGIO_DIR(bfin_read_PORTGIO_DIR() | GPIO_PIN_2); + gpio_request(GPIO_PIN_1, "gpio_cfi_flash"); +#ifdef GPIO_MASK_2 + gpio_request(GPIO_PIN_2, "gpio_cfi_flash"); +#endif gpio_cfi_flash_swizzle((void *)CONFIG_SYS_FLASH_BASE); } diff --git a/board/cm-bf537e/gpio_cfi_flash.c b/board/cm-bf537e/gpio_cfi_flash.c index a9e69cf..79ee844 100644 --- a/board/cm-bf537e/gpio_cfi_flash.c +++ b/board/cm-bf537e/gpio_cfi_flash.c @@ -8,10 +8,11 @@
-#define GPIO_PIN_1 PF4 +#define GPIO_PIN_1 GPIO_PF4 #define GPIO_MASK_1 (1 << 21) #define GPIO_MASK (GPIO_MASK_1)
@@ -19,16 +20,10 @@ void *gpio_cfi_flash_swizzle(void *vaddr) { unsigned long addr = (unsigned long)vaddr;
- if (addr & GPIO_MASK_1) - bfin_write_PORTFIO_SET(GPIO_PIN_1); - else - bfin_write_PORTFIO_CLEAR(GPIO_PIN_1); + gpio_set_value(GPIO_PIN_1, addr & GPIO_MASK_1);
SSYNC(); @@ -55,6 +50,9 @@ MAKE_FLASH(64, q) /* flash_write64() flash_read64() */
void gpio_cfi_flash_init(void) { - bfin_write_PORTFIO_DIR(bfin_read_PORTFIO_DIR() | GPIO_PIN_1); + gpio_request(GPIO_PIN_1, "gpio_cfi_flash"); +#ifdef GPIO_MASK_2 + gpio_request(GPIO_PIN_2, "gpio_cfi_flash"); +#endif gpio_cfi_flash_swizzle((void *)CONFIG_SYS_FLASH_BASE); } diff --git a/board/cm-bf537u/gpio_cfi_flash.c b/board/cm-bf537u/gpio_cfi_flash.c index 68633ec..416c689 100644 --- a/board/cm-bf537u/gpio_cfi_flash.c +++ b/board/cm-bf537u/gpio_cfi_flash.c @@ -8,10 +8,11 @@
-#define GPIO_PIN_1 PH0 +#define GPIO_PIN_1 GPIO_PH0 #define GPIO_MASK_1 (1 << 21) #define GPIO_MASK (GPIO_MASK_1)
void gpio_cfi_flash_init(void) { - bfin_write_PORTHIO_DIR(bfin_read_PORTHIO_DIR() | GPIO_PIN_1); + gpio_request(GPIO_PIN_1, "gpio_cfi_flash"); +#ifdef GPIO_MASK_2 + gpio_request(GPIO_PIN_2, "gpio_cfi_flash"); +#endif gpio_cfi_flash_swizzle((void *)CONFIG_SYS_FLASH_BASE); } diff --git a/board/tcm-bf537/gpio_cfi_flash.c b/board/tcm-bf537/gpio_cfi_flash.c index ac8587c..08ea7af 100644 --- a/board/tcm-bf537/gpio_cfi_flash.c +++ b/board/tcm-bf537/gpio_cfi_flash.c @@ -8,12 +8,13 @@
-#define GPIO_PIN_1 PF4 +#define GPIO_PIN_1 GPIO_PF4 #define GPIO_MASK_1 (1 << 21) -#define GPIO_PIN_2 PF5 +#define GPIO_PIN_2 GPIO_PF5 #define GPIO_MASK_2 (1 << 22) #define GPIO_MASK (GPIO_MASK_1 | GPIO_MASK_2)
#ifdef GPIO_MASK_2 - if (addr & GPIO_MASK_2) - bfin_write_PORTFIO_SET(GPIO_PIN_2); - else - bfin_write_PORTFIO_CLEAR(GPIO_PIN_2); + gpio_set_value(GPIO_PIN_2, addr & GPIO_MASK_2); #endif
SSYNC(); @@ -57,6 +52,9 @@ MAKE_FLASH(64, q) /* flash_write64() flash_read64() */
void gpio_cfi_flash_init(void) { - bfin_write_PORTFIO_DIR(bfin_read_PORTFIO_DIR() | GPIO_PIN_1 | GPIO_PIN_2); + gpio_request(GPIO_PIN_1, "gpio_cfi_flash"); +#ifdef GPIO_MASK_2 + gpio_request(GPIO_PIN_2, "gpio_cfi_flash"); +#endif gpio_cfi_flash_swizzle((void *)CONFIG_SYS_FLASH_BASE); }
Rather than bang MMRs directly, use the new portmux framework to handle the details. While we're doing this, let boards declare the exact list of pins they need in case there is one or two they don't actually have hooked up.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- drivers/net/bfin_mac.c | 47 +++++++++++------------------------------------ 1 files changed, 11 insertions(+), 36 deletions(-)
diff --git a/drivers/net/bfin_mac.c b/drivers/net/bfin_mac.c index 720e126..ee4ad6c 100644 --- a/drivers/net/bfin_mac.c +++ b/drivers/net/bfin_mac.c @@ -16,6 +16,7 @@ #include <linux/mii.h>
#include <asm/blackfin.h> +#include <asm/portmux.h> #include <asm/mach-common/bits/dma.h> #include <asm/mach-common/bits/emac.h> #include <asm/mach-common/bits/pll.h> @@ -213,8 +214,17 @@ static int bfin_EMAC_recv(struct eth_device *dev) /* MDC = SCLK / MDC_freq / 2 - 1 */ #define MDC_FREQ_TO_DIV(mdc_freq) (get_sclk() / (mdc_freq) / 2 - 1)
+#ifndef CONFIG_BFIN_MAC_PINS +# ifdef CONFIG_RMII +# define CONFIG_BFIN_MAC_PINS P_RMII0 +# else +# define CONFIG_BFIN_MAC_PINS P_MII0 +# endif +#endif + static int bfin_miiphy_init(struct eth_device *dev, int *opmode) { + const unsigned short pins[] = CONFIG_BFIN_MAC_PINS; u16 phydat; size_t count;
@@ -222,42 +232,7 @@ static int bfin_miiphy_init(struct eth_device *dev, int *opmode) *pVR_CTL |= CLKBUFOE;
/* Set all the pins to peripheral mode */ -#ifdef CONFIG_RMII - /* grab RMII pins */ -# if defined(__ADSPBF51x__) - *pPORTF_MUX = (*pPORTF_MUX & \ - ~(PORT_x_MUX_3_MASK | PORT_x_MUX_4_MASK | PORT_x_MUX_5_MASK)) | \ - PORT_x_MUX_3_FUNC_1 | PORT_x_MUX_4_FUNC_1 | PORT_x_MUX_5_FUNC_1; - *pPORTF_FER |= PF8 | PF9 | PF10 | PF11 | PF12 | PF13 | PF14 | PF15; - *pPORTG_MUX = (*pPORTG_MUX & ~PORT_x_MUX_0_MASK) | PORT_x_MUX_0_FUNC_1; - *pPORTG_FER |= PG0 | PG1 | PG2; -# elif defined(__ADSPBF52x__) - *pPORTG_MUX = (*pPORTG_MUX & ~PORT_x_MUX_6_MASK) | PORT_x_MUX_6_FUNC_2; - *pPORTG_FER |= PG14 | PG15; - *pPORTH_MUX = (*pPORTH_MUX & ~(PORT_x_MUX_0_MASK | PORT_x_MUX_1_MASK)) | \ - PORT_x_MUX_0_FUNC_2 | PORT_x_MUX_1_FUNC_2; - *pPORTH_FER |= PH0 | PH1 | PH2 | PH3 | PH4 | PH5 | PH6 | PH7 | PH8; -# else - *pPORTH_FER |= PH0 | PH1 | PH4 | PH5 | PH6 | PH8 | PH9 | PH14 | PH15; -# endif -#else - /* grab MII & RMII pins */ -# if defined(__ADSPBF51x__) - *pPORTF_MUX = (*pPORTF_MUX & \ - ~(PORT_x_MUX_0_MASK | PORT_x_MUX_1_MASK | PORT_x_MUX_3_MASK | PORT_x_MUX_4_MASK | PORT_x_MUX_5_MASK)) | \ - PORT_x_MUX_0_FUNC_1 | PORT_x_MUX_1_FUNC_1 | PORT_x_MUX_3_FUNC_1 | PORT_x_MUX_4_FUNC_1 | PORT_x_MUX_5_FUNC_1; - *pPORTF_FER |= PF0 | PF1 | PF2 | PF3 | PF4 | PF5 | PF6 | PF8 | PF9 | PF10 | PF11 | PF12 | PF13 | PF14 | PF15; - *pPORTG_MUX = (*pPORTG_MUX & ~PORT_x_MUX_0_MASK) | PORT_x_MUX_0_FUNC_1; - *pPORTG_FER |= PG0 | PG1 | PG2; -# elif defined(__ADSPBF52x__) - *pPORTG_MUX = (*pPORTG_MUX & ~PORT_x_MUX_6_MASK) | PORT_x_MUX_6_FUNC_2; - *pPORTG_FER |= PG14 | PG15; - *pPORTH_MUX = PORT_x_MUX_0_FUNC_2 | PORT_x_MUX_1_FUNC_2 | PORT_x_MUX_2_FUNC_2; - *pPORTH_FER = -1; /* all pins */ -# else - *pPORTH_FER = -1; /* all pins */ -# endif -#endif + peripheral_request_list(pins, "bfin_mac");
/* Odd word alignment for Receive Frame DMA word */ /* Configure checksum support and rcve frame word alignment */
Hi Mike,
Signed-off-by: Mike Frysingervapier@gentoo.org
Applied to net repo.
thanks, Ben
Hi Mike,
On 7/11/2010 11:52 PM, Ben Warren wrote:
Hi Mike,
thanks, Ben
Instead, please keep together with all the others, and add this:
Acked-by: Ben Warrenbiggerbadderben@gmail.com
regards, Ben
done, thanks -mike
Signed-off-by: Mike Frysinger vapier@gentoo.org --- drivers/mtd/nand/bfin_nand.c | 16 ++++++++-------- 1 files changed, 8 insertions(+), 8 deletions(-)
diff --git a/drivers/mtd/nand/bfin_nand.c b/drivers/mtd/nand/bfin_nand.c index 6d3d450..3ee060f 100644 --- a/drivers/mtd/nand/bfin_nand.c +++ b/drivers/mtd/nand/bfin_nand.c @@ -26,6 +26,7 @@ #include <nand.h>
/* Bit masks for NFC_CTL */
@@ -337,6 +338,12 @@ static struct nand_ecclayout bootrom_ecclayout = { */ int board_nand_init(struct nand_chip *chip) { + const unsigned short pins[] = { + P_NAND_CE, P_NAND_RB, P_NAND_D0, P_NAND_D1, P_NAND_D2, + P_NAND_D3, P_NAND_D4, P_NAND_D5, P_NAND_D6, P_NAND_D7, + P_NAND_WE, P_NAND_RE, P_NAND_CLE, P_NAND_ALE, 0, + }; + pr_stamp();
/* set width/ecc/timings/etc... */ @@ -347,14 +354,7 @@ int board_nand_init(struct nand_chip *chip) bfin_write_NFC_IRQSTAT(0xffff);
/* enable GPIO function enable register */ -#ifdef __ADSPBF54x__ - bfin_write_PORTJ_FER(bfin_read_PORTJ_FER() | 6); -#elif defined(__ADSPBF52x__) - bfin_write_PORTH_FER(bfin_read_PORTH_FER() | 0xFCFF); - bfin_write_PORTH_MUX(0); -#else -# error no support for this variant -#endif + peripheral_request_list(pins, "bfin_nand");
chip->cmd_ctrl = bfin_nfc_cmd_ctrl; chip->read_buf = bfin_nfc_read_buf;
Acked-by: Scott Wood scottwood@freescale.com
-Scott
Signed-off-by: Mike Frysinger vapier@gentoo.org --- drivers/mmc/bfin_sdh.c | 18 +++++++++--------- 1 files changed, 9 insertions(+), 9 deletions(-)
diff --git a/drivers/mmc/bfin_sdh.c b/drivers/mmc/bfin_sdh.c index f9d560a..4a77779 100644 --- a/drivers/mmc/bfin_sdh.c +++ b/drivers/mmc/bfin_sdh.c @@ -15,6 +15,7 @@ #include <asm/errno.h> #include <asm/byteorder.h> #include <asm/blackfin.h> +#include <asm/portmux.h> #include <asm/mach-common/bits/sdh.h> #include <asm/mach-common/bits/dma.h>
@@ -41,11 +42,15 @@ # define bfin_write_DMA_X_COUNT bfin_write_DMA4_X_COUNT # define bfin_write_DMA_X_MODIFY bfin_write_DMA4_X_MODIFY # define bfin_write_DMA_CONFIG bfin_write_DMA4_CONFIG +# define PORTMUX_PINS \ + { P_RSI_DATA0, P_RSI_DATA1, P_RSI_DATA2, P_RSI_DATA3, P_RSI_CMD, P_RSI_CLK, 0 } #elif defined(__ADSPBF54x__) # define bfin_write_DMA_START_ADDR bfin_write_DMA22_START_ADDR # define bfin_write_DMA_X_COUNT bfin_write_DMA22_X_COUNT # define bfin_write_DMA_X_MODIFY bfin_write_DMA22_X_MODIFY # define bfin_write_DMA_CONFIG bfin_write_DMA22_CONFIG +# define PORTMUX_PINS \ + { P_SD_D0, P_SD_D1, P_SD_D2, P_SD_D3, P_SD_CLK, P_SD_CMD, 0 } #else # error no support for this proc yet #endif @@ -208,18 +213,13 @@ static void bfin_sdh_set_ios(struct mmc *mmc)
static int bfin_sdh_init(struct mmc *mmc) { - + const unsigned short pins[] = PORTMUX_PINS; u16 pwr_ctl = 0; -/* Initialize sdh controller */ + + /* Initialize sdh controller */ + peripheral_request_list(pins, "bfin_sdh"); #if defined(__ADSPBF54x__) bfin_write_DMAC1_PERIMUX(bfin_read_DMAC1_PERIMUX() | 0x1); - bfin_write_PORTC_FER(bfin_read_PORTC_FER() | 0x3F00); - bfin_write_PORTC_MUX(bfin_read_PORTC_MUX() & ~0xFFF0000); -#elif defined(__ADSPBF51x__) - bfin_write_PORTG_FER(bfin_read_PORTG_FER() | 0x01F8); - bfin_write_PORTG_MUX((bfin_read_PORTG_MUX() & ~0x3FC) | 0x154); -#else -# error no portmux for this proc yet #endif bfin_write_SDH_CFG(bfin_read_SDH_CFG() | CLKS_EN); /* Disable card detect pin */
Signed-off-by: Mike Frysinger vapier@gentoo.org --- drivers/block/pata_bfin.c | 25 ++++++++++++------------- 1 files changed, 12 insertions(+), 13 deletions(-)
diff --git a/drivers/block/pata_bfin.c b/drivers/block/pata_bfin.c index f16dabe..847c032 100644 --- a/drivers/block/pata_bfin.c +++ b/drivers/block/pata_bfin.c @@ -14,6 +14,7 @@ #include <asm/byteorder.h> #include <asm/io.h> #include <asm/errno.h> +#include <asm/portmux.h> #include <asm/mach-common/bits/pata.h> #include <ata.h> #include <libata.h> @@ -769,19 +770,17 @@ static int bfin_ata_reset_port(struct ata_port *ap) */ static int bfin_config_atapi_gpio(struct ata_port *ap) { - bfin_write_PORTH_FER(bfin_read_PORTH_FER() | 0x4); - bfin_write_PORTH_MUX(bfin_read_PORTH_MUX() & ~0x30); - bfin_write_PORTH_DIR_SET(0x4); - - bfin_write_PORTJ_FER(0x7f8); - bfin_write_PORTJ_MUX(bfin_read_PORTI_MUX() & ~0x3fffc0); - bfin_write_PORTJ_DIR_SET(0x5f8); - bfin_write_PORTJ_DIR_CLEAR(0x200); - bfin_write_PORTJ_INEN(0x200); - - bfin_write_PINT2_ASSIGN(0x0707); - bfin_write_PINT2_MASK_SET(0x200); - SSYNC(); + const unsigned short pins[] = { + P_ATAPI_RESET, P_ATAPI_DIOR, P_ATAPI_DIOW, P_ATAPI_CS0, + P_ATAPI_CS1, P_ATAPI_DMACK, P_ATAPI_DMARQ, P_ATAPI_INTRQ, + P_ATAPI_IORDY, P_ATAPI_D0A, P_ATAPI_D1A, P_ATAPI_D2A, + P_ATAPI_D3A, P_ATAPI_D4A, P_ATAPI_D5A, P_ATAPI_D6A, + P_ATAPI_D7A, P_ATAPI_D8A, P_ATAPI_D9A, P_ATAPI_D10A, + P_ATAPI_D11A, P_ATAPI_D12A, P_ATAPI_D13A, P_ATAPI_D14A, + P_ATAPI_D15A, P_ATAPI_A0A, P_ATAPI_A1A, P_ATAPI_A2A, 0, + }; + + peripheral_request_list(pins, "pata_bfin");
return 0; }
Use the new portmux framework to handle the details when possible. Unfortunately, we cannot yet use this in the standalone initialization logic, so we need to keep around the old portmux writes for now.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- arch/blackfin/cpu/serial.h | 19 +++++++++++++++++++ 1 files changed, 19 insertions(+), 0 deletions(-)
diff --git a/arch/blackfin/cpu/serial.h b/arch/blackfin/cpu/serial.h index 5f9be86..f9e311f 100644 --- a/arch/blackfin/cpu/serial.h +++ b/arch/blackfin/cpu/serial.h @@ -26,6 +26,8 @@
+#include <asm/portmux.h> + #define LOB(x) ((x) & 0xFF) #define HIB(x) (((x) >> 8) & 0xFF)
@@ -103,6 +105,23 @@ struct bfin_mmr_serial { __attribute__((always_inline)) static inline void serial_do_portmux(void) { + if (!BFIN_DEBUG_EARLY_SERIAL) { + const unsigned short pins[] = { +#if CONFIG_UART_CONSOLE == 0 + P_UART0_TX, P_UART0_RX, +#elif CONFIG_UART_CONSOLE == 1 + P_UART1_TX, P_UART1_RX, +#elif CONFIG_UART_CONSOLE == 2 + P_UART2_TX, P_UART2_RX, +#elif CONFIG_UART_CONSOLE == 3 + P_UART3_TX, P_UART3_RX, +#endif + 0, + }; + peripheral_request_list(pins, "bfin-uart"); + return; + } + #if defined(__ADSPBF51x__) # define DO_MUX(port, mux_tx, mux_rx, tx, rx) \ bfin_write_PORT##port##_MUX((bfin_read_PORT##port##_MUX() & ~(PORT_x_MUX_##mux_tx##_MASK | PORT_x_MUX_##mux_rx##_MASK)) | PORT_x_MUX_##mux_tx##_FUNC_2 | PORT_x_MUX_##mux_rx##_FUNC_2); \
Signed-off-by: Mike Frysinger vapier@gentoo.org --- drivers/spi/bfin_spi.c | 209 ++++++++++++------------------------------------ 1 files changed, 50 insertions(+), 159 deletions(-)
diff --git a/drivers/spi/bfin_spi.c b/drivers/spi/bfin_spi.c index f28d42b..4e008a7 100644 --- a/drivers/spi/bfin_spi.c +++ b/drivers/spi/bfin_spi.c @@ -13,6 +13,7 @@ #include <spi.h>
#include <asm/blackfin.h> +#include <asm/portmux.h> #include <asm/mach-common/bits/spi.h>
struct bfin_spi_slave { @@ -81,6 +82,42 @@ void spi_init() { }
+#ifdef SPI_CTL +# define SPI0_CTL SPI_CTL +#endif + +#define SPI_PINS(n) \ + [n] = { 0, P_SPI##n##_SCK, P_SPI##n##_MISO, P_SPI##n##_MOSI, 0 } +static unsigned short pins[][5] = { +#ifdef SPI0_CTL + SPI_PINS(0), +#endif +#ifdef SPI1_CTL + SPI_PINS(1), +#endif +#ifdef SPI2_CTL + SPI_PINS(2), +#endif +}; + +#define SPI_CS_PINS(n) \ + [n] = { \ + P_SPI##n##_SSEL1, P_SPI##n##_SSEL2, P_SPI##n##_SSEL3, \ + P_SPI##n##_SSEL4, P_SPI##n##_SSEL5, P_SPI##n##_SSEL6, \ + P_SPI##n##_SSEL7, \ + } +static const unsigned short cs_pins[][7] = { +#ifdef SPI0_CTL + SPI_CS_PINS(0), +#endif +#ifdef SPI1_CTL + SPI_CS_PINS(1), +#endif +#ifdef SPI2_CTL + SPI_CS_PINS(2), +#endif +}; + struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, unsigned int max_hz, unsigned int mode) { @@ -92,11 +129,14 @@ struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, if (!spi_cs_is_valid(bus, cs)) return NULL;
+ if (bus >= ARRAY_SIZE(pins) || pins[bus] == NULL) { + debug("%s: invalid bus %u\n", __func__, bus); + return NULL; + } switch (bus) { -#ifdef SPI_CTL -# define SPI0_CTL SPI_CTL -#endif +#ifdef SPI0_CTL case 0: mmr_base = SPI0_CTL; break; +#endif #ifdef SPI1_CTL case 1: mmr_base = SPI1_CTL; break; #endif @@ -142,168 +182,15 @@ void spi_free_slave(struct spi_slave *slave) free(bss); }
-static void spi_portmux(struct spi_slave *slave) -{ -#if defined(__ADSPBF51x__) -#define SET_MUX(port, mux, func) port##_mux = ((port##_mux & ~PORT_x_MUX_##mux##_MASK) | PORT_x_MUX_##mux##_FUNC_##func) - u16 f_mux = bfin_read_PORTF_MUX(); - u16 f_fer = bfin_read_PORTF_FER(); - u16 g_mux = bfin_read_PORTG_MUX(); - u16 g_fer = bfin_read_PORTG_FER(); - u16 h_mux = bfin_read_PORTH_MUX(); - u16 h_fer = bfin_read_PORTH_FER(); - switch (slave->bus) { - case 0: - /* set SCK/MISO/MOSI */ - SET_MUX(g, 7, 1); - g_fer |= PG12 | PG13 | PG14; - switch (slave->cs) { - case 1: SET_MUX(f, 2, 1); f_fer |= PF7; break; - case 2: /* see G above */ g_fer |= PG15; break; - case 3: SET_MUX(h, 1, 3); f_fer |= PH4; break; - case 4: /* no muxing */ h_fer |= PH8; break; - case 5: SET_MUX(g, 1, 3); h_fer |= PG3; break; - case 6: /* no muxing */ break; - case 7: /* no muxing */ break; - } - case 1: - /* set SCK/MISO/MOSI */ - SET_MUX(h, 0, 2); - h_fer |= PH1 | PH2 | PH3; - switch (slave->cs) { - case 1: SET_MUX(h, 2, 3); h_fer |= PH6; break; - case 2: SET_MUX(f, 0, 3); f_fer |= PF0; break; - case 3: SET_MUX(g, 0, 3); g_fer |= PG0; break; - case 4: SET_MUX(f, 3, 3); f_fer |= PF8; break; - case 5: SET_MUX(g, 6, 3); h_fer |= PG11; break; - case 6: /* no muxing */ break; - case 7: /* no muxing */ break; - } - } - bfin_write_PORTF_MUX(f_mux); - bfin_write_PORTF_FER(f_fer); - bfin_write_PORTG_MUX(g_mux); - bfin_write_PORTG_FER(g_fer); - bfin_write_PORTH_MUX(h_mux); - bfin_write_PORTH_FER(h_fer); -#elif defined(__ADSPBF52x__) -#define SET_MUX(port, mux, func) port##_mux = ((port##_mux & ~PORT_x_MUX_##mux##_MASK) | PORT_x_MUX_##mux##_FUNC_##func) - u16 f_mux = bfin_read_PORTF_MUX(); - u16 f_fer = bfin_read_PORTF_FER(); - u16 g_mux = bfin_read_PORTG_MUX(); - u16 g_fer = bfin_read_PORTG_FER(); - u16 h_mux = bfin_read_PORTH_MUX(); - u16 h_fer = bfin_read_PORTH_FER(); - /* set SCK/MISO/MOSI */ - SET_MUX(g, 0, 3); - g_fer |= PG2 | PG3 | PG4; - switch (slave->cs) { - case 1: /* see G above */ g_fer |= PG1; break; - case 2: SET_MUX(f, 4, 3); f_fer |= PF12; break; - case 3: SET_MUX(f, 4, 3); f_fer |= PF13; break; - case 4: SET_MUX(h, 1, 1); h_fer |= PH8; break; - case 5: SET_MUX(h, 2, 1); h_fer |= PH9; break; - case 6: SET_MUX(f, 1, 3); f_fer |= PF9; break; - case 7: SET_MUX(f, 2, 3); f_fer |= PF10; break; - } - bfin_write_PORTF_MUX(f_mux); - bfin_write_PORTF_FER(f_fer); - bfin_write_PORTG_MUX(g_mux); - bfin_write_PORTG_FER(g_fer); - bfin_write_PORTH_MUX(h_mux); - bfin_write_PORTH_FER(h_fer); -#elif defined(__ADSPBF534__) || defined(__ADSPBF536__) || defined(__ADSPBF537__) - u16 mux = bfin_read_PORT_MUX(); - u16 f_fer = bfin_read_PORTF_FER(); - /* set SCK/MISO/MOSI */ - f_fer |= PF11 | PF12 | PF13; - switch (slave->cs) { - case 1: f_fer |= PF10; break; - case 2: mux |= PJSE; break; - case 3: mux |= PJSE; break; - case 4: mux |= PFS4E; f_fer |= PF6; break; - case 5: mux |= PFS5E; f_fer |= PF5; break; - case 6: mux |= PFS6E; f_fer |= PF4; break; - case 7: mux |= PJCE_SPI; break; - } - bfin_write_PORT_MUX(mux); - bfin_write_PORTF_FER(f_fer); -#elif defined(__ADSPBF538__) || defined(__ADSPBF539__) - u16 fer, pins; - if (slave->bus == 1) - pins = PD0 | PD1 | PD2 | (slave->cs == 1 ? PD4 : 0); - else if (slave->bus == 2) - pins = PD5 | PD6 | PD7 | (slave->cs == 1 ? PD9 : 0); - else - pins = 0; - if (pins) { - fer = bfin_read_PORTDIO_FER(); - fer &= ~pins; - bfin_write_PORTDIO_FER(fer); - } -#elif defined(__ADSPBF54x__) -#define DO_MUX(port, pin) \ - mux = ((mux & ~PORT_x_MUX_##pin##_MASK) | PORT_x_MUX_##pin##_FUNC_1); \ - fer |= P##port##pin; - u32 mux; - u16 fer; - switch (slave->bus) { - case 0: - mux = bfin_read_PORTE_MUX(); - fer = bfin_read_PORTE_FER(); - /* set SCK/MISO/MOSI */ - DO_MUX(E, 0); - DO_MUX(E, 1); - DO_MUX(E, 2); - switch (slave->cs) { - case 1: DO_MUX(E, 4); break; - case 2: DO_MUX(E, 5); break; - case 3: DO_MUX(E, 6); break; - } - bfin_write_PORTE_MUX(mux); - bfin_write_PORTE_FER(fer); - break; - case 1: - mux = bfin_read_PORTG_MUX(); - fer = bfin_read_PORTG_FER(); - /* set SCK/MISO/MOSI */ - DO_MUX(G, 8); - DO_MUX(G, 9); - DO_MUX(G, 10); - switch (slave->cs) { - case 1: DO_MUX(G, 5); break; - case 2: DO_MUX(G, 6); break; - case 3: DO_MUX(G, 7); break; - } - bfin_write_PORTG_MUX(mux); - bfin_write_PORTG_FER(fer); - break; - case 2: - mux = bfin_read_PORTB_MUX(); - fer = bfin_read_PORTB_FER(); - /* set SCK/MISO/MOSI */ - DO_MUX(B, 12); - DO_MUX(B, 13); - DO_MUX(B, 14); - switch (slave->cs) { - case 1: DO_MUX(B, 9); break; - case 2: DO_MUX(B, 10); break; - case 3: DO_MUX(B, 11); break; - } - bfin_write_PORTB_MUX(mux); - bfin_write_PORTB_FER(fer); - break; - } -#endif -} - int spi_claim_bus(struct spi_slave *slave) { struct bfin_spi_slave *bss = to_bfin_spi_slave(slave);
debug("%s: bus:%i cs:%i\n", __func__, slave->bus, slave->cs);
- spi_portmux(slave); + pins[slave->bus][0] = cs_pins[slave->bus][slave->cs - 1]; + peripheral_request_list(pins[slave->bus], "bfin-spi"); + write_SPI_CTL(bss, bss->ctl); write_SPI_BAUD(bss, bss->baud); SSYNC(); @@ -314,7 +201,11 @@ int spi_claim_bus(struct spi_slave *slave) void spi_release_bus(struct spi_slave *slave) { struct bfin_spi_slave *bss = to_bfin_spi_slave(slave); + debug("%s: bus:%i cs:%i\n", __func__, slave->bus, slave->cs); + + peripheral_free_list(pins[slave->bus]); + write_SPI_CTL(bss, 0); SSYNC(); }
Rather than only support the pins dedicated as chip selects, utilize the gpio framework to support any gpio pin.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- drivers/spi/bfin_spi.c | 85 +++++++++++++++++++++++++------------ include/configs/bfin_adi_common.h | 1 + 2 files changed, 58 insertions(+), 28 deletions(-)
diff --git a/drivers/spi/bfin_spi.c b/drivers/spi/bfin_spi.c index 4e008a7..e0ad029 100644 --- a/drivers/spi/bfin_spi.c +++ b/drivers/spi/bfin_spi.c @@ -13,6 +13,7 @@ #include <spi.h>
#include <asm/blackfin.h> +#include <asm/gpio.h> #include <asm/portmux.h> #include <asm/mach-common/bits/spi.h>
@@ -34,48 +35,68 @@ MAKE_SPI_FUNC(SPI_BAUD, 0x14)
#define to_bfin_spi_slave(s) container_of(s, struct bfin_spi_slave, slave)
-__attribute__((weak)) +#define MAX_CTRL_CS 7 + +#define gpio_cs(cs) ((cs) - MAX_CTRL_CS) +#ifdef CONFIG_BFIN_SPI_GPIO_CS +# define is_gpio_cs(cs) ((cs) > MAX_CTRL_CS) +#else +# define is_gpio_cs(cs) 0 +#endif + int spi_cs_is_valid(unsigned int bus, unsigned int cs) { -#if defined(__ADSPBF538__) || defined(__ADSPBF539__) - /* The SPI1/SPI2 buses are weird ... only 1 CS */ - if (bus > 0 && cs != 1) - return 0; -#endif - return (cs >= 1 && cs <= 7); + if (is_gpio_cs(cs)) + return gpio_is_valid(gpio_cs(cs)); + else + return (cs >= 1 && cs <= MAX_CTRL_CS); }
-__attribute__((weak)) void spi_cs_activate(struct spi_slave *slave) { struct bfin_spi_slave *bss = to_bfin_spi_slave(slave); - write_SPI_FLG(bss, - (read_SPI_FLG(bss) & - ~((!bss->flg << 8) << slave->cs)) | - (1 << slave->cs)); + + if (is_gpio_cs(slave->cs)) { + unsigned int cs = gpio_cs(slave->cs); + gpio_set_value(cs, bss->flg); + debug("%s: SPI_CS_GPIO:%x\n", __func__, gpio_get_value(cs)); + } else { + write_SPI_FLG(bss, + (read_SPI_FLG(bss) & + ~((!bss->flg << 8) << slave->cs)) | + (1 << slave->cs)); + debug("%s: SPI_FLG:%x\n", __func__, read_SPI_FLG(bss)); + } + SSYNC(); - debug("%s: SPI_FLG:%x\n", __func__, read_SPI_FLG(bss)); }
-__attribute__((weak)) void spi_cs_deactivate(struct spi_slave *slave) { struct bfin_spi_slave *bss = to_bfin_spi_slave(slave); - u16 flg; - - /* make sure we force the cs to deassert rather than let the - * pin float back up. otherwise, exact timings may not be - * met some of the time leading to random behavior (ugh). - */ - flg = read_SPI_FLG(bss) | ((!bss->flg << 8) << slave->cs); - write_SPI_FLG(bss, flg); - SSYNC(); - debug("%s: SPI_FLG:%x\n", __func__, read_SPI_FLG(bss));
- flg &= ~(1 << slave->cs); - write_SPI_FLG(bss, flg); + if (is_gpio_cs(slave->cs)) { + unsigned int cs = gpio_cs(slave->cs); + gpio_set_value(cs, !bss->flg); + debug("%s: SPI_CS_GPIO:%x\n", __func__, gpio_get_value(cs)); + } else { + u16 flg; + + /* make sure we force the cs to deassert rather than let the + * pin float back up. otherwise, exact timings may not be + * met some of the time leading to random behavior (ugh). + */ + flg = read_SPI_FLG(bss) | ((!bss->flg << 8) << slave->cs); + write_SPI_FLG(bss, flg); + SSYNC(); + debug("%s: SPI_FLG:%x\n", __func__, read_SPI_FLG(bss)); + + flg &= ~(1 << slave->cs); + write_SPI_FLG(bss, flg); + debug("%s: SPI_FLG:%x\n", __func__, read_SPI_FLG(bss)); + } + SSYNC(); - debug("%s: SPI_FLG:%x\n", __func__, read_SPI_FLG(bss)); }
void spi_init() @@ -188,7 +209,13 @@ int spi_claim_bus(struct spi_slave *slave)
- pins[slave->bus][0] = cs_pins[slave->bus][slave->cs - 1]; + if (is_gpio_cs(slave->cs)) { + unsigned int cs = gpio_cs(slave->cs); + gpio_request(cs, "bfin-spi"); + gpio_direction_output(cs, !bss->flg); + pins[slave->bus][0] = P_DONTCARE; + } else + pins[slave->bus][0] = cs_pins[slave->bus][slave->cs - 1]; peripheral_request_list(pins[slave->bus], "bfin-spi");
write_SPI_CTL(bss, bss->ctl); @@ -205,6 +232,8 @@ void spi_release_bus(struct spi_slave *slave) debug("%s: bus:%i cs:%i\n", __func__, slave->bus, slave->cs);
peripheral_free_list(pins[slave->bus]); + if (is_gpio_cs(slave->cs)) + gpio_free(gpio_cs(slave->cs));
write_SPI_CTL(bss, 0); SSYNC(); diff --git a/include/configs/bfin_adi_common.h b/include/configs/bfin_adi_common.h index fa1e694..82daeb1 100644 --- a/include/configs/bfin_adi_common.h +++ b/include/configs/bfin_adi_common.h @@ -254,6 +254,7 @@ /* * Misc Settings */ +#define CONFIG_BFIN_SPI_GPIO_CS /* Only matters if BFIN_SPI is enabled */ #define CONFIG_LZMA
#endif
Signed-off-by: Mike Frysinger vapier@gentoo.org --- board/bf533-stamp/bf533-stamp.c | 47 ++++++++++++++++---------------------- 1 files changed, 20 insertions(+), 27 deletions(-)
diff --git a/board/bf533-stamp/bf533-stamp.c b/board/bf533-stamp/bf533-stamp.c index fd10eae..935aad2 100644 --- a/board/bf533-stamp/bf533-stamp.c +++ b/board/bf533-stamp/bf533-stamp.c @@ -27,8 +27,7 @@
#include <common.h> #include <netdev.h> -#include <asm/io.h> -#include "bf533-stamp.h" +#include <asm/gpio.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -46,15 +45,10 @@ int checkboard(void) */ void swap_to(int device_id) { - bfin_write_FIO_DIR(bfin_read_FIO_DIR() | PF1 | PF0); - SSYNC(); - bfin_write_FIO_FLAG_C(PF1); - if (device_id == ETHERNET) - bfin_write_FIO_FLAG_S(PF0); - else if (device_id == FLASH) - bfin_write_FIO_FLAG_C(PF0); - else - printf("Unknown device to switch\n"); + gpio_request(GPIO_PF0, "eth_flash_swap"); + gpio_request(GPIO_PF1, "eth_flash_swap"); + gpio_direction_output(GPIO_PF0, device_id == ETHERNET); + gpio_direction_output(GPIO_PF1, 0); SSYNC(); }
@@ -75,24 +69,23 @@ int misc_init_r(void) #define STATUS_LED_OFF 0 #define STATUS_LED_ON 1
+static int gpio_setup; + static void stamp_led_set(int LED1, int LED2, int LED3) { - bfin_write_FIO_INEN(bfin_read_FIO_INEN() & ~(PF2 | PF3 | PF4)); - bfin_write_FIO_DIR(bfin_read_FIO_DIR() | (PF2 | PF3 | PF4)); - - if (LED1 == STATUS_LED_OFF) - *pFIO_FLAG_S = PF2; - else - *pFIO_FLAG_C = PF2; - if (LED2 == STATUS_LED_OFF) - *pFIO_FLAG_S = PF3; - else - *pFIO_FLAG_C = PF3; - if (LED3 == STATUS_LED_OFF) - *pFIO_FLAG_S = PF4; - else - *pFIO_FLAG_C = PF4; - SSYNC(); + if (!gpio_setup) { + gpio_request(GPIO_PF2, "boot_progress"); + gpio_request(GPIO_PF3, "boot_progress"); + gpio_request(GPIO_PF4, "boot_progress"); + gpio_direction_output(GPIO_PF2, LED1); + gpio_direction_output(GPIO_PF3, LED2); + gpio_direction_output(GPIO_PF4, LED3); + gpio_setup = 1; + } else { + gpio_set_value(GPIO_PF2, LED1); + gpio_set_value(GPIO_PF3, LED2); + gpio_set_value(GPIO_PF4, LED3); + } }
Signed-off-by: Mike Frysinger vapier@gentoo.org --- board/blackstamp/blackstamp.c | 12 +++--------- 1 files changed, 3 insertions(+), 9 deletions(-)
diff --git a/board/blackstamp/blackstamp.c b/board/blackstamp/blackstamp.c index 6355c10..06d004a 100644 --- a/board/blackstamp/blackstamp.c +++ b/board/blackstamp/blackstamp.c @@ -13,7 +13,7 @@
#include <common.h> #include <netdev.h> -#include <asm/io.h> +#include <asm/gpio.h>
@@ -27,14 +27,8 @@ int checkboard(void) #ifdef SHARED_RESOURCES void swap_to(int device_id) { - bfin_write_FIO_DIR(bfin_read_FIO_DIR() | PF0); - SSYNC(); - if (device_id == ETHERNET) - bfin_write_FIO_FLAG_S(PF0); - else if (device_id == FLASH) - bfin_write_FIO_FLAG_C(PF0); - else - printf("Unknown device to switch\n"); + gpio_request(GPIO_PF0, "eth_flash_swap"); + gpio_direction_output(GPIO_PF0, device_id == ETHERNET); SSYNC(); } #endif
Much of the local bf533-stamp.h header is unused, and the few bits that are are only needed in one file. So move the few used bits out and punt all the rest.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- board/bf533-stamp/bf533-stamp.h | 53 --------------------------------------- board/bf533-stamp/ide-cf.c | 10 ++++++- 2 files changed, 9 insertions(+), 54 deletions(-) delete mode 100644 board/bf533-stamp/bf533-stamp.h
diff --git a/board/bf533-stamp/bf533-stamp.h b/board/bf533-stamp/bf533-stamp.h deleted file mode 100644 index ebd39c7..0000000 --- a/board/bf533-stamp/bf533-stamp.h +++ /dev/null @@ -1,53 +0,0 @@ -/* - * U-boot - stamp.h - * - * Copyright (c) 2005-2007 Analog Devices Inc. - * - * (C) Copyright 2000-2004 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, - * MA 02110-1301 USA - */ - -#ifndef __STAMP_H__ -#define __STAMP_H__ - -extern void init_Flags(void); - -extern volatile unsigned long *ambctl0; -extern volatile unsigned long *ambctl1; -extern volatile unsigned long *amgctl; - -/* Definitions used in Compact Flash Boot support */ -#define FIO_EDGE_CF_BITS 0x0000 -#define FIO_POLAR_CF_BITS 0x0000 -#define FIO_EDGE_BITS 0x1E0 -#define FIO_POLAR_BITS 0x160 - -/* Compact flash status bits in status register */ -#define CF_STAT_BITS 0x00000060 - -/* CF Flags used to switch between expansion and external - * memory banks - */ -#define CF_PF0 0x0001 -#define CF_PF1 0x0002 -#define CF_PF1_PF0 0x0003 - -#endif diff --git a/board/bf533-stamp/ide-cf.c b/board/bf533-stamp/ide-cf.c index 23e786b..3e4080e 100644 --- a/board/bf533-stamp/ide-cf.c +++ b/board/bf533-stamp/ide-cf.c @@ -11,7 +11,6 @@ #include <common.h> #include <config.h> #include <asm/blackfin.h> -#include "bf533-stamp.h"
void cf_outb(unsigned char val, volatile unsigned char *addr) { @@ -66,6 +65,15 @@ void cf_outsw(unsigned short *addr, unsigned short *sect_buf, int words) swap_to(FLASH); }
+/* Definitions used in Compact Flash Boot support */ +#define FIO_EDGE_CF_BITS 0x0000 +#define FIO_POLAR_CF_BITS 0x0000 +#define FIO_EDGE_BITS 0x1E0 +#define FIO_POLAR_BITS 0x160 + +/* Compact flash status bits in status register */ +#define CF_STAT_BITS 0x00000060 + void cf_ide_init(void) { int i, cf_stat;
The original BF518F-EZBRD's have a Micrel KSZ8893 DSA on them, but newer ones only have a National PHY (which lack a RX Error interrupt line). So in the board eth init code, dynamically detect what is hooked up to the MAC and handle each accordingly.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- board/bf518f-ezbrd/bf518f-ezbrd.c | 23 +++++++++++++---------- include/configs/bf518f-ezbrd.h | 20 ++++++++++++++++++++ 2 files changed, 33 insertions(+), 10 deletions(-)
diff --git a/board/bf518f-ezbrd/bf518f-ezbrd.c b/board/bf518f-ezbrd/bf518f-ezbrd.c index 85b350f..c2ab598 100644 --- a/board/bf518f-ezbrd/bf518f-ezbrd.c +++ b/board/bf518f-ezbrd/bf518f-ezbrd.c @@ -61,6 +61,7 @@ static void board_init_enetaddr(uchar *mac_addr) #define KSZ_WRITE 0x02 #define KSZ_READ 0x03
+#define KSZ_REG_CHID 0x00 /* Register 0: Chip ID0 */ #define KSZ_REG_STPID 0x01 /* Register 1: Chip ID1 / Start Switch */ #define KSZ_REG_GC9 0x0b /* Register 11: Global Control 9 */ #define KSZ_REG_P3C0 0x30 /* Register 48: Port 3 Control 0 */ @@ -78,15 +79,17 @@ static int ksz8893m_reg_set(struct spi_slave *slave, uchar reg, uchar data) return ksz8893m_transfer(slave, KSZ_WRITE, reg, data, din); }
-static int ksz8893m_reg_clear(struct spi_slave *slave, uchar reg, uchar mask) +static int ksz8893m_reg_read(struct spi_slave *slave, uchar reg) { - int ret = 0; + int ret; unsigned char din[3]; + ret = ksz8893m_transfer(slave, KSZ_READ, reg, 0, din); + return ret ? ret : din[2]; +}
- ret |= ksz8893m_transfer(slave, KSZ_READ, reg, 0, din); - ret |= ksz8893m_reg_set(slave, reg, din[2] & mask); - - return ret; +static int ksz8893m_reg_clear(struct spi_slave *slave, uchar reg, uchar mask) +{ + return ksz8893m_reg_set(slave, reg, ksz8893m_reg_read(slave, reg) & mask); }
static int ksz8893m_reset(struct spi_slave *slave) @@ -107,16 +110,16 @@ static int ksz8893m_reset(struct spi_slave *slave)
int board_eth_init(bd_t *bis) { - static bool switch_is_alive = false; + static bool switch_is_alive = false, phy_is_ksz = true; int ret;
if (!switch_is_alive) { struct spi_slave *slave = spi_setup_slave(0, 1, KSZ_MAX_HZ, SPI_MODE_3); if (slave) { if (!spi_claim_bus(slave)) { - ret = ksz8893m_reset(slave); - if (!ret) - switch_is_alive = true; + phy_is_ksz = (ksz8893m_reg_read(slave, KSZ_REG_CHID) == 0x88); + ret = phy_is_ksz ? ksz8893m_reset(slave) : 0; + switch_is_alive = (ret == 0); spi_release_bus(slave); } spi_free_slave(slave); diff --git a/include/configs/bf518f-ezbrd.h b/include/configs/bf518f-ezbrd.h index 1e821d9..7d20b66 100644 --- a/include/configs/bf518f-ezbrd.h +++ b/include/configs/bf518f-ezbrd.h @@ -63,6 +63,26 @@ #if !defined(__ADSPBF512__) && !defined(__ADSPBF514__) #define ADI_CMDS_NETWORK 1 #define CONFIG_BFIN_MAC +#define CONFIG_BFIN_MAC_PINS \ + { \ + P_MII0_ETxD0, \ + P_MII0_ETxD1, \ + P_MII0_ETxD2, \ + P_MII0_ETxD3, \ + P_MII0_ETxEN, \ + P_MII0_TxCLK, \ + P_MII0_PHYINT, \ + P_MII0_COL, \ + P_MII0_ERxD0, \ + P_MII0_ERxD1, \ + P_MII0_ERxD2, \ + P_MII0_ERxD3, \ + P_MII0_ERxDV, \ + P_MII0_ERxCLK, \ + P_MII0_CRS, \ + P_MII0_MDC, \ + P_MII0_MDIO, \ + 0 } #define CONFIG_NETCONSOLE 1 #define CONFIG_NET_MULTI 1 #endif
Hi Mike,
thanks, Ben
On 7/11/2010 11:53 PM, Ben Warren wrote:
Hi Mike,
thanks, Ben
On second thought, it probably makes more sense to keep this as part of your patchset. I shouldn't have pulled it in the first place since it's really board code.
regards, Ben
Signed-off-by: Mike Frysinger vapier@gentoo.org --- board/bf518f-ezbrd/bf518f-ezbrd.c | 18 ++++++------------ 1 files changed, 6 insertions(+), 12 deletions(-)
diff --git a/board/bf518f-ezbrd/bf518f-ezbrd.c b/board/bf518f-ezbrd/bf518f-ezbrd.c index c2ab598..ff1ac4c 100644 --- a/board/bf518f-ezbrd/bf518f-ezbrd.c +++ b/board/bf518f-ezbrd/bf518f-ezbrd.c @@ -14,6 +14,7 @@ #include <spi.h> #include <asm/blackfin.h> #include <asm/net.h> +#include <asm/portmux.h> #include <asm/mach-common/bits/otp.h> #include <asm/sdh.h>
@@ -146,18 +147,11 @@ int misc_init_r(void)
int board_early_init_f(void) { -#if !defined(CONFIG_SYS_NO_FLASH) - /* setup BF518-EZBRD GPIO pin PG11 to AMS2. */ - bfin_write_PORTG_MUX((bfin_read_PORTG_MUX() & ~PORT_x_MUX_6_MASK) | PORT_x_MUX_6_FUNC_2); - bfin_write_PORTG_FER(bfin_read_PORTG_FER() | PG11); - -# if !defined(CONFIG_BFIN_SPI) - /* setup BF518-EZBRD GPIO pin PG15 to AMS3. */ - bfin_write_PORTG_MUX((bfin_read_PORTG_MUX() & ~PORT_x_MUX_7_MASK) | PORT_x_MUX_7_FUNC_3); - bfin_write_PORTG_FER(bfin_read_PORTG_FER() | PG15); -# endif -#endif - return 0; + /* connect async banks by default */ + const unsigned short pins[] = { + P_AMS2, P_AMS3, 0, + }; + return peripheral_request_list(pins, "async"); }
#ifdef CONFIG_BFIN_SDH
Signed-off-by: Mike Frysinger vapier@gentoo.org --- board/bf548-ezkit/bf548-ezkit.c | 64 +++++++------------------------------- board/bf548-ezkit/video.c | 27 ++++++++-------- 2 files changed, 26 insertions(+), 65 deletions(-)
diff --git a/board/bf548-ezkit/bf548-ezkit.c b/board/bf548-ezkit/bf548-ezkit.c index 65fb81a..cb9ee86 100644 --- a/board/bf548-ezkit/bf548-ezkit.c +++ b/board/bf548-ezkit/bf548-ezkit.c @@ -7,10 +7,12 @@ */
#include <common.h> -#include <netdev.h> #include <config.h> #include <command.h> +#include <netdev.h> #include <asm/blackfin.h> +#include <asm/gpio.h> +#include <asm/portmux.h> #include <asm/sdh.h>
DECLARE_GLOBAL_DATA_PTR; @@ -24,53 +26,13 @@ int checkboard(void)
int board_early_init_f(void) { - /* Port H: PH8 - PH13 == A4 - A9 - * address lines of the parallel asynchronous memory interface - */ - - /************************************************ - * configure GPIO * - * set port H function enable register * - * configure PH8-PH13 as peripheral (not GPIO) * - *************************************************/ - bfin_write_PORTH_FER(0x3F03); - - /************************************************ - * set port H MUX to configure PH8-PH13 * - * 1st Function (MUX = 00) (bits 16-27 == 0) * - * Set to address signals A4-A9 * - *************************************************/ - bfin_write_PORTH_MUX(0); - - /************************************************ - * set port H direction register * - * enable PH8-PH13 as outputs * - *************************************************/ - bfin_write_PORTH_DIR_SET(0x3F00); - - /* Port I: PI0 - PH14 == A10 - A24 - * address lines of the parallel asynchronous memory interface - */ - - /************************************************ - * set port I function enable register * - * configure PI0-PI14 as peripheral (not GPIO) * - *************************************************/ - bfin_write_PORTI_FER(0x7fff); - - /************************************************** - * set PORT I MUX to configure PI14-PI0 as * - * 1st Function (MUX=00) - address signals A10-A24 * - ***************************************************/ - bfin_write_PORTI_MUX(0); - - /**************************************** - * set PORT I direction register * - * enable PI0 - PI14 as outputs * - *****************************************/ - bfin_write_PORTI_DIR_SET(0x7fff); - - return 0; + /* Set async addr lines as peripheral */ + const unsigned short pins[] = { + P_A4, P_A5, P_A6, P_A7, P_A8, P_A9, P_A10, P_A11, P_A12, + P_A13, P_A14, P_A15, P_A16, P_A17, P_A18, P_A19, P_A20, + P_A21, P_A22, P_A23, P_A24, 0 + }; + return peripheral_request_list(pins, "async"); }
#ifdef CONFIG_SMC911X @@ -96,9 +58,7 @@ void board_musb_init(void) * be low for device mode and high for host mode. We set it high * here because we are in host mode. */ - bfin_write_PORTE_FER(bfin_read_PORTE_FER() & ~PE7); - bfin_write_PORTE_DIR_SET(PE7); - bfin_write_PORTE_SET(PE7); - SSYNC(); + gpio_request(GPIO_PE7, "musb-vbus"); + gpio_direction_output(GPIO_PE7, 1); } #endif diff --git a/board/bf548-ezkit/video.c b/board/bf548-ezkit/video.c index 10b08e2..af3d58b 100644 --- a/board/bf548-ezkit/video.c +++ b/board/bf548-ezkit/video.c @@ -11,6 +11,8 @@ #include <config.h> #include <malloc.h> #include <asm/blackfin.h> +#include <asm/gpio.h> +#include <asm/portmux.h> #include <asm/mach-common/bits/dma.h> #include <i2c.h> #include <linux/types.h> @@ -173,22 +175,21 @@ void Init_DMA(void *dst)
void Init_Ports(void) { - *pPORTF_MUX = 0x00000000; - *pPORTF_FER |= 0xFFFF; /* PPI0..15 */ - - *pPORTG_MUX &= ~(PORT_x_MUX_0_MASK | PORT_x_MUX_1_MASK | PORT_x_MUX_2_MASK | PORT_x_MUX_3_MASK | PORT_x_MUX_4_MASK); - *pPORTG_FER |= PG0 | PG1 | PG2 | PG3 | PG4; /* CLK, FS1, FS2, PPI16..17 */ - + const unsigned short pins[] = { + P_PPI0_D0, P_PPI0_D1, P_PPI0_D2, P_PPI0_D3, P_PPI0_D4, + P_PPI0_D5, P_PPI0_D6, P_PPI0_D7, P_PPI0_D8, P_PPI0_D9, + P_PPI0_D10, P_PPI0_D11, P_PPI0_D12, P_PPI0_D13, P_PPI0_D14, + P_PPI0_D15, P_PPI0_D16, P_PPI0_D17, #if !defined(CONFIG_VIDEO_RGB666) - *pPORTD_MUX &= ~(PORT_x_MUX_0_MASK | PORT_x_MUX_1_MASK | PORT_x_MUX_2_MASK | PORT_x_MUX_3_MASK | PORT_x_MUX_4_MASK | PORT_x_MUX_5_MASK); - *pPORTD_MUX |= (PORT_x_MUX_0_FUNC_4 | PORT_x_MUX_1_FUNC_4 | PORT_x_MUX_2_FUNC_4 | PORT_x_MUX_3_FUNC_4 | PORT_x_MUX_4_FUNC_4 | PORT_x_MUX_5_FUNC_4); - *pPORTD_FER |= PD0 | PD1 | PD2 | PD3 | PD4 | PD5; /* PPI18..23 */ + P_PPI0_D18, P_PPI0_D19, P_PPI0_D20, P_PPI0_D21, P_PPI0_D22, + P_PPI0_D23, #endif + P_PPI0_CLK, P_PPI0_FS1, P_PPI0_FS2, 0, + }; + peripheral_request_list(pins, "lcd");
- *pPORTE_FER &= ~PE3; /* DISP */ - *pPORTE_DIR_SET = PE3; - *pPORTE_SET = PE3; - + gpio_request(GPIO_PE3, "lcd-disp"); + gpio_direction_output(GPIO_PE3, 1); }
void EnableDMA(void)
Signed-off-by: Mike Frysinger vapier@gentoo.org --- board/bf527-ezkit/bf527-ezkit.c | 7 +++---- board/bf527-ezkit/video.c | 13 ++++++------- 2 files changed, 9 insertions(+), 11 deletions(-)
diff --git a/board/bf527-ezkit/bf527-ezkit.c b/board/bf527-ezkit/bf527-ezkit.c index a911880..211cf24 100644 --- a/board/bf527-ezkit/bf527-ezkit.c +++ b/board/bf527-ezkit/bf527-ezkit.c @@ -12,6 +12,7 @@ #include <net.h> #include <netdev.h> #include <asm/blackfin.h> +#include <asm/gpio.h> #include <asm/net.h> #include <asm/mach-common/bits/otp.h>
@@ -75,9 +76,7 @@ void board_musb_init(void) /* * BF527 EZ-KITs require PG13 to be high for HOST mode */ - bfin_write_PORTG_FER(bfin_read_PORTG_FER() & ~PG13); - bfin_write_PORTGIO_DIR(bfin_read_PORTGIO_DIR() | PG13); - bfin_write_PORTGIO_SET(PG13); - SSYNC(); + gpio_request(GPIO_PG13, "musb-vbus"); + gpio_direction_output(GPIO_PG13, 1); } #endif diff --git a/board/bf527-ezkit/video.c b/board/bf527-ezkit/video.c index 8f6ea23..891070b 100644 --- a/board/bf527-ezkit/video.c +++ b/board/bf527-ezkit/video.c @@ -11,6 +11,7 @@ #include <config.h> #include <malloc.h> #include <asm/blackfin.h> +#include <asm/portmux.h> #include <asm/mach-common/bits/dma.h> #include <spi.h> #include <linux/types.h> @@ -171,13 +172,11 @@ void DisablePPI(void)
void Init_Ports(void) { - *pPORTF_MUX &= ~PORT_x_MUX_0_MASK; - *pPORTF_MUX |= PORT_x_MUX_0_FUNC_1; - *pPORTF_FER |= PF0 | PF1 | PF2 | PF3 | PF4 | PF5 | PF6 | PF7; - - *pPORTG_MUX &= ~PORT_x_MUX_1_MASK; - *pPORTG_MUX |= PORT_x_MUX_1_FUNC_1; - *pPORTG_FER |= PG5; + const unsigned short pins[] = { + P_PPI0_D0, P_PPI0_D1, P_PPI0_D2, P_PPI0_D3, P_PPI0_D4, + P_PPI0_D5, P_PPI0_D6, P_PPI0_D7, P_PPI0_FS2, 0, + }; + peripheral_request_list(pins, "lcd"); }
void Init_PPI(void)
Signed-off-by: Mike Frysinger vapier@gentoo.org --- board/cm-bf548/cm-bf548.c | 55 ++++++-------------------------------------- board/cm-bf548/video.c | 33 +++++++++++--------------- 2 files changed, 22 insertions(+), 66 deletions(-)
diff --git a/board/cm-bf548/cm-bf548.c b/board/cm-bf548/cm-bf548.c index 3627586..90ce4c3 100644 --- a/board/cm-bf548/cm-bf548.c +++ b/board/cm-bf548/cm-bf548.c @@ -11,6 +11,7 @@ #include <command.h> #include <netdev.h> #include <asm/blackfin.h> +#include <asm/portmux.h>
@@ -23,53 +24,13 @@ int checkboard(void)
int board_eth_init(bd_t *bis) diff --git a/board/cm-bf548/video.c b/board/cm-bf548/video.c index 4097f09..d43f5a1 100644 --- a/board/cm-bf548/video.c +++ b/board/cm-bf548/video.c @@ -11,6 +11,8 @@ #include <config.h> #include <malloc.h> #include <asm/blackfin.h> +#include <asm/gpio.h> +#include <asm/portmux.h> #include <asm/mach-common/bits/dma.h> #include <i2c.h> #include <linux/types.h> @@ -174,28 +176,21 @@ void Init_DMA(void *dst)
void Init_Ports(void) { - *pPORTF_MUX = 0x00000000; - *pPORTF_FER |= 0xFFFF; /* PPI0..15 */ - - *pPORTG_MUX &= - ~(PORT_x_MUX_0_MASK | PORT_x_MUX_1_MASK | PORT_x_MUX_2_MASK | - PORT_x_MUX_3_MASK | PORT_x_MUX_4_MASK); - *pPORTG_FER |= PG0 | PG1 | PG2 | PG3 | PG4; /* CLK, FS1, FS2, PPI16..17 */ - + const unsigned short pins[] = { + P_PPI0_D0, P_PPI0_D1, P_PPI0_D2, P_PPI0_D3, P_PPI0_D4, + P_PPI0_D5, P_PPI0_D6, P_PPI0_D7, P_PPI0_D8, P_PPI0_D9, + P_PPI0_D10, P_PPI0_D11, P_PPI0_D12, P_PPI0_D13, P_PPI0_D14, + P_PPI0_D15, P_PPI0_D16, P_PPI0_D17, #if !defined(CONFIG_VIDEO_RGB666) - *pPORTD_MUX &= - ~(PORT_x_MUX_0_MASK | PORT_x_MUX_1_MASK | PORT_x_MUX_2_MASK | - PORT_x_MUX_3_MASK | PORT_x_MUX_4_MASK | PORT_x_MUX_5_MASK); - *pPORTD_MUX |= - (PORT_x_MUX_0_FUNC_4 | PORT_x_MUX_1_FUNC_4 | PORT_x_MUX_2_FUNC_4 | - PORT_x_MUX_3_FUNC_4 | PORT_x_MUX_4_FUNC_4 | PORT_x_MUX_5_FUNC_4); - *pPORTD_FER |= PD0 | PD1 | PD2 | PD3 | PD4 | PD5; /* PPI18..23 */ + P_PPI0_D18, P_PPI0_D19, P_PPI0_D20, P_PPI0_D21, P_PPI0_D22, + P_PPI0_D23, #endif + P_PPI0_CLK, P_PPI0_FS1, P_PPI0_FS2, 0, + }; + peripheral_request_list(pins, "lcd");
The L1 regions of Core B are not directly accessible from Core A, so we need to use DMA to get at them.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- arch/blackfin/include/asm/blackfin_local.h | 10 +++++++++- 1 files changed, 9 insertions(+), 1 deletions(-)
diff --git a/arch/blackfin/include/asm/blackfin_local.h b/arch/blackfin/include/asm/blackfin_local.h index 3fd34b3..48f793a 100644 --- a/arch/blackfin/include/asm/blackfin_local.h +++ b/arch/blackfin/include/asm/blackfin_local.h @@ -75,7 +75,15 @@ extern void blackfin_dcache_flush_invalidate_range(const void *, const void *); * regions can only be accessed via DMA, so if the address in question is in * that region, make sure we attempt to DMA indirectly. */ -# define addr_bfin_on_chip_mem(addr) (((unsigned long)(addr) & 0xFFF00000) == 0xFFA00000) +# ifdef __ADSPBF561__ + /* Core B regions all need dma from Core A */ +# define addr_bfin_on_chip_mem(addr) \ + ((((unsigned long)(addr) & 0xFFF00000) == 0xFFA00000) || \ + (((unsigned long)(addr) & 0xFFC00000) == 0xFF400000)) +# else +# define addr_bfin_on_chip_mem(addr) \ + (((unsigned long)(addr) & 0xFFF00000) == 0xFFA00000) +# endif
# include <asm/system.h>
Signed-off-by: Mike Frysinger vapier@gentoo.org --- include/configs/bf518f-ezbrd.h | 2 -- include/configs/bf526-ezbrd.h | 2 -- include/configs/bf527-ezkit.h | 2 -- include/configs/bf533-ezkit.h | 2 -- include/configs/bf533-stamp.h | 2 -- include/configs/bf537-pnav.h | 2 -- include/configs/bf537-stamp.h | 2 -- include/configs/bf538f-ezkit.h | 2 -- include/configs/bf548-ezkit.h | 2 -- include/configs/bf561-ezkit.h | 2 -- include/configs/bfin_adi_common.h | 12 ++++++++++++ include/configs/cm-bf527.h | 2 -- include/configs/cm-bf537e.h | 2 -- include/configs/cm-bf537u.h | 2 -- include/configs/cm-bf548.h | 2 -- include/configs/ibf-dsp561.h | 2 -- include/configs/tcm-bf518.h | 2 -- include/configs/tcm-bf537.h | 2 -- 18 files changed, 12 insertions(+), 34 deletions(-)
diff --git a/include/configs/bf518f-ezbrd.h b/include/configs/bf518f-ezbrd.h index 7d20b66..6eec1c9 100644 --- a/include/configs/bf518f-ezbrd.h +++ b/include/configs/bf518f-ezbrd.h @@ -137,8 +137,6 @@ */ #define CONFIG_BFIN_TWI_I2C 1 #define CONFIG_HARD_I2C 1 -#define CONFIG_SYS_I2C_SPEED 50000 -#define CONFIG_SYS_I2C_SLAVE 0
/* diff --git a/include/configs/bf526-ezbrd.h b/include/configs/bf526-ezbrd.h index ecda216..82396d0 100644 --- a/include/configs/bf526-ezbrd.h +++ b/include/configs/bf526-ezbrd.h @@ -134,8 +134,6 @@ */ #define CONFIG_BFIN_TWI_I2C 1 #define CONFIG_HARD_I2C 1 -#define CONFIG_SYS_I2C_SPEED 50000 -#define CONFIG_SYS_I2C_SLAVE 0
/* diff --git a/include/configs/bf527-ezkit.h b/include/configs/bf527-ezkit.h index 7800c32..07e4ce8 100644 --- a/include/configs/bf527-ezkit.h +++ b/include/configs/bf527-ezkit.h @@ -138,8 +138,6 @@ */ #define CONFIG_BFIN_TWI_I2C 1 #define CONFIG_HARD_I2C 1 -#define CONFIG_SYS_I2C_SPEED 50000 -#define CONFIG_SYS_I2C_SLAVE 0
/* diff --git a/include/configs/bf533-ezkit.h b/include/configs/bf533-ezkit.h index c80ddca..37a7059 100644 --- a/include/configs/bf533-ezkit.h +++ b/include/configs/bf533-ezkit.h @@ -136,8 +136,6 @@ } while (0) #define I2C_DELAY udelay(5) /* 1/4 I2C clock duration */
-#define CONFIG_SYS_I2C_SPEED 50000 -#define CONFIG_SYS_I2C_SLAVE 0 #endif
diff --git a/include/configs/bf533-stamp.h b/include/configs/bf533-stamp.h index 2ec9c42..02c8bc3 100644 --- a/include/configs/bf533-stamp.h +++ b/include/configs/bf533-stamp.h @@ -180,8 +180,6 @@ } while (0) #define I2C_DELAY udelay(5) /* 1/4 I2C clock duration */
diff --git a/include/configs/bf537-pnav.h b/include/configs/bf537-pnav.h index cf40d06..8daebc8 100644 --- a/include/configs/bf537-pnav.h +++ b/include/configs/bf537-pnav.h @@ -155,8 +155,6 @@ */ #define CONFIG_BFIN_TWI_I2C 1 #define CONFIG_HARD_I2C 1 -#define CONFIG_SYS_I2C_SPEED 50000 -#define CONFIG_SYS_I2C_SLAVE 0
/* diff --git a/include/configs/bf537-stamp.h b/include/configs/bf537-stamp.h index cba4ac0..3592862 100644 --- a/include/configs/bf537-stamp.h +++ b/include/configs/bf537-stamp.h @@ -137,8 +137,6 @@ */ #define CONFIG_BFIN_TWI_I2C 1 #define CONFIG_HARD_I2C 1 -#define CONFIG_SYS_I2C_SPEED 50000 -#define CONFIG_SYS_I2C_SLAVE 0
/* diff --git a/include/configs/bf538f-ezkit.h b/include/configs/bf538f-ezkit.h index 59e0565..1c14b6b 100644 --- a/include/configs/bf538f-ezkit.h +++ b/include/configs/bf538f-ezkit.h @@ -134,8 +134,6 @@ */ #define CONFIG_BFIN_TWI_I2C 1 #define CONFIG_HARD_I2C 1 -#define CONFIG_SYS_I2C_SPEED 50000 -#define CONFIG_SYS_I2C_SLAVE 0
/* diff --git a/include/configs/bf548-ezkit.h b/include/configs/bf548-ezkit.h index f9c9711..60cca0c 100644 --- a/include/configs/bf548-ezkit.h +++ b/include/configs/bf548-ezkit.h @@ -140,8 +140,6 @@ */ #define CONFIG_BFIN_TWI_I2C 1 #define CONFIG_HARD_I2C 1 -#define CONFIG_SYS_I2C_SPEED 50000 -#define CONFIG_SYS_I2C_SLAVE 0
/* diff --git a/include/configs/bf561-ezkit.h b/include/configs/bf561-ezkit.h index 1e3fdef..036bfe4 100644 --- a/include/configs/bf561-ezkit.h +++ b/include/configs/bf561-ezkit.h @@ -151,8 +151,6 @@ } while (0) #define I2C_DELAY udelay(5) /* 1/4 I2C clock duration */
diff --git a/include/configs/bfin_adi_common.h b/include/configs/bfin_adi_common.h index 82daeb1..57a7309 100644 --- a/include/configs/bfin_adi_common.h +++ b/include/configs/bfin_adi_common.h @@ -252,6 +252,18 @@ #endif
/* + * I2C Settings + */ +#if defined(CONFIG_HARD_I2C) || defined(CONFIG_SOFT_I2C) +# ifndef CONFIG_SYS_I2C_SPEED +# define CONFIG_SYS_I2C_SPEED 50000 +# endif +# ifndef CONFIG_SYS_I2C_SLAVE +# define CONFIG_SYS_I2C_SLAVE 0 +# endif +#endif + +/* * Misc Settings */ #define CONFIG_BFIN_SPI_GPIO_CS /* Only matters if BFIN_SPI is enabled */ diff --git a/include/configs/cm-bf527.h b/include/configs/cm-bf527.h index ad1dd12..e0c6d53 100644 --- a/include/configs/cm-bf527.h +++ b/include/configs/cm-bf527.h @@ -117,8 +117,6 @@ */ #define CONFIG_BFIN_TWI_I2C 1 #define CONFIG_HARD_I2C 1 -#define CONFIG_SYS_I2C_SPEED 50000 -#define CONFIG_SYS_I2C_SLAVE 0
/* diff --git a/include/configs/cm-bf537e.h b/include/configs/cm-bf537e.h index 8d0bc12..742df9c 100644 --- a/include/configs/cm-bf537e.h +++ b/include/configs/cm-bf537e.h @@ -119,8 +119,6 @@ */ #define CONFIG_BFIN_TWI_I2C 1 #define CONFIG_HARD_I2C 1 -#define CONFIG_SYS_I2C_SPEED 50000 -#define CONFIG_SYS_I2C_SLAVE 0
/* diff --git a/include/configs/cm-bf537u.h b/include/configs/cm-bf537u.h index bbea3ab..9def99f 100644 --- a/include/configs/cm-bf537u.h +++ b/include/configs/cm-bf537u.h @@ -120,8 +120,6 @@ */ #define CONFIG_BFIN_TWI_I2C 1 #define CONFIG_HARD_I2C 1 -#define CONFIG_SYS_I2C_SPEED 50000 -#define CONFIG_SYS_I2C_SLAVE 0
/* diff --git a/include/configs/cm-bf548.h b/include/configs/cm-bf548.h index 93c4c8d..63b9399 100644 --- a/include/configs/cm-bf548.h +++ b/include/configs/cm-bf548.h @@ -107,8 +107,6 @@ */ #define CONFIG_BFIN_TWI_I2C 1 #define CONFIG_HARD_I2C 1 -#define CONFIG_SYS_I2C_SPEED 50000 -#define CONFIG_SYS_I2C_SLAVE 0
/* diff --git a/include/configs/ibf-dsp561.h b/include/configs/ibf-dsp561.h index 5601416..2c0a263 100644 --- a/include/configs/ibf-dsp561.h +++ b/include/configs/ibf-dsp561.h @@ -138,8 +138,6 @@ } while (0) #define I2C_DELAY udelay(5) /* 1/4 I2C clock duration */
diff --git a/include/configs/tcm-bf518.h b/include/configs/tcm-bf518.h index 9c04d8a..52055e8 100644 --- a/include/configs/tcm-bf518.h +++ b/include/configs/tcm-bf518.h @@ -106,8 +106,6 @@ */ #define CONFIG_BFIN_TWI_I2C 1 #define CONFIG_HARD_I2C 1 -#define CONFIG_SYS_I2C_SPEED 50000 -#define CONFIG_SYS_I2C_SLAVE 0
/* diff --git a/include/configs/tcm-bf537.h b/include/configs/tcm-bf537.h index 409a042..24ce8f8 100644 --- a/include/configs/tcm-bf537.h +++ b/include/configs/tcm-bf537.h @@ -120,8 +120,6 @@ */ #define CONFIG_BFIN_TWI_I2C 1 #define CONFIG_HARD_I2C 1 -#define CONFIG_SYS_I2C_SPEED 50000 -#define CONFIG_SYS_I2C_SLAVE 0
Hello Mike,
Acked-by: Heiko Schocher hs@denx.de
bye Heiko
Some commands (like 'mii') use this name to select devices, but they break when those names contain spaces. So drop the space from the Blackfin EMAC driver.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- drivers/net/bfin_mac.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/drivers/net/bfin_mac.c b/drivers/net/bfin_mac.c index ee4ad6c..e691bdf 100644 --- a/drivers/net/bfin_mac.c +++ b/drivers/net/bfin_mac.c @@ -99,7 +99,7 @@ int bfin_EMAC_initialize(bd_t *bis) hang();
memset(dev, 0, sizeof(*dev)); - sprintf(dev->name, "Blackfin EMAC"); + strcpy(dev->name, "bfin_mac");
dev->iobase = 0; dev->priv = 0;
Signed-off-by: Mike Frysinger vapier@gentoo.org --- include/configs/bfin_adi_common.h | 1 + 1 files changed, 1 insertions(+), 0 deletions(-)
diff --git a/include/configs/bfin_adi_common.h b/include/configs/bfin_adi_common.h index 57a7309..901a32f 100644 --- a/include/configs/bfin_adi_common.h +++ b/include/configs/bfin_adi_common.h @@ -248,6 +248,7 @@ # define CONFIG_SYS_AUTOLOAD "no" # endif # endif +# define CONFIG_IP_DEFRAG # define CONFIG_NET_RETRY_COUNT 20 #endif
From: Michael Hennerich michael.hennerich@analog.com
Support the new AD7160 eval board.
Signed-off-by: Michael Hennerich michael.hennerich@analog.com Signed-off-by: Mike Frysinger vapier@gentoo.org --- MAINTAINERS | 2 + MAKEALL | 1 + board/bf527-ad7160-eval/Makefile | 54 ++++++++++ board/bf527-ad7160-eval/bf527-ad7160-eval.c | 25 +++++ board/bf527-ad7160-eval/config.mk | 33 ++++++ boards.cfg | 1 + include/configs/bf527-ad7160-eval.h | 148 +++++++++++++++++++++++++++ 7 files changed, 264 insertions(+), 0 deletions(-) create mode 100644 board/bf527-ad7160-eval/Makefile create mode 100644 board/bf527-ad7160-eval/bf527-ad7160-eval.c create mode 100644 board/bf527-ad7160-eval/config.mk create mode 100644 include/configs/bf527-ad7160-eval.h
diff --git a/MAINTAINERS b/MAINTAINERS index 9485070..7e66e8d 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -998,6 +998,8 @@ Blackfin Team u-boot-devel@blackfin.uclinux.org BF548-EZKIT BF548 BF561-EZKIT BF561
+ BF527-AD7160-EVAL BF527 + Bluetechnix Tinyboards bluetechnix@blackfin.uclinux.org Blackfin Team u-boot-devel@blackfin.uclinux.org
diff --git a/MAKEALL b/MAKEALL index 4637390..ebd0ddc 100755 --- a/MAKEALL +++ b/MAKEALL @@ -892,6 +892,7 @@ LIST_avr32=" \ LIST_blackfin=" \ bf518f-ezbrd \ bf526-ezbrd \ + bf527-ad7160-eval \ bf527-ezkit \ bf527-ezkit-v2 \ bf533-ezkit \ diff --git a/board/bf527-ad7160-eval/Makefile b/board/bf527-ad7160-eval/Makefile new file mode 100644 index 0000000..f2bd2c2 --- /dev/null +++ b/board/bf527-ad7160-eval/Makefile @@ -0,0 +1,54 @@ +# +# U-boot - Makefile +# +# Copyright (c) 2005-2008 Analog Device Inc. +# +# (C) Copyright 2000-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS-y := $(BOARD).o + +SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) +SOBJS := $(addprefix $(obj),$(SOBJS-y)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/bf527-ad7160-eval/bf527-ad7160-eval.c b/board/bf527-ad7160-eval/bf527-ad7160-eval.c new file mode 100644 index 0000000..b06d5ab --- /dev/null +++ b/board/bf527-ad7160-eval/bf527-ad7160-eval.c @@ -0,0 +1,25 @@ +/* + * U-boot - main board file + * + * Copyright (c) 2010 Analog Devices Inc. + * + * Licensed under the GPL-2 or later. + */ + +#include <common.h> +#include <asm/blackfin.h> +#include <asm/mach-common/bits/pll.h> + +int checkboard(void) +{ + printf("Board: ADI BF527 AD7160-EVAL board\n"); + printf(" Support: http://blackfin.uclinux.org/%5Cn"); + return 0; +} + +int misc_init_r(void) +{ + /* CLKIN Buffer Output Enable */ + *pVR_CTL |= CLKBUFOE; + return 0; +} diff --git a/board/bf527-ad7160-eval/config.mk b/board/bf527-ad7160-eval/config.mk new file mode 100644 index 0000000..f85bef5 --- /dev/null +++ b/board/bf527-ad7160-eval/config.mk @@ -0,0 +1,33 @@ +# +# Copyright (c) 2005-2008 Analog Device Inc. +# +# (C) Copyright 2001 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +# This is not actually used for Blackfin boards so do not change it +#TEXT_BASE = do-not-use-me + +CFLAGS_lib_generic += -O2 +CFLAGS_lzma += -O2 + +# Set some default LDR flags based on boot mode. +LDR_FLAGS += $(LDR_FLAGS-$(CONFIG_BFIN_BOOT_MODE)) diff --git a/boards.cfg b/boards.cfg index da31c36..18008b5 100644 --- a/boards.cfg +++ b/boards.cfg @@ -282,6 +282,7 @@ favr-32-ezkit avr32 at32ap - earthlcd at32ap700x hammerhead avr32 at32ap - miromico at32ap700x bf518f-ezbrd blackfin blackfin bf526-ezbrd blackfin blackfin +bf527-ad7160-eval blackfin blackfin bf527-ezkit blackfin blackfin bf533-ezkit blackfin blackfin bf533-stamp blackfin blackfin diff --git a/include/configs/bf527-ad7160-eval.h b/include/configs/bf527-ad7160-eval.h new file mode 100644 index 0000000..eb3a2b7 --- /dev/null +++ b/include/configs/bf527-ad7160-eval.h @@ -0,0 +1,148 @@ +/* + * U-boot - Configuration file for BF527 AD7160-EVAL board + */ + +#ifndef __CONFIG_BF527_AD7160_EVAL_H__ +#define __CONFIG_BF527_AD7160_EVAL_H__ + +#include <asm/config-pre.h> + + +/* + * Processor Settings + */ +#define CONFIG_BFIN_CPU bf527-0.2 +#define CONFIG_BFIN_BOOT_MODE BFIN_BOOT_SPI_MASTER + + +/* + * Clock Settings + * CCLK = (CLKIN * VCO_MULT) / CCLK_DIV + * SCLK = (CLKIN * VCO_MULT) / SCLK_DIV + */ +/* CONFIG_CLKIN_HZ is any value in Hz */ +#define CONFIG_CLKIN_HZ 24000000 +/* CLKIN_HALF controls the DF bit in PLL_CTL 0 = CLKIN */ +/* 1 = CLKIN / 2 */ +#define CONFIG_CLKIN_HALF 0 +/* PLL_BYPASS controls the BYPASS bit in PLL_CTL 0 = do not bypass */ +/* 1 = bypass PLL */ +#define CONFIG_PLL_BYPASS 0 +/* VCO_MULT controls the MSEL (multiplier) bits in PLL_CTL */ +/* Values can range from 0-63 (where 0 means 64) */ +#define CONFIG_VCO_MULT 25 +/* CCLK_DIV controls the core clock divider */ +/* Values can be 1, 2, 4, or 8 ONLY */ +#define CONFIG_CCLK_DIV 1 +/* SCLK_DIV controls the system clock divider */ +/* Values can range from 1-15 */ +#define CONFIG_SCLK_DIV 5 + + +/* + * Memory Settings + */ +#define CONFIG_MEM_ADD_WDTH 10 +#define CONFIG_MEM_SIZE 64 + +#define CONFIG_EBIU_SDRRC_VAL 0x03F6 +#define CONFIG_EBIU_SDGCTL_VAL (SCTLE | CL_3 | PASR_ALL | TRAS_6 | TRP_3 | TRCD_3 | TWR_2 | PSS) + +#define CONFIG_EBIU_AMGCTL_VAL (AMCKEN | AMBEN_ALL) +#define CONFIG_EBIU_AMBCTL0_VAL (B1WAT_15 | B1RAT_15 | B1HT_3 | B1RDYPOL | B0WAT_15 | B0RAT_15 | B0HT_3 | B0RDYPOL) +#define CONFIG_EBIU_AMBCTL1_VAL (B3WAT_15 | B3RAT_15 | B3HT_3 | B3RDYPOL | B2WAT_15 | B2RAT_15 | B2HT_3 | B2RDYPOL) + +#define CONFIG_SYS_MONITOR_LEN (768 * 1024) +#define CONFIG_SYS_MALLOC_LEN (640 * 1024) + + +/* + * NAND Settings + * (can't be used same time as ethernet) + */ +#if (CONFIG_BFIN_BOOT_MODE == BFIN_BOOT_NAND) +# define CONFIG_BFIN_NFC +# define CONFIG_BFIN_NFC_BOOTROM_ECC +#endif +#ifdef CONFIG_BFIN_NFC +#define CONFIG_BFIN_NFC_CTL_VAL 0x0033 +#define CONFIG_DRIVER_NAND_BFIN +#define CONFIG_SYS_NAND_BASE 0 /* not actually used */ +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define NAND_MAX_CHIPS 1 +#endif + + +/* + * Flash Settings + */ +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_FLASH_BASE 0x20000000 +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_SYS_FLASH_PROTECTION +#define CONFIG_SYS_MAX_FLASH_BANKS 1 +#define CONFIG_SYS_MAX_FLASH_SECT 259 + + +/* + * SPI Settings + */ +#define CONFIG_BFIN_SPI +#define CONFIG_ENV_SPI_MAX_HZ 30000000 +#define CONFIG_SF_DEFAULT_SPEED 30000000 +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_STMICRO + + +/* + * Env Storage Settings + */ +#if (CONFIG_BFIN_BOOT_MODE == BFIN_BOOT_SPI_MASTER) +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_OFFSET 0x10000 +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_ENV_SECT_SIZE 0x10000 +#define CONFIG_ENV_IS_EMBEDDED_IN_LDR +#elif (CONFIG_BFIN_BOOT_MODE == BFIN_BOOT_NAND) +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_OFFSET 0x40000 +#define CONFIG_ENV_SIZE 0x20000 +#else +#define CONFIG_ENV_IS_IN_FLASH +#define CONFIG_ENV_OFFSET 0x4000 +#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + CONFIG_ENV_OFFSET) +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_ENV_SECT_SIZE 0x2000 +#define CONFIG_ENV_IS_EMBEDDED_IN_LDR +#endif + + +/* + * I2C Settings + */ +#define CONFIG_BFIN_TWI_I2C 1 +#define CONFIG_HARD_I2C 1 + + +/* + * SPI_MMC Settings + */ +#define CONFIG_MMC +#define CONFIG_CMD_EXT2 +#define CONFIG_SPI_MMC +#define CONFIG_SPI_MMC_DEFAULT_CS (7 + GPIO_PH3) + + +/* + * Misc Settings + */ +#define CONFIG_MISC_INIT_R +#define CONFIG_UART_CONSOLE 0 + + +/* + * Pull in common ADI header for remaining command/environment setup + */ +#include <configs/bfin_adi_common.h> + +#endif
The u-boot.lds CPP unification missed the Blackfin-specific clean target. It is no longer needed, so punt it.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- Makefile | 1 - 1 files changed, 0 insertions(+), 1 deletions(-)
diff --git a/Makefile b/Makefile index 1d87f37..9c4e3a4 100644 --- a/Makefile +++ b/Makefile @@ -2436,7 +2436,6 @@ clean: $(obj)board/netstar/{eeprom,crcek,crcit,*.srec,*.bin} \ $(obj)board/trab/trab_fkt $(obj)board/voiceblue/eeprom \ $(obj)board/armltd/{integratorap,integratorcp}/u-boot.lds \ - $(obj)arch/blackfin/lib/u-boot.lds \ $(obj)u-boot.lds \ $(obj)arch/blackfin/cpu/bootrom-asm-offsets.[chs] @rm -f $(obj)include/bmp_logo.h
The SPI env code didn't support redundant environments until recently, but this code was written before that. Since it has never been tested (and currently causes a build failure), simply punt it. If the functionality is actually desired, it can be re-added once it has been tested.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- include/configs/bf561-acvilon.h | 1 - 1 files changed, 0 insertions(+), 1 deletions(-)
diff --git a/include/configs/bf561-acvilon.h b/include/configs/bf561-acvilon.h index 0be170c..44854c7 100644 --- a/include/configs/bf561-acvilon.h +++ b/include/configs/bf561-acvilon.h @@ -131,7 +131,6 @@ #define CONFIG_ENV_SECT_SIZE (1056 * 8) #define CONFIG_ENV_OFFSET ((16 + 256) * 1056) #define CONFIG_ENV_SIZE (8 * 1056) -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE)
participants (5)
Aldo Cedillo
Ben Warren
Heiko Schocher
Mike Frysinger
Scott Wood
