[U-Boot] [[RFC Patch] 1/2] tools: buildmand: Remove duplicated code
Signed-off-by: York Sun york.sun@nxp.com CC: Simon Glass sjg@chromium.org --- The duplicated code seems to exist since the beginning of buildman.
tools/buildman/builderthread.py | 4 ---- 1 file changed, 4 deletions(-)
diff --git a/tools/buildman/builderthread.py b/tools/buildman/builderthread.py index c512d3b..16e87f3 100644 --- a/tools/buildman/builderthread.py +++ b/tools/buildman/builderthread.py @@ -304,10 +304,6 @@ class BuilderThread(threading.Thread): print >>fd, 'arch', result.toolchain.arch fd.write('%s' % result.return_code)
- with open(os.path.join(build_dir, 'toolchain'), 'w') as fd: - print >>fd, 'gcc', result.toolchain.gcc - print >>fd, 'path', result.toolchain.path - # Write out the image and function size information and an objdump env = result.toolchain.MakeEnvironment(self.builder.full_path) lines = []
Now we can use compiler wrapper such as ccache or distcc for buildman.
Signed-off-by: York Sun york.sun@nxp.com CC: Simon Glass sjg@chromium.org --- This is not perfect and may need some improvement. Something I didn't figure out is how to drop the name under [toolchain-wrapper]. I intended to have this format but bsettings.GetItems doesn't like it.
[toolchain-wrapper] ccache
It doesn't deal with more than one line for this setting. For now, the last setting is taken.
tools/buildman/README | 9 +++++++++ tools/buildman/toolchain.py | 17 +++++++++++++++-- 2 files changed, 24 insertions(+), 2 deletions(-)
diff --git a/tools/buildman/README b/tools/buildman/README index 8c5f861..514bebc 100644 --- a/tools/buildman/README +++ b/tools/buildman/README @@ -211,6 +211,15 @@ arm: arm-none-eabi-
and buildman will find arm-none-eabi-gcc in /usr/bin if you have it installed.
+[toolchain-wrapper] +wrapper: ccache + +This tells buildman to use a compiler wrapper in front of CROSS_COMPILE. In +this example, ccache. It doesn't affect the toolchain scan. The wrapper is +added when CROSS_COMPILE environtal variable is set. The name in this +section is ignored. If more than one line is provided, only the last one +is taken. + 3. Make sure you have the require Python pre-requisites
Buildman uses multiprocessing, Queue, shutil, StringIO, ConfigParser and diff --git a/tools/buildman/toolchain.py b/tools/buildman/toolchain.py index 41e4e4c..01cdb03 100644 --- a/tools/buildman/toolchain.py +++ b/tools/buildman/toolchain.py @@ -127,6 +127,15 @@ class Toolchain: return PRIORITY_CALC + prio return PRIORITY_CALC + prio
+ def GetWrapper(self, show_warning=True): + """Get toolchain wrapper from the setting file. + """ + value = '' + for name, value in bsettings.GetItems('toolchain-wrapper'): + if not value: + print "Warning: Wrapper not found" + return value + def MakeEnvironment(self, full_path): """Returns an environment for using the toolchain.
@@ -138,10 +147,14 @@ class Toolchain: PATH """ env = dict(os.environ) + wrapper = self.GetWrapper() + if wrapper: + wrapper = wrapper + ' ' + if full_path: - env['CROSS_COMPILE'] = os.path.join(self.path, self.cross) + env['CROSS_COMPILE'] = wrapper + os.path.join(self.path, self.cross) else: - env['CROSS_COMPILE'] = self.cross + env['CROSS_COMPILE'] = wrapper + self.cross env['PATH'] = self.path + ':' + env['PATH']
return env
Hi York,
Looks good, a few nits below.
I think it is good to have this in a separate section, as you have done. If we put it in the '[toolchain]' section, the name 'wrapper' would be special, and mean something, whereas the other names would not.
- Make sure you have the require Python pre-requisites
- def GetWrapper(self, show_warning=True):
value = ''
if not value:
return value
Can you make it add the ' ' here?
- def MakeEnvironment(self, full_path): """Returns an environment for using the toolchain.
if wrapper:
Instead of here
if full_path:
env['CROSS_COMPILE'] = wrapper + self.cross env['PATH'] = self.path + ':' + env['PATH'] return env
-- 2.7.4
York Sun
