RE: [U-Boot-Users] [PATCH] New ADS GraphicsClient+ board port
Our brand-new board has flash byte-swapped. When we respin (we only made 5 in the first batch) we'll fix it. But for now, it's backward. And it turns out (so far) that there are minimal changes in the CFI code, which could be #ifdef'ed. Actually I'm using a strataflash.c from another board, but I don't think that matters too much -- it's still CFI-driven.
-----Original Message----- From: u-boot-users-admin@lists.sourceforge.net [mailto:u-boot-users-admin@lists.sourceforge.net] Sent: Thursday, March 11, 2004 5:01 PM To: George G. Davis Cc: Brad Kemp; u-boot-users@lists.sourceforge.net Subject: Re: [U-Boot-Users] [PATCH] New ADS GraphicsClient+ board port
On Thu, 2004-03-11 at 14:28, George G. Davis wrote:
On Thu, Mar 11, 2004 at 02:56:24PM -0500, Brad Kemp wrote:
George, What problem did you have with the CFI flash driver?
Couldn't detect flash. I didn't try to debug it much beyond that since I already had the flash.c ported from a few months ago. So I punted with that for now. I took a look at that common CFI flash driver and had the opinion that the BE/LE support could/should probably be done better, e.g. via appropriate use of cpu_to_{le,be{8,16,32,64} macros. But that was just an opinion drawn from a mere glance at the source.
I think it should be configurable period. I am using the CFI driver on a BE system but I have the LE option defined since my flash is byte swapped. So that works for me, but I have to override the _LITTLE_ENDIAN define in just that file. So I think it should somehow look for a different define to override how it works. IE something like CONFIG_FLASH_CFI_BYTE_SWAP or something. Comments?
Thanks, Matthew
-- Regards, George
Brad
-----Original Message----- From: George G. Davis [mailto:davis_g@comcast.net] Sent: Thursday, March 11, 2004 2:17 PM To: u-boot-users@lists.sourceforge.net Subject: [U-Boot-Users] [PATCH] New ADS GraphicsClient+ board port
Greetings,
I humbly submit this trivial board port for the ADS GraphicsClient+. This SA-1110 based board is actually EOL but it's still useful to me for Linux development/testing. I'll eventually make this thing use the common CFI flash support instead of the flash.c included here. But for now I was unable to get the CFI flash support working on this target.
This patch is based on latest CVS HEAD +/- a few hours.
Thanks!
-- Regards, George
diff -x CVS -ruN u-boot.orig/board/gcplus/config.mk u-boot.new/board/gcplus/config.mk --- u-boot.orig/board/gcplus/config.mk 1969-12-31 19:00:00.000000000 -0500 +++ u-boot.new/board/gcplus/config.mk 2003-11-06 00:36:23.000000000 -0500 @@ -0,0 +1,13 @@ +# +# ADS GCPlus board with SA1110 cpu +# +# The ADS GCPlus has 2 banks of 16 MiB SDRAM +# +# We use the ADS GCPlus Linux boot ROM to load U-Boot into SDRAM +# at c020'0000 and then move ourself to c8f0'0000. Basically, just +# install the U-Boot binary as you would the Linux zImage and then +# reap the benfits of more convenient Linux development cycles, i.e. +# bootp;tftp;bootm, repeat, etc.,. +#
+TEXT_BASE = 0xc8f00000 diff -x CVS -ruN u-boot.orig/board/gcplus/flash.c u-boot.new/board/gcplus/flash.c --- u-boot.orig/board/gcplus/flash.c 1969-12-31 19:00:00.000000000 -0500 +++ u-boot.new/board/gcplus/flash.c 2003-12-09 11:29:34.000000000 -0500 @@ -0,0 +1,440 @@ +/*
- (C) Copyright 2001
- Kyle Harris, Nexus Technologies, Inc. kharris@nexus-tech.net
- Wolfgang Denk, DENX Software Engineering, wd@denx.de.
- 2003 (c) MontaVista Software, Inc.
- project.
- MA 02111-1307 USA
+#include <common.h> +#include <linux/byteorder/swab.h>
+flash_info_t flash_info[CFG_MAX_FLASH_BANKS]; /* info for FLASH chips */
+/* Board support for 1 or 2 flash devices */ +#define FLASH_PORT_WIDTH32 +#undef FLASH_PORT_WIDTH16
+#ifdef FLASH_PORT_WIDTH16 +#define FLASH_PORT_WIDTH ushort +#define FLASH_PORT_WIDTHV vu_short +#define SWAP(x) __swab16(x) +#else +#define FLASH_PORT_WIDTH ulong +#define FLASH_PORT_WIDTHV vu_long +#define SWAP(x) __swab32(x) +#endif
+#define FPW FLASH_PORT_WIDTH +#define FPWV FLASH_PORT_WIDTHV
+#define mb() __asm__ __volatile__ ("" : : : "memory")
- Functions
+static ulong flash_get_size(FPW * addr, flash_info_t * info); +static int write_data(flash_info_t * info, ulong dest, FPW data); +static void flash_get_offsets(ulong base, flash_info_t * info); +void inline spin_wheel(void);
+unsigned long +flash_init(void) +{
- int i;
- ulong size = 0;
- for (i = 0; i < CFG_MAX_FLASH_BANKS; i++) {
switch (i) {
case 0:
flash_get_size((FPW *) PHYS_FLASH_1,
&flash_info[i]);
flash_get_offsets(PHYS_FLASH_1, &flash_info[i]);
break;
default:
panic("configured too many flash banks!\n");
break;
size += flash_info[i].size;
- /* Protect monitor and environment sectors
- flash_protect(FLAG_PROTECT_SET,
CFG_FLASH_BASE,
CFG_FLASH_BASE + monitor_flash_len - 1,
&flash_info[0]);
CFG_ENV_ADDR,
CFG_ENV_ADDR + CFG_ENV_SIZE - 1, &flash_info[0]);
- return size;
+static void +flash_get_offsets(ulong base, flash_info_t * info) +{
- int i;
- if (info->flash_id == FLASH_UNKNOWN) {
return;
- if ((info->flash_id & FLASH_VENDMASK) == FLASH_MAN_INTEL) {
for (i = 0; i < info->sector_count; i++) {
info->start[i] = base + (i *
PHYS_FLASH_SECT_SIZE);
info->protect[i] = 0;
+void +flash_print_info(flash_info_t * info) +{
- int i;
printf("missing or unknown FLASH type\n");
return;
- switch (info->flash_id & FLASH_VENDMASK) {
- case FLASH_MAN_INTEL:
printf("INTEL ");
break;
- default:
printf("Unknown Vendor ");
break;
- switch (info->flash_id & FLASH_TYPEMASK) {
- case FLASH_28F128J3A:
printf("28F128J3A\n");
break;
- case FLASH_28F640J5:
printf("28F640J5\n");
break;
- default:
printf("Unknown Chip Type\n");
break;
- printf(" Size: %ld MB in %d Sectors\n",
info->size >> 20, info->sector_count);
- printf(" Sector Start Addresses:");
- for (i = 0; i < info->sector_count; ++i) {
if ((i % 5) == 0)
printf("\n ");
printf(" %08lX%s",
info->start[i], info->protect[i] ? "
(RO)" : " ");
- printf("\n");
- return;
- The following code cannot be run from FLASH!
+static ulong +flash_get_size(FPW * addr, flash_info_t * info) +{
- volatile FPW value;
- /* Write auto select command: read Manufacturer ID */
- addr[0x5555] = (FPW) 0x00AA00AA;
- addr[0x2AAA] = (FPW) 0x00550055;
- addr[0x5555] = (FPW) 0x00900090;
- mb();
- value = addr[0];
- switch (value) {
- case (FPW) INTEL_MANUFACT:
info->flash_id = FLASH_MAN_INTEL;
break;
- default:
info->flash_id = FLASH_UNKNOWN;
info->sector_count = 0;
info->size = 0;
addr[0] = (FPW) 0x00FF00FF; /* restore read mode */
return (0); /* no or unknown flash */
- mb();
- value = addr[1]; /* device ID */
- switch (value) {
- case (FPW) INTEL_ID_28F128J3A:
info->flash_id += FLASH_28F128J3A;
info->sector_count = 128;
info->size = 0x02000000;
break; /* => 16 MB */
- case (FPW) INTEL_ID_28F640J5:
info->flash_id += FLASH_28F640J5;
info->sector_count = 64;
info->size = 0x01000000;
- default:
break;
- if (info->sector_count > CFG_MAX_FLASH_SECT) {
printf("** ERROR: sector count %d > max (%d) **\n",
info->sector_count, CFG_MAX_FLASH_SECT);
info->sector_count = CFG_MAX_FLASH_SECT;
- addr[0] = (FPW) 0x00FF00FF; /* restore read mode */
- return (info->size);
+int +flash_erase(flash_info_t * info, int s_first, int s_last) +{
- int flag, prot, sect;
- ulong type, start, last;
- int rcode = 0;
- if ((s_first < 0) || (s_first > s_last)) {
printf("- missing\n");
} else {
printf("- no sectors to erase\n");
return 1;
- type = (info->flash_id & FLASH_VENDMASK);
- if ((type != FLASH_MAN_INTEL)) {
printf("Can't erase unknown flash type %08lx -
aborted\n",
info->flash_id);
return 1;
- prot = 0;
- for (sect = s_first; sect <= s_last; ++sect) {
if (info->protect[sect]) {
prot++;
- if (prot) {
printf("- Warning: %d protected sectors will
not be erased!\n",
prot);
- } else {
printf("\n");
- start = get_timer(0);
- last = start;
- /* Disable interrupts which might cause a timeout here */
- flag = disable_interrupts();
- /* Start erase on unprotected sectors */
- for (sect = s_first; sect <= s_last; sect++) {
if (info->protect[sect] == 0) { /* not protected */
FPWV *addr = (FPWV *) (info->start[sect]);
FPW status;
printf("Erasing sector %2d ... ", sect);
/* arm simple, non interrupt dependent timer */
reset_timer_masked();
*addr = (FPW) 0x00500050; /*
clear status register */
*addr = (FPW) 0x00200020; /*
erase setup */
*addr = (FPW) 0x00D000D0; /*
erase confirm */
while (((status =
*addr) & (FPW) 0x00800080) !=
(FPW) 0x00800080) {
if (get_timer_masked() >
CFG_FLASH_ERASE_TOUT) {
printf("Timeout\n");
*addr = (FPW)
0x00B000B0; /* suspend erase */
*addr = (FPW)
0x00FF00FF; /* reset to read mode */
rcode = 1;
break;
clear status register cmd. */
*addr = (FPW) 0x00FF00FF; /*
resest to read mode */
printf(" done\n");
- return rcode;
- Copy memory to flash, returns:
- 0 - OK
- 1 - write timeout
- 2 - Flash not erased
- 4 - Flash not identified
+int +write_buff(flash_info_t * info, uchar * src, ulong addr, ulong cnt) +{
- ulong cp, wp;
- FPW data;
- int count, i, l, rc, port_width;
return 4;
+/* get lower word aligned address */ +#ifdef FLASH_PORT_WIDTH16
- wp = (addr & ~1);
- port_width = 2;
+#else
- wp = (addr & ~3);
- port_width = 4;
* handle unaligned start bytes
- if ((l = addr - wp) != 0) {
data = 0;
for (i = 0, cp = wp; i < l; ++i, ++cp) {
data = (data << 8) | (*(uchar *) cp);
for (; i < port_width && cnt > 0; ++i) {
data = (data << 8) | *src++;
--cnt;
++cp;
for (; cnt == 0 && i < port_width; ++i, ++cp) {
if ((rc = write_data(info, wp, SWAP(data))) != 0) {
return (rc);
wp += port_width;
* handle word aligned part
- count = 0;
- while (cnt >= port_width) {
data = 0;
for (i = 0; i < port_width; ++i) {
return (rc);
wp += port_width;
cnt -= port_width;
if (count++ > 0x800) {
spin_wheel();
count = 0;
- if (cnt == 0) {
return (0);
* handle unaligned tail bytes
- data = 0;
- for (i = 0, cp = wp; i < port_width && cnt > 0; ++i, ++cp) {
--cnt;
- for (; i < port_width; ++i, ++cp) {
- return (write_data(info, wp, SWAP(data)));
- Write a word or halfword to Flash, returns:
- 0 - OK
- 1 - write timeout
+static int +write_data(flash_info_t * info, ulong dest, FPW data) +{
- FPWV *addr = (FPWV *) dest;
- ulong status;
- int flag;
- /* Check if Flash is (sufficiently) erased */
- if ((*addr & data) != data) {
printf("not erased at %08lx (%x)\n", (ulong)
addr, *addr);
return (2);
- *addr = (FPW) 0x00400040; /* write setup */
- *addr = data;
- /* arm simple, non interrupt dependent timer */
- reset_timer_masked();
- /* wait while polling the status register */
- while (((status = *addr) & (FPW) 0x00800080) != (FPW)
0x00800080) {
if (get_timer_masked() > CFG_FLASH_WRITE_TOUT) {
return (1);
- *addr = (FPW) 0x00FF00FF; /* restore read mode */
- return (0);
+void inline +spin_wheel(void) +{
- static int p = 0;
- static char w[] = "\/-";
- printf("\010%c", w[p]);
- (++p == 3) ? (p = 0) : 0;
+} diff -x CVS -ruN u-boot.orig/board/gcplus/gcplus.c u-boot.new/board/gcplus/gcplus.c --- u-boot.orig/board/gcplus/gcplus.c 1969-12-31 19:00:00.000000000 -0500 +++ u-boot.new/board/gcplus/gcplus.c 2004-03-09 21:52:57.000000000 -0500 @@ -0,0 +1,73 @@ +/*
- (C) Copyright 2002
- Sysgo Real-Time Solutions, GmbH <www.elinos.com>
- Marius Groeger mgroeger@sysgo.de
- 2003-2004 (c) MontaVista Software, Inc.
- project.
- MA 02111-1307 USA
+#include <common.h> +#include <SA-1100.h>
- Miscelaneous platform dependent initialisations
+int +board_init(void) +{
- DECLARE_GLOBAL_DATA_PTR;
- gd->bd->bi_arch_number = 29; /* ADS
GraphicsClientPlus Board */
- gd->bd->bi_boot_params = 0xc000003c; /* Weird address? */
- /* Most of the ADS GCPlus I/O is connected to Static nCS2.
* So I'm brute forcing nCS2 timiming here for worst case.
- MSC1 &= ~0xFFFF;
- MSC1 |= 0x8649;
- /* Nothing is connected to Static nCS4 or nCS5. But I'm using
* nCS4 as a paranoia safe guard to force nCS2, nOE; nWE high
* after accessing I/O via (non-VLIO) nCS2. What can I say, I'm
* paranoid and lack decent tools to alleviate my fear. I sure
* do wish I had a logic analyzer. : (
- MSC2 = 0xfff9fff9;
+int +dram_init(void) +{
- gd->bd->bi_dram[0].start = PHYS_SDRAM_1;
- gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE;
- gd->bd->bi_dram[1].start = PHYS_SDRAM_2;
- gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE;
- return (0);
+} diff -x CVS -ruN u-boot.orig/board/gcplus/Makefile u-boot.new/board/gcplus/Makefile --- u-boot.orig/board/gcplus/Makefile 1969-12-31 19:00:00.000000000 -0500 +++ u-boot.new/board/gcplus/Makefile 2004-03-09 21:50:31.000000000 -0500 @@ -0,0 +1,49 @@ +# +# (C) Copyright 2000 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# 2003 (c) MontaVista Software, Inc. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +#
+include $(TOPDIR)/config.mk
+LIB = lib$(BOARD).a
+OBJS := gcplus.o flash.o +SOBJS := memsetup.o
+$(LIB): $(OBJS) $(SOBJS)
- $(AR) crv $@ $(OBJS) $(SOBJS)
+clean:
- rm -f $(SOBJS) $(OBJS)
+distclean: clean
- rm -f $(LIB) core *.bak .depend
+.depend: Makefile $(SOBJS:.o=.S) $(OBJS:.o=.c)
$(CC) -M $(CPPFLAGS) $(SOBJS:.o=.S) $(OBJS:.o=.c) > $@
+-include .depend
+############################################################# ############ diff -x CVS -ruN u-boot.orig/board/gcplus/memsetup.S u-boot.new/board/gcplus/memsetup.S --- u-boot.orig/board/gcplus/memsetup.S 1969-12-31 19:00:00.000000000 -0500 +++ u-boot.new/board/gcplus/memsetup.S 2004-03-09 23:12:53.000000000 -0500 @@ -0,0 +1,77 @@ +/*
- Memory Setup stuff - taken from blob memsetup.S
- Copyright (C) 1999 2000 2001 Erik Mouw
(J.A.K.Mouw@its.tudelft.nl) and
Jan-Derk Bakker (J.D.Bakker@its.tudelft.nl)
- project.
- MA 02111-1307 USA
+#include "config.h" +#include "version.h"
- .globl memsetup
+memsetup:
- /* The ADS GC+ for Linux Boot Rom Ver. 1.73 does memory
init for us.
* However the darn thing leaves the MMU enabled before
handing control
* over to us. So we need to disable the MMU and we use memsetup
* to do it.
+@ The following code segment was borrowed with gratitude from: +@ linux-2.4.19-rmk7/arch/arm/boot/compressed/head-sa1100.S
- @ Data cache might be active.
- @ Be sure to flush kernel binary out of the cache,
- @ whatever state it is, before it is turned off.
- @ This is done by fetching through currently executed
- @ memory to be sure we hit the same cache.
- bic r2, pc, #0x1f
- add r3, r2, #0x4000 @ 16 kb is quite enough...
+1: ldr r0, [r2], #32
- teq r2, r3
- bne 1b
- mcr p15, 0, r0, c7, c10, 4 @ drain WB
- mcr p15, 0, r0, c7, c7, 0 @ flush I & D caches
- @ disabling MMU and caches
- mrc p15, 0, r0, c1, c0, 0 @ read control reg
- bic r0, r0, #0x0d @ clear WB, DC, MMU
- bic r0, r0, #0x1000 @ clear Icache
- mcr p15, 0, r0, c1, c0, 0
- nop
- nop
- nop
- nop
- nop
- b 2f
+2:
- nop
- nop
- nop
- nop
- nop
- mov pc, lr
diff -x CVS -ruN u-boot.orig/board/gcplus/u-boot.lds u-boot.new/board/gcplus/u-boot.lds --- u-boot.orig/board/gcplus/u-boot.lds 1969-12-31 19:00:00.000000000 -0500 +++ u-boot.new/board/gcplus/u-boot.lds 2004-03-06 16:03:44.000000000 -0500 @@ -0,0 +1,57 @@ +/*
- (C) Copyright 2000
- project.
- MA 02111-1307 USA
+OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{
- . = 0x00000000;
- . = ALIGN(4);
- .text :
cpu/sa1100/start.o (.text)
*(.text)
- . = ALIGN(4);
- .rodata : { *(.rodata) }
- . = ALIGN(4);
- .data : { *(.data) }
- . = ALIGN(4);
- .got : { *(.got) }
- __u_boot_cmd_start = .;
- .u_boot_cmd : { *(.u_boot_cmd) }
- __u_boot_cmd_end = .;
- . = ALIGN(4);
- __bss_start = .;
- .bss : { *(.bss) }
- _end = .;
+} diff -x CVS -ruN u-boot.orig/include/configs/gcplus.h u-boot.new/include/configs/gcplus.h --- u-boot.orig/include/configs/gcplus.h 1969-12-31 19:00:00.000000000 -0500 +++ u-boot.new/include/configs/gcplus.h 2004-03-11 09:41:31.000000000 -0500 @@ -0,0 +1,174 @@ +/*
- Configuation settings for the ADS GraphicsClient+ board.
- project.
- MA 02111-1307 USA
+#ifndef __CONFIG_H +#define __CONFIG_H
+#undef DEBUG
- The ADS GCPlus Linux boot ROM loads U-Boot into RAM at 0xc0200000.
- We don't actually init RAM in this case since we're using
U-Boot as
- an secondary boot loader during Linux kernel development
and testing,
- e.g. bootp/tftp download of the kernel is a far more convenient
- when testing new kernels on this target. However the ADS
GCPlus Linux
- boot ROM leaves the MMU enabled when it passes control to
U-Boot. So
- we use memsetup (CONFIG_INIT_CRITICAL) to remedy that problem.
+#define CONFIG_INIT_CRITICAL
- High Level Configuration Options
- (easy to change)
+#define CONFIG_SA1110 1 /* This is an SA1100 CPU */ +#define CONFIG_GCPLUS 1 /* on an ADS GCPlus Board */
+#undef CONFIG_USE_IRQ /* we don't need IRQ/FIQ stuff */
+#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1
- Size of malloc() pool
+#define CFG_MALLOC_LEN (CFG_ENV_SIZE + 128*1024) +#define CFG_GBL_DATA_SIZE 128 /* size rsrvd for initial data */
- Hardware drivers
+#define CONFIG_DRIVER_LAN91C96 /* we have an SMC9194 on-board */ +#define CONFIG_LAN91C96_BASE 0x100e0000
- select serial console configuration
+#define CONFIG_SERIAL3 1 /* we use SERIAL 3 on ADS GCPlus */
+/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE
+#define CONFIG_BAUDRATE 38400
+#define CONFIG_COMMANDS (CONFIG_CMD_DFL | CFG_CMD_DHCP) +#define CONFIG_BOOTP_MASK CONFIG_BOOTP_DEFAULT
+/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ +#include <cmd_confdefs.h>
+#define CONFIG_BOOTDELAY 3 +#define CONFIG_BOOTARGS "console=ttySA0,38400n8 mtdparts=sa1100-flash:1m@0(zImage),3m@1m(ramdisk.gz),12m@4m(us erfs) root=/dev/nfs ip=bootp" +#define CONFIG_BOOTCOMMAND "bootp;tftp;bootm" +#define CFG_AUTOLOAD "n" /* No autoload */
+#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#define CONFIG_KGDB_BAUDRATE 38400 /* speed to run kgdb serial port */ +#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif
- Miscellaneous configurable options
+#define CFG_LONGHELP /* undef to save memory */ +#define CFG_PROMPT "ADS GCPlus # " /* Monitor Command Prompt */ +#define CFG_CBSIZE 256 /* Console I/O Buffer Size */ +#define CFG_PBSIZE (CFG_CBSIZE+sizeof(CFG_PROMPT)+16) /* Print Buffer Size */ +#define CFG_MAXARGS 16 /* max number of command args */ +#define CFG_BARGSIZE CFG_CBSIZE /* Boot Argument Buffer Size */
+#define CFG_MEMTEST_START 0xc0400000 /* memtest works on */ +#define CFG_MEMTEST_END 0xc0800000 /* 4 ... 8 MB in DRAM */
+#undef CFG_CLKS_IN_HZ /* everything, incl board info, in Hz */
+#define CFG_LOAD_ADDR 0xc0000000 /* default load address */
+#define CFG_HZ 3686400 /* incrementer freq: 3.6864 MHz */ +#define CFG_CPUSPEED 0x0a /* set core clock to 206MHz */
/* valid baudrates */
+#define CFG_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 }
- Stack sizes
- The stack sizes are set up in start.S using the settings below
+#define CONFIG_STACKSIZE (128*1024) /* regular stack */ +#ifdef CONFIG_USE_IRQ +#define CONFIG_STACKSIZE_IRQ (4*1024) /* IRQ stack */ +#define CONFIG_STACKSIZE_FIQ (4*1024) /* FIQ stack */ +#endif
- Physical Memory Map
+#define CONFIG_NR_DRAM_BANKS 2 /* we have 2 banks of DRAM */ +#define PHYS_SDRAM_1 0xc0000000 /* SDRAM Bank #1 */ +#define PHYS_SDRAM_1_SIZE 0x01000000 /* 16 MB */ +#define PHYS_SDRAM_2 0xc8000000 /* SDRAM Bank #2 */ +#define PHYS_SDRAM_2_SIZE 0x01000000 /* 16 MB */
+#define PHYS_FLASH_1 0x08000000 /* Flash Bank #1 */ +#define PHYS_FLASH_SIZE 0x00800000 /* 8 MB */ +#define PHYS_FLASH_BANK_SIZE 0x01000000 /* 16 MB Banks */ +#define PHYS_FLASH_SECT_SIZE 0x00040000 /* 256 KB sectors (x2) */
+#define CFG_FLASH_BASE PHYS_FLASH_1
- FLASH and environment organization
+#if 1 +#define CFG_MAX_FLASH_BANKS 1 /* max number of memory banks */ +#define CFG_MAX_FLASH_SECT 128 /* max number of sectors on one chip */
+/* timeout values are in ticks */ +#define CFG_FLASH_ERASE_TOUT (2*CFG_HZ) /* Timeout for Flash Erase */ +#define CFG_FLASH_WRITE_TOUT (2*CFG_HZ) /* Timeout for Flash Write */ +#else +/* REVISIT: This doesn't work on ADS GCPlus just yet: +#define CFG_FLASH_CFI 1 /* flash is CFI conformant */ +#define CFG_FLASH_CFI_DRIVER 1 /* use common cfi driver */ +#define CFG_FLASH_USE_BUFFER_WRITE 1 /* use buffered writes (20x faster) */ +#define CFG_MAX_FLASH_BANKS 1 /* max # of memory banks */ +#define CFG_FLASH_INCREMENT 0 /* there is only one bank */ +#define CFG_MAX_FLASH_SECT 128 /* max # of sectors on one chip */ +//#define CFG_FLASH_PROTECTION 1 /* hardware flash protection */ +#define CFG_FLASH_BANKS_LIST { CFG_FLASH_BASE } +#endif
+#define CFG_ENV_IS_IN_FLASH 1 +#define CFG_ENV_ADDR (PHYS_FLASH_1 + PHYS_FLASH_SECT_SIZE) /* Addr of Environment Sector */ +#define CFG_ENV_SIZE PHYS_FLASH_SECT_SIZE
+#endif /* __CONFIG_H */ diff -x CVS -ruN u-boot.orig/Makefile u-boot.new/Makefile --- u-boot.orig/Makefile 2004-03-11 14:00:20.000000000 -0500 +++ u-boot.new/Makefile 2004-03-09 23:16:52.000000000 -0500 @@ -912,6 +912,9 @@ shannon_config : unconfig @./mkconfig $(@:_config=) arm sa1100 shannon
+gcplus_config : unconfig
- @./mkconfig $(@:_config=) arm sa1100 gcplus
############################################################## ########### ## ARM92xT Systems
This SF.Net email is sponsored by: IBM Linux Tutorials Free Linux tutorial presented by Daniel Robbins, President and CEO of GenToo technologies. Learn everything from fundamentals to system administration.http://ads.osdn.com/?ad_id=1470&alloc_id=3638&op=click _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
Kerl, John
