[PATCH 0/4] Minor fixes for MediaTek pinctrl driver
This patch series provides fixes for MediaTek pinctrl driver common parts and mt7629.
Sam Shih (2): pinctrl: mediatek: fix wrong assignment in mtk_get_pin_name pinctrl: mediatek: add get_pin_muxing ops for mediatek pinctrl
Weijie Gao (2): pinctrl: mediatek: do not probe gpio driver if not enabled pinctrl: mt7629: add jtag function and pin group
drivers/pinctrl/mediatek/pinctrl-mt7629.c | 7 +++++ drivers/pinctrl/mediatek/pinctrl-mtk-common.c | 28 +++++++++++++++---- 2 files changed, 30 insertions(+), 5 deletions(-)
This is a bug fix for mtk pinctrl common part. Appearently pins should be used instead of grps in mtk_get_pin_name().
Signed-off-by: Sam Shih sam.shih@mediatek.com --- drivers/pinctrl/mediatek/pinctrl-mtk-common.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/pinctrl/mediatek/pinctrl-mtk-common.c b/drivers/pinctrl/mediatek/pinctrl-mtk-common.c index 4dd3f73ead..b700dd98bf 100644 --- a/drivers/pinctrl/mediatek/pinctrl-mtk-common.c +++ b/drivers/pinctrl/mediatek/pinctrl-mtk-common.c @@ -219,7 +219,7 @@ static const char *mtk_get_pin_name(struct udevice *dev, { struct mtk_pinctrl_priv *priv = dev_get_priv(dev);
- if (!priv->soc->grps[selector].name) + if (!priv->soc->pins[selector].name) return mtk_pinctrl_dummy_name;
return priv->soc->pins[selector].name;
This patch add get_pin_muxing support for mediatek pinctrl drivers
Signed-off-by: Sam Shih sam.shih@mediatek.com --- drivers/pinctrl/mediatek/pinctrl-mtk-common.c | 14 ++++++++++++++ 1 file changed, 14 insertions(+)
diff --git a/drivers/pinctrl/mediatek/pinctrl-mtk-common.c b/drivers/pinctrl/mediatek/pinctrl-mtk-common.c index b700dd98bf..b2212c2559 100644 --- a/drivers/pinctrl/mediatek/pinctrl-mtk-common.c +++ b/drivers/pinctrl/mediatek/pinctrl-mtk-common.c @@ -232,6 +232,19 @@ static int mtk_get_pins_count(struct udevice *dev) return priv->soc->npins; }
+static int mtk_get_pin_muxing(struct udevice *dev, unsigned int selector, + char *buf, int size) +{ + int val, err; + + err = mtk_hw_get_value(dev, selector, PINCTRL_PIN_REG_MODE, &val); + if (err) + return err; + + snprintf(buf, size, "Aux Func.%d", val); + return 0; +} + static const char *mtk_get_group_name(struct udevice *dev, unsigned int selector) { @@ -512,6 +525,7 @@ static int mtk_pinconf_group_set(struct udevice *dev, const struct pinctrl_ops mtk_pinctrl_ops = { .get_pins_count = mtk_get_pins_count, .get_pin_name = mtk_get_pin_name, + .get_pin_muxing = mtk_get_pin_muxing, .get_groups_count = mtk_get_groups_count, .get_group_name = mtk_get_group_name, .get_functions_count = mtk_get_functions_count,
The mtk pinctrl driver is a combination driver with support for both pinctrl and gpio. When this driver is used in SPL, gpio support may not be enabled, and this will result in a compilation error.
To fix this, macros are added to make sure gpio related code will only be compiled when gpio support is enabled.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- drivers/pinctrl/mediatek/pinctrl-mtk-common.c | 12 ++++++++---- 1 file changed, 8 insertions(+), 4 deletions(-)
diff --git a/drivers/pinctrl/mediatek/pinctrl-mtk-common.c b/drivers/pinctrl/mediatek/pinctrl-mtk-common.c index b2212c2559..264c6458c9 100644 --- a/drivers/pinctrl/mediatek/pinctrl-mtk-common.c +++ b/drivers/pinctrl/mediatek/pinctrl-mtk-common.c @@ -540,6 +540,8 @@ const struct pinctrl_ops mtk_pinctrl_ops = { .set_state = pinctrl_generic_set_state, };
+#if CONFIG_IS_ENABLED(DM_GPIO) || \ + (defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_GPIO_SUPPORT)) static int mtk_gpio_get(struct udevice *dev, unsigned int off) { int val, err; @@ -647,12 +649,13 @@ static int mtk_gpiochip_register(struct udevice *parent)
return 0; } +#endif
int mtk_pinctrl_common_probe(struct udevice *dev, struct mtk_pinctrl_soc *soc) { struct mtk_pinctrl_priv *priv = dev_get_priv(dev); - int ret; + int ret = 0;
priv->base = dev_read_addr_ptr(dev); if (!priv->base) @@ -660,9 +663,10 @@ int mtk_pinctrl_common_probe(struct udevice *dev,
priv->soc = soc;
+#if CONFIG_IS_ENABLED(DM_GPIO) || \ + (defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_GPIO_SUPPORT)) ret = mtk_gpiochip_register(dev); - if (ret) - return ret; +#endif
- return 0; + return ret; }
The EPHY LEDs of mt7629 can be used as JTAG. This patch adds the jtag pin group to the pinctrl driver.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- drivers/pinctrl/mediatek/pinctrl-mt7629.c | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/drivers/pinctrl/mediatek/pinctrl-mt7629.c b/drivers/pinctrl/mediatek/pinctrl-mt7629.c index 7ce64fde25..5d4bec2234 100644 --- a/drivers/pinctrl/mediatek/pinctrl-mt7629.c +++ b/drivers/pinctrl/mediatek/pinctrl-mt7629.c @@ -201,6 +201,10 @@ static int mt7629_wf2g_led_funcs[] = { 1, }; static int mt7629_wf5g_led_pins[] = { 18, }; static int mt7629_wf5g_led_funcs[] = { 1, };
+/* LED for EPHY used as JTAG */ +static int mt7629_ephy_leds_jtag_pins[] = { 12, 13, 14, 15, 16, }; +static int mt7629_ephy_leds_jtag_funcs[] = { 7, 7, 7, 7, 7, }; + /* Watchdog */ static int mt7629_watchdog_pins[] = { 11, }; static int mt7629_watchdog_funcs[] = { 1, }; @@ -297,6 +301,7 @@ static const struct mtk_group_desc mt7629_groups[] = { PINCTRL_PIN_GROUP("ephy_led2", mt7629_ephy_led2), PINCTRL_PIN_GROUP("ephy_led3", mt7629_ephy_led3), PINCTRL_PIN_GROUP("ephy_led4", mt7629_ephy_led4), + PINCTRL_PIN_GROUP("ephy_leds_jtag", mt7629_ephy_leds_jtag), PINCTRL_PIN_GROUP("wf2g_led", mt7629_wf2g_led), PINCTRL_PIN_GROUP("wf5g_led", mt7629_wf5g_led), PINCTRL_PIN_GROUP("watchdog", mt7629_watchdog), @@ -364,6 +369,7 @@ static const char *const mt7629_uart_groups[] = { "uart1_0_txd_rxd", static const char *const mt7629_wdt_groups[] = { "watchdog", }; static const char *const mt7629_wifi_groups[] = { "wf0_5g", "wf0_2g", }; static const char *const mt7629_flash_groups[] = { "snfi", "spi_nor" }; +static const char *const mt7629_jtag_groups[] = { "ephy_leds_jtag" };
static const struct mtk_function_desc mt7629_functions[] = { {"eth", mt7629_ethernet_groups, ARRAY_SIZE(mt7629_ethernet_groups)}, @@ -376,6 +382,7 @@ static const struct mtk_function_desc mt7629_functions[] = { {"watchdog", mt7629_wdt_groups, ARRAY_SIZE(mt7629_wdt_groups)}, {"wifi", mt7629_wifi_groups, ARRAY_SIZE(mt7629_wifi_groups)}, {"flash", mt7629_flash_groups, ARRAY_SIZE(mt7629_flash_groups)}, + {"jtag", mt7629_jtag_groups, ARRAY_SIZE(mt7629_jtag_groups)}, };
static struct mtk_pinctrl_soc mt7629_data = {
Weijie Gao
