[U-Boot] [PATCH v2 14/18] at91: mtd: nand: Add dev_warn() to correct build error in driver
The code does not compile if ECC is enabled.
Signed-off-by: Andre Renaud andre@designa-electronics.com Signed-off-by: Simon Glass sjg@chromium.org ---
Changes in v2: None
drivers/mtd/nand/atmel_nand.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/mtd/nand/atmel_nand.c b/drivers/mtd/nand/atmel_nand.c index 8fac824..15958cb 100644 --- a/drivers/mtd/nand/atmel_nand.c +++ b/drivers/mtd/nand/atmel_nand.c @@ -20,6 +20,8 @@ #include <watchdog.h> #include <linux/mtd/nand_ecc.h>
+#define dev_warn(dev, msg...) + #ifdef CONFIG_ATMEL_NAND_HWECC
/* Register access macros */
Changes in v2: None
This should go in include/linux/compat.h with the others.
-Scott
Scott Wood
