[U-Boot] [PATCH v2] am335x: add initial AM335x IDK board support
This patch extends the am335x_evm board for the AM335x IDK.
The IDK board uses MII for the ethernet phy (same as Beaglebone board) and MMC0 for storage (but without card detect line).
The IDK uses UART3 for console. So u-boot must be build with CONFIG_SERIAL4 and CONFIG_CONS_INDEX=4 or for the am335x_evm_uart3 board configuration as introduced by Andrew Bradfords recent patch series "am33xx: Enable UART {1,2,3,4,5}...". When using the IDK with console on UART0, those patches are not required. In this case the board slightly needs to be modified.
Signed-off-by: Matthias Fuchs matthias.fuchs@esd.eu --- Changes in v2: - rebased because board.c had been moved
board/ti/am335x/board.c | 7 ++++++- board/ti/am335x/mux.c | 20 ++++++++++++++++++++ 2 files changed, 26 insertions(+), 1 deletions(-)
diff --git a/board/ti/am335x/board.c b/board/ti/am335x/board.c index 5d279ec..b1d9959 100644 --- a/board/ti/am335x/board.c +++ b/board/ti/am335x/board.c @@ -68,6 +68,11 @@ static inline int board_is_evm_sk(void) return !strncmp("A335X_SK", header.name, HDR_NAME_LEN); }
+static inline int board_is_idk(void) +{ + return !strncmp(header.config, "SKU#02", 6); +} + /* * Read header information from EEPROM into global structure. */ @@ -361,7 +366,7 @@ int board_eth_init(bd_t *bis) return -1; }
- if (board_is_bone() || board_is_bone_lt()) { + if (board_is_bone() || board_is_bone_lt() || board_is_idk()) { writel(MII_MODE_ENABLE, &cdev->miisel); cpsw_slaves[0].phy_if = cpsw_slaves[1].phy_if = PHY_INTERFACE_MODE_MII; diff --git a/board/ti/am335x/mux.c b/board/ti/am335x/mux.c index 2992979..cc0db7a 100644 --- a/board/ti/am335x/mux.c +++ b/board/ti/am335x/mux.c @@ -39,6 +39,17 @@ static struct module_pin_mux mmc0_pin_mux[] = { {-1}, };
+static struct module_pin_mux mmc0_no_cd_pin_mux[] = { + {OFFSET(mmc0_dat3), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_DAT3 */ + {OFFSET(mmc0_dat2), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_DAT2 */ + {OFFSET(mmc0_dat1), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_DAT1 */ + {OFFSET(mmc0_dat0), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_DAT0 */ + {OFFSET(mmc0_clk), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_CLK */ + {OFFSET(mmc0_cmd), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_CMD */ + {OFFSET(mcasp0_aclkr), (MODE(4) | RXACTIVE)}, /* MMC0_WP */ + {-1}, +}; + static struct module_pin_mux mmc0_pin_mux_sk_evm[] = { {OFFSET(mmc0_dat3), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_DAT3 */ {OFFSET(mmc0_dat2), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_DAT2 */ @@ -196,6 +207,15 @@ void enable_board_pin_mux(struct am335x_baseboard_id *header) configure_module_pin_mux(mmc1_pin_mux); configure_module_pin_mux(spi0_pin_mux); } + } else if (!strncmp(header->config, "SKU#02", 6)) { + /* + * Industrial Motor Control (IDK) + * note: IDK console is on UART3 by default. + * So u-boot mus be build with CONFIG_SERIAL4 and + * CONFIG_CONS_INDEX=4 + */ + configure_module_pin_mux(mii1_pin_mux); + configure_module_pin_mux(mmc0_no_cd_pin_mux); } else if (!strncmp(header->name, "A335X_SK", HDR_NAME_LEN)) { /* Starter Kit EVM */ configure_module_pin_mux(i2c1_pin_mux);
Changes in v2:
Applied to u-boot-ti/master, thanks!
Matthias Fuchs
