[PATCH] cmd: tlv_eeprom: fix signature for populate_serial_number function
populate_serial_number is not used internally for the tlv_eeprom command, but rather provided as a library function for external use.. Remove the devnum that had recently been added by mistake, returning the function to its original signature.
Instead place a 0-initialised member variable inside the function to same purpose, along with a node that it only supports reading from the first EEPROM in the system.
Fixes: dfda0c0 ("cmd: tlv_eeprom: remove use of global variable current_dev") Signed-off-by: Josua Mayer josua@solid-run.com Cc: Stefan Roese sr@denx.de Cc: Baruch Siach baruch@tkos.co.il Cc: Heinrich Schuchardt xypron.glpk@gmx.de --- cmd/tlv_eeprom.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/cmd/tlv_eeprom.c b/cmd/tlv_eeprom.c index 79796394c5c..0ca4d714645 100644 --- a/cmd/tlv_eeprom.c +++ b/cmd/tlv_eeprom.c @@ -1100,11 +1100,12 @@ int mac_read_from_eeprom(void) * * This function must be called after relocation. */ -int populate_serial_number(int devnum) +int populate_serial_number(void) { char serialstr[257]; int eeprom_index; struct tlvinfo_tlv *eeprom_tlv; + int devnum = 0; // TODO: support multiple EEPROMs
if (env_get("serial#")) return 0;
%s/node/note/
- This function must be called after relocation.
If populate_serial_number() is to be used as a library function, it should live in lib/ or possibly in drivers/misc/. The definition needs to be provided in an include file. Otherwise the function should be deleted.
Where will this library function be used?
Shouldn't the EEPROM with the serial number be identified via the device-tree?
Best regards
Heinrich
Hi Heinrich,
Am 16.05.23 um 14:21 schrieb Heinrich Schuchardt:
%s/node/note/
Good find!
I don't know for sure. GitHub search finds its use in board files on some old ONIE u-boot forks.
Main purpose of this patch right now is to undo my accidental change and restore the default behaviour: The previous instance of devnum variable inside tlv_eeprom.c would have had value 0 by default.
Something like that would be nice. However we also want to use identical device-tree between Linux and U-Boot. I am not sure if we have such indication.
Best regards
Heinrich
- Josua Mayer
On 5/16/23 13:49, Josua Mayer wrote:
Hi Heinrich,
%s/node/note/
Good find!
The right places to call the function might be board/solidrun/clearfog/clearfog.c and board/kobol/helios4/helios4.c as these platforms enable CMD_TLV_EEPROM. But I have no such board.
The function has remained unused in upstream U-Boot since 2020. If we do not plan to use it, it should be removed.
Stefan and Dennis, what are your thoughts?
Best regards
Heinrich
Best regards
Heinrich
- Josua Mayer
Josua Mayer
