[U-Boot] [PATCH 1/2 v1] sf: probe: Add support Atmel AT45DB series devices special commands
Atmel AT45DB series devices commands is different from common spi flash commands. This patch add support for AT45DB special commands. Add a flag AT45DB_CMD to control whether use those commands.
Signed-off-by: Haikun Wang Haikun.Wang@freescale.com ---
Changes in v1: None
drivers/mtd/spi/sf_internal.h | 7 +++++++ drivers/mtd/spi/sf_ops.c | 2 +- drivers/mtd/spi/sf_probe.c | 10 ++++++++++ 3 files changed, 18 insertions(+), 1 deletion(-)
diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index 785f7a9..234af21 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -43,6 +43,7 @@ enum { SST_BP = 1 << 3, SST_WP = 1 << 4, WR_QPP = 1 << 5, + AT45DB_CMD = 1 << 6, };
#define SST_WR (SST_BP | SST_WP) @@ -106,6 +107,12 @@ enum { #define SPI_FLASH_PAGE_ERASE_TIMEOUT (5 * CONFIG_SYS_HZ) #define SPI_FLASH_SECTOR_ERASE_TIMEOUT (10 * CONFIG_SYS_HZ)
+/* Atmel AT45DB specific */ +#define CMD_ATMEL_PAGE_PROGRAM 0x82 +#define CMD_ATMEL_READ_STATUS 0xd7 +#define CMD_ATMEL_FLAG_STATUS 0xd7 +#define CMD_ATMEL_BLK_ERASE 0x50 + /* SST specific */ #ifdef CONFIG_SPI_FLASH_SST # define CMD_SST_BP 0x02 /* Byte Program */ diff --git a/drivers/mtd/spi/sf_ops.c b/drivers/mtd/spi/sf_ops.c index 34bc54e..27ce5f9 100644 --- a/drivers/mtd/spi/sf_ops.c +++ b/drivers/mtd/spi/sf_ops.c @@ -165,7 +165,7 @@ int spi_flash_cmd_wait_ready(struct spi_flash *flash, unsigned long timeout) u8 poll_bit = STATUS_WIP; u8 cmd = flash->poll_cmd;
- if (cmd == CMD_FLAG_STATUS) { + if (cmd == CMD_FLAG_STATUS || cmd == CMD_ATMEL_FLAG_STATUS) { poll_bit = STATUS_PEC; check_status = poll_bit; } diff --git a/drivers/mtd/spi/sf_probe.c b/drivers/mtd/spi/sf_probe.c index 4103723..2ccddf2 100644 --- a/drivers/mtd/spi/sf_probe.c +++ b/drivers/mtd/spi/sf_probe.c @@ -226,6 +226,16 @@ static int spi_flash_validate_params(struct spi_slave *spi, u8 *idcode, flash->poll_cmd = CMD_FLAG_STATUS; #endif
+#ifdef CONFIG_SPI_FLASH_ATMEL + if (params->flags & AT45DB_CMD) { + flash->poll_cmd = CMD_ATMEL_READ_STATUS; + flash->write_cmd = CMD_ATMEL_PAGE_PROGRAM; + /* use block-erase command, eight pages */ + flash->erase_cmd = CMD_ATMEL_BLK_ERASE; + flash->erase_size = flash->page_size * 8; + } +#endif + /* Configure the BAR - discover bank cmds and read current bank */ #ifdef CONFIG_SPI_FLASH_BAR u8 curr_bank = 0;
Hi Haikun,
Changes in v1: None
Why not use 0x2 to align with current mtd/spi framework?
- /* SST specific */ #ifdef CONFIG_SPI_FLASH_SST # define CMD_SST_BP 0x02 /* Byte Program */
- if (cmd == CMD_FLAG_STATUS || cmd == CMD_ATMEL_FLAG_STATUS) { poll_bit = STATUS_PEC; check_status = poll_bit; }
- if (params->flags & AT45DB_CMD) {
The SPI Flash's default page size is 264 bytes, but mtd/spi framework supports 256 and 512 bytes for one page. In your patch, you does not handle such case, can your driver works as expected?
Regards, Peng.
On 3/25/2015 10:10 PM, Fan Peng-B51431 wrote:
Hi Haikun,
Changes in v1: None
I didn't find the program command '0x2' in AT45DB021D datasheet. Do you ever use it in AT45DBxxxx flash chip?
Fine, I know mtd/spi framework doesn't support page-size of 264bytes. In fact we change the chip's page-size to 256bytes before using it. It is a big work to adjust the framework support 264bytes. So how about add a check here, if the chip has a page-size of 264bytes, we just return an error. Or I will add a AT45DB special flash driver under Driver Model.
Hi Haikun,
Hi Haikun,
Changes in v1: None
My fault. 0x2h is supported by AT45DB021E, but not AT45DB021D. You can use 0x82.
I used a similar chip AT45DB021E, not AT45DB021D. And I have a local patch for this chip.
If others use a same chip, he/she has no idea about this.
No big work, just send a configuration command to the chip.
This AT45XXD chip's page size can only be configured once. you can check the status register, BIT 0's meaning is PAGE SIZE is 256 or 264. If the page size is 264, you can configure the chip to 256 seeing "11.1 Programming the Configuration Register". If the page size is already 256, no need to configure it again. You can added related function in sf_ops.c and invoke this function in sf_probe.c when probe. you can take the following piece of code as a reference as you like, it works for AT45DB021E. About read status, I suppose you can use the FLAG_STATUS to get the correct value.
#if defined(CONFIG_SPI_FLASH_ATMEL) /* * For the AT45DB021E, there are an extra eight bytes * of memory in each page for a total of an extra 8KB * (64-Kbits) of user-accessible memory. * In order to be compatible with spi framework, we use 256bytes. */
int spi_flash_cmd_write_config(struct spi_flash *flash, u8 wc) { u8 data[3]; u8 cmd; int ret;
ret = spi_flash_cmd_read_status(flash, &data[0]); if (ret < 0) return ret;
/* * PAGE SIZE Page Size, bit 0. * 0 Device is configured for standard DataFlash page size (264 bytes). * 1 Device is configured for “power of 2” binary page size (256 bytes). */ if (wc == SPI_FLASH_PAGE_256) { /* Already 256? */ if (data[0] & 1) return 0; } else if (wc == SPI_FLASH_PAGE_264) { /* Already 264? */ if ((data[0] & 1) == 0) return 0; } else { debug("Unsupport page configuration!\n"); return -1; }
/* * 3D, 2A, 80, A6 command seq will configure flash page size 256. * 3D, 2A, 80, A7 command seq will configure flash page size 264. */ cmd = 0x3D; if (wc == SPI_FLASH_PAGE_256) data[2] = 0xA6; else if (wc == SPI_FLASH_PAGE_264) data[2] = 0xA7; data[1] = 0x80; data[0] = 0x2A; ret = spi_flash_write_common(flash, &cmd, 1, data, 3); if (ret) { debug("SF: fail to write config register\n"); return ret; }
/* Check again the page size*/ xxxxxxxxxxxxxxxxxx
return 0; } #endif
Regards, Peng.
On 3/26/2015 11:05 AM, Fan Peng-B51431 wrote:
Hi Haikun,
Hi Haikun,
Changes in v1: None
Does AT45DB021E support '0x82'?
I am not true whether others approve this. As you said chips only can be configured once and it is irreversible. At least we should let user choice configure or not.
Best regards, Wang Haikun
- For the AT45DB021E, there are an extra eight bytes
- of memory in each page for a total of an extra 8KB
- (64-Kbits) of user-accessible memory.
- In order to be compatible with spi framework, we use 256bytes.
ret = spi_flash_cmd_read_status(flash, &data[0]); if (ret < 0) return ret; /* * PAGE SIZE Page Size, bit 0. * 0 Device is configured for standard DataFlash page size (264 bytes). * 1 Device is configured for “power of 2” binary page size (256
/* * 3D, 2A, 80, A6 command seq will configure flash page size 256. * 3D, 2A, 80, A7 command seq will configure flash page size 264. */ cmd = 0x3D; if (wc == SPI_FLASH_PAGE_256) data[2] = 0xA6; else if (wc == SPI_FLASH_PAGE_264) data[2] = 0xA7; data[1] = 0x80; data[0] = 0x2A; ret = spi_flash_write_common(flash, &cmd, 1, data, 3); if (ret) { debug("SF: fail to write config register\n"); return ret; } /* Check again the page size*/ xxxxxxxxxxxxxxxxxx return 0;
} #endif
Regards, Peng.
Hi Haikun,
Hi Haikun,
Changes in v1: None
Yeah. 0x82h "Main Memory Page Program through Buffer with Built-In Erase"
Hmm.. then you can add the checking page size stuff there as you like.
} #endif
Regards, Peng.
Regards, Peng.
Haikun Wang
Peng Fan
